    4. Sayit Adapter- Probleme nach Update
      do5tj80 @Thomas Braun last edited by
      thuebner@iobroker:~$ iob nodejs-update
      iobroker nodejs-update [<major-version>]
      Upgrade the Node.JS installation to the current LTS
      Options:
        --help  Show help  [boolean]
      mehr kommt da nicht.
        Thomas Braun Most Active @do5tj80 last edited by
        @do5tj80
        iob stop
        iob fix
        iob nodejs-update
        Und setz den User in die Gruppen 'sudo' und 'iobroker' rein.
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer-vm
                     Chassis: vm
              Virtualization: kvm
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 5.10.0-26-amd64
                Architecture: x86-64
          model name      : Common KVM processor
          Docker          : false
          Virtualization  : kvm
          Kernel          : x86_64
          Userland        : amd64
          Systemuptime and Load:
           18:49:14 up 5 min,  1 user,  load average: 1.05, 0.95, 0.45
          CPU threads: 4
          *** Time and Time Zones ***
                         Local time: Sun 2023-11-26 18:49:14 CET
                     Universal time: Sun 2023-11-26 17:49:14 UTC
                           RTC time: Sun 2023-11-26 17:49:15
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          thuebner
          /home/thuebner
          thuebner cdrom floppy sudo audio dip video plugdev netdev iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            4.9G        3.7G        817M        0.0K        410M        1.0G
          Swap:            11G          0B         11G
          Total:           16G        3.7G         12G
                   4921 M total memory
                   3693 M used memory
                    159 M active memory
                   3645 M inactive memory
                    816 M free memory
                     50 M buffer memory
                    359 M swap cache
                  11215 M total swap
                      0 M used swap
                  11215 M free swap
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          Filesystem                    Type      Size  Used Avail Use% Mounted on
          udev                          devtmpfs  2.4G     0  2.4G   0% /dev
          tmpfs                         tmpfs     493M  540K  492M   1% /run
          /dev/mapper/iobroker--vg-root ext4       38G  9.4G   27G  27% /
          tmpfs                         tmpfs     2.5G     0  2.5G   0% /dev/shm
          tmpfs                         tmpfs     5.0M     0  5.0M   0% /run/lock
          /dev/vda1                     ext2      470M   86M  360M  20% /boot
          tmpfs                         tmpfs     493M     0  493M   0% /run/user/0
          [sudo] password for thuebner:
          [Sun Nov 26 18:43:36 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
          [Sun Nov 26 18:43:36 2023] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro
          [Sun Nov 26 18:43:36 2023] EXT4-fs (vda1): mounting ext2 file system using the ext4 subsystem
          [Sun Nov 26 18:43:36 2023] EXT4-fs (vda1): mounted filesystem without journal. Opts: (null)
          TARGET  SOURCE                        FSTYPE OPTIONS
          /       /dev/mapper/iobroker--vg-root ext4   rw,relatime,errors=remount-ro
          `-/boot /dev/vda1                     ext2   rw,relatime
          /var:
          2.8G    /var/
          2.2G    /var/log/journal/14cb46b5198d45d6a08ee6b6ab2c73d2
          2.2G    /var/log
          382M    /var/cache
          Archived and active journals take up 32.0M in the file system.
