    4. Shellys ("Alt und Plus") über MQTT Adapter
      hotspot_2 @mickym last edited by hotspot_2
      @mickym Hallo, ich habe mal noch eine Verständnisfrage:
      Ich habe ja einen Flow gebastelt der drei Lichter im Keller anschaltet wenn der Bewegungsmelder getriggert wird oder wenn der Lichttaster angeht. Nach 5 Minuten geht das Licht dann wieder aus (Trigger). Ich würde nun gerne noch zusätzlich das halten eines Lichtschalters (long push) abfangen um damit das Licht dann manuell aus und einschalten zu können.
              "id": "ae979309777cfd8f",
              "type": "mqtt in",
              "z": "692f3cf44001c136",
              "name": "",
              "topic": "shellies/sonstiges/bwm_wk/status",
              "qos": "2",
              "datatype": "auto-detect",
              "broker": "b22fc4d3e3f172bb",
              "nl": false,
              "rap": true,
              "rh": 0,
              "inputs": 0,
              "x": 170,
              "y": 140,
              "wires": [
                      "b275779cdcb8ca87"
              "id": "4d6c21f253707f3a",
              "type": "mqtt in",
              "name": "",
              "topic": "shellies/sonstiges/bwm_flur_keller/status",
              "qos": "2",
              "nl": false,
              "rap": true,
              "rh": 0,
              "inputs": 0,
              "x": 200,
              "y": 200,
              "wires": [
                      "ce3fea7966a34734"
              "id": "ce3fea7966a34734",
              "type": "switch",
              "name": "",
              "property": "payload.motion",
              "propertyType": "msg",
              "rules": [
                      "t": "true"
              "checkall": "true",
              "repair": false,
              "outputs": 1,
              "x": 490,
              "y": 200,
              "wires": [
                      "ad67b76febdf0a92"
              "id": "de365cd7a4813149",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "{\t   \"id\":199,\t   \"src\":\"hotspot_2\",\t   \"method\":\"Switch.Set\",\t   \"params\":{\"id\":0,\"on\":payload}\t}\t \t",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1230,
              "y": 260,
              "wires": [
                      "541e8fa04f94475d",
                      "df00a6eda1372fa1",
                      "7e4aebe657e40852"
              "id": "0e35c29460abd499",
              "type": "mqtt out",
              "name": "",
              "topic": "shellies/licht/keller/waschkueche/rpc",
              "qos": "",
              "retain": "",
              "respTopic": "",
              "contentType": "",
              "userProps": "",
              "correl": "",
              "expiry": "",
              "x": 2430,
              "y": 340,
              "wires": []
              "id": "541e8fa04f94475d",
              "type": "mqtt out",
              "name": "",
              "topic": "shellies/licht/keller/flur_keller_vorne/rpc",
              "qos": "",
              "retain": "",
              "respTopic": "",
              "contentType": "",
              "userProps": "",
              "correl": "",
              "expiry": "",
              "x": 1560,
              "y": 200,
              "wires": []
              "id": "658b57870ce763a7",
              "type": "trigger",
              "name": "",
              "op1": "true",
              "op2": "false",
              "op1type": "bool",
              "op2type": "bool",
              "duration": "5",
              "extend": true,
              "overrideDelay": false,
              "units": "min",
              "reset": "",
              "bytopic": "all",
              "topic": "topic",
              "outputs": 1,
              "x": 1030,
              "y": 260,
              "wires": [
                      "de365cd7a4813149"
              "id": "ad67b76febdf0a92",
              "type": "ioBroker get",
              "name": "Schalter",
              "topic": "0_userdata.0.hausautomation.bwm_flur_keller_aktiv",
              "attrname": "payload",
              "payloadType": "value",
              "errOnInvalidState": "nothing",
              "x": 640,
              "y": 200,
              "wires": [
                      "c7a2538582f26f99"
              "id": "c7a2538582f26f99",
              "type": "switch",
              "name": "Schalter = true?",
              "property": "payload",
              "rules": [
                      "t": "true"
              "checkall": "true",
              "repair": false,
              "outputs": 1,
              "x": 820,
              "y": 200,
              "wires": [
                      "658b57870ce763a7"
              "id": "df00a6eda1372fa1",
              "type": "mqtt out",
              "name": "",
              "topic": "shellies/licht/keller/flur_keller_hinten/rpc",
