    3. Off Topic
    4. Internetausfälle durch iobroker?
    • DJMarc75
      DJMarc75 @Maas-Meister last edited by
      @maas-meister mal die langfassung von
      iob diag
      bitte zeigen
      • Codierknecht
        Codierknecht Developer Most Active @crunchip last edited by
        @crunchip
        Hast Recht. Noch nichtmal auf "halbe Versionsnummer" kann man sich jetzt noch verlassen 😞
          			v.2023-10-10
           Static hostname: MaasServer
                 Icon name: computer-desktop
                   Chassis: desktop
          Operating System: Ubuntu 22.04.3 LTS
                    Kernel: Linux 5.15.0-89-generic
              Architecture: x86-64
           Hardware Vendor: Gigabyte Technology Co., Ltd.
            Hardware Model: To be filled by O.E.M.
          Installation: 		native
          Kernel: 		x86_64
          Userland: 		amd64
          Timezone: 		Europe/Berlin (CET, +0100)
          User-ID: 		1000
          X-Server: 		false
          Boot Target: 		graphical.target
          Pending OS-Updates: 	2
          Pending iob updates: 	0
          Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
          			/usr/bin/node 		v18.19.0
          			/usr/bin/npm 		10.2.3
          			/usr/bin/npx 		10.2.3
          			/usr/bin/corepack 	0.22.0
          Recommended versions are nodejs 18.19.0 and npm 10.2.3
          MEMORY:
          Mem:            7.8G        4.8G        235M        326M        2.8G        2.4G
          Swap:           2.0G        7.0M        2.0G
          Total:          9.9G        4.8G        2.3G
          Active iob-Instances: 	47
          Active repo(s): Stable (default)
          ioBroker Core: 		js-controller 		5.0.16
          			admin 			6.12.0
          ioBroker Status: 	iobroker is running on this host.
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.0                  : admin                 : MaasServer                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.web.0                    : web                   : MaasServer                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects: 		29110
          States: 		26122
          Size of iob-Database:
          33M	/opt/iobroker/iobroker-data/objects.jsonl
          14M	/opt/iobroker/iobroker-data/objects.json.migrated
          14M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
          40M	/opt/iobroker/iobroker-data/states.jsonl
          6.0M	/opt/iobroker/iobroker-data/states.json.migrated
          6.0M	/opt/iobroker/iobroker-data/states.json.bak.migrated
          0	/opt/iobroker/iobroker-data/states.json.broken
          • DJMarc75
            @maas-meister bitte auch die Langfassung zeigen
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Chassis: desktop
              model name	: Intel(R) Celeron(R) CPU 1037U @ 1.80GHz
              Docker          : false
              Virtualization  : none
              Kernel          : x86_64
              Userland        : amd64
              Systemuptime and Load:
               18:23:24 up 20:16,  2 users,  load average: 2.09, 1.92, 1.53
              CPU threads: 2
              *** Time and Time Zones ***
                             Local time: Tue 2023-12-05 18:23:24 CET
                         Universal time: Tue 2023-12-05 17:23:24 UTC
                               RTC time: Tue 2023-12-05 17:23:24
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              maas-meister
              /home/maas-meister
              maas-meister adm cdrom sudo dip plugdev lpadmin lxd sambashare iobroker
              *** X-Server-Setup ***
              X-Server: 	false
              Desktop: 	ubuntu
              Terminal: 	wayland
              *** MEMORY ***
              Mem:            7.8G        4.7G        293M        341M        2.8G        2.4G
              Swap:           2.0G        8.0M        2.0G
                       7829 M total memory
                       4743 M used memory
                       1509 M active memory
                       5268 M inactive memory
                        293 M free memory
                        426 M buffer memory
                       2365 M swap cache
                       2047 M total swap
                          8 M used swap
                       2039 M free swap
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              Filesystem     Type   Size  Used Avail Use% Mounted on
              tmpfs          tmpfs  783M  1.8M  782M   1% /run
              /dev/sda2      ext4   234G   31G  191G  14% /
              tmpfs          tmpfs  3.9G   20M  3.9G   1% /dev/shm
              tmpfs          tmpfs  5.0M  4.0K  5.0M   1% /run/lock
              /dev/sda1      vfat   511M  6.1M  505M   2% /boot/efi
              tmpfs          tmpfs  783M  120K  783M   1% /run/user/1000
              [Mon Dec  4 22:06:40 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
              [Mon Dec  4 22:06:41 2023] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro. Quota mode: none.
