    4. BackItUp erstellt keine backups mehr
      Thomas Braun Most Active @ronk last edited by
      @ronk
      Ja, natürlich per ssh.
        ronk @Thomas Braun last edited by ronk
        Komme nicht drauf. Port 22?
          @ronk
          Üblicherweise ist es Port 22.
            @thomas-braun said in BackItUp erstellt keine backups mehr:
            @ronk
            so. bin jetzt drauf. musste ssh starten.
            Skript v.2023-10-10
            *** BASE SYSTEM ***
               Static hostname: raspberrypi
                     Icon name: computer
              Operating System: Debian GNU/Linux 11 (bullseye)
                        Kernel: Linux 6.1.21-v8+
                  Architecture: arm64
            Model           : Raspberry Pi 4 Model B Rev 1.5
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : arm64
            Systemuptime and Load:
             18:03:16 up 13 min,  2 users,  load average: 1.04, 1.36, 1.08
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** Time and Time Zones ***
                           Local time: Mon 2023-12-04 18:03:16 CET
                       Universal time: Mon 2023-12-04 17:03:16 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            ronny
            /home/ronny
            ronny adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin docker gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            Boot Target:    multi-user.target
            *** MEMORY ***
            Mem:            3.8G        1.5G        660M        128M        1.6G        2.1G
            Swap:            99M          0B         99M
            Total:          3.9G        1.5G        760M
                     3794 M total memory
                     1520 M used memory
                     2271 M active memory
                      428 M inactive memory
                      660 M free memory
                      138 M buffer memory
                     1474 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FAILED SERVICES ***
              UNIT             LOAD   ACTIVE SUB    DESCRIPTION
            * rc-local.service loaded failed failed /etc/rc.local Compatibility
            LOAD   = Reflects whether the unit definition was properly loaded.
            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
            SUB    = The low-level unit activation state, values depend on unit type.
            1 loaded units listed.
            *** FILESYSTEM ***
            /dev/root      ext4       29G   15G   13G  55% /
            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
            tmpfs          tmpfs     759M  3.4M  756M   1% /run
            /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
            tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
            [Mon Dec  4 17:49:55 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1680x1050M@60 smsc95xx.macaddr=D8:3A:DD:16:F4:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e446591d-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
            [Mon Dec  4 17:49:56 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
            [Mon Dec  4 17:49:56 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
            [Mon Dec  4 17:49:57 2023] EXT4-fs (mmcblk0p2): recovery complete
            [Mon Dec  4 17:49:57 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Mon Dec  4 17:49:57 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Mon Dec  4 17:50:00 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            10G     /var/
            7.6G    /var/lib
            7.4G    /var/lib/docker
            6.9G    /var/lib/docker/overlay2
            1.2G    /var/log/journal/55f00fb070744f2da4bf0d8a099975a6
            Archived and active journals take up 1.1G in the file system.