              "qos": "",
              "retain": "",
              "respTopic": "",
              "contentType": "",
              "userProps": "",
              "correl": "",
              "expiry": "",
              "x": 1560,
              "y": 260,
              "wires": []
              "id": "eb3fcf783b74fd7a",
              "type": "mqtt in",
              "name": "",
              "topic": "shellies/licht/keller/waschkueche/events/rpc",
              "qos": "2",
              "nl": false,
              "rap": true,
              "rh": 0,
              "inputs": 0,
              "x": 200,
              "y": 260,
              "wires": [
                      "1e6515cac6ba6901"
              "id": "90c60a9f3a115521",
              "type": "mqtt in",
              "name": "",
              "topic": "shellies/licht/keller/flur_keller_hinten/events/rpc",
              "qos": "2",
              "nl": false,
              "rap": true,
              "rh": 0,
              "inputs": 0,
              "x": 220,
              "y": 320,
              "wires": [
                      "1e6515cac6ba6901"
              "id": "1416273ebfce58bb",
              "type": "mqtt in",
              "name": "",
              "topic": "shellies/licht/keller/flur_keller_vorne/events/rpc",
              "qos": "2",
              "nl": false,
              "rap": true,
              "rh": 0,
              "inputs": 0,
              "x": 210,
              "y": 380,
              "wires": [
                      "1e6515cac6ba6901"
              "id": "1e6515cac6ba6901",
              "type": "switch",
              "name": "NotifyEvent",
              "property": "payload.method",
              "rules": [
                      "t": "eq",
                      "v": "NotifyEvent",
                      "vt": "str"
              "checkall": "true",
              "repair": false,
              "outputs": 1,
              "x": 530,
              "y": 320,
              "wires": [
                      "ccaf9c5d06ca071a"
              "id": "ccaf9c5d06ca071a",
              "type": "switch",
              "name": "input:0 = btn_down",
              "property": "payload.params.events[0].component=\"input:0\" and payload.params.events[0].event = \"btn_down\"",
              "propertyType": "jsonata",
              "rules": [
                      "t": "true"
              "checkall": "true",
              "repair": false,
              "outputs": 1,
              "x": 730,
              "y": 320,
              "wires": [
                      "658b57870ce763a7"
              "id": "323856145be0390f",
              "name": "",
              "topic": "0_userdata.0.hausautomation.lux_bewegungsmelder_wk",
              "attrname": "limit_lux_wk",
              "x": 1790,
              "y": 320,
              "wires": [
                      "29d46c0be09b69a6"
              "id": "29d46c0be09b69a6",
              "type": "switch",
              "name": "lux_wk < limit_lux_wk",
              "property": "lux_wk",
              "propertyType": "flow",
              "rules": [
                      "t": "lte",
                      "v": "limit_lux_wk",
                      "vt": "msg"
              "checkall": "true",
              "repair": false,
              "outputs": 1,
              "x": 2140,
              "y": 320,
              "wires": [
                      "0e35c29460abd499"
              "id": "7e4aebe657e40852",
              "type": "switch",
              "name": "",
              "property": "payload.params.on",
              "rules": [
                      "t": "true"
                      "t": "false"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 1450,
              "y": 340,
              "wires": [
                      "323856145be0390f"
                      "519701bc8160d15c"
              "id": "b275779cdcb8ca87",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "lux_wk",
                      "pt": "flow",
                      "to": "payload.lux",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 430,
              "y": 140,
              "wires": [
                      "ce3fea7966a34734"
              "id": "0a4a5cad7064557a",
              "type": "junction",
              "x": 2240,
              "y": 360,
              "wires": [
                      "0e35c29460abd499"
              "id": "519701bc8160d15c",
              "type": "junction",
              "x": 1580,
              "y": 360,
              "wires": [
                      "0a4a5cad7064557a"
              "id": "b22fc4d3e3f172bb",
              "type": "mqtt-broker",
              "name": "iobroker mqtt adapter",
              "broker": "localhost",
              "port": "1883",
              "clientid": "mqttin_nodered",
