    3. Einsteigerfragen
    4. Installation
    5. ioBroker neu aufgesetzt, VIS läßt sich nicht installieren
      Thomas Braun Most Active @stoffel67 last edited by
      @stoffel67
      iob add vis
        stoffel67 @Thomas Braun last edited by stoffel67
        pi@raspip:/opt/iobroker $ iob add vis
        NPM version: 10.2.3
        Installing iobroker.vis@1.4.16... (System call)
        npm ERR! code 6
        npm ERR! path /opt/iobroker/node_modules/iobroker.vis
        npm ERR! command failed
        npm ERR! command sh -c node main.js --install
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-05T14_10_26_946Z-debug-0.log
        host.raspip Cannot install iobroker.vis@1.4.16: 6
        oder mit "sudo..."
          @stoffel67
          iob diag
          sagt in der Langfassung?
          • Marc Berg
            Marc Berg Most Active last edited by
            Musste man in der VIS Version nicht noch weiter zurückgehen? 1.4.6 oder so?
            S 1 Reply Last reply Reply Quote 2
              stoffel67 @Thomas Braun last edited by Homoran
              ist aber viel...
              Skript v.2023-10-10
              *** BASE SYSTEM ***
               Static hostname: raspip
                     Icon name: computer
                        Kernel: Linux 6.1.0-rpi6-rpi-v8
                  Architecture: arm64
              Model		: Raspberry Pi 4 Model B Rev 1.1
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : arm64
              Systemuptime and Load:
               15:13:13 up 45 min,  3 users,  load average: 4.47, 3.79, 3.11
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                             Local time: Tue 2023-12-05 15:13:13 CET
                         Universal time: Tue 2023-12-05 14:13:13 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server: 	false
              Desktop: 	LXDE-pi-wayfire
              Terminal: 	wayland
              Boot Target: 	graphical.target
              *** MEMORY ***
              Mem:            4.0G        2.4G        865M        164M        964M        1.5G
              Swap:           104M          0B        104M
              Total:          4.1G        2.4G        970M
                       3792 M total memory
                       2319 M used memory
                       2545 M active memory
                        114 M inactive memory
                        825 M free memory
                         14 M buffer memory
                        905 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              udev           devtmpfs  1.6G     0  1.6G   0% /dev
              tmpfs          tmpfs     380M  1.4M  378M   1% /run
              /dev/sda2      ext4      235G  6.5G  216G   3% /
              tmpfs          tmpfs     1.9G   30M  1.9G   2% /dev/shm
              /dev/sda1      vfat      510M   74M  437M  15% /boot/firmware
              tmpfs          tmpfs     380M   40K  380M   1% /run/user/1000
              [Tue Dec  5 14:27:14 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:45:C1:49 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=fa6f7a9b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
              [Tue Dec  5 14:27:19 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
              [Tue Dec  5 14:27:21 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
              TARGET               SOURCE    FSTYPE      OPTIONS
              /                    /dev/sda2 ext4        rw,noatime
              |-/run/user/1000/doc portal    fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
              `-/boot/firmware     /dev/sda1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              846M	/var/
              474M	/var/cache
              467M	/var/cache/apt
              355M	/var/cache/apt/archives
              201M	/var/lib
              Archived and active journals take up 68.3M in the file system.
