    4. BackItUp erstellt keine backups mehr
      ronk last edited by ronk
      Wahrscheinlich doch eher das hier:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model		: Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       17:11:32 up 23:52,  1 user,  load average: 0.30, 0.53, 0.39
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Mon 2023-12-04 17:11:32 CET
                 Universal time: Mon 2023-12-04 16:11:32 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      ronny
      /home/ronny
      ronny adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin docker gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: 	true
      Desktop: 	LXDE-pi
      Terminal: 	x11
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:            3.8G        1.8G        434M        168M        1.5G        1.7G
      Swap:            99M         26M         73M
      Total:          3.9G        1.9G        507M
               3794 M total memory
               1831 M used memory
               2155 M active memory
                713 M inactive memory
                434 M free memory
                 22 M buffer memory
               1506 M swap cache
                 99 M total swap
                 26 M used swap
                 73 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
      * rc-local.service loaded failed failed /etc/rc.local Compatibility
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G   15G   13G  55% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  3.5M  756M   1% /run
      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
      [Sun Dec  3 17:19:11 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:16:F4:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e446591d-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Sun Dec  3 17:19:12 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Dec  3 17:19:12 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sun Dec  3 17:19:15 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      10G	/var/
      7.6G	/var/lib
      7.4G	/var/lib/docker
      6.9G	/var/lib/docker/overlay2
      1.2G	/var/log/journal/55f00fb070744f2da4bf0d8a099975a6
      Archived and active journals take up 1.1G in the file system.
      /opt/iobroker/backups:
      196M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      209M	/opt/iobroker/iobroker-data/
      155M	/opt/iobroker/iobroker-data/files
      67M	/opt/iobroker/iobroker-data/files/javascript.admin
      48M	/opt/iobroker/iobroker-data/files/javascript.admin/static
      47M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
      21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      11M	/opt/iobroker/iobroker-data/objects.jsonl
      8.4M	/opt/iobroker/iobroker-data/states.jsonl
      8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
      7.5M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.19.0
      /usr/bin/node 		v18.19.0
      /usr/bin/npm 		10.2.3
      /usr/bin/npx 		10.2.3
      /usr/bin/corepack 	0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 500
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	5.0.16
      admin: 		6.12.0
      javascript: 	7.1.6
      Adapters from github: 	0
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.58
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.solax.0                  : solax                 : raspberrypi                              -  enabled
      + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.16   , installed 5.0.16
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
      Adapter    "solax"        : 0.8.0    , installed 0.8.0
      Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-icontwo"  : 0.98.0   , installed 0.98.0
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Objects and States
      Objects: 	3135
      States: 	3110
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://download.docker.com/linux/debian bullseye InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       19252      991/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       19342      991/iobroker.js-con
      tcp        0      0 192.168.178.58:1883     0.0.0.0:*               LISTEN      1002       25907      3925/io.mqtt.0
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          220655     23063/cupsd
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          15345      967/smbd
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          15344      967/smbd
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          14913      567/vncserver-x11-c
      tcp        0      0 0.0.0.0:4000            0.0.0.0:*               LISTEN      0          16237      1443/docker-proxy
      tcp        0      0 0.0.0.0:3100            0.0.0.0:*               LISTEN      0          16113      1302/docker-proxy
      tcp        0      0 0.0.0.0:7194            0.0.0.0:*               LISTEN      0          17174      1341/docker-proxy
      tcp        0      0 0.0.0.0:7190            0.0.0.0:*               LISTEN      0          17738      1249/docker-proxy
      tcp6       0      0 :::3000                 :::*                    LISTEN      116        19245      990/grafana
      tcp6       0      0 :::139                  :::*                    LISTEN      0          15343      967/smbd
      tcp6       0      0 :::445                  :::*                    LISTEN      0          15342      967/smbd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          220654     23063/cupsd
      tcp6       0      0 :::5900                 :::*                    LISTEN      0          14912      567/vncserver-x11-c
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        17426      555/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1002       26655      2937/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1002       24235      4073/io.web.0
      tcp6       0      0 :::4000                 :::*                    LISTEN      0          16240      1451/docker-proxy
      tcp6       0      0 :::3100                 :::*                    LISTEN      0          17162      1313/docker-proxy
      tcp6       0      0 :::7194                 :::*                    LISTEN      0          17177      1347/docker-proxy
      tcp6       0      0 :::7190                 :::*                    LISTEN      0          17141      1278/docker-proxy
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11680      399/avahi-daemon: r
      udp        0      0 0.0.0.0:34039           0.0.0.0:*                           108        11682      399/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11815      475/dhcpcd
      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          88759      545/nmbd
