*Gelöst* Adapter Install für Telegram funktioniert nicht.
@thomas-braun Here we are
======== Start marking the full check here ========= Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: iobrokermaster Icon name: computer Operating System: Raspbian GNU/Linux 11 (bullseye) Kernel: Linux 5.10.103-v7l+ Architecture: arm Model : Raspberry Pi 4 Model B Rev 1.4 Docker : false Virtualization : none Kernel : armv7l Userland : armhf Systemuptime and Load: 12:07:03 up 2:25, 1 user, load average: 1.97, 1.78, 1.65 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Sun 2023-12-10 12:07:03 CET Universal time: Sun 2023-12-10 11:07:03 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 7.9G 2.1G 4.8G 0.0K 948M 5.5G Swap: 99M 0B 99M Total: 8.0G 2.1G 4.9G 7897 M total memory 2101 M used memory 377 M active memory 2505 M inactive memory 4847 M free memory 154 M buffer memory 794 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * lightdm.service loaded failed failed Light Display Manager LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 110G 20G 86G 19% / devtmpfs devtmpfs 3.7G 0 3.7G 0% /dev tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 1.6G 860K 1.6G 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/sda1 vfat 253M 49M 204M 20% /boot tmpfs tmpfs 790M 20K 790M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Sun Dec 10 09:41:47 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=DC:A6:32:EE:30:6C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles [Sun Dec 10 09:41:49 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null) [Sun Dec 10 09:41:49 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [Sun Dec 10 09:41:51 2023] EXT4-fs (sda2): re-mounted. Opts: (null) Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime `-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro Files in neuralgic directories: /var: 4.9G /var/ 3.9G /var/cache 3.8G /var/cache/apt/archives 3.8G /var/cache/apt 821M /var/log Archived and active journals take up 808.0M in the file system. /opt/iobroker/backups: 15M /opt/iobroker/backups/ 2.8M /opt/iobroker/backups/scripte 2.4M /opt/iobroker/backups/scripte/Meine_Geräte 312K /opt/iobroker/backups/scripte/Meine_Geräte/Temp_Ansagen 284K /opt/iobroker/backups/scripte/Test /opt/iobroker/iobroker-data: 4.9G /opt/iobroker/iobroker-data/ 4.2G /opt/iobroker/iobroker-data/history 454M /opt/iobroker/iobroker-data/files 191M /opt/iobroker/iobroker-data/backup-objects 90M /opt/iobroker/iobroker-data/files/echarts.admin The five largest files in iobroker-data are: 40M /opt/iobroker/iobroker-data/objects.jsonl 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map 24M /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map 24M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map 24M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': find: '/dev/serial/by-id/': No such file or directory *** NodeJS-Installation *** /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.0-1nodesource1 Candidate: 18.19.0-1nodesource1 Version table: *** 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 12.22.12~dfsg-1~deb11u4 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: npm ERR! code ELSPROBLEMS npm ERR! invalid: iobroker.alexa2@3.26.3 /opt/iobroker/node_modules/iobroker.alexa2 npm ERR! invalid: iobroker.cameras@1.3.0 /opt/iobroker/node_modules/iobroker.cameras npm ERR! invalid: iobroker.fully-tablet-control@0.3.6-1 /opt/iobroker/node_modules/iobroker.fully-tablet-control npm ERR! invalid: iobroker.homepilot20@0.0.32 /opt/iobroker/node_modules/iobroker.homepilot20 npm ERR! invalid: iobroker.vis-materialdesign@0.5.94 /opt/iobroker/node_modules/iobroker.vis-materialdesign npm ERR! invalid: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor npm ERR! invalid: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5 npm ERR! invalid: string_decoder@1.3.0 /opt/iobroker/node_modules/string_decoder npm ERR! invalid: ms@2.0.0 /opt/iobroker/node_modules/ms npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents npm ERR! missing: cli@0.4.x, required by ipv6@3.1.1 npm ERR! missing: cliff@0.1.x, required by ipv6@3.1.1 npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-10T11_07_13_165Z-debug-0.log *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: redis Core adapters versions js-controller: 5.0.16 admin: 6.12.0 javascript: 7.1.6 npm ERR! code ELSPROBLEMS npm ERR! invalid: iobroker.alexa2@3.26.3 /opt/iobroker/node_modules/iobroker.alexa2 npm ERR! invalid: iobroker.cameras@1.3.0 /opt/iobroker/node_modules/iobroker.cameras npm ERR! invalid: iobroker.fully-tablet-control@0.3.6-1 /opt/iobroker/node_modules/iobroker.fully-tablet-control npm ERR! invalid: iobroker.homepilot20@0.0.32 /opt/iobroker/node_modules/iobroker.homepilot20 npm ERR! invalid: iobroker.vis-materialdesign@0.5.94 /opt/iobroker/node_modules/iobroker.vis-materialdesign npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-10T11_07_36_329Z-debug-0.log Adapters from github: 4 Adapter State + system.adapter.admin.2 : admin : iobrokermaster - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : iobrokermaster - enabled + system.adapter.alexa2.1 : alexa2 : iobrokermaster - enabled + system.adapter.awtrix-light.0 : awtrix-light : iobrokermaster - enabled + system.adapter.backitup.0 : backitup : iobrokermaster - enabled + system.adapter.broadlink2.0 : broadlink2 : iobrokermaster - enabled system.adapter.cloud.0 : cloud : iobrokermaster - disabled + system.adapter.device-reminder.0 : device-reminder : iobrokermaster - enabled system.adapter.discovery.0 : discovery : iobrokermaster - disabled system.adapter.dwd.0 : dwd : iobrokermaster - enabled + system.adapter.echarts.0 : echarts : iobrokermaster - enabled + system.adapter.email.0 : email : iobrokermaster - enabled system.adapter.flot.0 : flot : iobrokermaster - enabled + system.adapter.fully-tablet-control.0 : fully-tablet-control : iobrokermaster - enabled + system.adapter.fullybrowser.0 : fullybrowser : iobrokermaster - enabled system.adapter.harmony.0 : harmony : iobrokermaster - disabled + system.adapter.history.0 : history : iobrokermaster - enabled + system.adapter.homepilot20.0 : homepilot20 : iobrokermaster - enabled + system.adapter.hue-extended.0 : hue-extended : iobrokermaster - enabled system.adapter.hue.0 : hue : iobrokermaster - disabled, port: 443 system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobrokermaster - enabled + system.adapter.info.0 : info : iobrokermaster - enabled + system.adapter.iot.0 : iot : iobrokermaster - enabled + system.adapter.jarvis.0 : jarvis : iobrokermaster - enabled + system.adapter.javascript.0 : javascript : iobrokermaster - enabled + system.adapter.meross.0 : meross : iobrokermaster - enabled system.adapter.mobile.0 : mobile : iobrokermaster - disabled + system.adapter.mqtt.0 : mqtt : iobrokermaster - enabled, port: 1883, bind: 0.0.0.0 system.adapter.nina.0 : nina : iobrokermaster - disabled + system.adapter.parser.0 : parser : iobrokermaster - enabled + system.adapter.ping.0 : ping : iobrokermaster - enabled + system.adapter.psa.0 : psa : iobrokermaster - enabled + system.adapter.pushover.1 : pushover : iobrokermaster - enabled + system.adapter.simple-api.0 : simple-api : iobrokermaster - enabled, port: 8099, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : iobrokermaster - enabled, port: 1893, bind: 0.0.0.0 + system.adapter.sourceanalytix.0 : sourceanalytix : iobrokermaster - enabled system.adapter.starline.0 : starline : iobrokermaster - disabled + system.adapter.tankerkoenig.0 : tankerkoenig : iobrokermaster - enabled + system.adapter.telegram.0 : telegram : iobrokermaster - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : iobrokermaster - enabled + system.adapter.tr-064.0 : tr-064 : iobrokermaster - enabled system.adapter.tuya.0 : tuya : iobrokermaster - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : iobrokermaster - enabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : iobrokermaster - enabled system.adapter.vis-history.0 : vis-history : iobrokermaster - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobrokermaster - enabled + system.adapter.vis-inventwo.0 : vis-inventwo : iobrokermaster - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobrokermaster - enabled system.adapter.vis-keyboard.0 : vis-keyboard : iobrokermaster - enabled system.adapter.vis-map.0 : vis-map : iobrokermaster - enabled system.adapter.vis-material-advanced.0 : vis-material-advanced : iobrokermaster - enabled system.adapter.vis-material.0 : vis-material : iobrokermaster - enabled system.adapter.vis-materialdesign.0 : vis-materialdesign : iobrokermaster - enabled system.adapter.vis-metro.0 : vis-metro : iobrokermaster - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobrokermaster - enabled system.adapter.vis.0 : vis : iobrokermaster - enabled + system.adapter.web.0 : web : iobrokermaster - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.yr.0 : yr : iobrokermaster - enabled + system.adapter.zigbee.0 : zigbee : iobrokermaster - enabled, port: /dev/ttyACM0 + instance is alive Enabled adapters with bindings + system.adapter.admin.2 : admin : iobrokermaster - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.mqtt.0 : mqtt : iobrokermaster - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : iobrokermaster - enabled, port: 8099, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : iobrokermaster - enabled, port: 1893, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : iobrokermaster - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : iobrokermaster - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobrokermaster - enabled, port: /dev/ttyACM0 ioBroker-Repositories Stable (default): http://download.iobroker.net/sources-dist.json Beta (latest) : http://download.iobroker.net/sources-dist-latest.json Active repo(s): Stable (default) Installed ioBroker-Instances Used repository: Stable (default) Adapter "admin" : 6.12.0 , installed 6.12.0 Adapter "alexa2" : 3.26.3 , installed 3.26.3 Adapter "awtrix-light" : 0.10.0 , installed 0.10.0 Adapter "backitup" : 2.8.7 , installed 2.8.7 Adapter "broadlink2" : 2.1.5 , installed 2.1.5 Adapter "cloud" : 4.4.1 , installed 4.4.1 Adapter "device-reminder": 3.0.0 , installed 3.0.0 Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 1.5.4 , installed 1.5.4 Adapter "email" : 1.2.0 , installed 1.2.0 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fullybrowser" : 3.0.6 , installed 3.0.6 Adapter "harmony" : 1.3.0 , installed 1.3.0 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "hue" : 3.10.1 , installed 3.10.1 Adapter "hue-extended" : 2.0.0 , installed 2.0.0 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "info" : 2.0.0 , installed 2.0.0 Adapter "iot" : 2.0.11 , installed 2.0.11 Adapter "jarvis" : 3.1.8 , installed 3.1.8 Adapter "javascript" : 7.1.6 , installed 7.1.6 Controller "js-controller": 5.0.16 , installed 5.0.16 Adapter "meross" : 1.15.1 , installed 1.15.1 Adapter "mobile" : 1.0.1 , installed 1.0.1 Adapter "mqtt" : 5.1.0 , installed 5.1.0 Adapter "nina" : 0.0.25 , installed 0.0.25 Adapter "parser" : 2.0.7 , installed 2.0.7 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "proxy" : 1.3.2 , installed 1.3.2 Adapter "psa" : 0.0.11 , installed 0.0.12 Adapter "pushover" : 3.0.3 , installed 3.0.3 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "sonoff" : 3.0.3 , installed 3.0.3 Adapter "starline" : 1.1.3 , installed 1.1.3 Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7 Adapter "telegram" : 3.0.0 , installed 2.0.1 [Updatable] Adapter "text2command" : 3.0.2 , installed 3.0.2 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "tuya" : 3.14.2 , installed 3.14.2 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-keyboard" : 0.0.2 , installed 0.0.2 Adapter "vis-map" : 1.0.4 , installed 1.0.4 Adapter "vis-material" : 0.1.3 , installed 0.1.3 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "web" : 6.1.10 , installed 6.1.10 Adapter "ws" : 2.5.8 , installed 2.5.8 Adapter "yr" : 5.3.0 , installed 5.3.0 Adapter "zigbee" : 1.8.24 , installed 1.8.24 Objects and States Please stand by - This may take a while Objects: 25038 States: 20414 *** OS-Repositories and Updates *** Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:8400 0.0.0.0:* LISTEN 1001 21419 2373/io.jarvis.0 tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 14404 493/sshd: /usr/sbin tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 14379 467/cupsd tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 14264 1104/io.mqtt.0 tcp 0 0 0.0.0.0:1893 0.0.0.0:* LISTEN 1001 