    4. *Gelöst* Adapter Install für Telegram funktioniert nicht.
      Bibo*13 @Thomas Braun last edited by
      @thomas-braun Here we are
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: iobrokermaster
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       12:07:03 up  2:25,  1 user,  load average: 1.97, 1.78, 1.65
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sun 2023-12-10 12:07:03 CET
                 Universal time: Sun 2023-12-10 11:07:03 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.9G        2.1G        4.8G        0.0K        948M        5.5G
      Swap:            99M          0B         99M
      Total:          8.0G        2.1G        4.9G
               7897 M total memory
               2101 M used memory
                377 M active memory
               2505 M inactive memory
               4847 M free memory
                154 M buffer memory
                794 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT            LOAD   ACTIVE SUB    DESCRIPTION
      * lightdm.service loaded failed failed Light Display Manager
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4      110G   20G   86G  19% /
      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  860K  1.6G   1% /run
      /dev/sda1      vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     790M   20K  790M   1% /run/user/1000
      [Sun Dec 10 09:41:47 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:EE:30:6C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Sun Dec 10 09:41:49 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      [Sun Dec 10 09:41:49 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Sun Dec 10 09:41:51 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      4.9G    /var/
      3.9G    /var/cache
      3.8G    /var/cache/apt/archives
      3.8G    /var/cache/apt
      821M    /var/log
      Archived and active journals take up 808.0M in the file system.
      /opt/iobroker/backups:
      15M     /opt/iobroker/backups/
      2.8M    /opt/iobroker/backups/scripte
      2.4M    /opt/iobroker/backups/scripte/Meine_Geräte
      312K    /opt/iobroker/backups/scripte/Meine_Geräte/Temp_Ansagen
      284K    /opt/iobroker/backups/scripte/Test
      /opt/iobroker/iobroker-data:
      4.9G    /opt/iobroker/iobroker-data/
      4.2G    /opt/iobroker/iobroker-data/history
      454M    /opt/iobroker/iobroker-data/files
      191M    /opt/iobroker/iobroker-data/backup-objects
      90M     /opt/iobroker/iobroker-data/files/echarts.admin
      40M     /opt/iobroker/iobroker-data/objects.jsonl
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! invalid: iobroker.alexa2@3.26.3 /opt/iobroker/node_modules/iobroker.alexa2
      npm ERR! invalid: iobroker.cameras@1.3.0 /opt/iobroker/node_modules/iobroker.cameras
      npm ERR! invalid: iobroker.fully-tablet-control@0.3.6-1 /opt/iobroker/node_modules/iobroker.fully-tablet-control
      npm ERR! invalid: iobroker.homepilot20@0.0.32 /opt/iobroker/node_modules/iobroker.homepilot20
      npm ERR! invalid: iobroker.vis-materialdesign@0.5.94 /opt/iobroker/node_modules/iobroker.vis-materialdesign
      npm ERR! invalid: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
      npm ERR! invalid: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
      npm ERR! invalid: string_decoder@1.3.0 /opt/iobroker/node_modules/string_decoder
      npm ERR! invalid: ms@2.0.0 /opt/iobroker/node_modules/ms
      npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
      npm ERR! missing: cli@0.4.x, required by ipv6@3.1.1
      npm ERR! missing: cliff@0.1.x, required by ipv6@3.1.1
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-10T11_07_13_165Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      Core adapters versions
      js-controller:  5.0.16
      admin:          6.12.0
      javascript:     7.1.6
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-10T11_07_36_329Z-debug-0.log
      Adapters from github:   4
      Adapter State
      + system.adapter.admin.2                  : admin                 : iobrokermaster                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobrokermaster                           -  enabled
      + system.adapter.alexa2.1                 : alexa2                : iobrokermaster                           -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : iobrokermaster                           -  enabled
      + system.adapter.backitup.0               : backitup              : iobrokermaster                           -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : iobrokermaster                           -  enabled
        system.adapter.cloud.0                  : cloud                 : iobrokermaster                           - disabled
      + system.adapter.device-reminder.0        : device-reminder       : iobrokermaster                           -  enabled
        system.adapter.discovery.0              : discovery             : iobrokermaster                           - disabled
        system.adapter.dwd.0                    : dwd                   : iobrokermaster                           -  enabled
      + system.adapter.echarts.0                : echarts               : iobrokermaster                           -  enabled
      + system.adapter.email.0                  : email                 : iobrokermaster                           -  enabled
        system.adapter.flot.0                   : flot                  : iobrokermaster                           -  enabled
      + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobrokermaster                           -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iobrokermaster                           -  enabled
        system.adapter.harmony.0                : harmony               : iobrokermaster                           - disabled
      + system.adapter.history.0                : history               : iobrokermaster                           -  enabled
      + system.adapter.homepilot20.0            : homepilot20           : iobrokermaster                           -  enabled
      + system.adapter.hue-extended.0           : hue-extended          : iobrokermaster                           -  enabled
        system.adapter.hue.0                    : hue                   : iobrokermaster                           - disabled, port: 443
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobrokermaster                           -  enabled
      + system.adapter.info.0                   : info                  : iobrokermaster                           -  enabled
