    3. Einsteigerfragen
    4. Installation
    5. Backup aus älterer Version einspielen
      firefighter166 @Marc Berg last edited by
      @marc-berg
      Jetzt sollte es mit dem Hostnamen doch passen, jetzt mal abwarten was passiert, wenn ich versuche das Backup einzuspielen.
      -------------------------     2023-12-08 11:42:07      -------------------------
      -----              Welcome to your ioBroker Docker container!              -----
      -----                    Startupscript is now running!                     -----
      -----                          Please be patient!                          -----
      -----                          System Information                          -----
      -----                    arch:                x86_64                       -----
      -----                    hostname:            iobroker-1                   -----
      -----                          Version Information                         -----
      -----                    image:               v7.2.0                       -----
      -----                    build:               2023-02-10T23:45:25+00:00    -----
      -----                    node:                v16.20.2                     -----
      -----                    npm:                 8.19.4                       -----
      -----                        Environment Variables                         -----
      -----                    SETGID:              1000                         -----
      -----                    SETUID:              1000                         -----
      -----                  Step 1 of 5: Preparing container                   -----
      This is not the first run of this container. Skipping first run preparation.
      -----             Step 2 of 5: Detecting ioBroker installation             -----
      Existing installation of ioBroker detected in "/opt/iobroker".
      -----             Step 3 of 5: Checking ioBroker installation              -----
      (Re)setting permissions (This might take a while! Please be patient!)... Done.
      Fixing "sudo-bug" by replacing sudo with gosu... Done.
      Hostname in ioBroker matches the hostname of this container.
      No action required.
      -----                Step 4 of 5: Applying special settings                -----
      Some adapters have special requirements/ settings which can be activated by the use of environment variables.
      For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
      -----                    Step 5 of 5: ioBroker startup                     -----
      Starting ioBroker...
      ##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
      host.iobroker-1 check instance "system.adapter.admin.0" for host "iobroker-1"
      host.iobroker-1 check instance "system.adapter.discovery.0" for host "iobroker-1"
      host.iobroker-1 check instance "system.adapter.backitup.0" for host "iobroker-1"
      Send diag info: {"uuid":"f53b18b4-a546-4bd5-8027-f5107b97e1d9","language":"de","country":"","hosts":[{"version":"4.0.24","platform":"Javascript/Node.js","type":"linux"}],"node":"v16.20.2","arch":"x64","docker":true,"adapters":{"admin":{"version":"6.3.5","platform":"Javascript/Node.js"},"discovery":{"version":"3.1.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.5.12","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":3,"compactMode":false,"noCompactInstances":0,"model":"AMD GX-424CC SOC with Radeon(TM) R5E Graphics","cpus":4,"mem":15734272000,"ostype":"Linux","city":""}
      ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
      • Marc Berg
        Marc Berg Most Active @firefighter166 last edited by
        @firefighter166 sagte in Backup aus älterer Version einspielen:
        ich bin zuversichtlich.
          @marc-berg
          Das ist mal der Log beim Backup einspielen.
          ioBroker Backitup Restore
          Restore and Restart completed successfully!!
          [DEBUG] [iobroker] Start ioBroker Restore ...
          [DEBUG] [iobroker] iobroker controller daemon is not running
          [DEBUG] [iobroker] host.iobroker-1 OK.
          [DEBUG] [iobroker] The current version of js-controller differs from the version in the backup.
          [DEBUG] [iobroker] The js-controller version of the backup can not be restored automatically.
          [DEBUG] [iobroker] Note, that your backup might differ in behavior due to this version change!
          [DEBUG] [iobroker] Removing current installation of iobroker.admin
          [DEBUG] [iobroker] removed 22 packages in 3s
          [DEBUG] [iobroker] 35 packages are looking for funding
          [DEBUG] [iobroker] run `npm fund` for details
          [DEBUG] [iobroker] Removing current installation of iobroker.backitup
          [DEBUG] [iobroker] removed 124 packages in 3s
          [DEBUG] [iobroker] 25 packages are looking for funding
          [DEBUG] [iobroker] Removing current installation of iobroker.discovery
          [DEBUG] [iobroker] removed 43 packages in 2s
          [DEBUG] [iobroker] 13 packages are looking for funding
          [DEBUG] [iobroker] host.iobroker-1 Clear all objects and states...
          [DEBUG] [iobroker] clean 144 objects...
          [DEBUG] [iobroker] clean 101 states...
          [DEBUG] [iobroker] host.iobroker-1 done.