              TARGET                                   SOURCE                         FSTYPE      OPTIONS
              /                                        /dev/sda2                      ext4        rw,relatime,errors=remount-ro
              |-/run/user/1000/doc                     portal                         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
              |-/snap/bare/5                           /dev/loop1                     squashfs    ro,nodev,relatime,errors=continue
              |-/snap/core20/1974                      /dev/loop2                     squashfs    ro,nodev,relatime,errors=continue
              |-/snap/core18/2796                      /dev/loop3                     squashfs    ro,nodev,relatime,errors=continue
              |-/snap/core20/2015                      /dev/loop4                     squashfs    ro,nodev,relatime,errors=continue
              |-/snap/core22/858                       /dev/loop5                     squashfs    ro,nodev,relatime,errors=continue
              |-/snap/core22/864                       /dev/loop6                     squashfs    ro,nodev,relatime,errors=continue
              |-/snap/firefox/3504                     /dev/loop7                     squashfs    ro,nodev,relatime,errors=continue
              |-/snap/gnome-3-28-1804/198              /dev/loop8                     squashfs    ro,nodev,relatime,errors=continue
              |-/snap/gnome-3-28-1804/194              /dev/loop11                    squashfs    ro,nodev,relatime,errors=continue
              |-/snap/gnome-3-38-2004/143              /dev/loop12                    squashfs    ro,nodev,relatime,errors=continue
              |-/snap/gnome-3-38-2004/140              /dev/loop9                     squashfs    ro,nodev,relatime,errors=continue
              |-/snap/gnome-42-2204/141                /dev/loop10                    squashfs    ro,nodev,relatime,errors=continue
              |-/snap/gnome-42-2204/132                /dev/loop13                    squashfs    ro,nodev,relatime,errors=continue
              |-/snap/gtk-common-themes/1534           /dev/loop14                    squashfs    ro,nodev,relatime,errors=continue
              |-/snap/gtk-common-themes/1535           /dev/loop15                    squashfs    ro,nodev,relatime,errors=continue
              |-/snap/snap-store/638                   /dev/loop16                    squashfs    ro,nodev,relatime,errors=continue
              |-/snap/snap-store/959                   /dev/loop17                    squashfs    ro,nodev,relatime,errors=continue
              |-/var/snap/firefox/common/host-hunspell /dev/sda2[/usr/share/hunspell] ext4        ro,noexec,noatime,errors=remount-ro
              |-/snap/snapd/20092                      /dev/loop18                    squashfs    ro,nodev,relatime,errors=continue
              |-/snap/snapd/20290                      /dev/loop19                    squashfs    ro,nodev,relatime,errors=continue
              |-/snap/spotify/70                       /dev/loop21                    squashfs    ro,nodev,relatime,errors=continue
              |-/snap/spotify/73                       /dev/loop20                    squashfs    ro,nodev,relatime,errors=continue
              |-/boot/efi                              /dev/sda1                      vfat        rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
              `-/snap/core18/2812                      /dev/loop22                    squashfs    ro,nodev,relatime,errors=continue
              /var:
              8.6G	/var/
              5.0G	/var/lib
              4.6G	/var/lib/snapd
              3.5G	/var/log
              3.4G	/var/log/journal/573de1de43694820a522c2dbc558889f
              Archived and active journals take up 3.3G in the file system.
              /opt/iobroker/backups:
              1.8G	/opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              2.2G	/opt/iobroker/iobroker-data/
              1.5G	/opt/iobroker/iobroker-data/files
              602M	/opt/iobroker/iobroker-data/files/vis-2-beta
              545M	/opt/iobroker/iobroker-data/files/vis-2-beta/static
              543M	/opt/iobroker/iobroker-data/files/vis-2-beta/static/js
              47M	/opt/iobroker/iobroker-data/states.jsonl
              35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
              33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
              24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
              USB-Devices by-id:
              *** NodeJS-Installation ***
              /usr/bin/npm 		10.2.3
              /usr/bin/npx 		10.2.3
              nodejs:
                Installed: 18.19.0-1nodesource1
                Candidate: 18.19.0-1nodesource1
                Version table:
               *** 18.19.0-1nodesource1 1001
                      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                      100 /var/lib/dpkg/status
                   18.18.2-1nodesource1 1001
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
                   12.22.9~dfsg-1ubuntu3.2 500
                      500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                      500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                   12.22.9~dfsg-1ubuntu3 500
                      500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller: 	5.0.16
              admin: 		6.12.0
              javascript: 	7.1.6
              Adapters from github: 	6
              Adapter State
              + system.adapter.alexa2.0                 : alexa2                : MaasServer                               -  enabled
                system.adapter.alias-manager.0          : alias-manager         : MaasServer                               -  enabled
              + system.adapter.awtrix-light.0           : awtrix-light          : MaasServer                               -  enabled
              + system.adapter.backitup.0               : backitup              : MaasServer                               -  enabled
                system.adapter.birthdays.0              : birthdays             : MaasServer                               -  enabled
              + system.adapter.bring.0                  : bring                 : MaasServer                               -  enabled
                system.adapter.daswetter.0              : daswetter             : MaasServer                               -  enabled
              + system.adapter.device-watcher.0         : device-watcher        : MaasServer                               -  enabled
                system.adapter.devices.0                : devices               : MaasServer                               -  enabled
              + system.adapter.discovery.0              : discovery             : MaasServer                               -  enabled
                system.adapter.dwd.0                    : dwd                   : MaasServer                               -  enabled
