    3. Off Topic
    4. Internetausfälle durch iobroker?
    • Codierknecht
      Codierknecht Developer Most Active @crunchip last edited by
      @crunchip
      Hast Recht. Noch nichtmal auf "halbe Versionsnummer" kann man sich jetzt noch verlassen 😞
        Maas-Meister last edited by
        			v.2023-10-10
         Static hostname: MaasServer
               Icon name: computer-desktop
                 Chassis: desktop
        Operating System: Ubuntu 22.04.3 LTS
                  Kernel: Linux 5.15.0-89-generic
            Architecture: x86-64
         Hardware Vendor: Gigabyte Technology Co., Ltd.
          Hardware Model: To be filled by O.E.M.
        Installation: 		native
        Kernel: 		x86_64
        Userland: 		amd64
        Timezone: 		Europe/Berlin (CET, +0100)
        User-ID: 		1000
        X-Server: 		false
        Boot Target: 		graphical.target
        Pending OS-Updates: 	2
        Pending iob updates: 	0
        Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
        			/usr/bin/node 		v18.19.0
        			/usr/bin/npm 		10.2.3
        			/usr/bin/npx 		10.2.3
        			/usr/bin/corepack 	0.22.0
        Recommended versions are nodejs 18.19.0 and npm 10.2.3
        MEMORY:
        Mem:            7.8G        4.8G        235M        326M        2.8G        2.4G
        Swap:           2.0G        7.0M        2.0G
        Total:          9.9G        4.8G        2.3G
        Active iob-Instances: 	47
        Active repo(s): Stable (default)
        ioBroker Core: 		js-controller 		5.0.16
        			admin 			6.12.0
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : MaasServer                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : MaasServer                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects: 		29110
        States: 		26122
        Size of iob-Database:
        33M	/opt/iobroker/iobroker-data/objects.jsonl
        14M	/opt/iobroker/iobroker-data/objects.json.migrated
        14M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
        40M	/opt/iobroker/iobroker-data/states.jsonl
        6.0M	/opt/iobroker/iobroker-data/states.json.migrated
        6.0M	/opt/iobroker/iobroker-data/states.json.bak.migrated
        0	/opt/iobroker/iobroker-data/states.json.broken
        • DJMarc75
          DJMarc75 @Maas-Meister last edited by
          @maas-meister bitte auch die Langfassung zeigen
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Chassis: desktop
            model name	: Intel(R) Celeron(R) CPU 1037U @ 1.80GHz
            Docker          : false
            Virtualization  : none
            Kernel          : x86_64
            Userland        : amd64
            Systemuptime and Load:
             18:23:24 up 20:16,  2 users,  load average: 2.09, 1.92, 1.53
            CPU threads: 2
            *** Time and Time Zones ***
                           Local time: Tue 2023-12-05 18:23:24 CET
                       Universal time: Tue 2023-12-05 17:23:24 UTC
                             RTC time: Tue 2023-12-05 17:23:24
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            maas-meister
            /home/maas-meister
            maas-meister adm cdrom sudo dip plugdev lpadmin lxd sambashare iobroker
            *** X-Server-Setup ***
            X-Server: 	false
            Desktop: 	ubuntu
            Terminal: 	wayland
            *** MEMORY ***
            Mem:            7.8G        4.7G        293M        341M        2.8G        2.4G
            Swap:           2.0G        8.0M        2.0G
                     7829 M total memory
                     4743 M used memory
                     1509 M active memory
                     5268 M inactive memory
                      293 M free memory
                      426 M buffer memory
                     2365 M swap cache
                     2047 M total swap
                        8 M used swap
                     2039 M free swap
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            Filesystem     Type   Size  Used Avail Use% Mounted on
            tmpfs          tmpfs  783M  1.8M  782M   1% /run
            /dev/sda2      ext4   234G   31G  191G  14% /
            tmpfs          tmpfs  3.9G   20M  3.9G   1% /dev/shm
            tmpfs          tmpfs  5.0M  4.0K  5.0M   1% /run/lock
            /dev/sda1      vfat   511M  6.1M  505M   2% /boot/efi
            tmpfs          tmpfs  783M  120K  783M   1% /run/user/1000
            [Mon Dec  4 22:06:40 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
            [Mon Dec  4 22:06:41 2023] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro. Quota mode: none.
