    4. BackItUp erstellt keine backups mehr
      ronk @Thomas Braun last edited by ronk
      @thomas-braun said in BackItUp erstellt keine backups mehr:
      @ronk
      Üblicherweise ist es Port 22.
      so. bin jetzt drauf. musste ssh starten.
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       18:03:16 up 13 min,  2 users,  load average: 1.04, 1.36, 1.08
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Mon 2023-12-04 18:03:16 CET
                 Universal time: Mon 2023-12-04 17:03:16 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      ronny
      /home/ronny
      ronny adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin docker gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            3.8G        1.5G        660M        128M        1.6G        2.1G
      Swap:            99M          0B         99M
      Total:          3.9G        1.5G        760M
               3794 M total memory
               1520 M used memory
               2271 M active memory
                428 M inactive memory
                660 M free memory
                138 M buffer memory
               1474 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
      * rc-local.service loaded failed failed /etc/rc.local Compatibility
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G   15G   13G  55% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  3.4M  756M   1% /run
      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
      [Mon Dec  4 17:49:55 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1680x1050M@60 smsc95xx.macaddr=D8:3A:DD:16:F4:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e446591d-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Mon Dec  4 17:49:56 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Mon Dec  4 17:49:56 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Mon Dec  4 17:49:57 2023] EXT4-fs (mmcblk0p2): recovery complete
      [Mon Dec  4 17:49:57 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Mon Dec  4 17:49:57 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Mon Dec  4 17:50:00 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      10G     /var/
      7.6G    /var/lib
      7.4G    /var/lib/docker
      6.9G    /var/lib/docker/overlay2
      1.2G    /var/log/journal/55f00fb070744f2da4bf0d8a099975a6
      Archived and active journals take up 1.1G in the file system.
      /opt/iobroker/backups:
      196M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      205M    /opt/iobroker/iobroker-data/
      155M    /opt/iobroker/iobroker-data/files
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      47M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      12M     /opt/iobroker/iobroker-data/objects.jsonl
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
      7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
      7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 500
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.16
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   0
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.58
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.solax.0                  : solax                 : raspberrypi                              -  enabled
      + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.16   , installed 5.0.16
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
      Adapter    "solax"        : 0.8.0    , installed 0.8.0
      Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-icontwo"  : 0.98.0   , installed 0.98.0
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Objects and States
      Objects:        3135
      States:         3111
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://apt.grafana.com stable InRelease
      Hit:6 https://download.docker.com/linux/debian bullseye InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.178.58:1883     0.0.0.0:*               LISTEN      1002       20354      3429/io.mqtt.0
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          15448      951/smbd
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          23613      3593/sshd: /usr/sbi
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          15447      951/smbd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11746      547/cupsd
      tcp        0      0 0.0.0.0:7190            0.0.0.0:*               LISTEN      0          18017      1552/docker-proxy
      tcp        0      0 0.0.0.0:7194            0.0.0.0:*               LISTEN      0          17908      1369/docker-proxy
      tcp        0      0 0.0.0.0:3100            0.0.0.0:*               LISTEN      0          17964      1465/docker-proxy
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       15968      733/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       16007      733/iobroker.js-con
      tcp        0      0 0.0.0.0:4000            0.0.0.0:*               LISTEN      0          17067      1514/docker-proxy
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          11130      577/vncserver-x11-c
      tcp6       0      0 :::139                  :::*                    LISTEN      0          15446      951/smbd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          23615      3593/sshd: /usr/sbi
      tcp6       0      0 :::445                  :::*                    LISTEN      0          13274      951/smbd
      tcp6       0      0 :::3000                 :::*                    LISTEN      116        16296      732/grafana
      tcp6       0      0 :::7190                 :::*                    LISTEN      0          18545      1559/docker-proxy