14175 1028/io.sonoff.0 tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 14588 545/iobroker.js-con tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 116 10816 478/redis-server 12 tcp6 0 0 :::8081 :::* LISTEN 1001 14869 698/io.admin.2 tcp6 0 0 :::8082 :::* LISTEN 1001 14280 1119/io.web.0 tcp6 0 0 :::22 :::* LISTEN 0 14406 493/sshd: /usr/sbin tcp6 0 0 ::1:631 :::* LISTEN 0 14378 467/cupsd tcp6 0 0 :::3000 :::* LISTEN 1001 23143 2121/io.fullybrowse tcp6 0 0 :::8099 :::* LISTEN 1001 23516 2434/io.simple-api. tcp6 0 0 ::1:6379 :::* LISTEN 116 10817 478/redis-server 12 udp 0 0 0.0.0.0:36256 0.0.0.0:* 1001 21786 1613/io.broadlink2. udp 0 0 0.0.0.0:60987 0.0.0.0:* 1001 20598 1613/io.broadlink2. udp 0 0 0.0.0.0:68 0.0.0.0:* 0 12157 769/dhcpcd udp 0 0 0.0.0.0:631 0.0.0.0:* 0 13626 496/cups-browsed udp 0 0 0.0.0.0:15001 0.0.0.0:* 1001 20595 1613/io.broadlink2. udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 13504 364/avahi-daemon: r udp 0 0 0.0.0.0:48526 0.0.0.0:* 108 13506 364/avahi-daemon: r udp6 0 0 :::57783 :::* 108 13507 364/avahi-daemon: r udp6 0 0 :::546 :::* 0 12169 769/dhcpcd udp6 0 0 :::5353 :::* 108 13505 364/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-12-10 11:45:16.113 - info: host.iobrokermaster iobroker upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript 2023-12-10 11:45:17.155 - info: host.iobrokermaster iobroker exit 0 2023-12-10 11:45:50.171 - info: host.iobrokermaster Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json" 2023-12-10 11:51:57.166 - info: javascript.0 (915) script.js.Meine_Geraete.Astrotag_Night: neue Tagezeit: Mittag 2023-12-10 11:51:57.168 - info: javascript.0 (915) script.js.Meine_Geraete.Astrotag_Night: nächste kommende Tagezeit: Nachmittag 2023-12-10 11:59:00.603 - info: host.iobrokermaster instance system.adapter.yr.0 started with pid 24957 2023-12-10 11:59:48.870 - info: host.iobrokermaster instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-12-10 12:00:00.541 - info: host.iobrokermaster instance system.adapter.dwd.0 started with pid 27411 2023-12-10 12:00:04.590 - info: dwd.0 (27411) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.16 2023-12-10 12:00:07.822 - info: dwd.0 (27411) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2023-12-10 12:00:08.373 - info: host.iobrokermaster instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-12-10 12:01:00.059 - info: tankerkoenig.0 (1720) Scheduled restart. 2023-12-10 12:01:00.066 - info: tankerkoenig.0 (1720) terminating 2023-12-10 12:01:00.069 - info: tankerkoenig.0 (1720) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-12-10 12:01:00.576 - info: tankerkoenig.0 (1720) terminating 2023-12-10 12:01:00.623 - warn: tankerkoenig.0 (1720) Could not perform strict object check of state tankerkoenig.0.stations.adapterStatus: DB closed 2023-12-10 12:01:01.210 - info: host.iobrokermaster instance system.adapter.tankerkoenig.0 scheduled normal terminated and will be restarted on schedule. 2023-12-10 12:01:01.212 - info: host.iobrokermaster Restart adapter system.adapter.tankerkoenig.0 because enabled 2023-12-10 12:01:02.478 - info: host.iobrokermaster instance system.adapter.tankerkoenig.0 started with pid 29149 2023-12-10 12:01:06.161 - info: tankerkoenig.0 (29149) starting. Version 3.3.7 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v18.19.0, js-controller: 5.0.16 2023-12-10 12:01:06.405 - info: tankerkoenig.0 (29149) Adapter is already in daemon mode 2023-12-10 12:01:06.407 - info: tankerkoenig.0 (29149) Sync time set to 30 minutes or 1800000 ms 2023-12-10 12:01:14.416 - info: tankerkoenig.0 (29149) Start first request 2023-12-10 12:07:40.619 - info: javascript.0 (915) script.js.Meine_Geraete.Bewegung_Speisekammer: Speisekammer offen 2023-12-10 12:08:22.271 - info: javascript.0 (915) script.js.common.Lichtauswertung: Speisekammer Licht ausgeschaltet. ============ Mark until here for C&P ============= iob diag has finished.
sudo systemctl set-default multi-user.target
Installier diese Adapter nochmal (oder schmeiß sie raus):
was bewirkt das sudo systemctl set-default multi-user.target -
Das bewirkt, das die Meldung mit dem nicht startenden Service lightdm.service verschwindet.