            TARGET                                   SOURCE                         FSTYPE      OPTIONS
            /                                        /dev/sda2                      ext4        rw,relatime,errors=remount-ro
            |-/run/user/1000/doc                     portal                         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
            |-/snap/bare/5                           /dev/loop1                     squashfs    ro,nodev,relatime,errors=continue
            |-/snap/core20/1974                      /dev/loop2                     squashfs    ro,nodev,relatime,errors=continue
            |-/snap/core18/2796                      /dev/loop3                     squashfs    ro,nodev,relatime,errors=continue
            |-/snap/core20/2015                      /dev/loop4                     squashfs    ro,nodev,relatime,errors=continue
            |-/snap/core22/858                       /dev/loop5                     squashfs    ro,nodev,relatime,errors=continue
            |-/snap/core22/864                       /dev/loop6                     squashfs    ro,nodev,relatime,errors=continue
            |-/snap/firefox/3504                     /dev/loop7                     squashfs    ro,nodev,relatime,errors=continue
            |-/snap/gnome-3-28-1804/198              /dev/loop8                     squashfs    ro,nodev,relatime,errors=continue
            |-/snap/gnome-3-28-1804/194              /dev/loop11                    squashfs    ro,nodev,relatime,errors=continue
            |-/snap/gnome-3-38-2004/143              /dev/loop12                    squashfs    ro,nodev,relatime,errors=continue
            |-/snap/gnome-3-38-2004/140              /dev/loop9                     squashfs    ro,nodev,relatime,errors=continue
            |-/snap/gnome-42-2204/141                /dev/loop10                    squashfs    ro,nodev,relatime,errors=continue
            |-/snap/gnome-42-2204/132                /dev/loop13                    squashfs    ro,nodev,relatime,errors=continue
            |-/snap/gtk-common-themes/1534           /dev/loop14                    squashfs    ro,nodev,relatime,errors=continue
            |-/snap/gtk-common-themes/1535           /dev/loop15                    squashfs    ro,nodev,relatime,errors=continue
            |-/snap/snap-store/638                   /dev/loop16                    squashfs    ro,nodev,relatime,errors=continue
            |-/snap/snap-store/959                   /dev/loop17                    squashfs    ro,nodev,relatime,errors=continue
            |-/var/snap/firefox/common/host-hunspell /dev/sda2[/usr/share/hunspell] ext4        ro,noexec,noatime,errors=remount-ro
            |-/snap/snapd/20092                      /dev/loop18                    squashfs    ro,nodev,relatime,errors=continue
            |-/snap/snapd/20290                      /dev/loop19                    squashfs    ro,nodev,relatime,errors=continue
            |-/snap/spotify/70                       /dev/loop21                    squashfs    ro,nodev,relatime,errors=continue
            |-/snap/spotify/73                       /dev/loop20                    squashfs    ro,nodev,relatime,errors=continue
            |-/boot/efi                              /dev/sda1                      vfat        rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
            `-/snap/core18/2812                      /dev/loop22                    squashfs    ro,nodev,relatime,errors=continue
            /var:
            8.6G	/var/
            5.0G	/var/lib
            4.6G	/var/lib/snapd
            3.5G	/var/log
            3.4G	/var/log/journal/573de1de43694820a522c2dbc558889f
            Archived and active journals take up 3.3G in the file system.
            /opt/iobroker/backups:
            1.8G	/opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            2.2G	/opt/iobroker/iobroker-data/
            1.5G	/opt/iobroker/iobroker-data/files
            602M	/opt/iobroker/iobroker-data/files/vis-2-beta
            545M	/opt/iobroker/iobroker-data/files/vis-2-beta/static
            543M	/opt/iobroker/iobroker-data/files/vis-2-beta/static/js
            47M	/opt/iobroker/iobroker-data/states.jsonl
            35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
            33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
            24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
            USB-Devices by-id:
            *** NodeJS-Installation ***
            /usr/bin/npm 		10.2.3
            /usr/bin/npx 		10.2.3
            nodejs:
              Installed: 18.19.0-1nodesource1
              Candidate: 18.19.0-1nodesource1
              Version table:
             *** 18.19.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 18.18.2-1nodesource1 1001
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
                 12.22.9~dfsg-1ubuntu3.2 500
                    500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                    500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                 12.22.9~dfsg-1ubuntu3 500
                    500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller: 	5.0.16
            admin: 		6.12.0
            javascript: 	7.1.6
            Adapters from github: 	6
            Adapter State
            + system.adapter.alexa2.0                 : alexa2                : MaasServer                               -  enabled
              system.adapter.alias-manager.0          : alias-manager         : MaasServer                               -  enabled
            + system.adapter.awtrix-light.0           : awtrix-light          : MaasServer                               -  enabled
            + system.adapter.backitup.0               : backitup              : MaasServer                               -  enabled
              system.adapter.birthdays.0              : birthdays             : MaasServer                               -  enabled
            + system.adapter.bring.0                  : bring                 : MaasServer                               -  enabled
              system.adapter.daswetter.0              : daswetter             : MaasServer                               -  enabled
            + system.adapter.device-watcher.0         : device-watcher        : MaasServer                               -  enabled
              system.adapter.devices.0                : devices               : MaasServer                               -  enabled
            + system.adapter.discovery.0              : discovery             : MaasServer                               -  enabled
              system.adapter.dwd.0                    : dwd                   : MaasServer                               -  enabled
            + system.adapter.echarts.0                : echarts               : MaasServer                               -  enabled
            + system.adapter.energiefluss.0           : energiefluss          : MaasServer                               -  enabled
            + system.adapter.fb-checkpresence.0       : fb-checkpresence      : MaasServer                               -  enabled
