    4. Test Adapter Smart EQ und Hello Smart v0.0.x
      Thomas Braun Most Active @MacMan 0 last edited by
      @macman-0 sagte in Test Adapter Smart EQ und Hello Smart v0.0.x:
      Mach ich nächstes mal sorry
      Mach es jetzt.
        MacMan 0 last edited by MacMan 0
        @thomas-braun said in Test Adapter Smart EQ und Hello Smart v0.0.x:
        iob
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: raspberrypi4
               Icon name: computer
                  Kernel: Linux 6.1.0-rpi6-rpi-v8
            Architecture: arm64
        Model		: Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         16:47:57 up 22 min,  3 users,  load average: 0.87, 0.59, 0.31
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sun 2023-12-03 16:47:57 CET
                   Universal time: Sun 2023-12-03 15:47:57 UTC
                         RTC time: n/a
                        Time zone: Europe/XXXXX (CET, +0100)
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        rasputin
        /home/rasputin
        rasputin adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop: 	LXDE-pi-wayfire
        Terminal: 	wayland
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:            1.9G        736M        585M         53M        765M        1.2G
        Swap:           104M          0B        104M
        Total:          2.0G        736M        690M
                 1848 M total memory
                  702 M used memory
                  839 M active memory
                  293 M inactive memory
                  558 M free memory
                   25 M buffer memory
                  704 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
          UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
        * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  658M     0  658M   0% /dev
        tmpfs          tmpfs     185M  1.3M  184M   1% /run
        /dev/mmcblk0p2 ext4      117G  5.7G  106G   6% /
        tmpfs          tmpfs     925M  216K  924M   1% /dev/shm
        /dev/mmcblk0p1 vfat      510M   74M  437M  15% /boot/firmware
        tmpfs          tmpfs     185M   40K  185M   1% /run/user/1000
        [Sun Dec  3 16:25:52 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:EB:13:BD vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d3ad1695-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=CH
        [Sun Dec  3 16:25:55 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sun Dec  3 16:25:57 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET               SOURCE         FSTYPE      OPTIONS
        /                    /dev/mmcblk0p2 ext4        rw,noatime
        |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        900M	/var/
        501M	/var/cache
        494M	/var/cache/apt
        383M	/var/cache/apt/archives
        193M	/var/lib
        Archived and active journals take up 103.9M in the file system.
        /opt/iobroker/backups:
        1.3M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        38M	/opt/iobroker/iobroker-data/
        15M	/opt/iobroker/iobroker-data/files
        15M	/opt/iobroker/iobroker-data/backup-objects
        13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
        7.8M	/opt/iobroker/iobroker-data/objects.jsonl
        6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
        1.6M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
        1.3M	/opt/iobroker/iobroker-data/states.jsonl
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.19.0
        /usr/bin/node 		v18.19.0
        /usr/bin/npm 		10.2.3
        /usr/bin/npx 		10.2.3
        /usr/bin/corepack 	0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 600
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 600
             18.18.1-1nodesource1 600
             18.18.0-1nodesource1 600
             18.17.1-1nodesource1 600
             18.17.0-1nodesource1 600
             18.16.1-1nodesource1 600
             18.16.0-1nodesource1 600
             18.15.0-1nodesource1 600
             18.14.2-1nodesource1 600
             18.14.1-1nodesource1 600
             18.14.0-1nodesource1 600
             18.13.0+dfsg1-1 500
             18.13.0-1nodesource1 600
             18.12.0-1nodesource1 600
             18.11.0-1nodesource1 600
             18.10.0-1nodesource1 600
             18.9.1-1nodesource1 600
             18.9.0-1nodesource1 600
             18.8.0-1nodesource1 600
             18.7.0-1nodesource1 600
             18.6.0-1nodesource1 600
             18.5.0-1nodesource1 600
             18.4.0-1nodesource1 600
             18.3.0-1nodesource1 600
             18.2.0-1nodesource1 600
             18.1.0-1nodesource1 600
             18.0.0-1nodesource1 600
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	5.0.16
        admin: 		6.12.0
        javascript: 	"javascript" not found
        Adapters from github: 	1
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi4                             -  enabled
        + system.adapter.smart-eq.0               : smart-eq              : raspberrypi4                             -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
        Controller "js-controller": 5.0.16   , installed 5.0.16
        Adapter    "smart-eq"     : 0.0.4    , installed 0.1.0
        Objects and States
        Objects: 	167
        States: 	123
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      1000       18512      1031/wayvnc
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17042      662/cupsd
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          527        720/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19582      664/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17852      664/iobroker.js-con
