    4. VIS von Sigi234
    VIS von Sigi234
      Sushibomba last edited by
      Gehts dir wieder besser @sigi234 ?
        sigi234 Forum Testing Most Active @Sushibomba last edited by
        @sushibomba sagte in VIS von Sigi234:
        Ja geht so. Danke. Bin noch schlapp.
          Sushibomba @sigi234 last edited by
          @sigi234
          Ohhh nicht schön dann gute Besserung weiterhin.
          Fühlst du dich denn trotzdem in der Lage meine Frage oben zu beantworten? Wäre echt klasse damit ich die Rollladensteuerung endlich nutzen kann auf dem Tablet. Vielen Dank.
            @sushibomba
            Zeig mir noch mal was du genau willst.
              Sushibomba @Sushibomba last edited by Sushibomba
              @sigi234
              Kannst du mir sagen wie ich die komplette Dropdownliste auf meinem Tablet sichtbar bekommen wenn ich drauf klicke?
              DU hattest selbst mal wegen der Lösung gefragt.
              @sigi234
              Und noch das Widget als Code:
              [{"tpl":"tplMaListWindowShutter","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","showTitle":true,"onlyTitle":false,"titleSize":" medium","widgetBackground":"","TextColor":"white","subtitleSize":"x-small","valueAlign":"left","valueVertical":"center","opacityColor":"white","inverted":true,"borderRadius":"10","showIcon":true,"centerIcon":true,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"alias.0.Rolladensteuerung.Rollo_WZ_RECHTS","border":false,"title":"WZ R. ","subtitle":"","valueSize":" medium","valueAsSubtitle":false,"borderColor":"white","useOverallRoundedValues":"checked","roundLeftUp":"10","roundLeftBottom":"0","roundRightUp":"0","roundRightBottom":"10","boxShadow":"unchecked","shadowWidth":"2","readOnly":true},"style":{"left":"1460px","top":"117px","z-index":"1","width":"275px","height":"58px","line-height":"","text-align":"center","font-style":"normal","font-variant":"","color":"#ffb900","font-weight":"","font-size":"0px"},"widgetSet":"vis-material-advanced"}]
                @sushibomba
                Schau ich mir mal an, haben immer wieder Stromausfall
                  @sigi234
                  Ok super. Ich danke dir recht herzlich vorab und wünsche dir einen schönen 1.ten Advent
                    @sigi234
                    vis-material-advanced funktioniert nicht mehr richtig.
                      @sigi234
                      Und welches Widget kannst du mir als Alternative vorschlagen wo das mit dem scrollen auf dem Tablet funktioniert?
                        @sigi234
                        Was möchtest du genau?
                          @sigi234
                          Ich möchte die Prozentzahl vom jeweiligen Rollladen angezeigt bekommen und bei klick auf die Zahl soll sich ein DropDown öffnen wo ich dann von 100%-0% alles auswählen kann.
                          Nur sehe ich halt nicht die komplette Liste beim Dropdown und ich würde gerne alles direkt beim klick angezeigt bekommen.
                          sigi234 DJMarc75 A 3 Replies Last reply Reply Quote 0
                            @sushibomba
                            Da gibt es doch Widgets für Rollläden.
                              @sigi234
                              Ja es soll ja auch zum Rest passen. Welches schwebt dir denn vor?
                              • DJMarc75
                                DJMarc75 @Sushibomba last edited by
                                ich nutze zwar "nur" die materialdesign Widgets (ohne advanced) habe das aber mit folgendem CSS gelöst:
                                .v-menu__content{
                                 max-height: 800px !important;
                                Die 800px legen die Höhe des Menüs fest und können natürlich angepasst werden.
                                Ein Versuch wäre es ja wert ob das bei Deinem Widget auch funktioniert.
                                  Sushibomba @DJMarc75 last edited by
                                  @djmarc75
                                  Danke Marc das war der Hinweis den ich braucht. Mal wieder vielen Dank. Funktioniert einwandfrei auf dem Desktop zumindest 👏 😊 👍
                                    Andronid @Sushibomba last edited by
                                    @sushibomba Kannst du mir sagen, wo du die Anzeige der Prozentzahlen her hast?
                                      Kail last edited by
                                      Hallo Sigi,
                                      tolle VIS und Quelle für Inspirationen.
                                      2 Fragen hätte ich:
                                      Schaltest Du Deinen TV über eine Smarte Steckdose ein, läuft da ein Script, was dann erst die Steckdose und dann den Sender bzw. Einstellungen am TV vornimmt?
                                      Wenn ich über einen Button einen Sender anwählen und an das Device weitergeben möchte, wie setze ichdas um?
                                      Danke und Grüße Kail
                                        sigi234 Forum Testing Most Active @Kail last edited by
                                        @kail sagte in VIS von Sigi234:
                                        Hallo Sigi,
                                        2 Fragen hätte ich:
                                        Nein, ist nur zur Anzeige vom Verbrauch
                                        Welchen TV hast du?
                                          Kail @sigi234 last edited by
                                          @sigi234
                                          Es geht um Radiostationen die ich (für ein bestimmtes Ausgabegerät) über den LMS-Adapter weitergeben möchte
                                            sigi234 Forum Testing Most Active @Kail last edited by sigi234
                                            @sigi234
                                            Input Widget
                                            Oder Inventwo Radio Button Widget
                                            ode abfrage vis vis projekte
                                            151
                                            1344
                                            596075