      udp        0      0 192.168.178.58:137      0.0.0.0:*                           0          88758      545/nmbd
      udp        0      0 172.19.255.255:137      0.0.0.0:*                           0          25133      545/nmbd
      udp        0      0 172.19.0.1:137          0.0.0.0:*                           0          25132      545/nmbd
      udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          25129      545/nmbd
      udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          25128      545/nmbd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          25125      545/nmbd
      udp        0      0 169.254.220.2:137       0.0.0.0:*                           0          25124      545/nmbd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          25121      545/nmbd
      udp        0      0 169.254.196.34:137      0.0.0.0:*                           0          25120      545/nmbd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          25117      545/nmbd
      udp        0      0 169.254.177.111:137     0.0.0.0:*                           0          25116      545/nmbd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          25113      545/nmbd
      udp        0      0 169.254.172.90:137      0.0.0.0:*                           0          25112      545/nmbd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          25109      545/nmbd
      udp        0      0 169.254.106.196:137     0.0.0.0:*                           0          25108      545/nmbd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          25105      545/nmbd
      udp        0      0 169.254.100.68:137      0.0.0.0:*                           0          25104      545/nmbd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          25101      545/nmbd
      udp        0      0 169.254.29.97:137       0.0.0.0:*                           0          25100      545/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          14971      545/nmbd
      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          88761      545/nmbd
      udp        0      0 192.168.178.58:138      0.0.0.0:*                           0          88760      545/nmbd
      udp        0      0 172.19.255.255:138      0.0.0.0:*                           0          25135      545/nmbd
      udp        0      0 172.19.0.1:138          0.0.0.0:*                           0          25134      545/nmbd
      udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          25131      545/nmbd
      udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          25130      545/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          25127      545/nmbd
      udp        0      0 169.254.220.2:138       0.0.0.0:*                           0          25126      545/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          25123      545/nmbd
      udp        0      0 169.254.196.34:138      0.0.0.0:*                           0          25122      545/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          25119      545/nmbd
      udp        0      0 169.254.177.111:138     0.0.0.0:*                           0          25118      545/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          25115      545/nmbd
      udp        0      0 169.254.172.90:138      0.0.0.0:*                           0          25114      545/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          25111      545/nmbd
      udp        0      0 169.254.106.196:138     0.0.0.0:*                           0          25110      545/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          25107      545/nmbd
      udp        0      0 169.254.100.68:138      0.0.0.0:*                           0          25106      545/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          25103      545/nmbd
      udp        0      0 169.254.29.97:138       0.0.0.0:*                           0          25102      545/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          14972      545/nmbd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          222416     23067/cups-browsed
      udp6       0      0 :::5353                 :::*                                108        11681      399/avahi-daemon: r
      udp6       0      0 :::42465                :::*                                108        11683      399/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          776265     475/dhcpcd
      2023-12-04 16:47:12.223  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 16:48:14.032  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 16:50:20.144  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 16:51:12.341  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 16:51:21.757  - info: solax.0 (4211) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
      2023-12-04 16:52:12.420  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 16:53:12.298  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 16:54:12.217  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 16:55:12.242  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 16:56:12.169  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 16:56:21.736  - info: solax.0 (4211) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
      2023-12-04 16:58:12.327  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 16:59:19.342  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 17:00:39.233  - info: admin.0 (2937) <== Disconnect system.user.admin from ::ffff:192.168.178.20
      2023-12-04 17:01:21.779  - info: solax.0 (4211) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
      2023-12-04 17:02:12.357  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 17:03:19.845  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 17:04:12.955  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 17:05:12.451  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 17:06:12.406  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 17:06:21.719  - info: solax.0 (4211) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
      2023-12-04 17:08:12.270  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 17:09:12.644  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 17:11:12.297  - info: tesla-motors.0 (4122) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 17:11:21.695  - info: solax.0 (4211) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
      Oh Gott...
      DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @ronk last edited by
        @ronk sagte in BackItUp erstellt keine backups mehr:
        und das bitte in CODETAGS packen 😉
          Thomas Braun Most Active @ronk last edited by
          @ronk
          Bis auf den laufenden Desktop-Mumpitz ist das okay.