          [DEBUG] [iobroker] host.iobroker-1 Processed 0/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 200/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 400/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 600/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 800/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 1000/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 1200/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 1400/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 1600/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 1800/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 2000/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 2200/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 2400/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 2600/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 2800/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 3000/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 3200/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 3400/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 3600/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 3800/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 4000/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 4200/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 4400/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 4600/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 4800/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 5000/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 5200/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 5400/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 5600/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 5800/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 6000/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 6200/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 6400/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 6600/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 6800/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 7000/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 7200/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 7400/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 7600/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 7800/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 8000/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 8200/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 8400/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 8600/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 8800/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 9000/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 9200/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 9400/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 9600/9998 objects
          [DEBUG] [iobroker] host.iobroker-1 Processed 9800/9998 objects
          [DEBUG] [iobroker] 9998 objects restored.
          [DEBUG] [iobroker] host.iobroker-1 Processed 0/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 200/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 400/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 600/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 800/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 1000/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 1200/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 1400/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 1600/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 1800/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 2000/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 2200/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 2400/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 2600/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 2800/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 3000/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 3200/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 3400/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 3600/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 3800/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 4000/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 4200/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 4400/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 4600/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 4800/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 5000/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 5200/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 5400/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 5600/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 5800/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 6000/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 6200/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 6400/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 6600/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 6800/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 7000/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 7200/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 7400/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 7600/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 7800/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 8000/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 8200/8477 states
          [DEBUG] [iobroker] host.iobroker-1 Processed 8400/8477 states
          [DEBUG] [iobroker] 8477 states restored.
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//cache.manifest
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//cordova.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/add_kian.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/app.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/backgrounds.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/doc.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/montserrat-regular-webfont.woff
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/styles.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/vis-common-user.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/vis-editor.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/vis.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//edit.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//edit.src.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/add.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-height.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-horizontal-center-2.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-horizontal-left.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-horizontal-right-2.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-vertical-bottom-2.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-vertical-center-2.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-vertical-top-2.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-width.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/bar.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/cancel.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/checkbox.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/container.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/control.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/copy.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/delete.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/dialog.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/distribute-horizontal-equal.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/distribute-vertical-equal.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/door.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/filter.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/groupFixed.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/groupVisibility.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/info.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/lamp.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/lock.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/lockIcon.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/navigation.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/ok.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/refresh-4.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/rename.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/rgb.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/shutter.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/state.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/stateful.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/static.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/table.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/temperature.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/timestamp.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/tools.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/value.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/window.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/Heating.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/Lamp.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/OutsideTemp.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/Window.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/back/box-radial.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/back/flowers.jpg
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/back/oblique-line-bk.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-10.svg
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-15.svg
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-20.svg
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-25.svg
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-30.svg
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-40.svg
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-5.svg
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-50.svg
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bulbOff.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bulbOn.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bulb_off.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bulb_on.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/camera.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/cc-nc-by.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/disconnect.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/door-bell.mp3
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/editmode-pattern.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/eg_trans.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/favicon.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/faviconEdit.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/garage-door-closed.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/garage-door-opened.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/gear-icon-md.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/hexabump.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/kde_folder.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/no_filter.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/sound.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/tank.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/vis.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/zip.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//index.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//index.src.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/app.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/config.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/conn.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/connSignalR.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/fileManager.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/fileManager.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/add.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/back.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/delete.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/down.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/edit-rename.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/folder-new-7.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/folder-new.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/icons.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/list.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/play.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/refresh.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/stop.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/up.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/circleLeftIcon.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/JS.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/bmp.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/css.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/folder-blue.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/folder-brown.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/folder-green.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/gif.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/img2.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/jpg.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/misc.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/mp3.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/png.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/prg.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/svg.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/undef.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/wav.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/zip.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/bmp.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/css.