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18152      1200/io.admin.0
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17041      662/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          529        720/sshd: /usr/sbin
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14038      487/avahi-daemon: r
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          19556      1003/cups-browsed
        udp        0      0 0.0.0.0:39569           0.0.0.0:*                           104        14040      487/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                104        14039      487/avahi-daemon: r
        udp6       0      0 :::47633                :::*                                104        14041      487/avahi-daemon: r
        udp6       0      0 fe80::d102:490f:2c4:546 :::*                                0          20945      557/NetworkManager
        2023-12-03 16:31:58.270  - info: smart-eq.0 (1963) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-12-03 16:31:58.305  - info: host.raspberrypi4 stopInstance system.adapter.smart-eq.0 send kill signal
        2023-12-03 16:31:58.772  - info: smart-eq.0 (1963) terminating
        2023-12-03 16:31:58.816  - info: host.raspberrypi4 instance system.adapter.smart-eq.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-12-03 16:32:01.323  - info: host.raspberrypi4 instance system.adapter.smart-eq.0 started with pid 1978
        2023-12-03 16:32:02.848  - debug: smart-eq.0 (1978) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2023-12-03 16:32:02.880  - debug: smart-eq.0 (1978) Objects client ready ... initialize now
        2023-12-03 16:32:02.882  - debug: smart-eq.0 (1978) Objects create System PubSub Client
        2023-12-03 16:32:02.884  - debug: smart-eq.0 (1978) Objects create User PubSub Client
        2023-12-03 16:32:02.906  - debug: smart-eq.0 (1978) Objects client initialize lua scripts
        2023-12-03 16:32:02.916  - debug: smart-eq.0 (1978) Objects connected to redis: 127.0.0.1:9001
        2023-12-03 16:32:02.933  - debug: smart-eq.0 (1978) Redis States: Use Redis connection: 127.0.0.1:9000
        2023-12-03 16:32:02.941  - debug: smart-eq.0 (1978) States create System PubSub Client
        2023-12-03 16:32:02.942  - debug: smart-eq.0 (1978) States create User PubSub Client
        2023-12-03 16:32:02.955  - debug: smart-eq.0 (1978) States connected to redis: 127.0.0.1:9000
        2023-12-03 16:32:02.987  - debug: smart-eq.0 (1978) Plugin sentry Initialize Plugin (enabled=true)
        2023-12-03 16:32:03.401  - info: smart-eq.0 (1978) starting. Version 0.1.0 (non-npm: TA2k/ioBroker.smart-eq) in /opt/iobroker/node_modules/iobroker.smart-eq, node: v18.19.0, js-controller: 5.0.16
        2023-12-03 16:32:03.519  - debug: smart-eq.0 (1978) Found current session
        2023-12-03 16:32:03.520  - info: smart-eq.0 (1978) Login with username and password
        2023-12-03 16:32:04.203  - debug: smart-eq.0 (1978) "<!DOCTYPE html><html lang=en xmlns=http://www.w3.org/1999/xhtml><head><meta charset=utf-8><meta http-equiv=X-UA-Compatible content=\"IE=edge\"><meta name=viewport content=\"width=device-width,initial-scale=1\"><link rel=icon href=/ciam/auth/static/favicon.ico><title>Mercedes me</title><link rel=stylesheet href=https://cdn.jsdelivr.net/npm/semantic-ui@2.4.2/dist/semantic.min.css integrity=\"sha256-UXesixbeLkB/UYxVTzuj/gg3+LMzgwAmg3zD+C4ZASQ=\" crossorigin=anonymous><script src=https://cdn.jsdelivr.net/npm/jquery@3.5.1/dist/jquery.min.js integrity=\"sha256-9/aliU8dGd2tb6OSsuzixeV4y/faTqgFtohetphbbj0=\" crossorigin=anonymous></script><script src=https://cdn.jsdelivr.net/npm/semantic-ui@2.4.2/dist/semantic.min.js integrity=\"sha256-CgSoWC9w5wNmI1aN8dIMK+6DPelUEtvDr+Bc2m/0Nx8=\" crossorigin=anonymous></script><script>/*<![CDATA[*/\n      const initialState = \"{\\\"resume\\\":\\\"\\/as\\/AGC3OUbNym\\/resume\\/as\\/authorization.ping\\\",\\\"country\\\":\\\"DE\\\",\\\"recaptchaSiteKey\\\":\\\"6LfCyY0oAAAAAPxZXwyESMtV6m8DTTPsel7odAUZ\\\",\\\"urlPF\\\":\\\"https:\\/\\/id.mercedes-benz.com\\\",\\\"isBotCheckActive\\\":true,\\\"appName\\\":\\\"seqcprod\\\",\\\"contextPath\\\":\\\"\\/ciam\\/auth\\\",\\\"isRememberMeEnabledByDefault\\\":false,\\\"touchpoint\\\":null,\\\"isRecaptchaActive\\\":true,\\\"isPasswordStrengthMeterEnabled\\\":false,\\\"acr\\\":[\\\"MFA\\\"],\\\"deployedStage\\\":\\\"PROD\\\",\\\"acr_values\\\":\\\"mfa\\\",\\\"requestInfo\\\":\\\"eyJlbmMiOiJBMjU2Q0JDLUhTNTEyIiwia2lkIjoiRklSU1RfRU5DUllQVElPTl9JRCIsImFsZyI6IlBCRVMyLUhTNTEyK0EyNTZLVyIsImN0eSI6IkpXVCIsInAyYyI6NjU1MzYsInAycyI6ImRyenp6dEZNejhrT1RsTXoifQ.u_sEEBhkXzBIZotcdh_A1DLvAR6Zkq_oGWHrya_TAqCmohCcZxu34sW-Gm3oR--qLcv8QkAqj7dlV5N7S4oCLxAaITB4SwA9.5tTGZGpbwTYAvYCFRBv9Eg.hfKAxtWMt5Yj4RKx4LJnVlsD9N5H6IGZNGxZaRB5aGtdIMvTbhmKtryj-QD4EhGRDib2Vw0mUkUo1cYfLBD0Br5a8i2eNydHNhrnJmq6C0Fh9gdkmsF-rW1LrxQHWlsuUkRod9bMhDwGFGF4_DuKgXI8ueOZWM_8b4O74BAgcjk9RieZUCQyBj4l_0veZ79gvqEIGM2hjw571KXoMY4lH3mDMJNMqpig0zAzor1GyqhJ0OtEGtvz5ptqOwd3KKY8GMbkt6znwoim_Pi_McOd8oTbeSMNxNTnCAia4DFy8oWR9k55Kb9NUKe1oOQe6nP69E7LeRClCg5xv-nJ419uBBSzZgnhIVlK4Mlek00Uli7LIT7w-R2Zycq4gjXKZ5G6o9RM8g-5RYkiX4Nj_k1PW2bbK0Cuuip3FDnIDWYpXpc8jcKy-x82Et5J1QiJjoC2PxHimEpvjHDAllNQkJBSyCub9MRlWh31TzlIvtoPxXpuYf2NAfLmbgHNPFFCtin1-fCb-DgegGXfuSrpLVGfYz7r3aQla491XMbJa15143_yUdP6WwPknxM6Nm4dFCcKsZO1ls4pHXZYyxqiYlw-sAZQSOf0ri4vDBye5t0cNy70nJfh7ueiOh_uXxgbkQhj9zB7aYF8JYZqHo0s-OrcoHbs_X3PZbAnKvO6AfU2agb6mfyfbyBLksaTrNX9W4j2CLYfHzwWtkhbLBh_-kadm7FChxfk-OUXUaBfMq62gOXKP161CHvOsT7Azgd-OxXGSxPAxBtVHy2iZd3IlvExQtqVl7r2_-dRLXMtXLwmdipsfGrPpAFMh7Zh_ahc9Q7isNMPEyxUn8atnFiR8w7YBS3Z-qCSbQxFjM4rCo6Fa6CftRmABgUAdPLrYsv5VDB9bjTnnIHtzs99nGx52gmJLLOCvIIEV58JBOM9YACu1RpQQ7BPva5I6zEJVjghDUdWjTtnvuz2zIFaAceYBl2ihhYwYgX3P7irZi-gaO9_E_P3M9Ia0W9ytvopGNJocGPak439oMp4Okoqg2adgllvng.UnBVFIjYAEA-jn76cHVMSWvPXHrgA9w1AM8M41tKD-Q\\\",\\\"lang\\\":\\\"de\\\",\\\"brand\\\":\\\"smart\\\",\\\"hideRegistration\\\":false}\"// SPA