    4. Zigbee Probleme mit tradfri und eine Frage zum Adapter
      arteck Developer Most Active @Stefan_NK last edited by arteck
      @stefan_nk doch hat es..
      einz nach dem anderen ..
      der adapter knallt nicht mehr..
      der configure ist jetzt das problem...
      geht den die andere Birne ??? kannst du die steuern ??
        Stefan_NK @arteck last edited by
        @arteck Bei der zweiten Lampe bekomme ich den gleichen Fehler
        2023-11-15 08:17:04.234 - info: admin.0 (1049) ==> Connected system.user.admin from ::ffff:192.168.179.35
        2023-11-15 08:17:04.630 - info: zigbee.0 (157474) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyACM0","manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2469688","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469688-if00","vendorId":"1cf1","productId":"0030"},{"path":"/dev/ttyAMA0"}]
        2023-11-15 08:17:13.631 - info: zigbee.0 (157474) Zigbee: allowing new devices to join.
        2023-11-15 08:17:38.001 - info: zigbee.0 (157474) Starting interview of '0xb43522fffe9b547b'
        2023-11-15 08:17:38.046 - info: zigbee.0 (157474) Device '0xb43522fffe9b547b' announced itself
        2023-11-15 08:17:39.775 - info: zigbee.0 (157474) Successfully interviewed '0xb43522fffe9b547b', device has successfully been paired
        2023-11-15 08:17:39.775 - info: zigbee.0 (157474) Device '0xb43522fffe9b547b' is supported, identified as: IKEA TRADFRI LED bulb E27 1055 lumen, dimmable, white spectrum (LED2201G8)
        2023-11-15 08:17:39.777 - info: zigbee.0 (157474) Configuring 0xb43522fffe9b547b TRADFRI bulb E27 WS globe 1055lm
        2023-11-15 08:17:39.787 - error: zigbee.0 (157474) DeviceConfigure:Failed to DeviceConfigure.configure 0xb43522fffe9b547b TRADFRI bulb E27 WS globe 1055lm (TypeError: Cannot read properties of undefined (reading 'configure')
        at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:136:37)
        at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:113:21))
        2023-11-15 08:18:14.900 - info: zigbee.0 (157474) Zigbee: stop joining
        2023-11-15 08:18:28.317 - info: admin.0 (1049) <== Disconnect system.user.admin from ::ffff:192.168.179.35
        Ich habe schon länger eine LED1836G9 eingebunden, die funktioniert einwandfrei.
          @stefan_nk installiere mal die GIT version ..jetzt
          nochmal.. es ist egal ob die Birne gleich aussieht oder die gleiche Bezeichnung auf der Verpakung steht..
          wenn die Birne sich anders meldet dann hat Ikea die interne Modellnummer geändert..
            @arteck
            Super 👍 👍 Vielen, vielen Dank. Wirklich spitze, dass das jetzt doch so schnell geklappt hat. Bist ein Wahnsinn.
            Beide Lampen konnten gepairt werden. Die E14 hat zwar kein Symbol, aber das it ja egal. Beide lassen sich steuern.
            Soll ich bei der nächsten offiziellen Version von der Github Installation wieder weg? Wie kann ich dann zurück zur "normalen" Version?
            Thomas Braun arteck 2 Replies Last reply Reply Quote 0
              Thomas Braun Most Active @Stefan_NK last edited by Thomas Braun
              @stefan_nk sagte in Zigbee Probleme mit tradfri und eine Frage zum Adapter:
              Einfach weiter Updates wie gewohnt einspielen, wenn Sie angeboten werden.
              Eine 1.8.25 kommt dann darüber rein.
                @stefan_nk erstmal so lassen.. ausser du brauchst was . sonst sind die Änderungen im /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js weg
                da muss ich noch jemanden überzeugen das da ein Bug ist
                  @arteck Einmal bin ich es noch... Es scheint dank Euch alles zu funktionieren. Die Steuerung über VIS und Blockly funktioniert wie geplant.
                  Im LOG bekomme ich immer einen info-Eintrag. Etwa alle 5 Minuten, aber nur über die beiden Lampen. Die anderen Zigbee Geräte machen das nicht. Nur... falls es wichtig wäre....
