    4. Adapter Klipper-Moonraker
    • N
      Netcrusher @Sushibomba last edited by
      Moin zusammen, ich habe mir ein Script geschrieben, welches periodisch die moonraker api nach den wichtigsten Infos abfragt und in iobroker Javascript States schreibt. Das wäre mit Hilfe der moonraker API-Dokumentation auch recht einfach erweiterbar.
      Falls es jemand gebrauchen kann (ohne Gewähr):
      const printerName = 'VORON'; // Replace with your actual printer name
      const printerBaseUrl = 'http://192.168.2.32'; // Replace with your actual moonraker ip
      const updateInterval = 20000; // 20 seconds
      // Function to make an HTTP request and return a promise
      function getPrinterStatus(url) {
          return new Promise((resolve, reject) => {
              const request = require('request');
              request(url, { json: true }, (err, res, body) => {
                  if (err) {
                      reject(err);
                  } else {
                      resolve(body);
      // Function to get metadata for the given filename
      function getFileMetadata(filename) {
          const metadataUrl = printerBaseUrl + `/server/files/metadata?filename=${encodeURIComponent(filename)}`;
          return getPrinterStatus(metadataUrl); // Reusing the HTTP request function
      // Function to convert seconds to HH:MM:SS
      function toHHMMSS(seconds) {
          const hours = Math.floor(seconds / 3600);
          const minutes = Math.floor((seconds % 3600) / 60);
          const sec = Math.floor(seconds % 60);
          return [hours, minutes, sec]
              .map(v => v < 10 ? "0" + v : v)
              .join(":");
      // Function to update the online status of the printer
      function updatePrinterOnlineStatus(isOnline) {
          const onlineStateName = `${printerName}.onlineStatus`;
          createOrUpdateState(onlineStateName, isOnline);
      // Function to create or update ioBroker states
      function createOrUpdateState(fullStateName, value, key='') {
          // Check if the key contains 'duration' and format it if it does
          if (key.includes('duration')) {
              value = toHHMMSS(value);
          // Check if the key contains 'progress' and multiply by 100 and round it if it does
          if (key.includes('progress')) {
              value = Math.round(value * 100); // Converts to percentage and rounds to the nearest integer
          if (!existsState(fullStateName)) {
              createState(fullStateName, {
                  type: typeof value,
                  read: true,
                  write: false,
                  desc: 'Printer status value'
                  setState(fullStateName, value, true);
          } else {
      // Function to process the printer status and update the ioBroker states
      function processPrinterStatus(printerData, parentKey = '') {
          Object.keys(printerData).forEach(key => {
              const value = printerData[key];
              let fullStateName = `${printerName}`;
              if (parentKey) {
                  fullStateName += `.${parentKey}`;
              fullStateName += `.${key}`;
              if (value !== null && typeof value === 'object' && !(value instanceof Array)) {
                  // It's a nested object, so we need to recurse
                  processPrinterStatus(value, key);
              } else {
                  // It's a value, so we create or update the state
                  createOrUpdateState(fullStateName, value, key);
      // Function to nullify file metadata states in ioBroker
      function nullifyFileMetadataStates() {
          var states = $(`*.${printerName}.file_metadata.*`/*Printer file metadata*/);
          states.each(function(id, i){
              setState(id, {val: null, ack: true});
      // Polling function
      function startPolling() {
          setInterval(() => {
              getPrinterStatus(printerBaseUrl + '/printer/objects/query?display_status&print_stats&extruder&heater_bed&system_stats')
                  .then(response => {
                      if (response && response.result) {
                          const printStats = response.result.status.print_stats || {};
                          const filename = printStats.filename;
                          // Update printer status
                          processPrinterStatus(response.result);
                          // If there is a filename, get and process the file metadata
                          if (filename) {
                              getFileMetadata(filename).then(metadataResponse => {
                                  if (metadataResponse && metadataResponse.result) {
                                      processPrinterStatus(metadataResponse.result, 'file_metadata');
                              }).catch(error => {
                                  console.error('Error fetching file metadata:', error);
                          } else {
                              // If filename is empty, nullify all file_metadata states
                              nullifyFileMetadataStates();
                          updatePrinterOnlineStatus(true); // Printer is online
                  .catch(error => {
                      console.log('Error fetching printer status... setting Printer offline');
                      updatePrinterOnlineStatus(false); // Printer is offline
          }, updateInterval);
      // Start the polling process
      startPolling();
      Merlin123 C 2 Replies Last reply Reply Quote 0
      • Merlin123
        Merlin123 @Netcrusher last edited by Merlin123
        @netcrusher
        Erstmal Danke für das Script! Das ist ja klasse! 🙂
        Beim ersten Versuch kam nix. Hab dann aber gemerkt, dass beim Creatlity K1 Moonraker auf Port 7125 läuft. Zum Glück schluckt Dein Script auch nen Port hinter der IP 😄
        Mal schauen, was ich damit alles machen kann. Auch jeden Fall ne tolle Arbeit!