              "autoConnect": true,
              "usetls": false,
              "protocolVersion": "4",
              "keepalive": "60",
              "cleansession": true,
              "birthTopic": "",
              "birthQos": "0",
              "birthPayload": "",
              "birthMsg": {},
              "closeTopic": "",
              "closeQos": "0",
              "closePayload": "",
              "closeMsg": {},
              "willTopic": "",
              "willQos": "0",
              "willPayload": "",
              "willMsg": {},
              "userProps": "",
              "sessionExpiry": ""
      Wie bekomme ich das hin das ich in dem Switch vor dem Trigger (input:0 = btn_down) das Event für den Long Push noch abfangen kann und von da aus dann verzweige zu dem was passiert wenn das Licht manuell aus und eingeschalten wird? Vor dem Trigger würde ich noch einen Switch einbauen der abfrägt ob das Licht manuell eingeschalten wurde (iobroker_objekt boolean) um dann den Trigger nicht zu starten wenn das Licht manuell angeschalten wurde damit es dann auch manuell wieder ausgeschalten werden muss oder ausgeschaltet werden kann.
        hotspot_2 @hotspot_2 last edited by hotspot_2
        @hotspot_2
        So, die Abfrage ob das Licht manuell eingeschaltet wurde ist mal drin.
                "type": "mqtt in",
                "name": "",
                "qos": "2",
                "nl": false,
                "rap": true,
                "rh": 0,
                "inputs": 0,
                "x": 170,
                "y": 140,
                "wires": [
                        "b275779cdcb8ca87"
                "type": "mqtt in",
                "name": "",
                "qos": "2",
                "nl": false,
                "rap": true,
                "rh": 0,
                "inputs": 0,
                "x": 200,
                "y": 200,
                "wires": [
                        "ce3fea7966a34734"
                "type": "switch",
                "name": "",
                "rules": [
                        "t": "true"
                "checkall": "true",
                "repair": false,
                "outputs": 1,
                "x": 490,
                "y": 200,
                "wires": [
                        "ad67b76febdf0a92"
                "type": "change",
                "name": "",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "tot": "jsonata"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 1670,
                "y": 260,
                "wires": [
                        "541e8fa04f94475d",
                        "df00a6eda1372fa1",
                        "7e4aebe657e40852"
                "type": "mqtt out",
                "name": "",
                "qos": "",
                "retain": "",
                "respTopic": "",
                "contentType": "",
                "userProps": "",
                "correl": "",
                "expiry": "",
                "x": 2870,
                "y": 340,
                "wires": []
                "type": "mqtt out",
                "name": "",
                "qos": "",
                "retain": "",
                "respTopic": "",
                "contentType": "",
                "userProps": "",
                "correl": "",
                "expiry": "",
                "x": 2000,
                "y": 200,
                "wires": []
                "type": "trigger",
                "name": "",
                "op1": "true",
                "op2": "false",
                "op1type": "bool",
                "op2type": "bool",
                "duration": "5",
                "extend": true,
                "units": "min",
                "reset": "",
                "bytopic": "all",
                "topic": "topic",
                "outputs": 1,
                "x": 1470,
                "y": 260,
                "wires": [
                        "de365cd7a4813149"
                "name": "Schalter",
                "x": 640,
                "y": 200,
                "wires": [
                        "c7a2538582f26f99"
                "type": "switch",
                "rules": [
                        "t": "true"
                "checkall": "true",
                "repair": false,
                "outputs": 1,
                "x": 820,
                "y": 200,
                "wires": [
                        "6ab813a6b99d1545"
                "type": "mqtt out",
                "name": "",
                "qos": "",
                "retain": "",
                "respTopic": "",
                "contentType": "",
                "userProps": "",
                "correl": "",
                "expiry": "",
                "x": 2000,
                "y": 260,
                "wires": []
                "type": "mqtt in",
