    4. BackItUp erstellt keine backups mehr
      ronk @Thomas Braun last edited by
      @thomas-braun said in BackItUp erstellt keine backups mehr:
      @ronk
      Gib nochmal die Zusammenfassung nach dem Reboot.
      Netzwerkfehler über putty. ssh ist doch richtig?
        Thomas Braun Most Active @ronk last edited by
        @ronk
        Ja, natürlich per ssh.
          ronk @Thomas Braun last edited by ronk
          Komme nicht drauf. Port 22?
            @ronk
            Üblicherweise ist es Port 22.
              @ronk
              so. bin jetzt drauf. musste ssh starten.
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                 Static hostname: raspberrypi
                       Icon name: computer
                Operating System: Debian GNU/Linux 11 (bullseye)
                          Kernel: Linux 6.1.21-v8+
                    Architecture: arm64
              Model           : Raspberry Pi 4 Model B Rev 1.5
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : arm64
              Systemuptime and Load:
               18:03:16 up 13 min,  2 users,  load average: 1.04, 1.36, 1.08
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                             Local time: Mon 2023-12-04 18:03:16 CET
                         Universal time: Mon 2023-12-04 17:03:16 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              ronny
              /home/ronny
              ronny adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin docker gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:            3.8G        1.5G        660M        128M        1.6G        2.1G
              Swap:            99M          0B         99M
              Total:          3.9G        1.5G        760M
                       3794 M total memory
                       1520 M used memory
                       2271 M active memory
                        428 M inactive memory
                        660 M free memory
                        138 M buffer memory
                       1474 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FAILED SERVICES ***
                UNIT             LOAD   ACTIVE SUB    DESCRIPTION
              * rc-local.service loaded failed failed /etc/rc.local Compatibility
              LOAD   = Reflects whether the unit definition was properly loaded.
              ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
              SUB    = The low-level unit activation state, values depend on unit type.
              1 loaded units listed.
              *** FILESYSTEM ***
              /dev/root      ext4       29G   15G   13G  55% /
              devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
              tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
              tmpfs          tmpfs     759M  3.4M  756M   1% /run
              /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
              tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
              [Mon Dec  4 17:49:55 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1680x1050M@60 smsc95xx.macaddr=D8:3A:DD:16:F4:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e446591d-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
              [Mon Dec  4 17:49:56 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
              [Mon Dec  4 17:49:56 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
              [Mon Dec  4 17:49:57 2023] EXT4-fs (mmcblk0p2): recovery complete
              [Mon Dec  4 17:49:57 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Mon Dec  4 17:49:57 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Mon Dec  4 17:50:00 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              TARGET  SOURCE         FSTYPE OPTIONS
              /       /dev/mmcblk0p2 ext4   rw,noatime
              `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              10G     /var/
              7.6G    /var/lib
              7.4G    /var/lib/docker
              6.9G    /var/lib/docker/overlay2
              1.2G    /var/log/journal/55f00fb070744f2da4bf0d8a099975a6
              Archived and active journals take up 1.1G in the file system.