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/folder-blue.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/folder-brown.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/folder-green.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/gif.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/img2.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/jpg.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/js.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/misc.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/mp3.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/png.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/prg.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/svg.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/undef.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/wav.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/zip.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/vis.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visAbout.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEdit.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEditExt.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEditInspect.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEditTemplates.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEditWelcome.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visUtils.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visWizard.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/words.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/ace.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/ext-language_tools.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/ext-searchbox.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/mode-css.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/mode-html.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/mode-javascript.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/worker-css.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/worker-html.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/worker-javascript.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/add2home-2.0.8.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/channel.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/device.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/icons.gif
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/loading.gif
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/state.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/ui.fancytree.jquery.min.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/ui.fancytree.min.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/farbtastic.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/jquery-ui-timepicker-addon-1.6.3.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/jquery.jgrowl.min.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/jquery.multiselect-1.13.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/jquery.multiselect.filter.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/superfish/megafish.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/superfish/superfish-navbar.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/superfish/superfish-vertical.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/superfish/superfish.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/delete.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/edit-undo-8.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/logout.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/marker.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/mask.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/shape_align_bottom.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/shape_align_left.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/shape_align_right.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/shape_align_top.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/wheel.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/add2home-2.0.8.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/can.custom.min.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/colResizable-1.5.min.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/dropzone.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/farbtastic.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/html2canvas.min.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery-ui-1.10.3.dragdropsort.min.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery-ui-timepicker-addon-1.6.3.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.ba-resize.min.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.base64.min.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.fancytree-all.min.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.inputmask.bundle.min.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.jgrowl.map
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.jgrowl.min.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.multiselect-1.13.min.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.multiselect.filter-1.5pre.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.ui.datepicker.min.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.ui.touch-punch.min.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.wakeup.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jqueryui.selectmenu.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/loStorage.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/moment-with-locales.min.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/quo.standalone.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/superclick.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/translate.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//manifest.webmanifest
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//offline.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/fire.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/fireColor.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/lowbattery.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/motion.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/motionColor.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/online.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/waterColor.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/waterDrops.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/wifiColor.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/wifiColorRed.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/css/table.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/doc.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_AckBool.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_BasicState.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_BulbOnOffCtrl.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ContainerView.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_FilterDropdown.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_FullScreen.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_HTML.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_HTMLnavigation.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_HtmlLogout.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_Image.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_Note.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_RedNumber.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ScreenResolution.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_Shape.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_Speech2Text.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_StatefulContainerView8.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_StatefulIFrame8.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_StatefulImage.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_TableBody.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_TimeValue.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBool.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBoolCheckbox.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBoolCtrl.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBoolCtrlSvg.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBoolSelect.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueFloat.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueFloatBar.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueGesture.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueInput.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueLastchange.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueList.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueListHtml.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueListHtml8.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueString.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueStringImg.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueStringRaw.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueTimestamp.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_iFrame.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_tplFrame.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_tplLink.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/doc_example_hm_val_number.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micActive.svg
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micDetected.svg
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micInactive.svg
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micSent.svg
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micStarted.svg
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/pin_red5.svg
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/js/table.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/echarts/img/Prev_tplEchartsChart.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/echarts.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/fritzdect/css/style.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/fritzdect/js/fritzdect.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/fritzdect.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/css/style.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/img/calendar.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/img/messages.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/js/info.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/js/words.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot/css/jquery.jqplot.min.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot/doc.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot/img/Prev_MeterGauge.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot/js/jquery.jqplot.min.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/doc.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_ContainerButtonDialog.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_ContainerDialog.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_ContainerDialogExternal.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_ContainerIconDialog.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_JquiDialog.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_JquiIconDialog.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/ct.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/hue.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/internet-web-browser-2.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/doc.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/img/Prev_Carousel.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/img/Prev_Swipe.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/img/noSwipe.jpg
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/js/jquery.roundabout-shapes.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/js/jquery.roundabout.min.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/js/jquery.touchSwipe.min.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/jquery.sliderTabs.js
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/indicator.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/indicatorActive.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/leftArrow.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/leftPanelArrow.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/rightArrow.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/rightPanelArrow.png
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/jquery.sliderTabs.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/jquery.sliderTabs.css.orig
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/jquery.sliderTabs.min.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/todo/dev.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/todo/homematic.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/todo/special.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/todo/weather.html
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis.0/main/vis-user.css
          [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis.0/main/vis-views.json
          [DEBUG] [iobroker] Reinstalling adapter "admin" from "iobroker.admin@6.2.22"
          [DEBUG] [iobroker] added 87 packages, and changed 1 package in 12s
          [DEBUG] [iobroker] 24 packages are looking for funding
          [DEBUG] [iobroker] Reinstalling adapter "backitup" from "iobroker.backitup@2.4.12"
          [DEBUG] [iobroker] added 76 packages, and removed 9 packages in 9s
          [DEBUG] [iobroker] 28 packages are looking for funding
          [DEBUG] [iobroker] Forced restore - executing setup ...
          [DEBUG] [iobroker] System successfully restored!
          [DEBUG] [iobroker] ioBroker Restore completed successfully
          [EXIT] 0 **** Restore completed successfully!! ****
          [EXIT] **** Docker Container restart now... ****
          • Marc Berg
            @firefighter166
            Die VIS wird wegen eines Bugs erstmal nicht funktionieren, hier muss erstmal ein Downgrade gemacht werden.