                "name": "",
                "qos": "2",
                "nl": false,
                "rap": true,
                "rh": 0,
                "inputs": 0,
                "x": 200,
                "y": 260,
                "wires": [
                        "1e6515cac6ba6901"
                "type": "mqtt in",
                "name": "",
                "qos": "2",
                "nl": false,
                "rap": true,
                "rh": 0,
                "inputs": 0,
                "x": 220,
                "y": 320,
                "wires": [
                        "1e6515cac6ba6901"
                "type": "mqtt in",
                "name": "",
                "qos": "2",
                "nl": false,
                "rap": true,
                "rh": 0,
                "inputs": 0,
                "x": 210,
                "y": 380,
                "wires": [
                        "1e6515cac6ba6901"
                "type": "switch",
                "rules": [
                        "t": "eq",
                        "v": "NotifyEvent",
                        "vt": "str"
                "checkall": "true",
                "repair": false,
                "outputs": 1,
                "x": 530,
                "y": 320,
                "wires": [
                        "ccaf9c5d06ca071a"
                "type": "switch",
                "rules": [
                        "t": "true"
                "checkall": "true",
                "repair": false,
                "outputs": 1,
                "x": 730,
                "y": 320,
                "wires": [
                        "6ab813a6b99d1545"
                "name": "",
                "x": 2230,
                "y": 320,
                "wires": [
                        "29d46c0be09b69a6"
                "type": "switch",
                "rules": [
                        "t": "lte",
                        "vt": "msg"
                "checkall": "true",
                "repair": false,
                "outputs": 1,
                "x": 2580,
                "y": 320,
                "wires": [
                        "0e35c29460abd499"
                "type": "switch",
                "name": "",
                "rules": [
                        "t": "true"
                        "t": "false"
                "checkall": "true",
                "repair": false,
                "outputs": 2,
                "x": 1890,
                "y": 340,
                "wires": [
                        "323856145be0390f"
                        "519701bc8160d15c"
                "type": "change",
                "name": "",
                "rules": [
                        "t": "set",
                        "p": "lux_wk",
                        "pt": "flow",
                        "tot": "msg"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 430,
                "y": 140,
                "wires": [
                        "ce3fea7966a34734"
                "id": "6ab813a6b99d1545",
                "name": "licht_flur_keller_manuell",
                "topic": "0_userdata.0.hausautomation.licht_flur_keller_manuell",
                "attrname": "licht_flur_keller_manuell",
                "x": 1090,
                "y": 260,
                "wires": [
                        "1fb3162fdf7cba13"
                "id": "1fb3162fdf7cba13",
                "type": "switch",
                "name": "",
                "property": "llicht_flur_keller_manuell",
                "rules": [
                        "t": "false"
                        "t": "true"
                "checkall": "true",
                "repair": false,
                "outputs": 2,
                "x": 1290,
                "y": 260,
                "wires": [
                        "658b57870ce763a7"
                "type": "junction",
                "x": 2680,
                "y": 360,
                "wires": [
                        "0e35c29460abd499"
                "type": "junction",
                "x": 2020,
                "y": 360,
                "wires": [
                        "0a4a5cad7064557a"
                "port": "1883",
                "usetls": false,
                "keepalive": "60",
                "birthTopic": "",
                "birthQos": "0",
                "birthPayload": "",
                "birthMsg": {},
                "closeTopic": "",
                "closeQos": "0",
                "closePayload": "",
                "closeMsg": {},
                "willTopic": "",
                "willQos": "0",
                "willPayload": "",
                "willMsg": {},
                "userProps": "",
                "sessionExpiry": ""
        Nun, bräuchte ich noch einen Tipp wie ich hier verzweigen kann wenn der Schalter lange gedrückt wurde.
