    4. Neuer Adapter für Roborock-Staubsauger
    • Flexer
      Flexer last edited by Flexer
      Hallo @copystring
      habe mir vor 10 min die letzte Dev gezogen. Konnte den Roborock nicht mehr starten. Ging nur über die App. Im Log sieht es so aus
      	2023-12-08 18:39:58.313	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:56.323	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:54.274	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:52.468	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:50.326	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:48.285	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:46.334	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:44.300	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:42.618	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:40.442	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:38.928	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:36.380	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:34.239	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:32.495	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:30.326	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:28.273	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:26.466	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:24.641	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:22.261	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:20.252	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:18.536	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:16.485	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:14.429	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:12.755	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:10.283	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:08.587	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:06.308	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:04.272	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:02.313	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:39:01.084	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:58.722	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:56.317	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:54.379	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:52.267	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:50.378	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:48.298	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:46.288	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:44.234	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:42.234	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:40.274	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:38.278	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:36.278	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:34.248	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:32.275	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:30.232	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:28.604	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:26.350	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:24.302	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:22.260	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:20.253	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:18.252	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:16.309	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:14.241	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:12.243	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:10.259	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:08.308	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:06.496	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:04.354	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:02.357	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:38:00.288	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:37:58.315	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:37:56.328	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:37:54.319	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:37:52.223	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:37:50.251	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:37:48.249	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:37:46.324	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:37:44.394	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:37:42.352	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:37:40.477	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:37:38.303	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:37:36.290	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:37:34.219	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:37:32.245	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:37:30.336	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:37:28.256	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:37:26.288	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      roborock.0
      2023-12-08 18:37:24.213	error	Failed to execute writing test.rrmap on robot 73IcwgDn1vor4XzkGQz8Oa Error: ENOENT: no such file or directory, open './test.rrmap' at Object.openSync (node:fs:601:3) at Object.writeFileSync (node:fs:2249:35) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:101:9) at processTicksAndRejections (node:internal/process/task_queues:95:5)
        BamBam89 @Flexer last edited by
        hat jemand eine Idee woher die Warnungen kommen?
        roborock.0
        Zeit
        debug
        Nachricht
        roborock.0
        2023-12-10 11:28:41.157	warn	Failed to execute get_consumable on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 4619 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:41.157	warn	Failed to execute get_status on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 6114 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:41.154	warn	Failed to execute get_room_mapping on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 6703 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:40.158	warn	Failed to execute get_network_info on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 7719 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:40.157	warn	Failed to execute get_consumable on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 2954 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:40.157	warn	Failed to execute get_carpet_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 7273 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:40.156	warn	Failed to execute get_timer on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 8602 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:40.156	warn	Failed to execute get_server_timer on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 3368 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:40.156	warn	Failed to execute get_water_box_custom_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 9608 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:40.155	warn	Failed to execute get_carpet_clean_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 3895 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:40.154	warn	Failed to execute get_room_mapping on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 9438 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:40.154	warn	Failed to execute get_status on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 2171 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:39.154	warn	Failed to execute get_network_info on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 3527 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:39.154	warn	Failed to execute get_water_box_custom_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 3459 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:39.154	warn	Failed to execute get_carpet_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 2204 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:39.154	warn	Failed to execute get_timer on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 6316 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:39.154	warn	Failed to execute get_server_timer on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 8218 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:39.153	warn	Failed to execute get_consumable on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 9246 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:39.153	warn	Failed to execute get_status on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 8081 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:39.152	warn	Failed to execute get_room_mapping on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 5984 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:39.151	warn	Failed to execute get_carpet_clean_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 7506 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:38.171	warn	Failed to execute get_carpet_clean_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 5065 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:38.165	warn	Failed to execute get_water_box_custom_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 4560 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:38.165	warn	Failed to execute get_room_mapping on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 8412 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:38.163	warn	Failed to execute get_network_info on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 3654 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:38.152	warn	Failed to execute get_status on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 7120 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:38.152	warn	Failed to execute get_carpet_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 8395 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:38.151	warn	Failed to execute get_timer on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 4927 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:38.151	warn	Failed to execute get_server_timer on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 2101 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:38.150	warn	Failed to execute get_consumable on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 7708 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:37.156	warn	Failed to execute get_carpet_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 6922 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:37.156	warn	Failed to execute get_timer on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 6706 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:37.155	warn	Failed to execute get_server_timer on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 9030 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:37.155	warn	Failed to execute get_room_mapping on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 1270 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:37.154	warn	Failed to execute get_carpet_clean_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 7524 timed out after 10 seconds for response.102
        roborock.0
        2023-12-10 11:28:37.154	warn	Failed to execute get_status on robot 4Pdmlh6A41cjZXBieYbjqk Error: Request with id 2596 timed out after 10 seconds for response.102
        11 Warnungen pro Sekunde.
        Danke euch und einen schönen zweiten Advent.
          tritanium @copystring last edited by
          @copystring
          Hallölle, leider musste ich wieder zurück auf "stable" 😞
          -> mit der aktuellen /dev waren zwar alle "Fehlermeldungen" weg, aber ein bedienen via DP "app_start" = true ging nicht !
          Warum auch immer.... jetzt wieder stable -> zack... gehts wieder mittels "app_start" = true.
          copystring 1 Reply Last reply Reply Quote 0
          • copystring
            copystring @tritanium last edited by
            @tritanium Ja, weil in der dev ein breaking change ist. Bei Befehlen muss ack: true gesetzt werden.