initialization data\n      const landingPage = null// page to load on init\n      const landingPageParams = null\n      const landingErrors = null// errors to display on init\n      const autoResume = null// return to PF on init if true\n      const contextPath = \"\\/ciam\\/auth\"\n      const brand = \"smart\"\n      const pageTitle = null\n      const showError = null\n      const errorLang = null\n      const errorSummary = null\n      const errorStatus = null\n      const errorRequestId = null\n      const errorShowBack = null\n      /*]]>*/</script><link href=/ciam/auth/static/js/app.2683ac43.js rel=preload as=script><link href=/ciam/auth/static/js/chunk-vendors.eb7f60d5.js rel=preload as=script></head><body><noscript><strong>We're sorry but this page doesn't work properly without JavaScript enabled. Please enable it to continue.</strong></noscript><div id=app></div><script src=/ciam/auth/static/js/chunk-vendors.eb7f60d5.js></script><script src=/ciam/auth/static/js/app.2683ac43.js></script></body></html>"
        2023-12-03 16:32:04.941  - debug: smart-eq.0 (1978) {"result":"GOTO_LOGIN_OTP","country":"CH","lang":"de"}
        2023-12-03 16:32:05.037  - error: smart-eq.0 (1978) AxiosError: Request failed with status code 403
        2023-12-03 16:32:05.038  - error: smart-eq.0 (1978) {"errors":[{"key":"errors.mfa.skip"}],"trackingId":"40991849747c7d0efd0e6a397323790d"}
        2023-12-03 16:32:33.396  - info: admin.0 (1200) <== Disconnect system.user.admin from ::ffff:10.0.1.69 admin
        2023-12-03 16:32:33.415  - info: admin.0 (1200) <== Disconnect system.user.admin from ::ffff:10.0.1.69 admin
        			v.2023-10-10
               Icon name: computer
            Architecture: arm64
        Installation: 		native
        Kernel: 		aarch64
        Userland: 		arm64
        Timezone: 		Europe/Zurich (CET, +0100)
        User-ID: 		1000
        X-Server: 		false
        Pending OS-Updates: 	0
        Pending iob updates: 	0
        Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
        			/usr/bin/npm 		10.2.3
        			/usr/bin/npx 		10.2.3
        Recommended versions are nodejs 18.19.0 and npm 10.2.3
        MEMORY:
        Mem:            1.9G        742M        580M         55M        766M        1.2G
        Swap:           104M          0B        104M
        Total:          2.0G        742M        685M
        Active iob-Instances: 	5
        ioBroker Core: 		js-controller 		5.0.16
        			admin 			6.12.0
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        Objects: 		167
        States: 		123
        Size of iob-Database:
        Thomas Braun T 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @MacMan 0 last edited by Thomas Braun
          Terminal: wayland
          Server werden ohne Desktop betrieben. Schalt das aus.
          sudo systemctl set-defautl multi-user.target
          Davon abgesehen schaut das aber okay aus.
            Habe Desktop ausgeschaltet und Neustart gemacht und nochmals probiert mit neuen Nummern aber es geht immer noch nicht.
            Frage vielleicht weisst Du das ja:
            Ich habe ja einen älteren Raspi wo alles perfekt läuft - könnte ich da was rüberkopieren der Token etc. einfach alles drin hat sodass der Adapter dann im neuen Raspi funktioniert ?
              @macman-0
              403 ist was auf dem Server:
              https://www.zenrows.com/blog/axios-403#randomize-the-user-agent-in-axios-request
                Da steht: Change your User Agent to Solve Axios 403
                Ich frage mal "dumm" könnte es eine Rolle spielen mit welchem Browser und oder OS
                ich den ioBroker bediene ?
                  @macman-0
                  Vielleicht. Vielleicht lässt der Server auch keine parallelen Logins zu. Es gibt mehrere Möglichkeiten, warum der Türsteher dich nicht reinlässt.
                  axios meldet sich aber mit einen eigenen UA, da spielt dein lokaler Browser/OS keine Rolle .
                    Das habe ich mir auch gedacht aber dann würde doch die SmartEQ Handy App und ein login via Browser auch nicht parallel klappen - oder ?
                    Ich könnte dass testen indem ich den funktionierende Raspi einfach abschalte.
                    Ich mache das morgen - muss leider jetzt weg.
                      @macman-0
                      Wie gesagt, es gibt gleich mehrere Möglichkeiten.
                        Danke jedenfalls fürs helfen 🙂
                          tombox @MacMan 0 last edited by
                          @macman-0
                          welche app verwendest du smart-eq oder hello smart
                          kommt ein top code an oder nicht
                            @tombox said in Test Adapter Smart EQ und Hello Smart v0.0.x:
                            Ich verwende smart-eq - was meinst Du mit top code ?
                              @macman-0 ich meine otp code. smart eq habe ich gerade getestet geht bei mir.
                                Bei mir geht ja auch eine alte Installation. Nur wenn ich einen neuen Raspi aufsetze geht es nicht. Deshalb meine Frage - hast Du auch alles frisch auf einem Raspi installiert ?
                                  @macman-0 Ich sehe kein Zusammenhang mit der Installation.
