    4. Bambulab 3d-Drucker adapter
    • kmxak
      gibt ne neue x1c firmware... angeblich soll sich was am mqtt getan haben, weiß aber noch nix genaueres.
      Webranger 1 Reply Last reply Reply Quote 0
      • Webranger
        Webranger @kmxak last edited by
        Ich hab mal nen update gemacht.
        Hab zwar noch ne verbindung aber es wird mir das log voll geschrieben.
        bambulab.0
        2023-12-11 21:32:12.081	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
        bambulab.0
        2023-12-11 21:32:11.073	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
        bambulab.0
        2023-12-11 21:32:10.369	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
        bambulab.0
        2023-12-11 21:32:10.070	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
        bambulab.0
        2023-12-11 21:32:08.022	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
        bambulab.0
        2023-12-11 21:32:07.072	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
        bambulab.0
        2023-12-11 21:32:06.006	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
        bambulab.0
        2023-12-11 21:32:05.084	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
        BjoernF M 2 Replies Last reply Reply Quote 0
        • BjoernF
          BjoernF @Webranger last edited by
          @webranger jupp, hauts log zu und sobald die instanz läuft gehts ordentlich mit der CPU hoch....da hat sich mit der neuen Firmware beim X1C definitiv was mit MQTT verändert.....bei 3x X1C und 3 Instanzen aktuell net lustig leider 😞
            mick70 @Webranger last edited by mick70
            @webranger hier auch. Ich habe einfach das fragliche Objekt gelöscht und an gleicher Stelle ein neues mit gleichem Namen aber als String angelegt (Expertenmodus). Wird brav gefüllt, keine Fehler mehr. [Ed.: Einfacher kann man natürlich gleich den Typ entsprechend ändern]
            Ist halt ein workaround, va wenn man mit finishTime noch was machen will, muss man halt mehr tun.
            P1S übrigens hier.
            H BjoernF 2 Replies Last reply Reply Quote 0
              homecineplexx @mick70 last edited by
              @mick70 beim P1S gibts auch schon einen Update?
              BjoernF 1 Reply Last reply Reply Quote 0
              • BjoernF
                BjoernF @mick70 last edited by
                @mick70 da reicht es auch dem Objekt einfach den Zustandstyp auf STRING zu stellen 🙂
                Aber mal blöd gefragt, muss der DP zur Finish Time sekündlich ne geschrieben werden????
                Was mich ebenso stutzig macht ist die sehr hohe Zahl an Ausgabeereignissen und die damit einhergehenden Performance Einbußen. Das System wird einfach super lahm sobald die Instanzen jetzt laufen....
                • BjoernF
                  BjoernF @homecineplexx last edited by
                  @homecineplexx nein, nur X1C hat ein FW update bekommen. P1x kommt später mit NoiseCancelling usw.
                    homecineplexx @BjoernF last edited by
                    @bjoernf said in Bambulab 3d-Drucker adapter:
                    danke, daher auch meine frage an @mick70 da er zum Schluss geschrieben hat: "P1S übrigens hier." und das hab ich nicht ganz verstanden
                      mick70 @homecineplexx last edited by
                      @homecineplexx Ich hatte das Problem mit den Fehlermeldungen beim P1S auch ohne das dafür noch nicht veröffentlichte NC update. FW Stand beim P1S ist afair 09/2023. Die Ursache für den Fehler im Adapter liegt daher evtl woanders.
                      @BjoernF Ja, ich hätte auch gleich den Typ ändern können. Meine Reihenfolge war andersrum, ich wollte erst probieren, ob der Adapter das Objekt nach dem Löschen einfach für mich neu richtig anlegt - das war leider nicht der Fall, gab neue Fehler, und ich musste das Objekt selbst neu anlegen. Diesen (retrospektiv) umständlichen Weg hatte ich beschrieben 😁
                      • BjoernF
                        BjoernF last edited by BjoernF
                        @Dutchman sieht so aus alsob hier sekündlich mc_remaining_time aktualisiert wird, was dann auch durch deinen angelegten DP für finishTime sekündlich updated und die Instanz unnötig belastet. Könnte man das updaten des finishTime DPs nicht auf die Änderung im mc_remaining_time DP triggern? Also maximal minütlich?