            + system.adapter.fritzbox.0               : fritzbox              : MaasServer                               -  enabled
            + system.adapter.fullybrowser.0           : fullybrowser          : MaasServer                               -  enabled
            + system.adapter.harmony.0                : harmony               : MaasServer                               -  enabled
            + system.adapter.history.0                : history               : MaasServer                               -  enabled
              system.adapter.ical.0                   : ical                  : MaasServer                               -  enabled
              system.adapter.ical.1                   : ical                  : MaasServer                               -  enabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : MaasServer                               -  enabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : MaasServer                               -  enabled
            + system.adapter.info.0                   : info                  : MaasServer                               -  enabled
            + system.adapter.iot.0                    : iot                   : MaasServer                               -  enabled
            + system.adapter.javascript.0             : javascript            : MaasServer                               -  enabled
            + system.adapter.kostal-piko-ba.0         : kostal-piko-ba        : MaasServer                               -  enabled
              system.adapter.meteoalarm.0             : meteoalarm            : MaasServer                               -  enabled
            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : MaasServer                               -  enabled, port: 54321
            + system.adapter.mqtt.0                   : mqtt                  : MaasServer                               -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.netatmo-crawler.0        : netatmo-crawler       : MaasServer                               -  enabled
            + system.adapter.nibeuplink.0             : nibeuplink            : MaasServer                               -  enabled
            + system.adapter.openligadb.0             : openligadb            : MaasServer                               -  enabled
              system.adapter.openweathermap.0         : openweathermap        : MaasServer                               - disabled
            + system.adapter.ping.0                   : ping                  : MaasServer                               -  enabled
            + system.adapter.pvforecast.0             : pvforecast            : MaasServer                               -  enabled
            + system.adapter.rssfeed.0                : rssfeed               : MaasServer                               -  enabled
            + system.adapter.scheduler.0              : scheduler             : MaasServer                               -  enabled
            + system.adapter.shelly.0                 : shelly                : MaasServer                               -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shelly.1                 : shelly                : MaasServer                               -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shuttercontrol.0         : shuttercontrol        : MaasServer                               -  enabled
            + system.adapter.smartthings.0            : smartthings           : MaasServer                               -  enabled
            + system.adapter.sonos.0                  : sonos                 : MaasServer                               -  enabled
            + system.adapter.sourceanalytix.0         : sourceanalytix        : MaasServer                               -  enabled
            + system.adapter.spotify-premium.0        : spotify-premium       : MaasServer                               -  enabled
            + system.adapter.tankerkoenig.0           : tankerkoenig          : MaasServer                               -  enabled
            + system.adapter.tibberlink.0             : tibberlink            : MaasServer                               -  enabled
            + system.adapter.time-switch.0            : time-switch           : MaasServer                               -  enabled
            + system.adapter.tr-064.0                 : tr-064                : MaasServer                               -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : MaasServer                               -  enabled
            + system.adapter.tvprogram.0              : tvprogram             : MaasServer                               -  enabled
              system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : MaasServer                               -  enabled
              system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : MaasServer                               -  enabled
              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: MaasServer                               -  enabled
              system.adapter.vis-bars.0               : vis-bars              : MaasServer                               -  enabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : MaasServer                               -  enabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : MaasServer                               -  enabled
              system.adapter.vis-history.0            : vis-history           : MaasServer                               -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : MaasServer                               -  enabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : MaasServer                               -  enabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : MaasServer                               -  enabled
              system.adapter.vis-justgage.0           : vis-justgage          : MaasServer                               -  enabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : MaasServer                               -  enabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : MaasServer                               -  enabled
              system.adapter.vis-metro.0              : vis-metro             : MaasServer                               -  enabled
              system.adapter.vis-weather.0            : vis-weather           : MaasServer                               -  enabled
              system.adapter.vis.0                    : vis                   : MaasServer                               -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : MaasServer                               -  enabled
            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : MaasServer                               -  enabled
            + system.adapter.wifilight.0              : wifilight             : MaasServer                               -  enabled
            + system.adapter.wled.0                   : wled                  : MaasServer                               -  enabled
            + system.adapter.zigbee.0                 : zigbee                : MaasServer                               -  enabled, port: tcp://192.168.178.203:6638
            + instance is alive
