    3. Einsteigerfragen
    4. [gelöst] Zweiter Homematic-Adapter startet nicht
      automatix @Homoran last edited by automatix
      @homoran : Hier das Ende der Logdatei
      2023-12-08 20:15:28.439  - info: hm-rega.1 (4979) update favorites to enum.favorites
      2023-12-08 20:15:33.653  - info: hm-rpc.1 (5009) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.16
      2023-12-08 20:15:33.726  - info: hm-rega.0 (4964) ReGaHSS 192.168.178.46 up
      2023-12-08 20:15:33.830  - error: hm-rega.0 (4964) post request error: connect ECONNREFUSED 192.168.178.46:8181
      2023-12-08 20:15:33.832  - error: hm-rega.0 (4964) CCU 192.168.178.46 unreachable
      2023-12-08 20:15:34.133  - info: hm-rpc.1 (5009) xmlrpc server is trying to listen on 192.168.178.108:8082
      2023-12-08 20:15:34.135  - info: hm-rpc.1 (5009) xmlrpc client is trying to connect to 192.168.178.45:2001/ with ["http://192.168.178.108:8082","iobroker:hm-rpc.1:37a21bcd3bfcba027b7ff1f3ff99593f"]
      2023-12-08 20:15:34.222  - info: hm-rpc.1 (5009) xmlrpc <- system.listMethods ["iobroker:hm-rpc.1:37a21bcd3bfcba027b7ff1f3ff99593f"]
      2023-12-08 20:15:34.252  - info: hm-rpc.1 (5009) xmlrpc <- listDevices ["iobroker:hm-rpc.1:37a21bcd3bfcba027b7ff1f3ff99593f"]
      2023-12-08 20:15:34.406  - info: hm-rpc.1 (5009) xmlrpc -> 189 devices
      2023-12-08 20:15:34.507  - info: hm-rpc.1 (5009) Connected
      2023-12-08 20:15:55.064  - error: hm-rpc.0 (4994) Init not possible, going to stop: connect ECONNREFUSED 192.168.178.46:2001
      2023-12-08 20:15:55.082  - info: hm-rpc.0 (4994) xmlrpc -> 192.168.178.46:2001/ init ["http://192.168.178.108:2001",""]
      2023-12-08 20:15:55.096  - error: hm-rpc.0 (4994) Cannot call init: [http://192.168.178.108:2001, ""] connect ECONNREFUSED 192.168.178.46:2001
      2023-12-08 20:15:55.111  - info: hm-rpc.0 (4994) terminating
      2023-12-08 20:15:55.115  - info: hm-rpc.0 (4994) Terminated (NO_ERROR): Without reason
      2023-12-08 20:16:03.882  - info: hm-rega.0 (4964) ReGaHSS 192.168.178.46 up
      2023-12-08 20:16:03.925  - error: hm-rega.0 (4964) post request error: connect ECONNREFUSED 192.168.178.46:8181
      2023-12-08 20:16:03.926  - error: hm-rega.0 (4964) CCU 192.168.178.46 unreachable
      2023-12-08 20:16:26.052  - info: hm-rega.0 (4964) Got terminate signal TERMINATE_YOURSELF
      2023-12-08 20:16:26.177  - info: hm-rega.0 (4964) terminating
      2023-12-08 20:16:26.181  - info: hm-rega.0 (4964) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-12-08 20:16:26.556  - info: hm-rega.0 (4964) terminating
      2023-12-08 20:16:29.858  - info: hm-rpc.0 (5024) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.16
      2023-12-08 20:16:30.264  - info: hm-rpc.0 (5024) xmlrpc server is trying to listen on 0.0.0.0:2001
      2023-12-08 20:16:30.267  - info: hm-rpc.0 (5024) xmlrpc client is trying to connect to 192.168.178.46:2001/ with ["http://192.168.178.108:2001","iobroker:hm-rpc.0:672a253d77e59472513d027b6e1395e7"]
      2023-12-08 20:16:30.339  - error: hm-rpc.0 (5024) Init not possible, going to stop: connect ECONNREFUSED 192.168.178.46:2001
      2023-12-08 20:16:33.363  - info: hm-rega.0 (5035) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v18.19.0, js-controller: 5.0.16
      2023-12-08 20:16:33.585  - info: hm-rega.0 (5035) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
      2023-12-08 20:16:33.715  - info: hm-rega.0 (5035) ReGaHSS 192.168.178.46 up
      2023-12-08 20:16:33.820  - error: hm-rega.0 (5035) post request error: connect ECONNREFUSED 192.168.178.46:8181
      2023-12-08 20:16:33.822  - error: hm-rega.0 (5035) CCU 192.168.178.46 unreachable
      2023-12-08 20:16:36.276  - info: hm-rpc.0 (5024) Got terminate signal TERMINATE_YOURSELF
