    4. Homebridge-Adapter: Funktionierende Plugins und Beispiele
      loverz last edited by loverz
      Hab "Local-Homebridge-Mode" wie hier beschrieben installliert:
      https://github.com/ioBroker/ioBroker.ham
      Die Bridge wird in der Homeapp auch angezeigt, aber wie ist der Homekit Setup Code?
      Sehe den nirgends 😞
      Wenn ich „00000000“ eingebe:
      Und bei „12345678“
      Habs rausgefunden:
       "bridge": {
          "name": "Homebridge",
          "username": "CC:22:3D:E3:CE:99",
          "port": 51826,
          "pin": "090-99-090"
      zu Beginn in der Config eintragen.
      Steht leider in keiner Doku!
      • U
        uwe72 @loverz last edited by
        Kann mir jemand helfen wie ich hier den unify-protect Adapter integrieren kann?
          Thomas Braun Most Active @uwe72 last edited by
          @uwe72
          Warum experimentierst du nicht damit herum?
          https://github.com/peterbaumert/ioBroker.unifi-protect
            MartiMan @Thomas Braun last edited by
            Hi all,
            Sorry but I'm not able to write in German, reading it without problems though.
            I use ioBroker for years and just found this adapter but I'm having issues with the homebridge-eosstb plugin.
            My logs show no errors in silly mode and the settopbox communication works but no are being objects created and the plugin is not available in my home app on the iPhone.
            Any ideas?
            Thanks!
              apollon77 @MartiMan last edited by
              @martiman I think for this you need to tell a bit more in detail what you setup and how. Which mode you use the adapter in and such
                MartiMan @apollon77 last edited by MartiMan
                @apollon77 Thanks for your answer.
                These are the settings I'm using:
                  @martiman Ok, so Wrapper Mode ... so you have added the homebridge started by the adapter to our Apple Home and then the states are not provided? The a more complete log (as text from disk logfile) would be helpful
                    @apollon77
                    From what I understand from the manual, the plugin will create the link to the Home app.
                    "homebridge-eosstb is a Homebridge plugin allowing you to control your set-top box (typically an ARRIS DCX960 / VIP5002W or HUMAX EOS1008R / 2008C) running on the Magenta AT / Telenet BE / Sunrise CH / Virgin Media GB & IE / Ziggo NL Horizon TV platform with Apple HomeKit using the Home app and the Apple TV Remote in the Control Center."
                    This is the full log after a restart of the plugin.
                    iobroker.2023-12-06.log.html
                      @apollon77 I assume the objects of the Homebridge plugin should be added as a ham subfolder?
                        @martiman Butall this do nt happen automatically ... you need to go into the Apple home and click the "+" and then scan ender the pin you defined in the config to add the bridge to youe apple home. Did you do that?
                          @apollon77 Late reply, new system running on bookworm now which took me some time...
                          Well I'm using yahka for all my lights and gates combined with the S7 adapter so I'm familiar with that.
                          From my understanding Homebridge supplies the Homekit bridge that makes that Homebridge plugins will be recognised by the Home app.
                          According to the ham README.md the wrapper mode does not support this (I had a RTFM moment lol):
                          "IMPORTANT: This mode allows to use the device integrations of the provided homebridge plugins. No "bridge" is provided that can be used by the Home App!"
                          So then I should get at least some variables in objects that I can connect to yahka using enum no?
                          Or how should I interpret the "device integrations" mentioned above?
                          I really don't want to also have Homebridge running for just this plugin.
                          UPDATE:
                          After installing "homebridge-seasons", as it was tested and confirmed working, I suddenly started getting log errors which I didn't get with homebridge-eosstb plugin alone!?
                          Now the ham folder in objects gets a 0 folder with all necessary variables of the seasons plugin.
                          Still no eosstb variables.
                          2023-12-10 10:10:31.217 - debug: ham.0 (9301) setState Season.Season.Season-Name: set value = Winter
                          2023-12-10 10:10:31.219 - error: ham.0 (9301) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2023-12-10 10:10:31.220 - error: ham.0 (9301) unhandled promise rejection: Cannot add a bridged Accessory with the same UUID as another bridged Accessory: 25ec2c37-426c-4b8e-a20f-976770fa1af5
                          2023-12-10 10:10:31.347 - error: ham.0 (9301) Error: Cannot add a bridged Accessory with the same UUID as another bridged Accessory: 25ec2c37-426c-4b8e-a20f-976770fa1af5
                          at WrapperBridge.Accessory.addBridgedAccessory (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/src/lib/Accessory.ts:594:15)
                          at WrapperBridge.addBridgedAccessory (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:299:55)
                          at /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/src/bridgeService.ts:554:11
                          at Array.forEach ()
                          at /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/src/bridgeService.ts:542:19
                          at /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/src/lib/util/once.ts:10:18
                          at SeasonsPlatform.accessories (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-seasons/index.js:64:3)
                          at /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/src/bridgeService.ts:537:17
                          at new Promise ()
                          at BridgeService.loadPlatformAccessories (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/bridgeService.js:400:16)
                          2023-12-10 10:10:31.348 - error: ham.0 (9301) Cannot add a bridged Accessory with the same UUID as another bridged Accessory: 25ec2c37-426c-4b8e-a20f-976770fa1af5
                          2023-12-10 10:10:31.374 - info: ham.0 (9301) cleaned everything up...