        Der Event, der laut der Shelly Dokumenation, beim langen Schalterdruck erzeugt wird ist "long_push".
        • mickym
          Mit dem langen Drücken würde ich halt eine Flowvariable toggeln und diese in einem Switch abfragen und so die Automatik blockieren.
            @mickym Hast Du mir noch einen Tipp wie ich die Abfrage hinbekomme bezüglich der zwei unterschiedlichen Events? Kann ich das JSONata in dem switch node so abändern das ich dort dann abzeigen kann je nachdem was gedrückt wurde?
            • mickym
              mickym Most Active @hotspot_2 last edited by mickym
              @hotspot_2 Verstehe ich nicht ganz?
              long_push
              Bei den events solltest Du dóch folgendes Event bekommen?
                 "src": "shellypro4pm-f008d1d8b8b8",
                 "dst": "user_1",
                 "method": "NotifyEvent",
                 "params": {
                    "ts": 1631266629.79,
                    "events": [
                          "component": "input:0",
                          "id": 0,
                          "event": "long_push",
                          "ts": 1631266629.79
              Und Du brauchst doch nur den long-push um vom Automatik Modus auf den manuellen Modus umzustellen.
              Oder bekommst Du das Event direkt in einem Datenpunkt Input:0 - Du weißt ich hab die Geräte ja nicht
              • mickym
                @hotspot_2 Ich habs mal nicht mit einem Datenpunkt - sondern einer Flowvariable gemacht. Ich hab auch keine Ahnung ob Du mqtt richtig rausfilterts . Kannst natürlich auch wieder einen Datenpunkt toggeln.
                Ich hab halt nach Beschreibung in die Inject Node so ein Notification Event Objekt genommen, wie es unten steht.
                Ich toggle halt eine Flow variable mit true und false. Geht auch mit einem Datenpunkt im iobroker.
                Das untenstehende Objekt auf einen long_push event mit der switch Node zu selektieren geht so:
                so selektierst Du alle events der input:0 Komponente und kannst mit mehreren Ausgängen natürlich auch andere Events selektieren.
                        "id": "2d55768c7365f5d3",
                        "type": "inject",
                        "z": "7e6af0015415146d",
                        "name": "",
                        "props": [
                                "p": "payload"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "payload": "{\"src\":\"shellypro4pm-f008d1d8b8b8\",\"dst\":\"user_1\",\"method\":\"NotifyEvent\",\"params\":{\"ts\":1631266629.79,\"events\":[{\"component\":\"input:0\",\"id\":0,\"event\":\"long_push\",\"ts\":1631266629.79}]}}",
                        "payloadType": "json",
                        "x": 2410,
                        "y": 2240,
                        "wires": [
                                "64eb8e8d7476f747"
                        "id": "64eb8e8d7476f747",
                        "type": "switch",
                        "name": "Event of input:0",
                        "property": "payload.params.events[component=\"input:0\"].event",
                        "rules": [
                                "t": "eq",
                                "v": "long_push",
                                "vt": "str"
                                "t": "eq",
                                "v": "double_push",
                                "vt": "str"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 2620,
                        "y": 2360,
                        "wires": [
                                "5b74af2f251d0335",
                                "3e7660c3a451876a"
                                "1fb9b2d47582aa92"
                        "id": "5b74af2f251d0335",
                        "type": "change",
                        "name": "",
                        "rules": [
                                "t": "set",
                                "p": "auto",
                                "pt": "flow",
                                "to": "$exists($flowContext(\"auto\")) ? $not($flowContext(\"auto\")) : true\t",
                                "tot": "jsonata"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 2860,
                        "y": 2340,
                        "wires": [
                        "type": "mqtt in",
                        "name": "",
                        "qos": "2",
                        "nl": false,
                        "rap": true,
                        "rh": 0,
                        "inputs": 0,
                        "x": 2190,
                        "y": 2580,
                        "wires": [
                                "b275779cdcb8ca87"
                        "type": "mqtt in",
                        "name": "",
                        "qos": "2",
                        "nl": false,
                        "rap": true,
                        "rh": 0,
                        "inputs": 0,
                        "x": 2220,
                        "y": 2640,
                        "wires": [
                                "ce3fea7966a34734"
                        "type": "switch",
                        "name": "",
                        "rules": [
                                "t": "true"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 1,