      tcp6       0      0 :::7194                 :::*                    LISTEN      0          17911      1376/docker-proxy
      tcp6       0      0 :::3100                 :::*                    LISTEN      0          17967      1471/docker-proxy
      tcp6       0      0 :::4000                 :::*                    LISTEN      0          17072      1522/docker-proxy
      tcp6       0      0 :::8081                 :::*                    LISTEN      1002       22110      3489/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1002       22130      3535/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        15368      564/influxd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11745      547/cupsd
      tcp6       0      0 :::5900                 :::*                    LISTEN      0          11129      577/vncserver-x11-c
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15318      480/dhcpcd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23297      550/nmbd
      udp        0      0 169.254.251.49:137      0.0.0.0:*                           0          23296      550/nmbd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23293      550/nmbd
      udp        0      0 169.254.224.59:137      0.0.0.0:*                           0          23292      550/nmbd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23289      550/nmbd
      udp        0      0 169.254.176.113:137     0.0.0.0:*                           0          23288      550/nmbd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23285      550/nmbd
      udp        0      0 169.254.166.163:137     0.0.0.0:*                           0          23284      550/nmbd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23281      550/nmbd
      udp        0      0 169.254.137.51:137      0.0.0.0:*                           0          23280      550/nmbd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23277      550/nmbd
      udp        0      0 169.254.124.18:137      0.0.0.0:*                           0          23276      550/nmbd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          23273      550/nmbd
      udp        0      0 169.254.88.37:137       0.0.0.0:*                           0          23272      550/nmbd
      udp        0      0 172.19.255.255:137      0.0.0.0:*                           0          17877      550/nmbd
      udp        0      0 172.19.0.1:137          0.0.0.0:*                           0          17876      550/nmbd
      udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          17873      550/nmbd
      udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          17872      550/nmbd
      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          13186      550/nmbd
      udp        0      0 192.168.178.58:137      0.0.0.0:*                           0          13185      550/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          12987      550/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23299      550/nmbd
      udp        0      0 169.254.251.49:138      0.0.0.0:*                           0          23298      550/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23295      550/nmbd
      udp        0      0 169.254.224.59:138      0.0.0.0:*                           0          23294      550/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23291      550/nmbd
      udp        0      0 169.254.176.113:138     0.0.0.0:*                           0          23290      550/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23287      550/nmbd
      udp        0      0 169.254.166.163:138     0.0.0.0:*                           0          23286      550/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23283      550/nmbd
      udp        0      0 169.254.137.51:138      0.0.0.0:*                           0          23282      550/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23279      550/nmbd
      udp        0      0 169.254.124.18:138      0.0.0.0:*                           0          23278      550/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          23275      550/nmbd
      udp        0      0 169.254.88.37:138       0.0.0.0:*                           0          23274      550/nmbd
      udp        0      0 172.19.255.255:138      0.0.0.0:*                           0          17879      550/nmbd
      udp        0      0 172.19.0.1:138          0.0.0.0:*                           0          17878      550/nmbd
      udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          17875      550/nmbd
      udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          17874      550/nmbd
      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          13188      550/nmbd
      udp        0      0 192.168.178.58:138      0.0.0.0:*                           0          13187      550/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          12988      550/nmbd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          11761      620/cups-browsed
      udp        0      0 0.0.0.0:33728           0.0.0.0:*                           108        12911      414/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12909      414/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          13087      480/dhcpcd
      udp6       0      0 :::41701                :::*                                108        12912      414/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        12910      414/avahi-daemon: r
      2023-12-04 17:51:54.035  - info: tesla-motors.0 (3601) Session loaded
      2023-12-04 17:51:54.036  - info: tesla-motors.0 (3601) Refresh session
      2023-12-04 17:51:54.991  - info: tesla-motors.0 (3601) Receive device list