            ioBroker-Repositories
            Stable (default): http://download.iobroker.net/sources-dist.json
            Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
            Installed ioBroker-Instances
            Used repository: Stable (default)
            Adapter    "admin"        : 6.12.0   , installed 6.12.0
            Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
            Adapter    "awtrix-light" : 0.10.0   , installed 0.10.0
            Adapter    "backitup"     : 2.8.7    , installed 2.8.7
            Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
            Adapter    "bring"        : 1.8.4    , installed 1.8.4
            Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
            Adapter    "device-watcher": 2.9.6   , installed 2.9.6
            Adapter    "echarts"      : 1.5.4    , installed 1.5.4
            Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
            Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
            Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
            Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
            Adapter    "harmony"      : 1.3.0    , installed 1.3.0
            Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
            Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
            Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
            Adapter    "iot"          : 2.0.11   , installed 2.0.11
            Adapter    "javascript"   : 7.1.6    , installed 7.1.6
            Controller "js-controller": 5.0.16   , installed 5.0.16
            Adapter    "kostal-piko-ba": 3.0.8   , installed 3.0.8
            Adapter    "meteoalarm"   : 2.3.7    , installed 2.3.7
            Adapter    "mihome"       : 1.4.0    , installed 1.4.0
            Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
            Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
            Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
            Adapter    "nibeuplink"   : 1.3.0    , installed 1.3.0
            Adapter    "openligadb"   : 1.2.4    , installed 1.3.4
            Adapter    "openweathermap": 0.4.5   , installed 0.4.5
            Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
            Adapter    "pushover"     : 3.0.3    , installed 3.0.3
            Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
            Adapter    "radar2"       : 2.1.0    , installed 2.1.0
            Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
            Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
            Adapter    "shelly"       : 6.6.1    , installed 6.6.1
            Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
            Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
            Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
            Adapter    "sonos"        : 3.0.0    , installed 3.0.0
            Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
            Adapter    "tibberlink"   : 1.6.1    , installed 1.6.1
            Adapter    "trashschedule": 2.3.0    , installed 2.3.0
            Adapter    "tuya"         : 3.14.2   , installed 3.14.2
            Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
            Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
            Adapter    "vis"          : 1.4.16   , installed 1.4.16
            Adapter    "vis-icontwo"  : 0.98.0   , installed 0.98.0
            Adapter    "vis-justgage" : 2.0.2    , installed 2.0.2
            Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
            Adapter    "weatherunderground": 3.6.0, installed 3.6.0
            Adapter    "web"          : 6.1.10   , installed 6.1.10
            Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
            Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
            Adapter    "wled"         : 0.7.1    , installed 0.7.1
            Adapter    "ws"           : 2.5.8    , installed 2.5.8
            Adapter    "yahka"        : 1.0.3    , installed 1.0.3
            Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
            Objects and States
            Objects: 	29110
            States: 	26122
            W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target Packages (main/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target Translations (main/i18n/Translation-de) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target DEP-11 (main/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target DEP-11 (main/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target DEP-11-icons-small (main/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target DEP-11-icons (main/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target DEP-11-icons-hidpi (main/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target CNF (main/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target CNF (main/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target Packages (restricted/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target Packages (restricted/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target Packages (restricted/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target Translations (restricted/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target Translations (restricted/i18n/Translation-de) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target DEP-11 (restricted/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target DEP-11 (restricted/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target DEP-11-icons-small (restricted/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target DEP-11-icons (restricted/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target DEP-11-icons-hidpi (restricted/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target CNF (restricted/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            W: Target CNF (restricted/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list:36 and /etc/apt/sources.list:50
            Hit:1 http://security.ubuntu.com/ubuntu jammy-security InRelease
            Hit:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
            Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
            Hit:4 http://archive.ubuntu.com/ubuntu jammy InRelease
            Hit:5 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
            Reading package lists...
            Pending Updates: 2
            *** Listening Ports ***
            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        21373      453/systemd-resolve
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          127106     17657/cupsd
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       91101      15008/iobroker.js-c
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       90001      15008/iobroker.js-c
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       558202     38321/io.mqtt.0
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       93176      15302/io.shelly.1
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17016      1/init
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       90100      15026/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       93624      15363/io.web.0
