    4. Fritzbox DECT Adapter
    • JLeg
      JLeg last edited by
      @foxthefox sagte in Fritzbox DECT Adapter:
      @jleg
      und wie genau geht das?
      in ioBroker.docs hab ichs grad nicht gefunden
      https://iobroker.readthedocs.io/de/latest/development/iopackage.html#confval-common.messages
      (imo sehr gute Doku!)
        foxthefox Developer @JLeg last edited by
        @jleg
        super, danke
          foxthefox Developer @foxthefox last edited by
          @foxthefox
          nur mal so zur Info, bin die nächste Zeit offline
          wollerosekaufe 1 Reply Last reply Reply Quote 0
          • wollerosekaufe
            wollerosekaufe @foxthefox last edited by
            @foxthefox
            moin, war auch paar tage unterwegs 😆
            gerade nochmal die statistik und debug angemacht, bleibt leider dabei
            fritzdect.0
            	2023-11-17 22:47:32.676	warn	[Polling] <== TypeError: Cannot read properties of null (reading 'val')
            fritzdect.0
            	2023-11-17 22:47:32.662	debug	With 000000000000got the following to parse{"devicestats":{"temperature":{"stats":{"count":"96","grid":"900","datatime":"1700257650","_@attribute":"30,30,30,30,30,30,30,35,35,35,55,30,30,30,35,35,35,35,40,40,40,40,40,40,45,45,50,50,55,55,55,60,60,65,65,65,65,60,60,55,55,55,55,55,55,55,65,65,55,55,50,40,35,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,35,30,30,35,35,35,35,35,35,35,35,35,35,35,35"}},"voltage":{"stats":{"count":"360","grid":"10","datatime":"1700257650","_@attribute":"238936,238855,238920,238918,238896,238242,238695,238519,238457,238425,238435,238193,238069,238252,238252,238252,238252,238252,238252,237860,237860,237860,237860,237860,237860,237860,237860,237860,237860,237860,237860,237894,237894,237894,237894,237894,237894,237894,237894,237894,237894,237894,237894,237240,237240,237240,237240,237240,237240,237240,237240,237240,237240,237240,237240,237384,237384,237384,237384,237384,237384,237384,237384,237384,237384,237384,237384,238220,238220,238220,238220,238220,238220,238220,238220,238220,238220,238220,238220,238300,238300,238300,238300,238300,238300,238300,238300,238300,238300,238300,238300,238465,238465,238465,238465,238465,238465,238465,238465,238465,238465,238465,238465,237793,237793,237793,237793,237793,237793,237793,237793,237793,237793,237793,237793,238290,238290,238290,238290,238290,238290,238290,238290,238290,238290,238290,238290,238184,238184,238184,238184,238184,238184,238184,238184,238184,238184,238184,238184,237962,237962,237962,237962,237962,237962,237962,237962,237962,237962,237962,237962,238686,238686,238686,238686,238686,238686,238686,238686,238686,238686,238686,238686,238754,238754,238754,238754,238754,238754,238754,238754,238754,238754,238754,238754,238647,238647,238647,238647,238647,238647,238647,238647,238647,238647,238647,238647,238995,238995,238995,238995,238995,238995,238995,238995,238995,238995,238995,238995,238780,238780,238780,238780,238780,238780,238780,238780,238780,238780,238780,238780,237721,237721,237721,237721,237721,237721,237721,237721,237721,237721,237721,237721,237047,237047,237047,237047,237047,237047,237047,237047,237047,237047,237047,237047,236187,236187,236187,236187,236187,236187,236187,236187,236187,236187,236187,236187,236188,236188,236188,236188,236188,236188,236188,236188,236188,236188,236188,236188,236272,236272,236272,236272,236272,236272,236272,236272,236272,236272,236272,236272,236410,236410,236410,236410,236410,236410,236410,236410,236410,236410,236410,236410,237006,237006,237006,237006,237006,237006,237006,237006,237006,237006,237006,237006,237879,237879,237879,237879,237879,237879,237879,237879,237879,237879,237879,237879,237656,237656,237656,237656,237656,237656,237656,237656,237656,237656,237656,237656,237978,237978,237978,237978,237978,237978,237978,237978,237978,237978,237978,237978,237565,237565,237565,237565,237565,237565,237565,237565,237565,237565,237565,237565,237288,237288,237288,237288,237288,237288,237288,237288,237288,237288,237288,237288,237473,237473,237473,237473,237473"}},"power":{"stats":{"count":"360","grid":"10","datatime":"1700257650","_@attribute":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}},"energy":{"stats":[{"count":"12","grid":"2678400","datatime":"1700248463","_@attribute":"0,0,0,0,0,0,0,0,1,0,0,0"},{"count":"31","grid":"86400","datatime":"1700248463","_@attribute":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}]}}}
              foxthefox Developer @wollerosekaufe last edited by
              @wollerosekaufe
              Danke, mache mich weiter auf die Suche was da der Störenfried ist.