      2023-12-08 20:16:36.285  - info: hm-rpc.0 (5024) xmlrpc -> 192.168.178.46:2001/ init ["http://192.168.178.108:2001",""]
      2023-12-08 20:16:36.303  - error: hm-rpc.0 (5024) Cannot call init: [http://192.168.178.108:2001, ""] connect ECONNREFUSED 192.168.178.46:2001
      2023-12-08 20:16:36.306  - info: hm-rpc.0 (5024) terminating
      2023-12-08 20:16:36.313  - info: hm-rpc.0 (5024) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-12-08 20:16:43.781  - info: hm-rpc.0 (5054) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.16
      2023-12-08 20:16:44.123  - info: hm-rpc.0 (5054) xmlrpc server is trying to listen on 0.0.0.0:2001
      2023-12-08 20:16:44.124  - info: hm-rpc.0 (5054) xmlrpc client is trying to connect to 192.168.178.46:2001/ with ["http://192.168.178.108:2001","iobroker:hm-rpc.0:b12b2759017f42979ace9bd39aca4d0d"]
      2023-12-08 20:16:44.173  - error: hm-rpc.0 (5054) Init not possible, going to stop: connect ECONNREFUSED 192.168.178.46:2001
        Homoran Global Moderator Administrators @automatix last edited by
        @automatix sagte in Probleme bei der Einbindung eines zweiten Homematic Adapters:
        da musst du dir wohl mal due Firewall näher Ansehen
          automatix @Homoran last edited by Homoran
          @homoran : habe jetzt in der Raspberrymatic die Ports 2001 und 8182 freigegeben. Läuft aber immer noch nicht. Hier der Log:
          2023-12-08 20:40:10.110  - info: hm-rpc.0 (5503) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.16
          2023-12-08 20:40:10.506  - info: hm-rpc.0 (5503) xmlrpc server is trying to listen on 0.0.0.0:2001
          2023-12-08 20:40:10.508  - info: hm-rpc.0 (5503) xmlrpc client is trying to connect to 192.168.178.46:2001/ with ["http://192.168.178.108:2001","iobroker:hm-rpc.0:aad9c8421ebcb8242ae91fe4458f8df1"]
          2023-12-08 20:40:10.580  - error: hm-rpc.0 (5503) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
          2023-12-08 20:40:22.099  - info: hm-rpc.0 (5503) Got terminate signal TERMINATE_YOURSELF
          2023-12-08 20:40:22.108  - info: hm-rpc.0 (5503) xmlrpc -> 192.168.178.46:2001/ init ["http://192.168.178.108:2001",""]
          2023-12-08 20:40:22.135  - error: hm-rpc.0 (5503) Cannot call init: [http://192.168.178.108:2001, ""] Unknown XML-RPC tag 'TITLE'
          2023-12-08 20:40:22.137  - info: hm-rpc.0 (5503) terminating
          2023-12-08 20:40:22.140  - info: hm-rpc.0 (5503) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-12-08 20:40:29.608  - info: hm-rpc.0 (5518) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.16
          2023-12-08 20:40:29.947  - info: hm-rpc.0 (5518) xmlrpc server is trying to listen on 0.0.0.0:2001
          2023-12-08 20:40:29.949  - info: hm-rpc.0 (5518) xmlrpc client is trying to connect to 192.168.178.46:2001/ with ["http://192.168.178.108:2001","iobroker:hm-rpc.0:837cd7bdb32389d29a5b6cf12e3f4e5c"]
          2023-12-08 20:40:30.021  - error: hm-rpc.0 (5518) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
          2023-12-08 20:40:41.010  - info: hm-rega.0 (5534) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v18.19.0, js-controller: 5.0.16
          2023-12-08 20:40:41.231  - info: hm-rega.0 (5534) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
          2023-12-08 20:40:41.359  - info: hm-rega.0 (5534) ReGaHSS 192.168.178.46 up
          2023-12-08 20:40:41.485  - error: hm-rega.0 (5534) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 Unauthorized</title>\n </head>\n <body>\n  <h1>401 Unauthorized</h1>\n </body>\n</html>\n"
          2023-12-08 20:40:41.487  - error: hm-rega.0 (5534) ReGaHSS 192.168.178.46 down
            Immer noch die Firewall!
            warum die?
              @homoran : Sorry, 2001 und 8181.