          /opt/iobroker/backups:
          101M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          754M    /opt/iobroker/iobroker-data/
          557M    /opt/iobroker/iobroker-data/files
          133M    /opt/iobroker/iobroker-data/backup-objects
          89M     /opt/iobroker/iobroker-data/files/vis-2-beta
          67M     /opt/iobroker/iobroker-data/files/javascript.admin
          46M     /opt/iobroker/iobroker-data/objects.jsonl
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
          18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2426815-if00
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.18.2
          /usr/bin/node           v18.18.2
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          /usr/bin/corepack       0.19.0
          nodejs:
            Installed: 18.18.2-1nodesource1
            Candidate: 18.18.2-1nodesource1
            Version table:
           *** 18.18.2-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
                  500 http://ftp.tu-chemnitz.de/debian bullseye/main amd64 Packages
                  500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
               10.24.0~dfsg-1~deb10u1 500
                  500 http://ftp.de.debian.org/debian buster/main amd64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.16
          admin:          6.12.0
          javascript:     7.1.6
          Adapters from github:   5
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
          + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
            system.adapter.devices.0                : devices               : iobroker                                 -  enabled
          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
          + system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
          + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
          + system.adapter.evcc.0                   : evcc                  : iobroker                                 -  enabled, port: 7070
          + system.adapter.evcc.1                   : evcc                  : iobroker                                 -  enabled, port: 7071
          + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
          + system.adapter.fronius.1                : fronius               : iobroker                                 -  enabled
          + system.adapter.fronius.2                : fronius               : iobroker                                 -  enabled
            system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
            system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
            system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
            system.adapter.ical.4                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
            system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            system.adapter.km200.0                  : km200                 : iobroker                                 - disabled
          + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.3.15
          + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
          + system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.3.15
          + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
            system.adapter.owfs.0                   : owfs                  : iobroker                                 - disabled, port: 4304
          + system.adapter.phantomjs.0              : phantomjs             : iobroker                                 -  enabled
          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
            system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
          + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
          + system.adapter.roomba.0                 : roomba                : iobroker                                 -  enabled
            system.adapter.s7.0                     : s7                    : iobroker                                 - disabled
          + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.3.15
          + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
          + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
          + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
          + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
          + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3307
          + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
          + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
          + system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
          + system.adapter.vw-connect.2             : vw-connect            : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.12.0   , installed 6.12.0
          Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
          Adapter    "backitup"     : 2.8.7    , installed 2.8.7
          Adapter    "bring"        : 1.8.4    , installed 1.8.4
          Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
          Adapter    "device-reminder": 3.0.0  , installed 3.0.0
          Adapter    "email"        : 1.2.0    , installed 1.2.0
          Adapter    "ems-esp"      : 2.6.1    , installed 2.6.2
          Adapter    "evcc"         : 0.0.10   , installed 0.0.10
          Adapter    "fronius"      : 2.0.2    , installed 2.0.2
          Adapter    "fullybrowser" : 3.0.6    , installed 2.2.0  [Updatable]
          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
          Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.16   , installed 5.0.16
          Adapter    "km200"        : 2.0.3    , installed 2.0.3
          Adapter    "knx"          : 2.0.23   , installed 2.0.23
          Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
          Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
          Adapter    "modbus"       : 5.0.11   , installed 5.0.11
          Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
          Adapter    "nina"         : 0.0.25   , installed 0.0.25
          Adapter    "nut"          : 1.6.0    , installed 1.6.0
          Adapter    "owfs"         : 0.7.0    , installed 0.7.0
          Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
          Adapter    "proxmox"      : 2.2.1    , installed 2.2.1
          Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
          Adapter    "roomba"       : 1.2.2    , installed 1.2.2
          Adapter    "s7"           : 1.3.15   , installed 1.3.15
          Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
          Adapter    "samsung"      : 0.5.11   , installed 0.5.11
          Adapter    "sayit"        : 3.0.5    , installed 3.0.5
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
          Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
          Adapter    "sql"          : 2.2.0    , installed 2.2.0
          Adapter    "squeezeboxrpc": 1.3.9    , installed 1.3.9
          Adapter    "synology"     : 3.0.1    , installed 3.0.1
          Adapter    "telegram"     : 2.0.1    , installed 2.0.1
          Adapter    "text2command" : 3.0.2    , installed 3.0.2
          Adapter    "trashschedule": 2.3.0    , installed 2.3.0
          Adapter    "unifi"        : 0.6.6    , installed 0.6.6
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-icontwo"  : 0.97.1   , installed 0.97.1
          Adapter    "vis-justgage" : 2.0.2    , installed 2.0.1  [Updatable]
          Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
          Adapter    "web"          : 6.1.10   , installed 6.1.10
          Adapter    "wled"         : 0.7.1    , installed 0.7.1
          Adapter    "ws"           : 2.5.8    , installed 2.5.8
          Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
          Objects and States
          Objects:        54381
          States:         44412
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 https://repos.influxdata.com/debian stable InRelease
          Hit:3 http://ftp.de.debian.org/debian buster InRelease
          Hit:4 http://ftp.tu-chemnitz.de/debian bullseye InRelease
          Hit:5 http://ftp.tu-chemnitz.de/debian bullseye-updates InRelease
          Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists... Done
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       11979      416/iobroker.js-con
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       13463      416/iobroker.js-con
          tcp        0      0 192.168.3.15:9292       0.0.0.0:*               LISTEN      1001       13788      596/io.hm-rpc.0
          tcp        0      0 0.0.0.0:55597           0.0.0.0:*               LISTEN      107        17824      950/rpc.statd
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11441      1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13445      430/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15027      784/io.shelly.1
          tcp        0      0 192.168.3.15:2010       0.0.0.0:*               LISTEN      1001       13865      626/io.hm-rpc.2
          tcp        0      0 192.168.3.15:1883       0.0.0.0:*               LISTEN      1001       14822      701/io.mqtt.0
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       15471      800/io.sonoff.0
          tcp        0      0 192.168.3.15:8701       0.0.0.0:*               LISTEN      1001       14534      611/io.hm-rpc.1
          tcp6       0      0 :::3500                 :::*                    LISTEN      1001       16498      898/io.sonos.0
          tcp6       0      0 :::50125                :::*                    LISTEN      107        17830      950/rpc.statd
          tcp6       0      0 :::111                  :::*                    LISTEN      0          11445      1/init
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13561      449/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22985      1711/io.web.0
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21247      1593/io.socketio.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          13447      430/sshd: /usr/sbin
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21185      1577/io.simple-api.