              + system.adapter.echarts.0                : echarts               : MaasServer                               -  enabled
              + system.adapter.energiefluss.0           : energiefluss          : MaasServer                               -  enabled
              + system.adapter.fb-checkpresence.0       : fb-checkpresence      : MaasServer                               -  enabled
              + system.adapter.fritzbox.0               : fritzbox              : MaasServer                               -  enabled
              + system.adapter.fullybrowser.0           : fullybrowser          : MaasServer                               -  enabled
              + system.adapter.harmony.0                : harmony               : MaasServer                               -  enabled
              + system.adapter.history.0                : history               : MaasServer                               -  enabled
                system.adapter.ical.0                   : ical                  : MaasServer                               -  enabled
                system.adapter.ical.1                   : ical                  : MaasServer                               -  enabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : MaasServer                               -  enabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : MaasServer                               -  enabled
              + system.adapter.info.0                   : info                  : MaasServer                               -  enabled
              + system.adapter.iot.0                    : iot                   : MaasServer                               -  enabled
              + system.adapter.javascript.0             : javascript            : MaasServer                               -  enabled
              + system.adapter.kostal-piko-ba.0         : kostal-piko-ba        : MaasServer                               -  enabled
                system.adapter.meteoalarm.0             : meteoalarm            : MaasServer                               -  enabled
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : MaasServer                               -  enabled, port: 54321
              + system.adapter.mqtt.0                   : mqtt                  : MaasServer                               -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.netatmo-crawler.0        : netatmo-crawler       : MaasServer                               -  enabled
              + system.adapter.nibeuplink.0             : nibeuplink            : MaasServer                               -  enabled
              + system.adapter.openligadb.0             : openligadb            : MaasServer                               -  enabled
                system.adapter.openweathermap.0         : openweathermap        : MaasServer                               - disabled
              + system.adapter.ping.0                   : ping                  : MaasServer                               -  enabled
              + system.adapter.pvforecast.0             : pvforecast            : MaasServer                               -  enabled
              + system.adapter.rssfeed.0                : rssfeed               : MaasServer                               -  enabled
              + system.adapter.scheduler.0              : scheduler             : MaasServer                               -  enabled
              + system.adapter.shelly.0                 : shelly                : MaasServer                               -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.shelly.1                 : shelly                : MaasServer                               -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.shuttercontrol.0         : shuttercontrol        : MaasServer                               -  enabled
              + system.adapter.smartthings.0            : smartthings           : MaasServer                               -  enabled
              + system.adapter.sonos.0                  : sonos                 : MaasServer                               -  enabled
              + system.adapter.sourceanalytix.0         : sourceanalytix        : MaasServer                               -  enabled
              + system.adapter.spotify-premium.0        : spotify-premium       : MaasServer                               -  enabled
              + system.adapter.tankerkoenig.0           : tankerkoenig          : MaasServer                               -  enabled
              + system.adapter.tibberlink.0             : tibberlink            : MaasServer                               -  enabled
              + system.adapter.time-switch.0            : time-switch           : MaasServer                               -  enabled
              + system.adapter.tr-064.0                 : tr-064                : MaasServer                               -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : MaasServer                               -  enabled
              + system.adapter.tvprogram.0              : tvprogram             : MaasServer                               -  enabled
                system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : MaasServer                               -  enabled
                system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : MaasServer                               -  enabled
                system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: MaasServer                               -  enabled
                system.adapter.vis-bars.0               : vis-bars              : MaasServer                               -  enabled
                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : MaasServer                               -  enabled
                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : MaasServer                               -  enabled
                system.adapter.vis-history.0            : vis-history           : MaasServer                               -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : MaasServer                               -  enabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : MaasServer                               -  enabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : MaasServer                               -  enabled
                system.adapter.vis-justgage.0           : vis-justgage          : MaasServer                               -  enabled
                system.adapter.vis-material-advanced.0  : vis-material-advanced : MaasServer                               -  enabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : MaasServer                               -  enabled
                system.adapter.vis-metro.0              : vis-metro             : MaasServer                               -  enabled
                system.adapter.vis-weather.0            : vis-weather           : MaasServer                               -  enabled
                system.adapter.vis.0                    : vis                   : MaasServer                               -  enabled