      2023-12-04 17:51:55.323  - info: tesla-motors.0 (3601) Found 1 devices
      2023-12-04 17:51:56.689  - info: accuweather.0 (3616) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.accuweather, node: v18.19.0, js-controller: 5.0.16
      2023-12-04 17:51:56.876  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.energy_cost_breakdown.home.raw_value" has to be type "number" but received type "string"
      2023-12-04 17:51:57.252  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points17.values05.raw_value" has to be type "number" but received type "string"
      2023-12-04 17:51:57.253  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points17.values06.raw_value" has to be type "number" but received type "string"
      2023-12-04 17:51:57.279  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points24.values05.raw_value" has to be type "string" but received type "number"
      2023-12-04 17:51:57.283  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.charge_history.charging_history_graph.data_points24.values06.raw_value" has to be type "string" but received type "number"
      2023-12-04 17:51:58.296  - info: host.raspberrypi instance system.adapter.vis-inventwo.0 started with pid 3633
      2023-12-04 17:52:00.793  - info: vis-inventwo.0 (3633) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v18.19.0, js-controller: 5.0.16
      2023-12-04 17:52:03.015  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJ3xxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 17:52:03.411  - info: host.raspberrypi instance system.adapter.solax.0 started with pid 3649
      2023-12-04 17:52:05.781  - info: solax.0 (3649) starting. Version 0.8.0 in /opt/iobroker/node_modules/iobroker.solax, node: v18.19.0, js-controller: 5.0.16
      2023-12-04 17:52:06.872  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 3665
      2023-12-04 17:52:09.178  - info: backitup.0 (3665) starting. Version 2.8.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.16
      2023-12-04 17:52:09.278  - info: backitup.0 (3665) [iobroker] backup will be activated at 02:40 every 1 day(s)
      2023-12-04 17:52:09.683  - info: solax.0 (3649) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
      2023-12-04 17:53:56.485  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 17:54:38.261  - info: admin.0 (3489) ==> Connected system.user.admin from ::ffff:192.168.178.20
      2023-12-04 17:57:09.577  - info: solax.0 (3649) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
      2023-12-04 18:01:56.126  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
      2023-12-04 18:02:09.564  - info: solax.0 (3649) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
      2023-12-04 18:03:02.529  - info: tesla-motors.0 (3601) State value to set for "tesla-motors.0.5YJxxx.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
        Thomas Braun Most Active @ronk last edited by
        @ronk
        Immer sauber rebooten, nie einfach vom Strom reißen.
          ronk last edited by
          nochmal booten?
            @ronk
            War eigentlich ein allgemeiner Hinweis zum Umgang mit einem Betriebssystem. Die mögen das alle nicht.
              ronk last edited by
                                      v.2023-10-10
                       Icon name: computer
                    Architecture: arm64
              Installation:           native
              Kernel:                 aarch64
              Userland:               arm64
              Timezone:               Europe/Berlin (CET, +0100)
              User-ID:                1000
              X-Server:               false
              Pending OS-Updates:     0
              Pending iob updates:    0
              Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                      /usr/bin/npm            10.2.3
                                      /usr/bin/npx            10.2.3
              Recommended versions are nodejs 18.19.0 and npm 10.2.3
              MEMORY:
              Mem:            3.8G        1.6G        485M        129M        1.7G        1.9G
              Swap:            99M          0B         99M
              Total:          3.9G        1.6G        585M
              Active iob-Instances:   14
              ioBroker Core:          js-controller           5.0.16
                                      admin                   6.12.0
              Objects type: jsonl
              States  type: jsonl
              Objects:                3135
              States:                 3110
              Size of iob-Database:
              1.1M    /opt/iobroker/iobroker-data/states.jsonl
                ronk last edited by
                Influx db Sicherung läuft nun. Richtiger Token hilft. In Grafana finde ich keinen Token. Wo kann ich einen erstellen?
                • Marc Berg
                  Marc Berg Most Active @ronk last edited by Marc Berg
                  @ronk sagte in BackItUp erstellt keine backups mehr:
                  Service Accounts --> Add service account (Role "Admin") --> Token
                    ronk @Marc Berg last edited by
                    @marc-berg
                    Danke. Display name auch admin? Oder ist das egal?
                    • Marc Berg
                      Oder ist das egal?
                      Egal ...
                        @marc-berg
                        Danke. Das wars. Sicherung läuft durch. Token...
                        Ich danke euch.
                        Viele Grüße.
                        • Eulo
                          Eulo @Marc Berg last edited by
                          @marc-berg wie mounte ich denn manuell?
                          1239