          udp        0      0 0.0.0.0:59512           0.0.0.0:*                           1001       33770      768/io.shelly.0
          udp        0      0 192.168.3.15:39048      0.0.0.0:*                           1001       21048      1496/io.knx.0
          udp        0      0 192.168.3.15:43214      0.0.0.0:*                           1001       21522      1496/io.knx.0
          udp        0      0 192.168.3.15:51574      0.0.0.0:*                           1001       20870      1496/io.knx.0
          udp        0      0 192.168.3.15:47927      0.0.0.0:*                           1001       20355      1496/io.knx.0
          udp        0      0 192.168.3.15:48759      0.0.0.0:*                           1001       20752      1496/io.knx.0
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11442      1/init
          udp        0      0 127.0.0.1:702           0.0.0.0:*                           0          17816      950/rpc.statd
          udp        0      0 0.0.0.0:58089           0.0.0.0:*                           107        17821      950/rpc.statd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23602      1728/io.wled.0
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15383      768/io.shelly.0
          udp6       0      0 :::57382                :::*                                107        17827      950/rpc.statd
          udp6       0      0 :::111                  :::*                                0          11448      1/init
          2023-11-26 18:48:24.757  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:26.958  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=9
          2023-11-26 18:48:26.959  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:26.985  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
          2023-11-26 18:48:26.985  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:27.437  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=4
          2023-11-26 18:48:27.437  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:29.355  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=8
          2023-11-26 18:48:29.356  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:29.383  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
          2023-11-26 18:48:29.383  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:29.874  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=5
          2023-11-26 18:48:29.874  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:32.046  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=7
          2023-11-26 18:48:32.046  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:32.103  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
          2023-11-26 18:48:32.103  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:32.610  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=6
          2023-11-26 18:48:32.610  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:34.573  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=7
          2023-11-26 18:48:34.573  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:34.610  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=10
          2023-11-26 18:48:34.610  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          2023-11-26 18:48:43.745  - warn: influxdb.0 (491) Error on writeSeries: HttpError: failure writing points to database: partial write: points beyond retention policy dropped=6
          2023-11-26 18:48:43.745  - warn: influxdb.0 (491) All possible data points were written, others can not really be corrected
          iob diag has finished.
            @do5tj80
            Der Eintrag
            muss raus.
            Und setz den User auch noch in die Gruppe 'adm'.
              @thomas-braun said in Sayit Adapter- Probleme nach Update:
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                         Chassis: vm
                  Virtualization: kvm
              Docker          : false
              Kernel          : x86_64
              Userland        : amd64
               19:08:23 up 24 min,  1 user,  load average: 0.34, 0.48, 0.53
              CPU threads: 4
                             Local time: Sun 2023-11-26 19:08:23 CET
                         Universal time: Sun 2023-11-26 18:08:23 UTC
                               RTC time: Sun 2023-11-26 18:08:24
                            NTP service: active
                        RTC in local TZ: no
              thuebner
              /home/thuebner
              thuebner adm cdrom floppy sudo audio dip video plugdev netdev iobroker
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            4.9G        4.0G        502M        0.0K        464M        746M
              Swap:            11G        308M         10G
              Total:           16G        4.3G         11G
                       4921 M total memory
                       3954 M used memory
                        475 M active memory
                       3651 M inactive memory
                        502 M free memory
                         29 M buffer memory
                        434 M swap cache
                      11215 M total swap
                        308 M used swap
                      10907 M free swap
              *** FILESYSTEM ***
              tmpfs                         tmpfs     493M  560K  492M   1% /run
              /dev/mapper/iobroker--vg-root ext4       38G  9.5G   27G  27% /
              /var:
              2.8G    /var/
              2.2G    /var/log
              382M    /var/cache
              Archived and active journals take up 2.1G in the file system.