                system.adapter.weatherunderground.0     : weatherunderground    : MaasServer                               -  enabled
              + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : MaasServer                               -  enabled
              + system.adapter.wifilight.0              : wifilight             : MaasServer                               -  enabled
              + system.adapter.wled.0                   : wled                  : MaasServer                               -  enabled
              + system.adapter.zigbee.0                 : zigbee                : MaasServer                               -  enabled, port: tcp://192.168.178.203:6638
              + instance is alive
              ioBroker-Repositories
              Stable (default): http://download.iobroker.net/sources-dist.json
              Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
              Installed ioBroker-Instances
              Used repository: Stable (default)
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
              Adapter    "awtrix-light" : 0.10.0   , installed 0.10.0
              Adapter    "backitup"     : 2.8.7    , installed 2.8.7
              Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
              Adapter    "bring"        : 1.8.4    , installed 1.8.4
              Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
              Adapter    "device-watcher": 2.9.6   , installed 2.9.6
              Adapter    "echarts"      : 1.5.4    , installed 1.5.4
              Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
              Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
              Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
              Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
              Adapter    "harmony"      : 1.3.0    , installed 1.3.0
              Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
              Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
              Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
              Adapter    "iot"          : 2.0.11   , installed 2.0.11
              Adapter    "javascript"   : 7.1.6    , installed 7.1.6
              Controller "js-controller": 5.0.16   , installed 5.0.16
              Adapter    "kostal-piko-ba": 3.0.8   , installed 3.0.8
              Adapter    "meteoalarm"   : 2.3.7    , installed 2.3.7
              Adapter    "mihome"       : 1.4.0    , installed 1.4.0
              Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
              Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
              Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
              Adapter    "nibeuplink"   : 1.3.0    , installed 1.3.0
              Adapter    "openligadb"   : 1.2.4    , installed 1.3.4
              Adapter    "openweathermap": 0.4.5   , installed 0.4.5
              Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
              Adapter    "pushover"     : 3.0.3    , installed 3.0.3
              Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
              Adapter    "radar2"       : 2.1.0    , installed 2.1.0
              Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
              Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
              Adapter    "shelly"       : 6.6.1    , installed 6.6.1
              Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
              Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
              Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
              Adapter    "sonos"        : 3.0.0    , installed 3.0.0
              Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
              Adapter    "tibberlink"   : 1.6.1    , installed 1.6.1
              Adapter    "trashschedule": 2.3.0    , installed 2.3.0
              Adapter    "tuya"         : 3.14.2   , installed 3.14.2
              Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
              Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
              Adapter    "vis"          : 1.4.16   , installed 1.4.16
              Adapter    "vis-icontwo"  : 0.98.0   , installed 0.98.0
              Adapter    "vis-justgage" : 2.0.2    , installed 2.0.2
              Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
              Adapter    "weatherunderground": 3.6.0, installed 3.6.0
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
              Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
              Adapter    "wled"         : 0.7.1    , installed 0.7.1
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Adapter    "yahka"        : 1.0.3    , installed 1.0.3
              Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
              Objects and States
              Objects: 	29110
              States: 	26122
              W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target Packages (main/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target Translations (main/i18n/Translation-de) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target DEP-11 (main/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target DEP-11 (main/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target DEP-11-icons-small (main/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target DEP-11-icons (main/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target DEP-11-icons-hidpi (main/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target CNF (main/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target CNF (main/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target Packages (restricted/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target Packages (restricted/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target Packages (restricted/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target Translations (restricted/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target Translations (restricted/i18n/Translation-de) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target DEP-11 (restricted/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target DEP-11 (restricted/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target DEP-11-icons-small (restricted/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target DEP-11-icons (restricted/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target DEP-11-icons-hidpi (restricted/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target CNF (restricted/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              W: Target CNF (restricted/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
              Hit:1 http://security.ubuntu.com/ubuntu jammy-security InRelease
              Hit:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
              Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
              Hit:4 http://archive.ubuntu.com/ubuntu jammy InRelease
              Hit:5 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
              Reading package lists...
