    4. Redis in ioBroker - Überblick
      kiste01 @Meister Mopper last edited by
      @meister-mopper sagte in Redis in ioBroker - Überblick:
      da isses
      iob diag
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.0-26-amd64
            Architecture: x86-64
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       19:03:25 up 8 days,  5:44,  1 user,  load average: 0.62, 0.63, 0.62
      CPU threads: 8
      *** Time and Time Zones ***
                     Local time: Mon 2023-12-11 19:03:25 CET
                 Universal time: Mon 2023-12-11 18:03:25 UTC
                       RTC time: Mon 2023-12-11 18:03:26
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi cdrom floppy sudo audio dip video plugdev netdev iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.9G        5.5G        1.7G        0.0K        772M        2.2G
      Swap:           974M        207M        767M
      Total:          8.9G        5.7G        2.5G
               7944 M total memory
               5487 M used memory
                784 M active memory
               5176 M inactive memory
               1685 M free memory
                107 M buffer memory
                665 M swap cache
                974 M total swap
                207 M used swap
                767 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     795M  524K  794M   1% /run
      /dev/sda1      ext4      8.9G  6.2G  2.2G  74% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     795M     0  795M   0% /run/user/1000
      [Sun Dec  3 13:19:11 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [Sun Dec  3 13:19:11 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      1.3G    /var/
      694M    /var/log
      673M    /var/log/journal/57f27019fc434c12b80e1a85b8486719
      419M    /var/cache
      Archived and active journals take up 136.0M in the file system.
      /opt/iobroker/backups:
      134M    /opt/iobroker/backups/
      4.0K    /opt/iobroker/backups/jarvis_DEVICES
      /opt/iobroker/iobroker-data:
      828M    /opt/iobroker/iobroker-data/
      507M    /opt/iobroker/iobroker-data/files
      168M    /opt/iobroker/iobroker-data/backup-objects
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      58M     /opt/iobroker/iobroker-data/files/echarts
      115M    /opt/iobroker/iobroker-data/objects.jsonl
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-SHA_CUL868-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! missing: chroma-js@^2.4.2, required by iobroker.javascript@7.1.6
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-11T18_03_35_833Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      Core adapters versions
      js-controller:  5.0.16
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   4
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.airconwithme.0           : airconwithme          : iobroker                                 - disabled, compact disabled
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled, compact disabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled, compact disabled
        system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 - disabled, compact disabled
      + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled, compact disabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled, compact disabled
        system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled, compact disabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled, compact disabled
      + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled, compact disabled
      + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled, compact disabled
      + system.adapter.deyeidc.1                : deyeidc               : iobroker                                 -  enabled, compact disabled, port: 8899
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled, compact disabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled, compact disabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled, compact disabled
      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled, compact disabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled, compact disabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled, compact disabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled, compact disabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 - disabled, compact disabled
        system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled, compact disabled
      + system.adapter.go-e.0                   : go-e                  : iobroker                                 -  enabled, compact disabled
        system.adapter.history.0                : history               : iobroker                                 - disabled, compact disabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled, compact disabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, compact disabled, port: 0
      + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled, compact disabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled, compact disabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, compact disabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled, compact disabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled, compact disabled
        system.adapter.iqontrol.0               : iqontrol              : iobroker                                 - disabled, compact disabled
      + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled, compact disabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
        system.adapter.maxcube.0                : maxcube               : iobroker                                 - disabled, port: 62910, bind: 0.0.0.0
      + system.adapter.mercedesme.0             : mercedesme            : iobroker                                 -  enabled, compact disabled
      + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled, compact disabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, compact disabled, port: 54321
        system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
      + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled, compact disabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1891, bind: 192.168.178.45
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 - disabled, compact disabled
      + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled, compact disabled
        system.adapter.node-red.0               : node-red              : iobroker                                 - disabled, compact disabled, port: 1880, bind: 0.0.0.0
      + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled, compact disabled
      + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled, compact disabled
      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, compact disabled, port: 8006
      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled, compact disabled
        system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled, compact disabled
        system.adapter.schoolfree.1             : schoolfree            : iobroker                                 -  enabled, compact disabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1882, bind: 0.0.0.0
        system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 - disabled, compact disabled
        system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 - disabled, compact disabled
      + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled, compact disabled
        system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, compact disabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.solaredge-modbus.0       : solaredge-modbus      : iobroker                                 - disabled, compact disabled, port: 1502
        system.adapter.solaredge.0              : solaredge             : iobroker                                 -  enabled, compact disabled
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, compact disabled, port: 1887, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled, compact disabled
        system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker                                 - disabled, compact disabled
        system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 - disabled, compact disabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tesla-motors.0           : tesla-motors          : iobroker                                 -  enabled, compact disabled
        system.adapter.text2command.0           : text2command          : iobroker                                 - disabled, compact disabled
      + system.adapter.tibberlink.0             : tibberlink            : iobroker                                 -  enabled, compact disabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled, compact disabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled, compact disabled
      + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled, compact disabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled, compact disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled, compact disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled, compact disabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled, compact disabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.webuntis.0               : webuntis              : iobroker                                 - disabled, compact disabled
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled, compact disabled
      + system.adapter.wireless-mbus.0          : wireless-mbus         : iobroker                                 -  enabled, compact disabled
        system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled, compact disabled
      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, compact disabled, port: tcp://192.168.178.188:6638
      + instance is alive
      ioBroker-Repositories
      Beta (latest) : http://iobroker.live/repo/sources-dist-latest.json
      Stable (default): http://iobroker.live/repo/sources-dist.json
      default.ursprünglich: http://download.iobroker.net/sources-dist.json
      latest.ursprünglich: http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): Stable (default)
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "airconwithme" : 0.0.4    , installed 0.0.4
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "awtrix-light" : 0.10.0   , installed 0.10.0
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
      Adapter    "device-reminder": 3.0.0  , installed 3.0.0
      Adapter    "device-watcher": 2.9.6   , installed 2.9.6
      Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
      Adapter    "echarts"      : 1.5.4    , installed 1.5.4
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
      Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
      Adapter    "go-e"         : 1.0.29   , installed 1.0.29
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.16   , installed 5.0.16
      Adapter    "maxcube"      : 1.0.4    , installed 1.0.4
      Adapter    "mercedesme"   : 0.1.1    , installed 0.1.3
      Adapter    "meross"       : 1.15.1   , installed 1.15.1
      Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "parcel"       : 0.0.27   , installed 0.1.1
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
      Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
      Adapter    "schoolfree"   : 1.1.3    , installed 1.1.3
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
      Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
      Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.1
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
      Adapter    "telegram"     : 3.0.0    , installed 3.0.0
      Adapter    "telegram-menu": 0.8.5    , installed 0.8.5
      Adapter    "tesla-motors" : 1.3.2    , installed 1.4.0
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "tibberlink"   : 1.6.1    , installed 1.6.1
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "unifi"        : 0.6.6    , installed 0.6.6
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-icontwo"  : 0.98.0   , installed 0.98.0
      Adapter    "vis-justgage" : 2.0.2    , installed 2.0.2
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "webuntis"     : 0.3.4    , installed 0.3.4
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "wireless-mbus": 0.9.1    , installed 0.9.1
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
      Objects and States
      Objects:        76024
      States:         53380
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
      W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Get:4 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Err:4 https://dl.yarnpkg.com/debian stable InRelease
      Fetched 17.1 kB in 1s (23.4 kB/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       21206440   2434765/io.sonoff.0
      tcp        0      0 192.168.178.45:1891     0.0.0.0:*               LISTEN      1001       6115434    1903378/io.mqtt.0
      tcp        0      0 192.168.178.45:1892     0.0.0.0:*               LISTEN      1001       6115435    1903378/io.mqtt.0
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       6113685    1903182/iobroker.js
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      108        12678      414/redis-server 12
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1220       1/init
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       6114922    1903717/io.jarvis.0
      tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1001       6113022    1903314/io.hm-rpc.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          719        431/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       6115571    1903536/io.shelly.1
      tcp6       0      0 ::1:6379                :::*                    LISTEN      108        12679      414/redis-server 12
      tcp6       0      0 :::111                  :::*                    LISTEN      0          1224       1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6112923    1903200/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       6119709    1904662/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          721        431/sshd: /usr/sbin
      udp        0      0 0.0.0.0:38132           0.0.0.0:*                           1001       6381360    1903551/io.backitup
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       13604939   55971/io.shelly.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       6114617    1903501/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       6114618    1903501/io.tuya.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14471      342/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1221       1/init
      udp6       0      0 :::111                  :::*                                0          1227       1/init
      2023-12-11 19:03:22.323  - info: sonoff.0 (2434765) Client [Gosund03-Tiefkühler-Küche] connection closed: timeout
      2023-12-11 19:03:22.672  - info: smartthings.0 (1904306) State value to set for "smartthings.0.e3135ff0-60a2-43d8-85fb-5400bee8fad1.status.tvChannel.tvChannel.value" has to be type "number" but received type "string"
      2023-12-11 19:03:32.118  - info: sonoff.0 (2434765) Client [Gosund06-Geschirrspüler] connected with secret 1702317812117_7589
      2023-12-11 19:03:32.678  - info: smartthings.0 (1904306) State value to set for "smartthings.0.e3135ff0-60a2-43d8-85fb-5400bee8fad1.status.tvChannel.tvChannel.value" has to be type "number" but received type "string"
      2023-12-11 19:03:33.865  - info: sonoff.0 (2434765) Client [Gosund26-Lüfter] connected with secret 1702317813865_1176
      2023-12-11 19:03:35.820  - info: sonoff.0 (2434765) Client [Gosund05-Wäschetrockner] connection closed: timeout
      2023-12-11 19:03:36.383  - info: sonoff.0 (2434765) Client [Gosund10-Handstaubsauger] connected with secret 1702317816383_8915
      2023-12-11 19:03:38.007  - info: sonoff.0 (2434765) Client [Gosund07-Waschmaschine] connection closed: timeout
      2023-12-11 19:03:42.728  - info: smartthings.0 (1904306) State value to set for "smartthings.0.e3135ff0-60a2-43d8-85fb-5400bee8fad1.status.tvChannel.tvChannel.value" has to be type "number" but received type "string"
