    4. Parsing Website Autogas
      Homoran Global Moderator Administrators @Flexer last edited by
      @flexer sagte in Parsing Website Autogas:
      @homoran Achso einfach nur rechte Maustaste Quelltext anzeigen lassen hab ich gemacht
      dann brauch ich das als text in code-tags
      kann ich am Tablet nicht machen
      Flexer 1 Reply Last reply Reply Quote 0
      • Flexer
        Flexer @Homoran last edited by Flexer
        @homoran So?
        <span class="name">Autogas</span>
                                            <span class="prix">0,999 &euro;</span>
          @homoran So?
          ist das alles?
          • Flexer
            @homoran Was brauchst du genau? Den ganzen Quelltext der Seite?
              @flexer prix\"\>([\d\,]+)
              ja, oder ist die "Lösung" bereits eindeutig?
              • Flexer
                <!DOCTYPE html>
                <html>
                <head>
                    <meta http-equiv="Content-Type" content="application/xhtml+xml; charset=UTF-8" />
                    <meta charset="utf-8" />
                    <meta name="viewport" content="width=device-width, initial-scale=1.0, minimum-scale=1.0, maximum-scale=1.0, user-scalable=no">
                    <meta property="og:type" content="article" />
                    <meta property="og:url" content="https://store.totalenergies.de/de_DE/ND000842" />
                    <meta property="og:description" />
                    <meta name="description" content="SCHWALMTAL">
                    <meta property="og:image" content="https://cf.vista.alzp.tgscloud.net/images-vista/TOTAL_ENERGIES.jpg" />
                    <meta property="og:title" content="SCHWALMTAL ND000842" />
                    <link rel="shortcut icon" href="/favicon.ico" />
                    <title>Tankstelle  SCHWALMTAL - SCHWALMTAL UNGERATH 301</title>
                    <!--[if IE 8]> <link href="/Content/Site-ie.css" type="text/css" rel="stylesheet" /> <![endif]-->
                    <link href="/Content/css?v=UNYHCRnraF_kl5hrcmuChVxd3p6cdAMqtpsiOSOTBQs1" rel="stylesheet"/>
                    <script src="/bundles/jquery?v=MZVaRGaAZivrCwFv-Q1F6rMPhQfwlY1fMhfjS2YKdJI1"></script>
                </head>
                <body>
                <script type="text/javascript">
                    var utag_data = {
                        page_section:"fichestation",
                        page_category:"Page_detail",
                        page_subcategory:"B002",
                        page_name:"ND000842",
                        page_type:"Station_detail",
                        site_name:"",
                        site_section:"1",
                        env_type:"PROD",
                        language:"3"
                </script>
                    (function (a, b, c, d) {
                        a = '//tags.tiqcdn.com/utag/totalms//prod/utag.js';
                        b = document; c = 'script'; d = b.createElement(c); d.src = a; d.type = 'text/java' + c; d.async = true;
                        a = b.getElementsByTagName(c)[0]; a.parentNode.insertBefore(d, a);
                </script>
                    $(window).on("load", function () {
                        var heightBlock = $("#info_block").height() + 20;
                        if (heightBlock > $('#mapa').height()) {
                            $('#mapa').css({ 'height': heightBlock });
                    $(window).resize(function () {
                        if (!$('#btnDetailMap').is(':visible')) {
                            $('#info_block').removeAttr('style');
                            $('#mapa').attr('style', $('#mapa').attr('style').split(';')[0] + ';');
                    $(function () {
                        $('#btnDetailMap').on('click', function (e) {
                            $('#info_block').toggle();
                            $('#mapa').toggle();
                            if ($('#info_block').is(':visible')) {
                                $(this).html('Karte');
                                $(this).attr('title', 'Karte');
                            } else {
                                $(this).html('TANKSTELLE');
                                $(this).attr('title', 'TANKSTELLE');
                </script>
                <div class="header">
                    <div id="logo">
                        <a href="https://www.totalenergies.de" title="TOTAL">
                            <img alt="TOTAL" title="TOTAL" src="/Content/images/header-logo-total.png" />
                        </a>
                    </div>
                </div>
                <div class="main">
                    <div class="block">
                        <div class="FileAriane"><h1 class="titre1">SCHWALMTAL : SCHWALMTAL UNGERATH 301</h1> <label class="titre2"></label></div>
                        <div class="info" id="info_block">
                            <img class="picto_top" alt="SCHWALMTAL UNGERATH 301" title="SCHWALMTAL UNGERATH 301" src="https://cf.vista.alzp.tgscloud.net/images-vista/TOTAL_ENERGIES.jpg" />
                            <div class="title">
                                <h2>SCHWALMTAL UNGERATH 301</h2>
                                    <span class="time">
                                        <img alt="Open" src="/Content/images/shopping.png" />
                                        <p>Heute: 06:00 - 23:00 </p>
                                    </span>
                                <span class="type">
                                </span>
                            </div>
                            <div class="clear"></div>
                            <div class="adress">