              /opt/iobroker/backups:
              196M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              205M    /opt/iobroker/iobroker-data/
              155M    /opt/iobroker/iobroker-data/files
              67M     /opt/iobroker/iobroker-data/files/javascript.admin
              48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
              47M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
              12M     /opt/iobroker/iobroker-data/objects.jsonl
              8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
              7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
              7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
              USB-Devices by-id:
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.19.0
              /usr/bin/node           v18.19.0
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              /usr/bin/corepack       0.22.0
              nodejs:
                Installed: 18.19.0-1nodesource1
                Candidate: 18.19.0-1nodesource1
                Version table:
               *** 18.19.0-1nodesource1 500
                      100 /var/lib/dpkg/status
                   18.18.2-1nodesource1 500
                   18.18.1-1nodesource1 500
                   18.18.0-1nodesource1 500
                   18.17.1-1nodesource1 500
                   18.17.0-1nodesource1 500
                   18.16.1-1nodesource1 500
                   18.16.0-1nodesource1 500
                   18.15.0-1nodesource1 500
                   18.14.2-1nodesource1 500
                   18.14.1-1nodesource1 500
                   18.14.0-1nodesource1 500
                   18.13.0-1nodesource1 500
                   18.12.0-1nodesource1 500
                   18.11.0-1nodesource1 500
                   18.10.0-1nodesource1 500
                   18.9.1-1nodesource1 500
                   18.9.0-1nodesource1 500
                   18.8.0-1nodesource1 500
                   18.7.0-1nodesource1 500
                   18.6.0-1nodesource1 500
                   18.5.0-1nodesource1 500
                   18.4.0-1nodesource1 500
                   18.3.0-1nodesource1 500
                   18.2.0-1nodesource1 500
                   18.1.0-1nodesource1 500
                   18.0.0-1nodesource1 500
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.16
              admin:          6.12.0
              javascript:     7.1.6
              Adapters from github:   0
              Adapter State
              + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
              + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
              + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
              + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
              + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
              + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
              + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
              + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.58
              + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
              + system.adapter.solax.0                  : solax                 : raspberrypi                              -  enabled
              + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
              + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "backitup"     : 2.8.7    , installed 2.8.7
              Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
              Adapter    "javascript"   : 7.1.6    , installed 7.1.6
              Controller "js-controller": 5.0.16   , installed 5.0.16
              Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
              Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
              Adapter    "solax"        : 0.8.0    , installed 0.8.0
              Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
              Adapter    "vis"          : 1.4.16   , installed 1.4.16
              Adapter    "vis-icontwo"  : 0.98.0   , installed 0.98.0
              Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Objects and States
              Objects:        3135
              States:         3111
              Hit:1 http://deb.debian.org/debian bullseye InRelease
              Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:5 https://apt.grafana.com stable InRelease
              Hit:6 https://download.docker.com/linux/debian bullseye InRelease
              Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 192.168.178.58:1883     0.0.0.0:*               LISTEN      1002       20354      3429/io.mqtt.0
              tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          15448      951/smbd
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          23613      3593/sshd: /usr/sbi
              tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          15447      951/smbd
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11746      547/cupsd
              tcp        0      0 0.0.0.0:7190            0.0.0.0:*               LISTEN      0          18017      1552/docker-proxy
              tcp        0      0 0.0.0.0:7194            0.0.0.0:*               LISTEN      0          17908      1369/docker-proxy
              tcp        0      0 0.0.0.0:3100            0.0.0.0:*               LISTEN      0          17964      1465/docker-proxy
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       15968      733/iobroker.js-con
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       16007      733/iobroker.js-con
              tcp        0      0 0.0.0.0:4000            0.0.0.0:*               LISTEN      0          17067      1514/docker-proxy
              tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          11130      577/vncserver-x11-c
              tcp6       0      0 :::139                  :::*                    LISTEN      0          15446      951/smbd
              tcp6       0      0 :::22                   :::*                    LISTEN      0          23615      3593/sshd: /usr/sbi
              tcp6       0      0 :::445                  :::*                    LISTEN      0          13274      951/smbd
              tcp6       0      0 :::3000                 :::*                    LISTEN      116        16296      732/grafana