                  2023-11-15 18:31:52.238 - info: zigbee.0 (247012) Configuring 0xb43522fffe6a89e6 TRADFRI bulb E14 WS candle 470lm
                  2023-11-15 18:31:52.757 - info: zigbee.0 (247012) Configuring 0xb43522fffe9b547b TRADFRI bulb E27 WS globe 1055lm
                  2023-11-15 18:36:52.343 - info: zigbee.0 (247012) Configuring 0xb43522fffe6a89e6 TRADFRI bulb E14 WS candle 470lm
                  2023-11-15 18:36:52.864 - info: zigbee.0 (247012) Configuring 0xb43522fffe9b547b TRADFRI bulb E27 WS globe 1055lm
                  2023-11-15 18:41:52.454 - info: zigbee.0 (247012) Configuring 0xb43522fffe6a89e6 TRADFRI bulb E14 WS candle 470lm
                  2023-11-15 18:41:52.975 - info: zigbee.0 (247012) Configuring 0xb43522fffe9b547b TRADFRI bulb E27 WS globe 1055lm
                  2023-11-15 18:46:52.566 - info: zigbee.0 (247012) Configuring 0xb43522fffe6a89e6 TRADFRI bulb E14 WS candle 470lm
                  2023-11-15 18:46:53.082 - info: zigbee.0 (247012) Configuring 0xb43522fffe9b547b TRADFRI bulb E27 WS globe 1055lm
                  2023-11-15 18:51:52.680 - info: zigbee.0 (247012) Configuring 0xb43522fffe6a89e6 TRADFRI bulb E14 WS candle 470lm
                  2023-11-15 18:51:53.185 - info: zigbee.0 (247012) Configuring 0xb43522fffe9b547b TRADFRI bulb E27 WS globe 1055lm
                  2023-11-15 18:56:52.787 - info: zigbee.0 (247012) Configuring 0xb43522fffe6a89e6 TRADFRI bulb E14 WS candle 470lm
                  2023-11-15 18:56:53.296 - info: zigbee.0 (247012) Configuring 0xb43522fffe9b547b TRADFRI bulb E27 WS globe 1055lm
                    TomComm27 last edited by
                    ich habe gerade viel ausprobiert mit Externe Konverter und Co aber es funktioniert einfach nicht dass das Gerät richtig erkannt wird!
                    Ich verwende den zigbee2mqtt Adapter deswegen bin ich mir nicht sicher ob ich es genauso machen muss/kann mit der Github version? Und wenn ja wie geht das?😨
                    Hier meine Infos:
                    /opt/zigbee2mqtt/data/configuration.yaml
                    homeassistant: false
                    permit_join: true
                    frontend:
                      port: 80xx
                      host: 192.xxx.xxx.xxx
                    mqtt:
                      base_topic: zigbee2mqtt
                      server: mqtt://192.xxx.xxx.xxx:xxxx
                      user: xxx
                      password: xxxxxxxxxxx
                      keepalive: 60
                      reject_unauthorized: true
                      version: 4
                      client_id:
                    serial:
                      port: /dev/ttyACM0
                    advanced:
                      pan_id: 10328
                      ext_pan_id:
                        - 221
                        - xxx
                        - xxx
                        - xxx
                        - xxx
                        - xxx
                        - xxx
                        - xxx
                      channel: 11
                      network_key:
                        - 38
                        - 73
                        - 42
                        - 108
                        - 105
                        - 179
                        - 130
                        - 245
                        - xxx
                        - xx
                        - xxx
                        - xx
                        - xxx
                        - xxx
                        - xxx
                        - xxx
                      last_seen: ISO_8601_local
                      legacy_api: false
                      legacy_availability_payload: false
                      homeassistant_legacy_entity_attributes: false
                      cache_state: false
                      output: json
                      log_level: info
                    device_options:
                      legacy: false
                    availability: true
                    devices: devices.yaml
                    Hier die Log Meldung:
                    2023-11-29 14:12:40Zigbee: allowing new devices to join.
                    Info 2023-11-29 14:12:42MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"udfh5-8"}'
                    Info 2023-11-29 14:13:10Device '0xb43522fffe814999' joined
                    Info 2023-11-29 14:13:10MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xb43522fffe814999","ieee_address":"0xb43522fffe814999"},"type":"device_joined"}'
                    Info 2023-11-29 14:13:10MQTT publish: topic 'zigbee2mqtt/0xb43522fffe814999', payload '{"last_seen":"2023-11-29T14:13:09+01:00"}'
                    Info 2023-11-29 14:13:10Starting interview of '0xb43522fffe814999'
                    Info 2023-11-29 14:13:10MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xb43522fffe814999","ieee_address":"0xb43522fffe814999","status":"started"},"type":"device_interview"}'
                    Info 2023-11-29 14:13:10MQTT publish: topic 'zigbee2mqtt/0xb43522fffe814999', payload '{"last_seen":"2023-11-29T14:13:10+01:00","linkquality":255}'