              Jetzt folgender log:
              2023-12-08 20:53:03.402  - info: hm-rpc.0 (5767) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.16
              2023-12-08 20:53:03.740  - info: hm-rpc.0 (5767) xmlrpc server is trying to listen on 0.0.0.0:2001
              2023-12-08 20:53:03.742  - info: hm-rpc.0 (5767) xmlrpc client is trying to connect to 192.168.178.46:2001/ with ["http://192.168.178.108:2001","iobroker:hm-rpc.0:8e301537134b939773d413fcfcd396ac"]
              2023-12-08 20:53:03.826  - error: hm-rpc.0 (5767) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
              2023-12-08 20:53:08.532  - info: hm-rega.0 (5782) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v18.19.0, js-controller: 5.0.16
              2023-12-08 20:53:08.753  - info: hm-rega.0 (5782) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
              2023-12-08 20:53:08.884  - info: hm-rega.0 (5782) ReGaHSS 192.168.178.46 up
              2023-12-08 20:53:09.000  - error: hm-rega.0 (5782) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 Unauthorized</title>\n </head>\n <body>\n  <h1>401 Unauthorized</h1>\n </body>\n</html>\n"
              2023-12-08 20:53:09.001  - error: hm-rega.0 (5782) ReGaHSS 192.168.178.46 down
                , 2001 und 8181.
                https://www.iobroker.net/#de/adapters/adapterref/iobroker.hm-rpc/README.md?homematicport
                  @homoran Danke für den Link, ich schaue mir morgen mal die Firewall der Raspberrymatic noch mal genauer an.
                  Homoran Samson71 2 Replies Last reply Reply Quote 0
                    und das hier
                    • Samson71
                      Samson71 Global Moderator @automatix last edited by
                      @automatix
                      Mach die doch einfach zum Testen mal für den Moment ganz aus. Wenn es dann geht ist zumindest klar woran es liegt.
                      Homoran A 2 Replies Last reply Reply Quote 0
                        Homoran Global Moderator Administrators @Samson71 last edited by
                        @samson71 sagte in Probleme bei der Einbindung eines zweiten Homematic Adapters:
                        @automatix
                        Unauthorized
                          automatix @Samson71 last edited by
                          @samson71
                          habe die Firewall im Raspi komplett ausgemacht:
                          keine Änderung
                          der Zugriff über den Link geht:
                            hier der aktuelle Eintrag in der Logdatei:
                            2023-12-10 14:44:24.841  - debug: hm-rpc.2 (1277) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            2023-12-10 14:44:24.904  - debug: hm-rpc.2 (1277) Objects client ready ... initialize now
                            2023-12-10 14:44:24.909  - debug: hm-rpc.2 (1277) Objects create System PubSub Client
                            2023-12-10 14:44:24.912  - debug: hm-rpc.2 (1277) Objects create User PubSub Client
                            2023-12-10 14:44:24.971  - debug: hm-rpc.2 (1277) Objects client initialize lua scripts
                            2023-12-10 14:44:24.987  - debug: hm-rpc.2 (1277) Objects connected to redis: 127.0.0.1:9001
                            2023-12-10 14:44:25.038  - debug: hm-rpc.2 (1277) Redis States: Use Redis connection: 127.0.0.1:9000
                            2023-12-10 14:44:25.062  - debug: hm-rpc.2 (1277) States create System PubSub Client
                            2023-12-10 14:44:25.064  - debug: hm-rpc.2 (1277) States create User PubSub Client
                            2023-12-10 14:44:25.134  - debug: hm-rpc.2 (1277) States connected to redis: 127.0.0.1:9000
                            2023-12-10 14:44:25.200  - debug: hm-rpc.2 (1277) Plugin sentry Initialize Plugin (enabled=true)
                            2023-12-10 14:44:26.018  - info: hm-rpc.2 (1277) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.16
                            2023-12-10 14:44:26.230  - info: hm-rpc.2 (1277) xmlrpc server is trying to listen on 192.168.178.108:8081
                            2023-12-10 14:44:26.233  - info: hm-rpc.2 (1277) xmlrpc client is trying to connect to 192.168.178.46:2001/ with ["http://192.168.178.1:8081","iobroker:hm-rpc.2:a24f120b5aed6aac0b2e30891de7b91c"]
                            2023-12-10 14:44:26.235  - debug: hm-rpc.2 (1277) Connect...
                            2023-12-10 14:44:26.237  - debug: hm-rpc.2 (1277) xmlrpc -> 192.168.178.46:2001/ init ["http://192.168.178.1:8081","iobroker:hm-rpc.2:a24f120b5aed6aac0b2e30891de7b91c"]
                            2023-12-10 14:44:26.266  - debug: hm-rpc.2 (1277) start connecting interval
                            2023-12-10 14:44:26.309  - error: hm-rpc.2 (1277) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                            Zeile 16 / 17 liegt wohl der fehler, kann mir aber nicht erklären warum. Wenn ich dem Adapterpaar 2 die IP-Adresse des Adapterpaar 1 gebe und Adapterpaar 1 abschalte dann funktioniert es. Kann also nicht mit der Einstellung im Raspberrymatic zu tun haben.
                              automatix @automatix last edited by
                              @automatix
                              Der Schluss im letzten Satz stimmt nicht. Hat doch was mit der Rasperrymatic zu tun. Werde die mal neu aufsetzen.
                                @automatix
                                Ich habe jetzt die Raspberrymatic neu aufgesetzt und die Firewall wie folgt konfiguriert:
                                Jetzt funktionieren auch die neu hinzugekommenen Adapter für die zweite CCU. Danke für die Unterstützung und Geduld.
                                634
