    4. Test Freestyle Libre LibreLinkUp
    • Skyx3
      Skyx3 @Skyx3 last edited by Skyx3
      Einfach nur für die Akten, mit dem folgenden Blockly kann man das Objekt (Hex-DAtum) konvertieren und dann das alter des Sensor in Tage und Stunden berechnen / darstellen.
      Der Alias "letzter Tausch" linkt auf libre.X.general.sensor.a
        <variables>
          <variable id="#vzG9aWhz|;gfN4n)T6g">alter</variable>
          <variable id=".J)CTmL9ogje^96O(sCE">restlaufzeit</variable>
          <variable id="|ID!mE{~=VpHFy^j]V!1">Alter Sensor</variable>
        </variables>
        <block type="schedule" id="hhTY:!Sd4rKLz*8pWp}%" x="113" y="-112">
          <field name="SCHEDULE">*/10 0 * * *</field>
            <block type="controls_if" id="n`bmzZWzu=LPf*mGDEvo">
                <block type="logic_compare" id="EQltsvUgTL=a9gN~t{::">
                  <field name="OP">GT</field>
                    <block type="get_value" id="ia^=UK`~pk}@BwDTV33o">
                      <field name="OID">alias.0.Diabetes.letzter_Tausch</field>
                    <block type="math_number" id="azRCG4}6jg|Qn!NqN[}}">
                      <field name="NUM">1</field>
                <block type="variables_set" id="COS^[FTn{:6~p6Tjk!9t">
                  <field name="VAR" id="#vzG9aWhz|;gfN4n)T6g">alter</field>
                    <block type="math_arithmetic" id="UE4!x7Vjk+7rAk*}[yE_" inline="false">
                      <field name="OP">DIVIDE</field>
                        <shadow type="math_number" id="AK7y#r-ZL(}A4/m=hGO~">
                        <block type="math_arithmetic" id="$|Q8O#N%jeacsaO4/-J2" inline="false">
                            <shadow type="math_number" id="qfh3jPJ`WsFp{~_qSa^b">
                            <block type="time_get" id="Z~U95u;zD?u?D{jt_N)I">
                              <field name="OPTION">object</field>
                            <shadow type="math_number" id="4sqSFY4JQTFiU~gh?7+j">
                            <block type="convert_from_date" id="/N#)J@bQC_V3bG+EENqy">
                                <block type="math_arithmetic" id="31!zp]DxJ=tpoWbzEG%r">
                                    <shadow type="math_number" id="25bG(UE8?^ipR|d;h0X(">
                                    <block type="get_value" id="x,6==aKcyyVwk4U[^xR9">
                                    <shadow type="math_number" id="oukO+j9+c,S6Qw:Hz/d|">
                                      <field name="NUM">1000</field>
                        <shadow type="math_number" id="i?4JJp?zv6!;h0l{#xV@">
                          <field name="NUM">86400000</field>
                    <block type="variables_set" id="{[eT-N=C*JQ1]S9oeotQ">
                      <field name="VAR" id=".J)CTmL9ogje^96O(sCE">restlaufzeit</field>
                        <block type="math_round" id="PF1]W0n:DG]nmGy.|30j">
                          <field name="OP">ROUNDDOWN</field>
                          <value name="NUM">
                            <shadow type="math_number" id="iS}v%mVz1`5TdK5k|0/-">
                              <field name="NUM">3.1</field>
                            <block type="math_arithmetic" id="nP_~7A|@R~1MuU+PYWZM">
                                <shadow type="math_number" id="[Uo2upe@*N_2hCvEzdPn">
                                  <field name="NUM">14</field>
                                <shadow type="math_number">
                                <block type="variables_get" id="ECP_(j@L[Oh+p6-uG?a#">
                        <block type="variables_set" id="T^FCprlb7KwI;i2xhA7}">
                          <field name="VAR" id="|ID!mE{~=VpHFy^j]V!1">Alter Sensor</field>
                            <block type="math_arithmetic" id=";WF{/suilbVRR#QThgs_">
                                <shadow type="math_number" id="i`raoCs/gN,Gqqv%!QYJ">
                                <block type="math_rndfixed" id="vJ8.eP*j..35i@+#7lw`">
                                  <field name="n">2</field>
                                  <value name="x">
                                    <shadow type="math_number" id="Jly4J1e]Y^g9x59+0w7d">
                                      <field name="NUM">3.1234</field>
                                    <block type="variables_get" id="(LwY1RkqIr-U=*^!dnzj">
                                <shadow type="math_number" id=":pUl5xa?y0$B@xx?fgSz">
                                <block type="math_round" id="7/IM.yFR.Hb=I2~Ekr+%">
                                  <value name="NUM">
                                    <block type="variables_get" id="RQ^8X;p!CtDrNuX3h?us">
                            <block type="update" id="H7yk;!er?J7eX5mKek`V">
                              <field name="OID">0_userdata.0.VirtuelleDevices.Diabetes.Sensor_Alter</field>
                                <block type="text_join" id="|MP[)C0zLk4~X@KE6BBP">