            tcp6       0      0 :::3389                 :::*                    LISTEN      126        24129      800/xrdp
            tcp6       0      0 :::3500                 :::*                    LISTEN      1001       386267     29099/io.sonos.0
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          127105     17657/cupsd
            tcp6       0      0 ::1:3350                :::*                    LISTEN      0          22741      765/xrdp-sesman
            tcp6       0      0 :::61991                :::*                    LISTEN      1001       94522      15499/io.harmony.0
            tcp6       0      0 :::111                  :::*                    LISTEN      0          17018      1/init
            udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       641662     41290/chrome
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       557609     38365/io.wled.0
            udp        0      0 192.168.178.10:5353     0.0.0.0:*                           1001       92662      15126/io.tr-064.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        22573      665/avahi-daemon: r
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       94214      15281/io.shelly.0
            udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        21372      453/systemd-resolve
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17017      1/init
            udp        0      0 0.0.0.0:57483           0.0.0.0:*                           115        22575      665/avahi-daemon: r
            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       387656     29288/io.mihome-vac
            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       94523      15499/io.harmony.0
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          126795     17661/cups-browsed
            udp6       0      0 :::5353                 :::*                                115        22574      665/avahi-daemon: r
            udp6       0      0 :::34664                :::*                                115        22576      665/avahi-daemon: r
            udp6       0      0 :::111                  :::*                                0          17019      1/init
            udp6       0      0 fe80::60ba:5c16:9b7:546 :::*                                0          24703      669/NetworkManager
            2023-12-05 18:17:57.236  - debug: openligadb.0 (29256) request url https://api.openligadb.de/getgoalgetters/bl1/2023
            2023-12-05 18:17:57.341  - debug: openligadb.0 (29256) createObject currgameday
            2023-12-05 18:17:57.347  - debug: openligadb.0 (29256) createObject table
            2023-12-05 18:17:57.361  - debug: openligadb.0 (29256) setState currgameday
            2023-12-05 18:17:57.362  - debug: openligadb.0 (29256) setState name: bl1.2023.currgameday
            2023-12-05 18:17:57.365  - debug: openligadb.0 (29256) setState table
            2023-12-05 18:17:57.365  - debug: openligadb.0 (29256) setState name: bl1.2023.table
            2023-12-05 18:17:57.380  - debug: openligadb.0 (29256) createObject goalgetters
            2023-12-05 18:17:57.422  - debug: openligadb.0 (29256) setState goalgetters
            2023-12-05 18:17:57.422  - debug: openligadb.0 (29256) setState name: bl1.2023.goalgetters
            2023-12-05 18:17:57.505  - debug: openligadb.0 (29256) createObject allmatches
            2023-12-05 18:17:57.614  - debug: openligadb.0 (29256) setState allmatches
            2023-12-05 18:17:57.614  - debug: openligadb.0 (29256) setState name: bl1.2023.allmatches
            2023-12-05 18:20:00.007  - warn: host.MaasServer instance system.adapter.netatmo-crawler.0 already running with pid 37401
            2023-12-05 18:20:00.056  - info: host.MaasServer instance system.adapter.dwd.0 started with pid 43285
            2023-12-05 18:20:03.511  - info: dwd.0 (43285) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.16
            2023-12-05 18:20:04.078  - info: host.MaasServer instance system.adapter.meteoalarm.0 started with pid 43300
            2023-12-05 18:20:07.203  - info: dwd.0 (43285) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2023-12-05 18:20:07.725  - info: meteoalarm.0 (43300) starting. Version 2.3.7 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v18.19.0, js-controller: 5.0.16
            2023-12-05 18:20:07.848  - info: host.MaasServer instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-12-05 18:20:15.480  - info: meteoalarm.0 (43300) 15.1: Updated Weather Alarms for Kreis Verden -> 2 alarm(s) found
            2023-12-05 18:20:15.481  - info: meteoalarm.0 (43300) Terminated (ADAPTER_REQUESTED_TERMINATION): All data processed. Adapter stopped until next scheduled process.
            2023-12-05 18:20:16.048  - info: host.MaasServer instance system.adapter.meteoalarm.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-12-05 18:22:10.422  - warn: sonos.0 (29099) State "sonos.0.root.192_168_178_51.current_track_number" has no existing object, this might lead to an error in future versions
            2023-12-05 18:22:10.488  - warn: sonos.0 (29099) State "sonos.0.root.192_168_178_51.queue_html" has no existing object, this might lead to an error in future versions
            DJMarc75 Codierknecht 2 Replies Last reply Reply Quote 0
            • OliverIO
              OliverIO @Maas-Meister last edited by
              @maas-meister sagte in Internetausfälle durch iobroker?:
              ich habe sehr viele Internetausfälle / Neuverbindungen
              wie äußert sich das.
              fällt dann wirklich das internet aus?
              oder das LAN
              oder das WLAN?
              hast du doppelte IP-Adressen oder MAC Adressen im Netz?
              Was hast du getan zum zeitpunkt als es nicht mehr funktionierte?
              • DJMarc75
                @maas-meister
                Was mir auffällt ist dass Deine beiden Shelly Instanzen auf dem selben Port laufen - das geht nicht.
                Zum Rest kann ich nix sagen 😉
                • Codierknecht
                  Codierknecht Developer Most Active @Maas-Meister last edited by
                  Ich lese zwar
                  X-Server: 	false
                  aber bei den mounts auch was von "gnome", "gtk" usw.
                  Ist da jetzt ein Desktop drauf oder nicht?
                  M Thomas Braun 2 Replies Last reply Reply Quote 0
                    Maas-Meister @OliverIO last edited by
                    @oliverio
                    • Ich habe dann keine Verbindung mehr von der FritzBox nach "draußen".
                      Nach 2-5min. ist die Verbindung dann wieder da.
                      Die Ausfälle sind alle 10-30min.
                    • LAN und WLAN läuft weiterhin.
                    Das ich massive Ausfälle habe, ist mir erst einige Tage später aufgefallen.
                    Ich kann leider keinen Zeitpunkt mehr definieren, sodass ich gucken kann, was ich am System gemacht habe.
                    Ich habe einige feste IPs im Netzwerk, dann ich die doppelten irgendwie ermitteln?
                    In der Übersicht ist nichts auffällig.