            /opt/iobroker/backups:
            196M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            205M    /opt/iobroker/iobroker-data/
            155M    /opt/iobroker/iobroker-data/files
            67M     /opt/iobroker/iobroker-data/files/javascript.admin
            48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
            47M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
            12M     /opt/iobroker/iobroker-data/objects.jsonl
            8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
            7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
            7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
            USB-Devices by-id:
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.19.0
            /usr/bin/node           v18.19.0
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            /usr/bin/corepack       0.22.0
            nodejs:
              Installed: 18.19.0-1nodesource1
              Candidate: 18.19.0-1nodesource1
              Version table:
             *** 18.19.0-1nodesource1 500
                    100 /var/lib/dpkg/status
                 18.18.2-1nodesource1 500
                 18.18.1-1nodesource1 500
                 18.18.0-1nodesource1 500
                 18.17.1-1nodesource1 500
                 18.17.0-1nodesource1 500
                 18.16.1-1nodesource1 500
                 18.16.0-1nodesource1 500
                 18.15.0-1nodesource1 500
                 18.14.2-1nodesource1 500
                 18.14.1-1nodesource1 500
                 18.14.0-1nodesource1 500
                 18.13.0-1nodesource1 500
                 18.12.0-1nodesource1 500
                 18.11.0-1nodesource1 500
                 18.10.0-1nodesource1 500
                 18.9.1-1nodesource1 500
                 18.9.0-1nodesource1 500
                 18.8.0-1nodesource1 500
                 18.7.0-1nodesource1 500
                 18.6.0-1nodesource1 500
                 18.5.0-1nodesource1 500
                 18.4.0-1nodesource1 500
                 18.3.0-1nodesource1 500
                 18.2.0-1nodesource1 500
                 18.1.0-1nodesource1 500
                 18.0.0-1nodesource1 500
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.16
            admin:          6.12.0
            javascript:     7.1.6
            Adapters from github:   0
            Adapter State
            + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
            + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
            + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
            + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
            + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
            + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
            + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.58
            + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
            + system.adapter.solax.0                  : solax                 : raspberrypi                              -  enabled
            + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
              system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
              system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
            + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
            Adapter    "admin"        : 6.12.0   , installed 6.12.0
            Adapter    "backitup"     : 2.8.7    , installed 2.8.7
            Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
            Adapter    "javascript"   : 7.1.6    , installed 7.1.6
            Controller "js-controller": 5.0.16   , installed 5.0.16
            Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
            Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
            Adapter    "solax"        : 0.8.0    , installed 0.8.0
            Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
            Adapter    "vis"          : 1.4.16   , installed 1.4.16
            Adapter    "vis-icontwo"  : 0.98.0   , installed 0.98.0
            Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
            Adapter    "web"          : 6.1.10   , installed 6.1.10
            Adapter    "ws"           : 2.5.8    , installed 2.5.8
            Objects and States
            Objects:        3135
            States:         3111
            Hit:1 http://deb.debian.org/debian bullseye InRelease
            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:5 https://apt.grafana.com stable InRelease
            Hit:6 https://download.docker.com/linux/debian bullseye InRelease
            Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 192.168.178.58:1883     0.0.0.0:*               LISTEN      1002       20354      3429/io.mqtt.0
            tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          15448      951/smbd
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          23613      3593/sshd: /usr/sbi
            tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          15447      951/smbd
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11746      547/cupsd
            tcp        0      0 0.0.0.0:7190            0.0.0.0:*               LISTEN      0          18017      1552/docker-proxy
            tcp        0      0 0.0.0.0:7194            0.0.0.0:*               LISTEN      0          17908      1369/docker-proxy
            tcp        0      0 0.0.0.0:3100            0.0.0.0:*               LISTEN      0          17964      1465/docker-proxy
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       15968      733/iobroker.js-con
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       16007      733/iobroker.js-con
            tcp        0      0 0.0.0.0:4000            0.0.0.0:*               LISTEN      0          17067      1514/docker-proxy
            tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          11130      577/vncserver-x11-c
            tcp6       0      0 :::139                  :::*                    LISTEN      0          15446      951/smbd
            tcp6       0      0 :::22                   :::*                    LISTEN      0          23615      3593/sshd: /usr/sbi
            tcp6       0      0 :::445                  :::*                    LISTEN      0          13274      951/smbd