              Bei mir läuft es leider korrekt durch, aber ich werde den Unterschied schon noch finden.
                @wollerosekaufe
                Unter Umständen habe ich die Problematik gefunden.
                Es existiert eine Version 2.5.9 in github, bitte testen.
                • wollerosekaufe
                  wollerosekaufe @foxthefox last edited by wollerosekaufe
                  @foxthefox said in Fritzbox DECT Adapter:
                  das schaut sehr gut aus ❤
                  vmtl. nur ein kurzer hänger der influxdb, aber sicherheitshalber mal als notiz:
                  influxdb.0
                  	2023-11-19 14:21:34.240	info	Connected!
                  influxdb.0
                  	2023-11-19 14:21:33.945	info	Applying retention policy for iobroker to 31536000 seconds. Shard Group Duration (calculated): 604800 seconds
                  influxdb.0
                  	2023-11-19 14:21:33.733	info	Influx DB Version used: 2.x
                  influxdb.0
                  	2023-11-19 14:21:33.732	info	Connecting https://odroidc4:8086/ ...
                  influxdb.0
                  	2023-11-19 14:21:23.727	error	Error during ping: Error: socket hang up. Attempting reconnect.
                  influxdb.0
                  	2023-11-19 14:21:23.717	info	Add point that had error for fritzdect.0.DECT_0000000000.operationmode to buffer again, error-count=1
                  influxdb.0
                  	2023-11-19 14:21:23.717	warn	Error on writePoint("{"value":"Comfort","time":"2023-11-19T13:21:12.172Z","from":"system.adapter.fritzdect.0","q":0,"ack":true}): Error: socket hang up / "socket hang up""
                  influxdb.0
                  	2023-11-19 14:21:23.714	warn	Point could not be written to database: iobroker
                  btw der andere fehler mit den docker logs
                  > iobroker  | 2023-11-05T14:07:21.461112467Z strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes)
                  > iobroker  | 2023-11-05T14:07:21.461303722Z strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)
                  hat nichts mit deinem adapter zu tun. das kommt bei mehreren wenn man in die einstellungen geht.
                  hab mal einen thread dazu aufgemacht https://forum.iobroker.net/topic/70355/zertifikatsproblem-definitions-certificatesprops
                    foxthefox Developer last edited by
                    das sieht doch zumindest für fritzdect gut aus.
                    Dann veröffentliche ich mal die 2.5.9
                      HansJochen last edited by
                      danke für den coolen Adapter, der bei mir schon lange sehr zuverlässig funktioniert.
                      Ich bin in den letzten Tagen über diese Warnung im Log gestolpert, die alle paar Minuten auftaucht:
                      State value to set for "fritzdect.0.DECT_xxx.celsius" has value "-0.5" less than min "0"
                      Die Meldung sagt schon aus, was das Problem ist: Der Datenpunkt ist für 0 - 32°C angelegt. Bei meiner Außensteckdose im Gartenhaus kommen aber auch mal kältere Temperaturen vor. Ich habe den Range einfach von Hand geändert. Vielleicht wäre deutlich großzügigerer Bereich (etwa -30°C bis +50°C) sinnvoll. Kann ja auch sein, dass eine Innensteckdose mal hinter einem Ofen steckt.