                      Maas-Meister @Codierknecht last edited by
                      @codierknecht
                      Ich habe meinen Desktop/Bildschirm direkt am Server angeschlossen, sofern das die Frage war 😊
                      MartinP Codierknecht 2 Replies Last reply Reply Quote 0
                      • MartinP
                        MartinP @Maas-Meister last edited by
                        @maas-meister Das Logging der Fritzbox wäre sicherlich auch interessant...
                        Unter "System/Ereignisse/Internetverbindung" irgendwelche Loggings?
                        • Codierknecht
                          @codierknecht
                          Das heißt, auf der Maschine läuft ein "klickibunti" Linux mit Desktop?
                          Also KDE, Gnome, Cinnamon oder etwas vergleichbares?
                          Oder hängen da lediglich Monitor und Tatstatur dran und Du arbeitest da in der Konsole?
                            Maas-Meister @MartinP last edited by
                            @martinp sagte in Internetausfälle durch iobroker?:
                            05.12.23
                            18:45:50
                            IPv6-Präfix wurde erfolgreich aktualisiert. Neues Präfix: 2003:f4:3701:5b00::/56
                            05.12.23
                            18:30:50
                            Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.142.201, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                            05.12.23
                            18:30:50
                            Internetverbindung IPv6: AFTR konnte nicht bezogen werden: Grund 7 (got no aftr)
                            05.12.23
                            18:30:50
                            IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3701:5b00::/56
                            05.12.23
                            18:30:50
                            Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:15f:3e37:12ff:feea:226d
                            05.12.23
                            18:30:50
                            Information des Anbieters über die Geschwindigkeit des Internetzugangs (verfügbare Bitrate): 26412/30706 kbit/s
                            05.12.23
                            18:30:41
                            DSL ist verfügbar (DSL-Synchronisierung besteht mit 37291/31951 kbit/s).
                            05.12.23
                            18:29:44
                            PPPoE-Fehler: Zeitüberschreitung.
                            05.12.23
                            18:29:17
                            DSL-Synchronisierung beginnt (Training).
                            05.12.23
                            18:29:11
                            DSL antwortet nicht (Keine DSL-Synchronisierung).
                            05.12.23
                            18:28:58
                            DSL ist verfügbar (DSL-Synchronisierung besteht mit 39354/34107 kbit/s).
                            05.12.23
                            18:27:32
                            05.12.23
                            18:27:06
                            Zeitüberschreitung bei der PPP-Aushandlung.
                            05.12.23
                            18:27:06
                            Internetverbindung IPv6 wurde getrennt, Präfix nicht mehr gültig.
                            05.12.23
                            18:27:06
                            Internetverbindung wurde getrennt.
                            05.12.23
                            18:27:01
                            05.12.23
                            18:00:28
                            IPv6-Präfix wurde erfolgreich aktualisiert. Neues Präfix: 2003:f4:3701:4c00::/56
                            05.12.23
                            17:45:28
                            Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.142.168, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                            05.12.23
                            17:45:28
                            05.12.23
                            17:45:28
                            IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3701:4c00::/56
                            05.12.23
                            17:45:28
                            Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:150:3e37:12ff:feea:226d
                            05.12.23
                            17:45:18
                            DSL ist verfügbar (DSL-Synchronisierung besteht mit 26422/30717 kbit/s).
                            05.12.23
                            17:43:54
                            05.12.23
                            17:43:48
                            05.12.23
                            17:43:48
                            05.12.23
                            17:43:48
                            05.12.23
                            17:43:43
                            05.12.23
                            16:34:00
                            IPv6-Präfix wurde erfolgreich aktualisiert. Neues Präfix: 2003:f4:3701:1000::/56
                            05.12.23
                            16:19:01
                            Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.142.75, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                            05.12.23
                            16:19:00
                            05.12.23
                            16:19:00
                            IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3701:1000::/56
                            05.12.23
                            16:19:00
                            Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:117:3e37:12ff:feea:226d
                            05.12.23
                            16:18:51
                            DSL ist verfügbar (DSL-Synchronisierung besteht mit 37461/34309 kbit/s).
                            05.12.23
                            16:17:26
                            05.12.23
                            16:17:21
                            05.12.23
                            16:17:20
                            05.12.23
                            16:17:20
                            05.12.23
                            16:17:16
                            05.12.23
                            16:16:59
                            Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.142.74, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                            05.12.23
                            16:16:59
                            05.12.23
                            16:16:59
                            IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3701:e00::/56
                            05.12.23
                            16:16:59
                            Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:116:3e37:12ff:feea:226d
                            05.12.23
                            16:16:59
                            Information des Anbieters über die Geschwindigkeit des Internetzugangs (verfügbare Bitrate): 35648/33535 kbit/s
                            05.12.23
                            16:16:49
                            DSL ist verfügbar (DSL-Synchronisierung besteht mit 63082/35756 kbit/s).
