    4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
    • N
      nick-night last edited by nick-night
      Ich habe da noch einige Warnmeldungen im log gefunden, vielleicht hilft das ja bei der Weiterentwicklung.
      homeconnect.0
      2023-12-03 13:23:48.114	info	SIEMENS-WM14U840EU-68A40E343E3E/programs/available/LaundryCare.Washer.Program.Cotton: Program currently not available.
      homeconnect.0
      2023-12-03 13:23:19.182	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "3960" greater than max "null"
      homeconnect.0
      2023-12-03 13:23:19.138	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress" has value "40" greater than max "null"
      homeconnect.0
      2023-12-03 13:22:49.047	info	SIEMENS-WM14U840EU-68A40E343E3E/programs/available/LaundryCare.Washer.Program.Sensitive: Program currently not available.
      homeconnect.0
      2023-12-03 13:22:19.141	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4020" greater than max "null"
      homeconnect.0
      2023-12-03 13:22:13.117	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress" has value "39" greater than max "null"
      homeconnect.0
      2023-12-03 13:21:48.539	info	SIEMENS-WM14U840EU-68A40E343E3E/programs/available/LaundryCare.Washer.Program.DarkWash: Program currently not available.
      homeconnect.0
      2023-12-03 13:21:19.130	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4080" greater than max "null"
      homeconnect.0
      2023-12-03 13:21:07.127	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress" has value "38" greater than max "null"
      homeconnect.0
      2023-12-03 13:20:48.658	info	SIEMENS-WM14U840EU-68A40E343E3E/programs/available/LaundryCare.Washer.Program.DelicatesSilk: Program currently not available.
      homeconnect.0
      2023-12-03 13:20:19.185	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4140" greater than max "null"
      homeconnect.0
      2023-12-03 13:20:01.127	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress" has value "37" greater than max "null"
      homeconnect.0
      2023-12-03 13:19:48.077	info	SIEMENS-WM14U840EU-68A40E343E3E/programs/available/LaundryCare.Washer.Program.Wool: Program currently not available.
      homeconnect.0
      2023-12-03 13:19:19.130	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4200" greater than max "null"
      homeconnect.0
      2023-12-03 13:18:55.140	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress" has value "36" greater than max "null"
      homeconnect.0
      2023-12-03 13:18:48.976	info	SIEMENS-WM14U840EU-68A40E343E3E/programs/available/LaundryCare.Washer.Program.Curtains: Program currently not available.
      homeconnect.0
      2023-12-03 13:18:48.930	warn	This object will not be created in future versions. Please report this to the developer.
      homeconnect.0
      2023-12-03 13:18:48.929	warn	Object homeconnect.0.SIEMENS-LC97FVV60-68A40E2D00B4.programs.available.options.Cooking_Common_Option_Hood_VentingLevel is invalid: obj.common.min has an invalid type! Expected "number", received "object"
      homeconnect.0
      2023-12-03 13:18:19.179	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4260" greater than max "null"
      homeconnect.0
      2023-12-03 13:17:49.117	info	SIEMENS-KI86SHD40-68A40E2F7C09/programs: Operation not supported for HomeAppliance type FridgeFreezer.
      homeconnect.0
      2023-12-03 13:17:49.113	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress" has value "35" greater than max "null"
      homeconnect.0
      2023-12-03 13:17:19.127	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4320" greater than max "null"
      homeconnect.0
      2023-12-03 13:16:50.042	info	SIEMENS-WM14U840EU-68A40E343E3E/programs/available/LaundryCare.Washer.Program.Cotton.CottonEco: Program currently not available.
      homeconnect.0
      2023-12-03 13:16:43.109	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress" has value "34" greater than max "null"
      homeconnect.0
      2023-12-03 13:16:19.178	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4380" greater than max "null"
      homeconnect.0
      2023-12-03 13:15:48.020	info	SIEMENS-KI86SHD40-68A40E2F7C09/programs/selected: Operation not supported for HomeAppliance type FridgeFreezer.
      homeconnect.0
      2023-12-03 13:15:36.589	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress" has value "33" greater than max "null"
      homeconnect.0
      2023-12-03 13:15:18.606	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4440" greater than max "null"
      homeconnect.0
      2023-12-03 13:14:48.071	info	SIEMENS-WM14U840EU-68A40E343E3E/programs/available/LaundryCare.Washer.Program.WaterProof: Program currently not available.
      homeconnect.0
      2023-12-03 13:14:30.589	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress" has value "32" greater than max "null"
      homeconnect.0
      2023-12-03 13:14:18.647	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4500" greater than max "null"
      homeconnect.0
      2023-12-03 13:13:48.135	info	SIEMENS-WM14U840EU-68A40E343E3E/programs/available/LaundryCare.Washer.Program.DownDuvet.Duvet: Program currently not available.
      homeconnect.0
      2023-12-03 13:13:24.584	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress" has value "31" greater than max "null"
      homeconnect.0
      2023-12-03 13:13:18.610	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4560" greater than max "null"
      homeconnect.0
      2023-12-03 13:12:48.257	info	SIEMENS-LC97FVV60-68A40E2D00B4/programs/selected/options: There is no program selected.
      homeconnect.0
      2023-12-03 13:12:18.666	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4620" greater than max "null"
      homeconnect.0
      2023-12-03 13:12:18.624	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress" has value "30" greater than max "null"
      homeconnect.0
      2023-12-03 13:11:48.544	info	SIEMENS-KI86SHD40-68A40E2F7C09/programs/selected/options: Operation not supported for HomeAppliance type FridgeFreezer.
      homeconnect.0
      2023-12-03 13:11:18.649	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4680" greater than max "null"
      homeconnect.0
      2023-12-03 13:11:12.590	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress" has value "29" greater than max "null"
      homeconnect.0
      2023-12-03 13:10:48.067	info	SIEMENS-KI86SHD40-68A40E2F7C09/programs/active: Operation not supported for HomeAppliance type FridgeFreezer.
      homeconnect.0
      2023-12-03 13:10:18.653	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4740" greater than max "null"
      homeconnect.0
      2023-12-03 13:10:06.589	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress" has value "28" greater than max "null"
      homeconnect.0
      2023-12-03 13:09:48.179	info	SIEMENS-LC97FVV60-68A40E2D00B4/programs/active/options: There is no program active.
      homeconnect.0
      2023-12-03 13:09:48.141	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_WaterForecast" has value "80" greater than max "null"
      homeconnect.0
      2023-12-03 13:09:48.139	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_EnergyForecast" has value "80" greater than max "null"
      homeconnect.0
      2023-12-03 13:09:48.124	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4771" greater than max "null"
      homeconnect.0
      2023-12-03 13:09:48.123	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress" has value "27" greater than max "null"
      homeconnect.0
      2023-12-03 13:09:48.120	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_EstimatedTotalProgramTime" has value "6600" greater than max "null"
      homeconnect.0
      2023-12-03 13:09:18.601	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4800" greater than max "null"
      homeconnect.0
      2023-12-03 13:09:00.585	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress" has value "27" greater than max "null"
      homeconnect.0
      2023-12-03 13:08:48.689	info	SIEMENS-KI86SHD40-68A40E2F7C09/programs/active/options: Operation not supported for HomeAppliance type FridgeFreezer.
      homeconnect.0
      2023-12-03 13:08:18.602	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4860" greater than max "null"
      homeconnect.0
      2023-12-03 13:07:54.599	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress" has value "26" greater than max "null"
      homeconnect.0
      2023-12-03 13:07:48.810	info	SIEMENS-HN678G4S6-68A40E31A2B9/programs/available/Cooking.Oven.Program.HeatingMode.SabbathProgramme: Program currently not available.
      homeconnect.0
      2023-12-03 13:07:18.600	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4920" greater than max "null"
      homeconnect.0
      2023-12-03 13:06:52.205	warn	This object will not be created in future versions. Please report this to the developer.
      homeconnect.0
      2023-12-03 13:06:52.204	warn	Object homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.status.BSH_Common_Status_OperationState is invalid: obj.common.min has an invalid type! Expected "number", received "object"
      homeconnect.0
      2023-12-03 13:06:52.203	warn	This object will not be created in future versions. Please report this to the developer.
      homeconnect.0
      2023-12-03 13:06:52.203	warn	Object homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.status.BSH_Common_Status_DoorState is invalid: obj.common.min has an invalid type! Expected "number", received "object"
      homeconnect.0
      2023-12-03 13:06:51.837	info	No array: selected
      homeconnect.0
      2023-12-03 13:06:51.828	info	No array: active
      homeconnect.0
      2023-12-03 13:06:51.445	info	SIEMENS-LC97FVV60-68A40E2D00B4/programs/selected: There is no program selected.