      + system.adapter.iot.0                    : iot                   : iobrokermaster                           -  enabled
      + system.adapter.jarvis.0                 : jarvis                : iobrokermaster                           -  enabled
      + system.adapter.javascript.0             : javascript            : iobrokermaster                           -  enabled
      + system.adapter.meross.0                 : meross                : iobrokermaster                           -  enabled
        system.adapter.mobile.0                 : mobile                : iobrokermaster                           - disabled
      + system.adapter.mqtt.0                   : mqtt                  : iobrokermaster                           -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.nina.0                   : nina                  : iobrokermaster                           - disabled
      + system.adapter.parser.0                 : parser                : iobrokermaster                           -  enabled
      + system.adapter.ping.0                   : ping                  : iobrokermaster                           -  enabled
      + system.adapter.psa.0                    : psa                   : iobrokermaster                           -  enabled
      + system.adapter.pushover.1               : pushover              : iobrokermaster                           -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobrokermaster                           -  enabled, port: 8099, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobrokermaster                           -  enabled, port: 1893, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobrokermaster                           -  enabled
        system.adapter.starline.0               : starline              : iobrokermaster                           - disabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobrokermaster                           -  enabled
      + system.adapter.telegram.0               : telegram              : iobrokermaster                           -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : iobrokermaster                           -  enabled
      + system.adapter.tr-064.0                 : tr-064                : iobrokermaster                           -  enabled
        system.adapter.tuya.0                   : tuya                  : iobrokermaster                           - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobrokermaster                           -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobrokermaster                           -  enabled
        system.adapter.vis-history.0            : vis-history           : iobrokermaster                           -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobrokermaster                           -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobrokermaster                           -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobrokermaster                           -  enabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iobrokermaster                           -  enabled
        system.adapter.vis-map.0                : vis-map               : iobrokermaster                           -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobrokermaster                           -  enabled
        system.adapter.vis-material.0           : vis-material          : iobrokermaster                           -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobrokermaster                           -  enabled
        system.adapter.vis-metro.0              : vis-metro             : iobrokermaster                           -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobrokermaster                           -  enabled
        system.adapter.vis.0                    : vis                   : iobrokermaster                           -  enabled
      + system.adapter.web.0                    : web                   : iobrokermaster                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.yr.0                     : yr                    : iobrokermaster                           -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobrokermaster                           -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): Stable (default)
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "awtrix-light" : 0.10.0   , installed 0.10.0
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "device-reminder": 3.0.0  , installed 3.0.0
      Adapter    "echarts"      : 1.5.4    , installed 1.5.4
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
      Adapter    "harmony"      : 1.3.0    , installed 1.3.0
      Adapter    "hue"          : 3.10.1   , installed 3.10.1
      Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.16   , installed 5.0.16
      Adapter    "meross"       : 1.15.1   , installed 1.15.1
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "parser"       : 2.0.7    , installed 2.0.7
      Adapter    "proxy"        : 1.3.2    , installed 1.3.2
      Adapter    "psa"          : 0.0.11   , installed 0.0.12
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "starline"     : 1.1.3    , installed 1.1.3
      Adapter    "telegram"     : 3.0.0    , installed 2.0.1  [Updatable]
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
      Objects and States
      Objects:        25038
      States:         20414
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       21419      2373/io.jarvis.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14404      493/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14379      467/cupsd
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14264      1104/io.mqtt.0
      tcp        0      0 0.0.0.0:1893            0.0.0.0:*               LISTEN      1001       14175      1028/io.sonoff.0
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       14588      545/iobroker.js-con
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      116        10816      478/redis-server 12
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14869      698/io.admin.2
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       14280      1119/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14406      493/sshd: /usr/sbin
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14378      467/cupsd
      tcp6       0      0 :::3000                 :::*                    LISTEN      1001       23143      2121/io.fullybrowse
      tcp6       0      0 :::8099                 :::*                    LISTEN      1001       23516      2434/io.simple-api.