            Guck mal hier: https://forum.iobroker.net/topic/70838/vis-kann-nach-restore-nicht-installiert-werden/3
            Danach machst du ein Upgrade aller Adapter und des js-controllers auf die Version 5.0.x. Dieses Backup kannst du dann auch auf einem aktuellen Image einspielen.
              firefighter166 @Marc Berg last edited by firefighter166
              @marc-berg said in Backup aus älterer Version einspielen:
              Ich glaube es nicht es ist wieder da. Jetzt mache ich mal Stück für Stück weiter damit ich auf die neue Version umziehen kann.
              Wo finde ich nochmal den Befehl für das Upgrade des js-controllers?
              • Marc Berg
                In dieser alten Versionskonstellation so:
                pkill -u iobroker
                iobroker update
                iobroker upgrade self
                  @marc-berg
                  Vielen Dank bis hierhin für die super Unterstützung. Ich habe jetzt bis auf dem Raspberry welcher als Slave läuft alles auf dem neusten Stand.
                  Marc Berg Thomas Braun 2 Replies Last reply Reply Quote 0
                  • Marc Berg
                    @firefighter166
                    In Zukunft bitte mit allen relevanten Infos gleich rausrücken. Dass du eine Multihost-Umgebung hast, wäre wichtig gewesen zu wissen.
                    @homoran sagte in Backup aus älterer Version einspielen:
                    @firefighter166
                    jetzt bring mal alle notwendigen Informationen strukturiert bei.
                      firefighter166 last edited by firefighter166
                      @marc-berg
                      Also ich habe im Keller einen Raspberry der in der Unterverteilung sitzt und mittels Node Red meine Zählerstände abliest. Diese wurde dann in einer Influx DB gespeichert.
                        Thomas Braun Most Active @firefighter166 last edited by
                        Dann bring den auch auf Stand.
                          firefighter166 @Thomas Braun last edited by
                          Habe ich über zwei Wege versucht, er lässt sich nicht Updaten. Egal ob über dem Update Button in der Oberfläche oder über die Konsole
                          • Marc Berg
                            Marc Berg Most Active @firefighter166 last edited by Marc Berg
                            Und der Raspi sagt dann "ich hab' kein Bock auf 'n Upgrade", oder gibt's auch eine Fehlermeldung? 🙂
                              Das glaube ich nicht.
                                @marc-berg
                                Mit folgendem Befehl habe ich es direkt auf dem Pi mittels Putty probiert.
                                cd /opt/iobroker/
                                sudo iobroker stop
                                sudo iobroker update
                                sudo iobroker upgrade self
                                sudo iobroker start
                                Das macht er dann folgendes:
                                pi@iobrokerstrom:/opt/iobroker $ sudo iobroker stop
                                pi@iobrokerstrom:/opt/iobroker $ sudo iobroker update
                                Used repository: stable
                                Adapter    "admin"        : 6.12.0   , installed 5.3.4  [Updatable]
                                Adapter    "backitup"     : 2.8.7    , installed 2.3.3  [Updatable]
                                Adapter    "devices"      : 1.1.5    , installed 1.0.12 [Updatable]
                                Adapter    "discovery"    : 4.2.0    , installed 2.8.0  [Updatable]
                                Controller "js-controller": 5.0.16   , installed 4.0.23 [Updatable]
                                Adapter    "node-red"     : 4.0.3    , installed 3.3.1  [Updatable]
                                Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                                pi@iobrokerstrom:/opt/iobroker $ sudo iobroker upgrade self
                                Update js-controller from @4.0.23 to @5.0.16
                                Stopped Objects DB
                                Stopped States DB
                                NPM version: 6.14.16
                                Installing iobroker.js-controller@5.0.16... (System call)
                                pi@iobrokerstrom:/opt/iobroker $ sudo iobroker start
                                  @firefighter166
                                  Joh...
                                  Wie immer:
                                  iobroker wird nie, gar nicht, unter keinen Umständen mit sudo angepackt.
                                  iob stop
                                  iob fix
                                  iob start
                                    @firefighter166
                                    Und das ganze Konstrukt schaut wie aus?
                                    iob diag
                                    anschauen.
                                      @thomas-braun said in Backup aus älterer Version einspielen:
                                      iob start
                                      Okay, das wusste ich mit Sudo nicht. Jetzt habe ich den Befehl über sie Konsole ausgeführt.