                                  Erhälst du bei deiner neuen installation ein OTP ?
                                    Ja im eMail heist das dann TAN Code.
                                    Frage gibt es einen Unterschied zwischen dem TAN Code den man von der APP erhält und dem von der Webseite, oder müssten beide gehen ?
                                    Ich habe beide probiert leider ohne Erfolg.
                                      @macman-0
                                      Es muss der eingegeben werden der nach Adapterstart versendet wird nicht von der app oder Webseite.
                                        Ohh - danke 🙂 dachte das wars - aber es macht leider keinen unterschied
                                        2023-12-04 16:08:35.467  - debug: smart-eq.0 (2191) {"result":"GOTO_LOGIN_OTP","country":"CH","lang":"de"}
                                        2023-12-04 16:08:35.571  - error: smart-eq.0 (2191) AxiosError: Request failed with status code 403
                                        2023-12-04 16:08:35.571  - error: smart-eq.0 (2191) {"errors":[{"key":"errors.mfa.skip"}],"trackingId":"fb4ecec3c2ad7b1c88af64efe157ee9a"}
                                        2023-12-04 16:08:45.935  - info: admin.0 (1204) ==> Connected system.user.admin from ::ffff:10.0.1.69
                                        2023-12-04 16:08:53.056  - info: host.raspberrypi4 stopInstance system.adapter.smart-eq.0 (force=false, process=true)
                                        2023-12-04 16:08:53.068  - info: smart-eq.0 (2191) Got terminate signal TERMINATE_YOURSELF
                                        2023-12-04 16:08:53.072  - info: smart-eq.0 (2191) terminating
                                        2023-12-04 16:08:53.076  - debug: smart-eq.0 (2191) Plugin sentry destroyed
                                        2023-12-04 16:08:53.078  - info: smart-eq.0 (2191) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2023-12-04 16:08:53.111  - info: host.raspberrypi4 stopInstance system.adapter.smart-eq.0 send kill signal
                                        2023-12-04 16:08:53.144  - info: admin.0 (1204) <== Disconnect system.user.admin from ::ffff:10.0.1.69
                                        2023-12-04 16:08:53.581  - info: smart-eq.0 (2191) terminating
                                        2023-12-04 16:08:53.626  - info: host.raspberrypi4 instance system.adapter.smart-eq.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2023-12-04 16:08:56.137  - info: host.raspberrypi4 instance system.adapter.smart-eq.0 started with pid 2207
                                        2023-12-04 16:08:57.634  - debug: smart-eq.0 (2207) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2023-12-04 16:08:57.666  - debug: smart-eq.0 (2207) Objects client ready ... initialize now
                                        2023-12-04 16:08:57.668  - debug: smart-eq.0 (2207) Objects create System PubSub Client
                                        2023-12-04 16:08:57.670  - debug: smart-eq.0 (2207) Objects create User PubSub Client
                                        2023-12-04 16:08:57.692  - debug: smart-eq.0 (2207) Objects client initialize lua scripts
                                        2023-12-04 16:08:57.702  - debug: smart-eq.0 (2207) Objects connected to redis: 127.0.0.1:9001
                                        2023-12-04 16:08:57.720  - debug: smart-eq.0 (2207) Redis States: Use Redis connection: 127.0.0.1:9000
                                        2023-12-04 16:08:57.728  - debug: smart-eq.0 (2207) States create System PubSub Client
                                        2023-12-04 16:08:57.729  - debug: smart-eq.0 (2207) States create User PubSub Client
                                        2023-12-04 16:08:57.742  - debug: smart-eq.0 (2207) States connected to redis: 127.0.0.1:9000
                                        2023-12-04 16:08:57.773  - debug: smart-eq.0 (2207) Plugin sentry Initialize Plugin (enabled=true)
                                        2023-12-04 16:08:58.243  - info: smart-eq.0 (2207) starting. Version 0.1.0 (non-npm: TA2k/ioBroker.smart-eq) in /opt/iobroker/node_modules/iobroker.smart-eq, node: v18.19.0, js-controller: 5.0.16
                                        2023-12-04 16:08:58.320  - debug: smart-eq.0 (2207) Found current session
                                        2023-12-04 16:08:58.322  - info: smart-eq.0 (2207) Login with username and password
                                        2023-12-04 16:08:58.710  - error: smart-eq.0 (2207) AxiosError: Request failed with status code 403
                                        2023-12-04 16:08:58.711  - error: smart-eq.0 (2207) {"errors":[{"key":"errors.mfa.skip"}],"trackingId":"9e7e78af875eb59574794e24b5555e1a"}
                                        2023-12-04 16:08:58.712  - error: smart-eq.0 (2207) Failed to login via OTP. Please enter the OTP code from the mail in the adapter settings and and save.