              tcp6       0      0 :::7190                 :::*                    LISTEN      0          18545      1559/docker-proxy
              tcp6       0      0 :::7194                 :::*                    LISTEN      0          17911      1376/docker-proxy
              tcp6       0      0 :::3100                 :::*                    LISTEN      0          17967      1471/docker-proxy
              tcp6       0      0 :::4000                 :::*                    LISTEN      0          17072      1522/docker-proxy
              tcp6       0      0 :::8081                 :::*                    LISTEN      1002       22110      3489/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1002       22130      3535/io.web.0
              tcp6       0      0 :::8086                 :::*                    LISTEN      999        15368      564/influxd
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11745      547/cupsd
              tcp6       0      0 :::5900                 :::*                    LISTEN      0          11129      577/vncserver-x11-c
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15318      480/dhcpcd
              udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23297      550/nmbd
              udp        0      0 169.254.251.49:137      0.0.0.0:*                           0          23296      550/nmbd
              udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23293      550/nmbd
              udp        0      0 169.254.224.59:137      0.0.0.0:*                           0          23292      550/nmbd
              udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23289      550/nmbd
              udp        0      0 169.254.176.113:137     0.0.0.0:*                           0          23288      550/nmbd
              udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23285      550/nmbd
              udp        0      0 169.254.166.163:137     0.0.0.0:*                           0          23284      550/nmbd
              udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23281      550/nmbd
              udp        0      0 169.254.137.51:137      0.0.0.0:*                           0          23280      550/nmbd
              udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23277      550/nmbd
              udp        0      0 169.254.124.18:137      0.0.0.0:*                           0          23276      550/nmbd
              udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23273      550/nmbd
              udp        0      0 169.254.88.37:137       0.0.0.0:*                           0          23272      550/nmbd
              udp        0      0 172.19.255.255:137      0.0.0.0:*                           0          17877      550/nmbd
              udp        0      0 172.19.0.1:137          0.0.0.0:*                           0          17876      550/nmbd
              udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          17873      550/nmbd
              udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          17872      550/nmbd
              udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          13186      550/nmbd
              udp        0      0 192.168.178.58:137      0.0.0.0:*                           0          13185      550/nmbd
              udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          12987      550/nmbd
              udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23299      550/nmbd
              udp        0      0 169.254.251.49:138      0.0.0.0:*                           0          23298      550/nmbd
              udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23295      550/nmbd
              udp        0      0 169.254.224.59:138      0.0.0.0:*                           0          23294      550/nmbd
              udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23291      550/nmbd
              udp        0      0 169.254.176.113:138     0.0.0.0:*                           0          23290      550/nmbd
              udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23287      550/nmbd
              udp        0      0 169.254.166.163:138     0.0.0.0:*                           0          23286      550/nmbd
              udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23283      550/nmbd
              udp        0      0 169.254.137.51:138      0.0.0.0:*                           0          23282      550/nmbd
              udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23279      550/nmbd
              udp        0      0 169.254.124.18:138      0.0.0.0:*                           0          23278      550/nmbd
              udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23275      550/nmbd
              udp        0      0 169.254.88.37:138       0.0.0.0:*                           0          23274      550/nmbd
              udp        0      0 172.19.255.255:138      0.0.0.0:*                           0          17879      550/nmbd
              udp        0      0 172.19.0.1:138          0.0.0.0:*                           0          17878      550/nmbd
              udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          17875      550/nmbd
              udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          17874      550/nmbd
              udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          13188      550/nmbd
              udp        0      0 192.168.178.58:138      0.0.0.0:*                           0          13187      550/nmbd
              udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          12988      550/nmbd
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          11761      620/cups-browsed
              udp        0      0 0.0.0.0:33728           0.0.0.0:*                           108        12911      414/avahi-daemon: r
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12909      414/avahi-daemon: r
              udp6       0      0 :::546                  :::*                                0          13087      480/dhcpcd
              udp6       0      0 :::41701                :::*                                108        12912      414/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                108        12910      414/avahi-daemon: r
