Adapter werden nicht mehr geupdated
@thomas-braun glaube meine sicherungskopie hat es jetzt auch hinter sich:
Last login: Sun Dec 10 10:20:16 on console accu@iMac ~ % ssh pi@192.168.1.13 pi@192.168.1.13's password: Linux Raspi 6.1.64-v7+ #1702 SMP Wed Nov 29 14:16:46 GMT 2023 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Sun Dec 10 08:29:18 2023 pi@Raspi:~ $ iob status node:internal/modules/cjs/loader:1137 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Module._load (node:internal/modules/cjs/loader:975:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) at node:internal/main/run_main_module:28:49 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.19.0 pi@Raspi:~ $ iob upgrade all node:internal/modules/cjs/loader:1137 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Module._load (node:internal/modules/cjs/loader:975:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) at node:internal/main/run_main_module:28:49 { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v18.19.0 pi@Raspi:~ $
ich installiere jetzt mal die Bookworm Version auf ner anderen Speicherkarte und berichte ... -
cd /opt/iobroker sudo -H -u iobroker npm install iobroker.js-controller
@thomas-braun ich hoffe er läuft diesmal durch. Musste nach 4h letztens abbrechen, weil er eingeforen ist.
pi@Raspi:~ $ cd /opt/iobroker pi@Raspi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142 npm WARN deprecated har-validator@5.1.5: this library is no longer supported npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142 npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead. npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed. npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained. npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797) npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797) npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797) npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797) npm WARN deprecated multer@1.4.2: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10. npm WARN deprecated multer@1.4.2: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10. npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies. npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3 npm WARN deprecated passport.socketio@3.7.0: Please check the workaround in https://github.com/jfromaniello/passport.socketio/issues/148 npm WARN deprecated request@2.88.0: request has been deprecated, see https://github.com/request/request/issues/3142 npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142 npm WARN deprecated bcrypt@3.0.6: versions < v5.0.0 do not handle NUL in passwords properly npm WARN deprecated bcrypt@3.0.8: versions < v5.0.0 do not handle NUL in passwords properly npm WARN deprecated vm2@3.9.19: The library contains critical security issues and should not be used for production! The maintenance of the project has been discontinued. Consider migrating your code to isolated-vm. npm WARN deprecated node-pre-gyp@0.12.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future npm WARN deprecated node-pre-gyp@0.14.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future npm WARN deprecated appium-logger@2.1.0: Moved into appium-support npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen) npm WARN deprecated core-js@1.2.7: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js. npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js. (##################) ⠹ reify:iobroker.admin: http fetch GET 200 https://registry.npmjs.org/iobroker.admin/-/iobroker.admin-5.4.9.tgz 923762ms (cache miss)
@thomas-braun installation ist erfolgreich durchgelaufen und der neu ioBroker installiert gerade die Instanzen.
Was schmerzt sind, dass ich meine skripte aus dem alten ioB nicht mehr habe.Die speicherkarte mit der geschrotteten iob instanz habe ich noch. Gibts da irgendeine chance die Blockly Skripte rauszuextrahieren?
Hast du kein gescheites Backup extern liegen?
@thomas-braun leider nein - ich hatte nur immer backups auf der gleichen Speicherkarte gemacht.
andere Frage: es gab doch mal unter Buster einen Befahl wo man den Speicher für die ioBroker optimieren konnte. Wie hieß der gleich nochmal? -
@accu sagte in Adapter werden nicht mehr geupdated:
Keine Ahnung was du meinst.
@thomas-braun ich finde den Post leider nicht mehr. Ich hatte damals schon gepostet, dass ich zu wenig Speicher frei habe.
Du hattest mir mal einen Befehl genannt wo man (leihenhafte Wiedergabe) den Speicher für alle Adapter konsolidieren kann mit dem Nachteil, wenn ein Adapter dann abstürzt alle runtergerissen werden. -
Vermutlich meinst du den Kompakt-Modus des iobroker.
Ich weiß aber so aus dem Kopf nicht wo der einzustellen ist.Aber ich würde dringend zu einem größeren Rechner raten. Mit 1 GB reißt du nix mehr.
Hast Du noch irgendwo das JavaScript davon rumliegen?
Dann hilft das hier: https://forum.iobroker.net/topic/70930/backup-von-scripten-wiederherstellen-json-xml/2Edit
Es gibt auch ein Script, um Blockly aus Sicherungen wiederherzustellen.
Musst Du hier im Forum mal suchen ... -
@thomas-braun ja genau das war es. Das hatte eigentlich gut funktioniert. Habs gefunden:
pi@raspberrypi:~ $ iob compact enable Compact mode for this host is now enabled Please restart ioBroker for this change to take effect! pi@raspberrypi:~ $
bzgl. neuen Rechner hatte ich gesehen, dass es jetzt ja schon einen Raspberry 5 gibt. Was würdest du empfehlen? 4er oder 5er? (ich würde eigentlich gerne vermeiden wollen dass ich alles neu kaufen muss und würde mein Gehäuse gerne weiter nutzen wollen. Beim 5er braucht man wohl extra Kühlkörper ..
Ich nutze den Raspi, wie gesagt nur für ein paar Adapter die ganzen features mit schnelleren USB Ports etc. brauche ich eigentlich nicht wirklich. -
4er oder 5er?
Egal. Ich hab hier einen 4er mit 8GB laufen, der tut es für meine Zwecke noch etwas.
Das Gehäuse von Pi 2/3 passt weder zu Pi4 noch Pi5
auch Pi1-3 braucht Kühlkörperist aber beides kein finanzieller Klimmzug
@homoran auf thingiverse gibt's schon Gehäuse für den 5er...
@da_woody sagte in Adapter werden nicht mehr geupdated:
das wird ja noch teurer!
https://www.prusa3d.com/de/produkt/original-prusa-xl-teilmontierter-3d-drucker-3/ -
nuja, muss ja kein überteuerter prusa sein. vor allem nicht dein gewähltes modell. das ja schon ein nobelhobel.
hab einen creality ender 3v2 und demnächst einen creality K1 zu hause stehn.
hab schon für einige leute was gedruckt, auch da im forum. das teuerste ist eigentlich meist der versand von Ö nach D.
gibt aber sicher auch da im forum jemanden der für nen schmalen taler in D was drucken würde... -
@thomas-braun habe Deinen Rat befolgt und einen Pi4 mit 8 GB RAM gekauft. Hoffe damit ist das Speicherproblem erledigt.
2 Fragen:
mein alter Pi läuft im Netzwerk unter der 192.168.1.13 als Server. Ich habe diverse Homematic Programme, die auf diese IP zugreifen und keine Lust die alle in der HM anpassen zu müssen. In meiner Fritzbox (3490) nutze ich statisches DHCP. Heißt die IPs werden innerhalb der festgelegten Range automatisch vergeben ABER einmal vergeben, setze ich den Haken "Immer diese IP" verwenden. Gibt es eine Möglichkeit den neuen Pi mit der Alten IP Adresse zu betreiben?Kann ich irgendwie die komplette Konfiguration von meinem alten ioBroker (Adpater, Settings, blockly Skripte) jetzt auf den neuen Pi übertragen?
Mit einem Backup?
@thomas-braun nachdem ich beide Pis jetzt im Netzwerk habe (Pi alt = 192.168.1.13 / Pi neu = 192.168.1.150) habe ich gehofft ich kann mich beim alten irgendwie einloggen und das Backup triggern so dass es gleich rüber zu den neuen geschrieben wird. Geht sowas?