                        im übrigen werden beide DPs auch sekündlich aktualisiert, wenn KEIN Druckauftrag läuft.....
                        Webranger 1 Reply Last reply Reply Quote 1
                        • Webranger
                          Webranger @BjoernF last edited by
                          Ich hab den Adapter jetzt erstmal gestopt und warte auf ein update.
                          Sollte ja auch noch was mit den zeiten kommen.
                            hennott @Webranger last edited by
                            @webranger auf was für einer Hardware läuft er bei Dir?
                            • Webranger
                              Webranger @hennott last edited by
                              @hennott Intel NUC im Container.
                                @webranger ich hatte von dem Adapter 16 Instanzen auf einem QNAP als Container laufen und das hat der Performance nicht so stark geschadet, allerdings massiv Ressourcen verbraten, weswegen ich jetzt warte, bis man in einer Instanz mehrere Drucker einrichten kann.
                                • skvarel
                                  skvarel Developer last edited by skvarel
                                  Das liegt NICHT am Update vom X1 ... das tritt auch beim P1S auf.
                                  @Dutchman weiß aber schon Bescheid und will sich kümmern.
                                  https://github.com/DrozmotiX/ioBroker.bambulab/issues/58
                                  skvarel created this issue in DrozmotiX/ioBroker.bambulab
                                  closed .finishTime" has to be type "date" but received type "string" #58
                                    Was mir auch noch aufgefallen ist: Ich trenne den Drucker bei Nichtgebrauch immer mit Shelly vom Netz (spart so 9W). Trotzdem versucht der Adapter alle 30 Sekunden zu verbinden und wirft dann Fehler aus:
                                    bambulab.0
                                    2023-12-19 07:15:59.411	warn	Connection to Printer closed
                                    bambulab.0
                                    2023-12-19 07:15:59.410	error	Connection issue occurred Error: connect EHOSTUNREACH 192.168.178.137:8883
                                    bambulab.0
                                    2023-12-19 07:15:26.355	warn	Connection to Printer closed
                                    bambulab.0
                                    2023-12-19 07:15:26.354	error	Connection issue occurred Error: connect EHOSTUNREACH 192.168.178.137:8883
                                    Dieses Intervall ist unabhängig von der Einstellung "Sekunden zwischen der Datenabfrage (Wird nur für die P1x-Serie verwendet)". Das ist schon recht oft und das Log wird so arg unübersichtlich.
                                    @Dutchman Vielleicht wären ja Instanzeinstellungen möglich, mit denen man das reconnect-Intervall verlängern und Fehlermeldungen verhindern könnte, wenn man Drucker nicht im Dauerbetrieb einsetzen möchte?
                                    BjoernF Gargano 2 Replies Last reply Reply Quote 0
                                    • BjoernF
                                      @mick70 kleines blockly und Instanz mit dem Shelly starten/stoppen 😉👍🏻
                                        mick70 last edited by mick70
                                        @bjoernf Das wäre ein halbwegs eleganter Workaround - kann man Instanzen im Blockly inzwischen direkt ein- und ausschalten oder muss man da immer noch ein Javascript nutzen (z.B. so)?
                                        [Edit: Der Datenpunkt "Alive" der Instanz im Zweig "System" (sichtbar im Expertenmodus) kann jedenfalls manuell zum Ein-/Ausschalten der Instanz genutzt werden. Probiere ich so jetzt auch mal im Blockly]
                                        [Edit 2: Klappt, dieses Thema ist für mich gelöst!]
                                        Interessant wird's eh erst, wenn das string/date Problem beim "finishTime"-Datenpunkt behoben ist, denn bei jedem Neustart der Instanz wird der Typ ja wieder zurückgesetzt und löst dann die entsprechenden Fehlermeldungen aus.
                                        • Flexer
                                          Flexer last edited by
                                          Gibts hier schon was neues?
                                            Metro75 @Dutchman last edited by
                                            @dutchman Guten Abend. Wo genau in den Netzwerk-Einstellungen meint ihr? In der Handy-App, oder in BambuStudio. Hab mir jetzt den gesamten Thread durchgelesen. Steh irgendwie auf dem Schlauch.
                                            274
                                            87012
