Error Node-Red
Bei einem renomierten Verkäufer! Sowas kaufe ich nicht privat.
An den USB Ports hängt nichts dran. -
Die Stromversorgung wird aber nachhaltig bemängelt. Da stimmt was nicht.
Neben den anderen Baustellen... -
So Betriebssystem neu Bullseye in 64 bit iobroker neu installiert wie siehts denn jetzt aus !?======== Start marking the full check here ========= Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: GordonX-Home Icon name: computer Operating System: Raspbian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Model : Raspberry Pi 4 Model B Rev 1.1 Docker : false Virtualization : none Kernel : aarch64 Userland : armhf Systemuptime and Load: 11:44:25 up 18:55, 2 users, load average: 5.02, 3.60, 3.22 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: ~ Under-voltage detected ~ Arm frequency capped Previously detected issues: ~ Under-voltage has occurred ~ Arm frequency capping has occurred *** Time and Time Zones *** Local time: Sun 2023-12-10 11:44:26 CET Universal time: Sun 2023-12-10 10:44:26 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input render netdev lp admin gpio i2c spi iobroker *** X-Server-Setup *** X-Server: true Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 3.7G 1.9G 768M 1.0M 1.1G 1.8G Swap: 99M 0B 99M Total: 3.8G 1.9G 868M 3744 M total memory 1874 M used memory 2012 M active memory 727 M inactive memory 768 M free memory 111 M buffer memory 990 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 12G 16G 42% / devtmpfs devtmpfs 1.6G 0 1.6G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 749M 1.1M 748M 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 255M 51M 205M 20% /boot tmpfs tmpfs 375M 20K 375M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,ioc harset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 593M /var/ 202M /var/log 164M /var/lib 125M /var/cache 115M /var/cache/apt Archived and active journals take up 96.0M in the file system. /opt/iobroker/backups: 11M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 480M /opt/iobroker/iobroker-data/ 414M /opt/iobroker/iobroker-data/files 131M /opt/iobroker/iobroker-data/files/vis-2 76M /opt/iobroker/iobroker-data/files/vis-2/static 75M /opt/iobroker/iobroker-data/files/vis-2/static/js The five largest files in iobroker-data are: 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.m ap 23M /opt/iobroker/iobroker-data/objects.jsonl 21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.m ap 21M /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.6c01 4a31.js.map 18M /opt/iobroker/iobroker-data/files/vis-2/static/js/main.3d92bcec.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': find: '/dev/serial/by-id/': No such file or directory *** NodeJS-Installation *** /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.0-1nodesource1 Candidate: 18.19.0-1nodesource1 Version table: *** 18.19.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.18.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 12.22.12~dfsg-1~deb11u4 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package s Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.16 admin: 6.12.0 javascript: 7.1.6 Adapters from github: 0 Adapter State + system.adapter.admin.0 : admin : GordonX-Home - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as : admin + system.adapter.alarm.0 : alarm : GordonX-Home - enabled + system.adapter.alexa-timer-vis.0 : alexa-timer-vis : GordonX-Home - enabled + system.adapter.alexa2.0 : alexa2 : GordonX-Home - enabled + system.adapter.backitup.0 : backitup : GordonX-Home - enabled system.adapter.daswetter.0 : daswetter : GordonX-Home - enabled + system.adapter.discovery.0 : discovery : GordonX-Home - enabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : GordonX-Home - enabled system.adapter.flot.0 : flot : GordonX-Home - enabled + system.adapter.fritzbox.0 : fritzbox : GordonX-Home - enabled + system.adapter.fritzdect.0 : fritzdect : GordonX-Home - enabled + system.adapter.fullcalendar.0 : fullcalendar : GordonX-Home - enabled system.adapter.fullybrowser.0 : fullybrowser : GordonX-Home - disabled + system.adapter.harmony.0 : harmony : GordonX-Home - enabled system.adapter.hass.0 : hass : GordonX-Home - disabled, port: 8123 + system.adapter.history.0 : history : GordonX-Home - enabled + system.adapter.hue.0 : hue : GordonX-Home - enabled, port: 443 system.adapter.ical.0 : ical : GordonX-Home - enabled system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: Gor donX-Home - enabled system.adapter.icons-icons8.0 : icons-icons8 : GordonX-Home - enabled system.adapter.influxdb.0 : influxdb : GordonX-Home - disabled, port: 8086 + system.adapter.iot.0 : iot : GordonX-Home - enabled + system.adapter.javascript.0 : javascript : GordonX-Home - enabled + system.adapter.node-red.0 : node-red : GordonX-Home - enabled, port: 1880, bind: 0.0.0.0 system.adapter.octoprint.0 : octoprint : GordonX-Home - disabled system.adapter.owfs.0 : owfs : GordonX-Home - disabled, port: 4304 + system.adapter.roborock.0 : roborock : GordonX-Home - enabled + system.adapter.rpi2.0 : rpi2 : GordonX-Home - enabled + system.adapter.smartthings.0 : smartthings : GordonX-Home - enabled + system.adapter.sql.0 : sql : GordonX-Home - enabled, port: 3307 + system.adapter.synology.0 : synology : GordonX-Home - enabled, port: 5001 + system.adapter.telegram-menu.0 : telegram-menu : GordonX-Home - enabled + system.adapter.telegram.0 : telegram : GordonX-Home - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : GordonX-Home - enabled + system.adapter.tr-064.0 : tr-064 : GordonX-Home - enabled + system.adapter.tuya.0 : tuya : GordonX-Home - enabled + system.adapter.vis-2.0 : vis-2 : GordonX-Home - enabled system.adapter.vis-bars.0 : vis-bars : GordonX-Home - enabled system.adapter.vis-colorpicker.0 : vis-colorpicker : GordonX-Home - enabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : GordonX-Home - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : GordonX-Home - enabled system.adapter.vis-icontwo.0 : vis-icontwo : GordonX-Home - enabled + system.adapter.vis-inventwo.0 : vis-inventwo : GordonX-Home - enabled system.adapter.vis.0 : vis : GordonX-Home - disabled + system.adapter.web.0 : web : GordonX-Home - enabled, port: 8082, bind: 0.0.0.0, run as: admi n + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : GordonX-Home - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin + system.adapter.hue.0 : hue : GordonX-Home - enabled, port: 443 + system.adapter.node-red.0 : node-red : GordonX-Home - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.sql.0 : sql : GordonX-Home - enabled, port: 3307 + system.adapter.synology.0 : synology : GordonX-Home - enabled, port: 5001 + system.adapter.telegram.0 : telegram : GordonX-Home - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : GordonX-Home - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.12.0 , installed 6.12.0 Adapter "alarm" : 3.4.3 , installed 3.4.3 Adapter "alexa-timer-vis": 0.2.0 , installed 0.2.0 Adapter "alexa2" : 3.26.3 , installed 3.26.3 Adapter "backitup" : 2.8.7 , installed 2.8.7 Adapter "daswetter" : 3.1.11 , installed 3.1.10 [Updatable] Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "fb-checkpresence": 1.2.2 , installed 1.2.2 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fritzbox" : 0.5.0 , installed 0.5.0 Adapter "fritzdect" : 2.5.9 , installed 2.3.1 [Updatable] Adapter "fullcalendar" : 2.2.6 , installed 2.2.6 Adapter "fullybrowser" : 3.0.6 , installed 3.0.6 Adapter "harmony" : 1.3.0 , installed 1.3.0 Adapter "hass" : 1.4.0 , installed 1.4.0 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "hue" : 3.10.1 , installed 3.10.1 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "influxdb" : 3.2.0 , installed 3.2.0 Adapter "iot" : 2.0.11 , installed 2.0.11 Adapter "javascript" : 7.1.6 , installed 7.1.6 Controller "js-controller": 5.0.16 , installed 5.0.16 Adapter "node-red" : 4.0.3 , installed 4.0.3 Adapter "octoprint" : 5.1.0 , installed 5.1.0 Adapter "owfs" : 0.7.0 , installed 0.7.0 Adapter "roborock" : 0.4.4 , installed 0.4.4 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartthings" : 0.0.4 , installed 0.0.4 Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "sql" : 2.2.0 , installed 2.2.0 Adapter "synology" : 3.0.1 , installed 3.0.1 Adapter "telegram" : 3.0.0 , installed 3.0.0 Adapter "telegram-menu": 0.8.5 , installed 0.8.5 Adapter "text2command" : 3.0.2 , installed 3.0.2 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "tuya" : 3.14.2 , installed 3.14.2 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-icontwo" : 0.98.0 , installed 0.98.0 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "web" : 6.1.10 , installed 6.1.10 Adapter "ws" : 2.5.8 , installed 2.5.8 Objects and States Please stand by - This may take a while Objects: 15236 States: 11961 *** OS-Repositories and Updates *** W: GPG error: https://repos.influxdata.com/ubuntu bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E E: The repository 'https://repos.influxdata.com/ubuntu bullseye InRelease' is not signed. Pending Updates: 1 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 118 163682 8961/influxd tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1001 24810 1640/node-red tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 16623 559/iobroker.js-con tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 18433 559/iobroker.js-con tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 15629 592/sshd: /usr/sbin tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 995325 26097/cupsd tcp6 0 0 ::1:631 :::* LISTEN 0 995324 26097/cupsd tcp6 0 0 :::8082 :::* LISTEN 1001 278145 