      homeconnect.0
      2023-12-03 13:06:51.376	info	State value to set for "homeconnect.0.SIEMENS-LC97FVV60-68A40E2D00B4.status.BSH_Common_Status_RemoteControlStartAllowed" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:06:51.375	info	State value to set for "homeconnect.0.SIEMENS-LC97FVV60-68A40E2D00B4.status.BSH_Common_Status_RemoteControlActive" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:06:51.371	info	No array: selected
      homeconnect.0
      2023-12-03 13:06:51.369	info	No array: active
      homeconnect.0
      2023-12-03 13:06:51.346	info	State value to set for "homeconnect.0.SIEMENS-LC97FVV60-68A40E2D00B4.status.BSH_Common_Status_LocalControlActive" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:06:51.345	info	State value to set for "homeconnect.0.SIEMENS-HN678G4S6-68A40E31A2B9.status.Cooking_Oven_Status_CurrentCavityTemperature" has to be stringified but received type "number"
      homeconnect.0
      2023-12-03 13:06:51.344	info	State value to set for "homeconnect.0.SIEMENS-HN678G4S6-68A40E31A2B9.status.BSH_Common_Status_RemoteControlActive" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:06:51.328	info	State value to set for "homeconnect.0.SIEMENS-HN678G4S6-68A40E31A2B9.status.BSH_Common_Status_RemoteControlStartAllowed" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:06:51.326	info	State value to set for "homeconnect.0.SIEMENS-HN678G4S6-68A40E31A2B9.status.BSH_Common_Status_LocalControlActive" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:06:51.278	info	State value to set for "homeconnect.0.SIEMENS-EX875KYW1E-68A40E29964A.status.BSH_Common_Status_RemoteControlActive" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:06:51.246	info	State value to set for "homeconnect.0.SIEMENS-EX875KYW1E-68A40E29964A.status.BSH_Common_Status_LocalControlActive" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:06:51.202	info	SIEMENS-LC97FVV60-68A40E2D00B4/programs/active: There is no program active.
      homeconnect.0
      2023-12-03 13:06:51.192	info	No array: selected
      homeconnect.0
      2023-12-03 13:06:51.182	info	No array: active
      homeconnect.0
      2023-12-03 13:06:51.161	info	SIEMENS-HN678G4S6-68A40E31A2B9/programs/selected/options: There is no program selected.
      homeconnect.0
      2023-12-03 13:06:51.157	info	SIEMENS-HN678G4S6-68A40E31A2B9/programs/selected: There is no program selected.
      homeconnect.0
      2023-12-03 13:06:51.154	info	SIEMENS-HN678G4S6-68A40E31A2B9/programs/active/options: There is no program active.
      homeconnect.0
      2023-12-03 13:06:51.149	info	SIEMENS-HN678G4S6-68A40E31A2B9/programs/active: There is no program active.
      homeconnect.0
      2023-12-03 13:06:51.051	info	SIEMENS-EX875KYW1E-68A40E29964A/programs/selected: There is no program selected.
      homeconnect.0
      2023-12-03 13:06:51.039	info	SIEMENS-EX875KYW1E-68A40E29964A/programs/active: There is no program active.
      homeconnect.0
      2023-12-03 13:06:51.035	info	No available programs found for: SIEMENS-EX875KYW1E-68A40E29964A
      homeconnect.0
      2023-12-03 13:06:51.034	info	No array: selected
      homeconnect.0
      2023-12-03 13:06:51.033	info	No array: active
      homeconnect.0
      2023-12-03 13:06:51.019	info	SIEMENS-EX875KYW1E-68A40E29964A/programs/selected/options: There is no program selected.
      homeconnect.0
      2023-12-03 13:06:51.010	info	SIEMENS-EX875KYW1E-68A40E29964A/programs/active/options: There is no program active.
      homeconnect.0
      2023-12-03 13:06:50.702	info	State value to set for "homeconnect.0.SIEMENS-KI86SHD40-68A40E2F7C09.general.connected" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:06:50.184	info	State value to set for "homeconnect.0.SIEMENS-SN578S26TE-68A40E022F3B.status.BSH_Common_Status_RemoteControlStartAllowed" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:06:50.178	info	State value to set for "homeconnect.0.SIEMENS-SN578S26TE-68A40E022F3B.status.BSH_Common_Status_RemoteControlActive" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:06:50.133	info	No array: selected
      homeconnect.0
      2023-12-03 13:06:50.129	info	No array: active
      homeconnect.0
      2023-12-03 13:06:50.103	info	SIEMENS-SN578S26TE-68A40E022F3B/programs/active/options: There is no program active.
      homeconnect.0
      2023-12-03 13:06:50.095	info	SIEMENS-SN578S26TE-68A40E022F3B/programs/active: There is no program active.
      homeconnect.0
      2023-12-03 13:06:50.089	info	State value to set for "homeconnect.0.SIEMENS-LC97FVV60-68A40E2D00B4.general.connected" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:06:50.076	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress" has value "100" greater than max "null"
      homeconnect.0
      2023-12-03 13:06:49.747	info	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.general.connected" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:06:49.668	info	State value to set for "homeconnect.0.SIEMENS-WT47X940EU-68A40E36358D.general.connected" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:06:49.288	info	State value to set for "homeconnect.0.SIEMENS-HN678G4S6-68A40E31A2B9.general.connected" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:06:48.907	info	State value to set for "homeconnect.0.SIEMENS-EX875KYW1E-68A40E29964A.general.connected" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:06:48.572	info	State value to set for "homeconnect.0.SIEMENS-SN578S26TE-68A40E022F3B.general.connected" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:06:48.553	info	Found 7 devices
      homeconnect.0
      2023-12-03 13:06:47.841	info	starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v18.18.2, js-controller: 5.0.17
      homeconnect.0
      2023-12-03 13:06:47.596	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      homeconnect.0
      2023-12-03 13:06:42.389	info	terminating
      homeconnect.0
      2023-12-03 13:06:41.887	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      homeconnect.0
      2023-12-03 13:06:41.884	info	terminating
      homeconnect.0
      2023-12-03 13:06:41.882	info	Got terminate signal TERMINATE_YOURSELF
      Hier noch der Debug Mode, den Token habe ich mal raus gelöscht.
      homeconnect.0
      2023-12-03 13:39:19.722	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "3000" greater than max "null"
      homeconnect.0
      2023-12-03 13:39:19.718	debug	Set event state
      homeconnect.0
      2023-12-03 13:39:19.714	debug	SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime:3000
      homeconnect.0
      2023-12-03 13:39:19.713	debug	event: {"type":"NOTIFY","data":"{\"haId\":\"SIEMENS-WM14U840EU-68A40E343E3E\",\"items\":[{\"handling\":\"none\",\"key\":\"BSH.Common.Option.RemainingProgramTime\",\"level\":\"hint\",\"timestamp\":1701607159,\"unit\":\"seconds\",\"uri\":\"/api/homeappliances/SIEMENS-WM14U840EU-68A40E343E3E/programs/active/options/BSH.Common.Option.RemainingProgramTime\",\"value\":3000}]}","lastEventId":"SIEMENS-WM14U840EU-68A40E343E3E","origin":"https://api.home-connect.com"}
      homeconnect.0
      2023-12-03 13:38:43.655	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress" has value "54" greater than max "null"
      homeconnect.0
      2023-12-03 13:38:43.650	debug	Set event state
      homeconnect.0
      2023-12-03 13:38:43.647	debug	SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_ProgramProgress:54
      homeconnect.0
      2023-12-03 13:38:43.646	debug	event: {"type":"NOTIFY","data":"{\"haId\":\"SIEMENS-WM14U840EU-68A40E343E3E\",\"items\":[{\"handling\":\"none\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"level\":\"hint\",\"timestamp\":1701607123,\"unit\":\"%\",\"uri\":\"/api/homeappliances/SIEMENS-WM14U840EU-68A40E343E3E/programs/active/options/BSH.Common.Option.ProgramProgress\",\"value\":54}]}","lastEventId":"SIEMENS-WM14U840EU-68A40E343E3E","origin":"https://api.home-connect.com"}
      homeconnect.0
      2023-12-03 13:38:29.349	debug	Extend Settings: SIEMENS-KI86SHD40-68A40E2F7C09.settings.Refrigeration_FridgeFreezer_Setting_SuperModeFreezer
      homeconnect.0
      2023-12-03 13:38:29.349	debug	{"data":{"name":"superGefrieren","key":"Refrigeration.FridgeFreezer.Setting.SuperModeFreezer","constraints":{"default":false,"access":"readWrite"},"type":"Boolean","value":false}}
      homeconnect.0
      2023-12-03 13:38:29.348	debug	/settings/Refrigeration.FridgeFreezer.Setting.SuperModeFreezer
      homeconnect.0
      2023-12-03 13:38:29.348	debug	{"data":{"name":"superGefrieren","key":"Refrigeration.FridgeFreezer.Setting.SuperModeFreezer","constraints":{"default":false,"access":"readWrite"},"type":"Boolean","value":false}}
      homeconnect.0