      tcp6       0      0 ::1:6379                :::*                    LISTEN      116        10817      478/redis-server 12
      udp        0      0 0.0.0.0:36256           0.0.0.0:*                           1001       21786      1613/io.broadlink2.
      udp        0      0 0.0.0.0:60987           0.0.0.0:*                           1001       20598      1613/io.broadlink2.
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12157      769/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13626      496/cups-browsed
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       20595      1613/io.broadlink2.
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13504      364/avahi-daemon: r
      udp        0      0 0.0.0.0:48526           0.0.0.0:*                           108        13506      364/avahi-daemon: r
      udp6       0      0 :::57783                :::*                                108        13507      364/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          12169      769/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        13505      364/avahi-daemon: r
      2023-12-10 11:45:16.113  - info: host.iobrokermaster iobroker upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
      2023-12-10 11:45:17.155  - info: host.iobrokermaster iobroker exit 0
      2023-12-10 11:45:50.171  - info: host.iobrokermaster Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
      2023-12-10 11:51:57.166  - info: javascript.0 (915) script.js.Meine_Geraete.Astrotag_Night: neue Tagezeit: Mittag
      2023-12-10 11:51:57.168  - info: javascript.0 (915) script.js.Meine_Geraete.Astrotag_Night: nächste kommende Tagezeit: Nachmittag
      2023-12-10 11:59:00.603  - info: host.iobrokermaster instance system.adapter.yr.0 started with pid 24957
      2023-12-10 11:59:48.870  - info: host.iobrokermaster instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-12-10 12:00:00.541  - info: host.iobrokermaster instance system.adapter.dwd.0 started with pid 27411
      2023-12-10 12:00:04.590  - info: dwd.0 (27411) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.16
      2023-12-10 12:00:07.822  - info: dwd.0 (27411) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-12-10 12:00:08.373  - info: host.iobrokermaster instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-12-10 12:01:00.059  - info: tankerkoenig.0 (1720) Scheduled restart.
      2023-12-10 12:01:00.066  - info: tankerkoenig.0 (1720) terminating
      2023-12-10 12:01:00.069  - info: tankerkoenig.0 (1720) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2023-12-10 12:01:00.576  - info: tankerkoenig.0 (1720) terminating
      2023-12-10 12:01:00.623  - warn: tankerkoenig.0 (1720) Could not perform strict object check of state tankerkoenig.0.stations.adapterStatus: DB closed
      2023-12-10 12:01:01.210  - info: host.iobrokermaster instance system.adapter.tankerkoenig.0 scheduled normal terminated and will be restarted on schedule.
      2023-12-10 12:01:01.212  - info: host.iobrokermaster Restart adapter system.adapter.tankerkoenig.0 because enabled
      2023-12-10 12:01:02.478  - info: host.iobrokermaster instance system.adapter.tankerkoenig.0 started with pid 29149
      2023-12-10 12:01:06.161  - info: tankerkoenig.0 (29149) starting. Version 3.3.7 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v18.19.0, js-controller: 5.0.16
      2023-12-10 12:01:06.405  - info: tankerkoenig.0 (29149) Adapter is already in daemon mode
      2023-12-10 12:01:06.407  - info: tankerkoenig.0 (29149) Sync time set to 30 minutes or 1800000 ms
      2023-12-10 12:01:14.416  - info: tankerkoenig.0 (29149) Start first request
      2023-12-10 12:07:40.619  - info: javascript.0 (915) script.js.Meine_Geraete.Bewegung_Speisekammer: Speisekammer offen
      2023-12-10 12:08:22.271  - info: javascript.0 (915) script.js.common.Lichtauswertung: Speisekammer Licht ausgeschaltet.
      iob diag has finished.