                        "x": 2510,
                        "y": 2640,
                        "wires": [
                                "ad67b76febdf0a92"
                        "type": "change",
                        "name": "",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "tot": "jsonata"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 3490,
                        "y": 2660,
                        "wires": [
                                "541e8fa04f94475d",
                                "df00a6eda1372fa1",
                                "7e4aebe657e40852"
                        "type": "mqtt out",
                        "name": "",
                        "qos": "",
                        "retain": "",
                        "respTopic": "",
                        "contentType": "",
                        "userProps": "",
                        "correl": "",
                        "expiry": "",
                        "x": 4690,
                        "y": 2740,
                        "wires": []
                        "type": "mqtt out",
                        "name": "",
                        "qos": "",
                        "retain": "",
                        "respTopic": "",
                        "contentType": "",
                        "userProps": "",
                        "correl": "",
                        "expiry": "",
                        "x": 3820,
                        "y": 2600,
                        "wires": []
                        "type": "trigger",
                        "name": "",
                        "op1": "true",
                        "op2": "false",
                        "op1type": "bool",
                        "op2type": "bool",
                        "duration": "5",
                        "extend": true,
                        "units": "min",
                        "reset": "",
                        "bytopic": "all",
                        "topic": "topic",
                        "outputs": 1,
                        "x": 3290,
                        "y": 2660,
                        "wires": [
                                "de365cd7a4813149"
                        "name": "Schalter",
                        "x": 2660,
                        "y": 2640,
                        "wires": [
                                "c7a2538582f26f99"
                        "type": "switch",
                        "rules": [
                                "t": "true"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 1,
                        "x": 2840,
                        "y": 2640,
                        "wires": [
                                "b52632d1d3763274"
                        "type": "mqtt out",
                        "name": "",
                        "qos": "",
                        "retain": "",
                        "respTopic": "",
                        "contentType": "",
                        "userProps": "",
                        "correl": "",
                        "expiry": "",
                        "x": 3820,
                        "y": 2660,
                        "wires": []
                        "type": "switch",
                        "d": true,
                        "rules": [
                                "t": "true"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 1,
                        "x": 2490,
                        "y": 2500,
                        "wires": [
                        "name": "",
                        "x": 4050,
                        "y": 2720,
                        "wires": [
                                "29d46c0be09b69a6"
                        "type": "switch",
                        "rules": [
                                "t": "lte",
                                "vt": "msg"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 1,
                        "x": 4400,
                        "y": 2720,
                        "wires": [
                                "0e35c29460abd499"
                        "type": "switch",
                        "name": "",
                        "rules": [
                                "t": "true"
                                "t": "false"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 3710,
                        "y": 2740,
                        "wires": [
                                "323856145be0390f"
                                "519701bc8160d15c"
                        "type": "change",
                        "name": "",
                        "rules": [
                                "t": "set",
                                "p": "lux_wk",
                                "pt": "flow",
                                "tot": "msg"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 2450,
                        "y": 2580,
                        "wires": [
                                "ce3fea7966a34734"
                        "type": "mqtt in",
                        "name": "",
                        "qos": "2",
                        "nl": false,
                        "rap": true,
                        "rh": 0,
                        "inputs": 0,
                        "x": 2120,