            tcp6       0      0 :::3000                 :::*                    LISTEN      116        16296      732/grafana
            tcp6       0      0 :::7190                 :::*                    LISTEN      0          18545      1559/docker-proxy
            tcp6       0      0 :::7194                 :::*                    LISTEN      0          17911      1376/docker-proxy
            tcp6       0      0 :::3100                 :::*                    LISTEN      0          17967      1471/docker-proxy
            tcp6       0      0 :::4000                 :::*                    LISTEN      0          17072      1522/docker-proxy
            tcp6       0      0 :::8081                 :::*                    LISTEN      1002       22110      3489/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1002       22130      3535/io.web.0
            tcp6       0      0 :::8086                 :::*                    LISTEN      999        15368      564/influxd
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11745      547/cupsd
            tcp6       0      0 :::5900                 :::*                    LISTEN      0          11129      577/vncserver-x11-c
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15318      480/dhcpcd
            udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23297      550/nmbd
            udp        0      0 169.254.251.49:137      0.0.0.0:*                           0          23296      550/nmbd
            udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23293      550/nmbd
            udp        0      0 169.254.224.59:137      0.0.0.0:*                           0          23292      550/nmbd
            udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23289      550/nmbd
            udp        0      0 169.254.176.113:137     0.0.0.0:*                           0          23288      550/nmbd
            udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23285      550/nmbd
            udp        0      0 169.254.166.163:137     0.0.0.0:*                           0          23284      550/nmbd
            udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23281      550/nmbd
            udp        0      0 169.254.137.51:137      0.0.0.0:*                           0          23280      550/nmbd
            udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23277      550/nmbd
            udp        0      0 169.254.124.18:137      0.0.0.0:*                           0          23276      550/nmbd
            udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23273      550/nmbd
            udp        0      0 169.254.88.37:137       0.0.0.0:*                           0          23272      550/nmbd
            udp        0      0 172.19.255.255:137      0.0.0.0:*                           0          17877      550/nmbd
            udp        0      0 172.19.0.1:137          0.0.0.0:*                           0          17876      550/nmbd
            udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          17873      550/nmbd
            udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          17872      550/nmbd
            udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          13186      550/nmbd
            udp        0      0 192.168.178.58:137      0.0.0.0:*                           0          13185      550/nmbd
            udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          12987      550/nmbd
            udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23299      550/nmbd
            udp        0      0 169.254.251.49:138      0.0.0.0:*                           0          23298      550/nmbd
            udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23295      550/nmbd
            udp        0      0 169.254.224.59:138      0.0.0.0:*                           0          23294      550/nmbd
            udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23291      550/nmbd
            udp        0      0 169.254.176.113:138     0.0.0.0:*                           0          23290      550/nmbd
            udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23287      550/nmbd
            udp        0      0 169.254.166.163:138     0.0.0.0:*                           0          23286      550/nmbd
            udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23283      550/nmbd
            udp        0      0 169.254.137.51:138      0.0.0.0:*                           0          23282      550/nmbd
            udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23279      550/nmbd
            udp        0      0 169.254.124.18:138      0.0.0.0:*                           0          23278      550/nmbd
            udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23275      550/nmbd
            udp        0      0 169.254.88.37:138       0.0.0.0:*                           0          23274      550/nmbd
            udp        0      0 172.19.255.255:138      0.0.0.0:*                           0          17879      550/nmbd
            udp        0      0 172.19.0.1:138          0.0.0.0:*                           0          17878      550/nmbd
            udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          17875      550/nmbd
            udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          17874      550/nmbd
            udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          13188      550/nmbd
            udp        0      0 192.168.178.58:138      0.0.0.0:*                           0          13187      550/nmbd
            udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          12988      550/nmbd
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          11761      620/cups-browsed
            udp        0      0 0.0.0.0:33728           0.0.0.0:*                           108        12911      414/avahi-daemon: r
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12909      414/avahi-daemon: r
            udp6       0      0 :::546                  :::*                                0          13087      480/dhcpcd
            udp6       0      0 :::41701                :::*                                108        12912      414/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        12910      414/avahi-daemon: r