          Schalt das Ding aus:
          sudo systemctl set-default multi-user.target
          sudo reboot
            ronk last edited by
            Der laufende Desktop-Mumpitz: ist das der, mit dem ich über RealVNC rankomme? Das würde ich schon gerne so lassen, wenns nicht schadet.
              @ronk
              Ja, und auch RealVNC wird nicht auf einem Server verwendet. Wozu auch? Da gibt es eh nix zu klicken oder zu sehen. ioBroker über WebGUI, das OS über die Kommandozeile.
                ronk @Thomas Braun last edited by
                @thomas-braun said in BackItUp erstellt keine backups mehr:
                @ronk
                Das verstehe ich schon. Ich bin aber nicht wirklich sattelfest mit der Kommandozeile... Schadet es denn...?
                  @ronk
                  Ja. Punkt.
                    @ronk
                    Ja. Punkt.
                    Gut. Ist weg.
                      @ronk
                      Gib nochmal die Zusammenfassung nach dem Reboot.
                        @ronk
                        Netzwerkfehler über putty. ssh ist doch richtig?
                          @ronk
                          Ja, natürlich per ssh.
                            ronk @Thomas Braun last edited by ronk
                            Komme nicht drauf. Port 22?
                              @ronk
                              Üblicherweise ist es Port 22.
                                @ronk
                                so. bin jetzt drauf. musste ssh starten.
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : arm64
                                 18:03:16 up 13 min,  2 users,  load average: 1.04, 1.36, 1.08
                                CPU threads: 4
                                Current issues:
                                               Local time: Mon 2023-12-04 18:03:16 CET
                                           Universal time: Mon 2023-12-04 17:03:16 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                ronny
                                /home/ronny
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                Boot Target:    multi-user.target
                                *** MEMORY ***
                                Mem:            3.8G        1.5G        660M        128M        1.6G        2.1G
                                Swap:            99M          0B         99M
                                Total:          3.9G        1.5G        760M
                                         3794 M total memory
                                         1520 M used memory
                                         2271 M active memory
                                          428 M inactive memory
                                          660 M free memory
                                          138 M buffer memory
                                         1474 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                tmpfs          tmpfs     759M  3.4M  756M   1% /run
                                tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                                [Mon Dec  4 17:49:55 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1680x1050M@60 smsc95xx.macaddr=D8:3A:DD:16:F4:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e446591d-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                [Mon Dec  4 17:49:56 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                                [Mon Dec  4 17:49:56 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                                [Mon Dec  4 17:49:57 2023] EXT4-fs (mmcblk0p2): recovery complete
                                [Mon Dec  4 17:49:57 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                [Mon Dec  4 17:49:57 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                [Mon Dec  4 17:50:00 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                /var:
                                10G     /var/
                                7.6G    /var/lib
                                205M    /opt/iobroker/iobroker-data/
                                12M     /opt/iobroker/iobroker-data/objects.jsonl
                                7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
                                USB-Devices by-id:
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.12.0
                                javascript:     7.1.6
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        3135
                                States:         3111
                                Hit:1 http://deb.debian.org/debian bullseye InRelease
                                Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                Hit:5 https://apt.grafana.com stable InRelease
                                Hit:6 https://download.docker.com/linux/debian bullseye InRelease
                                Pending Updates: 0
                                tcp        0      0 192.168.178.58:1883     0.0.0.0:*               LISTEN      1002       20354      3429/io.mqtt.0
                                tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          15448      951/smbd
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          23613      3593/sshd: /usr/sbi
                                tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          15447      951/smbd
                                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11746      547/cupsd
                                tcp        0      0 0.0.0.0:7190            0.0.0.0:*               LISTEN      0          18017      1552/docker-proxy
                                tcp        0      0 0.0.0.0:7194            0.0.0.0:*               LISTEN      0          17908      1369/docker-proxy
                                tcp        0      0 0.0.0.0:3100            0.0.0.0:*               LISTEN      0          17964      1465/docker-proxy
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       15968      733/iobroker.js-con
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       16007      733/iobroker.js-con
                                tcp        0      0 0.0.0.0:4000            0.0.0.0:*               LISTEN      0          17067      1514/docker-proxy
                                tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          11130      577/vncserver-x11-c
                                tcp6       0      0 :::139                  :::*                    LISTEN      0          15446      951/smbd
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          23615      3593/sshd: /usr/sbi
                                tcp6       0      0 :::445                  :::*                    LISTEN      0          13274      951/smbd
                                tcp6       0      0 :::3000                 :::*                    LISTEN      116        16296      732/grafana