                        "y": 2300,
                        "wires": [
                                "1e6515cac6ba6901"
                        "type": "mqtt in",
                        "name": "",
                        "qos": "2",
                        "nl": false,
                        "rap": true,
                        "rh": 0,
                        "inputs": 0,
                        "x": 2140,
                        "y": 2360,
                        "wires": [
                                "1e6515cac6ba6901"
                        "type": "mqtt in",
                        "name": "",
                        "qos": "2",
                        "nl": false,
                        "rap": true,
                        "rh": 0,
                        "inputs": 0,
                        "x": 2130,
                        "y": 2420,
                        "wires": [
                                "1e6515cac6ba6901"
                        "type": "switch",
                        "rules": [
                                "t": "eq",
                                "v": "NotifyEvent",
                                "vt": "str"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 1,
                        "x": 2430,
                        "y": 2360,
                        "wires": [
                                "64eb8e8d7476f747"
                        "x": 2730,
                        "y": 2500,
                        "wires": [
                        "id": "b52632d1d3763274",
                        "type": "switch",
                        "name": "Automatik?",
                        "property": "auto",
                        "rules": [
                                "t": "true"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 1,
                        "x": 3030,
                        "y": 2640,
                        "wires": [
                                "658b57870ce763a7"
                        "id": "3e7660c3a451876a",
                        "type": "debug",
                        "name": "long_push Event",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "complete": "payload",
                        "targetType": "msg",
                        "statusVal": "",
                        "statusType": "auto",
                        "x": 2850,
                        "y": 2280,
                        "wires": []
                        "id": "1fb9b2d47582aa92",
                        "type": "debug",
                        "name": "double_push Event",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "statusVal": "",
                        "x": 2830,
                        "y": 2400,
                        "wires": []
                        "type": "junction",
                        "x": 4500,
                        "y": 2760,
                        "wires": [
                                "0e35c29460abd499"
                        "type": "junction",
                        "x": 3840,
                        "y": 2760,
                        "wires": [
                                "0a4a5cad7064557a"
                        "port": "1883",
                        "usetls": false,
                        "keepalive": "60",
                        "birthTopic": "",
                        "birthQos": "0",
                        "birthPayload": "",
                        "birthMsg": {},
                        "closeTopic": "",
                        "closeQos": "0",
                        "closePayload": "",
                        "closeMsg": {},
                        "willTopic": "",
                        "willQos": "0",
                        "willPayload": "",
                        "willMsg": {},
                        "userProps": "",
                        "sessionExpiry": ""
                Mit dieser Anweisung:
                payload.params.event[component="input:0"].event
                filterst Du alles events die von der Komponente input:0 kommen und dann aus diesem Objekt selektierst Du die event Eigenschaft.
                So kannst Du dann aus dem Notification Objekt - alle Eventtypen in der Switch Node direkt abfragen:
                Wenn mehrere Events zu input:0 aufeinmal kommen, was aber unwahrscheinlich ist - dann wäre es ein Array - dann müsste man das ggf. noch abfangen.
                  @mickym Ich habe mal wieder ein kleines Problem wo ich keine Idee habe wie ich das lösen kann. Vielleicht hast ja Du einen Tipp.
                  Ich habe drei Bewegungsmelder die im Treppenhaus (3 Stockwerke) das Licht komplett anmachen wenn es dunkel ist. Nun würde ich gerne mit dem gleichen Flow abfangen das wenn es hell ist bei Bewegung im Keller auch nur das Licht im Keller angeht. Das klappt schon soweit, allerdings löst im Moment noch jeder drei Bewegungsmelder das Licht im Keller ist.
                  Gibt es eine einfach Möglichkeit festzustellen von welchem der drei Bewegungsmelder die Message kommt?
                  Danke schon mal.
                  • mickym
                    @hotspot_2 klar im topic der Nachricht steht doch woher sie stammt. Falls du dir das topic mit der Get_node (Schalter) überschreibst, must du das ursprüngliche topic halt in eine andere Eigenschaft des Nachrichtenobjekts verschieben.