            T Flexer 2 Replies Last reply Reply Quote 0
              tritanium @copystring last edited by tritanium
              @copystring
              Asooooo ✌ äähm, Stand das irgendwo ❓ ...nicht das ich was überlesen habe...🙄 ??
              -> nun ja, dann könnte ich ja wieder zur /dev ❓ 🤣
              Aber ist das nicht entgegen den "Rules" in Blockly..?
              Ich habe mal "gelernt" das alles was gesteuert werden soll via Datenpunkten, explizit "kein ACK" gesetzt werden soll, weil der/die Adapter das tun, damit man festellen kann, das sie den Befehl verstanden haben und dann auch ausführen...
              • copystring
                @tritanium https://github.com/copystring/ioBroker.roborock/commit/1ce38d7958be0655e088f41bc76102d66a22375c#diff-b335630551682c19a781afebcf4d07bf978fb1f8ac04c6bf87428ed5106870f5R72
                Ja, du kannst die dev nehmen.
                0 copystring committed to copystring/ioBroker.roborock
                Update README.md
                  @copystring
                  Jaaaahaaaa 🙂 ok... gebe zu, habe ich nicht gelesen 😛
                  Danke trotzdem für deine "hyperschnelle Reaktion" ... dann bringe ich nun die KIDS ins Bett und gehe danach zurück auf /dev.
                  lg Micha
                  • copystring
                    copystring last edited by copystring
                    @tritanium said in Neuer Adapter für Roborock-Staubsauger:
                    @copystring
                    Guter Hinweis. Das wusste ich bisher nicht und dachte, das wäre genau andersherum. Dann muss ich das wohl nochmal anpassen.
                      @copystring
                      Zumindest habe ich das so bei Matthias Kleine im ioBroker Master Kurs und der "Blockly" Thematik "Steuern vs. aktualisieren" so gelernt 🙂
                      Steuern -> ohne ACK den Wert übergeben, denn "ack" wird vom Adapter dann zurück bestätigt
                      aktualisieren -> mit ACK den Wert übergeben, dann weiß der Adapter, dadurch das ACK gesetzt ist, er muss nichts machen und auch nichts bestätigen.
                      So habe ich es "erlernt"
                        @copystring
                        So, jetzt bin ich wieder auf /dev.
                        Kommt direkt ne Error Meldung:
                        Scheint aber nix tragisches zu sein (hoffe ich) 🙂
                        Und wie du geschrieben hast: ..mit gesetztem >ACK< startet auch wieder der Robi ...
                        Ändere ich halt erst einmal meine Blocklys ... 🤣
                        Danke nochmal für den Hinweis ... grüße Micha
                        EDIT:
                        Wenn ich die Robis nun via DP "app_stop" oder DP "app_charge" anhalte bzw. zurück schicke kommt obiger ERROR
                        Ich hoffe das hilft dir ...
                        • Flexer
                          Flexer @copystring last edited by Flexer
                          @copystring das mit dem ack befehl geht dann aber nur über Blockly und nicht über die vis direkt oder?
                          • copystring
                            copystring @Flexer last edited by
                            @flexer genau. Ich muss es genau umgekehrt einbauen, damit es auch mit der vis läuft. Dann wäre es auch kein breaking change mehr.
                            • copystring
                              copystring @copystring last edited by copystring
                              Die neue dev funktioniert ab sofort wieder zuvor. Kein breaking change mehr. Befehle werden ohne ack: true angenommen.
                                @copystring
                                ..heisst, wenn ich JETZT nochmal die /dev aktualisiere, habe ich deine "Rückänderung" ? 🤔
                                • copystring
                                  @tritanium genau so ist es.
                                    moulder last edited by
                                    Hi, toller Adapter! 🙂 Gibt es bereits ein Objekt, mit welchem man den Roboter zum Andocken befehlen kann? Ich finde die Möglichkeit nur in der visualisierten Map und als Objekt lediglich ein "Stop".
                                      tritanium @moulder last edited by tritanium
                                      @moulder sagte in Neuer Adapter für Roborock-Staubsauger:
                                      Klar, nimm den hier und er fährt zurück ins Dock zum Laden:
                                      • Flexer
                                        Hier jetzt meine Vis für das Handy.
                                        Danke für den tollen Adapter 👍🏻
                                          moulder @tritanium last edited by
                                          @tritanium Ach klasse, vielen Dank! 😊
                                            @jahnbes
                                            @SpacerX
                                            Hallo ihr beiden, hat jemand schon den DOCK Typ 8 ?
                                            Wir haben seit ca. 2 Wochen einen "Q REVO" und die Dock "outet" sich als Typ 8 (in der Wiki nicht verfügbar) deshalb dachte ich mir, das du Bert, den ggfs. anlegen wollen würdest.
                                            Unser Dock hat:
                                            • Frischwasser,
                                            • Brauchwasser,
                                            • Saugerbeutel,
                                            • Windmaschine zum "trockenpusten" der "runden Wischmöpse"
                                            • Filter (?) wo soll der sitzen?
                                            • Reinigungschale
                                            Freue mich über ne kurze Info..
                                            lg Micha
                                            jahnbes 2 Replies Last reply Reply Quote 0
                                            919
                                            315256