                          2023-12-10 10:10:31.394 - info: ham.0 (9301) terminating
                          2023-12-10 10:10:31.396 - warn: ham.0 (9301) Terminated (UNCAUGHT_EXCEPTION): Without reason
                          2023-12-10 10:10:31.397 - debug: ham.0 (9301) [10/12/2023, 10:10:31] [EOSSTB] Goodbye
                          2023-12-10 10:10:31.898 - info: ham.0 (9301) terminating
                          2023-12-10 10:10:31.969 - error: host.rpi4 Caught by controller[1]: [10/12/2023, 10:10:30] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                          2023-12-10 10:10:31.970 - error: host.rpi4 Caught by controller[2]: [10/12/2023, 10:10:30] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                          2023-12-10 10:10:31.970 - error: host.rpi4 Caught by controller[3]: [10/12/2023, 10:10:30] The plugin "homebridge-eosstb" requires a Homebridge version of >=1.6.0 which does not satisfy the current Homebridge version of 1.5.0. You may need to update this plugin (or Homebridge) to a newer version. You may face unexpected issues or stability problems running this plugin.
                          2023-12-10 10:10:31.970 - error: host.rpi4 instance system.adapter.ham.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          2023-12-10 10:10:31.971 - info: host.rpi4 Restart adapter system.adapter.ham.0 because enabled
                          2023-12-10 10:11:02.013 - info: host.rpi4 instance system.adapter.ham.0 started with pid 9342
                          So apparently eosstb needs at least homebridge V1.6.0 and ham apparently still runs V1.5.0.
                            @martiman sagte in Homebridge-Adapter: Funktionierende Plugins und Beispiele:
                            hehe ... jooo ... Wrapper mode ist genau das ... und keine Bridge.. Nimm den Local Mode, dann startet er eine Bridge
                              @apollon77 I installed homebridge for this one and also android plugin for Shield TV. I don’t really need to automate these so Siri access is enough 😉
                                dfrozen1977 @apollon77 last edited by
                                @apollon77
                                @alexeimotkoff/homebridge-daichi-comfort-conditioner
                                  "bridge": {
                                    "username": "CC:22:3D:E3:CE:30",
                                    "port": 51826,
                                    "pin": "031-45-154"
                                  "platforms": [
                                      "name": "Daichi Comfort",
                                      "username": "************",
                                      "password": "************",
                                      "platform": "DaichiComfortConditioner"
                                ![HAM.png](/assets/uploads/files/1712289853797-ham.png) ```
                                  eugenmayer last edited by
                                  homebridge-thermotek
                                  • wrapper mode
                                    "description": "Add configuration for your accessories or platforms according to the docs of the plugins.",
                                    "accessories": [],
                                    "platforms": [
                                        "host": "zz.xx.yy.cc",
                                        "port": "6653",
                                        "platform": "ThermotecRadiatorControl"
                                  haselchen O 2 Replies Last reply Reply Quote 1
                                  • haselchen
                                    haselchen Most Active @eugenmayer last edited by
                                    @eugenmayer
                                    Dieser Post soll uns was sagen? 🤔
                                    • O
                                      oFbEQnpoLKKl6mbY5e13 @haselchen last edited by
                                      @haselchen
                                      Dass es ein funktionierendes Plugin ist?
                                      • haselchen
                                        haselchen Most Active @oFbEQnpoLKKl6mbY5e13 last edited by
                                        @ofbeqnpolkkl6mby5e13
                                        Okay, vielleicht hatte ich das einfach nur vermisst 😎
                                        Bitte packt auf jeden Fall Pluginname, Version des Plugins, die Version des ham Adapters und EUre nodejs Version mit rein. Danke!
                                        Danke Ingo
                                        • O
                                          oFbEQnpoLKKl6mbY5e13 @eugenmayer last edited by oFbEQnpoLKKl6mbY5e13
                                          @eugenmayer
                                          Trage die Infos -siehe den Hinweis von @haselchen- bitte noch nach.
                                            tob111 last edited by
                                            Hallo habe den ham 5.3.1 und versuche gerade über homebridge-ring mein Ring Alarm System einzubinden. An die Sensoren komme ich schön ran, die sind auch alle gelistet. Das Problem ist die Kamera. Da werden zwar auch Infos gelistet, ich würde aber gerne auf die Snapshots zugreifen. Wo finde ich die?
                                            238
                                            50106