      2023-12-03 13:38:29.194	debug	Extend Settings: SIEMENS-KI86SHD40-68A40E2F7C09.settings.Refrigeration_Common_Setting_VacationMode
      homeconnect.0
      2023-12-03 13:38:29.194	debug	{"data":{"name":"Urlaubs-Modus","key":"Refrigeration.Common.Setting.VacationMode","constraints":{"access":"readWrite"},"type":"Boolean","value":false}}
      homeconnect.0
      2023-12-03 13:38:29.194	debug	/settings/Refrigeration.Common.Setting.VacationMode
      homeconnect.0
      2023-12-03 13:38:29.193	debug	{"data":{"name":"Urlaubs-Modus","key":"Refrigeration.Common.Setting.VacationMode","constraints":{"access":"readWrite"},"type":"Boolean","value":false}}
      homeconnect.0
      2023-12-03 13:38:29.044	debug	Extend Settings: SIEMENS-KI86SHD40-68A40E2F7C09.settings.Refrigeration_FridgeFreezer_Setting_SetpointTemperatureFreezer
      homeconnect.0
      2023-12-03 13:38:29.044	debug	{"data":{"name":"Temperatur Gefrierfach","key":"Refrigeration.FridgeFreezer.Setting.SetpointTemperatureFreezer","constraints":{"min":-24,"max":-16,"default":-18,"access":"readWrite"},"unit":"°C","type":"Double","value":-18}}
      homeconnect.0
      2023-12-03 13:38:29.044	debug	/settings/Refrigeration.FridgeFreezer.Setting.SetpointTemperatureFreezer
      homeconnect.0
      2023-12-03 13:38:29.043	debug	{"data":{"name":"Temperatur Gefrierfach","key":"Refrigeration.FridgeFreezer.Setting.SetpointTemperatureFreezer","constraints":{"min":-24,"max":-16,"default":-18,"access":"readWrite"},"unit":"°C","type":"Double","value":-18}}
      homeconnect.0
      2023-12-03 13:38:28.829	debug	Extend Settings: SIEMENS-KI86SHD40-68A40E2F7C09.settings.BSH_Common_Setting_PowerState
      homeconnect.0
      2023-12-03 13:38:28.829	debug	{"data":{"name":"Energiezustand","key":"BSH.Common.Setting.PowerState","constraints":{"allowedvalues":["BSH.Common.EnumType.PowerState.MainsOff","BSH.Common.EnumType.PowerState.Off","BSH.Common.EnumType.PowerState.On","BSH.Common.EnumType.PowerState.Standby"],"displayvalues":["Aus","Aus","An","Standby"],"default":"BSH.Common.EnumType.PowerState.On","access":"read"},"type":"BSH.Common.EnumType.PowerState","displayvalue":"An","value":"BSH.Common.EnumType.PowerState.On"}}
      homeconnect.0
      2023-12-03 13:38:28.828	debug	/settings/BSH.Common.Setting.PowerState
      homeconnect.0
      2023-12-03 13:38:28.828	debug	{"data":{"name":"Energiezustand","key":"BSH.Common.Setting.PowerState","constraints":{"allowedvalues":["BSH.Common.EnumType.PowerState.MainsOff","BSH.Common.EnumType.PowerState.Off","BSH.Common.EnumType.PowerState.On","BSH.Common.EnumType.PowerState.Standby"],"displayvalues":["Aus","Aus","An","Standby"],"default":"BSH.Common.EnumType.PowerState.On","access":"read"},"type":"BSH.Common.EnumType.PowerState","displayvalue":"An","value":"BSH.Common.EnumType.PowerState.On"}}
      homeconnect.0
      2023-12-03 13:38:28.562	debug	Extend Settings: SIEMENS-KI86SHD40-68A40E2F7C09.settings.Refrigeration_FridgeFreezer_Setting_SuperModeRefrigerator
      homeconnect.0
      2023-12-03 13:38:28.562	debug	{"data":{"name":"superKühlen","key":"Refrigeration.FridgeFreezer.Setting.SuperModeRefrigerator","constraints":{"default":false,"access":"readWrite"},"type":"Boolean","value":false}}
      homeconnect.0
      2023-12-03 13:38:28.561	debug	/settings/Refrigeration.FridgeFreezer.Setting.SuperModeRefrigerator
      homeconnect.0
      2023-12-03 13:38:28.560	debug	{"data":{"name":"superKühlen","key":"Refrigeration.FridgeFreezer.Setting.SuperModeRefrigerator","constraints":{"default":false,"access":"readWrite"},"type":"Boolean","value":false}}
      homeconnect.0
      2023-12-03 13:38:28.499	debug	Set default value
      homeconnect.0
      2023-12-03 13:38:28.488	debug	Extend Settings: SIEMENS-KI86SHD40-68A40E2F7C09.settings.Refrigeration_FridgeFreezer_Setting_SetpointTemperatureRefrigerator
      homeconnect.0
      2023-12-03 13:38:28.488	debug	{"data":{"name":"Temperatur Kühlfach","key":"Refrigeration.FridgeFreezer.Setting.SetpointTemperatureRefrigerator","constraints":{"min":2,"max":8,"default":4,"access":"readWrite"},"unit":"°C","type":"Double","value":6}}
      homeconnect.0
      2023-12-03 13:38:28.487	debug	/settings/Refrigeration.FridgeFreezer.Setting.SetpointTemperatureRefrigerator
      homeconnect.0
      2023-12-03 13:38:28.475	debug	{"data":{"name":"Temperatur Kühlfach","key":"Refrigeration.FridgeFreezer.Setting.SetpointTemperatureRefrigerator","constraints":{"min":2,"max":8,"default":4,"access":"readWrite"},"unit":"°C","type":"Double","value":6}}
      homeconnect.0
      2023-12-03 13:38:28.440	debug	Extend Options: SIEMENS-LC97FVV60-68A40E2D00B4.programs.available.options.Cooking_Common_Option_Hood_IntensiveLevel
      homeconnect.0
      2023-12-03 13:38:28.427	warn	This object will not be created in future versions. Please report this to the developer.
      homeconnect.0
      2023-12-03 13:38:28.426	warn	Object homeconnect.0.SIEMENS-LC97FVV60-68A40E2D00B4.programs.available.options.Cooking_Common_Option_Hood_VentingLevel is invalid: obj.common.min has an invalid type! Expected "number", received "object"
      homeconnect.0
      2023-12-03 13:38:28.421	debug	Extend common option: homeconnect.0.SIEMENS-LC97FVV60-68A40E2D00B4.programs.available.options.Cooking_Common_Option_Hood_VentingLevel
      homeconnect.0
      2023-12-03 13:38:28.411	debug	Set default value
      homeconnect.0
      2023-12-03 13:38:28.395	debug	Extend Options: SIEMENS-LC97FVV60-68A40E2D00B4.programs.available.options.Cooking_Common_Option_Hood_VentingLevel
      homeconnect.0
      2023-12-03 13:38:28.394	debug	{"data":{"key":"Cooking.Common.Program.Hood.Venting","name":"Lüfterstufe","options":[{"key":"Cooking.Common.Option.Hood.VentingLevel","type":"Cooking.Hood.EnumType.Stage","constraints":{"allowedvalues":["Cooking.Hood.EnumType.Stage.FanStage01","Cooking.Hood.EnumType.Stage.FanStage02","Cooking.Hood.EnumType.Stage.FanStage03"],"displayvalues":["1","2","3"],"default":"Cooking.Hood.EnumType.Stage.FanStage02"},"name":"Lüfterstufe"},{"key":"Cooking.Common.Option.Hood.IntensiveLevel","type":"Cooking.Hood.EnumType.IntensiveStage","constraints":{"allowedvalues":["Cooking.Hood.EnumType.IntensiveStage.IntensiveStage1","Cooking.Hood.EnumType.IntensiveStage.IntensiveStage2"],"displayvalues":["Intensiv 1","Intensiv 2"]},"name":"Intensivstufen"}]}}
      homeconnect.0
      2023-12-03 13:38:28.393	debug	/programs/available/Cooking.Common.Program.Hood.Venting
      homeconnect.0
      2023-12-03 13:38:28.382	debug	{"data":{"key":"Cooking.Common.Program.Hood.Venting","name":"Lüfterstufe","options":[{"key":"Cooking.Common.Option.Hood.VentingLevel","type":"Cooking.Hood.EnumType.Stage","constraints":{"allowedvalues":["Cooking.Hood.EnumType.Stage.FanStage01","Cooking.Hood.EnumType.Stage.FanStage02","Cooking.Hood.EnumType.Stage.FanStage03"],"displayvalues":["1","2","3"],"default":"Cooking.Hood.EnumType.Stage.FanStage02"},"name":"Lüfterstufe"},{"key":"Cooking.Common.Option.Hood.IntensiveLevel","type":"Cooking.Hood.EnumType.IntensiveStage","constraints":{"allowedvalues":["Cooking.Hood.EnumType.IntensiveStage.IntensiveStage1","Cooking.Hood.EnumType.IntensiveStage.IntensiveStage2"],"displayvalues":["Intensiv 1","Intensiv 2"]},"name":"Intensivstufen"}]}}
      homeconnect.0
      2023-12-03 13:38:28.305	debug	{"data":{"key":"Cooking.Common.Program.Hood.DelayedShutOff","name":"Lüfternachlauf","options":[]}}
      homeconnect.0
      2023-12-03 13:38:28.304	debug	/programs/available/Cooking.Common.Program.Hood.DelayedShutOff
      homeconnect.0
      2023-12-03 13:38:28.294	debug	{"data":{"key":"Cooking.Common.Program.Hood.DelayedShutOff","name":"Lüfternachlauf","options":[]}}
      homeconnect.0
      2023-12-03 13:38:28.212	debug	{"data":{"key":"Cooking.Common.Program.Hood.Automatic","name":"Automatikbetrieb","options":[]}}
      homeconnect.0
      2023-12-03 13:38:28.212	debug	/programs/available/Cooking.Common.Program.Hood.Automatic
      homeconnect.0
      2023-12-03 13:38:28.200	debug	{"data":{"key":"Cooking.Common.Program.Hood.Automatic","name":"Automatikbetrieb","options":[]}}
      homeconnect.0
      2023-12-03 13:38:27.999	debug	{"error":{"description":"Operation not supported for HomeAppliance type FridgeFreezer","key":"SDK.Error.UnsupportedOperation"}}
      homeconnect.0
      2023-12-03 13:38:27.999	info	SIEMENS-KI86SHD40-68A40E2F7C09/programs/selected/options: Operation not supported for HomeAppliance type FridgeFreezer.
      homeconnect.0
      2023-12-03 13:38:27.970	debug	{"error":{"description":"Operation not supported for HomeAppliance type FridgeFreezer","key":"SDK.Error.UnsupportedOperation"}}
      homeconnect.0
      2023-12-03 13:38:27.969	info	SIEMENS-KI86SHD40-68A40E2F7C09/programs/active: Operation not supported for HomeAppliance type FridgeFreezer.
