    4. Mehrere Werte Trennen
    • mickym
      mickym Most Active last edited by mickym
      So ich hab dir das jetzt so gemacht aus den Werten.
       <variables>
         <variable id="lku$YIe5iNvg1c$0Ej,z">liste</variable>
         <variable id="W.tP*CKGS*C%p*4we0T2">Pfad</variable>
         <variable id="xi5qt{!-3U!jw+W%{(+c">Element</variable>
         <variable id="+EQ]^**(f1=abAu.Aa#f">i</variable>
         <variable id="o[p7?ic9W(Mko]+M2CvA">ObjektID</variable>
       </variables>
       <block type="variables_set" id="#{z9Q!0km6$_6EzsuXGj" x="-1062" y="38">
         <field name="VAR" id="lku$YIe5iNvg1c$0Ej,z">liste</field>
           <block type="convert_jsonata" id="m0aREl#Cn8]G#uPnS`M*">
             <value name="EXPRESSION">
               <shadow type="text" id="CqqLMaIltCf-ffsG9#Ft">
                 <field name="TEXT">[['4',0.2543],['3',0.2545],['2',0.2605],['1',0.2905]]</field>
             <value name="TARGET">
               <block type="text" id="rIrm8`d^x/ffRm.f1p3{">
                 <field name="TEXT"></field>
           <block type="debug" id="D^:m#Qv-67um.b_3O3[S">
             <value name="TEXT">
               <shadow type="text" id="R{iZ36IcY}{48ntEy(TX">
               <block type="variables_get" id="Uk7/9?nWG)0*mI+RvPC%">
               <block type="variables_set" id="4vJ2qMGDFrZ)Y%}VgmJG">
                 <field name="VAR" id="W.tP*CKGS*C%p*4we0T2">Pfad</field>
                   <block type="text" id="^nuYf2E%qyQFC^@vcgt;">
                     <field name="TEXT">0_userdata.0.Test.Tibber_Akku_Laden.GünstigsteStunde</field>
                   <block type="variables_set" id="IHQX3BKq@ymP}cBNGe:)">
                     <field name="VAR" id="xi5qt{!-3U!jw+W%{(+c">Element</field>
                       <block type="math_number" id="j!@MESwT{Tys.@42/JY0">
                         <field name="NUM">0</field>
                       <block type="controls_forEach" id="igN;;}v9LZyu?K{UVtnq">
                         <field name="VAR" id="+EQ]^**(f1=abAu.Aa#f">i</field>
                         <value name="LIST">
                           <block type="variables_get" id="8x{KZYY,-N.cb(+]qk8F">
                         <statement name="DO">
                           <block type="math_change" id="RmBP0@E;mUX-z:RdkzWB">
                             <value name="DELTA">
                               <shadow type="math_number" id="z2Y!gAu[;6_TfuHsSUVt">
                                 <field name="NUM">1</field>
                               <block type="controls_if" id="k?-7_kahGo2pV7q#=Inu">
                                   <block type="logic_compare" id="M+9J0Y:B^2_]C3F^dd?)">
                                     <field name="OP">GT</field>
                                       <block type="variables_get" id="=O]}.~4luM__;y+%Nwp$">
                                       <block type="math_number" id="I3F_Q2OJ1-DaUTjqbZ=V">
                                         <field name="NUM">4</field>
                                   <block type="controls_flow_statements" id="@fH2JkL|,c.CnGhwIqY2">
                                     <field name="FLOW">BREAK</field>
                                   <block type="variables_set" id="-bXW!Ad?RF=4MtAD{q{:">
                                     <field name="VAR" id="o[p7?ic9W(Mko]+M2CvA">ObjektID</field>
                                       <block type="text_join" id="LYn1ddrg?aJLt:kQKCmE">
                                         <value name="ADD0">
                                           <block type="variables_get" id="hvC5ZrO.L]8Lb/TrQ*`W">
                                         <value name="ADD1">
                                           <block type="variables_get" id=",erpvFSU{X%wHOmmClSh">
                                       <block type="debug" id="-.R;#`bo{H(P583.mN@w">
                                         <value name="TEXT">
                                           <shadow type="text" id="}Nz6/888LPgQWAKxIZoL">
                                           <block type="variables_get" id="9+a;?m7:#YCVsiSlTGqf">
                                           <block type="control_ex" id="jUO#ep~v+tr#OH*JR!.!">
                                             <field name="TYPE">true</field>
                                             <value name="OID">
                                               <shadow type="field_oid" id="zLxx.8ed8xP2_,ofIqC|">
                                                 <field name="oid">Object ID</field>
                                               <block type="variables_get" id="e7~UG4vbb?n3_/2`r|nW">
                                               <shadow type="logic_boolean" id="J|1[aa_{%$0YGjD$QEc!">
                                               <block type="lists_getIndex" id="~oxe)mu8Nu.6V^{L8@(%">
                                                   <block type="variables_get" id="EhO#77HGNxOpea*7AHw8">
                                                 <value name="AT">
                                                   <block type="math_number" id="8K`k^D~MwQ2M=l{cx!kv">
                                             <value name="DELAY_MS">
                                               <shadow type="math_number" id="K~HEg;[^Q7pF+^tL^hU[">
      Musst halt den Pfad anpassen.