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                           Static hostname: iobrokerstrom
                                                 Icon name: computer
                                          Operating System: Raspbian GNU/Linux 11 (bullseye)
                                                    Kernel: Linux 5.10.92-v7+
                                              Architecture: arm
                                        Model           : Raspberry Pi 3 Model B Rev 1.2
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : armv7l
                                        Userland        : armhf
                                        Systemuptime and Load:
                                         14:28:37 up 45 min,  1 user,  load average: 0.27, 0.46, 0.46
                                        CPU threads: 4
                                        *** RASPBERRY THROTTLING ***
                                        Current issues:
                                        ~ Under-voltage detected
                                        ~ Arm frequency capped
                                        Previously detected issues:
                                        ~ Under-voltage has occurred
                                        ~ Arm frequency capping has occurred
                                        *** Time and Time Zones ***
                                                       Local time: Fri 2023-12-08 14:28:38 CET
                                                   Universal time: Fri 2023-12-08 13:28:38 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** User and Groups ***
                                        pi
                                        /home/pi
                                        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                        *** X-Server-Setup ***
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:            922M         86M        460M        0.0K        376M        776M
                                        Swap:            99M          0B         99M
                                        Total:          1.0G         86M        560M
                                                  922 M total memory
                                                   86 M used memory
                                                  217 M active memory
                                                  166 M inactive memory
                                                  459 M free memory
                                                   54 M buffer memory
                                                  321 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FAILED SERVICES ***
                                        0 loaded units listed.
                                        *** FILESYSTEM ***
                                        /dev/root      ext4       29G  5.2G   23G  19% /
                                        devtmpfs       devtmpfs  333M     0  333M   0% /dev
                                        tmpfs          tmpfs     462M     0  462M   0% /dev/shm
                                        tmpfs          tmpfs     185M  736K  184M   1% /run
                                        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                                        tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
                                        [Fri Dec  8 13:42:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=edaee7dd-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Fri Dec  8 13:42:46 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                        [Fri Dec  8 13:42:46 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                        [Fri Dec  8 13:42:49 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                        TARGET  SOURCE         FSTYPE OPTIONS
                                        /       /dev/mmcblk0p2 ext4   rw,noatime
                                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                        /var:
                                        3.3G    /var/
                                        2.9G    /var/log/journal/24f1b2dc7af348df8a22d9dfe87b5d3d
                                        2.9G    /var/log
                                        150M    /var/cache
                                        Archived and active journals take up 2.8G in the file system.
                                        /opt/iobroker/backups:
                                        5.1M    /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        21M     /opt/iobroker/iobroker-data/
                                        17M     /opt/iobroker/iobroker-data/node-red/node_modules
                                        5.2M    /opt/iobroker/iobroker-data/node-red/node_modules/moment
                                        5.0M    /opt/iobroker/iobroker-data/node-red/node_modules/lodash
                                        2.6M    /opt/iobroker/iobroker-data/objects.jsonl
                                        608K    /opt/iobroker/iobroker-data/node-red/node_modules/moment/min/moment-with-locales.js
                                        532K    /opt/iobroker/iobroker-data/node-red/node_modules/lodash/lodash.js
                                        440K    /opt/iobroker/iobroker-data/node-red/node_modules/moment/min/locales.js
                                        364K    /opt/iobroker/iobroker-data/node-red/node_modules/moment/min/moment-with-locales.min.js
                                        USB-Devices by-id:
                                        /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0023-if00-port0
                                        /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0038-if00-port0
                                        /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0030-if00-port0
                                        *** NodeJS-Installation ***
                                        /home/iobroker/.diag.sh: line 277: nodejs: command not found
                                        /usr/bin/node           v12.22.11
                                        /usr/bin/npm            6.14.16
                                        /usr/bin/npx            6.14.16
                                        /home/iobroker/.diag.sh: line 281: corepack: command not found
                                        /home/iobroker/.diag.sh: line 288: nodejs: command not found
                                        *** nodejs is NOT correctly installed ***
                                        nodejs:
                                          Installed: 12.22.11-deb-1nodesource1
                                          Candidate: 12.22.12-deb-1nodesource1
                                          Version table:
                                             12.22.12-deb-1nodesource1 500
                                                500 https://deb.nodesource.com/node_12.x bullseye/main armhf Packages
                                             12.22.12~dfsg-1~deb11u4 500
                                                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                         *** 12.22.11-deb-1nodesource1 100
                                                100 /var/lib/dpkg/status
                                        No problems detected
                                          Thomas Braun Most Active @firefighter166 last edited by Thomas Braun
                                          @firefighter166
                                          Die Stromversorgung ist zu schwach.
                                          Nodejs ist hoffnungslos veraltet.
                                          Die Ausgabe ist nicht vollständig.
                                            @firefighter166
                                            Bring erstmal nodejs auf Stand.
                                            iob nodejs-update
                                            wird dir v18 einspielen.
                                            4116