        Wie man Man die voraussichtliche Zeit oder den Fortschritt rausbekommt, weißt Du nicht zufällig? Das fehlt mir hier leider auch noch.
        Vielleicht kannst Du ja mit @Dutchman zusammenarbeiten, damit das wieder ein lauffähiger Adapter wird.
        • Dutchman
          Dutchman Developer Most Active Administrators @Merlin123 last edited by
          @merlin123 sagte in Adapter Klipper-Moonraker:
          @netcrusher
          Würde da gerne den Adapter weitermachen, das Problem ist das ich keine Klipper Installation haben
          Der Adapter arbeitet bereits über websocket was effizienter ist aber ich kan nur schwierig blind programmieren
          Also wen jemand Zeit/bock hat da zusammen drüber zu schauen oder mir einen Zugang geben kann kümmere ich mich sehr gerne darum!
            Hansi1234 @Dutchman last edited by
            @dutchman gebe ich dir. Muss nur schauen, wie es zeitlich passt. Wireguard ist vorhanden
            • Dutchman
              Dutchman Developer Most Active Administrators @Hansi1234 last edited by
              @hansi1234 sagte in Adapter Klipper-Moonraker:
              cool mit wireguard sollte es klappen, kein stress ich bin gerade noch dabei ESPHome zu Finalisten, WLED ein update zu geben, e-message implementieren, solar manager die basis auf zu bauen und sourceanalytiX ein major update zu geben
              aber glaube die KlipperMoonraker Sachen sind ziemlich easy und meister teil bereits vorhanden. die Entwicklung hat damals aufgehört da ich keine daten mehr hatte um mit zu arbeiten
              • Dutchman
                Dutchman Developer Most Active Administrators @gerald123 last edited by Dutchman
                @gerald123 sagte in Adapter Klipper-Moonraker:
                Kann mir hier wer von euch weiterhelfen wie ich diese Meldung beseitigen kann?
                ich benötige dazu Informationen, fuer jeden Datenpunkt ist hier beschrieben was fuer einen typen er hat.
                Diese Fehler bedeuten entweder das der wert noch nicht in der liste steht oder den falschen typen hat
                https://github.com/DrozmotiX/ioBroker.klipper-moonraker/blob/main/lib/stateAttr.js
                z.b.
                	'endstop_pin': {
                		type: 'number',
                		read: true,
                		write: false,
                		role: 'state',
                hier steht es als number, wen es aber ein string sein soll muss hier der typ korrigiert werden
                ALgemein: sorry Leute ich war die letzte zeit, sagen wir 1,5 Jahre, nicht so aktiv im forum und habe einiges verpasst worunter auch dieses Thema dank @Hansi1234 der mich retagged hatte und die Meldung ganz oben stand bin ich erst ich erst wach geworden ...
                schande ueber mein Haupt !
                H S 2 Replies Last reply Reply Quote 1
                  @dutchman rechtfertigen musst du dich nicht 😊 ich schreib dir eine PM wegen Zugang
                  • Dutchman
                    Vielen Dank!!!
                    Segway 1 Reply Last reply Reply Quote 1
                    • Segway
                      Segway last edited by Segway
                      @dutchman
                      Hatte gerade ein Issue aufgemacht auf Guthub um nachzufragen ob der Adapter ein Upgrade erhält.
                      Leider erst jetzt gelesen dass du schon dran bist 🙂
                      Wo kann ich helfen ? Soll ich was testen ?