                    Info 2023-11-29 14:13:11MQTT publish: topic 'zigbee2mqtt/0xb43522fffe814999', payload '{"last_seen":"2023-11-29T14:13:10+01:00","linkquality":255}'
                    Info 2023-11-29 14:13:11MQTT publish: topic 'zigbee2mqtt/0xb43522fffe814999', payload '{"last_seen":"2023-11-29T14:13:11+01:00","linkquality":255}'
                    Info 2023-11-29 14:13:11Successfully interviewed '0xb43522fffe814999', device has successfully been paired
                    Warning 2023-11-29 14:13:11Device '0xb43522fffe814999' with Zigbee model 'TRADFRI bulb E14 WS candle 470lm' and manufacturer name 'IKEA of Sweden' is NOT supported, please follow https://www.zigbee2mqtt.io/advanced/support-new-devices/01_support_new_devices.html
                    Info 2023-11-29 14:13:11MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":null,"friendly_name":"0xb43522fffe814999","ieee_address":"0xb43522fffe814999","status":"successful","supported":false},"type":"device_interview"}'
                    Warning 2023-11-29 14:13:35Received message from unsupported device with Zigbee model 'TRADFRI bulb E14 WS candle 470lm' and manufacturer name 'IKEA of Sweden'
                    Warning 2023-11-29 14:13:35Please see: https://www.zigbee2mqtt.io/advanced/support-new-devices/01_support_new_devices.html
                    Info 2023-11-29 14:13:35MQTT publish: topic 'zigbee2mqtt/0xb43522fffe814999', payload '{"last_seen":"2023-11-29T14:13:34+01:00","linkquality":255}'
                    Warning 2023-11-29 14:13:38Received message from unsupported device with Zigbee model 'TRADFRI bulb E14 WS candle 470lm' and manufacturer name 'IKEA of Sweden'
                    Warning 2023-11-29 14:13:38Please see: https://www.zigbee2mqtt.io/advanced/support-new-devices/01_support_new_devices.html
                    Info 2023-11-29 14:13:38MQTT publish: topic 'zigbee2mqtt/0xb43522fffe814999', payload '{"last_seen":"2023-11-29T14:13:37+01:00","linkquality":255}'
                    Warning 2023-11-29 14:13:41Received message from unsupported device with Zigbee model 'TRADFRI bulb E14 WS candle 470lm' and manufacturer name 'IKEA of Sweden'
                    Warning 2023-11-29 14:13:41Please see: https://www.zigbee2mqtt.io/advanced/support-new-devices/01_support_new_devices.html
                    Info 2023-11-29 14:13:41MQTT publish: topic 'zigbee2mqtt/0xb43522fffe814999', payload '{"last_seen":"2023-11-29T14:13:40+01:00","linkquality":255}'
                    Warning 2023-11-29 14:13:43Received message from unsupported device with Zigbee model 'TRADFRI bulb E14 WS candle 470lm' and manufacturer name 'IKEA of Sweden'
                    Warning 2023-11-29 14:13:44Please see: https://www.zigbee2mqtt.io/advanced/support-new-devices/01_support_new_devices.html
                    Info 2023-11-29 14:13:44MQTT publish: topic 'zigbee2mqtt/0xb43522fffe814999', payload '{"last_seen":"2023-11-29T14:13:43+01:00","linkquality":255}'
                    Warning 2023-11-29 14:13:46Received message from unsupported device with Zigbee model 'TRADFRI bulb E14 WS candle 470lm' and manufacturer name 'IKEA of Sweden'
                    Warning 2023-11-29 14:13:46Please see: https://www.zigbee2mqtt.io/advanced/support-new-devices/01_support_new_devices.html
                    Ich hoffe die Lösung ist genauso easy wie bei Stefan 🙂
                    Fg Tomas
                      arteck Developer Most Active @TomComm27 last edited by arteck
                      @tomcomm27 einfach ist alles wenn man weiss wie es zu machen ist..
                      leider ist im zigbee2mqtt project es eben nicht SO einfach... da musst du auf ne neue Version warten..sonst musst du den branch wechseln.was wiedderum mit Problem her kommt da du dann auf DEV Version bist und diese nicht immer funktioniert..
                      also abwarten
                      @stefan_nk installier mal die GIT version des adapter.. dann sollte die Meldung weg sein
                        TomComm27 @arteck last edited by
                        @arteck danke schon mal für die Info!
                        Das ich es richtig verstehe...falls mein Ikea Licht wirklich die 2107C4 ist und das zigbee2mqtt projekt diese schon auf ihrer Homepage als Unterstütztes Gerät drinnen haben heißt das noch nicht das dies in der derzeit aktuellsten zigbee2mqtt Version schon deinnen ist?🤪
                          @tomcomm27 ja es ist gelistet weil es in DEV unterstützt wird.
                          die 1.34 ist draussen
                            @arteck beim iobroker zigbee2mqtt Adapter hat sich ja die Cersion von 2.13.3 nich geändert🤔
                            Wie bekomme ich die neue Version aktualisiert?
                            Muss ich das im Terminal machen nicht im iobroker?
                            Danke!
                              TomComm27 @TomComm27 last edited by
                              @tomcomm27 hab es schon selber hinbekommen!
                              Im Raspberry im Terminal folgendes ausführen:
                              cd /opt/zigbee2mqtt
                              ./update.sh
                              Lampe wird jetzt komplett erkannt👍
                              3999