      homeconnect.0
      2023-12-03 13:38:27.888	debug	Set api value
      homeconnect.0
      2023-12-03 13:38:27.884	debug	Set api value
      homeconnect.0
      2023-12-03 13:38:27.883	debug	Set api value
      homeconnect.0
      2023-12-03 13:38:27.882	debug	Set api value
      homeconnect.0
      homeconnect.0
      2023-12-03 13:38:27.881	debug	Set api value
      homeconnect.0
      2023-12-03 13:38:27.872	debug	Create State: SIEMENS-KI86SHD40-68A40E2F7C09.settings.BSH_Common_Setting_PowerState
      homeconnect.0
      2023-12-03 13:38:27.872	debug	Create State: SIEMENS-KI86SHD40-68A40E2F7C09.settings.Refrigeration_Common_Setting_VacationMode
      homeconnect.0
      2023-12-03 13:38:27.871	debug	Create State: SIEMENS-KI86SHD40-68A40E2F7C09.settings.Refrigeration_FridgeFreezer_Setting_SuperModeRefrigerator
      homeconnect.0
      2023-12-03 13:38:27.871	debug	Create State: SIEMENS-KI86SHD40-68A40E2F7C09.settings.Refrigeration_FridgeFreezer_Setting_SuperModeFreezer
      homeconnect.0
      2023-12-03 13:38:27.870	debug	Create State: SIEMENS-KI86SHD40-68A40E2F7C09.settings.Refrigeration_FridgeFreezer_Setting_SetpointTemperatureRefrigerator
      homeconnect.0
      2023-12-03 13:38:27.870	debug	Create State: SIEMENS-KI86SHD40-68A40E2F7C09.settings.Refrigeration_FridgeFreezer_Setting_SetpointTemperatureFreezer
      homeconnect.0
      2023-12-03 13:38:27.869	debug	{"data":{"settings":[{"key":"Refrigeration.FridgeFreezer.Setting.SetpointTemperatureFreezer","value":-18,"unit":"°C","name":"Temperatur Gefrierfach"},{"key":"Refrigeration.FridgeFreezer.Setting.SetpointTemperatureRefrigerator","value":6,"unit":"°C","name":"Temperatur Kühlfach"},{"key":"Refrigeration.FridgeFreezer.Setting.SuperModeFreezer","value":false,"name":"superGefrieren"},{"key":"Refrigeration.FridgeFreezer.Setting.SuperModeRefrigerator","value":false,"name":"superKühlen"},{"key":"Refrigeration.Common.Setting.VacationMode","value":false,"name":"Urlaubs-Modus"},{"key":"BSH.Common.Setting.PowerState","value":"BSH.Common.EnumType.PowerState.On","name":"Energiezustand","displayvalue":"An"}]}}
      homeconnect.0
      2023-12-03 13:38:27.869	debug	/settings
      homeconnect.0
      2023-12-03 13:38:27.858	debug	{"data":{"settings":[{"key":"Refrigeration.FridgeFreezer.Setting.SetpointTemperatureFreezer","value":-18,"unit":"°C","name":"Temperatur Gefrierfach"},{"key":"Refrigeration.FridgeFreezer.Setting.SetpointTemperatureRefrigerator","value":6,"unit":"°C","name":"Temperatur Kühlfach"},{"key":"Refrigeration.FridgeFreezer.Setting.SuperModeFreezer","value":false,"name":"superGefrieren"},{"key":"Refrigeration.FridgeFreezer.Setting.SuperModeRefrigerator","value":false,"name":"superKühlen"},{"key":"Refrigeration.Common.Setting.VacationMode","value":false,"name":"Urlaubs-Modus"},{"key":"BSH.Common.Setting.PowerState","value":"BSH.Common.EnumType.PowerState.On","name":"Energiezustand","displayvalue":"An"}]}}
      homeconnect.0
      2023-12-03 13:38:27.212	debug	{"error":{"description":"There is no program active","key":"SDK.Error.NoProgramActive"}}
      homeconnect.0
      2023-12-03 13:38:27.211	info	SIEMENS-LC97FVV60-68A40E2D00B4/programs/active/options: There is no program active.
      homeconnect.0
      2023-12-03 13:38:26.515	debug	{"error":{"description":"There is no program selected","key":"SDK.Error.NoProgramSelected"}}
      homeconnect.0
      2023-12-03 13:38:26.514	info	SIEMENS-LC97FVV60-68A40E2D00B4/programs/selected/options: There is no program selected.
      homeconnect.0
      2023-12-03 13:38:26.409	debug	{"error":{"description":"Operation not supported for HomeAppliance type FridgeFreezer","key":"SDK.Error.UnsupportedOperation"}}
      homeconnect.0
      2023-12-03 13:38:26.408	info	SIEMENS-KI86SHD40-68A40E2F7C09/programs/selected: Operation not supported for HomeAppliance type FridgeFreezer.
      homeconnect.0
      2023-12-03 13:38:26.326	info	No array: selected
      homeconnect.0
      2023-12-03 13:38:26.326	debug	Create State: SIEMENS-LC97FVV60-68A40E2D00B4.programs.available.Cooking_Common_Program_Hood_DelayedShutOff
      homeconnect.0
      2023-12-03 13:38:26.325	debug	SIEMENS-LC97FVV60-68A40E2D00B4 available: {"constraints":{"available":true,"execution":"startonly"},"key":"Cooking.Common.Program.Hood.DelayedShutOff","name":"Lüfternachlauf"}
      homeconnect.0
      2023-12-03 13:38:26.325	debug	Create State: SIEMENS-LC97FVV60-68A40E2D00B4.programs.available.Cooking_Common_Program_Hood_Venting
      homeconnect.0
      2023-12-03 13:38:26.324	debug	SIEMENS-LC97FVV60-68A40E2D00B4 available: {"constraints":{"available":true,"execution":"startonly"},"key":"Cooking.Common.Program.Hood.Venting","name":"Lüfterstufe"}
      homeconnect.0
      2023-12-03 13:38:26.324	debug	Create State: SIEMENS-LC97FVV60-68A40E2D00B4.programs.available.Cooking_Common_Program_Hood_Automatic
      homeconnect.0
      2023-12-03 13:38:26.323	debug	SIEMENS-LC97FVV60-68A40E2D00B4 available: {"constraints":{"available":true,"execution":"startonly"},"key":"Cooking.Common.Program.Hood.Automatic","name":"Automatikbetrieb"}
      homeconnect.0
      2023-12-03 13:38:26.323	info	No array: active
      homeconnect.0
      2023-12-03 13:38:26.322	debug	{"data":{"active":{"constraints":{"access":"readWrite"}},"programs":[{"constraints":{"available":true,"execution":"startonly"},"key":"Cooking.Common.Program.Hood.Automatic","name":"Automatikbetrieb"},{"constraints":{"available":true,"execution":"startonly"},"key":"Cooking.Common.Program.Hood.Venting","name":"Lüfterstufe"},{"constraints":{"available":true,"execution":"startonly"},"key":"Cooking.Common.Program.Hood.DelayedShutOff","name":"Lüfternachlauf"}],"selected":{"constraints":{"access":"read"}}}}
      homeconnect.0
      2023-12-03 13:38:26.322	debug	/programs
      homeconnect.0
      2023-12-03 13:38:26.310	debug	{"data":{"active":{"constraints":{"access":"readWrite"}},"programs":[{"constraints":{"available":true,"execution":"startonly"},"key":"Cooking.Common.Program.Hood.Automatic","name":"Automatikbetrieb"},{"constraints":{"available":true,"execution":"startonly"},"key":"Cooking.Common.Program.Hood.Venting","name":"Lüfterstufe"},{"constraints":{"available":true,"execution":"startonly"},"key":"Cooking.Common.Program.Hood.DelayedShutOff","name":"Lüfternachlauf"}],"selected":{"constraints":{"access":"read"}}}}
      homeconnect.0
      2023-12-03 13:38:19.670	warn	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "3060" greater than max "null"
      homeconnect.0
      2023-12-03 13:38:19.666	debug	Set event state
      homeconnect.0
      2023-12-03 13:38:19.664	debug	SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options.BSH_Common_Option_RemainingProgramTime:3060
      homeconnect.0
      2023-12-03 13:38:19.663	debug	event: {"type":"NOTIFY","data":"{\"haId\":\"SIEMENS-WM14U840EU-68A40E343E3E\",\"items\":[{\"handling\":\"none\",\"key\":\"BSH.Common.Option.RemainingProgramTime\",\"level\":\"hint\",\"timestamp\":1701607099,\"unit\":\"seconds\",\"uri\":\"/api/homeappliances/SIEMENS-WM14U840EU-68A40E343E3E/programs/active/options/BSH.Common.Option.RemainingProgramTime\",\"value\":3060}]}","lastEventId":"SIEMENS-WM14U840EU-68A40E343E3E","origin":"https://api.home-connect.com"}
      homeconnect.0
      2023-12-03 13:37:39.452	debug	Extend common option: homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.events.LaundryCare_Washer_Event_IDos2FillLevelPoor
      homeconnect.0
      2023-12-03 13:37:39.445	debug	Set event state
      homeconnect.0
      2023-12-03 13:37:39.442	debug	SIEMENS-WM14U840EU-68A40E343E3E.events.LaundryCare_Washer_Event_IDos2FillLevelPoor:BSH.Common.EnumType.EventPresentState.Confirmed
      homeconnect.0
      2023-12-03 13:37:39.440	debug	event: {"type":"EVENT","data":"{\"haId\":\"SIEMENS-WM14U840EU-68A40E343E3E\",\"items\":[{\"handling\":\"acknowledge\",\"key\":\"LaundryCare.Washer.Event.IDos2FillLevelPoor\",\"level\":\"warning\",\"timestamp\":1701607059,\"value\":\"BSH.Common.EnumType.EventPresentState.Confirmed\"}]}","lastEventId":"SIEMENS-WM14U840EU-68A40E343E3E","origin":"https://api.home-connect.com"}
      homeconnect.0
      2023-12-03 13:37:39.347	debug	Start EventStream
      homeconnect.0
      2023-12-03 13:37:39.346	info	Keep Alive failed Reconnect EventStream
      homeconnect.0
      2023-12-03 13:37:26.310	debug	{"error":{"description":"Operation not supported for HomeAppliance type FridgeFreezer","key":"SDK.Error.UnsupportedOperation"}}
      homeconnect.0
      2023-12-03 13:37:26.308	info	SIEMENS-KI86SHD40-68A40E2F7C09/programs: Operation not supported for HomeAppliance type FridgeFreezer.
