    3. Einsteigerfragen
    4. Netatmo Authentisirung fehler
      Thomas Braun Most Active @dg19222 last edited by
      @dg19222
      Ein Auszug aus dem Log, wenn der Adapter startet wäre vielleicht hilfreich.
      Schau mittels
      iob logs --watch
      zu was da passiert.
        dg19222 @Thomas Braun last edited by dg19222
        bild gelöscht
        Thomas Braun D 3 Replies Last reply Reply Quote 0
          @dg19222
          Keine Bildchen aus der Konsole, Texte auch als Text (in CodeTags eingebettet) hier rein.
            @thomas-braun ```
            2023-12-12 09:36:39.664 - info: netatmo.0 (41001) starting. Version 3.1.0 in /o pt/iobroker/node_modules/iobroker.netatmo, node: v18.19.0, js-controller: 5.0.16
            2023-12-12 09:36:39.679 - info: netatmo.0 (41001) Authenticating with Netatmo u sing individual client-ID xxxxxx@gmx.de
            2023-12-12 09:36:39.680 - warn: netatmo.0 (41001) API Error: Please Authenticat e manually once using the Admin UI of this instance.
            2023-12-12 09:36:39.679 - info: netatmo.0 (41001) Authenticating with Netatmo u sing individual client-ID xxxxx@gmx.de
            • DJMarc75
              DJMarc75 @dg19222 last edited by
              @dg19222 nimm das Bild bitte raus - persönliche Daten !
                dg19222 @dg19222 last edited by
                2023-12-12 09:36:39.679  - info: netatmo.0 (41001) Authenticating with Netatmo u        sing individual client-ID xxx@gmx.de
                2023-12-12 09:36:39.679  - info: netatmo.0 (41001) Authenticating with Netatmo u        sing individual client-ID xxxx@gmx.de
                  @dg19222 said in Netatmo Authentisirung fehler:
                    Thomas Braun Most Active @dg19222 last edited by Thomas Braun
                    @dg19222
                    Important Note for Authentication changes October 2022
                    According to Netatmo the "old" way to authenticate with username and password directly by entering them into the adapter will be disabled by October 2022.
                    Version 2.0 of the adapter addresses this change and adjust the authentication. All upgrades before October 2022 should allow a seamless upgrade to 2.0.0 on the first start automatically - else requires a new authentication.
                    Scheint mir hier der Fall zu sein.
                    Schau hier mal rein:
                    https://github.com/PArns/ioBroker.netatmo
                      @thomas-braun Ok geibt es dazu ne lösung ? was kann ich tun
                      habe ich leider schon alles probiert komme aber nicht weiter
                      Thomas Braun Winni 2 Replies Last reply Reply Quote 0
                        @dg19222
                        Keine Ahnung. Hab den Adapter selber nicht im Einsatz.
                        • Winni
                          Winni @dg19222 last edited by
                          @dg19222 Hast du schon mal den Browser-Cash gelöscht, oder einen anderen Browser probiert?
                            dg19222 @Winni last edited by
                            @winni Probiert ja ergebniss leider das gleiche
                            Winni 1 Reply Last reply Reply Quote 0
                            • Winni
                              Winni @dg19222 last edited by Winni
                              @dg19222 Habe es gerade mal bei mir probiert. Es hat auf Anhieb funktioniert. Vielleicht mal den Adapter de und dann neu installieren. Ansonsten fällt mir leider auch nichts ein.
                              Edit: Vielleicht das noch: https://myconnectedaccount.netatmo.com/security/edit-password/check
                                dg19222 @Winni last edited by dg19222
                                @winni auch das leider ohne erfolg :-(( schade
                                  @dg19222 Keiner mehr ne idee?
                                    wg @dg19222 last edited by wg
                                    @dg19222 Hast Du Dir die client-ID und -secret besorgt bei Netatmo? Und die dann auch eingegeben? Und danach nochmal "Authenticate with Netatmo" gedrückt?
                                    Ich habe heute morgen den iobroker auf raspi bookworm 64bit umgezogen und danach konnte die netatmo-Instanz keine Authentisierung mehr durchführen. email/pw alleine hat nicht gereicht - er hat bei mir nach der client-id verlangt ... also angelegt und dann gings.
                                      dg19222 @wg last edited by
                                      @wg Ja habe ich getan!
                                      Das Problem hat sich so eben gelöst Adapter von github geladen instaliert und läuft jetzt
                                      Danke allen für die hilfe
                                      796
