    3. Einsteigerfragen
    4. Installation
    5. ioBroker neu aufgesetzt, VIS läßt sich nicht installieren
      Homoran Global Moderator Administrators @stoffel67 last edited by Homoran
      @stoffel67 sagte in ioBroker neu aufgesetzt, VIS läßt sich nicht installieren:
      was läuft hier falsch?
      vis muss wegen eines Dauerbugs vor dem Restore installiert werden
      Workaround
      iob install vis@1.4.10 und dann updaten
        stoffel67 @Homoran last edited by
        da bekomm ich folgendes:
        pi@raspip:~ $ iob install vis@1.4.10
        NPM version: 10.2.3
        Installing iobroker.vis@1.4.10... (System call)
        npm ERR! code 6
        npm ERR! path /opt/iobroker/node_modules/iobroker.vis
        npm ERR! command failed
        npm ERR! command sh -c node main.js --install
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-05T13_43_27_831Z-debug-0.log
        host.raspip Cannot install iobroker.vis@1.4.10: 6
        pi@raspip:~ $
          Thomas Braun Most Active @stoffel67 last edited by
          @stoffel67
          iob update
          iob upgrade vis@1.4.10
            stoffel67 @Thomas Braun last edited by
            i@raspip:/opt/iobroker/node_modules/iobroker.enet $ iob update
            Used repository: stable
            Adapter    "admin"        : 6.12.0   , installed 6.12.0
            Adapter    "backitup"     : 2.8.7    , installed 2.8.7
            Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
            Adapter    "ds18b20"      : 2.0.5    , installed 2.0.4  [Updatable]
            Adapter    "email"        : 1.2.0    , installed 1.2.0
            Adapter    "enet"         : 1.0.1    , installed 1.0.2
            Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
            Adapter    "javascript"   : 7.1.6    , installed 7.1.4  [Updatable]
            Controller "js-controller": 5.0.16   , installed 5.0.16
            Adapter    "mobile"       : 1.0.1    , installed 1.0.1
            Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
            Adapter    "pushover"     : 3.0.3    , installed 3.0.3
            Adapter    "shelly"       : 6.6.1    , installed 6.6.1
            Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
            Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
            Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
            Adapter    "web"          : 6.1.10   , installed 6.1.10
            Adapter    "ws"           : 2.5.8    , installed 2.5.8
            Adapter    "yahka"        : 1.0.3    , installed 1.0.3
            pi@raspip:/opt/iobroker/node_modules/iobroker.enet $
            pi@raspip:/opt/iobroker/node_modules/iobroker.enet $ iob upgrade vis@1.4.10
            Adapter "vis"            is not installed.
              @stoffel67
              iob add vis@1.4.10
                gleicher Fehler
                pi@raspip:/opt/iobroker $ iob add vis@1.4.10
                NPM version: 10.2.3
                npm ERR! code 6
                npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-05T14_08_10_927Z-debug-0.log
                  @stoffel67
                  iob add vis
                    stoffel67 @Thomas Braun last edited by stoffel67
                    NPM version: 10.2.3
                    Installing iobroker.vis@1.4.16... (System call)
                    npm ERR! code 6
                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-05T14_10_26_946Z-debug-0.log
                    host.raspip Cannot install iobroker.vis@1.4.16: 6
                    oder mit "sudo..."
                      @stoffel67
                      iob diag
                      sagt in der Langfassung?
                      • Marc Berg
                        Marc Berg Most Active last edited by
                        Musste man in der VIS Version nicht noch weiter zurückgehen? 1.4.6 oder so?
                        S 1 Reply Last reply Reply Quote 2
                          stoffel67 @Thomas Braun last edited by Homoran
                          ist aber viel...
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                           Static hostname: raspip
                                 Icon name: computer
                                    Kernel: Linux 6.1.0-rpi6-rpi-v8
                              Architecture: arm64
                          Model		: Raspberry Pi 4 Model B Rev 1.1
                          Docker          : false
                          Virtualization  : none
                          Kernel          : aarch64
                          Userland        : arm64
                          Systemuptime and Load:
                           15:13:13 up 45 min,  3 users,  load average: 4.47, 3.79, 3.11
                          CPU threads: 4
                          *** RASPBERRY THROTTLING ***
                          Current issues:
                          Previously detected issues:
                          *** Time and Time Zones ***
                                         Local time: Tue 2023-12-05 15:13:13 CET
                                     Universal time: Tue 2023-12-05 14:13:13 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          *** User and Groups ***
                          pi
                          /home/pi
                          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                          *** X-Server-Setup ***
                          X-Server: 	false
                          Desktop: 	LXDE-pi-wayfire
                          Terminal: 	wayland
                          Boot Target: 	graphical.target
                          *** MEMORY ***
                          Mem:            4.0G        2.4G        865M        164M        964M        1.5G
                          Swap:           104M          0B        104M
                          Total:          4.1G        2.4G        970M
                                   3792 M total memory
                                   2319 M used memory
                                   2545 M active memory
                                    114 M inactive memory
                                    825 M free memory
                                     14 M buffer memory
                                    905 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FAILED SERVICES ***
                          0 loaded units listed.