                                  <mutation items="9"></mutation>
                                  <value name="ADD0">
                                    <block type="text" id="J=3|NL*6-umJ$4{gNge|">
                                      <field name="TEXT">Sensor in Verwendung: &lt;b&gt;&lt;br&gt;</field>
                                  <value name="ADD1">
                                    <block type="math_round" id="sGC$y!ZRDxZU6)uNsoUJ">
                                      <field name="OP">ROUND</field>
                                      <value name="NUM">
                                        <shadow type="math_number" id="tJyFJ)9$Y$l8l)W_v}J*">
                                        <block type="variables_get" id="l5B,d0rc%-bDQ$NZ*{8k">
                                  <value name="ADD2">
                                    <block type="text" id="NW72.wY%0C%$PI/X-u3Z">
                                      <field name="TEXT"> Tage und </field>
                                  <value name="ADD3">
                                    <block type="math_round" id="*]ttQE:1J:O|Et4$bnLw">
                                      <value name="NUM">
                                        <shadow type="math_number" id="CQ3=T]I8cu}C6#:1/ZH/">
                                        <block type="math_arithmetic" id="?roZ)r%e}B9Rk*/!1EqE">
                                            <shadow type="math_number" id="oE9fs:Y+ks4{Pw7I679t">
                                              <field name="NUM">24</field>
                                            <shadow type="math_number" id="ab!!Vw@b.AT4R/,f8Nr4">
                                              <field name="NUM">10</field>
                                            <block type="variables_get" id="%Q0P_y{sahwdL!,J-u7Q">
                                  <value name="ADD4">
                                    <block type="text" id="Kwk~aOYZ]aTv$;An)hYj">
                                      <field name="TEXT"> Stunden&lt;/b&gt;&lt;br&gt;Sensortausch in:&lt;br&gt;&lt;b&gt;</field>
                                  <value name="ADD5">
                                    <block type="math_round" id="bOa%obujAW?^M(pkPe#G">
                                      <value name="NUM">
                                        <shadow type="math_number" id="aV-dj.lG?gq#)W~;@qPn">
                                        <block type="variables_get" id="VAbuvB(I;#)![^PNr=EF">
                                  <value name="ADD6">
                                    <block type="text" id="(vxP]A;5@$hEFSp-uVb*">
                                      <field name="TEXT"> Tagen und </field>
                                  <value name="ADD7">
                                    <block type="math_round" id="b@:vu@cZ$D$dee^?geJo">
                                      <value name="NUM">
                                        <shadow type="math_number" id="BOOmywVUR8k9DZoOy@1}">
                                        <block type="math_arithmetic" id="=Bm!TOb]M}Xh%5B?4_g,">
                                            <shadow type="math_number" id="6SF]LI8U*R@f{,wA/.*T">
                                            <shadow type="math_number" id="7tkH!L`~yYdlmiC7g0IU">
                                            <block type="math_arithmetic" id="j=ToU[KCR-xh`tW[2=B7">
                                                <shadow type="math_number" id="Gds8Z,-mPg]G?_g]NW_C">
                                                <block type="variables_get" id="]!Kxw{K1nDOatT|jB3b1">
                                  <value name="ADD8">
                                    <block type="text" id="nd7Jd+!.5-wyo9}PT4^7">
                                      <field name="TEXT"> Stunden</field>
                                <block type="update" id="qeZrB9`8sIS)g#0bn334">
                                  <field name="OID">0_userdata.0.VirtuelleDevices.Diabetes.Sensor_Alter_2</field>
                                    <block type="convert_tonumber" id="5nw]@W06Tgu0(*dY-WQ`">
                                        <block type="variables_get" id="{{c]uj.R4(r)K0{!X:K%">
      • bahnuhr
        bahnuhr Forum Testing Most Active @Skyx3 last edited by
        @skyx3
        Ich habe dein Blockly noch nicht richtig verstanden.
        Du schreibst Datum liegt in: libre.X.general.sensor.a
        Und wo ist der DP im blockly ?
        Und wie rechnest du diesen dann um ?
        Weiterhin zeigt dein eingestelltes Blockly andere DP als der Scrrenshot:
        Skyx3 1 Reply Last reply Reply Quote 0
        • Skyx3
          Skyx3 @bahnuhr last edited by
          @bahnuhr
          Der Datenpunkt "letzter Tausch" ist ein Alias und hinter diesem liegt "libre.X.general.sensor.a".