              Pending Updates: 2
              *** Listening Ports ***
              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        21373      453/systemd-resolve
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          127106     17657/cupsd
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       91101      15008/iobroker.js-c
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       90001      15008/iobroker.js-c
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       558202     38321/io.mqtt.0
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       93176      15302/io.shelly.1
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17016      1/init
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       90100      15026/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       93624      15363/io.web.0
              tcp6       0      0 :::3389                 :::*                    LISTEN      126        24129      800/xrdp
              tcp6       0      0 :::3500                 :::*                    LISTEN      1001       386267     29099/io.sonos.0
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          127105     17657/cupsd
              tcp6       0      0 ::1:3350                :::*                    LISTEN      0          22741      765/xrdp-sesman
              tcp6       0      0 :::61991                :::*                    LISTEN      1001       94522      15499/io.harmony.0
              tcp6       0      0 :::111                  :::*                    LISTEN      0          17018      1/init
              udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       641662     41290/chrome
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       557609     38365/io.wled.0
              udp        0      0 192.168.178.10:5353     0.0.0.0:*                           1001       92662      15126/io.tr-064.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        22573      665/avahi-daemon: r
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       94214      15281/io.shelly.0
              udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        21372      453/systemd-resolve
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17017      1/init
              udp        0      0 0.0.0.0:57483           0.0.0.0:*                           115        22575      665/avahi-daemon: r
              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       387656     29288/io.mihome-vac
              udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       94523      15499/io.harmony.0
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          126795     17661/cups-browsed
              udp6       0      0 :::5353                 :::*                                115        22574      665/avahi-daemon: r
              udp6       0      0 :::34664                :::*                                115        22576      665/avahi-daemon: r
              udp6       0      0 :::111                  :::*                                0          17019      1/init
              udp6       0      0 fe80::60ba:5c16:9b7:546 :::*                                0          24703      669/NetworkManager
              2023-12-05 18:17:57.236  - debug: openligadb.0 (29256) request url https://api.openligadb.de/getgoalgetters/bl1/2023
              2023-12-05 18:17:57.341  - debug: openligadb.0 (29256) createObject currgameday
              2023-12-05 18:17:57.347  - debug: openligadb.0 (29256) createObject table
              2023-12-05 18:17:57.361  - debug: openligadb.0 (29256) setState currgameday
              2023-12-05 18:17:57.362  - debug: openligadb.0 (29256) setState name: bl1.2023.currgameday
              2023-12-05 18:17:57.365  - debug: openligadb.0 (29256) setState table
              2023-12-05 18:17:57.365  - debug: openligadb.0 (29256) setState name: bl1.2023.table
              2023-12-05 18:17:57.380  - debug: openligadb.0 (29256) createObject goalgetters
              2023-12-05 18:17:57.422  - debug: openligadb.0 (29256) setState goalgetters
              2023-12-05 18:17:57.422  - debug: openligadb.0 (29256) setState name: bl1.2023.goalgetters
              2023-12-05 18:17:57.505  - debug: openligadb.0 (29256) createObject allmatches
              2023-12-05 18:17:57.614  - debug: openligadb.0 (29256) setState allmatches
              2023-12-05 18:17:57.614  - debug: openligadb.0 (29256) setState name: bl1.2023.allmatches
              2023-12-05 18:20:00.007  - warn: host.MaasServer instance system.adapter.netatmo-crawler.0 already running with pid 37401
              2023-12-05 18:20:00.056  - info: host.MaasServer instance system.adapter.dwd.0 started with pid 43285
              2023-12-05 18:20:03.511  - info: dwd.0 (43285) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.16
              2023-12-05 18:20:04.078  - info: host.MaasServer instance system.adapter.meteoalarm.0 started with pid 43300
              2023-12-05 18:20:07.203  - info: dwd.0 (43285) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-12-05 18:20:07.725  - info: meteoalarm.0 (43300) starting. Version 2.3.7 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v18.19.0, js-controller: 5.0.16
              2023-12-05 18:20:07.848  - info: host.MaasServer instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-12-05 18:20:15.480  - info: meteoalarm.0 (43300) 15.1: Updated Weather Alarms for Kreis Verden -> 2 alarm(s) found
              2023-12-05 18:20:15.481  - info: meteoalarm.0 (43300) Terminated (ADAPTER_REQUESTED_TERMINATION): All data processed. Adapter stopped until next scheduled process.
              2023-12-05 18:20:16.048  - info: host.MaasServer instance system.adapter.meteoalarm.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-12-05 18:22:10.422  - warn: sonos.0 (29099) State "sonos.0.root.192_168_178_51.current_track_number" has no existing object, this might lead to an error in future versions
              2023-12-05 18:22:10.488  - warn: sonos.0 (29099) State "sonos.0.root.192_168_178_51.queue_html" has no existing object, this might lead to an error in future versions
              DJMarc75 Codierknecht 2 Replies Last reply Reply Quote 0
              • OliverIO
                OliverIO @Maas-Meister last edited by
                @maas-meister sagte in Internetausfälle durch iobroker?:
                ich habe sehr viele Internetausfälle / Neuverbindungen
                wie äußert sich das.
                fällt dann wirklich das internet aus?
                oder das LAN
                oder das WLAN?
                hast du doppelte IP-Adressen oder MAC Adressen im Netz?
                Was hast du getan zum zeitpunkt als es nicht mehr funktionierte?
                • DJMarc75
                  @maas-meister
                  Was mir auffällt ist dass Deine beiden Shelly Instanzen auf dem selben Port laufen - das geht nicht.
                  Zum Rest kann ich nix sagen 😉
                  • Codierknecht
                    Codierknecht Developer Most Active @Maas-Meister last edited by
                    Ich lese zwar
                    X-Server: 	false
                    aber bei den mounts auch was von "gnome", "gtk" usw.
                    Ist da jetzt ein Desktop drauf oder nicht?
                    M Thomas Braun 2 Replies Last reply Reply Quote 0
                      Maas-Meister @OliverIO last edited by
                      @oliverio
                      • Ich habe dann keine Verbindung mehr von der FritzBox nach "draußen".
                        Nach 2-5min. ist die Verbindung dann wieder da.
                        Die Ausfälle sind alle 10-30min.