                          *** FILESYSTEM ***
                          udev           devtmpfs  1.6G     0  1.6G   0% /dev
                          tmpfs          tmpfs     380M  1.4M  378M   1% /run
                          /dev/sda2      ext4      235G  6.5G  216G   3% /
                          tmpfs          tmpfs     1.9G   30M  1.9G   2% /dev/shm
                          /dev/sda1      vfat      510M   74M  437M  15% /boot/firmware
                          tmpfs          tmpfs     380M   40K  380M   1% /run/user/1000
                          [Tue Dec  5 14:27:14 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:45:C1:49 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=fa6f7a9b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                          [Tue Dec  5 14:27:19 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                          [Tue Dec  5 14:27:21 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                          TARGET               SOURCE    FSTYPE      OPTIONS
                          /                    /dev/sda2 ext4        rw,noatime
                          |-/run/user/1000/doc portal    fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                          `-/boot/firmware     /dev/sda1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          /var:
                          846M	/var/
                          474M	/var/cache
                          467M	/var/cache/apt
                          355M	/var/cache/apt/archives
                          201M	/var/lib
                          Archived and active journals take up 68.3M in the file system.
                          /opt/iobroker/backups:
                          7.9M	/opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          200M	/opt/iobroker/iobroker-data/
                          172M	/opt/iobroker/iobroker-data/files
                          52M	/opt/iobroker/iobroker-data/files/javascript.admin
                          34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                          33M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
                          21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                          19M	/opt/iobroker/iobroker-data/objects.jsonl
                          9.1M	/opt/iobroker/iobroker-data/states.jsonl
                          8.9M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
                          8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
                          USB-Devices by-id:
                          *** NodeJS-Installation ***
                          /usr/bin/nodejs 	v18.19.0
                          /usr/bin/node 		v18.19.0
                          /usr/bin/npm 		10.2.3
                          /usr/bin/npx 		10.2.3
                          /usr/bin/corepack 	0.22.0
                          nodejs:
                            Installed: 18.19.0-1nodesource1
                            Candidate: 18.19.0-1nodesource1
                            Version table:
                           *** 18.19.0-1nodesource1 500
                                  100 /var/lib/dpkg/status
                               18.18.2-1nodesource1 500
                               18.18.1-1nodesource1 500
                               18.18.0-1nodesource1 500
                               18.17.1-1nodesource1 500
                               18.17.0-1nodesource1 500
                               18.16.1-1nodesource1 500
                               18.16.0-1nodesource1 500
                               18.15.0-1nodesource1 500
                               18.14.2-1nodesource1 500
                               18.14.1-1nodesource1 500
                               18.14.0-1nodesource1 500
                               18.13.0+dfsg1-1 500
                               18.13.0-1nodesource1 500
                               18.12.0-1nodesource1 500
                               18.11.0-1nodesource1 500
                               18.10.0-1nodesource1 500
                               18.9.1-1nodesource1 500
                               18.9.0-1nodesource1 500
                               18.8.0-1nodesource1 500
                               18.7.0-1nodesource1 500
                               18.6.0-1nodesource1 500
                               18.5.0-1nodesource1 500
                               18.4.0-1nodesource1 500
                               18.3.0-1nodesource1 500
                               18.2.0-1nodesource1 500
                               18.1.0-1nodesource1 500
                               18.0.0-1nodesource1 500
                          No problems detected
                          Errors in npm tree:
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Core adapters versions
                          js-controller: 	5.0.16
                          admin: 		6.12.0
                          javascript: 	7.1.4
                          Adapters from github: 	1
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : raspip                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.backitup.0               : backitup              : raspip                                   -  enabled
                            system.adapter.daswetter.0              : daswetter             : raspip                                   - disabled
                          + system.adapter.discovery.0              : discovery             : raspip                                   - disabled
                          + system.adapter.ds18b20.0                : ds18b20               : raspip                                   -  enabled
                          + system.adapter.email.0                  : email                 : raspip                                   -  enabled
                            system.adapter.enet.0                   : enet                  : raspip                                   - disabled
                            system.adapter.flot.0                   : flot                  : raspip                                   - disabled
                          + system.adapter.fritzbox.0               : fritzbox              : raspip                                   -  enabled
                          + system.adapter.history.0                : history               : raspip                                   -  enabled
