    4. Test Freestyle Libre LibreLinkUp
    • Skyx3
      Skyx3 @Skyx3 last edited by
      @skyx3
      Ich habe nochmal einen kleinen Rundungsfehler behoben und die Titel etwas besser beschrieben:
        <variables>
          <variable id="#vzG9aWhz|;gfN4n)T6g">Alter des Sensors</variable>
          <variable id=".J)CTmL9ogje^96O(sCE">Restlaufzeit</variable>
          <variable id="|ID!mE{~=VpHFy^j]V!1">Restlaufzeit abzüglich Tage</variable>
        </variables>
        <block type="schedule" id="I#B83b9;5pM~~a$iXQZ1" x="137" y="-113">
          <field name="SCHEDULE">*/5 * * * *</field>
            <block type="controls_if" id="n`bmzZWzu=LPf*mGDEvo">
                <block type="logic_compare" id="EQltsvUgTL=a9gN~t{::">
                  <field name="OP">GT</field>
                    <block type="get_value" id="ia^=UK`~pk}@BwDTV33o">
                      <field name="OID">alias.0.Diabetes.letzter_Tausch</field>
                    <block type="math_number" id="azRCG4}6jg|Qn!NqN[}}">
                      <field name="NUM">1</field>
                <block type="comment" id="Wkzt1E/0QY14wRtcjxF9">
                  <field name="COMMENT">Berechnung Alter des Sensors</field>
                    <block type="variables_set" id="COS^[FTn{:6~p6Tjk!9t">
                      <field name="VAR" id="#vzG9aWhz|;gfN4n)T6g">Alter des Sensors</field>
                        <block type="math_arithmetic" id="UE4!x7Vjk+7rAk*}[yE_" inline="false">
                          <field name="OP">DIVIDE</field>
                            <shadow type="math_number" id="AK7y#r-ZL(}A4/m=hGO~">
                            <block type="math_arithmetic" id="$|Q8O#N%jeacsaO4/-J2" inline="false">
                                <shadow type="math_number" id="qfh3jPJ`WsFp{~_qSa^b">
                                <block type="time_get" id="Z~U95u;zD?u?D{jt_N)I">
                                  <field name="OPTION">object</field>
                                <shadow type="math_number" id="4sqSFY4JQTFiU~gh?7+j">
                                <block type="convert_from_date" id="/N#)J@bQC_V3bG+EENqy">
                                    <block type="math_arithmetic" id="31!zp]DxJ=tpoWbzEG%r">
                                        <shadow type="math_number" id="25bG(UE8?^ipR|d;h0X(">
                                        <block type="get_value" id="x,6==aKcyyVwk4U[^xR9">
                                        <shadow type="math_number" id="oukO+j9+c,S6Qw:Hz/d|">
                                          <field name="NUM">1000</field>
                            <shadow type="math_number" id="i?4JJp?zv6!;h0l{#xV@">
                              <field name="NUM">86400000</field>
                        <block type="comment" id="$BgyJiO(EkH@`s1Fv$FV">
                          <field name="COMMENT">Berechnungs Restlaufzeit des Sensors</field>
                            <block type="variables_set" id="{[eT-N=C*JQ1]S9oeotQ">
                              <field name="VAR" id=".J)CTmL9ogje^96O(sCE">Restlaufzeit</field>
                                <block type="math_arithmetic" id="nP_~7A|@R~1MuU+PYWZM">
                                    <shadow type="math_number" id="[Uo2upe@*N_2hCvEzdPn">
                                      <field name="NUM">14</field>
                                    <shadow type="math_number">
                                    <block type="variables_get" id="ECP_(j@L[Oh+p6-uG?a#">
                                <block type="variables_set" id="T^FCprlb7KwI;i2xhA7}">
                                  <field name="VAR" id="|ID!mE{~=VpHFy^j]V!1">Restlaufzeit abzüglich Tage</field>
                                    <block type="math_arithmetic" id=";WF{/suilbVRR#QThgs_">
                                        <shadow type="math_number" id="i`raoCs/gN,Gqqv%!QYJ">
                                        <block type="math_rndfixed" id="vJ8.eP*j..35i@+#7lw`">
                                          <field name="n">2</field>
                                          <value name="x">
                                            <shadow type="math_number" id="Jly4J1e]Y^g9x59+0w7d">
                                              <field name="NUM">3.1234</field>
                                            <block type="variables_get" id="(LwY1RkqIr-U=*^!dnzj">
                                        <shadow type="math_number" id=":pUl5xa?y0$B@xx?fgSz">
                                        <block type="math_round" id="7/IM.yFR.Hb=I2~Ekr+%">