                      • LAN und WLAN läuft weiterhin.
                      Das ich massive Ausfälle habe, ist mir erst einige Tage später aufgefallen.
                      Ich kann leider keinen Zeitpunkt mehr definieren, sodass ich gucken kann, was ich am System gemacht habe.
                      Ich habe einige feste IPs im Netzwerk, dann ich die doppelten irgendwie ermitteln?
                      In der Übersicht ist nichts auffällig.
                        Maas-Meister @Codierknecht last edited by
                        @codierknecht
                        Ich habe meinen Desktop/Bildschirm direkt am Server angeschlossen, sofern das die Frage war 😊
                        MartinP Codierknecht 2 Replies Last reply Reply Quote 0
                        • MartinP
                          MartinP @Maas-Meister last edited by
                          @maas-meister Das Logging der Fritzbox wäre sicherlich auch interessant...
                          Unter "System/Ereignisse/Internetverbindung" irgendwelche Loggings?
                          • Codierknecht
                            @codierknecht
                            Das heißt, auf der Maschine läuft ein "klickibunti" Linux mit Desktop?
                            Also KDE, Gnome, Cinnamon oder etwas vergleichbares?
                            Oder hängen da lediglich Monitor und Tatstatur dran und Du arbeitest da in der Konsole?
                              Maas-Meister @MartinP last edited by
                              @martinp sagte in Internetausfälle durch iobroker?:
                              05.12.23
                              18:45:50
                              IPv6-Präfix wurde erfolgreich aktualisiert. Neues Präfix: 2003:f4:3701:5b00::/56
                              05.12.23
                              18:30:50
                              Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.142.201, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                              05.12.23
                              18:30:50
                              Internetverbindung IPv6: AFTR konnte nicht bezogen werden: Grund 7 (got no aftr)
                              05.12.23
                              18:30:50
                              IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3701:5b00::/56
                              05.12.23
                              18:30:50
                              Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:15f:3e37:12ff:feea:226d
                              05.12.23
                              18:30:50
                              Information des Anbieters über die Geschwindigkeit des Internetzugangs (verfügbare Bitrate): 26412/30706 kbit/s
                              05.12.23
                              18:30:41
                              DSL ist verfügbar (DSL-Synchronisierung besteht mit 37291/31951 kbit/s).
                              05.12.23
                              18:29:44
                              PPPoE-Fehler: Zeitüberschreitung.
                              05.12.23
                              18:29:17
                              DSL-Synchronisierung beginnt (Training).
                              05.12.23
                              18:29:11
                              DSL antwortet nicht (Keine DSL-Synchronisierung).
                              05.12.23
                              18:28:58
                              DSL ist verfügbar (DSL-Synchronisierung besteht mit 39354/34107 kbit/s).
                              05.12.23
                              18:27:32
                              05.12.23
                              18:27:06
                              Zeitüberschreitung bei der PPP-Aushandlung.
                              05.12.23
                              18:27:06
                              Internetverbindung IPv6 wurde getrennt, Präfix nicht mehr gültig.
                              05.12.23
                              18:27:06
                              Internetverbindung wurde getrennt.
                              05.12.23
                              18:27:01
                              05.12.23
                              18:00:28
                              IPv6-Präfix wurde erfolgreich aktualisiert. Neues Präfix: 2003:f4:3701:4c00::/56
                              05.12.23
                              17:45:28
                              Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.142.168, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                              05.12.23
                              17:45:28
                              05.12.23
                              17:45:28
                              IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3701:4c00::/56
                              05.12.23
                              17:45:28
                              Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:150:3e37:12ff:feea:226d
                              05.12.23
                              17:45:18
                              DSL ist verfügbar (DSL-Synchronisierung besteht mit 26422/30717 kbit/s).
                              05.12.23
                              17:43:54
                              05.12.23
                              17:43:48
                              05.12.23
                              17:43:48
                              05.12.23
                              17:43:48
                              05.12.23
                              17:43:43
                              05.12.23
                              16:34:00
                              IPv6-Präfix wurde erfolgreich aktualisiert. Neues Präfix: 2003:f4:3701:1000::/56
                              05.12.23
                              16:19:01
                              Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.142.75, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                              05.12.23
                              16:19:00
                              05.12.23
                              16:19:00
                              IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3701:1000::/56
                              05.12.23
                              16:19:00
                              Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:117:3e37:12ff:feea:226d
                              05.12.23
                              16:18:51
                              DSL ist verfügbar (DSL-Synchronisierung besteht mit 37461/34309 kbit/s).