                            05.12.23
                            16:15:25
                            05.12.23
                            16:15:23
                            05.12.23
                            16:15:23
                            05.12.23
                            16:15:23
                            05.12.23
                            16:15:18
                            05.12.23
                            16:13:31
                            Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.142.67, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                            05.12.23
                            16:13:30
                            05.12.23
                            16:13:30
                            IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3701:a00::/56
                            05.12.23
                            16:13:30
                            Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:10e:3e37:12ff:feea:226d
                            05.12.23
                            16:13:21
                            DSL ist verfügbar (DSL-Synchronisierung besteht mit 35660/33547 kbit/s).
                            05.12.23
                            16:11:55
                            05.12.23
                            16:11:48
                            05.12.23
                            16:11:48
                            05.12.23
                            16:11:48
                            05.12.23
                            16:11:43
                            05.12.23
                            16:06:55
                            Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.142.50, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                            05.12.23
                            16:06:55
                            05.12.23
                            16:06:55
                            IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3701:300::/56
                            05.12.23
                            16:06:54
                            Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:108:3e37:12ff:feea:226d
                            05.12.23
                            16:06:54
                            Information des Anbieters über die Geschwindigkeit des Internetzugangs (verfügbare Bitrate): 41944/34388 kbit/s
                            05.12.23
                            16:06:45
                            DSL ist verfügbar (DSL-Synchronisierung besteht mit 84602/42463 kbit/s).
                            05.12.23
                            16:05:20
                            05.12.23
                            16:05:14
                            05.12.23
                            16:05:13
                            05.12.23
                            16:05:13
                            05.12.23
                            16:05:09
                            05.12.23
                            15:55:30
                            IPv6-Präfix wurde erfolgreich aktualisiert. Neues Präfix: 2003:f4:3700:f500::/56
                            05.12.23
                            15:40:30
                            Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.142.30, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                            05.12.23
                            15:40:30
                            05.12.23
                            15:40:30
                            IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3700:f500::/56
                            05.12.23
                            15:40:30
                            Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:f9:3e37:12ff:feea:226d
                            05.12.23
                            15:40:20
                            DSL ist verfügbar (DSL-Synchronisierung besteht mit 41958/34400 kbit/s).
                            05.12.23
                            15:39:19
                            05.12.23
                            15:38:56
                            05.12.23
                            15:38:50
                            05.12.23
                            15:38:34
                            DSL ist verfügbar (DSL-Synchronisierung besteht mit 67253/37344 kbit/s).
                            05.12.23
                            15:37:10
                            DSL-Synchronisierung beginnt (Training). [2 Meldungen seit 05.12.23 15:37:02]
                            05.12.23
                            15:36:54
                            05.12.23
                            15:36:53
                            05.12.23
                            15:36:53
                            05.12.23
                            15:36:49
                            05.12.23
                            15:33:22
                            IPv6-Präfix wurde erfolgreich aktualisiert. Neues Präfix: 2003:f4:3700:e900::/56
                            05.12.23
                            15:18:22
                            Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.142.17, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                            05.12.23
                            15:18:22
                            05.12.23
                            15:18:22
                            IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3700:e900::/56
                            05.12.23
                            15:18:21
                            Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:f0:3e37:12ff:feea:226d
                            05.12.23
                            15:18:21
                            Information des Anbieters über die Geschwindigkeit des Internetzugangs (verfügbare Bitrate): 42009/34826 kbit/s
                            05.12.23
                            15:18:12
                            DSL ist verfügbar (DSL-Synchronisierung besteht mit 46026/37440 kbit/s).
                            05.12.23
                            15:16:48
                            05.12.23
                            15:16:47
                            05.12.23
                            15:16:47
                            05.12.23
                            15:16:46
                            05.12.23
                            15:16:42
                            05.12.23
                            15:08:54
                            IPv6-Präfix wurde erfolgreich aktualisiert. Neues Präfix: 2003:f4:3700:d400::/56
                            05.12.23
                            14:53:54
                            Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.143.241, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                            05.12.23
                            14:53:54
                            05.12.23
                            14:53:54
                            IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3700:d400::/56
                            05.12.23
                            14:53:53
                            Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:d9:3e37:12ff:feea:226d
                            05.12.23
                            14:53:53
                            Information des Anbieters über die Geschwindigkeit des Internetzugangs (verfügbare Bitrate): 32633/29811 kbit/s
                            05.12.23
                            14:53:44
                            DSL ist verfügbar (DSL-Synchronisierung besteht mit 42024/34838 kbit/s).
                            05.12.23
                            14:52:20
                            05.12.23
                            14:52:19
                            05.12.23
                            14:52:18
                            05.12.23
                            14:52:18
                            05.12.23
                            14:52:14
                            05.12.23
                            14:28:10
                            IPv6-Präfix wurde erfolgreich aktualisiert. Neues Präfix: 2003:f4:3700:c000::/56
                            05.12.23
                            14:13:10
                            Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.143.209, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                            05.12.23
                            14:13:10
                            05.12.23
                            14:13:10
                            IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3700:c000::/56
                            05.12.23
                            14:13:10
                            Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:c4:3e37:12ff:feea:226d
                            05.12.23
                            14:13:01
                            DSL ist verfügbar (DSL-Synchronisierung besteht mit 32643/29822 kbit/s).