                            system.adapter.icons-icons8.0           : icons-icons8          : raspip                                   - disabled
                            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspip                                   - disabled
                          + system.adapter.info.0                   : info                  : raspip                                   -  enabled
                          + system.adapter.javascript.0             : javascript            : raspip                                   -  enabled
                            system.adapter.js2fs.0                  : js2fs                 : raspip                                   - disabled
                            system.adapter.mobile.0                 : mobile                : raspip                                   - disabled
                          + system.adapter.mqtt.0                   : mqtt                  : raspip                                   -  enabled, port: 1883, bind: 0.0.0.0
                          + system.adapter.ping.0                   : ping                  : raspip                                   -  enabled
                          + system.adapter.pushover.0               : pushover              : raspip                                   -  enabled
                            system.adapter.scenes.0                 : scenes                : raspip                                   - disabled
                          + system.adapter.shelly.0                 : shelly                : raspip                                   -  enabled, port: 1882, bind: 0.0.0.0
                          + system.adapter.shelly.1                 : shelly                : raspip                                   -  enabled, port: 1882, bind: 0.0.0.0
                          + system.adapter.simple-api.0             : simple-api            : raspip                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                          + system.adapter.smartmeter.0             : smartmeter            : raspip                                   -  enabled
                          + system.adapter.tr-064.0                 : tr-064                : raspip                                   -  enabled
                            system.adapter.vis-bars.0               : vis-bars              : raspip                                   - disabled
                            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspip                                   - disabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspip                                   - disabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspip                                   - disabled
                            system.adapter.vis-map.0                : vis-map               : raspip                                   - disabled
                            system.adapter.vis-plumb.0              : vis-plumb             : raspip                                   - disabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspip                                   - disabled
                            system.adapter.vis-weather.0            : vis-weather           : raspip                                   - disabled
                            system.adapter.vis.0                    : vis                   : raspip                                   - disabled
                          + system.adapter.web.0                    : web                   : raspip                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          + system.adapter.yahka.0                  : yahka                 : raspip                                   -  enabled
                          + instance is alive
                          ioBroker-Repositories
                          Active repo(s): stable
                          Installed ioBroker-Instances
                          Objects and States
                          Objects: 	8452
                          States: 	7611
                          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                          Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Reading package lists...
                          Pending Updates: 0
                          *** Listening Ports ***
                          tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      1000       17168      1172/wayvnc
                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       26659      2337/io.shelly.1
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       24950      2399/io.mqtt.0
                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16743      837/cupsd
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17241      838/iobroker.js-con
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17234      838/iobroker.js-con
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15061      851/sshd: /usr/sbin
                          tcp6       0      0 :::36677                :::*                    LISTEN      1001       22418      2262/io.yahka.0
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       25745      2322/io.simple-api.
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19175      1496/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25652      2277/io.web.0
                          tcp6       0      0 :::44761                :::*                    LISTEN      1001       22420      2262/io.yahka.0
                          tcp6       0      0 :::42731                :::*                    LISTEN      1001       22416      2262/io.yahka.0
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          15063      851/sshd: /usr/sbin
                          tcp6       0      0 :::85                   :::*                    LISTEN      1001       68478      35823/io.javascript
                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16742      837/cupsd
                          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17822      1102/cups-browsed
                          udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       54348      21022/chromium-brow
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        17478      636/avahi-daemon: r
                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       24781      2352/io.shelly.0