                        Sushibomba @Dutchman last edited by
                        @dutchman
                        Das mit deiner Liste verstehe ich noch nicht so ganz würde aber auch gerne helfen.
                        Was kann ich tun um die Entwicklung voran zu treiben? 🙂
                        • da_Woody
                          da_Woody last edited by
                          Wenn sich hier wer finden würde der mir bei der config von meinem sapphire pro helfen könnte, würde ich auch mitmachen...
                          Alle Treiber auf 2209 umgebaut, teilweise funktioniert er, aber halt nicht alles. Steht seit mehr als nem halben Jahr.
                          Zum Glück tut's der Ender 3v2 original top.
                          • Segway
                            Segway @Dutchman last edited by Segway
                            @dutchman
                            Gibts bei dem Adapter schon einen Fortschritt ?
                            @da_woody sagte in Adapter Klipper-Moonraker:
                            Welche Hilfe brauchste bei dem Sapphire pro ?
                            • da_Woody
                              da_Woody @Segway last edited by
                              @segway hat sich mehr oder weniger erledigt. hab mir zum geburtstag und weihnachten einen creality K1 gegönnt. der ist grad im anflug.
                              nunja, meine config werkelt nicht so, wie sie sollte. x y tut zwar, bei den stops bin ich mir nicht ganz sicher. z fährt allerdings maximal 1/3mehr mag das teil nicht.
                              die treiber hab ich auf 2209uart umgebaut.
                              schon monatelang nicht mehr aufgedreht.
                              🙄 jetzt initialisiert sich das ding nichtmal mehr. war kurz da, hab was aktualisiert, nix mehr...
                              müsste ich wohl neu insten... per SSH bin ich aber noch auf den raspi gekommen, die printer.conf runterkopiert.
                              printer.cfg
                              wenn du laune hast, kannst ja mal reinschauen...
                              • Segway
                                Segway @da_Woody last edited by
                                printer.cfg
                                Wenn ich mir das so anschauen stimmt die config nicht.....welchen Spahire hast du genau ?
                                pro SP3 2020
                                plus SP5 v1
                                plus SP5 v1.1
                                • da_Woody
                                  @segway sapphire pro im November 2019 gekauft.
                                  Umgebaut ( 2209uart und bltoutch) und mit Klipper hab ich damals versucht nach den Videos von Stonetime.
                                  Auf YouTube nach "stonetime klipper sapphire" suchen...
                                  • Segway
                                    @da_woody
                                    Lass uns das per Discord machen wenn Zeit hast ok ?
                                    • da_Woody
                                      @segway können wir machen tun am sein.
                                      musste grad neu insten, update hat nach der langen zeit nich geklappt. schon ewig nicht mehr auf discord gewesen...
                                      k, den ioB server hab ich drinnen, auch iobrokerklipper-moonraker chan gefunden. find dich allerdings nicht. gerade gesichtet...
                                      na egal, heut wird das eh nichts mehr. hunger, müde und keinen kopf dazu.
                                      auch keine ahnung wie und wann du zeit und lust hast. gibt ja auch den chat um sich abzustimmen. 🙂
                                      btw: heut ist der creality K1 aufgeschlagen. nach öffnen der schachtel ist mich aber erstmal ein polnischer eisbär angesprungen. werd den noch ~2 tage aklimatisieren lassen. ob der wohl auch mit dem adapter funktioniert?
                                      Segway foxriver76 2 Replies Last reply Reply Quote 0
                                      • Segway
                                        @da_woody
                                        der K1 ? Sollte auch gehen denke ich.
                                        Aber eins nach dem anderen ... Hab dich angeschrieben - dann sehen wir weiter
                                          Erstmal ein frohes neues Jahr an alle 🙂
                                          Wann geht's hier weiter @Dutchman ? Gibt's schon nen Plan?
                                          Du brauchst ja immer mal wieder ne Erinnerung wie du selber sagst 😉
                                          • foxriver76
                                            foxriver76 Developer @da_Woody last edited by
                                            @da_woody da ich aktuell vor der Kaufentscheidung stehe, hast du den K1 angebunden bekommen?
                                            1.0k
                                            adapter update klipper moonraker
                                            24
                                            124
                                            19874
