    4. [HowTo] ioBroker unter Docker auf Synology DiskStation
      Matze1708 last edited by
      also ich hatte alles noch mal gemacht.
      Habe auf dem Pi den iobroker gestoppt und diesesmal den ganzen Ordner kopiert. Dann in der Synology eingefügt und gemountet.
      • date stream content
      2017-11-19 09:21:32 stdout No connection to states 127.0.0.1:6379[redis]
      2017-11-19 09:20:49 stdout root@DS-S-Heim:/opt/iobroker# iobrokio[K[Ker host this
      2017-11-19 09:19:15 stdout iobroker controller daemon started. PID: 100
      2017-11-19 09:19:11 stdout Starting iobroker controller daemon…
      2017-11-19 09:19:10 stdout root@DS-S-Heim:/opt/iobroker# iobroker start
      2017-11-19 09:19:00 stdout No connection to states 127.0.0.1:6379[redis]
      2017-11-19 09:18:54 stdout root@DS-S-Heim:/opt/iobroker# iobroker host this
      2017-11-19 09:18:39 stdout @eaDir ftpUpload.sh iobroker killall.sh node_modules reinstall.sh
      2017-11-19 09:18:38 stdout backups etc install.sh iobroker-data log package.json
      2017-11-19 09:18:38 stdout root@DS-S-Heim:/opt/iobroker# ls
      2017-11-19 09:18:37 stdout root@DS-S-Heim:/opt# cd iobroker/
      2017-11-19 09:18:33 stdout iobroker scripts
      2017-11-19 09:18:33 stdout root@DS-S-Heim:/opt# ls
      2017-11-19 09:18:32 stdout root@DS-S-Heim:/# cd opt
      2017-11-19 09:18:27 stdout bin boot dev etc home lib lib64 media mnt opt proc root run sbin srv sys tmp usr var
      2017-11-19 09:18:27 stdout root@DS-S-Heim:/# ls
      2017-11-19 09:17:56 stdout No connection to states 127.0.0.1:6379[redis]
      2017-11-19 09:17:50 stdout root@DS-S-Heim:/# iobroker hst [K[K[Kost thos[K[Kis
      2017-11-19 09:17:40 stdout iobroker controller daemon is not running
      2017-11-19 09:17:38 stdout root@DS-S-Heim:/# [Kroot@DS-S-Heim:/# iobroker stop
      2017-11-19 09:16:02 stdout iobroker controller daemon already running. PID: 66
      2017-11-19 09:15:54 stdout [….] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon[?25l7[1G[[32m ok [39;49m8[?12l[?25h.
      2017-11-19 09:15:49 stdout [….] Stopping Avahi mDNS/DNS-SD Daemon: avahi-daemon[?25l7[1G[[32m ok [39;49m8[?12l[?25h.
      2017-11-19 09:15:47 stdout rm: das Entfernen von '/var/run/dbus/pid' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
      Ich sehe das der admin startet und alle module die im alten Broker waren… aber ich komme nicht auf das interface..... wie du siehst geht der hosts this auch nicht richtig.
      • andre
        andre Developer last edited by
        @Matze1708:
        Ich sehe das der admin startet und alle module die im alten Broker waren… aber ich komme nicht auf das interface..... wie du siehst geht der hosts this auch nicht richtig. `
        Kann es sein dass dein iobroker auf dem pi mit redis als states db lief?
        Laut log ist der Fehler doch eindeutig…
        "2017-11-19 09:19:00 stdout No connection to states 127.0.0.1:6379[redis]"
        Entweder du machst ein "iobroker setup custom" und stellst zurück auf File als states db oder du installierst auf der DS das redis Paket (so habe ich es).
        Alternativ könnte man redis auch im Container installieren.
        Für iobroker host this muss iobroker, glaube ich, gestoppt sein…
        MfG,
        André
        Gesendet von meinem D5803 mit Tapatalk
          Danke für die Hilfe.
          Macht es dann nicht mehr Sinn die Redis DB im Container fest zu installieren?
          Beim PI habe ich dahin gehend nichts geändert.
          • andre
            @Matze1708:
            Beim PI habe ich dahin gehend nichts geändert. ` Nein.
            Wenn man den Container (das Image) dann nach meiner Anleitung aktualisiert müsste man redis immer manuell neu installieren. Ich werde es nicht von vornherein mit integrieren. Es gibt ja die Möglichkeiten redis als eigenen Container oder als DS Paket zu installieren. Das sollte reichen.
            Eine Anleitung dazu steht noch auf meiner ToDo-Liste.
            MfG,
            André
              Ok,
              Es reicht also auf der DS das Paket oder einen Cotainer mit redis zu installieren?
              Wie erkennen sich dann die Anwendung?
                sooo…
                also als Paket ging es nicht zu installieren.. Das Paket hat nicht gesartet.
                Als Container aber schon eher... hier ist im Prozess schon mal zu erkennen das die einzelnen Adapter starten....