                      @mickym Hallo! Ich habe mal wieder eine Frage zum Thema NodeRED. Ich würde gerne diese URL absetzen in einem Flow "http://<ip_des_motion>/settings/actions?index=0&enabled=true&name=motion_on". Damit soll man die Blind Time der Shelly Motions zurücksetzen können damit sie gleich wieder reagieren und keine Wartezeiten entstehen, was gerade bei Steuerungen nicht so elegant ist. Ich hab auf Anhieb keine Node gefunden die einfach nur die URL absetzen kann ohne eine Antwort zu erwarten oder im payload weiterzugeben. Einfach nur URL absetzen genügt mir völlig.
                      Hast Du da einen Tipp?
                      • mickym
                        @hotspot_2 http-Request Node kann das. Du musst die payload ja nicht nutzen
                          @mickym Ich würde gerne vermeiden das die Payload überschrieben wird, aber das kann ich ja dann auch anders lösen.
                          • mickym
                            @hotspot_2 Die payload einfach vorher wegsichern in eine andere Eigenschaft und dann wiederherstellen oder wenn der Flow nicht darauf wartet kannst ja die http-request Node parallel schalten.
                                   "id": "16e222d916ed508d",
                                   "type": "inject",
                                   "z": "517cd16e4d7e6ae4",
                                   "name": "",
                                   "props": [
                                           "p": "payload"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "meine Payload",
                                   "payloadType": "str",
                                   "x": 200,
                                   "y": 760,
                                   "wires": [
                                           "256b81c5a9258da4",
                                           "e430ce787d9d6df9"
                                   "id": "ebe81636ff7f335a",
                                   "type": "http request",
                                   "name": "",
                                   "method": "GET",
                                   "ret": "txt",
                                   "paytoqs": "ignore",
                                   "url": "http://192.168.178.220/settings/actions?index=0&enabled=true&name=motion_on",
                                   "tls": "",
                                   "persist": false,
                                   "proxy": "",
                                   "insecureHTTPParser": false,
                                   "authType": "",
                                   "senderr": false,
                                   "headers": [],
                                   "x": 650,
                                   "y": 760,
                                   "wires": [
                                           "5a11e17731a11ba6",
                                           "3f6a9e00ac86a57c"
                                   "id": "256b81c5a9258da4",
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "move",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "backup",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 440,
                                   "y": 760,
                                   "wires": [
                                           "ebe81636ff7f335a"
                                   "id": "5a11e17731a11ba6",
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "move",
                                           "p": "backup",
                                           "pt": "msg",
                                           "to": "payload",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 860,
                                   "y": 760,
                                   "wires": [
                                           "60a5729510d0e2c7"
                                   "id": "3f6a9e00ac86a57c",
                                   "type": "debug",
                                   "name": "http request",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 870,
                                   "y": 700,
                                   "wires": []
                                   "id": "e430ce787d9d6df9",
                                   "type": "debug",
                                   "name": "payload vorher",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 440,
                                   "y": 700,
                                   "wires": []
                            oder halt payload ignorieren, wenn nicht auf Ergebnis gewartet werden muss.
                              @mickym Super! Vielen Dank. So komm ich weiter.
                                @hotspot_2 Hab noch mal was ;-). Wenn ich die Inhalte von Flow Eigenschaften einsehen möchte also welcher Wert da gerade drin steht? Wie krieg ich das hin? Das geht doch nicht mit den debug-Nodes, oder?
                                • mickym
                                  @hotspot_2 Meinst Du den Flow Kontext ? Den siehst Du im Kontext Tab
                                    @mickym Hallo! Ich habe zur Zeit ein Problem das mir ein Shelly (Licht) immer wieder mal angesteuert wird und ich kann mir nicht erklären warum. Gibt es da eine Möglichkeit das ich vor das MQTT Out Node irgendwas setze was mir die Payloads länger dokumentiert die da drüber gehen? Also so eine Art Log zu schreiben über längere Zeit?
                                    Danke schon mal für einen Tipp dazu.
                                    • mickym
                                      @hotspot_2 Einfach eine DebugNode nehmen und in die Systemkonsole schreiben (die DebugNode entsprechend sprechend benennen). Dann taucht alles im iobroker Protokoll auf.
                                      79565