                              05.12.23
                              16:17:26
                              05.12.23
                              16:17:21
                              05.12.23
                              16:17:20
                              05.12.23
                              16:17:20
                              05.12.23
                              16:17:16
                              05.12.23
                              16:16:59
                              Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.142.74, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                              05.12.23
                              16:16:59
                              05.12.23
                              16:16:59
                              IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3701:e00::/56
                              05.12.23
                              16:16:59
                              Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:116:3e37:12ff:feea:226d
                              05.12.23
                              16:16:59
                              Information des Anbieters über die Geschwindigkeit des Internetzugangs (verfügbare Bitrate): 35648/33535 kbit/s
                              05.12.23
                              16:16:49
                              DSL ist verfügbar (DSL-Synchronisierung besteht mit 63082/35756 kbit/s).
                              05.12.23
                              16:15:25
                              05.12.23
                              16:15:23
                              05.12.23
                              16:15:23
                              05.12.23
                              16:15:23
                              05.12.23
                              16:15:18
                              05.12.23
                              16:13:31
                              Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.142.67, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                              05.12.23
                              16:13:30
                              05.12.23
                              16:13:30
                              IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3701:a00::/56
                              05.12.23
                              16:13:30
                              Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:10e:3e37:12ff:feea:226d
                              05.12.23
                              16:13:21
                              DSL ist verfügbar (DSL-Synchronisierung besteht mit 35660/33547 kbit/s).
                              05.12.23
                              16:11:55
                              05.12.23
                              16:11:48
                              05.12.23
                              16:11:48
                              05.12.23
                              16:11:48
                              05.12.23
                              16:11:43
                              05.12.23
                              16:06:55
                              Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.142.50, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                              05.12.23
                              16:06:55
                              05.12.23
                              16:06:55
                              IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3701:300::/56
                              05.12.23
                              16:06:54
                              Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:108:3e37:12ff:feea:226d
                              05.12.23
                              16:06:54
                              Information des Anbieters über die Geschwindigkeit des Internetzugangs (verfügbare Bitrate): 41944/34388 kbit/s
                              05.12.23
                              16:06:45
                              DSL ist verfügbar (DSL-Synchronisierung besteht mit 84602/42463 kbit/s).
                              05.12.23
                              16:05:20
                              05.12.23
                              16:05:14
                              05.12.23
                              16:05:13
                              05.12.23
                              16:05:13
                              05.12.23
                              16:05:09
                              05.12.23
                              15:55:30
                              IPv6-Präfix wurde erfolgreich aktualisiert. Neues Präfix: 2003:f4:3700:f500::/56
                              05.12.23
                              15:40:30
                              Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.142.30, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                              05.12.23
                              15:40:30
                              05.12.23
                              15:40:30
                              IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3700:f500::/56
                              05.12.23
                              15:40:30
                              Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:f9:3e37:12ff:feea:226d
                              05.12.23
                              15:40:20
                              DSL ist verfügbar (DSL-Synchronisierung besteht mit 41958/34400 kbit/s).
                              05.12.23
                              15:39:19
                              05.12.23
                              15:38:56
                              05.12.23
                              15:38:50
                              05.12.23
                              15:38:34
                              DSL ist verfügbar (DSL-Synchronisierung besteht mit 67253/37344 kbit/s).
                              05.12.23
                              15:37:10
                              DSL-Synchronisierung beginnt (Training). [2 Meldungen seit 05.12.23 15:37:02]
                              05.12.23
                              15:36:54
                              05.12.23
                              15:36:53
                              05.12.23
                              15:36:53
                              05.12.23
                              15:36:49
                              05.12.23
                              15:33:22
                              IPv6-Präfix wurde erfolgreich aktualisiert. Neues Präfix: 2003:f4:3700:e900::/56
                              05.12.23
                              15:18:22
                              Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.142.17, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                              05.12.23
                              15:18:22
                              05.12.23
                              15:18:22
                              IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3700:e900::/56
                              05.12.23
                              15:18:21
                              Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:f0:3e37:12ff:feea:226d
                              05.12.23
                              15:18:21
                              Information des Anbieters über die Geschwindigkeit des Internetzugangs (verfügbare Bitrate): 42009/34826 kbit/s
                              05.12.23
                              15:18:12
                              DSL ist verfügbar (DSL-Synchronisierung besteht mit 46026/37440 kbit/s).
                              05.12.23
                              15:16:48
                              05.12.23
                              15:16:47
                              05.12.23
                              15:16:47
                              05.12.23
                              15:16:46
                              05.12.23
                              15:16:42
                              05.12.23
                              15:08:54
                              IPv6-Präfix wurde erfolgreich aktualisiert. Neues Präfix: 2003:f4:3700:d400::/56
                              05.12.23
                              14:53:54
                              Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.143.241, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                              05.12.23
                              14:53:54
                              05.12.23
                              14:53:54
                              IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3700:d400::/56
                              05.12.23
                              14:53:53
                              Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:d9:3e37:12ff:feea:226d
                              05.12.23
                              14:53:53
                              Information des Anbieters über die Geschwindigkeit des Internetzugangs (verfügbare Bitrate): 32633/29811 kbit/s
                              05.12.23
                              14:53:44
                              DSL ist verfügbar (DSL-Synchronisierung besteht mit 42024/34838 kbit/s).