      homeconnect.0
      2023-12-03 13:36:30.119	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 26 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:30.119	info	SIEMENS-LC97FVV60-68A40E2D00B4/settings: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 26 seconds..
      homeconnect.0
      2023-12-03 13:36:30.097	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 26 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:30.097	info	SIEMENS-WM14U840EU-68A40E343E3E/programs/selected/options: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 26 seconds..
      homeconnect.0
      2023-12-03 13:36:29.977	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 26 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:29.976	info	SIEMENS-LC97FVV60-68A40E2D00B4/programs/selected: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 26 seconds..
      homeconnect.0
      2023-12-03 13:36:29.963	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 26 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:29.962	info	SIEMENS-LC97FVV60-68A40E2D00B4/status: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 26 seconds..
      homeconnect.0
      2023-12-03 13:36:29.876	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 26 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:29.875	info	SIEMENS-KI86SHD40-68A40E2F7C09/status: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 26 seconds..
      homeconnect.0
      2023-12-03 13:36:29.862	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 26 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:29.862	info	SIEMENS-KI86SHD40-68A40E2F7C09/programs/active/options: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 26 seconds..
      homeconnect.0
      2023-12-03 13:36:29.553	debug	Delete: SIEMENS-KI86SHD40-68A40E2F7C09.programs.active.options
      homeconnect.0
      2023-12-03 13:36:29.553	debug	active.options.
      homeconnect.0
      2023-12-03 13:36:29.550	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 26 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:29.549	info	SIEMENS-WM14U840EU-68A40E343E3E/programs/active: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 26 seconds..
      homeconnect.0
      2023-12-03 13:36:29.527	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 26 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:29.526	info	SIEMENS-WM14U840EU-68A40E343E3E/programs: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 26 seconds..
      homeconnect.0
      2023-12-03 13:36:29.521	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 26 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:29.520	info	SIEMENS-LC97FVV60-68A40E2D00B4/programs/active: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 26 seconds..
      homeconnect.0
      2023-12-03 13:36:29.459	info	Too many requests. Please wait 24h.
      homeconnect.0
      2023-12-03 13:36:29.459	error	Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
      homeconnect.0
      2023-12-03 13:36:29.458	error	429 Too Many Requests
      homeconnect.0
      2023-12-03 13:36:29.350	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 27 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:29.349	info	SIEMENS-WM14U840EU-68A40E343E3E/programs/selected: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 27 seconds..
      homeconnect.0
      2023-12-03 13:36:29.337	debug	Start EventStream
      homeconnect.0
      2023-12-03 13:36:29.315	info	State value to set for "homeconnect.0.SIEMENS-KI86SHD40-68A40E2F7C09.general.connected" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:36:29.231	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 27 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:29.229	info	SIEMENS-WM14U840EU-68A40E343E3E/settings: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 27 seconds..
      homeconnect.0
      2023-12-03 13:36:29.077	debug	Delete: SIEMENS-LC97FVV60-68A40E2D00B4.programs.active.options
      homeconnect.0
      2023-12-03 13:36:29.077	debug	active.options.
      homeconnect.0
      2023-12-03 13:36:28.968	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 27 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.968	info	SIEMENS-EX875KYW1E-68A40E29964A/programs: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 27 seconds..
      homeconnect.0
      2023-12-03 13:36:28.904	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 27 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.904	info	SIEMENS-HN678G4S6-68A40E31A2B9/programs/active/options: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 27 seconds..
      homeconnect.0
      2023-12-03 13:36:28.895	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 27 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.895	info	SIEMENS-WM14U840EU-68A40E343E3E/programs/active/options: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 27 seconds..
      homeconnect.0
      2023-12-03 13:36:28.885	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 27 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.885	info	SIEMENS-WM14U840EU-68A40E343E3E/status: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 27 seconds..
      homeconnect.0
      2023-12-03 13:36:28.805	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 27 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.804	info	SIEMENS-EX875KYW1E-68A40E29964A/programs/active/options: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 27 seconds..
      homeconnect.0
      2023-12-03 13:36:28.758	info	State value to set for "homeconnect.0.SIEMENS-LC97FVV60-68A40E2D00B4.general.connected" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:36:28.733	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 27 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.732	info	SIEMENS-SN578S26TE-68A40E022F3B/programs/available/Dishcare.Dishwasher.Program.NightWash: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 27 seconds..
      homeconnect.0
      2023-12-03 13:36:28.669	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 27 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.668	info	SIEMENS-HN678G4S6-68A40E31A2B9/status: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 27 seconds..
      homeconnect.0
      2023-12-03 13:36:28.581	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 27 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.580	info	SIEMENS-HN678G4S6-68A40E31A2B9/settings: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 27 seconds..
      homeconnect.0
      2023-12-03 13:36:28.559	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 27 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.558	info	SIEMENS-EX875KYW1E-68A40E29964A/programs/selected: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 27 seconds..
      homeconnect.0
      2023-12-03 13:36:28.496	debug	Delete: SIEMENS-WM14U840EU-68A40E343E3E.programs.active.options
      homeconnect.0
      2023-12-03 13:36:28.495	debug	active.options.
      homeconnect.0
      2023-12-03 13:36:28.484	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 27 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.482	info	SIEMENS-EX875KYW1E-68A40E29964A/programs/selected/options: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 27 seconds..
      homeconnect.0
      2023-12-03 13:36:28.459	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 27 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.458	info	SIEMENS-SN578S26TE-68A40E022F3B/programs/available/Dishcare.Dishwasher.Program.Quick45: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 27 seconds..
      homeconnect.0
      2023-12-03 13:36:28.326	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 28 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.325	info	SIEMENS-HN678G4S6-68A40E31A2B9/programs: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 28 seconds..
      homeconnect.0
      2023-12-03 13:36:28.318	info	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.general.connected" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:36:28.305	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 28 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.305	info	SIEMENS-EX875KYW1E-68A40E29964A/status: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 28 seconds..
      homeconnect.0
      2023-12-03 13:36:28.278	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 28 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.277	info	SIEMENS-SN578S26TE-68A40E022F3B/programs/available/Dishcare.Dishwasher.Program.Auto3: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 28 seconds..
      homeconnect.0
      2023-12-03 13:36:28.227	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 28 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.227	info	SIEMENS-HN678G4S6-68A40E31A2B9/programs/selected/options: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 28 seconds..
      homeconnect.0
      2023-12-03 13:36:28.218	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 28 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.217	info	SIEMENS-SN578S26TE-68A40E022F3B/settings/BSH.Common.Setting.PowerState: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 28 seconds..
      homeconnect.0
      2023-12-03 13:36:28.209	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 28 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.209	info	SIEMENS-SN578S26TE-68A40E022F3B/programs/selected: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 28 seconds..
      homeconnect.0
      2023-12-03 13:36:28.190	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 28 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.189	info	SIEMENS-SN578S26TE-68A40E022F3B/programs/available/Dishcare.Dishwasher.Program.Auto1: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 28 seconds..
      homeconnect.0
      2023-12-03 13:36:28.152	info	State value to set for "homeconnect.0.SIEMENS-WT47X940EU-68A40E36358D.general.connected" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:36:28.042	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 28 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.041	info	SIEMENS-HN678G4S6-68A40E31A2B9/programs/active: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 28 seconds..
      homeconnect.0
      2023-12-03 13:36:28.029	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 28 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:28.028	info	SIEMENS-HN678G4S6-68A40E31A2B9/programs/selected: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 28 seconds..
      homeconnect.0
      2023-12-03 13:36:27.933	debug	Delete: SIEMENS-HN678G4S6-68A40E31A2B9.programs.active.options
      homeconnect.0
      2023-12-03 13:36:27.933	debug	active.options.
      homeconnect.0
      2023-12-03 13:36:27.922	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 28 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:27.922	info	SIEMENS-SN578S26TE-68A40E022F3B/status: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 28 seconds..
      homeconnect.0
      2023-12-03 13:36:27.915	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 28 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:27.914	info	SIEMENS-SN578S26TE-68A40E022F3B/programs/available/Dishcare.Dishwasher.Program.Glas40: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 28 seconds..
      homeconnect.0
      2023-12-03 13:36:27.779	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 28 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:27.778	info	SIEMENS-SN578S26TE-68A40E022F3B/programs/available/Dishcare.Dishwasher.Program.Eco50: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 28 seconds..
      homeconnect.0
      2023-12-03 13:36:27.766	info	State value to set for "homeconnect.0.SIEMENS-HN678G4S6-68A40E31A2B9.general.connected" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:36:27.680	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 28 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:27.679	info	SIEMENS-EX875KYW1E-68A40E29964A/settings: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 28 seconds..
      homeconnect.0
      2023-12-03 13:36:27.621	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 28 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:27.620	info	SIEMENS-SN578S26TE-68A40E022F3B/programs/selected/options: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 28 seconds..