              2023-12-04 17:51:54.035  - info: tesla-motors.0 (3601) Session loaded
              2023-12-04 17:51:54.036  - info: tesla-motors.0 (3601) Refresh session
              2023-12-04 17:51:54.991  - info: tesla-motors.0 (3601) Receive device list
              2023-12-04 17:51:55.323  - info: tesla-motors.0 (3601) Found 1 devices
              2023-12-04 17:51:56.689  - info: accuweather.0 (3616) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.accuweather, node: v18.19.0, js-controller: 5.0.16
              2023-12-04 17:51:56.876  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.energy_cost_breakdown.home.raw_value" has to be type "number" but received type "string"
              2023-12-04 17:51:57.252  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points17.values05.raw_value" has to be type "number" but received type "string"
              2023-12-04 17:51:57.253  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points17.values06.raw_value" has to be type "number" but received type "string"
              2023-12-04 17:51:57.279  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points24.values05.raw_value" has to be type "string" but received type "number"
              2023-12-04 17:51:57.283  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points24.values06.raw_value" has to be type "string" but received type "number"
              2023-12-04 17:51:58.296  - info: host.raspberrypi instance system.adapter.vis-inventwo.0 started with pid 3633
              2023-12-04 17:52:00.793  - info: vis-inventwo.0 (3633) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v18.19.0, js-controller: 5.0.16
              2023-12-04 17:52:03.015  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJ3xxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
              2023-12-04 17:52:03.411  - info: host.raspberrypi instance system.adapter.solax.0 started with pid 3649
              2023-12-04 17:52:05.781  - info: solax.0 (3649) starting. Version 0.8.0 in /opt/iobroker/node_modules/iobroker.solax, node: v18.19.0, js-controller: 5.0.16
              2023-12-04 17:52:06.872  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 3665
              2023-12-04 17:52:09.178  - info: backitup.0 (3665) starting. Version 2.8.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.16
              2023-12-04 17:52:09.278  - info: backitup.0 (3665) [iobroker] backup will be activated at 02:40 every 1 day(s)
              2023-12-04 17:52:09.683  - info: solax.0 (3649) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
              2023-12-04 17:53:56.485  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
              2023-12-04 17:54:38.261  - info: admin.0 (3489) ==> Connected system.user.admin from ::ffff:192.168.178.20
              2023-12-04 17:57:09.577  - info: solax.0 (3649) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
              2023-12-04 18:01:56.126  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
              2023-12-04 18:02:09.564  - info: solax.0 (3649) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
              2023-12-04 18:03:02.529  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
                @ronk
                Immer sauber rebooten, nie einfach vom Strom reißen.
                  ronk last edited by
                  nochmal booten?
                    @ronk
                    War eigentlich ein allgemeiner Hinweis zum Umgang mit einem Betriebssystem. Die mögen das alle nicht.
                      ronk last edited by
                                              v.2023-10-10
                               Icon name: computer
                            Architecture: arm64
                      Installation:           native
                      Kernel:                 aarch64
                      Userland:               arm64
                      Timezone:               Europe/Berlin (CET, +0100)
                      User-ID:                1000
                      X-Server:               false
                      Pending OS-Updates:     0
                      Pending iob updates:    0
                      Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                              /usr/bin/npm            10.2.3
                                              /usr/bin/npx            10.2.3
                      Recommended versions are nodejs 18.19.0 and npm 10.2.3
                      MEMORY:
                      Mem:            3.8G        1.6G        485M        129M        1.7G        1.9G
                      Swap:            99M          0B         99M
                      Total:          3.9G        1.6G        585M
                      Active iob-Instances:   14
                      ioBroker Core:          js-controller           5.0.16
                                              admin                   6.12.0
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                3135
                      States:                 3110
                      Size of iob-Database:
                      1.1M    /opt/iobroker/iobroker-data/states.jsonl
                        ronk last edited by
                        Influx db Sicherung läuft nun. Richtiger Token hilft. In Grafana finde ich keinen Token. Wo kann ich einen erstellen?
                        • Marc Berg
                          Marc Berg Most Active @ronk last edited by Marc Berg
                          @ronk sagte in BackItUp erstellt keine backups mehr:
                          Service Accounts --> Add service account (Role "Admin") --> Token
                            ronk @Marc Berg last edited by
                            @marc-berg
                            Danke. Display name auch admin? Oder ist das egal?
                            • Marc Berg
                              Oder ist das egal?
                              Egal ...
                                @marc-berg
                                Danke. Das wars. Sicherung läuft durch. Token...
                                Ich danke euch.
                                Viele Grüße.
                                • Eulo
                                  Eulo @Marc Berg last edited by
                                  @marc-berg wie mounte ich denn manuell?
                                  1239