                              05.12.23
                              14:52:20
                              05.12.23
                              14:52:19
                              05.12.23
                              14:52:18
                              05.12.23
                              14:52:18
                              05.12.23
                              14:52:14
                              05.12.23
                              14:28:10
                              IPv6-Präfix wurde erfolgreich aktualisiert. Neues Präfix: 2003:f4:3700:c000::/56
                              05.12.23
                              14:13:10
                              Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.143.209, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                              05.12.23
                              14:13:10
                              05.12.23
                              14:13:10
                              IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3700:c000::/56
                              05.12.23
                              14:13:10
                              Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:c4:3e37:12ff:feea:226d
                              05.12.23
                              14:13:01
                              DSL ist verfügbar (DSL-Synchronisierung besteht mit 32643/29822 kbit/s).
                              05.12.23
                              14:11:37
                              05.12.23
                              14:11:33
                              05.12.23
                              14:11:32
                              05.12.23
                              14:11:32
                              05.12.23
                              14:11:27
                              05.12.23
                              14:00:55
                              IPv6-Präfix wurde erfolgreich aktualisiert. Neues Präfix: 2003:f4:3700:ae00::/56
                              05.12.23
                              13:45:55
                              Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.143.192, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                              05.12.23
                              13:45:55
                              05.12.23
                              13:45:55
                              IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3700:ae00::/56
                              05.12.23
                              13:45:55
                              Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:b4:3e37:12ff:feea:226d
                              05.12.23
                              13:45:45
                              DSL ist verfügbar (DSL-Synchronisierung besteht mit 40616/35299 kbit/s).
                              05.12.23
                              13:44:21
                              05.12.23
                              13:44:20
                              05.12.23
                              13:44:20
                              05.12.23
                              13:44:20
                              05.12.23
                              13:44:15
                              05.12.23
                              12:59:08
                              IPv6-Präfix wurde erfolgreich aktualisiert. Neues Präfix: 2003:f4:3700:9500::/56
                              05.12.23
                              12:44:08
                              Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.143.158, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                              05.12.23
                              12:44:08
                              05.12.23
                              12:44:08
                              IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3700:9500::/56
                              05.12.23
                              12:44:08
                              Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:9a:3e37:12ff:feea:226d
                              05.12.23
                              12:43:58
                              DSL ist verfügbar (DSL-Synchronisierung besteht mit 42070/36076 kbit/s).
                              05.12.23
                              12:42:34
                              05.12.23
                              12:42:28
                              05.12.23
                              12:42:28
                              05.12.23
                              12:42:28
                              05.12.23
                              12:42:23
                              05.12.23
                              12:37:43
                              Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.143.157, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                              05.12.23
                              12:37:43
                              05.12.23
                              12:37:43
                              IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3700:9400::/56
                              05.12.23
                              12:37:42
                              Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:98:3e37:12ff:feea:226d
                              05.12.23
                              12:37:42
                              Information des Anbieters über die Geschwindigkeit des Internetzugangs (verfügbare Bitrate): 40794/35786 kbit/s
                              05.12.23
                              12:37:33
                              DSL ist verfügbar (DSL-Synchronisierung besteht mit 55668/37866 kbit/s).
                                Maas-Meister @Codierknecht last edited by Maas-Meister
                                @codierknecht sagte in Internetausfälle durch iobroker?:
                                @codierknecht
                                Ich glaube wir reden aneinander vorbei.
                                KDE, Gnome etc. kenne ich nicht.
                                Auf dem MiniPC läuft Ubuntu (in der Desktop Version) und darauf iobroker.
                                An dem MiniPc hängt mein Bildschirm mit Tastatur, aber das wolltest du bestimmt nicht wissen.
                                • DJMarc75
                                  @maas-meister hast Du da irgendwas mit Powerline am Start ?
                                    Thomas Braun Most Active @Codierknecht last edited by
                                    Das ist ein Fehler in diag
                                    Ist in der Beta gefixt, die ist aber noch nicht hochgeladen. Zu @apollon77 schiel...
                                    • Codierknecht
                                      @maas-meister
                                      Ich frage anders: Hast Du in Deinem Linux eine grafische Benutzeroberfläche, oder arbeitest Du nur per Kommandozeile?
                                      @Thomas-Braun
                                      Also ist da trotz anderslautender Info einer drauf?
                                        Maas-Meister @DJMarc75 last edited by
                                        @djmarc75
                                        Keine Ahnung.
                                        Wenn, dann nur Ausversehen.
                                        Ich nutze eigentlich nur die Standard-Anwendungen und bin nicht so tief im Thema drin.
                                        Ich müsste erstmal nach "Powerline" googlen, das sagt schon alles.
                                          @codierknecht
                                          Grafische Oberfläche.
                                          Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
                                            Ja, die Abfrage wird durch X11 getriggert, ein Wayland wird nicht gesehen in der Version.
                                            53
                                            4930