        Thomas Braun Most Active @Bibo*13 last edited by Thomas Braun
        @bibo-13
        sudo systemctl set-default multi-user.target
        Installier diese Adapter nochmal (oder schmeiß sie raus):
          was bewirkt das sudo systemctl set-default multi-user.target
            @bibo-13
            Das bewirkt, das die Meldung mit dem nicht startenden Service lightdm.service verschwindet.
              @thomas-braun Ok dann installiere ich diese Adapter noch einmal. Ist es besser sie vorher zu deinstallieren?
                @bibo-13 sagte in Adapter Install für Telegram funktioniert nicht.:
                Nein. Einfach drüber installieren. Kommen die alle aus dem github? Werden die überhaupt verwendet?
                  @thomas-braun ja bis auf cameras sind alle aktiv
                    Den ersten Adapter Alexa2 ausprobiert das gleiche mit den NPM Errors
                    host.iobrokermaster
                    2023-12-10 12:37:47.757	info	stopInstance system.adapter.alexa2.0 send kill signal
                    host.iobrokermaster
                    2023-12-10 12:37:47.747	info	stopInstance system.adapter.alexa2.0 (force=false, process=true)
                    host.iobrokermaster
                    2023-12-10 12:37:47.630	info	iobroker Update "system.adapter.alexa2.0"
                    host.iobrokermaster
                    2023-12-10 12:37:47.348	info	iobroker npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-10T11_34_11_619Z-debug-0.log
                    host.iobrokermaster
                    2023-12-10 12:37:47.341	info	iobroker npm ERR! notsup Unsupported platform for @img/sharp-win32-x64@0.33.0: wanted {"os":"win32","cpu":"x64"} (current: {"os":"linux","cpu":"arm"})npm ERR! notsup Valid os: win32npm ERR! notsup Actual os: linuxnpm ERR! notsup Valid cpu: x64npm ERR! notsup Actual cpu: arm
                    host.iobrokermaster
                    2023-12-10 12:37:47.330	info	iobroker npm ERR! code EBADPLATFORM
                    host.iobrokermaster
                    2023-12-10 12:34:10.135	info	iobroker NPM version: 10.2.3Installing iobroker.alexa2@3.26.3... (System call)
                    host.iobrokermaster
                    2023-12-10 12:34:08.453	info	iobroker Update alexa2 from @3.26.3 to @3.26.3
                    host.iobrokermaster
                    2023-12-10 12:34:04.202	info	iobroker upgrade alexa2@3.26.3 --debug
                      @bibo-13
                      Die Meldungen kommen ja auch nicht von dem Adapter, die hängen da generell in der Pipeline.
                      Ist die 'invalid'-Eintragung denn jetzt weg?
                        ja bis auf da bin ich noch dran. Aber keine Ahnung was cli socksv5 oder cliff sein sein:
                        Errors in npm tree:
                          @bibo-13
                          https://forum.iobroker.net/topic/69758/update-js-controller-nodejs-is-not-correctly-installed/35?_=1702205201927
                            So der Homepilot20 invalid ist jetzt auch weg.
                            was kann/muß ich jetzt noch machen?