                Aber einIobroker stopum````
                iobroker host this
                EDIT:
                Nach langem warten konnte ich iobroker host this ausführen und ioborker starten... Alles sehr langsam.... Aktuell startet das interface auf 8081 nicht... man sieht nur kurz das Rad und dann ist wieder alles weiss.
                  Telefisch last edited by
                  in anderem Thread" url="http://forum.iobroker.net/viewtopic.php?f=20&t=5371&p=54397#p54397">@Superdad [url=http://forum.iobroker.net/viewtopic.php?f=20&t=5371&p=54397#p54397:
                  ~~in anderem Thread"]~~Hallo,
                  im Synology unter Systemsteuerung - Aufgabenplaner folgendes anlegen:
                  Erstellen - geplante Aufgabe - benutzerdefiniertes Script:
                  Allgemein - bei Vorgang z.Bsp.: ioBroker starten
                  Benutzer: root
                  dann Aufgabeneinstellungen - benutzerdefiniertes Script:
                  dort eintragen:
                  cd /volume2/homes/admin/opt/iobroker
                  ./iobroker start
                  eintragen.
                  Wenn dein ioBroker in einem anderen Verzeichnis liegt, dann musst du das natürlich anpassen.
                  Unter Aufgabeneinstellung kannst du dir auch noch eine Bestätigungsmail schicken lassen.
                  Für ioBroker stoppen folgendes eintagen:
                  Zweites Script anlegen wie oben:
                  dann eintragen:
                  ./iobroker stop
                  dann kannst du auch mal per Hand stoppen und starten.
                  Gruss `
                  Hallo, ich stehe vor dem gleichen Problem.
                  Das Script funktioniert nur nicht, weil ich anscheinend keine Home-Verzeichnisse habe.
                  Keine Ahnung warum.
                  Wo läuft denn jetzt der ioBroker?
                  geändert: Thread zusammengeführt und Quote wegen Sinnzusammenhang eingefügt; Homoran (Mod)
                  • Dutchman
                    @Telefisch:
                    Wo läuft denn jetzt der ioBroker? `
                    Sorry habe keine Antwort zu dieser Frage würde aber empfehlen anstatt direkt auf dem NAS ioBroker in einem docker laufen zu lassen damit trennst du auch dein NAS System und processen von ioBroker was am Ende die bessere Lösung ist.
                    Greetz
                    Dutch
                    Send from mobile device
                      Äh ja läuft ja im Docker…
                      ich war davon ausgegangen dass das hier im Threat auch so ist.
                      :oops:
                        Man sollte keinen Thread kapern!
                        Es gibt auch einen Docker thread.
                        Rainer
                          Jaja, nu ist aber gut!
                          Da sucht man nach Lösungen bevor man eine Frage stellt und wieder von den allwissenden "BENUTZER GOOGLE-Usern" angemotzt wird und dann ist es auch wieder nicht richtig.
                          Also danke für diesen überflüssigen Hinweis!
                          Es tut mir unfassbar Leid dass ich zu dämlich für dieses Forum bin.
                          BTW…
                          ich hab ne Synology und ich habe ioBroker drauf laufen.
                          So abwegig war dieser Threat ja wohl nicht oder?
                            Verzeihung werter Herr (??).
                            @Telefisch:
                            dass ich zu dämlich für dieses Forum bin. `
                            so war das wirklich nicht gemeint!
                            @Telefisch:
                            Da sucht man nach Lösungen bevor man eine Frage stellt `
                            das ist ja auch gut so.
                            @Telefisch:
                            von den allwissenden "BENUTZER GOOGLE-Usern" angemotzt wird `
                            Ich suche doch gerade den Docker thread um dich dahin zu verschieben
                            Aber eine Frage habe ich noch zuvor:
                            Welches Docker-Image benutzst du?
                            Rainer
                              …ich bin so angefressen weil ich extra nach einer Problemlösung gesucht habe, bevor ich einen Threat dafür eröffne.
                              Weil genau das die typischen Besserwisser auf den Plan ruft, die alles können, vor allem hervorragend googeln.
                              So, Blutdruck ist wieder runter...
                              Also.
                              Welches Image ich verwende kann ich ehrlich gesagt nicht so genau ermitteln. Irgendwie finde ich keine Versionsinformationen außer:
                              buanet/iobroker:latest.
                              Ist das dann tatsächlich die letzte Version?
                              Mittlerweile gefunden habe ich diesen:
                              http://forum.iobroker.net/viewtopic.php ... lit=Docker
                              und
                              https://buanet.de/2017/09/iobroker-unte ... skstation/
                              Das werde ich jetzt nochmal durcharbeiten und dann sehen wir weiter.
                              Gruß Carsten
                                Also das buanet image.
                                Ok, das läuft auch lt. diesem Thread.
                                Dann werden dir hier gleich (?) die Wissenden weiterhelfen.