      homeconnect.0
      2023-12-03 13:36:27.552	debug	Delete: SIEMENS-EX875KYW1E-68A40E29964A.programs.active.options
      homeconnect.0
      2023-12-03 13:36:27.551	debug	active.options.
      homeconnect.0
      2023-12-03 13:36:27.539	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 28 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:27.538	info	SIEMENS-EX875KYW1E-68A40E29964A/programs/active: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 28 seconds..
      homeconnect.0
      2023-12-03 13:36:27.463	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 28 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:27.462	info	SIEMENS-SN578S26TE-68A40E022F3B/programs/active/options: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 28 seconds..
      homeconnect.0
      2023-12-03 13:36:27.439	debug	{"error":{"description":"The rate limit \"50 calls in 1 minute\" was reached. Requests are blocked during the remaining period of 29 seconds.","key":"429"}}
      homeconnect.0
      2023-12-03 13:36:27.438	info	SIEMENS-SN578S26TE-68A40E022F3B/programs/active: The rate limit "50 calls in 1 minute" was reached. Requests are blocked during the remaining period of 29 seconds..
      homeconnect.0
      2023-12-03 13:36:27.419	debug	{"data":{"key":"Dishcare.Dishwasher.Program.PreRinse","name":"Vorspülen","options":[]}}
      homeconnect.0
      2023-12-03 13:36:27.418	debug	/programs/available/Dishcare.Dishwasher.Program.PreRinse
      homeconnect.0
      2023-12-03 13:36:27.416	debug	{"data":{"key":"Dishcare.Dishwasher.Program.PreRinse","name":"Vorspülen","options":[]}}
      homeconnect.0
      2023-12-03 13:36:27.362	debug	{"data":{"key":"Dishcare.Dishwasher.Program.Auto2","name":"Auto 45-65°C","options":[]}}
      homeconnect.0
      2023-12-03 13:36:27.362	debug	/programs/available/Dishcare.Dishwasher.Program.Auto2
      homeconnect.0
      2023-12-03 13:36:27.361	debug	{"data":{"key":"Dishcare.Dishwasher.Program.Auto2","name":"Auto 45-65°C","options":[]}}
      homeconnect.0
      2023-12-03 13:36:27.337	info	State value to set for "homeconnect.0.SIEMENS-EX875KYW1E-68A40E29964A.general.connected" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:36:27.284	debug	Set api value
      homeconnect.0
      2023-12-03 13:36:27.172	debug	Create State: SIEMENS-SN578S26TE-68A40E022F3B.settings.BSH_Common_Setting_PowerState
      homeconnect.0
      2023-12-03 13:36:27.172	debug	{"data":{"settings":[{"key":"BSH.Common.Setting.PowerState","value":"BSH.Common.EnumType.PowerState.Off","name":"Energiezustand","displayvalue":"Aus"}]}}
      homeconnect.0
      2023-12-03 13:36:27.171	debug	/settings
      homeconnect.0
      2023-12-03 13:36:27.170	debug	{"data":{"settings":[{"key":"BSH.Common.Setting.PowerState","value":"BSH.Common.EnumType.PowerState.Off","name":"Energiezustand","displayvalue":"Aus"}]}}
      homeconnect.0
      2023-12-03 13:36:27.152	info	No array: selected
      homeconnect.0
      2023-12-03 13:36:27.151	debug	Create State: SIEMENS-SN578S26TE-68A40E022F3B.programs.available.Dishcare_Dishwasher_Program_PreRinse
      homeconnect.0
      2023-12-03 13:36:27.151	debug	SIEMENS-SN578S26TE-68A40E022F3B available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.PreRinse","name":"Vorspülen"}
      homeconnect.0
      2023-12-03 13:36:27.150	debug	Create State: SIEMENS-SN578S26TE-68A40E022F3B.programs.available.Dishcare_Dishwasher_Program_Quick45
      homeconnect.0
      2023-12-03 13:36:27.150	debug	SIEMENS-SN578S26TE-68A40E022F3B available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.Quick45","name":"Schnell 45°C"}
      homeconnect.0
      2023-12-03 13:36:27.149	debug	Create State: SIEMENS-SN578S26TE-68A40E022F3B.programs.available.Dishcare_Dishwasher_Program_Glas40
      homeconnect.0
      2023-12-03 13:36:27.149	debug	SIEMENS-SN578S26TE-68A40E022F3B available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.Glas40","name":"Glas 40°C"}
      homeconnect.0
      2023-12-03 13:36:27.148	debug	Create State: SIEMENS-SN578S26TE-68A40E022F3B.programs.available.Dishcare_Dishwasher_Program_NightWash
      homeconnect.0
      2023-12-03 13:36:27.146	debug	SIEMENS-SN578S26TE-68A40E022F3B available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.NightWash","name":"Leise 50°C"}
      homeconnect.0
      2023-12-03 13:36:27.146	debug	Create State: SIEMENS-SN578S26TE-68A40E022F3B.programs.available.Dishcare_Dishwasher_Program_Eco50
      homeconnect.0
      2023-12-03 13:36:27.145	debug	SIEMENS-SN578S26TE-68A40E022F3B available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.Eco50","name":"Eco 50°C"}
      homeconnect.0
      2023-12-03 13:36:27.145	debug	Create State: SIEMENS-SN578S26TE-68A40E022F3B.programs.available.Dishcare_Dishwasher_Program_Auto3
      homeconnect.0
      2023-12-03 13:36:27.144	debug	SIEMENS-SN578S26TE-68A40E022F3B available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.Auto3","name":"Auto 65-75°C"}
      homeconnect.0
      2023-12-03 13:36:27.144	debug	Create State: SIEMENS-SN578S26TE-68A40E022F3B.programs.available.Dishcare_Dishwasher_Program_Auto2
      homeconnect.0
      2023-12-03 13:36:27.143	debug	SIEMENS-SN578S26TE-68A40E022F3B available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.Auto2","name":"Auto 45-65°C"}
      homeconnect.0
      2023-12-03 13:36:27.143	debug	Create State: SIEMENS-SN578S26TE-68A40E022F3B.programs.available.Dishcare_Dishwasher_Program_Auto1
      homeconnect.0
      2023-12-03 13:36:27.142	debug	SIEMENS-SN578S26TE-68A40E022F3B available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.Auto1","name":"Auto 35-45°C"}
      homeconnect.0
      2023-12-03 13:36:27.142	info	No array: active
      homeconnect.0
      2023-12-03 13:36:27.141	debug	{"data":{"active":{"constraints":{"access":"read"}},"programs":[{"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.Auto1","name":"Auto 35-45°C"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.Auto2","name":"Auto 45-65°C"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.Auto3","name":"Auto 65-75°C"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.Eco50","name":"Eco 50°C"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.NightWash","name":"Leise 50°C"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.Glas40","name":"Glas 40°C"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.Quick45","name":"Schnell 45°C"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.PreRinse","name":"Vorspülen"}],"selected":{"constraints":{"access":"read"},"key":"Dishcare.Dishwasher.Program.Auto3","name":"Auto 65-75°C","options":[{"key":"BSH.Common.Option.StartInRelative","value":0,"unit":"seconds","name":"Startzeit"},{"key":"Dishcare.Dishwasher.Option.IntensivZone","value":false,"name":"Intensiv Zone"},{"key":"Dishcare.Dishwasher.Option.VarioSpeedPlus","value":true,"name":"varioSpeed Plus"},{"key":"Dishcare.Dishwasher.Option.HalfLoad","value":false,"name":"Halbe Beladung"},{"key":"Dishcare.Dishwasher.Option.HygienePlus","value":false,"name":"HygienePlus"},{"key":"Dishcare.Dishwasher.Option.BrillianceDry","value":false,"name":"Glanztrocknen"}]}}}
      homeconnect.0
      2023-12-03 13:36:27.141	debug	/programs
      homeconnect.0
      2023-12-03 13:36:27.140	debug	{"data":{"active":{"constraints":{"access":"read"}},"programs":[{"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.Auto1","name":"Auto 35-45°C"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.Auto2","name":"Auto 45-65°C"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.Auto3","name":"Auto 65-75°C"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.Eco50","name":"Eco 50°C"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.NightWash","name":"Leise 50°C"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.Glas40","name":"Glas 40°C"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.Quick45","name":"Schnell 45°C"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"Dishcare.Dishwasher.Program.PreRinse","name":"Vorspülen"}],"selected":{"constraints":{"access":"read"},"key":"Dishcare.Dishwasher.Program.Auto3","name":"Auto 65-75°C","options":[{"key":"BSH.Common.Option.StartInRelative","value":0,"unit":"seconds","name":"Startzeit"},{"key":"Dishcare.Dishwasher.Option.IntensivZone","value":false,"name":"Intensiv Zone"},{"key":"Dishcare.Dishwasher.Option.VarioSpeedPlus","value":true,"name":"varioSpeed Plus"},{"key":"Dishcare.Dishwasher.Option.HalfLoad","value":false,"name":"Halbe Beladung"},{"key":"Dishcare.Dishwasher.Option.HygienePlus","value":false,"name":"HygienePlus"},{"key":"Dishcare.Dishwasher.Option.BrillianceDry","value":false,"name":"Glanztrocknen"}]}}}
      homeconnect.0
      2023-12-03 13:36:27.090	debug	Delete: SIEMENS-SN578S26TE-68A40E022F3B.programs.active.options
      homeconnect.0
      2023-12-03 13:36:27.088	debug	active.options.