          Der Datenpunkt "libre.X.general.sensor.a" ist das Aktivierungsdatum des Sensors im Handy, dies ist allerdings ein Hex Format. Um dies in ein normales Datum umzuwandeln und die Differenz von heutigen Datum abzuziehen, also das Alter des Sensors, benötigt man diesen Teil vom Blockly:
          Wenn man aber nicht das Alter des Sensors haben will, sondern nur das Datum der Aktivierung reicht auch dies:
          Der Rest vom Blockly ist nur da um die Restlaufzeit in Tagen von den Stunden zu trennen und darzustellen, das schaut dann in der Visualisierung so aus:
          Skyx3 bahnuhr 2 Replies Last reply Reply Quote 0
          • Skyx3
            @skyx3
            Ich habe nochmal einen kleinen Rundungsfehler behoben und die Titel etwas besser beschrieben:
              <variables>
                <variable id="#vzG9aWhz|;gfN4n)T6g">Alter des Sensors</variable>
                <variable id=".J)CTmL9ogje^96O(sCE">Restlaufzeit</variable>
                <variable id="|ID!mE{~=VpHFy^j]V!1">Restlaufzeit abzüglich Tage</variable>
              </variables>
              <block type="schedule" id="I#B83b9;5pM~~a$iXQZ1" x="137" y="-113">
                <field name="SCHEDULE">*/5 * * * *</field>
                      <block type="comment" id="Wkzt1E/0QY14wRtcjxF9">
                        <field name="COMMENT">Berechnung Alter des Sensors</field>
                            <field name="VAR" id="#vzG9aWhz|;gfN4n)T6g">Alter des Sensors</field>
                              <block type="comment" id="$BgyJiO(EkH@`s1Fv$FV">
                                <field name="COMMENT">Berechnungs Restlaufzeit des Sensors</field>
                                    <field name="VAR" id=".J)CTmL9ogje^96O(sCE">Restlaufzeit</field>
                                        <field name="VAR" id="|ID!mE{~=VpHFy^j]V!1">Restlaufzeit abzüglich Tage</field>
                                                <value name="x">
                                                <value name="NUM">
                                          <block type="comment" id="4Wu/(q;Aiwh:Vqd4#BYT">
                                            <field name="COMMENT">Text Visualisierung</field>
                                                    <value name="ADD0">
                                                    <value name="ADD1">
                                                        <value name="NUM">
                                                    <value name="ADD2">
                                                    <value name="ADD3">
                                                        <value name="NUM">
                                                    <value name="ADD4">
                                                    <value name="ADD5">
                                                        <value name="NUM">
                                                    <value name="ADD6">
                                                    <value name="ADD7">
                                                        <value name="NUM">
                                                    <value name="ADD8">
                                                  <block type="comment" id="/Y3J`fOKQ(JAU;Iu{8L}">
                                                    <field name="COMMENT">Datenpunkt für Trigger</field>
                                                          <block type="comment" id="gjnt5~YilkeSR?E0[JOn">
                                                            <field name="COMMENT">Aktivierungsdatum des Sensors</field>
                                                              <block type="update" id="a*lh,xvJ/z,TMsb}LRDj">
        <field name="OID">0_userdata.0.VirtuelleDevices.Diabetes.Aktivierungsdatum_Sensor</field>
        <block type="convert_from_date" id="aClZMSP(^0(^0SpO`TmH">
        <mutation xmlns="http://www.w3.org/1999/xhtml" format="true" language="false"></mutation>
        <field name="OPTION">custom</field>
        <field name="FORMAT">TT.MM.JJJJ SS:mm</field>
        <block type="math_arithmetic" id="TDNCEyX%A0f3B_3=Id=m">
        <block type="get_value" id="!FNVD?@zF[Ln+O$WI,q#">
        <shadow type="math_number" id=")_,chWXajhl91ir8u#d{">
            • bahnuhr
              bahnuhr Forum Testing Most Active last edited by bahnuhr
              Hat Libre wieder etwas geändert ?
              Im log kommt:
              libre.0
              2023-10-04 15:41:26.246	error	Login failed. Please check your credentials and login to the app and accept the terms of use.
              edit:
              Erledigt.
              Beim Handy abmelden und dann wieder anmelden. Klappt.
              • bahnuhr
                @skyx3 sagte in Test Freestyle Libre LibreLinkUp:
                Hat bei meinem letzten Sensor nicht geklappt.
                DP wird nicht aktualisiert.
                Klappt das bei dir noch ?
                  best57 last edited by
                  Hallo, ich möchte die BZ-Werte meiner Tochter, die ich in der LibreLinUp App sehen kann, auch in den iobroker übernehmen und weiter verarbeiten. Mit dieser libre-Adapter soll das ja klappen. Leider schaffe ich das noch nicht.