              /opt/iobroker/backups:
              7.9M	/opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              200M	/opt/iobroker/iobroker-data/
              172M	/opt/iobroker/iobroker-data/files
              52M	/opt/iobroker/iobroker-data/files/javascript.admin
              34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
              33M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
              21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
              19M	/opt/iobroker/iobroker-data/objects.jsonl
              9.1M	/opt/iobroker/iobroker-data/states.jsonl
              8.9M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
              8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
              USB-Devices by-id:
              *** NodeJS-Installation ***
              /usr/bin/nodejs 	v18.19.0
              /usr/bin/node 		v18.19.0
              /usr/bin/npm 		10.2.3
              /usr/bin/npx 		10.2.3
              /usr/bin/corepack 	0.22.0
              nodejs:
                Installed: 18.19.0-1nodesource1
                Candidate: 18.19.0-1nodesource1
                Version table:
               *** 18.19.0-1nodesource1 500
                      100 /var/lib/dpkg/status
                   18.18.2-1nodesource1 500
                   18.18.1-1nodesource1 500
                   18.18.0-1nodesource1 500
                   18.17.1-1nodesource1 500
                   18.17.0-1nodesource1 500
                   18.16.1-1nodesource1 500
                   18.16.0-1nodesource1 500
                   18.15.0-1nodesource1 500
                   18.14.2-1nodesource1 500
                   18.14.1-1nodesource1 500
                   18.14.0-1nodesource1 500
                   18.13.0+dfsg1-1 500
                   18.13.0-1nodesource1 500
                   18.12.0-1nodesource1 500
                   18.11.0-1nodesource1 500
                   18.10.0-1nodesource1 500
                   18.9.1-1nodesource1 500
                   18.9.0-1nodesource1 500
                   18.8.0-1nodesource1 500
                   18.7.0-1nodesource1 500
                   18.6.0-1nodesource1 500
                   18.5.0-1nodesource1 500
                   18.4.0-1nodesource1 500
                   18.3.0-1nodesource1 500
                   18.2.0-1nodesource1 500
                   18.1.0-1nodesource1 500
                   18.0.0-1nodesource1 500
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller: 	5.0.16
              admin: 		6.12.0
              javascript: 	7.1.4
              Adapters from github: 	1
              Adapter State
              + system.adapter.admin.0                  : admin                 : raspip                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.backitup.0               : backitup              : raspip                                   -  enabled
                system.adapter.daswetter.0              : daswetter             : raspip                                   - disabled
              + system.adapter.discovery.0              : discovery             : raspip                                   - disabled
              + system.adapter.ds18b20.0                : ds18b20               : raspip                                   -  enabled
              + system.adapter.email.0                  : email                 : raspip                                   -  enabled
                system.adapter.enet.0                   : enet                  : raspip                                   - disabled
                system.adapter.flot.0                   : flot                  : raspip                                   - disabled
              + system.adapter.fritzbox.0               : fritzbox              : raspip                                   -  enabled
              + system.adapter.history.0                : history               : raspip                                   -  enabled
                system.adapter.icons-icons8.0           : icons-icons8          : raspip                                   - disabled
                system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspip                                   - disabled
              + system.adapter.info.0                   : info                  : raspip                                   -  enabled
              + system.adapter.javascript.0             : javascript            : raspip                                   -  enabled
                system.adapter.js2fs.0                  : js2fs                 : raspip                                   - disabled
                system.adapter.mobile.0                 : mobile                : raspip                                   - disabled
              + system.adapter.mqtt.0                   : mqtt                  : raspip                                   -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.ping.0                   : ping                  : raspip                                   -  enabled
              + system.adapter.pushover.0               : pushover              : raspip                                   -  enabled
                system.adapter.scenes.0                 : scenes                : raspip                                   - disabled
              + system.adapter.shelly.0                 : shelly                : raspip                                   -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.shelly.1                 : shelly                : raspip                                   -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.simple-api.0             : simple-api            : raspip                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              + system.adapter.smartmeter.0             : smartmeter            : raspip                                   -  enabled
              + system.adapter.tr-064.0                 : tr-064                : raspip                                   -  enabled
                system.adapter.vis-bars.0               : vis-bars              : raspip                                   - disabled
                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspip                                   - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspip                                   - disabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspip                                   - disabled
                system.adapter.vis-map.0                : vis-map               : raspip                                   - disabled
                system.adapter.vis-plumb.0              : vis-plumb             : raspip                                   - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspip                                   - disabled
                system.adapter.vis-weather.0            : vis-weather           : raspip                                   - disabled
                system.adapter.vis.0                    : vis                   : raspip                                   - disabled
              + system.adapter.web.0                    : web                   : raspip                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.yahka.0                  : yahka                 : raspip                                   -  enabled
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "backitup"     : 2.8.7    , installed 2.8.7
              Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
              Adapter    "ds18b20"      : 2.0.5    , installed 2.0.4  [Updatable]
              Adapter    "email"        : 1.2.0    , installed 1.2.0
              Adapter    "enet"         : 1.0.1    , installed 1.0.2
              Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
              Adapter    "javascript"   : 7.1.6    , installed 7.1.4  [Updatable]
              Controller "js-controller": 5.0.16   , installed 5.0.16
              Adapter    "mobile"       : 1.0.1    , installed 1.0.1
              Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
              Adapter    "pushover"     : 3.0.3    , installed 3.0.3
              Adapter    "shelly"       : 6.6.1    , installed 6.6.1
              Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
              Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
              Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Adapter    "yahka"        : 1.0.3    , installed 1.0.3
              Objects and States
              Objects: 	8452
              States: 	7611
              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      1000       17168      1172/wayvnc
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       26659      2337/io.shelly.1
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       24950      2399/io.mqtt.0
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16743      837/cupsd
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17241      838/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17234      838/iobroker.js-con
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15061      851/sshd: /usr/sbin
              tcp6       0      0 :::36677                :::*                    LISTEN      1001       22418      2262/io.yahka.0
              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       25745      2322/io.simple-api.