                                <h3>UNGERATH 301  </h3>
                                <h3>41366 SCHWALMTAL</h3>
                                <h3>GERMANY</h3>
                            </div>
                            <div class="horaire">
                                        <p>Montag: 06:00 - 23:00 </p>
                                        <p>Dienstag: 06:00 - 23:00 </p>
                                        <p>Mittwoch: 06:00 - 23:00 </p>
                                        <p>Donnerstag: 06:00 - 23:00 </p>
                                        <p>Freitag: 06:00 - 23:00 </p>
                                        <p>Samstag: 07:00 - 23:00 </p>
                                        <p>Sonntag: 08:00 - 23:00 </p>
                                        <p>Feiertage: 08:00 - 23:00 </p>
                            </div>
                            <div class="contact">
                                                <span>
                                                    <img alt="Total" src="/Content/images/fax1.png" />
                                                    <a class="tel" href="tel:02163-320176">02163-320176</a>
                                                </span>
                                                <span>
                                                    <img alt="Total" src="/Content/images/telephone.png" />
                                                    <a class="tel" href="tel:02163-943140"
                                                       onclick="utag.view({page_name:'fichestation',page_section:'Page_detail',page_name:'call_station',site_section:'1',language:'3',env_type:'PROD',site_name:''});">
                                                        02163-943140
                                                    </a>
                                                </span>
                            </div>
                            <div class="share">
                                <!-- Go to www.addthis.com/dashboard to generate a new set of sharing buttons -->
                                <a href="https://api.addthis.com/oexchange/0.8/forward/google_plusone_share/offer?url=http%3A%2F%2Fwww.addthis.com&pubid=ra-50c8bb7461aa7f5e&ct=1&title=AddThis%20-%20Get%20likes%2C%20get%20shares%2C%20get%20followers&pco=tbxnj-1.0" target="_blank"><img src="https://cache.addthiscdn.com/icons/v3/thumbs/32x32/google_plusone_share.png" border="0" alt="Google+" /></a>
                                <a href="https://api.addthis.com/oexchange/0.8/forward/facebook/offer?url=http%3A%2F%2Fwww.addthis.com&pubid=ra-50c8bb7461aa7f5e&ct=1&title=AddThis%20-%20Get%20likes%2C%20get%20shares%2C%20get%20followers&pco=tbxnj-1.0" target="_blank"><img src="https://cache.addthiscdn.com/icons/v3/thumbs/32x32/facebook.png" border="0" alt="Facebook" /></a>
                                <a href="https://api.addthis.com/oexchange/0.8/forward/twitter/offer?url=http%3A%2F%2Fwww.addthis.com&pubid=ra-50c8bb7461aa7f5e&ct=1&title=AddThis%20-%20Get%20likes%2C%20get%20shares%2C%20get%20followers&pco=tbxnj-1.0" target="_blank"><img src="https://cache.addthiscdn.com/icons/v3/thumbs/32x32/twitter.png" border="0" alt="Twitter" /></a>
                                <a href="https://www.addthis.com/bookmark.php?source=tbx32nj-1.0&v=300&url=http%3A%2F%2Fwww.addthis.com&pubid=ra-50c8bb7461aa7f5e&ct=1&title=AddThis%20-%20Get%20likes%2C%20get%20shares%2C%20get%20followers&pco=tbxnj-1.0" target="_blank"><img src="https://cache.addthiscdn.com/icons/v3/thumbs/32x32/addthis.png" border="0" alt="Addthis" /></a>
                            </div>
                        </div>
                        <div class="go-mobile">
                            <a id="btnDetailMap" href="#" title="Karte">Karte</a>
                            <a href="http://maps.apple.com/?q=51.2086,6.2808"
                               onclick="utag.view({page_name:'fichestation',page_section:'Page_detail',page_name:'go_to_station',site_section:'1',language:'3',env_type:'PROD',site_name:''});"
                               title="Route">Route</a>
                        </div>
                        <div class="map" id="mapa">
                            <iframe src="https://totalms.webgeoservices.com/maps/embed/?device=mobile-detail&storeId=ND000842&languageGoogleMaps=de&languageTranslation=de_DE"></iframe>
                        </div>
                    </div>
                                <div class="block">
                                    <h2>Autopflege</h2>
                                    <ul class="service">
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/wash_card_DE.png" alt="Autow&#228;sche" title="Autow&#228;sche" />
                                                <span class="name">Autow&#228;sche</span>
                                            </li>
                                    </ul>
                                </div>
                                <div class="block">
                                    <h2>KARTENAKZEPTANZ</h2>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/ENI.png" alt="ENI" title="ENI" />
                                                <span class="name">ENI</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/Aral.png" alt="Aral" title="Aral" />
                                                <span class="name">Aral</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/ClubCard.png" alt="Club TotalEnergies Germany" title="Club TotalEnergies Germany" />
                                                <span class="name">Club TotalEnergies Germany</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/amex_de.png" alt="American Express" title="American Express" />
