    4. Adapter werden nicht mehr geupdated
      Accu @Homoran last edited by
      @homoran wie bereitet man die neue Karte am PC vor? einfach übern Card Reader?
        Homoran Global Moderator Administrators @Accu last edited by
        @accu sagte in Adapter werden nicht mehr geupdated:
        wie sonst?
        was hast du denn bisher gemacht?
          Thomas Braun Most Active @Accu last edited by
          @accu
          iob fix
            @homoran ich hatte tatsächlich beim ersten mal den Raspi am Bildschirm
              Accu @Thomas Braun last edited by Accu
              @thomas-braun habe ich schon 2x drüber laufen lassen. Der Fehler bleibt der gleiche:
              pi@Raspi:~ $ iob fix
              library: loaded
              Library version=2023-10-13
                  Welcome to the ioBroker installation fixer!
                  Script version: 2023-10-13
                  You might need to enter your password a couple of times.
                  Installing prerequisites (1/5)
              OK:1 http://archive.raspberrypi.org/debian buster InRelease
              OK:2 https://deb.nodesource.com/node_18.x nodistro InRelease
              OK:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  Checking ioBroker user and directory permissions (2/5)
              Created /etc/sudoers.d/iobroker
              Fixing directory permissions...
                  Check and cleanup npm temporary directories (3/5)
              Done.
                  Database maintenance (4/5)
              Checking for uncompressed JSONL databases... This might take a while!
              Compressing /opt/iobroker/iobroker-data/states.jsonl
              Compressing /opt/iobroker/iobroker-data/objects.jsonl
              Compressed 2 JSONL files. Done
                  Checking autostart (5/5)
              Enabling autostart...
              Autostart enabled!
                  Your installation was fixed successfully
                  Run iobroker start to start ioBroker again!
              pi@Raspi:~ $ sudo -H -u iobroker npm install iobroker.js-controller
              npm ERR! code EACCES
              npm ERR! syscall mkdir
              npm ERR! path /home/pi/node_modules/iobroker.js-controller
              npm ERR! errno -13
              npm ERR! Error: EACCES: permission denied, mkdir '/home/pi/node_modules/iobroker.js-controller'
              npm ERR!  [Error: EACCES: permission denied, mkdir '/home/pi/node_modules/iobroker.js-controller'] {
              npm ERR!   errno: -13,
              npm ERR!   code: 'EACCES',
              npm ERR!   syscall: 'mkdir',
              npm ERR!   path: '/home/pi/node_modules/iobroker.js-controller'
              npm ERR! }
              npm ERR!
              npm ERR! The operation was rejected by your operating system.
              npm ERR! It is likely you do not have the permissions to access this file as the current user
              npm ERR!
              npm ERR! If you believe this might be a permissions issue, please double-check the
              npm ERR! permissions of the file and its containing directories, or try running
              npm ERR! the command again as root/Administrator.
              npm ERR! A complete
                @homoran sagte in Adapter werden nicht mehr geupdated:
                wieso nicht.
                🙂 Hatte irgendwie Richtung 'Image auf der Kommandozeile flashen' gedacht... Der Raspberry Imager hat aber afaik kein CLI.
                  Thomas Braun Most Active @Accu last edited by Thomas Braun
                  Du stehst im falschen Verzeichnis.
                  Und nein, der Fehler ist nicht der gleiche...
                    @thomas-braun ich habe jetzt mal meine Backup Speicherkarte vom System genommen, weil die andere Installation komplett zerschossen war.
                    Habe jetzt alle Updates gemacht und der iobroker läuft wieder.
                    Allerdings habe ich Probleme bei der Authentifizierung in den Adapter settings. Der Button lässt sich nicht drücken und erscheint ausgegraut. Auch in Firefox das gleiche. Liegt das evtl. an der veralteten Node Version. Gibt's da eine Möglichkeit noch aktuellere Versionen zu installieren ohne das bestehende Altsystem wieder zu Schrotten?
                    mein System sieht so aus:
                    Es gibt keine Nutzer-Sitzungen mit veralteten Prozessen.