                      Winni F 2 Replies Last reply Reply Quote 0
                      • Winni
                        Winni @HansJochen last edited by
                        @hansjochen Hallo, das kannst du selbst ändern. Im Objektordner beim Datenpunkt "celsius" auf den Stift klicken und dann runter scrollen.
                          HansJochen @Winni last edited by
                          Hallo @Winni
                          @winni sagte in Fritzbox DECT Adapter:
                          Danke für den Hinweis, damit hatte ich ja die Meldung bei mir ja auch weg bekommen. Ich dachte, dass ein großzügigerer Standard Wertebereich im Adapter sinnvoll wäre, weil das bei anderen bestimmt auch mal vorkommt.
                          Winni 1 Reply Last reply Reply Quote 0
                          • Winni
                            @hansjochen ok, hatte ich übersehen.
                              foxthefox Developer @HansJochen last edited by
                              @hansjochen
                              der Bereich ist schon länger mit -30..50°C im Adapter hinterlegt.
                              Allerdings werden angelegte Datenpunkte nicht überschrieben, d.h. damit die geänderten Wertebereiche auch wirksam werden, muß der Datenpunkt (oder der ganze Baum von der Instanz) gelöscht werden.
                              Beim Neustart wird der nichtexistierende Datenpunkt auch wieder angelegt, diesmal mit den geänderten Grenzen.
                                HansJochen @foxthefox last edited by
                                @foxthefox
                                Danke für den Hinweis. Ich hatte nicht daran gedacht, nachzusehen, ob das schon behoben ist.
                                  karsten089 last edited by
                                  Ich schließe mich hier mal an. Ich habe einen Rolladen über die FRITZ!Box verbunden, und den Fritz dect Adapter installiert und richtige ip und Login Daten eingegeben - alles auf grün... Leider erscheint das Gerät unter den Objekten nicht. Jemand eine Idee woran das liegen kann?
                                    foxthefox Developer @karsten089 last edited by
                                    @karsten089
                                    Was zeigt das Log nach dem Start?
                                    Da sollten Berechtigungen des Users angezeigt sein ( 2 ist gut).
                                    Und danach sollte etwas stehen, wieviele Geräte angelegt werden und das es fertig ist.
                                    Es hilft auch auf der AdapterConfig Seite mal die Tasten für "Meine Geräte/My Devices" zu drücken.
                                    Da sollte ein Fenster aufgehen und Text drin stehen (bestenfalls die ID von deinem Rollo usw.)
                                    Wenn da nichts kommt, dann passt etwas mit login nicht, oder die Integration des Gerätes in der FB.
                                    D K 2 Replies Last reply Reply Quote 0
                                      Dragon @foxthefox last edited by
                                      @foxthefox Würde auf den ersten Blick sagen, dass dem Benutzer die Berechtigung für die SmartHome Geräte fehlt. Ich habe mehrere Rollotron Dect in der Fritzbox und die funktionieren traumhaft.
                                        foxthefox Developer @Dragon last edited by
                                        @dragon sagte in Fritzbox DECT Adapter:
                                        das freut mich zu hören.
                                        gehe ich auch fast davon aus, das gilt es herauszufinden
                                          karsten089 @foxthefox last edited by
                                          @foxthefox @Dragon
                                          Danke euch, es lag tatsächlich am Login. Super, jetzt klappts.
                                          • Ro75
                                            Ro75 last edited by
                                            Ich habe gestern den Adapter von der 2.3.1 auf die 2.5.9 angehoben. Dann das Passwort neu gesetzt und es sah alles perfekt aus. Die Steckdosen (DECT 200) ohne Probleme, Daten kamen.
                                            Bei den DECT 301 (Heizung) sah auch alles gut aus, nur Anderungen z.b. Temperatur per Hand oder durch FB (Zeitplan) an den Geräten kamen nich im Adapter an. Änderung der Temperatur über den Adapter wurden nicht zur FB und damit zum DECT 301 übertragen.
                                            Also mit viel hängen und würgen wieder zurück zur 2.3.1 und alles ok.
                                            Ich würde gerne die neue Features nutzen, aber mit diesem BUG ist das unmöglich.
                                            Ro75.
                                            1.2k
                                            163
                                            31790
