    3. Entwicklung
    4. [Neuer Adapter] Reolink Kamera
      Wolfi last edited by
      Aktuell ist immer noch die Version 0.1.1 ist das richtig!
      oelison 1 Reply Last reply Reply Quote 1
      • oelison
        oelison @Wolfi last edited by oelison
        @wolfi Ja. Bis gerade eben. Jetzt gibt es die 0.1.2.
          Hohenbostler last edited by Hohenbostler
          Hi ich habe auch durch zufall den Adapter entdeckt und wollte Ihn mit meiner E1 Outdoor testen. Leider erfolglos.
          Jemand eine Idee ? Per ApI bekomme ich folgende antwort der CAM
          [ { "cmd" : "GetDevInfo", "code" : 0, "value" : { "DevInfo" : { "B485" : 0, "IOInputNum" : 0, "IOOutputNum" : 0, "audioNum" : 1, "buildDay" : "build 23083102", "cfgVer" : "v3.1.0.0", "channelNum" : 1, "detail" : "IPC_566SD85MPS10E1WC1100000001", "diskNum" : 1, "exactType" : "WIFI_SOLO_IPC", "firmVer" : "v3.1.0.2649_23083102", "frameworkVer" : 1, "hardVer" : "IPC_566SD85MP", "model" : "E1 Outdoor", "name" : "Camera1", "pakSuffix" : "pak,paks", "serial" : "268154102087680", "type" : "IPC", "wifi" : 1 } } } ]
          Im iobroker sieht es so aus.
          reolink.0
          	2023-11-07 09:11:04.628	error	AxiosError: Request failed with status code 400: ERR_BAD_REQUEST
          reolink.0
          	2023-11-07 09:11:04.435	info	Current IP: 192.168.178.124
          reolink.0
          	2023-11-07 09:11:04.432	info	Reolink adapter has started
          reolink.0
          	2023-11-07 09:11:04.402	info	starting. Version 0.1.2 (non-npm: aendue/ioBroker.reolink#7b802676e71a245acf518c108dec5fee5f2c2d9d) in /opt/iobroker/node_modules/iobroker.reolink, node: v18.17.1, js-controller: 5.0.12
          reolink.0
          	2023-11-07 09:10:58.661	info	terminating
          reolink.0
          	2023-11-07 09:10:58.159	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          reolink.0
          	2023-11-07 09:10:58.158	info	terminating
          reolink.0
          	2023-11-07 09:10:58.157	info	Got terminate signal TERMINATE_YOURSELF
          reolink.0
          	2023-11-07 09:07:53.469	error	AxiosError: Request failed with status code 400: ERR_BAD_REQUEST
          reolink.0
          	2023-11-07 09:07:53.209	info	Current IP: 192.168.178.124
          reolink.0
          	2023-11-07 09:07:53.204	info	Reolink adapter has started
          reolink.0
          	2023-11-07 09:07:53.161	info	starting. Version 0.1.2 (non-npm: aendue/ioBroker.reolink#7b802676e71a245acf518c108dec5fee5f2c2d9d) in /opt/iobroker/node_modules/iobroker.reolink, node: v18.17.1, js-controller: 5.0.12
          reolink.0
          	2023-11-07 09:07:47.488	info	terminating
          reolink.0
          	2023-11-07 09:07:46.984	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          reolink.0
          	2023-11-07 09:07:46.982	info	terminating
          reolink.0
          	2023-11-07 09:07:46.979	info	Got terminate signal TERMINATE_YOURSELF
          reolink.0
          	2023-11-07 09:04:28.282	error	AxiosError: Request failed with status code 400: ERR_BAD_REQUEST
          reolink.0
          	2023-11-07 09:04:27.749	info	Current IP: 192.168.178.124
          reolink.0
          	2023-11-07 09:04:27.726	info	Reolink adapter has started
          reolink.0
          	2023-11-07 09:04:27.404	info	starting. Version 0.1.2 (non-npm: aendue/ioBroker.reolink#7b802676e71a245acf518c108dec5fee5f2c2d9d) in /opt/iobroker/node_modules/iobroker.reolink, node: v18.17.1, js-controller: 5.0.12
          reolink.0
          	2023-11-07 09:04:19.085	info	terminating
          reolink.0
          	2023-11-07 09:04:18.583	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          reolink.0
          	2023-11-07 09:04:18.582	info	terminating
          reolink.0
          	2023-11-07 09:04:18.580	info	Got terminate signal TERMINATE_YOURSELF
          reolink.0
          	2023-11-07 08:24:35.389	error	AxiosError: Request failed with status code 400: ERR_BAD_REQUEST
          reolink.0
          	2023-11-07 08:24:35.142	info	Current IP: 192.168.178.124
          reolink.0
          	2023-11-07 08:24:35.139	info	Reolink adapter has started
          • N
            noidea last edited by
            Hallo Zusammen,
            ich bin seit gestern auch Besitzer einer Reolink E1 Outdoor. Ich kann per App als auch über Web Browser auf die Kamera zugreifen. Soweit so gut. Allerdings bekomme ich es nicht hin, das sich der Adapter mit der Kamera verbindet. Im Protokoll sehe ich folgende Fehlermeldung:
            Im Adapter habe ich folgende Eingetragen:
            Habe ich da irgendwas übersehen oder nicht beachtet?