                            05.12.23
                            14:11:37
                            05.12.23
                            14:11:33
                            05.12.23
                            14:11:32
                            05.12.23
                            14:11:32
                            05.12.23
                            14:11:27
                            05.12.23
                            14:00:55
                            IPv6-Präfix wurde erfolgreich aktualisiert. Neues Präfix: 2003:f4:3700:ae00::/56
                            05.12.23
                            13:45:55
                            Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.143.192, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                            05.12.23
                            13:45:55
                            05.12.23
                            13:45:55
                            IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3700:ae00::/56
                            05.12.23
                            13:45:55
                            Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:b4:3e37:12ff:feea:226d
                            05.12.23
                            13:45:45
                            DSL ist verfügbar (DSL-Synchronisierung besteht mit 40616/35299 kbit/s).
                            05.12.23
                            13:44:21
                            05.12.23
                            13:44:20
                            05.12.23
                            13:44:20
                            05.12.23
                            13:44:20
                            05.12.23
                            13:44:15
                            05.12.23
                            12:59:08
                            IPv6-Präfix wurde erfolgreich aktualisiert. Neues Präfix: 2003:f4:3700:9500::/56
                            05.12.23
                            12:44:08
                            Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.143.158, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                            05.12.23
                            12:44:08
                            05.12.23
                            12:44:08
                            IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3700:9500::/56
                            05.12.23
                            12:44:08
                            Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:9a:3e37:12ff:feea:226d
                            05.12.23
                            12:43:58
                            DSL ist verfügbar (DSL-Synchronisierung besteht mit 42070/36076 kbit/s).
                            05.12.23
                            12:42:34
                            05.12.23
                            12:42:28
                            05.12.23
                            12:42:28
                            05.12.23
                            12:42:28
                            05.12.23
                            12:42:23
                            05.12.23
                            12:37:43
                            Internetverbindung wurde erfolgreich hergestellt. IP-Adresse: 93.201.143.157, DNS-Server: 217.237.150.205 und 217.237.149.142, Gateway: 62.155.242.247, Breitband-PoP: VERJ01, LineID:1UND1.DEU.DTAG.MYT47
                            05.12.23
                            12:37:43
                            05.12.23
                            12:37:43
                            IPv6-Präfix wurde erfolgreich bezogen. Neues Präfix: 2003:f4:3700:9400::/56
                            05.12.23
                            12:37:42
                            Internetverbindung IPv6 wurde erfolgreich hergestellt. IP-Adresse: 2003:f4:37ff:98:3e37:12ff:feea:226d
                            05.12.23
                            12:37:42
                            Information des Anbieters über die Geschwindigkeit des Internetzugangs (verfügbare Bitrate): 40794/35786 kbit/s
                            05.12.23
                            12:37:33
                            DSL ist verfügbar (DSL-Synchronisierung besteht mit 55668/37866 kbit/s).
                              Maas-Meister @Codierknecht last edited by Maas-Meister
                              @codierknecht sagte in Internetausfälle durch iobroker?:
                              @codierknecht
                              Ich glaube wir reden aneinander vorbei.
                              KDE, Gnome etc. kenne ich nicht.
                              Auf dem MiniPC läuft Ubuntu (in der Desktop Version) und darauf iobroker.
                              An dem MiniPc hängt mein Bildschirm mit Tastatur, aber das wolltest du bestimmt nicht wissen.
                              • DJMarc75
                                @maas-meister hast Du da irgendwas mit Powerline am Start ?
                                  Thomas Braun Most Active @Codierknecht last edited by
                                  Das ist ein Fehler in diag
                                  Ist in der Beta gefixt, die ist aber noch nicht hochgeladen. Zu @apollon77 schiel...
                                  • Codierknecht
                                    @maas-meister
                                    Ich frage anders: Hast Du in Deinem Linux eine grafische Benutzeroberfläche, oder arbeitest Du nur per Kommandozeile?
                                    @Thomas-Braun
                                    Also ist da trotz anderslautender Info einer drauf?
                                      Maas-Meister @DJMarc75 last edited by
                                      @djmarc75
                                      Keine Ahnung.
                                      Wenn, dann nur Ausversehen.
                                      Ich nutze eigentlich nur die Standard-Anwendungen und bin nicht so tief im Thema drin.
                                      Ich müsste erstmal nach "Powerline" googlen, das sagt schon alles.
                                        @codierknecht
                                        Grafische Oberfläche.
                                        Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
                                          Ja, die Abfrage wird durch X11 getriggert, ein Wayland wird nicht gesehen in der Version.
                                          • DJMarc75
                                            kann ja nicht schaden 😉
                                            53
                                            4931