      homeconnect.0
      2023-12-03 13:36:26.858	info	State value to set for "homeconnect.0.SIEMENS-SN578S26TE-68A40E022F3B.general.connected" has to be stringified but received type "boolean"
      homeconnect.0
      2023-12-03 13:36:26.794	info	Found 7 devices
      homeconnect.0
      2023-12-03 13:36:26.793	debug	{"data":{"homeappliances":[{"brand":"Siemens","connected":true,"enumber":"SN578S26TE/11","haId":"SIEMENS-SN578S26TE-68A40E022F3B","name":"Geschirrspüler","type":"Dishwasher","vib":"SN578S26TE"},{"brand":"Siemens","connected":true,"enumber":"EX875KYW1E/01","haId":"SIEMENS-EX875KYW1E-68A40E29964A","name":"Kochfeld","type":"Hob","vib":"EX875KYW1E"},{"brand":"Siemens","connected":true,"enumber":"HN678G4S6/63","haId":"SIEMENS-HN678G4S6-68A40E31A2B9","name":"Backofen","type":"Oven","vib":"HN678G4S6"},{"brand":"Siemens","connected":false,"enumber":"WT47X940EU/05","haId":"SIEMENS-WT47X940EU-68A40E36358D","name":"Trockner","type":"Dryer","vib":"WT47X940EU"},{"brand":"Siemens","connected":true,"enumber":"WM14U840EU/08","haId":"SIEMENS-WM14U840EU-68A40E343E3E","name":"Waschmaschine","type":"Washer","vib":"WM14U840EU"},{"brand":"Siemens","connected":true,"enumber":"LC97FVV60/04","haId":"SIEMENS-LC97FVV60-68A40E2D00B4","name":"Dunstabzugshaube","type":"Hood","vib":"LC97FVV60"},{"brand":"Siemens","connected":true,"enumber":"KI86SHD40/05","haId":"SIEMENS-KI86SHD40-68A40E2F7C09","name":"Kühl-Gefrier-Kombination","type":"FridgeFreezer","vib":"KI86SHD40"}]}}
      homeconnect.0
      2023-12-03 13:36:26.676	debug	Get device list
      homeconnect.0
      2023-12-03 13:36:26.673	debug	{"access_token":"TOKEN VON MIR GELÖSCHT!!!","scope":"CookProcessor-Monitor Dryer-Settings Hob Washer-Control Dryer-Monitor Settings IdentifyAppliance Control CleaningRobot Washer-Settings CoffeeMaker Washer CookProcessor-Settings Hob-Settings Oven-Monitor Hood-Control WasherDryer-Monitor Oven-Settings CoffeeMaker-Monitor Monitor Hob-Monitor WasherDryer-Control Dishwasher-Control Refrigerator-Control Dishwasher Dryer-Control CleaningRobot-Control WineCooler Freezer-Monitor WasherDryer Oven Refrigerator-Monitor Oven-Control CookProcessor Freezer Freezer-Settings WineCooler-Control WineCooler-Settings Dishwasher-Settings Hood Dryer FridgeFreezer-Monitor CleaningRobot-Settings Refrigerator Refrigerator-Settings Hob-Control Dishwasher-Monitor CoffeeMaker-Settings FridgeFreezer-Settings CleaningRobot-Monitor WineCooler-Monitor Freezer-Control CoffeeMaker-Control Washer-Monitor Hood-Monitor Hood-Settings FridgeFreezer-Control CookProcessor-Control WasherDryer-Settings","token_type":"Bearer"}
      homeconnect.0
      2023-12-03 13:36:26.206	debug	Refresh Token
      homeconnect.0
      2023-12-03 13:36:26.203	debug	Found current session
      homeconnect.0
      2023-12-03 13:36:26.123	info	starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v18.18.2, js-controller: 5.0.17
      homeconnect.0
      2023-12-03 13:36:25.916	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      homeconnect.0
      2023-12-03 13:36:25.908	debug	Plugin sentry Initialize Plugin (enabled=true)
        tombox @nick-night last edited by
        @nick-night komisch kann eigentlich nie passieren
        verhält sich die GitHub version genauso?
        • N
          nick-night @tombox last edited by nick-night
          @tombox
          kann ich dir nicht sagen, habe bisher immer die normale Version benutzt und regelmäßig upgedatet. Ich stecke da nicht so tief in der Materie wie ich auf die Github version update. Zumindest klappte ein einfaches installieren von Github aus nicht bei mir, das hat er einfach abgebrochen. Den Adapter deinstallieren und den von Github neu einrichten würde ich jetzt ungerne machen, bin froh das es soweit läuft.
          Die Waschmaschine lief zu dem Zeitpunkt als ich in das log geschaut habe. Vielleicht hilft die Info auch weiter.
            @nick-night Ok ja muss nicht sein
            du kannst auch programs.active.options.BSH_Common_Option_ProgramProgress löschen und adapter neustarten ob es dann weg ist
              saeft_2003 Most Active last edited by saeft_2003
              ist es möglich wenn an einer Spülmaschine der Fernstart aktiviert wurde, die Spülmaschine über den adapter starten zu lassen?
              Ich hab dafür kein DP gefunden 🤔
                ManfredHi last edited by
                @saeft_2003 sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                ja, in den Datenpunkt
                homeconnect.0.0xxxxxxxxxxxxxxxx.programs.active.BSH_Common_Root_ActiveProgram
                das gewünschte programm schreiben.
                Welche Programme es gibt und wie sie heißen steht unter
                homeconnect.0.0xxxxxxxxxxxxxxxx.programs.available
                • N
                  @tombox
                  danke werde es mal versuchen. Aktuell wenn nichts läuft ist das Log sauber.
                  homeconnect.0
                  2023-12-07 21:11:19.102	info	State value to set for "homeconnect.0.SIEMENS-HN678G4S6-68A40E31A2B9.status.Cooking_Oven_Status_CurrentCavityTemperature" has to be stringified but received type "number"
                  homeconnect.0
                  2023-12-07 21:11:19.100	info	State value to set for "homeconnect.0.SIEMENS-HN678G4S6-68A40E31A2B9.status.BSH_Common_Status_RemoteControlActive" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:11:19.088	info	State value to set for "homeconnect.0.SIEMENS-HN678G4S6-68A40E31A2B9.status.BSH_Common_Status_RemoteControlStartAllowed" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:11:19.086	info	State value to set for "homeconnect.0.SIEMENS-HN678G4S6-68A40E31A2B9.status.BSH_Common_Status_LocalControlActive" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:11:19.049	info	No array: selected
                  homeconnect.0
                  2023-12-07 21:11:19.044	info	No array: active
                  homeconnect.0
                  2023-12-07 21:11:19.041	info	SIEMENS-HN678G4S6-68A40E31A2B9/programs/selected: There is no program selected.
                  homeconnect.0
                  2023-12-07 21:11:19.038	info	SIEMENS-HN678G4S6-68A40E31A2B9/programs/active: There is no program active.
                  homeconnect.0
                  2023-12-07 21:11:19.033	info	SIEMENS-HN678G4S6-68A40E31A2B9/programs/active/options: There is no program active.
                  homeconnect.0
                  2023-12-07 21:11:19.030	info	SIEMENS-HN678G4S6-68A40E31A2B9/programs/selected/options: There is no program selected.
                  homeconnect.0
                  2023-12-07 21:11:18.848	info	State value to set for "homeconnect.0.SIEMENS-LC97FVV60-68A40E2D00B4.status.BSH_Common_Status_RemoteControlStartAllowed" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:11:18.846	info	State value to set for "homeconnect.0.SIEMENS-LC97FVV60-68A40E2D00B4.status.BSH_Common_Status_RemoteControlActive" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:11:18.837	info	State value to set for "homeconnect.0.SIEMENS-LC97FVV60-68A40E2D00B4.status.BSH_Common_Status_LocalControlActive" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:11:18.783	info	No array: selected
                  homeconnect.0
                  2023-12-07 21:11:18.778	info	No array: active
                  homeconnect.0
                  2023-12-07 21:11:18.762	info	SIEMENS-LC97FVV60-68A40E2D00B4/programs/selected: There is no program selected.
                  homeconnect.0
                  2023-12-07 21:11:18.753	info	SIEMENS-LC97FVV60-68A40E2D00B4/programs/selected/options: There is no program selected.
                  homeconnect.0
                  2023-12-07 21:11:18.751	info	SIEMENS-LC97FVV60-68A40E2D00B4/programs/active/options: There is no program active.
                  homeconnect.0
                  2023-12-07 21:11:18.748	info	SIEMENS-LC97FVV60-68A40E2D00B4/programs/active: There is no program active.
                  homeconnect.0
                  2023-12-07 21:11:18.109	info	SIEMENS-KI86SHD40-68A40E2F7C09/programs/active: Operation not supported for HomeAppliance type FridgeFreezer.
                  homeconnect.0
                  2023-12-07 21:11:18.015	info	SIEMENS-KI86SHD40-68A40E2F7C09/programs/selected: Operation not supported for HomeAppliance type FridgeFreezer.
                  homeconnect.0
                  2023-12-07 21:11:17.372	info	State value to set for "homeconnect.0.SIEMENS-SN578S26TE-68A40E022F3B.status.BSH_Common_Status_RemoteControlStartAllowed" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:11:17.370	info	State value to set for "homeconnect.0.SIEMENS-SN578S26TE-68A40E022F3B.status.BSH_Common_Status_RemoteControlActive" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:11:17.106	info	No array: selected
                  homeconnect.0
                  2023-12-07 21:11:17.102	info	No array: active
                  homeconnect.0
                  2023-12-07 21:11:17.081	info	SIEMENS-SN578S26TE-68A40E022F3B/programs/active: There is no program active.
                  homeconnect.0
                  2023-12-07 21:11:17.076	info	SIEMENS-SN578S26TE-68A40E022F3B/programs/active/options: There is no program active.