            Wahrscheinlich liegt das Problem wieder schön zwischen den Ohren 🙂
            Vielen Dank und schöne Grüße
            B Axel Koeneke 2 Replies Last reply Reply Quote 0
              bommel_030 @noidea last edited by
              @noidea
              Hast du mal den Namen statt der IP versucht? Bei mir laufen 2 mit der IP, die 3. will nur mit FQDN angesprochen werden.
              • N
                noidea @bommel_030 last edited by
                @bommel_030
                Danke für die Info. Ich habe den Adapter jetzt noch mal neu installiert, was ich vorher auch schon mal gemacht hatte, und aus irgendeinem Grund funktioniert es jetzt. Ich habe keine Erklärung dafür. Vielleicht lag es irgendwie mit dem vorhin durchfegührtem Firmware Update der Kamera zusammen.
                Aber danke für den Tipp?
                  Wolfi @skvarel last edited by
                  @skvarel
                  Hallo hast du den Export deiner Vis schon gemacht?
                  Gruss
                    bommel_030 last edited by bommel_030
                    Mittlerweile ist hier auch ein PTZ-fähige Reolink angekommen. E1 Outdoor POE
                    Ich kann Preset Punkte anfahren, den Guard de-/aktivieren und dessen Zeit einstellen, aber beim Patrol scheitere ich...
                    Was muss ich da eingeben? 0 für aus, 1 für an? Egal was ich eingebe, ich bekomme nur:
                    reolink.1
                    2023-11-28 15:52:10.528	error	not defined
                    reolink.1
                    2023-11-28 15:52:10.528	error	sendCmd PtzCtrl: "set config failed"
                    reolink.1
                    2023-11-28 15:52:10.528	debug	[{"cmd":"PtzCtrl","code":1,"error":{"detail":"set config failed","rspCode":-13}}]
                    reolink.1
                    2023-11-28 15:52:10.528	debug	200
                    reolink.1
                    2023-11-28 15:52:10.362	debug	sendCmdObj: [{"cmd":"PtzCtrl","param":{"channel":0,"op":"StartPatrol","id":1}}]
                    reolink.1
                    2023-11-28 15:52:10.362	debug	sendCmd: PtzCtrl
                    reolink.1
                    2023-11-28 15:52:10.361	info	Changed state: ptzPatrol
                    reolink.1
                    2023-11-28 15:52:10.361	debug	state reolink.1.settings.ptzPatrol changed: 1 (ack = false)
                    Nachtrag
                    Laut Reolink (https://support.reolink.com/hc/en-us/articles/360039467593-How-to-Set-up-Preset-and-Patrol-for-Reolink-Cameras/) kann die E1 gar kein Patrol, hat sich also erledigt.
                    oelison 1 Reply Last reply Reply Quote 0
                    • Axel Koeneke
                      Axel Koeneke @noidea last edited by
                      @noidea sagte in [Neuer Adapter] Reolink Kamera:
                      Hallo Zusammen,
                      Hallo @noidea,
                      vermutlich hast du das gleiche Problem was auch mich beinahe wahnsinnig gemacht hat:
                      Wenn man eine Instanz anlegt und die IP-Adresse eingibt, dann ist da automatisch schon eine Leerstelle vor deiner Eingabe.
                      Das fällt aber leider nicht gleich auf, da nur ein kleiner Platz vor der "1" entsteht.
                      Dies ist reproduzierbar - also ein BUG 🙂
                      @oelison bitte selbst mal testen.
                      VG
                      Axel
                      N M 2 Replies Last reply Reply Quote 1
                      • skvarel
                        skvarel Developer @spanier last edited by skvarel
                        @wolfi sagte in [Neuer Adapter] Reolink Kamera:
                        @skvarel
                        Gruss
                        .. das habe völlig vergessen. Sorry. Hole ich die Woche auf jeden Fall nach!