@thomas-braun Ok dann installiere ich diese Adapter noch einmal. Ist es besser sie vorher zu deinstallieren?
@bibo-13 sagte in Adapter Install für Telegram funktioniert nicht.:
Nein. Einfach drüber installieren. Kommen die alle aus dem github? Werden die überhaupt verwendet?
@thomas-braun ja bis auf cameras sind alle aktiv
Den ersten Adapter Alexa2 ausprobiert das gleiche mit den NPM Errorshost.iobrokermaster 2023-12-10 12:37:47.757 info stopInstance system.adapter.alexa2.0 send kill signal host.iobrokermaster 2023-12-10 12:37:47.747 info stopInstance system.adapter.alexa2.0 (force=false, process=true) host.iobrokermaster 2023-12-10 12:37:47.630 info iobroker Update "system.adapter.alexa2.0" host.iobrokermaster 2023-12-10 12:37:47.348 info iobroker npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-10T11_34_11_619Z-debug-0.log host.iobrokermaster 2023-12-10 12:37:47.341 info iobroker npm ERR! notsup Unsupported platform for @img/sharp-win32-x64@0.33.0: wanted {"os":"win32","cpu":"x64"} (current: {"os":"linux","cpu":"arm"})npm ERR! notsup Valid os: win32npm ERR! notsup Actual os: linuxnpm ERR! notsup Valid cpu: x64npm ERR! notsup Actual cpu: arm host.iobrokermaster 2023-12-10 12:37:47.330 info iobroker npm ERR! code EBADPLATFORM host.iobrokermaster 2023-12-10 12:34:10.135 info iobroker NPM version: 10.2.3Installing iobroker.alexa2@3.26.3... (System call) host.iobrokermaster 2023-12-10 12:34:08.453 info iobroker Update alexa2 from @3.26.3 to @3.26.3 host.iobrokermaster 2023-12-10 12:34:04.202 info iobroker upgrade alexa2@3.26.3 --debug
Die Meldungen kommen ja auch nicht von dem Adapter, die hängen da generell in der Pipeline.
Ist die 'invalid'-Eintragung denn jetzt weg? -
ja bis auf da bin ich noch dran. Aber keine Ahnung was cli socksv5 oder cliff sein sein:
Errors in npm tree: npm ERR! code ELSPROBLEMS npm ERR! invalid: iobroker.homepilot20@0.0.32 /opt/iobroker/node_modules/iobroker.homepilot20 npm ERR! invalid: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5 npm ERR! missing: cli@0.4.x, required by ipv6@3.1.1 npm ERR! missing: cliff@0.1.x, required by ipv6@3.1.1
So der Homepilot20 invalid ist jetzt auch weg.
was kann/muß ich jetzt noch machen? -
Hier bitte:pi@iobrokermaster:~ $ cd /opt/iobroker pi@iobrokermaster:/opt/iobroker $ npm ls iobroker.inst@2.0.3 /opt/iobroker ├── colors@1.4.0 ├── fs-extra@7.0.1 ├── iobroker.admin@6.12.0 ├── iobroker.alexa2@3.26.1 ├── iobroker.awtrix-light@0.10.0 ├── iobroker.backitup@2.8.7 ├── iobroker.broadlink2@2.1.5 ├── iobroker.cloud@4.4.1 ├── iobroker.device-reminder@3.0.0 ├── iobroker.discovery@4.2.0 ├── iobroker.dwd@2.8.5 ├── iobroker.echarts@1.5.4 ├── iobroker.email@1.2.0 ├── iobroker.flot@1.12.0 ├── iobroker.fully-tablet-control@0.3.8 ├── iobroker.fullybrowser@3.0.6 ├── iobroker.harmony@1.3.0 ├── iobroker.history@3.0.1 ├── iobroker.homepilot20@0.0.48 ├── iobroker.hue-extended@2.0.0 ├── iobroker.hue@3.10.1 ├── iobroker.icons-mfd-svg@1.1.0 ├── iobroker.info@2.0.0 ├── iobroker.iot@2.0.11 ├── iobroker.jarvis@3.1.8 ├── iobroker.javascript@7.1.6 ├── iobroker.js-controller@5.0.16 ├── iobroker.meross@1.15.1 ├── iobroker.mobile@1.0.1 ├── iobroker.mqtt@5.1.0 ├── iobroker.nina@0.0.25 ├── iobroker.parser@2.0.7 ├── iobroker.ping@1.6.2 ├── iobroker.proxy@1.3.2 ├── iobroker.psa@0.0.12 ├── iobroker.pushover@3.0.3 ├── iobroker.rpi2@1.3.2 ├── iobroker.simple-api@2.7.2 ├── iobroker.socketio@6.6.0 ├── iobroker.sonoff@3.0.3 ├── iobroker.sourceanalytix@0.4.14 ├── iobroker.starline@1.1.3 ├── iobroker.tankerkoenig@3.3.7 ├── iobroker.telegram@2.0.1 ├── iobroker.text2command@3.0.2 ├── iobroker.tr-064@4.2.18 ├── iobroker.tuya@3.14.2 ├── iobroker.vis-colorpicker@2.0.3 ├── iobroker.vis-fancyswitch@1.1.0 ├── iobroker.vis-history@1.0.0 ├── iobroker.vis-hqwidgets@1.4.0 ├── iobroker.vis-inventwo@3.3.3 ├── iobroker.vis-jqui-mfd@1.0.12 ├── iobroker.vis-keyboard@0.0.2 ├── iobroker.vis-map@1.0.4 ├── iobroker.vis-material-advanced@1.7.4 ├── iobroker.vis-material@0.1.3 ├── iobroker.vis-metro@1.2.0 ├── iobroker.vis-timeandweather@1.2.2 ├── iobroker.vis@1.4.16 ├── iobroker.web@6.1.10 ├── iobroker.ws@2.5.8 ├── iobroker.yr@5.3.0 ├── iobroker.zigbee@1.8.24 ├── iobroker@2.0.3 ├── semver@5.7.2 └── yargs@7.1.2
Hier bitte:pi@iobrokermaster:/opt/iobroker $ iob update Used repository: Stable (default) Adapter "admin" : 6.12.0 , installed 6.12.0 Adapter "alexa2" : 3.26.3 , installed 3.26.1 [Updatable] Adapter "awtrix-light" : 0.10.0 , installed 0.10.0 Adapter "backitup" : 2.8.7 , installed 2.8.7 Adapter "broadlink2" : 2.1.5 , installed 2.1.5 Adapter "cloud" : 4.4.1 , installed 4.4.1 Adapter "device-reminder": 3.0.0 , installed 3.0.0 Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 1.5.4 , installed 1.5.4 Adapter "email" : 1.2.0 , installed 1.2.0 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fullybrowser" : 3.0.6 , installed 3.0.6 Adapter "harmony" : 1.3.0 , installed 1.3.0 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "hue" : 3.10.1 , installed 3.10.1 Adapter "hue-extended" : 2.0.0 , installed 2.0.0 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "info" : 2.0.0 , installed 2.0.0 Adapter "iot" : 2.0.11 , installed 2.0.11 Adapter "jarvis" : 3.1.8 , installed 3.1.8 Adapter "javascript" : 7.1.6 , installed 7.1.6 Controller "js-controller": 5.0.16 , installed 5.0.16 Adapter "meross" : 1.15.1 , installed 1.15.1 Adapter "mobile" : 1.0.1 , installed 1.0.1 Adapter "mqtt" : 5.1.0 , installed 5.1.0 Adapter "nina" : 0.0.25 , installed 0.0.25 Adapter "parser" : 2.0.7 , installed 2.0.7 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "proxy" : 1.3.2 , installed 1.3.2 Adapter "psa" : 0.0.11 , installed 0.0.12 Adapter "pushover" : 3.0.3 , installed 3.0.3 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "sonoff" : 3.0.3 , installed 3.0.3 Adapter "starline" : 1.1.3 , installed 1.1.3 Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7 Adapter "telegram" : 3.0.0 , installed 2.0.1 [Updatable] Adapter "text2command" : 3.0.2 , installed 3.0.2 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "tuya" : 3.14.2 , installed 3.14.2 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-keyboard" : 0.0.2 , installed 0.0.2 Adapter "vis-map" : 1.0.4 , installed 1.0.4 Adapter "vis-material" : 0.1.3 , installed 0.1.3 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "web" : 6.1.10 , installed 6.1.10 Adapter "ws" : 2.5.8 , installed 2.5.8 Adapter "yr" : 5.3.0 , installed 5.3.0 Adapter "zigbee" : 1.8.24 , installed 1.8.24
iob upgrade all -y --debug
Ok telegram ist durch ohne probleme -