            2023-12-04 17:51:54.035  - info: tesla-motors.0 (3601) Session loaded
            2023-12-04 17:51:54.036  - info: tesla-motors.0 (3601) Refresh session
            2023-12-04 17:51:54.991  - info: tesla-motors.0 (3601) Receive device list
            2023-12-04 17:51:55.323  - info: tesla-motors.0 (3601) Found 1 devices
            2023-12-04 17:51:56.689  - info: accuweather.0 (3616) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.accuweather, node: v18.19.0, js-controller: 5.0.16
            2023-12-04 17:51:56.876  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.energy_cost_breakdown.home.raw_value" has to be type "number" but received type "string"
            2023-12-04 17:51:57.252  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points17.values05.raw_value" has to be type "number" but received type "string"
            2023-12-04 17:51:57.253  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points17.values06.raw_value" has to be type "number" but received type "string"
            2023-12-04 17:51:57.279  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points24.values05.raw_value" has to be type "string" but received type "number"
            2023-12-04 17:51:57.283  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points24.values06.raw_value" has to be type "string" but received type "number"
            2023-12-04 17:51:58.296  - info: host.raspberrypi instance system.adapter.vis-inventwo.0 started with pid 3633
            2023-12-04 17:52:00.793  - info: vis-inventwo.0 (3633) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v18.19.0, js-controller: 5.0.16
            2023-12-04 17:52:03.015  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJ3xxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
            2023-12-04 17:52:03.411  - info: host.raspberrypi instance system.adapter.solax.0 started with pid 3649
            2023-12-04 17:52:05.781  - info: solax.0 (3649) starting. Version 0.8.0 in /opt/iobroker/node_modules/iobroker.solax, node: v18.19.0, js-controller: 5.0.16
            2023-12-04 17:52:06.872  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 3665
            2023-12-04 17:52:09.178  - info: backitup.0 (3665) starting. Version 2.8.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.16
            2023-12-04 17:52:09.278  - info: backitup.0 (3665) [iobroker] backup will be activated at 02:40 every 1 day(s)
            2023-12-04 17:52:09.683  - info: solax.0 (3649) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
            2023-12-04 17:53:56.485  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
            2023-12-04 17:54:38.261  - info: admin.0 (3489) ==> Connected system.user.admin from ::ffff:192.168.178.20
            2023-12-04 17:57:09.577  - info: solax.0 (3649) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
            2023-12-04 18:01:56.126  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
            2023-12-04 18:02:09.564  - info: solax.0 (3649) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
            2023-12-04 18:03:02.529  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
              @ronk
              Immer sauber rebooten, nie einfach vom Strom reißen.
                ronk last edited by
                nochmal booten?
                  @ronk
                  War eigentlich ein allgemeiner Hinweis zum Umgang mit einem Betriebssystem. Die mögen das alle nicht.
                    ronk last edited by
                                            v.2023-10-10
                             Icon name: computer
                          Architecture: arm64
                    Installation:           native
                    Kernel:                 aarch64
                    Userland:               arm64
                    Timezone:               Europe/Berlin (CET, +0100)
                    User-ID:                1000
                    X-Server:               false
                    Pending OS-Updates:     0
                    Pending iob updates:    0
                    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                            /usr/bin/npm            10.2.3
                                            /usr/bin/npx            10.2.3
                    Recommended versions are nodejs 18.19.0 and npm 10.2.3
                    MEMORY:
                    Mem:            3.8G        1.6G        485M        129M        1.7G        1.9G
                    Swap:            99M          0B         99M
                    Total:          3.9G        1.6G        585M
                    Active iob-Instances:   14
                    ioBroker Core:          js-controller           5.0.16
                                            admin                   6.12.0
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                3135
                    States:                 3110
                    Size of iob-Database:
                    1.1M    /opt/iobroker/iobroker-data/states.jsonl
                      ronk last edited by
                      Influx db Sicherung läuft nun. Richtiger Token hilft. In Grafana finde ich keinen Token. Wo kann ich einen erstellen?
                      • Marc Berg
                        Marc Berg Most Active @ronk last edited by Marc Berg
                        @ronk sagte in BackItUp erstellt keine backups mehr:
                        Service Accounts --> Add service account (Role "Admin") --> Token
                          ronk @Marc Berg last edited by
                          @marc-berg
                          Danke. Display name auch admin? Oder ist das egal?
                          • Marc Berg
                            Oder ist das egal?
                            Egal ...
                              @marc-berg
                              Danke. Das wars. Sicherung läuft durch. Token...
                              Ich danke euch.
                              Viele Grüße.
                              • Eulo
                                Eulo @Marc Berg last edited by
                                @marc-berg wie mounte ich denn manuell?
                                1240