                  homeconnect.0
                  2023-12-07 21:11:16.952	info	State value to set for "homeconnect.0.SIEMENS-KI86SHD40-68A40E2F7C09.general.connected" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:11:16.947	info	SIEMENS-EX875KYW1E-68A40E29964A/programs/selected/options: There is no program selected.
                  homeconnect.0
                  2023-12-07 21:11:16.905	info	State value to set for "homeconnect.0.SIEMENS-EX875KYW1E-68A40E29964A.status.BSH_Common_Status_RemoteControlActive" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:11:16.904	info	State value to set for "homeconnect.0.SIEMENS-EX875KYW1E-68A40E29964A.status.BSH_Common_Status_LocalControlActive" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:11:16.831	info	SIEMENS-EX875KYW1E-68A40E29964A/programs/selected: There is no program selected.
                  homeconnect.0
                  2023-12-07 21:11:16.828	info	SIEMENS-EX875KYW1E-68A40E29964A/programs/active: There is no program active.
                  homeconnect.0
                  2023-12-07 21:11:16.824	info	No available programs found for: SIEMENS-EX875KYW1E-68A40E29964A
                  homeconnect.0
                  2023-12-07 21:11:16.824	info	No array: selected
                  homeconnect.0
                  2023-12-07 21:11:16.822	info	No array: active
                  homeconnect.0
                  2023-12-07 21:11:16.805	info	SIEMENS-EX875KYW1E-68A40E29964A/programs/active/options: There is no program active.
                  homeconnect.0
                  2023-12-07 21:11:16.571	info	State value to set for "homeconnect.0.SIEMENS-LC97FVV60-68A40E2D00B4.general.connected" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:11:16.462	info	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.general.connected" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:11:16.324	info	State value to set for "homeconnect.0.SIEMENS-WT47X940EU-68A40E36358D.general.connected" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:11:15.944	info	State value to set for "homeconnect.0.SIEMENS-HN678G4S6-68A40E31A2B9.general.connected" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:11:15.528	info	State value to set for "homeconnect.0.SIEMENS-EX875KYW1E-68A40E29964A.general.connected" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:11:15.167	info	State value to set for "homeconnect.0.SIEMENS-SN578S26TE-68A40E022F3B.general.connected" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:11:15.100	info	Found 7 devices
                  homeconnect.0
                  2023-12-07 21:11:14.378	info	starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v18.18.2, js-controller: 5.0.17
                  homeconnect.0
                  2023-12-07 21:11:14.176	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                  Habe jetzt mal sogar noch einige mehr raus gelöscht die urplötzlich Warnungen ausgegeben haben. Eine kommt aber immer wieder.
                  homeconnect.0
                  2023-12-07 21:28:45.350	info	SIEMENS-EX875KYW1E-68A40E29964A/programs/selected: There is no program selected.
                  homeconnect.0
                  2023-12-07 21:28:45.334	info	State value to set for "homeconnect.0.SIEMENS-WM14U840EU-68A40E343E3E.general.connected" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:28:45.332	warn	State value to set for "homeconnect.0.SIEMENS-HN678G4S6-68A40E31A2B9.programs.available.options.Cooking_Oven_Option_SetpointTemperature" has value "200" greater than max "150"
                  homeconnect.0
                  2023-12-07 21:28:45.215	info	SIEMENS-EX875KYW1E-68A40E29964A/programs/active/options: There is no program active.
                  homeconnect.0
                  2023-12-07 21:28:45.074	info	State value to set for "homeconnect.0.SIEMENS-WT47X940EU-68A40E36358D.general.connected" has to be stringified but received type "boolean"
                  homeconnect.0
                  2023-12-07 21:28:44.902	info	No array: selected
                  homeconnect.0
                  2023-12-07 21:28:44.894	info	No array: active
                  homeconnect.0
                  2023-12-07 21:28:44.825	info	No available programs found for: SIEMENS-EX875KYW1E-68A40E29964A
                    GrillSgt last edited by GrillSgt
                    habe mich heute auch mal etwas mit dem Adapter beschäftigt. Beim Trockner ist alles gut, bei der Kaffeemaschine meckert er aber etwas rum:
                    homeconnect.0
                    2023-12-10 12:15:16.163	error	{"data":{"active":{"constraints":{"access":"read"}},"programs":[{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Espresso","name":"Espresso"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Coffee","name":"Caffè Crema"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Cappuccino","name":"Cappuccino"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.LatteMacchiato","name":"Latte Macchiato"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.MilkFroth","name":"Milchschaum"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.HotWater","name":"Heißwasser"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.EspressoMacchiato","name":"Espresso Macchiato"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Ristretto","name":"Ristretto"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Americano","name":"Americano"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.FlatWhite","name":"Flat White"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Verlaengerter","name":"Verlängerter"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.RedEye","name":"Red Eye"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeConLeche","name":"Café con leche"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Garoto","name":"Garoto"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.WienerMelange","name":"Wiener Melange"}],"selected":{"constraints":{"access":"read"}}}}
                    homeconnect.0
                    2023-12-10 12:15:16.162	error	/programs
                    homeconnect.0
                    2023-12-10 12:15:16.162	error	TypeError: returnValue.data[item].forEach is not a function at Homeconnect.getAPIValues (/opt/iobroker/node_modules/iobroker.homeconnect/main.js:573:32) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                    homeconnect.0
                    2023-12-10 12:15:16.158	error	TypeError: returnValue.data[item].forEach is not a function
                      tombox @GrillSgt last edited by
                      @grillsgt mit v1.2.2?
                      G 2 Replies Last reply Reply Quote 0
                        GrillSgt @tombox last edited by
                        @tombox sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                        Ist mit 1.1.1 - der Stable Version.
                        Habe jetzt von GitHub die Version 1.2.2 draufgebügelt. Scheint als sei der Fehler damit nicht mehr vorhanden. Ich beobachte es aber noch ein paar Tage und melde mich.
                        Viele Grüße
                        • werner2000x
                          werner2000x last edited by
                          Ich habe den Brandmelder 2 und versuche vergeblich einen Alarm auszulösen um eine Alarmanlage zu simulieren.
                          Beim Status Alarm -> Status kann man zwar was einstellen s.Foto aber es passiert nichts.
                          Gibt es dazu eine Lösung?
                            Wie versprochen die Rückmeldung. Demnach ist der Fehler mit 1.2.2 nicht mehr vorhanden.
                            Schöne Feiertage!
                            Michael
                              Schöne Feiertage!
                              Michael
                              • Merlin123
                                Merlin123 last edited by
                                Idee gesucht:
                                Es kommt bei unserem Bosch Trockner immer mal wieder vor, dass der Kondenswasserbehälter voll ist und das Trocknen stoppt.
                                Leider habe ich noch keine Möglichkeit gefunden, dass über den Adapter auszuwerten. Der Trockner steht laut Status auf bereit.
                                Kann man das irgendwie direkt auswerten?
                                Meine Workaround Idee:
                                Ich triggere auf den Status und wenn der von Run auf Ready geht, ist (vermutlich) der Behälter voll. Nach Run geht er ja eigentlich auf Finished.
                                Hat jemand ne bessere Idee?
                                  arteck Developer Most Active @Merlin123 last edited by arteck
                                  @merlin123 sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                                  also wir machen den JEDESMAL leer.. 🙂 so pare ich mir den gang in den Keller wenn der voll sein sollte
                                    captainchaos666 last edited by
                                    hat es schon jemand hin bekommen bei einer Kaffemaschine die Favoriten aufzurufen.
                                    Mit: programs.active.BSH_Common_Root_ActiveProgram kann ich über die Objekte die Voreingestellten Kaffeesorten auswählen. Leider fehlt mir hier die Auswahl der Favoriten.
                                    Zum testen starte ich gerade noch meine Versuche aus den Objekten heraus, später per Skript wenn ich weiß wie ich auf meine Favoriten komme
                                    Unter selected.options finde ich zwar meine Favouriten, kann aber den Voreingestellten Kaffe nicht auswählen
                                    Vielen Dank für Eure Unterstützung
                                    Alex
                                    Frederik Buss T 2 Replies Last reply Reply Quote 0
                                    • Frederik Buss
                                      Frederik Buss @captainchaos666 last edited by
                                      @captainchaos666 Das geht leider nicht, zumindest ging es nicht, als ich das ausprobiert habe. Ich habe ewig lange eine Möglichkeit gesucht automatisch einen Favoriten auszuwählen, um nicht morgens noch im Halbschlaf auf Milchschaum zu drücken. Am Ende habe ich aufgegeben und wähle seitdem den Standardkaffee "ConsumerProducts.CoffeeMaker.Program.Beverage.Coffee" aus. Übrigens nicht per ActiveProgram sonder über den Datenpunkt SelectedProgram.
                                        TT-Tom last edited by TT-Tom
                                        @frederik-buss
                                        @captainchaos666
                                        muss es leider bestätigen, habe auch mehrere Kaffeesession durch, ohne Erfolg. Mache es auch wie Frederick.
                                          tombox @captainchaos666 last edited by
                                          @captainchaos666
                                          Vielleicht kann auch home connect direkt helfen
                                          https://developer.home-connect.com/support/contact
                                          wie man Favoriten starten kann
                                            captainchaos666 @Frederik Buss last edited by
                                            @frederik-buss
                                            Vielen Dank für Eure Rückmeldung. Du schreibst "wähle seitdem den Standardkaffee "ConsumerProducts.CoffeeMaker.Program.Beverage.Coffee""
                                            Es wird bei mir nur das Display umgeschaltet. Mit welchem Befehl startest du dann die Maschine?
                                            Frederik Buss 1 Reply Last reply Reply Quote 0
                                            bsh bsh home connect home connect homeconnect adapter
                                            195
                                            1373
                                            499262