                                          <field name="OP">ROUNDDOWN</field>
                                          <value name="NUM">
                                              <field name="NUM">3.1</field>
                                            <block type="variables_get" id="RQ^8X;p!CtDrNuX3h?us">
                                    <block type="comment" id="4Wu/(q;Aiwh:Vqd4#BYT">
                                      <field name="COMMENT">Text Visualisierung</field>
                                        <block type="update" id="H7yk;!er?J7eX5mKek`V">
                                          <field name="OID">0_userdata.0.VirtuelleDevices.Diabetes.Sensor_Alter</field>
                                            <block type="text_join" id="|MP[)C0zLk4~X@KE6BBP">
                                              <mutation items="9"></mutation>
                                              <value name="ADD0">
                                                <block type="text" id="J=3|NL*6-umJ$4{gNge|">
                                                  <field name="TEXT">Sensor in Verwendung: &lt;b&gt;&lt;br&gt;</field>
                                              <value name="ADD1">
                                                <block type="math_round" id="sGC$y!ZRDxZU6)uNsoUJ">
                                                  <value name="NUM">
                                                    <shadow type="math_number" id="tJyFJ)9$Y$l8l)W_v}J*">
                                                    <block type="variables_get" id="l5B,d0rc%-bDQ$NZ*{8k">
                                              <value name="ADD2">
                                                <block type="text" id="NW72.wY%0C%$PI/X-u3Z">
                                                  <field name="TEXT"> Tage und </field>
                                              <value name="ADD3">
                                                <block type="math_round" id="*]ttQE:1J:O|Et4$bnLw">
                                                  <field name="OP">ROUND</field>
                                                  <value name="NUM">
                                                    <shadow type="math_number" id="CQ3=T]I8cu}C6#:1/ZH/">
                                                    <block type="math_arithmetic" id="?roZ)r%e}B9Rk*/!1EqE">
                                                        <shadow type="math_number" id="oE9fs:Y+ks4{Pw7I679t">
                                                          <field name="NUM">24</field>
                                                        <shadow type="math_number" id="ab!!Vw@b.AT4R/,f8Nr4">
                                                          <field name="NUM">10</field>
                                                        <block type="variables_get" id="%Q0P_y{sahwdL!,J-u7Q">
                                              <value name="ADD4">
                                                <block type="text" id="Kwk~aOYZ]aTv$;An)hYj">
                                                  <field name="TEXT"> Stunden&lt;/b&gt;&lt;br&gt;Sensortausch in:&lt;br&gt;&lt;b&gt;</field>
                                              <value name="ADD5">
                                                <block type="math_round" id="bOa%obujAW?^M(pkPe#G">
                                                  <value name="NUM">
                                                    <shadow type="math_number" id="aV-dj.lG?gq#)W~;@qPn">
                                                    <block type="variables_get" id="VAbuvB(I;#)![^PNr=EF">
                                              <value name="ADD6">
                                                <block type="text" id="(vxP]A;5@$hEFSp-uVb*">
                                                  <field name="TEXT"> Tagen und </field>
                                              <value name="ADD7">
                                                <block type="math_round" id="b@:vu@cZ$D$dee^?geJo">
                                                  <value name="NUM">
                                                    <shadow type="math_number" id="BOOmywVUR8k9DZoOy@1}">
                                                    <block type="math_arithmetic" id="=Bm!TOb]M}Xh%5B?4_g,">
                                                        <shadow type="math_number" id="6SF]LI8U*R@f{,wA/.*T">
                                                        <shadow type="math_number" id="7tkH!L`~yYdlmiC7g0IU">