                    pi@Raspi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                    /usr/bin/nodejs
                    v14.21.3
                    /usr/bin/node
                    v14.21.3
                    /usr/bin/npm
                    6.14.18
                    nodejs:
                      Installiert:           14.21.3-deb-1nodesource1
                      Installationskandidat: 14.21.3-deb-1nodesource1
                      Versionstabelle:
                     *** 14.21.3-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                            100 /var/lib/dpkg/status
                         10.24.0~dfsg-1~deb10u3 500
                      @accu
                      iob nodejs-update
                        ioBroker nodejs fixer 2023-10-13
                        No recommendation for a nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
                        Your current setup is:
                        /usr/bin/nodejs 	v14.21.3
                        /usr/bin/node 		v14.21.3
                        /usr/bin/npm 		6.14.18
                        /usr/local/bin/npx 		8.1.2
                        /usr/local/bin/corepack 	0.10.0
                        *** nodejs is NOT correctly installed ***
                        We found these nodejs versions available for installation:
                        nodejs:
                          Installed: 14.21.3-deb-1nodesource1
                          Candidate: 14.21.3-deb-1nodesource1
                          Version table:
                        Your nodejs-Installation seems to be faulty. Shall we try to fix it?
                        Press <y> to continue or any other key to quit
                        Fixing your nodejs setup
                        *** Deleting /usr/local/bin/npx ***
                        *** Deleting /usr/local/bin/corepack ***
                        Wrong paths have been fixed. Run 'iob diag' or 'iob node-fix' again to check if your installation is fine now
                        You are running nodejs v14.21.3. Do you want to install latest version from nodejs v.18 tree?
                        Trying to update your installation now. Please be patient.
                        Waiting for ioBroker to shut down - Give me a minute...
                        *** These repos are active on your system:
                        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                        Reading package lists... Done
                        *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                        *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                        Package: nodejs
                        Pin: origin deb.nodesource.com
                        Pin-Priority: 1001
                        *** These repos are active after the adjustments:
                        Get:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                        Get:4 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [6272 B]
                        Fetched 18.4 kB in 4s (5030 B/s)
                        Installing the recommended nodejs version now!
                        Exact recommended version unknown, installing a fallback!
                        (Reading database ... 144794 files and directories currently installed.)
                        Preparing to unpack .../nodejs_18.0.0-1nodesource1_armhf.deb ...
                        Detected old npm client, removing...
                        Unpacking nodejs (18.0.0-1nodesource1) over (14.21.3-deb-1nodesource1) ...
                        Setting up nodejs (18.0.0-1nodesource1) ...
                        Processing triggers for man-db (2.8.5-2) ...
                        Scanning processes...
                        Scanning candidates...
                        Scanning linux images...
                        Failed to check for processor microcode upgrades.
                        Restarting services...
                         systemctl restart pm2.service
                        No containers need to be restarted.
                        No user sessions are running outdated binaries.
                        Updating fallback to latest nodejs v18 release
                        (Reading database ... 145600 files and directories currently installed.)
                        Preparing to unpack .../nodejs_18.19.0-1nodesource1_armhf.deb ...
                        Unpacking nodejs (18.19.0-1nodesource1) over (18.0.0-1nodesource1) ...
                        Setting up nodejs (18.19.0-1nodesource1) ...
                        v18.19.0 has been installed! You are using the latest version now!
                        Installing the recommended nodejs version!
                        We tried our best to fix your nodejs. Please run iob diag again to verify.
                        *** RESTARTING ioBroker NOW! ***
                         Please refresh or restart your browser in a few moments.
                          @accu
                          Schau mit
                          iob diag
                          nach, ob das jetzt richtig installiert wurde.
                            @thomas-braun leider ist der Netatmo Authenticate Button immer noch ausgegraut 😞
                            			v.2023-10-10
                               Static hostname: Raspi
                                     Icon name: computer
                              Operating System: Raspbian GNU/Linux 10 (buster)
                                        Kernel: Linux 6.1.64-v7+
                                  Architecture: arm
                            Installation: 		native
                            Kernel: 		armv7l
                            Userland: 		armhf
                            Timezone: 		Europe/Berlin (CET, +0100)
                            User-ID: 		1000
                            X-Server: 		false
                            Boot Target: 		multi-user.target
                            Pending OS-Updates: 	0
                            Pending iob updates: 	32
                            Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
                            			/usr/bin/node 		v18.19.0
                            			/usr/bin/npm 		10.2.3
                            			/usr/bin/npx 		10.2.3
                            			/usr/bin/corepack 	0.22.0
                            Recommended versions are nodejs  and npm
                            MEMORY:
                            Mem:           922M        650M        109M        1.0M        162M        209M
                            Swap:           99M         99M        0.0K
                            Total:         1.0G        750M        109M
                            Active iob-Instances: 	11
                            Active repo: stable
                            ioBroker Core: 		js-controller 		3.3.22
                            			admin 			5.2.3
                            ioBroker Status: 	iobroker is running on this host.