                                tcp6       0      0 :::7190                 :::*                    LISTEN      0          18545      1559/docker-proxy
                                tcp6       0      0 :::7194                 :::*                    LISTEN      0          17911      1376/docker-proxy
                                tcp6       0      0 :::3100                 :::*                    LISTEN      0          17967      1471/docker-proxy
                                tcp6       0      0 :::4000                 :::*                    LISTEN      0          17072      1522/docker-proxy
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1002       22110      3489/io.admin.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1002       22130      3535/io.web.0
                                tcp6       0      0 :::8086                 :::*                    LISTEN      999        15368      564/influxd
                                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11745      547/cupsd
                                tcp6       0      0 :::5900                 :::*                    LISTEN      0          11129      577/vncserver-x11-c
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15318      480/dhcpcd
                                udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23297      550/nmbd
                                udp        0      0 169.254.251.49:137      0.0.0.0:*                           0          23296      550/nmbd
                                udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23293      550/nmbd
                                udp        0      0 169.254.224.59:137      0.0.0.0:*                           0          23292      550/nmbd
                                udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23289      550/nmbd
                                udp        0      0 169.254.176.113:137     0.0.0.0:*                           0          23288      550/nmbd
                                udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23285      550/nmbd
                                udp        0      0 169.254.166.163:137     0.0.0.0:*                           0          23284      550/nmbd
                                udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23281      550/nmbd
                                udp        0      0 169.254.137.51:137      0.0.0.0:*                           0          23280      550/nmbd
                                udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23277      550/nmbd
                                udp        0      0 169.254.124.18:137      0.0.0.0:*                           0          23276      550/nmbd
                                udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23273      550/nmbd
                                udp        0      0 169.254.88.37:137       0.0.0.0:*                           0          23272      550/nmbd
                                udp        0      0 172.19.255.255:137      0.0.0.0:*                           0          17877      550/nmbd
                                udp        0      0 172.19.0.1:137          0.0.0.0:*                           0          17876      550/nmbd
                                udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          17873      550/nmbd
                                udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          17872      550/nmbd
                                udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          13186      550/nmbd
                                udp        0      0 192.168.178.58:137      0.0.0.0:*                           0          13185      550/nmbd
                                udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          12987      550/nmbd
                                udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23299      550/nmbd
                                udp        0      0 169.254.251.49:138      0.0.0.0:*                           0          23298      550/nmbd
                                udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23295      550/nmbd
                                udp        0      0 169.254.224.59:138      0.0.0.0:*                           0          23294      550/nmbd
                                udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23291      550/nmbd
                                udp        0      0 169.254.176.113:138     0.0.0.0:*                           0          23290      550/nmbd
                                udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23287      550/nmbd
                                udp        0      0 169.254.166.163:138     0.0.0.0:*                           0          23286      550/nmbd
                                udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23283      550/nmbd
                                udp        0      0 169.254.137.51:138      0.0.0.0:*                           0          23282      550/nmbd
                                udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23279      550/nmbd
                                udp        0      0 169.254.124.18:138      0.0.0.0:*                           0          23278      550/nmbd
                                udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23275      550/nmbd
                                udp        0      0 169.254.88.37:138       0.0.0.0:*                           0          23274      550/nmbd
                                udp        0      0 172.19.255.255:138      0.0.0.0:*                           0          17879      550/nmbd
                                udp        0      0 172.19.0.1:138          0.0.0.0:*                           0          17878      550/nmbd
                                udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          17875      550/nmbd
                                udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          17874      550/nmbd
                                udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          13188      550/nmbd
                                udp        0      0 192.168.178.58:138      0.0.0.0:*                           0          13187      550/nmbd
                                udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          12988      550/nmbd
                                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          11761      620/cups-browsed
                                udp        0      0 0.0.0.0:33728           0.0.0.0:*                           108        12911      414/avahi-daemon: r