                                                        <block type="math_arithmetic" id="j=ToU[KCR-xh`tW[2=B7">
                                                            <shadow type="math_number" id="Gds8Z,-mPg]G?_g]NW_C">
                                                            <block type="variables_get" id="]!Kxw{K1nDOatT|jB3b1">
                                              <value name="ADD8">
                                                <block type="text" id="nd7Jd+!.5-wyo9}PT4^7">
                                                  <field name="TEXT"> Stunden</field>
                                            <block type="comment" id="/Y3J`fOKQ(JAU;Iu{8L}">
                                              <field name="COMMENT">Datenpunkt für Trigger</field>
                                                <block type="update" id="qeZrB9`8sIS)g#0bn334">
                                                  <field name="OID">0_userdata.0.VirtuelleDevices.Diabetes.Sensor_Alter_2</field>
                                                    <block type="convert_tonumber" id="5nw]@W06Tgu0(*dY-WQ`">
                                                        <block type="variables_get" id="{{c]uj.R4(r)K0{!X:K%">
                                                    <block type="comment" id="gjnt5~YilkeSR?E0[JOn">
                                                      <field name="COMMENT">Aktivierungsdatum des Sensors</field>
                                                        <block type="update" id="a*lh,xvJ/z,TMsb}LRDj">
                                                          <field name="OID">0_userdata.0.VirtuelleDevices.Diabetes.Aktivierungsdatum_Sensor</field>
                                                            <block type="convert_from_date" id="aClZMSP(^0(^0SpO`TmH">
                                                              <mutation xmlns="http://www.w3.org/1999/xhtml" format="true" language="false"></mutation>
                                                              <field name="OPTION">custom</field>
                                                              <field name="FORMAT">TT.MM.JJJJ SS:mm</field>
        <block type="math_arithmetic" id="TDNCEyX%A0f3B_3=Id=m">
        <block type="get_value" id="!FNVD?@zF[Ln+O$WI,q#">
        <shadow type="math_number" id=")_,chWXajhl91ir8u#d{">
      • bahnuhr
        bahnuhr Forum Testing Most Active last edited by bahnuhr
        Hat Libre wieder etwas geändert ?
        Im log kommt:
        libre.0
        2023-10-04 15:41:26.246	error	Login failed. Please check your credentials and login to the app and accept the terms of use.
        edit:
        Erledigt.
        Beim Handy abmelden und dann wieder anmelden. Klappt.
        • bahnuhr
          bahnuhr Forum Testing Most Active @Skyx3 last edited by
          @skyx3 sagte in Test Freestyle Libre LibreLinkUp:
          Datenpunkt "libre.X.general.sensor.a" ist das Aktivierungsdatum des Sensors
          Hat bei meinem letzten Sensor nicht geklappt.
          DP wird nicht aktualisiert.
          Klappt das bei dir noch ?
          Skyx3 bahnuhr 2 Replies Last reply Reply Quote 0
            best57 last edited by
            Hallo, ich möchte die BZ-Werte meiner Tochter, die ich in der LibreLinUp App sehen kann, auch in den iobroker übernehmen und weiter verarbeiten. Mit dieser libre-Adapter soll das ja klappen. Leider schaffe ich das noch nicht.
            Installiet habe ich zuerst die version 0.0.4 und jetzt die 0.0.5.
            Im Log steht:
            libre.0 2023-12-11 08:25:41.932	info	terminating
            libre.0 2023-12-11 08:25:41.430	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            libre.0 2023-12-11 08:25:41.429	debug	Plugin sentry destroyed
            libre.0 2023-12-11 08:25:41.427	info	terminating
            libre.0 2023-12-11 08:25:41.425	info	Got terminate signal TERMINATE_YOURSELF
            libre.0 2023-12-11 08:25:35.020	error	{"status":0,"data":{"redirect":true,"region":"eu"}}
            libre.0 2023-12-11 08:25:35.019	debug	{"status":0,"data":{"redirect":true,"region":"eu"}}
            libre.0 2023-12-11 08:25:33.973	info	starting. Version 0.0.5 (non-npm: TA2k/ioBroker.libre#dac7569094db0d63e5e867a0ca41ec11e0f1a22f) in /opt/iobroker/node_modules/iobroker.libre, node: v18.17.1, js-controller: 5.0.12
            die libre-Instanz zeigt das rote X bei "Verbunden mit Gerät oder Dienst"
            App-Email und App-Password sind korrekt eingetragen. Was kann ich noch tun?
