    4. Test Adapter Bosch ebik connect / flow
    • bahnuhr
      bahnuhr Forum Testing Most Active @tombox last edited by
      @tombox
      Danke, super klappt wieder.
        backfisch88 last edited by
        läuft wieder! besten dank!
        • Marco Stieg
          Marco Stieg last edited by
          Hallo zusammen.
          Hat schon jemand die Problematik gelöst, dass die Zeit in Bewegung immer eine Stunde zuviel ausgibt?
            Marcus007 last edited by
            Wird an dem Adapter noch was gemacht?
            Gruss Marcus
              tombox @Marcus007 last edited by
              @marcus007 ja bitte beta channel von iobroker verwenden
              draexler 1 Reply Last reply Reply Quote 0
              • draexler
                draexler @tombox last edited by
                @tombox Seit heute (evtl. auch schon länger) wird der Adapter nicht mehr grün:
                Das ist im LOG:
                	2023-12-01 18:46:34.962	error	instance system.adapter.bosch-ebike.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                host.iobroker
                2023-12-01 18:46:34.962	error	Caught by controller[0]: at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
                host.iobroker
                2023-12-01 18:46:34.962	error	Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                host.iobroker
                2023-12-01 18:46:34.961	error	Caught by controller[0]: at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:41)
                host.iobroker
                2023-12-01 18:46:34.961	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'value')
                host.iobroker
                2023-12-01 18:46:34.960	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                bosch-ebike.0
                2023-12-01 18:46:34.339	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                bosch-ebike.0
                2023-12-01 18:46:34.313	error	Cannot read properties of undefined (reading 'value')
                bosch-ebike.0
                2023-12-01 18:46:34.312	error	TypeError: Cannot read properties of undefined (reading 'value') at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:41) at processTicksAndRejections (node:internal/process/task_queues:95:5) at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
                bosch-ebike.0
                2023-12-01 18:46:34.310	error	unhandled promise rejection: Cannot read properties of undefined (reading 'value')
                bosch-ebike.0
                2023-12-01 18:46:34.308	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                admin.0
                2023-12-01 18:45:36.024	warn	bosch-ebike has an invalid jsonConfig: [{"instancePath":"","schemaPath":"#/required","keyword":"required","params":{"missingProperty":"type"},"message":"must have required property 'type'"}]
                  Thomas Braun Most Active @draexler last edited by
                  @draexler
                  iobroker und nodejs sind auf dem letzten Stand?
                  Auf welchem?
                  iob diag
                  anschauen.
                  • draexler
                    draexler @Thomas Braun last edited by draexler
                    @thomas-braun: Jetzt wo du so schreibst mit der nodejs..
                    Das habe ich heute morgen mit:
                    curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_node_update > iob_node_update
                    chmod 744 iob_node_update
                    /iob_node_update
                    geupdatet und evtl. funktioniert es seit dem nicht mehr.
                    hier das iob diag:
                                            v.2023-10-10
                       Static hostname: iobroker
                             Icon name: computer-vm
                               Chassis: vm
                        Virtualization: kvm
                      Operating System: Debian GNU/Linux 11 (bullseye)
                                Kernel: Linux 5.10.0-26-amd64
                          Architecture: x86-64
                    Installation:           kvm
                    Kernel:                 x86_64
                    Userland:               amd64
                    Timezone:               Europe/Berlin (CET, +0100)
                    User-ID:                1000
                    X-Server:               false
                    Boot Target:            graphical.target
                    Pending OS-Updates:     0
                    Pending iob updates:    0
                    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                            /usr/bin/node           v18.19.0
                                            /usr/bin/npm            10.2.3
                                            /usr/bin/npx            10.2.3
                                            /usr/bin/corepack       0.22.0
                    Recommended versions are nodejs 18.19.0 and npm 10.2.3
                    MEMORY:
                    Mem:            7.9G        4.8G        2.1G        0.0K        1.0G        2.9G
                    Swap:           974M          0B        974M
                    Total:          8.9G        4.8G        3.1G
                    Active iob-Instances:   57
                    Active repo(s): Stable (default)
                    ioBroker Core:          js-controller           5.0.16
                                            admin                   6.12.0
                    Objects type: jsonl
                    States  type: jsonl
                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    Objects:                27161
                    States:                 21499
                    Size of iob-Database:
                    37M     /opt/iobroker/iobroker-data/objects.jsonl
                    35M     /opt/iobroker/iobroker-data/states.jsonl
                      @draexler sagte in Test Adapter Bosch ebik connect / flow:
                      Nee, das passt.