                                        2023-12-04 16:08:58.720  - error: smart-eq.0 (2207) Missing token
                                        2023-12-04 16:08:58.729  - info: host.raspberrypi4 stopInstance system.adapter.smart-eq.0 (force=false, process=true)
                                        2023-12-04 16:08:58.736  - info: smart-eq.0 (2207) Got terminate signal TERMINATE_YOURSELF
                                        2023-12-04 16:08:58.737  - info: smart-eq.0 (2207) terminating
                                        2023-12-04 16:08:58.739  - debug: smart-eq.0 (2207) Plugin sentry destroyed
                                        2023-12-04 16:08:58.740  - info: smart-eq.0 (2207) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2023-12-04 16:08:58.777  - info: host.raspberrypi4 stopInstance system.adapter.smart-eq.0 send kill signal
                                        2023-12-04 16:08:59.243  - info: smart-eq.0 (2207) terminating
                                        2023-12-04 16:08:59.303  - info: host.raspberrypi4 instance system.adapter.smart-eq.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2023-12-04 16:09:01.799  - info: host.raspberrypi4 instance system.adapter.smart-eq.0 started with pid 2222
                                        2023-12-04 16:09:03.351  - debug: smart-eq.0 (2222) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2023-12-04 16:09:03.383  - debug: smart-eq.0 (2222) Objects client ready ... initialize now
                                        2023-12-04 16:09:03.386  - debug: smart-eq.0 (2222) Objects create System PubSub Client
                                        2023-12-04 16:09:03.387  - debug: smart-eq.0 (2222) Objects create User PubSub Client
                                        2023-12-04 16:09:03.409  - debug: smart-eq.0 (2222) Objects client initialize lua scripts
                                        2023-12-04 16:09:03.419  - debug: smart-eq.0 (2222) Objects connected to redis: 127.0.0.1:9001
                                        2023-12-04 16:09:03.436  - debug: smart-eq.0 (2222) Redis States: Use Redis connection: 127.0.0.1:9000
                                        2023-12-04 16:09:03.444  - debug: smart-eq.0 (2222) States create System PubSub Client
                                        2023-12-04 16:09:03.445  - debug: smart-eq.0 (2222) States create User PubSub Client
                                        2023-12-04 16:09:03.462  - debug: smart-eq.0 (2222) States connected to redis: 127.0.0.1:9000
                                        2023-12-04 16:09:03.494  - debug: smart-eq.0 (2222) Plugin sentry Initialize Plugin (enabled=true)
                                        2023-12-04 16:09:03.914  - info: smart-eq.0 (2222) starting. Version 0.1.0 (non-npm: TA2k/ioBroker.smart-eq) in /opt/iobroker/node_modules/iobroker.smart-eq, node: v18.19.0, js-controller: 5.0.16
                                        2023-12-04 16:09:03.981  - debug: smart-eq.0 (2222) Found current session
                                        2023-12-04 16:09:03.982  - info: smart-eq.0 (2222) Login with username and password
                                        2023-12-04 16:09:04.612  - debug: smart-eq.0 (2222) "<!DOCTYPE html><html lang=en xmlns=http://www.w3.org/1999/xhtml><head><meta charset=utf-8><meta http-equiv=X-UA-Compatible content=\"IE=edge\"><meta name=viewport content=\"width=device-width,initial-scale=1\"><link rel=icon href=/ciam/auth/static/favicon.ico><title>Mercedes me</title><link rel=stylesheet href=https://cdn.jsdelivr.net/npm/semantic-ui@2.4.2/dist/semantic.min.css integrity=\"sha256-UXesixbeLkB/UYxVTzuj/gg3+LMzgwAmg3zD+C4ZASQ=\" crossorigin=anonymous><script src=https://cdn.jsdelivr.net/npm/jquery@3.5.1/dist/jquery.min.js integrity=\"sha256-9/aliU8dGd2tb6OSsuzixeV4y/faTqgFtohetphbbj0=\" crossorigin=anonymous></script><script src=https://cdn.jsdelivr.net/npm/semantic-ui@2.4.2/dist/semantic.min.js integrity=\"sha256-CgSoWC9w5wNmI1aN8dIMK+6DPelUEtvDr+Bc2m/0Nx8=\" crossorigin=anonymous></script><script>/*<![CDATA[*/\n      const initialState = \"{\\\"resume\\\":\\\"\\/as\\/3ZCFPECodT\\/resume\\/as\\/authorization.ping\\\",\\\"country\\\":\\\"DE\\\",\\\"recaptchaSiteKey\\\":\\\"6LfCyY0oAAAAAPxZXwyESMtV6m8DTTPsel7odAUZ\\\",\\\"urlPF\\\":\\\"https:\\/\\/id.mercedes-benz.com\\\",\\\"isBotCheckActive\\\":true,\\\"appName\\\":\\\"seqcprod\\\",\\\"contextPath\\\":\\\"\\/ciam\\/auth\\\",\\\"isRememberMeEnabledByDefault\\\":false,\\\"touchpoint\\\":null,\\\"isRecaptchaActive\\\":true,\\\"isPasswordStrengthMeterEnabled\\\":false,\\\"acr\\\":[\\\"MFA\\\"],\\\"deployedStage\\\":\\\"PROD\\\",\\\"acr_values\\\":\\\"mfa\\\",\\\"requestInfo\\\":\\\"eyJlbmMiOiJBMjU2Q0JDLUhTNTEyIiwia2lkIjoiRklSU1RfRU5DUllQVElPTl9JRCIsImFsZyI6IlBCRVMyLUhTNTEyK0EyNTZLVyIsImN0eSI6IkpXVCIsInAyYyI6NjU1MzYsInAycyI6IldKR2o0blNRM0NXdkkwT0kifQ.Zxt7UYhX9uTU6dN8i6ctDTlfi9_L9TRqUK9WQAwVMkcwxMXZ7lbEKzq3SS0hETOwwibyV5Vja2dsUhWj_RHbYMtmDbnephZ6.CZX54PgyuFvXbLmXQmIaMQ.8PCG0s0W5YHMuE35edTpeVhLvex_2yZLFGvPooI6PWKduECcJBZfhj3z43J7FXOigX5-_Wwl-iC7QEvB_ydRsuPkVIEF0eOC-gUinTImDtl6BoMeLEmONFxa8bOcgmApzT9yue7w5C_Jd-iS-pGLjfF9zuP9N4RRnxr6D0ySQoSwirYEWkL2OaXzhXk_VrZVc8uaz6074FsinmDLNW2sX3edFauuhZYcFqqLchpJdBw-jIOR5HCAj_NB72zuHldGLkzp7ogQ_Yr4qyLK-2s-Xd3bbvNc0jdFZ_xQ9iNCYpCZ8A9s1XHG1BTnrtr0nzoEctcqdPl4RwPbMXFgsDG1eiy_zVUnnCFJawnqRVdeTIImnuRP44PFV1fHbsUKiK2Vnsv9VdDHneREbSgUXMfI4aDJQtjq1eTT2wMG6yA84G-NUzdfnBdqh-vAnosEHtbP0nAKW-j3OR1w8Rq98Nk-nfkibQbUHS7fhgsCmiGUNVO9PjJ_IK92pxZNzxU0e0910CGx2hMaP0x1tamEthINbJJ5ON22l0tjdcaGsQiY647Qh2ESk3Idg7w1jGh75MTVXAzNMXJ-D8IA-4kBW84xO98vefZhmr86fWpxFtJqo5fAnFGLqwM3GNaV2csBpgN4hx3hCDs7iof8rV_MkoNGOcIGaqAKzRJu19ZLEgAv_n_-L79aj98mcYry93cb0VqQ_fE7Yl9UwiMetbiOsar_u9s7rb1VL8vdWeuYQrPe5dLXQCxuoV8pmA0jDlTMHc8vHj2i3Ql8yQnEKn-lWFSxuK9Kuu12EK2CXnbrGcSO_RyexT-zfaNkTlFfgbLOPtVgssqzxNLS9H260iXhWSswHfsAO0_gXi6S1rJ4TMDGhcvbWQEOjNDsepegqRrbcqQVSAJvu8kbdDEAQ6xq75QAZgDYPB0JesfvNrNnIf9HgDdtylyH7HMhtigStmh4JtzpXhgT1gpP9JyCXSp3kh1kO7ZAXY2hQu4CfhZi-k3vAJY7Ik_z75WBjWicYkU7moG0yC42JSFsGwuJTCSiu4TAHA.Q-myTWMjIrlqJNjhvNItnRMGZaOeWRq61k-YUJPygp8\\\",\\\"lang\\\":\\\"de\\\",\\\"brand\\\":\\\"smart\\\",\\\"hideRegistration\\\":false}\"// SPA