                  Installiet habe ich zuerst die version 0.0.4 und jetzt die 0.0.5.
                  Im Log steht:
                  libre.0 2023-12-11 08:25:41.932	info	terminating
                  libre.0 2023-12-11 08:25:41.430	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  libre.0 2023-12-11 08:25:41.429	debug	Plugin sentry destroyed
                  libre.0 2023-12-11 08:25:41.427	info	terminating
                  libre.0 2023-12-11 08:25:41.425	info	Got terminate signal TERMINATE_YOURSELF
                  libre.0 2023-12-11 08:25:35.020	error	{"status":0,"data":{"redirect":true,"region":"eu"}}
                  libre.0 2023-12-11 08:25:35.019	debug	{"status":0,"data":{"redirect":true,"region":"eu"}}
                  libre.0 2023-12-11 08:25:33.973	info	starting. Version 0.0.5 (non-npm: TA2k/ioBroker.libre#dac7569094db0d63e5e867a0ca41ec11e0f1a22f) in /opt/iobroker/node_modules/iobroker.libre, node: v18.17.1, js-controller: 5.0.12
                  die libre-Instanz zeigt das rote X bei "Verbunden mit Gerät oder Dienst"
                  App-Email und App-Password sind korrekt eingetragen. Was kann ich noch tun?
                  danke und Gruß
                  T Thomas Braun 2 Replies Last reply Reply Quote 0
                    tombox @best57 last edited by
                    @best57 Ist dein Account in Deutschland angemeldet? du könntest in der region Einstellung in der Instanz mal eu probieren statt de
                      Thomas Braun Most Active @best57 last edited by
                      @best57 sagte in Test Freestyle Libre LibreLinkUp:
                      node: v18.17.1
                      Ist ein totes Gleis. Bring das per
                      iob nodejs-update
                      auf den aktuellen Stand. Ggf. zuvor iob fix ausführen.
                        best57 @Thomas Braun last edited by
                        @thomas-braun @tombox
                        danke, eure Tipps haben geholfen. Laut LOG kommen jetzt regelmäßig alle Daten an. Nun habe ich aber noch das gleiche Problem, wie @skyx3 oben beschrieben. Die Datenpunkte in libre.x.xxx.general.glucoseMeasurement werden nicht aktualisiert. Wohl aber alle in libre.x.xxx.graph.graphDataxx. Gibts da noch einen Hinweis? Wie hat @skyx3 das gelöst?
                        danke & Gruß
                        T Skyx3 2 Replies Last reply Reply Quote 0
                          @best57 mal debug log einschalten und schauen was für Daten kommen
                            best57 @tombox last edited by
                            @tombox debug-LOG ist aktiv. Da sehe ich, dass alle Daten ankommen und wie ich schon sagte, die Objekte in .graphDataxx werden regfelmäßig aktualisiert.
                            log-Auszug:
                            {"FactoryTimestamp":"12/12/2023 8:47:54 AM","Timestamp":"12/12/2023 9:47:54 AM","type":1,"ValueInMgPerDl":95,"TrendArrow":3,"TrendMessage":null,"MeasurementColor":4,"GlucoseUnits":1,"Value":95,"isHigh":false,"isLow":false}
                              @best57 general information werden nur bei adapter start aktualisiert graph wird im interval aktualisiert
                              gibt es Daten die nicht im graph sind?
                                @tombox ok, das war mir nicht klar. Dann muss ich mit den Daten im graph auskommen. Ich denke, das wird gehn.
                                  @best57 Ich kann auch die general data regelmässig aktualisieren aber bisher war das keine Anforderung
                                    @tombox ich werde mein Projekt schrittweise ausbauen. Falls es erfoderlich sein soll, komme ich auf dein Angebot zurück. Danke jedenfalls!
                                    • Skyx3
                                      @bahnuhr Ja, funktioniert noch.
                                      • Skyx3
                                        Skyx3 @best57 last edited by
                                        @best57 Ich lasse den Adapter alle 60sec via Skript neustarten.
                                        • Marko 0
                                          Marko 0 @G.Hawk last edited by
                                          @g-hawk Ich versuche das Blockli zum laufen zu bekommen der Datenpunkt über alex geht aber alles andere nicht kannst du mir helfen
                                          gruß Marko
                                          • bahnuhr
                                            bahnuhr Forum Testing Most Active @bahnuhr last edited by bahnuhr
                                            @bahnuhr sagte in Test Freestyle Libre LibreLinkUp:
                                            Habe immer noch das Problem, dass bei einem Sensorwechsel das Datum (libre.X.general.sensor.a) nicht aktualisiert wird.
                                            Vielleicht kann man sich dies mal anschauen.
                                            Nur ein Neustart des Adapters hilft dann.
                                            31.7k
                                            79.8k
                                            181
                                            18182