                                                <span class="name">American Express</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/dkv_de.png" alt="DKV" title="DKV" />
                                                <span class="name">DKV</span>
                                            </li>
                                            <li>
                                                    <img src="http://cf.vista.alzp.tgscloud.net/websites/Girocard.png" alt="Girocard" title="Girocard" />
                                                <span class="name">Girocard</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/eurotrafic_de.png" alt="Eurotrafic" title="Eurotrafic" />
                                                <span class="name">Eurotrafic</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/maestro_de.png" alt="Maestro" title="Maestro" />
                                                <span class="name">Maestro</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/Fleetcard711304.png" alt="Fleet Card" title="Fleet Card" />
                                                <span class="name">Fleet Card</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/uta_de.png" alt="UTA" title="UTA" />
                                                <span class="name">UTA</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/westfalen_de.png" alt="Westfalen" title="Westfalen" />
                                                <span class="name">Westfalen</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/Fleetcard710009.png" alt="Fleet Card Lokal" title="Fleet Card Lokal" />
                                                <span class="name">Fleet Card Lokal</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/mastercard_de.png" alt="Mastercard" title="Mastercard" />
                                                <span class="name">Mastercard</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/visa_de.png" alt="Visa" title="Visa" />
                                                <span class="name">Visa</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/vpay.png" alt="VPay" title="VPay" />
                                                <span class="name">VPay</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/Mol_fr.png" alt="MOL" title="MOL" />
                                                <span class="name">MOL</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/Apple_Pay.png" alt="Apple Pay" title="Apple Pay" />
                                                <span class="name">Apple Pay</span>
                                            </li>
                                            <li>
                                                    <img src="http://cf.vista.alzp.tgscloud.net/images-vista/Gutscheinkarte_Final.png" alt="TotalEnergies Geschenkgutscheine" title="TotalEnergies Geschenkgutscheine" />
                                                <span class="name">TotalEnergies Geschenkgutscheine</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/Google_Pay.png" alt="Google Pay" title="Google Pay" />
                                                <span class="name">Google Pay</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/LogPay.png" alt="LogPay" title="LogPay" />
                                                <span class="name">LogPay</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/prepaidmobilitycard.png" alt="Prepaid Mobility Karte" title="Prepaid Mobility Karte" />
                                                <span class="name">Prepaid Mobility Karte</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/Avia_de.png" alt="Avia" title="Avia" />
                                                <span class="name">Avia</span>
                                            </li>
                                    </ul>
                                </div>
                                <div class="block">
                                    <h2>PRODUKTE</h2>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/adblue_de.png" alt="AdBlue&#174;" title="AdBlue&#174;" />
                                                <span class="name">AdBlue&#174;</span>
                                                    <span class="prix">1,359 &euro;</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/supere10.png" alt="Super E10" title="Super E10" />
                                                <span class="name">Super E10</span>
                                                    <span class="prix">1,669 &euro;</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/Excellium98_de.png" alt="Excellium Super plus" title="Excellium Super plus" />
                                                <span class="name">Excellium Super plus</span>
                                                    <span class="prix">1,899 &euro;</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/sp95_de.png" alt="Super" title="Super" />
                                                <span class="name">Super</span>
                                                    <span class="prix">1,729 &euro;</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/ExcelliumDiesel_de.png" alt="Excellium Diesel" title="Excellium Diesel" />
                                                <span class="name">Excellium Diesel</span>
                                                    <span class="prix">1,809 &euro;</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/diesel_de.png" alt="Diesel" title="Diesel" />
                                                <span class="name">Diesel</span>