                          udp        0      0 0.0.0.0:44617           0.0.0.0:*                           104        17480      636/avahi-daemon: r
                          udp6       0      0 fe80::e5ae:efc9:6f6:546 :::*                                0          17878      744/NetworkManager
                          udp6       0      0 :::5353                 :::*                                104        17479      636/avahi-daemon: r
                          udp6       0      0 :::40997                :::*                                104        17481      636/avahi-daemon: r
                          2023-12-05 15:14:34.042  - info: smartmeter.0 (2307) Received 5 values, 1 updated
                          2023-12-05 15:14:34.045  - info: javascript.0 (35823) script.js.common.produktiv.VSM_Zaehlerstand: LGes:119444.89 kWh
                          2023-12-05 15:14:34.045  - info: javascript.0 (35823) script.js.common.produktiv.VSM_Zaehlerstand: Delta:302.89
                          2023-12-05 15:14:34.046  - info: javascript.0 (35823) script.js.common.produktiv.VSM_Zaehlerstand: Verbrauch % tolastYear: 12.61
                          2023-12-05 15:14:34.748  - info: javascript.0 (35823) script.js.common.produktiv.VSM_Zaehlerstand: LCur:372.70 W
                          2023-12-05 15:14:36.086  - info: smartmeter.0 (2307) Received 5 values, 2 updated
                          2023-12-05 15:14:37.009  - warn: ds18b20.0 (3363) Error reading sensor 10-000801ef2087: Error: No temperature read
                          2023-12-05 15:14:37.041  - warn: ds18b20.0 (3363) Error reading sensor 10-000801d0136f: Error: No temperature read
                          2023-12-05 15:14:38.038  - info: smartmeter.0 (2307) Received 5 values, 2 updated
                          2023-12-05 15:14:38.902  - info: javascript.0 (35823) script.js.common.produktiv.Resol_Reader2: Kollektor:12.2 Speicher:32.1 Pumpe:0%  Wert3:8888
                          2023-12-05 15:14:40.036  - info: smartmeter.0 (2307) Received 5 values, 1 updated
                          2023-12-05 15:14:41.008  - info: javascript.0 (35823) script.js.common.produktiv.Elco_GW: ..Elco-GW.boiler_water_temperature   Wert:30.38
                          2023-12-05 15:14:42.100  - info: smartmeter.0 (2307) Received 5 values, 2 updated
                          2023-12-05 15:14:43.426  - info: javascript.0 (35823) script.js.common.produktiv.Garten: 0 0 -85
                          2023-12-05 15:14:43.895  - info: javascript.0 (35823) script.js.common.produktiv.Resol_Reader2: Kollektor:12.2 Speicher:32 Pumpe:0%  Wert3:8888
                          2023-12-05 15:14:44.043  - info: smartmeter.0 (2307) Received 5 values, 2 updated
                          2023-12-05 15:14:44.044  - info: javascript.0 (35823) script.js.common.produktiv.VSM_Zaehlerstand: LGes:119444.89 kWh
                          2023-12-05 15:14:44.045  - info: javascript.0 (35823) script.js.common.produktiv.VSM_Zaehlerstand: Delta:302.89
                          2023-12-05 15:14:44.046  - info: javascript.0 (35823) script.js.common.produktiv.VSM_Zaehlerstand: Verbrauch % tolastYear: 12.61
                          2023-12-05 15:14:44.749  - info: javascript.0 (35823) script.js.common.produktiv.VSM_Zaehlerstand: LCur:372.80 W
                          2023-12-05 15:14:46.031  - info: smartmeter.0 (2307) Received 5 values, 1 updated
                          2023-12-05 15:14:48.072  - info: smartmeter.0 (2307) Received 5 values, 2 updated
                          2023-12-05 15:14:48.893  - info: javascript.0 (35823) script.js.common.produktiv.Resol_Reader2: Kollektor:12.2 Speicher:32.1 Pumpe:0%  Wert3:8888
                          2023-12-05 15:14:50.033  - info: smartmeter.0 (2307) Received 5 values, 1 updated
                          2023-12-05 15:14:52.066  - info: smartmeter.0 (2307) Received 5 values, 2 updated
                            @stoffel67
                            Warum läuft da der Desktop? Warum nicht die Lite-Version ohne Desktop installiert?
                            Schalt das aus!
                            sudo systemctl set-default multi-user.target
                            sudo reboot
                              stoffel67 @Marc Berg last edited by
                              @marc-berg
                              TOP
                              mit 1.4.6 gings und dann upgrade👍
                              • Marc Berg
                                Marc Berg Most Active last edited by Marc Berg
                                Konnte ich mich doch noch dunkel dran erinnern ...
                                Noch ein Tipp für die Zukunft: Wenn du den Text aus "iob diag" rauskopierst, sind dort schon Code Tags drin. Wenn du dann nochmals welche setzt, dann sieht das so aus wie bei dir hier (Kraut und Rüben) 🙂
                                S Homoran 2 Replies Last reply Reply Quote 0
                                  @marc-berg
                                  Danke, habs zu spät gemerkt😕
                                    @stoffel67 wo stehst du denn da?
                                      @stoffel67
                                      https://forum.iobroker.net/topic/70508/raspi-4-bootet-extrem-langsam/5?_=1701786641978
                                      Warum fragst du eigentlich, wenn du dann doch was anderes tust?
                                        Homoran Global Moderator Administrators @Marc Berg last edited by
                                        @marc-berg sagte in ioBroker neu aufgesetzt, VIS läßt sich nicht installieren:
                                        ich nicht 😢
                                          das System ist heute komplett gecrasht… und ich hatte noch einen Raspi mit laufender SSD,
                                          das System muss dringend laufen… wegen Hzg-Steuerung
                                          gibt sonst Ärger mit meiner besten „Hälfte“….
                                          werde aber deinen Hinweis ernst nehmen, bitte nicht böse sein.
                                            @stoffel67
                                            Dann kannst du es ja jetzt ausschalten.
                                            Und den die shelly-Instanzen würde ich mir auch anschauen, die dürfen nicht beide auf den gleichen Ports lauschen.
                                            1618