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19175      1496/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25652      2277/io.web.0
              tcp6       0      0 :::44761                :::*                    LISTEN      1001       22420      2262/io.yahka.0
              tcp6       0      0 :::42731                :::*                    LISTEN      1001       22416      2262/io.yahka.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          15063      851/sshd: /usr/sbin
              tcp6       0      0 :::85                   :::*                    LISTEN      1001       68478      35823/io.javascript
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16742      837/cupsd
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17822      1102/cups-browsed
              udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       54348      21022/chromium-brow
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        17478      636/avahi-daemon: r
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       24781      2352/io.shelly.0
              udp        0      0 0.0.0.0:44617           0.0.0.0:*                           104        17480      636/avahi-daemon: r
              udp6       0      0 fe80::e5ae:efc9:6f6:546 :::*                                0          17878      744/NetworkManager
              udp6       0      0 :::5353                 :::*                                104        17479      636/avahi-daemon: r
              udp6       0      0 :::40997                :::*                                104        17481      636/avahi-daemon: r
              2023-12-05 15:14:34.042  - info: smartmeter.0 (2307) Received 5 values, 1 updated
              2023-12-05 15:14:34.045  - info: javascript.0 (35823) script.js.common.produktiv.VSM_Zaehlerstand: LGes:119444.89 kWh
              2023-12-05 15:14:34.045  - info: javascript.0 (35823) script.js.common.produktiv.VSM_Zaehlerstand: Delta:302.89
              2023-12-05 15:14:34.046  - info: javascript.0 (35823) script.js.common.produktiv.VSM_Zaehlerstand: Verbrauch % tolastYear: 12.61
              2023-12-05 15:14:34.748  - info: javascript.0 (35823) script.js.common.produktiv.VSM_Zaehlerstand: LCur:372.70 W
              2023-12-05 15:14:36.086  - info: smartmeter.0 (2307) Received 5 values, 2 updated
              2023-12-05 15:14:37.009  - warn: ds18b20.0 (3363) Error reading sensor 10-000801ef2087: Error: No temperature read
              2023-12-05 15:14:37.041  - warn: ds18b20.0 (3363) Error reading sensor 10-000801d0136f: Error: No temperature read
              2023-12-05 15:14:38.038  - info: smartmeter.0 (2307) Received 5 values, 2 updated
              2023-12-05 15:14:38.902  - info: javascript.0 (35823) script.js.common.produktiv.Resol_Reader2: Kollektor:12.2 Speicher:32.1 Pumpe:0%  Wert3:8888
              2023-12-05 15:14:40.036  - info: smartmeter.0 (2307) Received 5 values, 1 updated
              2023-12-05 15:14:41.008  - info: javascript.0 (35823) script.js.common.produktiv.Elco_GW: ..Elco-GW.boiler_water_temperature   Wert:30.38
              2023-12-05 15:14:42.100  - info: smartmeter.0 (2307) Received 5 values, 2 updated
              2023-12-05 15:14:43.426  - info: javascript.0 (35823) script.js.common.produktiv.Garten: 0 0 -85
              2023-12-05 15:14:43.895  - info: javascript.0 (35823) script.js.common.produktiv.Resol_Reader2: Kollektor:12.2 Speicher:32 Pumpe:0%  Wert3:8888
              2023-12-05 15:14:44.043  - info: smartmeter.0 (2307) Received 5 values, 2 updated