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12909      414/avahi-daemon: r
                                udp6       0      0 :::546                  :::*                                0          13087      480/dhcpcd
                                udp6       0      0 :::41701                :::*                                108        12912      414/avahi-daemon: r
                                udp6       0      0 :::5353                 :::*                                108        12910      414/avahi-daemon: r
                                2023-12-04 17:51:54.035  - info: tesla-motors.0 (3601) Session loaded
                                2023-12-04 17:51:54.036  - info: tesla-motors.0 (3601) Refresh session
                                2023-12-04 17:51:54.991  - info: tesla-motors.0 (3601) Receive device list
                                2023-12-04 17:51:55.323  - info: tesla-motors.0 (3601) Found 1 devices
                                2023-12-04 17:51:56.689  - info: accuweather.0 (3616) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.accuweather, node: v18.19.0, js-controller: 5.0.16
                                2023-12-04 17:51:56.876  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.energy_cost_breakdown.home.raw_value" has to be type "number" but received type "string"
                                2023-12-04 17:51:57.252  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points17.values05.raw_value" has to be type "number" but received type "string"
                                2023-12-04 17:51:57.253  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points17.values06.raw_value" has to be type "number" but received type "string"
                                2023-12-04 17:51:57.279  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points24.values05.raw_value" has to be type "string" but received type "number"
                                2023-12-04 17:51:57.283  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points24.values06.raw_value" has to be type "string" but received type "number"
                                2023-12-04 17:51:58.296  - info: host.raspberrypi instance system.adapter.vis-inventwo.0 started with pid 3633
                                2023-12-04 17:52:00.793  - info: vis-inventwo.0 (3633) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v18.19.0, js-controller: 5.0.16
                                2023-12-04 17:52:03.015  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJ3xxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
                                2023-12-04 17:52:03.411  - info: host.raspberrypi instance system.adapter.solax.0 started with pid 3649
                                2023-12-04 17:52:05.781  - info: solax.0 (3649) starting. Version 0.8.0 in /opt/iobroker/node_modules/iobroker.solax, node: v18.19.0, js-controller: 5.0.16
                                2023-12-04 17:52:06.872  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 3665
                                2023-12-04 17:52:09.178  - info: backitup.0 (3665) starting. Version 2.8.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.16
                                2023-12-04 17:52:09.278  - info: backitup.0 (3665) [iobroker] backup will be activated at 02:40 every 1 day(s)
                                2023-12-04 17:52:09.683  - info: solax.0 (3649) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
                                2023-12-04 17:53:56.485  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
                                2023-12-04 17:54:38.261  - info: admin.0 (3489) ==> Connected system.user.admin from ::ffff:192.168.178.20
                                2023-12-04 17:57:09.577  - info: solax.0 (3649) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
                                2023-12-04 18:01:56.126  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
                                2023-12-04 18:02:09.564  - info: solax.0 (3649) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
                                2023-12-04 18:03:02.529  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
                                  @ronk
                                  Immer sauber rebooten, nie einfach vom Strom reißen.
                                    ronk last edited by
                                    nochmal booten?
                                      @ronk
                                      War eigentlich ein allgemeiner Hinweis zum Umgang mit einem Betriebssystem. Die mögen das alle nicht.
                                        ronk last edited by
        v.2023-10-10
                                                 Icon name: computer
                                              Architecture: arm64
                                        Installation:           native
                                        Kernel:                 aarch64
                                        Userland:               arm64
                                        Timezone:               Europe/Berlin (CET, +0100)
                                        User-ID:                1000
                                        X-Server:               false
                                        Pending OS-Updates:     0
                                        Pending iob updates:    0
                                        Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
                                        Recommended versions are nodejs 18.19.0 and npm 10.2.3
                                        MEMORY:
                                        Mem:            3.8G        1.6G        485M        129M        1.7G        1.9G
                                        Swap:            99M          0B         99M
                                        Total:          3.9G        1.6G        585M
                                        Active iob-Instances:   14
                                        ioBroker Core:          js-controller           5.0.16
        admin                   6.12.0
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                3135
                                        States:                 3110
                                        Size of iob-Database:
                                        1.1M    /opt/iobroker/iobroker-data/states.jsonl
                                          ronk last edited by
                                          Influx db Sicherung läuft nun. Richtiger Token hilft. In Grafana finde ich keinen Token. Wo kann ich einen erstellen?
                                          • Marc Berg
                                            Marc Berg Most Active @ronk last edited by Marc Berg
                                            Service Accounts --> Add service account (Role "Admin") --> Token
                                            1240