                                                    <span class="prix">1,639 &euro;</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/dieseltruck_de.png" alt="Truck Diesel" title="Truck Diesel" />
                                                <span class="name">Truck Diesel</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/gpl_de.png" alt="Autogas" title="Autogas" />
                                            </li>
                                    </ul>
                                        <div class="fuel-legal">Alle Angaben ohne Gew&#228;hr. Es gelten die Preise an der Tankstelle. Alle Preise in EUR &nbsp;: 2023-12-04 21:32:41</div>
                                </div>
                                <div class="block">
                                    <h2>RESTAURANT</h2>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/TotalEnergies_cafeBonjour_Logo-rgb.png" alt="Caf&#233; Bonjour" title="Caf&#233; Bonjour" />
                                                <span class="name">Caf&#233; Bonjour</span>
                                            </li>
                                    </ul>
                                </div>
                                <div class="block">
                                    <h2>SERVICES</h2>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/cashdispenser_de.png" alt="Geldautomat" title="Geldautomat" />
                                                <span class="name">Geldautomat</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/adbluebottles_de.png" alt="AdBlue&#174; im Gebinde" title="AdBlue&#174; im Gebinde" />
                                                <span class="name">AdBlue&#174; im Gebinde</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/wifi_de.png" alt="Wifi" title="Wifi" />
                                                <span class="name">Wifi</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/garage_de.png" alt="Autowerkstatt" title="Autowerkstatt" />
                                                <span class="name">Autowerkstatt</span>
                                            </li>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/wash_card_DE.png" alt="TotalEnergies Waschkarte" title="TotalEnergies Waschkarte" />
                                                <span class="name">TotalEnergies Waschkarte</span>
                                            </li>
                                    </ul>
                                </div>
                                <div class="block">
                                    <h2>SHOP</h2>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/lubricant_de.png" alt="Quartz Motor&#246;l" title="Quartz Motor&#246;l" />
                                                <span class="name">Quartz Motor&#246;l</span>
                                            </li>
                                    </ul>
                                </div>
                                <div class="block">
                                    <h2>TotalEnergies Truck</h2>
                                            <li>
                                                    <img src="https://cf.vista.alzp.tgscloud.net/images-vista/TotalTruck_fr_fr.png" alt="TotalEnergies Truck" title="TotalEnergies Truck" />
                                                <span class="name">TotalEnergies Truck</span>
                                            </li>
                                    </ul>
                                </div>
                            <div class="block">
                            <h2>DIE N&#196;CHSTGELEGENEN STANDORTE</h2>
                            <ul class="stations-links">
                                    <li><a href="https://store.totalenergies.de/de_DE/ND000759" title="MOENCHENGLADBACH BAHNSTR. 174 MOENCHENGLADBACH">TANKSTELLE TOTALENERGIES MOENCHENGLADBACH BAHNSTR. 174 (MOENCHENGLADBACH) 9,6km</a></li>
                                    <li><a href="https://store.totalenergies.de/de_DE/ND000133" title="MOENCHENGLADBACH DAHLENER STR.520 MOENCHENGLADBACH">TANKSTELLE TOTALENERGIES MOENCHENGLADBACH DAHLENER STR.520 (MOENCHENGLADBACH) 10,9km</a></li>
                                    <li><a href="https://store.totalenergies.de/de_DE/ND123890" title="WILLICH HAUPTSTR.149 WILLICH">TANKSTELLE TOTALENERGIES WILLICH HAUPTSTR.149 (WILLICH) 15,4km</a></li>
                                    <li><a href="https://store.totalenergies.de/de_DE/NN001075" title="ROERMOND-HOOGVONDEREN ROERMOND">TANKSTELLE TOTALENERGIES ROERMOND-HOOGVONDEREN (ROERMOND) 17,7km</a></li>
                                    <li><a href="https://store.totalenergies.de/de_DE/NN001936" title="TEGELEN INZ VISSERS TEGELEN">TANKSTELLE TOTALENERGIES TEGELEN INZ VISSERS (TEGELEN) 18,4km</a></li>
                            </ul>
                        </div>
                    <div class="block footer">
                        <ul>
                            <li><a href="http://www.total.de/kontakt-fuer-privatkunden/rechtlicher-hinweis.html" title="Rechtlicher Hinweis">Rechtlicher Hinweis</a></li>
                            <li> <a href="/SiteMap">Decouvrez toutes nos stations</a></li>
                        </ul>
                    </div>
                </div>
                </body>
                </html>
                • Flexer
                  Flexer @Flexer last edited by
                  @flexer @Homoran Also klappt fast. Habe jetzt den Preis von Adblue nicht von Autogas im Datenpunkt 😉
                    Homoran Global Moderator Administrators @Flexer last edited by Homoran
                    Also klappt fast.