        Einstein 0 @mickym last edited by Einstein 0
        @mickym vielen Dank für deine Hilfe und sorry, dass ich mich erst jetzt melde. Hatte gestern einfach keine Nerven mehr dafür.
        Heute habe ich das Script nachgebaut und gestartet. Leider schreibt es keine Werte in die Objekte.
        Es müssten eigentlich 3, 4, 2, 1 in den Objekten drinn stehen.
        Frage: der Wert/Format von JSONata im Script, ist fix oder muss der sich bei jeder Ausführung ändern? Weil die Preise aus der Liste ändern sich ja jeden Tag um 13Uhr, da da Tibber die neuen Preise zur Verfügung stellt. Evtl. liegt es ja da dran.
        • mickym
          mickym Most Active @Einstein 0 last edited by mickym
          @einstein-0 Den JSONATA Baustein brauchst Du nicht - rauslöschen - der war nur für mich, um Dein Array nachzubauen.
          Dann stimmt dich an Deinem Pfad nichts ich hatte Dir das doch schon bist GünstigerStunde alles hingeschrieben.
          In den Pfad gibst Du:
          0_userdata.0.Tibber.Tibber_Akku_Laden.GünstigsteStunde
          ohne Zahl ein - die wird dann über das Element gesetzt.
            @mickym als Pfad habe ich die ID von übergeordneten Order der Objekte eingetragen. (0_userdata.0.Tibber_Akku_Laden)
            Das Script sieht jetzt so aus:
            Die Objekte habe leider immer noch keinen Wert.
            Habe noch versucht eine oder beide Nullen aus dem Pfad wegzulassen, ging auch nicht.
            • mickym
              @einstein-0 Dein Pfad ist doch verkehrt - ich hab ihn doch unten anhand Deines Screenshots gepostet.
              Kopiere das bitte raus und trage es EXAKT in den Pfad ein:
              Die Datenpunkte sind alle unter
              und die Datenpunkte heißen GünstigsteStunde.
              Trag das bitte vollständig so ein:
              die Zahl wird dann im Blockly angehängt.
                @mickym said in Mehrere Werte Trennen:
                hab ich doch auch schon probiert. Geht nicht.
                • mickym
                  @einstein-0
                  Da ist ein Leerzeichen hinter Stunde!!
                  Deine Datenpunkte heißen doch
                  GünstigsteStunde1 etc. und nicht GünstigsteStunde 1
                  Du siehst doch hier - wo er hinschreiben will:
                  Sobald was oranges kommt, dann stimmt der Pfad nicht!
                    @mickym hab ich auch grad gesehen grrrr
                    geht aber immer noch nicht.
                    • mickym
                      @einstein-0 Wie heißt denn die Warnung im Log?
                        @mickym so geht´s jetzt - trotz Warnung
                        neu(funktioniert): 0_userdata.0.Tibber_Akku_Laden.GünstigsteStunde
                        alt(falsch): 0_userdata.0.Tibber.Tibber_Akku_Laden.GünstigsteStunde
                        • mickym
                          @einstein-0
                          Bei mir geht es.
                          Kopiere aus der ersten Spalte einfach nochmal direkt den Pfad aus den Objekten und lösche die Zahl weg.
                            @mickym hab ich ja gemacht, seit dem funktioniert es.
                            Nur die orangen Fehler verstehe ich nicht.
                            • mickym
                              @einstein-0 Und nicht steuere sonder aktualisiere.
                              Ich habe keine Ahnung was Du geändert hast.
                              Vielleicht importierst noch mal neu - ich hab es nun mit deinen Pfaden gemacht.
                               <variables>
                               </variables>
                                     <value name="TEXT">
                                             <field name="TEXT">0_userdata.0.Tibber.GünstigsteStunde</field>
                                                 <value name="LIST">
        <value name="ADD0">
        <value name="ADD1">
        <value name="TEXT">
        <value name="OID">
        <value name="AT">
                              • mickym
                                @einstein-0 Ja
                                bei mir ist nichts orange und ich habe die gleichen Datenpunkte erstellt. Hast Du die Datenpunkte auch als ZEichenkette erstellt?
                                Wie schaut Dein Log aus - ich muss leider gleich weg
                                E 2 Replies Last reply Reply Quote 0
                                  @mickym muss man die ID aus den Objekten kopieren oder den Namen? Ich habe die ID genommen.
                                    @mickym ne als Zahl
                                    • mickym
                                      @einstein-0 sagte in Mehrere Werte Trennen:
                                      Die ID ist richtig!
                                      Zeig Dein Log - dann liegt es daran, dass eine Zeichenkette geschrieben wird. Dann mach folgendes:
                                      klemm noch ein Konvertierungspuzzle nach Zahl hin.
                                        @mickym jetzt gehts, dass wars und war ne schwierige Geburt.
                                        Vielen vielen Dank für deine tolle Hilfe.
                                        • mickym
                                          @einstein-0 Ja na gut - also ich bin dann erst mal weg - aber dann kann ich ja beruhigt gehen.
                                          Am Besten immer alles von Anfang an zeigen, wie die Datenpunkte erstellt sind, was man machen will usw. - das verkürzt das Ganze wesentlich.
                                            @mickym 👍 👍 👍
                                            javascript
                                            1997