                            Objects type: file
                            States  type: file
                            + system.adapter.admin.0                  : admin                 : Raspi                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              system.adapter.web.0                    : web                   : Raspi                                    - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                            Objects: 		28472
                            States: 		14139
                            Size of iob-Database:
                            20M	/opt/iobroker/iobroker-data/objects.json.bak
                            17M	/opt/iobroker/iobroker-data/objects.json.broken
                            12K	/opt/iobroker/iobroker-data/objects.json.old
                            2.8M	/opt/iobroker/iobroker-data/states.json.bak
                            1.9M	/opt/iobroker/iobroker-data/states.json.old
                            0	/opt/iobroker/iobroker-data/states.json.broken
                              Und 1 GB RAM ist zu wenig.
                                @thomas-braun wie gesagt die updates macht er nicht bzw. läuft durch bei den updates aber bietet diese dann wieder zum update an
                                  @accu
                                  Zeigen...
                                  iob update
                                  iob upgrade all
                                    @thomas-braun glaube meine sicherungskopie hat es jetzt auch hinter sich:
                                    Last login: Sun Dec 10 10:20:16 on console
                                    accu@iMac ~ % ssh pi@192.168.1.13
                                    pi@192.168.1.13's password:
                                    Linux Raspi 6.1.64-v7+ #1702 SMP Wed Nov 29 14:16:46 GMT 2023 armv7l
                                    The programs included with the Debian GNU/Linux system are free software;
                                    the exact distribution terms for each program are described in the
                                    individual files in /usr/share/doc/*/copyright.
                                    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                    permitted by applicable law.
                                    Last login: Sun Dec 10 08:29:18 2023
                                    pi@Raspi:~ $ iob status
                                    node:internal/modules/cjs/loader:1137
                                      throw err;
                                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                        at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
                                        at Module._load (node:internal/modules/cjs/loader:975:27)
                                        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                        at node:internal/main/run_main_module:28:49 {
                                      code: 'MODULE_NOT_FOUND',
                                      requireStack: []
                                    Node.js v18.19.0
                                    pi@Raspi:~ $ iob upgrade all
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.0
                                    pi@Raspi:~ $
                                      ich installiere jetzt mal die Bookworm Version auf ner anderen Speicherkarte und berichte ...
                                        @accu
                                        cd /opt/iobroker
                                          @thomas-braun ich hoffe er läuft diesmal durch. Musste nach 4h letztens abbrechen, weil er eingeforen ist.
                                          pi@Raspi:~ $ cd /opt/iobroker
                                          pi@Raspi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                                          npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                          npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                          npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                                          npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                                          npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                          npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                          npm WARN deprecated multer@1.4.2: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
                                          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                          npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                          npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                          npm WARN deprecated passport.socketio@3.7.0: Please check the workaround in https://github.com/jfromaniello/passport.socketio/issues/148
                                          npm WARN deprecated request@2.88.0: request has been deprecated, see https://github.com/request/request/issues/3142
                                          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                          npm WARN deprecated bcrypt@3.0.6: versions < v5.0.0 do not handle NUL in passwords properly
                                          npm WARN deprecated bcrypt@3.0.8: versions < v5.0.0 do not handle NUL in passwords properly
                                          npm WARN deprecated vm2@3.9.19: The library contains critical security issues and should not be used for production! The maintenance of the project has been discontinued. Consider migrating your code to isolated-vm.
                                          npm WARN deprecated node-pre-gyp@0.12.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
                                          npm WARN deprecated node-pre-gyp@0.14.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
                                          npm WARN deprecated appium-logger@2.1.0: Moved into appium-support
                                          npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                                          npm WARN deprecated core-js@1.2.7: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
                                          npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
                                          (##################) ⠹ reify:iobroker.admin: http fetch GET 200 https://registry.npmjs.org/iobroker.admin/-/iobroker.admin-5.4.9.tgz 923762ms (cache miss)
                                          mikeal created this issue in request/request
                                          open Request’s Past, Present and Future #3142
                                          Qix- created this issue in visionmedia/debug
                                          closed ReDos Vulnerability Regression Visibility Notice #797
                                          sliterok created this issue in jfromaniello/passport.socketio
                                          closed For everyone who is struggling with this module #148
                                            @thomas-braun installation ist erfolgreich durchgelaufen und der neu ioBroker installiert gerade die Instanzen.
                                            Was schmerzt sind, dass ich meine skripte aus dem alten ioB nicht mehr habe.
                                            Die speicherkarte mit der geschrotteten iob instanz habe ich noch. Gibts da irgendeine chance die Blockly Skripte rauszuextrahieren?
                                            Thomas Braun Codierknecht 2 Replies Last reply Reply Quote 0
                                            2561