                    ja, musst num=8 nehmen, oder gas[^x]+x\"\>([\d\,]+)
                    Deswegen braucht man immer alles, den Regexgab es 8x im Quelltext
                    • Flexer
                      @homoran sagte in Parsing Website Autogas:
                      gas[^x]+x">([\d,]+)
                      Mega geil! Danke hat geklappt!! Aber wie kommt man denn auf diesen Ausdruck? Ich verstehe null die Logik dahinter. Wie kommt man da drauf?
                        ist doch ganz einfach 😂
                        musst nach etwas eindeutigem suchen, notfalls in Kombination
                        gas[^x]+x">([\d,]+)
                        finde gas
                        dann überspringe alles bis auf x [^x]+
                        dann das x, die Anführungsstriche und den größer als x\"\> sicherheitshalber escaped mit dem Backslash, damit es nicht als Operand gesehen wird
                        Jetzt das Gewünschte Ergebnis in runden Klammern, bestehend aus mehreren digits und Kommas ([\d\,]+)
                        Hier nochmal zum nachlesen
                        Flexer Albert K 3 Replies Last reply Reply Quote 1
                        • Flexer
                          @homoran Wow ok danke da muss ich mich mal reinarbeiten!!!
                          Danke!
                          • OliverIO
                            OliverIO @Flexer last edited by
                            @flexer
                            so müsste es funktionieren
                            typ number, und komma ankreuzen
                            regex:
                            <span class="name">Autogas<\/span>\s+<span class="prix">([\d,]+) &euro;<\/span>
                            Flexer OliverIO 2 Replies Last reply Reply Quote 0
                            • Flexer
                              Flexer @OliverIO last edited by
                              Also wenn ich das Number machen will macht er 999 draus?!??
                              • OliverIO
                                OliverIO @OliverIO last edited by OliverIO
                                @Flexer
                                @oliverio sagte in Parsing Website Autogas:
                                und komma ankreuzen
                                nochmal auf das komma klicken.
                                bei mir ist es immer angekreuzt, aber wenn man klickt wechselt es intern wohl von angekreuzt und zurück.
                                das ergebnis passt sich dann dynamisch an
                                • Albert K
                                  Albert K @Homoran last edited by
                                  Danke auch von mir. Damit habe ich es endlich geschafft den Preis meiner Stamm Tankstelle in Österreich zu parsen! 👍 👍 👍
                                  • Flexer
                                    @homoran Hallo und guten Morgen, ich muss leider nochmal was nachfragen.
                                    Leider kann ich den Wert nicht als Zahl in Grafana loggen. Ich bekomme die Fehlermeldung dass es ein String sei.
                                    Es soll aber eine Zahl sein
                                    Hat jemand eine Idee?
                                    • mickym
                                      mickym Most Active @Flexer last edited by mickym
                                      Gelöscht - da unpassender Beitrag
                                      • Flexer
                                        Flexer @mickym last edited by
                                        @mickym Huch was wurde denn hier gelöscht?
                                        • Marc Berg
                                          Marc Berg Most Active last edited by
                                          Die Tatsache, dass JETZT nur noch Number gespeichert werden soll, heißt ja nicht, dass nicht schon Strings drin stehen.
                                          Schau dir mal im Influx Data Explorer den Datentyp an. Einfach die Abfrage (ohne Aggregate) einfügen und "Raw Data" anklicken.
                                          • mickym
                                            @flexer Mein eigener Beitrag - da ich mich mit dem Parser Adapter nicht auskenne und da halt keine Zahl sondern ein String rauskommt. Deswegen arbeite ich ja lieber mit einem anderen Tool. Sorry für die Verwirrung.
                                            1020