15570/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 23200 1123/io.admin.0 tcp6 0 0 :::8086 :::* LISTEN 118 161441 8961/influxd tcp6 0 0 :::22 :::* LISTEN 0 14142 592/sshd: /usr/sbin tcp6 0 0 :::4369 :::* LISTEN 0 13802 1/init tcp6 0 0 :::61991 :::* LISTEN 1001 22479 1894/io.harmony.0 udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 27656 1579/io.tuya.0 udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 27657 1579/io.tuya.0 udp 0 0 0.0.0.0:61991 0.0.0.0:* 1001 22480 1894/io.harmony.0 udp 0 0 0.0.0.0:631 0.0.0.0:* 0 998442 26103/cups-browsed udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 115551 6077/avahi-daemon: udp 0 0 0.0.0.0:48483 0.0.0.0:* 108 115553 6077/avahi-daemon: udp 0 0 0.0.0.0:68 0.0.0.0:* 0 15683 483/dhcpcd udp6 0 0 :::546 :::* 0 14328 483/dhcpcd udp6 0 0 :::33783 :::* 108 115554 6077/avahi-daemon: udp6 0 0 :::5353 :::* 108 115552 6077/avahi-daemon: *** Log File - Last 25 Lines *** 2023-12-10 11:48:18.453 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpBlue.png": Error: Not exists 2023-12-10 11:48:18.680 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpPicsHorz.png": Error: Not exists 2023-12-10 11:48:18.776 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpPicsHorzDockClosed.png": Error: Not exists 2023-12-10 11:48:19.281 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpPicsHorzDockOpen.png": Error: Not exists 2023-12-10 11:48:19.744 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpPicsVert.png": Error: Not exists 2023-12-10 11:48:19.977 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpRed.png": Error: Not exists 2023-12-10 11:48:20.360 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpTextHorz.png": Error: Not exists 2023-12-10 11:48:20.789 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpTextVert.png": Error: Not exists 2023-12-10 11:48:21.010 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpTransp.png": Error: Not exists 2023-12-10 11:48:21.537 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/inject-bottom.png": Error: Not exists 2023-12-10 11:48:21.780 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/inject-left.png": Error: Not exists 2023-12-10 11:48:21.969 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/inject-right.png": Error: Not exists 2023-12-10 11:48:21.992 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/inject-top.png": Error: Not exists 2023-12-10 11:48:22.066 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/js/bars.js": Error: Not exists 2023-12-10 11:48:22.087 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/js/jquery.sidebar.js": Error: Not exists 2023-12-10 11:48:22.145 - error: vis-2.0 (12624) Cannot delete file "/widgets/bars.html": Error: Not exists 2023-12-10 11:48:22.187 - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/css/table.css": Error: Not exists 2023-12-10 11:48:22.201 - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/doc.html": Error: Not exists 2023-12-10 11:48:22.475 - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_AckBool.png": Error: Not exists 2023-12-10 11:48:22.524 - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_BasicState.png": Error: Not exists 2023-12-10 11:48:22.775 - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_BulbOnOffCtrl.png": Error: Not exists 2023-12-10 11:48:23.063 - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_ContainerView.png": Error: Not exists 2023-12-10 11:48:23.385 - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_FilterDropdown.png": Error: Not exists 2023-12-10 11:48:23.834 - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_FullScreen.png": Error: Not exists 2023-12-10 11:48:24.156 - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_HTML.png": Error: Not exists ============ Mark until here for C&P =============
oder sollte ich doch ein neues Netzteil kaufen !? Das jetzige ist extra für den Pi4 gekauft und hat 3A aber vllt hat es auch in der Technik gelitten als es im Unterschrank vom Meerwasser Aquarium gesteckt hatte. Es war zwar die Technik abgeschirmt mit einer Acryl Platte aber die Meer Luft ist ja trotzdem im Raum die sogar dazu geführt hatte das ich die Pi Lüfter regelmäßig jedes Jahr tauschen musste da diese durch Slaz Luft verklebt waren.
@aphofis sagte in Error Node-Red:
Spannungsversorgung immer noch schlapp.
also neues Netzteil -
Bullseye in 64 bit
Nö, das ist noch ein Mix aus 64bit-Kernel und 32bit-Userland.
Ich hatte alles komplett neu aufgesetzt -
zu hoch für 4 Kerne.
Graphisches Gedönse ausschalten...
Ich dachte du hättest die Kiste neuaufgesetzt... Warum dann nicht gleich gescheit?
Hab ich doch!
Nur wenn ein Touchscreen Display dran kommt brauche ich doch grafische unterstützung -
Das stimmt. Der Rest ist aber dann immer noch schief.
Das influx-Repo ist auch nicht richtig angelegt.