                      Besser aber den stabilen Befehl
                      iob nodejs-update
                      verwenden.
                      • bahnuhr
                        Ich habe auch seit Heute im log:
                        host.iobroker
                        2023-12-02 10:38:18.898	error	instance system.adapter.bosch-ebike.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        host.iobroker
                        2023-12-02 10:38:18.898	error	Caught by controller[1]: at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
                        host.iobroker
                        2023-12-02 10:38:18.898	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                        host.iobroker
                        2023-12-02 10:38:18.898	error	Caught by controller[1]: at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:41)
                        host.iobroker
                        2023-12-02 10:38:18.898	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'value')
                        host.iobroker
                        2023-12-02 10:38:18.898	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                        bosch-ebike.0
                        2023-12-02 10:38:18.322	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                        bosch-ebike.0
                        2023-12-02 10:38:18.321	info	terminating
                        bosch-ebike.0
                        2023-12-02 10:38:18.311	error	Cannot read properties of undefined (reading 'value')
                        bosch-ebike.0
                        2023-12-02 10:38:18.311	error	TypeError: Cannot read properties of undefined (reading 'value') at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:41) at processTicksAndRejections (node:internal/process/task_queues:95:5) at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
                        bosch-ebike.0
                        2023-12-02 10:38:18.307	error	unhandled promise rejection: Cannot read properties of undefined (reading 'value')
                        bosch-ebike.0
                        2023-12-02 10:38:18.307	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        javascript.0
                        2023-12-02 10:38:17.427	info	script.js.Scripte.Licht.Flur2_EG: Licht Flur 2 EG ausgeschaltet.
                        bosch-ebike.0
                        2023-12-02 10:38:17.265	info	Login to eBike flow
                        Keine Veränderung durchgeführt. Und ich bin aktuell.
                        Habe auch gleich ein issue erstellt.
                        https://github.com/TA2k/ioBroker.bosch-ebike/issues/12
                        bahnuhr created this issue in TA2k/ioBroker.bosch-ebike
                        closed iob Fehler im log; Adapter wird nicht grün #12
                        • bahnuhr
                          Habe 0.1.5 installiert.
                          Dann war alles ok.
                            der Adapter funktioniert gut (Flow-App).
                            Toll ist, dass die letzte Fahrt immer 01 ist.
                            Was mache ich falsch, dass der Batteriestatus nicht angezeigt wird?
                            Ein entsprechender Datenpunkt ist ja vorhanden.
                            Viele Grüße
                            Marcus
                            • bahnuhr
                              bahnuhr Forum Testing Most Active @Marcus007 last edited by
                              @marcus007 sagte in Test Adapter Bosch ebik connect / flow:
                              zeig den mal.
                              ich habe bei den Objekten kein DP.
                                Marcus007 @bahnuhr last edited by
                                @bahnuhr
                                Marcus
                                • bahnuhr
                                  @marcus007
                                  Ah, ja doch den hab ich auch.
                                  Steht aber nix drin.
                                    @bahnuhr
                                    Gibts keine Aussicht auf Übernahme des Akkustands?
                                    Marcus
                                    • bahnuhr
                                      @marcus007
                                      Keine Ahnung,
                                      Ich glaube auch nicht, dass dies der Akkustand ist.
                                      Sieht für mich eher aus wie: Verbrauch des Akkus während des trips.
                                      Denn dieser DP gibt es ja bei allen trips.
                                      Aber mach doch mal ein issue auf git auf.
                                        tombox @bahnuhr last edited by
                                        @bahnuhr Ja das ist der Verbrauch pro trip. Wird denn sowas in der app angezeigt? im Debug log sieht man auch immer was direkt von der API kommt
                                        bahnuhr 2 Replies Last reply Reply Quote 0
                                        • bahnuhr
                                          @tombox
                                          Habe gerade mal in die app auf dem Handy unter Statistiken geschaut.
                                          Dort steht bei den trips nichts von Battery.
                                          Aber den DP musst du doch irgendwo her haben. Vielleicht gibt es diesen ja bei dem connect System.
                                          Nur halt nicht bei flow.
                                          • bahnuhr
                                            bahnuhr Forum Testing Most Active @tombox last edited by bahnuhr
                                            @tombox
                                            Aber mal eine andere Frage:
                                            In der app sieht man bei den trips ein kleines Bild (google maps oder unten links steht mapbox).
                                            Könnte man dieses Bild auch einlesen um es dann in vis darstellen zu können.
                                            Unter Details sind jede Menge Infos bzgl. lat und lon. Nur wie macht man daraus ein Bild ?
                                            1.0k
                                            178
                                            32283
