    4. Node-Red
    5. Shelly Plus 1PM über MQTTund Node Red schalten
    • mickym
      mickym Most Active @NetFritz last edited by mickym
      @netfritz Inzwischen solltest Du die Shellies direkt über einen command Ast schalten können:
             "id": "d775455e51c30f95",
             "type": "mqtt out",
             "z": "529512d1ca548981",
             "name": "",
             "topic": "shellyplus1pm-3c610579ce9c/command/switch:0",
             "qos": "",
             "retain": "",
             "respTopic": "",
             "contentType": "",
             "userProps": "",
             "correl": "",
             "expiry": "",
             "broker": "1239431927fd4b8e",
             "x": 890,
             "y": 680,
             "wires": []
             "id": "c4c7f1430c4a3e09",
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "on",
             "payloadType": "str",
             "x": 570,
             "y": 640,
             "wires": [
                     "d775455e51c30f95"
             "id": "b15f359e5ef4442e",
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "toggle",
             "x": 570,
             "y": 720,
             "wires": [
                     "d775455e51c30f95"
             "id": "e26c283cc02a643c",
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "off",
             "x": 570,
             "y": 680,
             "wires": [
                     "d775455e51c30f95"
             "id": "1239431927fd4b8e",
             "type": "mqtt-broker",
             "name": "",
             "broker": "192.168.2.6",
             "port": "1883",
             "clientid": "",
             "autoConnect": true,
             "usetls": false,
             "protocolVersion": "4",
             "keepalive": "60",
             "cleansession": true,
             "birthTopic": "",
             "birthQos": "0",
             "birthPayload": "",
             "birthMsg": {},
             "closeTopic": "",
             "closeQos": "0",
             "closePayload": "",
             "closeMsg": {},
             "willTopic": "",
             "willQos": "0",
             "willPayload": "",
             "willMsg": {},
             "userProps": "",
             "sessionExpiry": ""
      über den rpc Datenpunkt kannst Du auch schalten, musst Du aber nicht mehr.
        Philipp 5 @mickym last edited by
        @mickym Hi, ich sitz jetzt seit 3h dran 😬 . Kannst du mir den Inhalt von z.B off schicken und der MqttOut posten?
        • mickym
          mickym Most Active @Philipp 5 last edited by
          @philipp-5 Na so wie Du es in der Abbildung siehst. Am Anfang steht halt dein Shelly und dann
          ..../command/switch:0
          halt mit den Doppelpunkt und Deinem Pfad zum Gerät
            @mickym ... joa.. und im inject einfach als string off schreiben ?
            • mickym
              mickym Most Active @Philipp 5 last edited by mickym
              @philipp-5 ja off/on/toogle also EINS von den dreien. Aber nur wenn es ein Gerät der 2. Generation ist. Bei Geräten der 1. Generation ist der Pfad anders. Was hast Du denn?
                @mickym Hab einen Plug S. Danke dir.. Ich glaube dann liegt mein Problem woanders.
                Kann ihn auslesen aber über command geht nichts.
                • mickym
                  @philipp-5 Na die PlugS sind vielleicht Generation 1 - warte da schaut das anders aus. Da musst Du das command unter relay/0 machen.
                  Also
                  .../relay/0/command
                    @mickym
                    oh man...
                    ich mach erstmal feierabend für Heute. Hast mir trotzdem schon geholfen, vielen Dank!
                    • mickym
                      @philipp-5 Hat es geklappt?
                        @mickym
                        nope 😞
                        • mickym
                          @philipp-5
                          Na ich seh schon - das ist eine 2.Generation - aber es fehlt das command topic!!!
                          shelly1/command/switch:0
                          Ich seh kein command Ast
                          Wichtig ist, dass die neueste Firmware drauf ist - die ersten konnten das noch nicht, da musstest Du über den rpc Punkt gehen.
                            @mickym
                            hab es eben nochmal versucht und einfach mal einen Factory-Reset durchgeführt.
                            Jetzt gehen die ".../command/swich:0" Befehle auf wundersame weise. Es gibt gerade eine optionale Beta-Firmware. Vielleicht hängt es damit zusammen.
                            Danke dir trotzdem für die Hilfe!
                            2658