                                Rainer
                                  Also, aktueller Stand:
                                  ich habe nochmal laut der Anleitung die iobroker-Daten aus dem Container ausgelagert.
                                  Jetzt liegt der iobroker im Verzeichnis docker\iobroker_mount und ist in den Container gemountet.
                                  Optimistisch wie ich bin habe ich diesen Pfad auch als script-Pfad ausprobiert und bekomme folgende Fehlermeldung:
                                  Standardausgabe/Fehler:
                                  /iobroker: line 1: node: command not found
                                  die Datei iobroker im ioBroker-Verzeichnis ist wohl nicht das ziel der Begierde :oops:
                                  Mangels Unix-Ahnung bin ich hier am Ende mit meinem Latein.
                                  Bin für jeden Tip dankbar
                                  Gruß Carsten
                                  • andre
                                    @Matze1708:
                                    sooo…
                                    iobroker host this
                                    EDIT:
                                    Nach langem warten konnte ich iobroker host this ausführen und ioborker starten... Alles sehr langsam.... Aktuell startet das interface auf 8081 nicht... man sieht nur kurz das Rad und dann ist wieder alles weiss. `
                                    Hallo Matze,
                                    ich kann mich erinnern, dass ich auch Probleme mit dem Synology Redis Paket hatte. Wollte zuerst nicht starten. Google hat mir da aber was ausgespuckt wo eine Datei angepasst werden musste, finde aber gerade den Link nicht mehr…
                                    Warum dein Container so langsam ist kann ich mir allerdings nicht erklären. Glaube schon einmal von jemanden sowas gelesen zu haben... Gibt es denn Fehlermeldungen? Was sagt die Auslastung der Synology? Hilft ein Neustart des Containers oder der DS? Welches Modell und wieviel RAM hast du eigentlich?
                                    MfG,
                                    André
                                    Gesendet von iPad mit Tapatalk Pro
                                    • andre
                                      Leute, Leute… Immer entspannt bleiben. 🙂
                                      Ersteinmal willkommen in "meinem" Thread...
                                      Ich habe mir eure verschobenen Beiträge jetzt das dritte Mal durch gelesen und bin zu dem Entschluss gekommen, dass irgendwas fehlt. 😉 Wie hat das ganze denn überhaupt angefangen? Was war die Ursprungsfrage? Irgendwas mit einem Script, aber welches? Bin gerne bereit zu unterstützen.
                                      Ein paar Sachen kann ich ja schonmal kommentieren...
                                      @Telefisch:
                                      Ist das dann tatsächlich die letzte Version? `
                                      Korrekt. Das Image wird jede Nacht automatisch neu erstellt, sodass man jedes Mal wenn man es neu herunter lädt die aktuellste Version erhält.
                                      @Telefisch:
                                      http://forum.iobroker.net/viewtopic.php … lit=Docker
                                      und
                                      Das werde ich jetzt nochmal durcharbeiten und dann sehen wir weiter. `
                                      Wie ist dabei der Stand? Alle Antworten gefunden die du gesucht hast?
                                      @Homoran:
                                      Ok, das läuft auch lt. diesem Thread. `
                                      So ist es. Läuft bei mir seit Ewigkeiten ohne Probleme.
                                      @Telefisch:
                                      Gruß Carsten `
                                      Hier greift jetzt meine Eingangsfrage. Um welches Script geht es? Was soll damit gemacht werden?
                                      MfG,
                                      André
                                        @andre:
                                        Hier greift jetzt meine Eingangsfrage. Um welches Script geht es? Was soll damit gemacht werden? `
                                        Ich habe extra den link zu dem anderen thread oben im zitat eingebunden, damit der Zusammenhang nachvollziehbar bleibt.
                                        Gruß Rainer
                                          es ging konkret darum, dass nach einem DSM-Update in der Regel der Docker samt Image zwar läuft aber ioBroker nochmal manuell gestartet werden muss.
                                          Da war ich auf der Suche nach einer Lösung auf den oben genannten Threat gestoßen und hatte gehofft mit dem "Startscript" was ich in den Aufgaben der Synology anlege dann meinen iobroker automatisch starten kann.
                                          Die Kommandozeile Script zu nennen ist vielleicht etwas übertrieben aber so heißt es bei Synology nunmal 🙂
                                          Das ist der letzte meiner Versuche…
                                          cd /volume1/docker/iobroker_mount
                                          ./iobroker start
                                          Da ich totaler Unix-Noob bin weiß ich nicht mehr weiter.
                                          Gruß Carsten
                                          • andre
                                            @Homoran:
                                            @andre:
                                            Gruß Rainer `
                                            Hallo Rainer,
                                            das glaube ich dir. Du meinst sicher den Post #237? Dann hat das Einfügen nicht geklappt. Da steht zwar was von url, sieht mir aber so aus alsob davor was fehlt…
                                            MfG,
                                            André
                                            buanet diskstation docker iobroker synology
                                            248
                                            2854
                                            1531266