              767M    /opt/iobroker/iobroker-data/
              59M     /opt/iobroker/iobroker-data/objects.jsonl
              USB-Devices by-id:
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              javascript:     7.1.6
              Adapter State
              + instance is alive
              Objects and States
              Objects:        54381
              States:         44373
              Hit:3 http://ftp.tu-chemnitz.de/debian bullseye InRelease
              Hit:4 http://ftp.tu-chemnitz.de/debian bullseye-updates InRelease
              Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
              Pending Updates: 0
              2023-11-26 19:00:06.574  - debug: ical.4 (3412) Checking unprocessed event 7 null Tischdienst = false, state = false
              2023-11-26 19:00:07.195  - info: daswetter.0 (3395) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
              2023-11-26 19:00:07.700  - info: daswetter.0 (3395) cleaned everything up...
              2023-11-26 19:00:09.489  - info: ical.3 (3428) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              2023-11-26 19:00:09.597  - info: ical.3 (3428) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
              2023-11-26 19:00:10.151  - info: ical.3 (3428) processing URL: Clara https://calendar.google.com/calendar/ical/huebner.clara.lena%40gmail.com/private-c7b2ebacd70794015b5c85a248f7381a/basic.ics
              2023-11-26 19:00:10.197  - info: ical.3 (3428) processing URL: Justus https://calendar.google.com/calendar/ical/huebner.justus.paul%40gmail.com/private-9522b9790da1082a532c5fba6ab42a2f/basic.ics
              2023-11-26 19:00:10.310  - info: ical.3 (3428) processing URL: Anne https://calendar.google.com/calendar/ical/huebner.ann%40googlemail.com/private-b54c816b59835b0a4511e025822684c7/basic.ics
              2023-11-26 19:00:10.488  - info: ical.3 (3428) processing URL: Tobias https://calendar.google.com/calendar/ical/do5tj80%40gmail.com/private-5cef9aaf7076853a604f44550c38fec5/basic.ics
              2023-11-26 19:00:11.578  - debug: ical.4 (3412) Plugin sentry destroyed
              2023-11-26 19:00:11.579  - info: ical.4 (3412) Terminated (NO_ERROR): Without reason
              2023-11-26 19:00:13.114  - info: ical.2 (3444) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              2023-11-26 19:00:13.244  - info: ical.2 (3444) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
              2023-11-26 19:00:13.819  - info: ical.2 (3444) processing URL: Abfallkalender https://calendar.google.com/calendar/ical/vk2p9rt7v6kj28111j11mkh9i4%40group.calendar.google.com/private-b873761754a89930da3e7513a5680d17/basic.ics
              2023-11-26 19:00:13.924  - warn: trashschedule.0 (1625) no events matches type "Biotonnenwäsche" with match "Biotonnenwäsche"
              2023-11-26 19:00:15.578  - info: ical.3 (3428) Terminated (NO_ERROR): Without reason
              2023-11-26 19:00:17.806  - info: ical.1 (3460) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              2023-11-26 19:00:18.098  - info: ical.1 (3460) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
              2023-11-26 19:00:18.920  - info: ical.2 (3444) Terminated (NO_ERROR): Without reason
              2023-11-26 19:00:19.912  - info: ical.1 (3460) processing URL: Theater https://calendar.google.com/calendar/ical/gelenauermarionettenspiele%40googlemail.com/private-c5262fd3590ceb70dd87a8f8f5873b64/basic.ics
              2023-11-26 19:00:25.451  - info: ical.1 (3460) Terminated (NO_ERROR): Without reason
              2023-11-26 19:01:20.968  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
              2023-11-26 19:01:21.056  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
              2023-11-26 19:03:23.989  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
              2023-11-26 19:03:24.047  - info: javascript.0 (506) script.js.Verknuepfungen.BW_Flur_OG: true
              in adm ist er jetzt und http://ftp.de.debian.org/debian buster InRelease sollte raus sein.
                @do5tj80
                Dann würde ich den Arbeitsspeicher anders verteilen.
                11GB für SWAP mach keinen Sinn, wenn nur 4GB primär zugeteilt werden.
                  do5tj80 @Thomas Braun last edited by do5tj80
                  Ok das schaue ich mir an.
                  Aber generel erst mal Danke , das du so viele Tip's gibst.
                    fvp @do5tj80 last edited by
                    Ich habe Version 4.0 ausprobiert. Leider noch mit dem gleichen Problem.