            danke und Gruß
            T Thomas Braun 2 Replies Last reply Reply Quote 0
              tombox @best57 last edited by
              @best57 Ist dein Account in Deutschland angemeldet? du könntest in der region Einstellung in der Instanz mal eu probieren statt de
                Thomas Braun Most Active @best57 last edited by
                @best57 sagte in Test Freestyle Libre LibreLinkUp:
                node: v18.17.1
                Ist ein totes Gleis. Bring das per
                iob nodejs-update
                auf den aktuellen Stand. Ggf. zuvor iob fix ausführen.
                  best57 @Thomas Braun last edited by
                  @thomas-braun @tombox
                  danke, eure Tipps haben geholfen. Laut LOG kommen jetzt regelmäßig alle Daten an. Nun habe ich aber noch das gleiche Problem, wie @skyx3 oben beschrieben. Die Datenpunkte in libre.x.xxx.general.glucoseMeasurement werden nicht aktualisiert. Wohl aber alle in libre.x.xxx.graph.graphDataxx. Gibts da noch einen Hinweis? Wie hat @skyx3 das gelöst?
                  danke & Gruß
                  T Skyx3 2 Replies Last reply Reply Quote 0
                    @best57 mal debug log einschalten und schauen was für Daten kommen
                      best57 @tombox last edited by
                      @tombox debug-LOG ist aktiv. Da sehe ich, dass alle Daten ankommen und wie ich schon sagte, die Objekte in .graphDataxx werden regfelmäßig aktualisiert.
                      log-Auszug:
                      {"FactoryTimestamp":"12/12/2023 8:47:54 AM","Timestamp":"12/12/2023 9:47:54 AM","type":1,"ValueInMgPerDl":95,"TrendArrow":3,"TrendMessage":null,"MeasurementColor":4,"GlucoseUnits":1,"Value":95,"isHigh":false,"isLow":false}
                        @best57 general information werden nur bei adapter start aktualisiert graph wird im interval aktualisiert
                        gibt es Daten die nicht im graph sind?
                          @tombox ok, das war mir nicht klar. Dann muss ich mit den Daten im graph auskommen. Ich denke, das wird gehn.
                            @best57 Ich kann auch die general data regelmässig aktualisieren aber bisher war das keine Anforderung
                              @tombox ich werde mein Projekt schrittweise ausbauen. Falls es erfoderlich sein soll, komme ich auf dein Angebot zurück. Danke jedenfalls!
                              • Skyx3
                                Skyx3 @bahnuhr last edited by
                                @bahnuhr Ja, funktioniert noch.
                                • Skyx3
                                  Skyx3 @best57 last edited by
                                  @best57 Ich lasse den Adapter alle 60sec via Skript neustarten.
                                  • Marko 0
                                    Marko 0 @G.Hawk last edited by
                                    @g-hawk Ich versuche das Blockli zum laufen zu bekommen der Datenpunkt über alex geht aber alles andere nicht kannst du mir helfen
                                    gruß Marko
                                    • bahnuhr
                                      bahnuhr Forum Testing Most Active @bahnuhr last edited by bahnuhr
                                      @bahnuhr sagte in Test Freestyle Libre LibreLinkUp:
                                      Habe immer noch das Problem, dass bei einem Sensorwechsel das Datum (libre.X.general.sensor.a) nicht aktualisiert wird.
                                      Vielleicht kann man sich dies mal anschauen.
                                      Nur ein Neustart des Adapters hilft dann.
                                        slohberg last edited by
                                        ich habe mir den Adapter heute zum ersten Mal installiert, Version 0.0.4 (so wurde sie in iobroker angeboten). Es treten aber die folgenden Fehler auf:
                                        2024-03-08 15:59:25.538 error {"data":{"minimumVersion":"4.7.0"},"status":920}
                                        2024-03-08 15:59:25.537 error AxiosError: Request failed with status code 403
                                        Hab ich da nicht die aktuellste Version? Wenn nein, wie kann ich die installieren?
                                        Vielen Dank, Gruß
                                        Sven
                                        • hsteinme
                                          hsteinme last edited by
                                          @slohberg Installiere die letzte Version 0.0.5 direkt aus GitHub.
                                            slohberg @hsteinme last edited by
                                            @hsteinme Danke, damit funktioniert es, ich bekomme jetzt Werte.
                                            31.7k
                                            79.8k
                                            181
                                            18195