initialization data\n      const landingPage = null// page to load on init\n      const landingPageParams = null\n      const landingErrors = null// errors to display on init\n      const autoResume = null// return to PF on init if true\n      const contextPath = \"\\/ciam\\/auth\"\n      const brand = \"smart\"\n      const pageTitle = null\n      const showError = null\n      const errorLang = null\n      const errorSummary = null\n      const errorStatus = null\n      const errorRequestId = null\n      const errorShowBack = null\n      /*]]>*/</script><link href=/ciam/auth/static/js/app.2683ac43.js rel=preload as=script><link href=/ciam/auth/static/js/chunk-vendors.eb7f60d5.js rel=preload as=script></head><body><noscript><strong>We're sorry but this page doesn't work properly without JavaScript enabled. Please enable it to continue.</strong></noscript><div id=app></div><script src=/ciam/auth/static/js/chunk-vendors.eb7f60d5.js></script><script src=/ciam/auth/static/js/app.2683ac43.js></script></body></html>"
                                        2023-12-04 16:09:05.252  - debug: smart-eq.0 (2222) {"result":"GOTO_LOGIN_OTP","country":"CH","lang":"de"}
                                        2023-12-04 16:09:05.356  - error: smart-eq.0 (2222) AxiosError: Request failed with status code 403
                                        2023-12-04 16:09:05.357  - error: smart-eq.0 (2222) {"errors":[{"key":"errors.mfa.skip"}],"trackingId":"b0034585d0f17d90c964eb11e6569648"}
                                        2023-12-04 16:09:13.625  - info: admin.0 (1204) ==> Connected system.user.admin from ::ffff:10.0.1.69
                                        2023-12-04 16:09:20.670  - info: host.raspberrypi4 stopInstance system.adapter.smart-eq.0 (force=false, process=true)
                                        2023-12-04 16:09:20.685  - info: smart-eq.0 (2222) Got terminate signal TERMINATE_YOURSELF
                                        2023-12-04 16:09:20.689  - info: smart-eq.0 (2222) terminating
                                        2023-12-04 16:09:20.692  - debug: smart-eq.0 (2222) Plugin sentry destroyed
                                        2023-12-04 16:09:20.694  - info: smart-eq.0 (2222) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2023-12-04 16:09:20.727  - info: host.raspberrypi4 stopInstance system.adapter.smart-eq.0 send kill signal
                                        2023-12-04 16:09:20.773  - info: admin.0 (1204) <== Disconnect system.user.admin from ::ffff:10.0.1.69
                                        2023-12-04 16:09:21.197  - info: smart-eq.0 (2222) terminating
                                        2023-12-04 16:09:21.276  - info: host.raspberrypi4 instance system.adapter.smart-eq.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2023-12-04 16:09:23.751  - info: host.raspberrypi4 instance system.adapter.smart-eq.0 started with pid 2237
                                        2023-12-04 16:09:25.233  - debug: smart-eq.0 (2237) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2023-12-04 16:09:25.265  - debug: smart-eq.0 (2237) Objects client ready ... initialize now
                                        2023-12-04 16:09:25.267  - debug: smart-eq.0 (2237) Objects create System PubSub Client
                                        2023-12-04 16:09:25.269  - debug: smart-eq.0 (2237) Objects create User PubSub Client
                                        2023-12-04 16:09:25.291  - debug: smart-eq.0 (2237) Objects client initialize lua scripts
                                        2023-12-04 16:09:25.301  - debug: smart-eq.0 (2237) Objects connected to redis: 127.0.0.1:9001
                                        2023-12-04 16:09:25.318  - debug: smart-eq.0 (2237) Redis States: Use Redis connection: 127.0.0.1:9000
                                        2023-12-04 16:09:25.325  - debug: smart-eq.0 (2237) States create System PubSub Client
                                        2023-12-04 16:09:25.327  - debug: smart-eq.0 (2237) States create User PubSub Client
                                        2023-12-04 16:09:25.339  - debug: smart-eq.0 (2237) States connected to redis: 127.0.0.1:9000
                                        2023-12-04 16:09:25.369  - debug: smart-eq.0 (2237) Plugin sentry Initialize Plugin (enabled=true)
                                        2023-12-04 16:09:25.797  - info: smart-eq.0 (2237) starting. Version 0.1.0 (non-npm: TA2k/ioBroker.smart-eq) in /opt/iobroker/node_modules/iobroker.smart-eq, node: v18.19.0, js-controller: 5.0.16
                                        2023-12-04 16:09:25.865  - debug: smart-eq.0 (2237) Found current session
                                        2023-12-04 16:09:25.867  - info: smart-eq.0 (2237) Login with username and password
                                        2023-12-04 16:09:26.261  - error: smart-eq.0 (2237) AxiosError: Request failed with status code 403
                                        2023-12-04 16:09:26.262  - error: smart-eq.0 (2237) {"errors":[{"key":"errors.mfa.skip"}],"trackingId":"fb59dcf0a354d0af8dd97128e4664331"}
                                        2023-12-04 16:09:26.262  - error: smart-eq.0 (2237) Failed to login via OTP. Please enter the OTP code from the mail in the adapter settings and and save.