                    Zum Test habe ich eine Windows VM genommen und die 3.0.5 dort probiert. Auch hier kein Ankündigungston .
                    sayit.0
                    	2023-12-12 12:02:29.026	error	Cannot write file: TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                    sayit.0
                    	2023-12-12 12:02:29.016	info	Upload announce mp3 files
                    sayit.0
                    	2023-12-12 12:02:29.012	info	starting. Version 3.0.5 in C:/ioBroker/node_modules/iobroker.sayit, node: v18.19.0, js-controller: 5.0.16
                    Ich hoffe er erbarmt sich jemand mich zu Unterstützen.
                    • bahnuhr
                      bahnuhr Forum Testing Most Active @fvp last edited by
                      @fvp
                      Sende erst das mp3
                      und nach x Sek. dann den Text.
                      Dies funktioniert.
                        fvp last edited by
                        @bahnuhr Danke für die Rückmeldung! Da habe ich aktuell noch keine Idee wie ich das geht. Bis jetzt habe ich einfach den Datenpunkt sayit.0.tts.text oder die Blockly-Funktion genutzt.
                        • bahnuhr
                          @fvp sagte in Sayit Adapter- Probleme nach Update:
                          Man muss halt auch mal die Hilfe der Adapter lesen.
                          Bringt manchmal Erleuchtung.
                          Denn da steht alles was du gerade suchst.
                          • bahnuhr
                            per js so:
                            setState('sayit.x.tts.text', '/opt/iobroker/iobroker-data/files/vis.0/mp3/xxx.mp3');
                            setTimeout(function() { setState('sayit.x.tts.text', "Spülmaschine ist fertig.") } , 3000);
                            F D 3 Replies Last reply Reply Quote 0
                              fvp @bahnuhr last edited by
                              @bahnuhr
                              Erstmal vielen Dank für den Code.
                              Das ich an dieser Stelle auch eine Datei angeben kann habe ich noch nicht gewusst.
                              In der Hilfe steht hier
                              sayit.N.tts.text: Phrase to be spoken.
                              Hast du den Ankündigungston im Adapter abgeschaltet ?
                              Ansonsten würde der Adapter in Zeile 2 ja versuchen diesen auszugeben ?
                                @bahnuhr
                                Ich habe deinen Tipp gerade ausprobiert.
                                Als Workaround kann man das so machen.
                                Aber die Idee hinter dem Adapter ist doch eigentlich das man sich darum nicht kümmern muss
                                        // place as first the announcement mp3
                                        tasks.push({
                                            text: announce,
                                            language,
                                            volume: Math.round((volume || 70) / 100 * (parseInt(annoVolume, 10) || 50)),
                                            ts: task.ts,
                                            testOptions
                                        // and then text
                                        tasks.push(task);
                                • bahnuhr
                                  @fvp
                                  Dein Script sagt jetzt aber absolut nix mit sayit.
                                    @bahnuhr
                                    Das ist nicht von mir.
                                    Ist ein Ausschnitt der Funktion addToQueue aus der main.js des Sayit Adapter.
                                    • bahnuhr
                                      Uns was willst du jetzt damit ?
                                      mal kritisch von mir:
                                      Du weißt nicht wie man eine mp3 sendet.
                                      und dann beschäftigst du dich mit der main.js
                                      Passt m.E. nicht zusammen.
                                      Aber einen workflow von mir hast du ja jetzt.
                                        @bahnuhr
                                        Ich möchte damit sagen: das von dir gezeigte Vorgehen, für das ich dankbar bin , geht daran vorbei wie der Adapter eigentlich konzipiert ist.
                                        Zu deiner Kritik.
                                        Du sendest ja keine MP3 sondern übergibst dem Adapter den Pfad zur Datei. Sorry das ich nicht wusste das der Adapter das unterstützt und das du dies mit senden meinst. Das heißt doch aber nicht das ich mich mit dem Thema nicht beschäftigt habe !?🤔
                                        Mal kritisch von mir:
                                        Warum eigentlich dieser "scharfe" Ton und kein konstruktives Zusammenarbeiten ? ✌
                                        • bahnuhr
                                          bahnuhr Forum Testing Most Active @fvp last edited by bahnuhr
                                          "scharfe" Ton
                                          War kein scharfer Ton.
                                          Ganz im Gegenteil; habe dir sogar eine Script Vorlage frei Haus geliefert.
                                          Aber ich habe dir am Anfang geschrieben du sollst du Hilfe lesen.
                                          Was du nicht gemacht hast.
                                          Und dann aber die main.js durchwühlen.
                                          Und dies finde ich halt falsch.
                                          Aber da du anscheinend empfinglich bist, bin ich jetzt raus.
                                          keine Hilfe mehr von mir.
                                          Schönen Abend dir.
                                            Schade aber vielen Dank für deine Mühe @bahnuhr
                                            51
                                            4230