                              @bibo-13
                              Zeig mal
                              cd /opt/iobroker
                              npm ls
                                @bibo-13
                                Und
                                iob update
                                  Hier bitte:
                                  pi@iobrokermaster:~ $ cd /opt/iobroker
                                  pi@iobrokermaster:/opt/iobroker $ npm ls
                                  iobroker.inst@2.0.3 /opt/iobroker
                                  ├── colors@1.4.0
                                  ├── fs-extra@7.0.1
                                  ├── iobroker.admin@6.12.0
                                  ├── iobroker.alexa2@3.26.1
                                  ├── iobroker.awtrix-light@0.10.0
                                  ├── iobroker.backitup@2.8.7
                                  ├── iobroker.broadlink2@2.1.5
                                  ├── iobroker.cloud@4.4.1
                                  ├── iobroker.device-reminder@3.0.0
                                  ├── iobroker.discovery@4.2.0
                                  ├── iobroker.dwd@2.8.5
                                  ├── iobroker.echarts@1.5.4
                                  ├── iobroker.email@1.2.0
                                  ├── iobroker.flot@1.12.0
                                  ├── iobroker.fully-tablet-control@0.3.8
                                  ├── iobroker.fullybrowser@3.0.6
                                  ├── iobroker.harmony@1.3.0
                                  ├── iobroker.history@3.0.1
                                  ├── iobroker.homepilot20@0.0.48
                                  ├── iobroker.hue-extended@2.0.0
                                  ├── iobroker.hue@3.10.1
                                  ├── iobroker.icons-mfd-svg@1.1.0
                                  ├── iobroker.info@2.0.0
                                  ├── iobroker.iot@2.0.11
                                  ├── iobroker.jarvis@3.1.8
                                  ├── iobroker.javascript@7.1.6
                                  ├── iobroker.js-controller@5.0.16
                                  ├── iobroker.meross@1.15.1
                                  ├── iobroker.mobile@1.0.1
                                  ├── iobroker.mqtt@5.1.0
                                  ├── iobroker.nina@0.0.25
                                  ├── iobroker.parser@2.0.7
                                  ├── iobroker.ping@1.6.2
                                  ├── iobroker.proxy@1.3.2
                                  ├── iobroker.psa@0.0.12
                                  ├── iobroker.pushover@3.0.3
                                  ├── iobroker.rpi2@1.3.2
                                  ├── iobroker.simple-api@2.7.2
                                  ├── iobroker.socketio@6.6.0
                                  ├── iobroker.sonoff@3.0.3
                                  ├── iobroker.sourceanalytix@0.4.14
                                  ├── iobroker.starline@1.1.3
                                  ├── iobroker.tankerkoenig@3.3.7
                                  ├── iobroker.telegram@2.0.1
                                  ├── iobroker.text2command@3.0.2
                                  ├── iobroker.tr-064@4.2.18
                                  ├── iobroker.tuya@3.14.2
                                  ├── iobroker.vis-colorpicker@2.0.3
                                  ├── iobroker.vis-fancyswitch@1.1.0
                                  ├── iobroker.vis-history@1.0.0
                                  ├── iobroker.vis-hqwidgets@1.4.0
                                  ├── iobroker.vis-inventwo@3.3.3
                                  ├── iobroker.vis-jqui-mfd@1.0.12
                                  ├── iobroker.vis-keyboard@0.0.2
                                  ├── iobroker.vis-map@1.0.4
                                  ├── iobroker.vis-material-advanced@1.7.4
                                  ├── iobroker.vis-material@0.1.3
                                  ├── iobroker.vis-metro@1.2.0
                                  ├── iobroker.vis-timeandweather@1.2.2
                                  ├── iobroker.vis@1.4.16
                                  ├── iobroker.web@6.1.10
                                  ├── iobroker.ws@2.5.8
                                  ├── iobroker.yr@5.3.0
                                  ├── iobroker.zigbee@1.8.24
                                  ├── iobroker@2.0.3
                                  ├── semver@5.7.2
                                  └── yargs@7.1.2
                                    Hier bitte:
                                    pi@iobrokermaster:/opt/iobroker $ iob update
                                    Adapter    "alexa2"       : 3.26.3   , installed 3.26.1 [Updatable]
                                      @bibo-13
                                      iob upgrade all -y --debug
                                        Ok telegram ist durch ohne probleme
                                          @bibo-13
                                          Und
                                          iob update
                                          ist jetzt auch sauber? Alles auf Stand?
                                            Ich hätte mal noch ne Frage die jetzt mit diesem Thema nichts zu tun.
                                            Beim Zigbee-Adapter warten eine Menge Anfragen wegen neuer Devices die aber schon im Herdsman bekannt sind.
                                            Wann ist denn hier mit einem Update zu rechnen? Oder wie bekommt man diese Devices angelernt?
                                            1160