                                        2023-12-04 16:09:26.270  - error: smart-eq.0 (2237) Missing token
                                        2023-12-04 16:09:26.277  - info: host.raspberrypi4 stopInstance system.adapter.smart-eq.0 (force=false, process=true)
                                        2023-12-04 16:09:26.283  - info: smart-eq.0 (2237) Got terminate signal TERMINATE_YOURSELF
                                        2023-12-04 16:09:26.284  - info: smart-eq.0 (2237) terminating
                                        2023-12-04 16:09:26.286  - debug: smart-eq.0 (2237) Plugin sentry destroyed
                                        2023-12-04 16:09:26.287  - info: smart-eq.0 (2237) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2023-12-04 16:09:26.325  - info: host.raspberrypi4 stopInstance system.adapter.smart-eq.0 send kill signal
                                        2023-12-04 16:09:26.791  - info: smart-eq.0 (2237) terminating
                                        2023-12-04 16:09:26.872  - info: host.raspberrypi4 instance system.adapter.smart-eq.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2023-12-04 16:09:29.360  - info: host.raspberrypi4 instance system.adapter.smart-eq.0 started with pid 2252
                                        2023-12-04 16:09:30.868  - debug: smart-eq.0 (2252) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2023-12-04 16:09:30.900  - debug: smart-eq.0 (2252) Objects client ready ... initialize now
                                        2023-12-04 16:09:30.902  - debug: smart-eq.0 (2252) Objects create System PubSub Client
                                        2023-12-04 16:09:30.904  - debug: smart-eq.0 (2252) Objects create User PubSub Client
                                        2023-12-04 16:09:30.926  - debug: smart-eq.0 (2252) Objects client initialize lua scripts
                                        2023-12-04 16:09:30.935  - debug: smart-eq.0 (2252) Objects connected to redis: 127.0.0.1:9001
                                        2023-12-04 16:09:30.952  - debug: smart-eq.0 (2252) Redis States: Use Redis connection: 127.0.0.1:9000
                                        2023-12-04 16:09:30.960  - debug: smart-eq.0 (2252) States create System PubSub Client
                                        2023-12-04 16:09:30.961  - debug: smart-eq.0 (2252) States create User PubSub Client
                                        2023-12-04 16:09:30.974  - debug: smart-eq.0 (2252) States connected to redis: 127.0.0.1:9000
                                        2023-12-04 16:09:31.006  - debug: smart-eq.0 (2252) Plugin sentry Initialize Plugin (enabled=true)
                                        2023-12-04 16:09:31.425  - info: smart-eq.0 (2252) starting. Version 0.1.0 (non-npm: TA2k/ioBroker.smart-eq) in /opt/iobroker/node_modules/iobroker.smart-eq, node: v18.19.0, js-controller: 5.0.16
                                        2023-12-04 16:09:31.529  - debug: smart-eq.0 (2252) Found current session
                                        2023-12-04 16:09:31.531  - info: smart-eq.0 (2252) Login with username and password
                                        2023-12-04 16:09:32.154  - debug: smart-eq.0 (2252) "<!DOCTYPE html><html lang=en xmlns=http://www.w3.org/1999/xhtml><head><meta charset=utf-8><meta http-equiv=X-UA-Compatible content=\"IE=edge\"><meta name=viewport content=\"width=device-width,initial-scale=1\"><link rel=icon href=/ciam/auth/static/favicon.ico><title>Mercedes me</title><link rel=stylesheet href=https://cdn.jsdelivr.net/npm/semantic-ui@2.4.2/dist/semantic.min.css integrity=\"sha256-UXesixbeLkB/UYxVTzuj/gg3+LMzgwAmg3zD+C4ZASQ=\" crossorigin=anonymous><script src=https://cdn.jsdelivr.net/npm/jquery@3.5.1/dist/jquery.min.js integrity=\"sha256-9/aliU8dGd2tb6OSsuzixeV4y/faTqgFtohetphbbj0=\" crossorigin=anonymous></script><script src=https://cdn.jsdelivr.net/npm/semantic-ui@2.4.2/dist/semantic.min.js integrity=\"sha256-CgSoWC9w5wNmI1aN8dIMK+6DPelUEtvDr+Bc2m/0Nx8=\" crossorigin=anonymous></script><script>/*<![CDATA[*/\n      const initialState = \"{\\\"resume\\\":\\\"\\/as\\/0iYlApjZyG\\/resume\\/as\\/authorization.ping\\\",\\\"country\\\":\\\"DE\\\",\\\"recaptchaSiteKey\\\":\\\"6LfCyY0oAAAAAPxZXwyESMtV6m8DTTPsel7odAUZ\\\",\\\"urlPF\\\":\\\"https:\\/\\/id.mercedes-benz.com\\\",\\\"isBotCheckActive\\\":true,\\\"appName\\\":\\\"seqcprod\\\",\\\"contextPath\\\":\\\"\\/ciam\\/auth\\\",\\\"isRememberMeEnabledByDefault\\\":false,\\\"touchpoint\\\":null,\\\"isRecaptchaActive\\\":true,\\\"isPasswordStrengthMeterEnabled\\\":false,\\\"acr\\\":[\\\"MFA\\\"],\\\"deployedStage\\\":\\\"PROD\\\",\\\"acr_values\\\":\\\"mfa\\\",\\\"requestInfo\\\":\\\"eyJlbmMiOiJBMjU2Q0JDLUhTNTEyIiwia2lkIjoiRklSU1RfRU5DUllQVElPTl9JRCIsImFsZyI6IlBCRVMyLUhTNTEyK0EyNTZLVyIsImN0eSI6IkpXVCIsInAyYyI6NjU1MzYsInAycyI6IlFLOV9Jd1VXU25SZFdTLUkifQ.FPrkXGXUZoezpfyavNYHoDfby5gb4uZbu6lE6dt__dpuraNQCYidyK0hIRt4HzRllce9ClAa8HBe0A8CWB0LHo1N4ljX34iM.h-ILN3yq6rD0XIKiinl3gw.Nx3O81A9ZLrJdFQZfWLjQF45WYwxScKU_UyeS8lgXHm6URw0eP-TAcAcbT_x8MVbyUpEGSHvypNJZCd28mE_lU5r2AsgVf5IJJDKqSKSeMT1tV3R1UP2MrHqL2Eo9D-Zm4lww8YbnHZFK4ZqqpYu4-mT2inlWZSt_AspmwGi007qjpf4uHIifvr11N9qisE0mRMzESz5xXZWjKU941Y2k_9bidxEVv8yS4ZlHztstmyvFjLSb9KKMa_m7KwWPebDLGe-b9dnyukbxFRSvgj8f3-hzfAdFaKLm5cq-H_rgX4gpRI6vr54xGfEuEnbGDHsLKMkT1kxh7-O-n886x4z4JhoTwp_7DHLfnPIh5FpdnGcky13UMPL93J2deY11oq8AFD9soFzq1ebZU1q4mrC3Nd-1LOvnZNPxWDeSnT7wUSyi5Uo2ZJFPLbLwMXizFEKgCZrE5q42TObTHC14oN_t-0lwMLI3DFttdwV2kgNTO2MiUDltnxKYOD5UnecK9cLFWzYsXVJ4aQbTXB2-9VULNHairBU5T1dd0VgaTpI9AtxI4Q-4o1t8ZLmRZPYaMlys-v_fxpZvai7eHaFMBXv1iNBJ9iunZ5cIpkDrlnUziGMrMJYp12iU5Xhz243zXV9F7Bjx4U_Ni06iyn_3zJN9ahV0cGhzCqlIEr53tJocuGBFSLP0TuEUMmN-lcMY1D40nrSIgCvP1NhMf4uKMtVxcEiVSabwQDzu1od9gEXMuRZDikuvvXPU7sFie_CEw85xM61NQaQs15MeUhhDYYGjcGaujR2b9VmD7n62E8A-pCIbLmMKgCajCOnwlno3Ga4TUy-4zkDfbPZDMFF1PwfK5ew3M9oGUnnl1nQIrKUaZO-T9ZTgR2Vt-EroF8tY-B_EvBSO-D_V2BIPHpBfA15sXCWyzb4WFdD_0IWfVszmS-mo9ch8iqk2WH6q8XPXGBKwgrDn2aqBpmsF_y9-W5G_-LqfzFNbyauzY5NP1TQqtOE1WN2OB_MojzVOdz7tu3hvz8UbWLDOtJuSvnFT-Wi6Q.sVWSzTcH-bUzGHJqs053ULdagGFqBaeqnAxeXQzHK0s\\\",\\\"lang\\\":\\\"de\\\",\\\"brand\\\":\\\"smart\\\",\\\"hideRegistration\\\":false}\"// SPA initialization data\n      const landingPage = null// page to load on init\n      const landingPageParams = null\n      const landingErrors = null// errors to display on init\n      const autoResume = null// return to PF on init if true\n      const contextPath = \"\\/ciam\\/auth\"\n      const brand = \"smart\"\n      const pageTitle = null\n      const showError = null\n      const errorLang = null\n      const errorSummary = null\n      const errorStatus = null\n      const errorRequestId = null\n      const errorShowBack = null\n      /*]]>*/</script><link href=/ciam/auth/static/js/app.2683ac43.js rel=preload as=script><link href=/ciam/auth/static/js/chunk-vendors.eb7f60d5.js rel=preload as=script></head><body><noscript><strong>We're sorry but this page doesn't work properly without JavaScript enabled. Please enable it to continue.</strong></noscript><div id=app></div><script src=/ciam/auth/static/js/chunk-vendors.eb7f60d5.js></script><script src=/ciam/auth/static/js/app.2683ac43.js></script></body></html>"
                                        2023-12-04 16:09:32.811  - debug: smart-eq.0 (2252) {"result":"GOTO_LOGIN_OTP","country":"CH","lang":"de"}
                                        2023-12-04 16:09:32.916  - error: smart-eq.0 (2252) AxiosError: Request failed with status code 403
                                        2023-12-04 16:09:32.917  - error: smart-eq.0 (2252) {"errors":[{"key":"errors.mfa.skip"}],"trackingId":"1ca1cb5df5087bbf08c28594df3b587a"}
                                        Was ich noch versucht habe - ich habe die SmartEQ APP auf dem iPad gelöscht frisch heruntergeladen und mich neu angemeldet. Einfach nur um zu sehen ob eMail und Passwort noch funktionieren.
                                        Und dies ist auch der Fall ich konnte mich problemlos anmelden.
                                        Prominent ist immer dieser Error: AxiosError: Request failed with status code 403
                                        Aber ich habe keine Ahnung was das bedeutet ?
                                          @macman-0 bräuchte ich den account um das nachzustellen vielleicht hat es etwas mit Schweiz zu tun
                                            Wie gesagt ich habe ja einen RasperryPi wo es perfekt läuft dort einfach mit einem alten Setup.
                                            Zum Glück habe ich damals einen Full-BackUp gemacht.
                                            Wieso hat es damals ende 2022 funktioniert ? Dann kam mir soeben die Idee eine ältere Version des Adapters zu installieren.
                                            Habe es zuerst mit 0.4.0 versucht das ging auch nicht aber mit 0.3.0 hat es nun funktioniert 🙂
                                            Die Schweiz hat also keine Schuld 🙂
                                            Vielleicht hilft Dir all diese info bei der nächsten Version. Ich kann ja nicht der einzige sein wo es nicht funktioniert hat ?
                                            Würde mich sehr freuen wenn jemand auch mal das neue RaspiOS Bookworm installiert dann den ioBroker und dann den SmartEQ Adapter einfach um zu sehen ob das Problem ev. doch nur nur bei mir existierte.🤗
                                            157
                                            24722