                        • oelison
                          oelison @bommel_030 last edited by
                          @bommel_030 Geht sowieso nicht. PTZ patrol braucht etwas mehr als nur ein Parameter. Das sollten wir aus dem Adapter löschen.
                            So bin endlich mal dazu gekommen und habe mein Adapter auf die Neuste Version (1.0.1) aktualisiert und siehe da Preset funktioniert auch.
                            Super Danke
                            (E1 Outdoor)
                              spike2 last edited by
                              Kann man mit dem Datenpunkt "reolink.0.settings.playAlarm" die Sirene an der Kamera auslösen ?
                              Also der Test hat nicht geklappt, vielleicht ein falscher Parameter?
                              • N
                                noidea @Axel Koeneke last edited by
                                @axel-koeneke
                                Haha. Ja genau das war das Problem bei mir. Hätte ich auch schreiben können, falls andere auch das Problem haben 🤔
                                Aber danke für Deinen Hinweis 🖖
                                • N
                                  Ist eigentlich geplant, in Zukunft die Datenpunkte für die Zeiten für die Aufnahme mit aufzunehmen?
                                  Ich würde nämlich gerne so etwas wie einen Urlaubsmodus integrieren und dann entsprechend den Timer für die Aufnahmen anpassen.
                                  • Ralf_N
                                    Ralf_N last edited by
                                    Hallo zusammen.
                                    Beim update für mein Reolink RLC-523WA über GH von der Version 0.1.1 auf die Version 1.01 bekomme ich danach folgen Fehler und der Adpter bleibt gelb
                                    "TypeError: Cannot read properties of undefined (reading 'DevInfo'): undefined"
                                    Alle meine Suchen blieben ohne Erfolg. 😖
                                    Wonach muss ich schauen ?
                                    Danke Euch.
                                    Ralf_N 1 Reply Last reply Reply Quote 0
                                    • Ralf_N
                                      Ralf_N @Ralf_N last edited by
                                      @ralf_n sagte in [Neuer Adapter] Reolink Kamera:
                                      Hallo zusammen.
                                      Danke Euch.
                                      Nach löschen und erneuter Eingabe : User/Passwort geht der Adapter nun auf GRUEN 🙂
                                      Könnte man ja mal irgendwo erwähnen ....
                                      Danke Euch.
                                        brokeling @Ralf_N last edited by brokeling
                                        Kann man eigentlich bei der reolink Kamera (E1 Outdoor) eine Aufnahme auf sd Karte mit iobroker starten???
                                        Hatte das bisher eigentlich nicht gebraucht und nie danach gesucht.
                                        Da finde ich leider nichts...
                                        Oder dass ein Kameraalarm (oder -aufnahme) eine andere Kameraaufnahme mit auslöst. Wäre auch gut.
                                          Bert 0 last edited by Bert 0
                                          habe hier eine Reolink E1 Zoom. Ich schaffe es nicht diese in den IOBroker mit diesem Adapter einzubinden. Passwort habe ich schon mehrfach neu eingetragen. Über eine normale Http Seite komme ich mit dem Benutzer und dem Passwort in die Kamera rein. Gibt es bei den Passwort irgendwelche Vorraussetzungen? Ich habe ein ziemlich langes Passwort mit vielen Sonderzeichen...
                                          reolink.0
                                          	2023-12-11 15:04:33.611	error	TypeError: Cannot read properties of undefined (reading 'DevInfo'): undefined
                                          reolink.0
                                          	2023-12-11 15:04:33.559	debug	camMdStateInfo 200: [{"cmd":"GetDevInfo","code":1,"error":{"auth_warning_info":{"remain_times":10,"unlock_time":0},"detail":"password wrong","rspCode":-502}}]
                                          reolink.0
                                          	2023-12-11 15:04:33.228	debug	getDevinfo
                                          reolink.0
                                          	2023-12-11 15:04:33.123	info	Current IP: 192
                                          Jemand eine Idee?
                                          • oelison
                                            oelison @Bert 0 last edited by
                                            @bert-0 Ja. Siehe github iobroker reolink err 22.
                                            Es gibt wohl ein paar Sonderzeichen die nicht richtig "escaped" werden. Ich habe mich da noch nicht drum gekümmert, da ich den Fehler noch nicht hatte. Wäre mal gut, wenn jemand schauen könnte welche Sonderzeichen den Ärger machen und am Ticket anhängen könnten.
                                            kamera neuer adapter reolink testen
                                            157
                                            1074
                                            449068