              2023-12-05 15:14:44.044  - info: javascript.0 (35823) script.js.common.produktiv.VSM_Zaehlerstand: LGes:119444.89 kWh
              2023-12-05 15:14:44.045  - info: javascript.0 (35823) script.js.common.produktiv.VSM_Zaehlerstand: Delta:302.89
              2023-12-05 15:14:44.046  - info: javascript.0 (35823) script.js.common.produktiv.VSM_Zaehlerstand: Verbrauch % tolastYear: 12.61
              2023-12-05 15:14:44.749  - info: javascript.0 (35823) script.js.common.produktiv.VSM_Zaehlerstand: LCur:372.80 W
              2023-12-05 15:14:46.031  - info: smartmeter.0 (2307) Received 5 values, 1 updated
              2023-12-05 15:14:48.072  - info: smartmeter.0 (2307) Received 5 values, 2 updated
              2023-12-05 15:14:48.893  - info: javascript.0 (35823) script.js.common.produktiv.Resol_Reader2: Kollektor:12.2 Speicher:32.1 Pumpe:0%  Wert3:8888
              2023-12-05 15:14:50.033  - info: smartmeter.0 (2307) Received 5 values, 1 updated
              2023-12-05 15:14:52.066  - info: smartmeter.0 (2307) Received 5 values, 2 updated
                @stoffel67
                Warum läuft da der Desktop? Warum nicht die Lite-Version ohne Desktop installiert?
                Schalt das aus!
                sudo systemctl set-default multi-user.target
                sudo reboot
                  stoffel67 @Marc Berg last edited by
                  @marc-berg
                  TOP
                  mit 1.4.6 gings und dann upgrade👍
                  • Marc Berg
                    Marc Berg Most Active last edited by Marc Berg
                    @stoffel67 sagte in ioBroker neu aufgesetzt, VIS läßt sich nicht installieren:
                    Konnte ich mich doch noch dunkel dran erinnern ...
                    Noch ein Tipp für die Zukunft: Wenn du den Text aus "iob diag" rauskopierst, sind dort schon Code Tags drin. Wenn du dann nochmals welche setzt, dann sieht das so aus wie bei dir hier (Kraut und Rüben) 🙂
                    S Homoran 2 Replies Last reply Reply Quote 0
                      @marc-berg
                      Danke, habs zu spät gemerkt😕
                        Homoran Global Moderator Administrators @stoffel67 last edited by
                        @stoffel67 wo stehst du denn da?
                          @stoffel67
                          https://forum.iobroker.net/topic/70508/raspi-4-bootet-extrem-langsam/5?_=1701786641978
                          Warum fragst du eigentlich, wenn du dann doch was anderes tust?
                            Homoran Global Moderator Administrators @Marc Berg last edited by
                            @marc-berg sagte in ioBroker neu aufgesetzt, VIS läßt sich nicht installieren:
                            ich nicht 😢
                              das System ist heute komplett gecrasht… und ich hatte noch einen Raspi mit laufender SSD,
                              das System muss dringend laufen… wegen Hzg-Steuerung
                              gibt sonst Ärger mit meiner besten „Hälfte“….
                              werde aber deinen Hinweis ernst nehmen, bitte nicht böse sein.
                                @stoffel67
                                Dann kannst du es ja jetzt ausschalten.
                                Und den die shelly-Instanzen würde ich mir auch anschauen, die dürfen nicht beide auf den gleichen Ports lauschen.
                                  @thomas-braun said in ioBroker neu aufgesetzt, VIS läßt sich nicht installieren:
                                  Ohh, guter Hinweis
                                  vielen Dank
                                  1618