      2023-12-11 19:03:47.551  - info: sonoff.0 (2434765) Client [Gosund20-Kühlschrank] connected with secret 1702317827551_3540
      2023-12-11 19:03:48.334  - info: sonoff.0 (2434765) Client [Gosund01-Zahnbürste 1OG] connection closed: timeout
      2023-12-11 19:03:51.442  - info: sonoff.0 (2434765) Client [Gosund04-Paul] connected with secret 1702317831442_4791
      2023-12-11 19:03:52.735  - info: smartthings.0 (1904306) State value to set for "smartthings.0.e3135ff0-60a2-43d8-85fb-5400bee8fad1.status.tvChannel.tvChannel.value" has to be type "number" but received type "string"
      2023-12-11 19:03:59.481  - info: sonoff.0 (2434765) Client [Gosund25-Keller-IT] connected with secret 1702317839481_2883
      2023-12-11 19:04:00.587  - info: sonoff.0 (2434765) Client [Gosund09-Wasserpumpe] connected with secret 1702317840586_361
      2023-12-11 19:04:04.341  - info: sonoff.0 (2434765) Client [Gosund03-Tiefkühler-Küche] connected with secret 1702317844341_5828
      2023-12-11 19:04:04.365  - info: smartthings.0 (1904306) State value to set for "smartthings.0.e3135ff0-60a2-43d8-85fb-5400bee8fad1.status.tvChannel.tvChannel.value" has to be type "number" but received type "string"
      2023-12-11 19:04:08.777  - info: sonoff.0 (2434765) Client [Gosund07-Waschmaschine] connected with secret 1702317848777_572
      2023-12-11 19:04:14.461  - info: smartthings.0 (1904306) State value to set for "smartthings.0.e3135ff0-60a2-43d8-85fb-5400bee8fad1.status.tvChannel.tvChannel.value" has to be type "number" but received type "string"
      2023-12-11 19:04:17.547  - info: sonoff.0 (2434765) Client [Gosund05-Wäschetrockner] connected with secret 1702317857546_7877
      2023-12-11 19:04:17.872  - info: sonoff.0 (2434765) Client [Gosund15-Zahnbürste DG] connection closed: timeout
      2023-12-11 19:04:18.424  - info: sonoff.0 (2434765) Client [Gosund01-Zahnbürste 1OG] connected with secret 1702317858423_1599
      2023-12-11 19:04:19.999  - info: sonoff.0 (2434765) Client [Gosund11- UlanziKüche] connected with secret 1702317859999_6523
      2023-12-11 19:04:21.747  - info: sonoff.0 (2434765) Client [Gosund14-Heizung] connection closed: timeout
      2023-12-11 19:04:22.948  - info: smartthings.0 (1904306) State value to set for "smartthings.0.e3135ff0-60a2-43d8-85fb-5400bee8fad1.status.tvChannel.tvChannel.value" has to be type "number" but received type "string"
      iob diag has finished.
      v.2023-10-10
      Chassis: vm
      Virtualization: kvm
      Installation: kvm
      Kernel: x86_64
      Userland: amd64
      Timezone: Europe/Berlin (CET, +0100)
      User-ID: 1000
      X-Server: false
      Boot Target: graphical.target
      Pending OS-Updates: 0
      Pending iob updates: 0
      Nodejs-Installation: /usr/bin/nodejs v18.19.0
      /usr/bin/npm 10.2.3
      /usr/bin/npx 10.2.3
      Recommended versions are nodejs 18.19.0 and npm 10.2.3
      MEMORY:
      total used free shared buff/cache available
      Mem: 7.9G 5.7G 1.2G 0.0K 1.0G 2.0G
      Total: 8.9G 5.9G 2.0G
      Active iob-Instances: 46
      ioBroker Core: js-controller 5.0.16
      admin 6.12.0
      ioBroker Status: iobroker is running on this host.
      Objects type: jsonl
      States type: redis
      • system.adapter.admin.0 : admin : iobroker - enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
      • system.adapter.web.0 : web : iobroker - enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects: 76024
      States: 53380
      Size of iob-Database:
      125M /opt/iobroker/iobroker-data/objects.jsonl
      11M /opt/iobroker/iobroker-data/states.jsonl
      =================== END OF SUMMARY ===================
        kiste01 @apollon77 last edited by
        @apollon77
        bin bei 4% - 7%, auch mal kurz bei 75%
          Rushmed Most Active last edited by
          Hallo, ich habe seit heute auch die Meldung dass mir wegen der Anzahl der Objekte Redis empfohlen wird.
          Meine Systemperfomance ist nicht super aber mindestens ok. Toll finde ich dass mindestens seit einem Jahr kein Abrturz zum Totalausfall geführt hat, vermutlich hat das etwas mit der .jsonl Einführung zu tun.
          Beim Lesen dieses Freds bekomme ich den Eindruck mit dem Umstieg auf Redis Performance gegen Stabilität zu tauschen.
          Hinweise wie:
          • DB liegt im RAM
          • ein gutes Backupkonzept muss her
          lassen mich das vermuten. Ist das korrekt so?
          Hier ist meine diag Ausgabe:
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: Smartazamba
                 Icon name: computer
                    Kernel: Linux 6.1.0-rpi7-rpi-v8
              Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
           20:00:30 up 2 days, 22:31,  2 users,  load average: 1.30, 1.02, 1.74
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
                         Local time: Mon 2023-12-11 20:00:30 CET
                     Universal time: Mon 2023-12-11 19:00:30 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            8.2G        4.1G        337M         10M        3.9G        4.1G
          Swap:             0B          0B          0B
          Total:          8.2G        4.1G        337M
                   7810 M total memory
                   3865 M used memory
                   6407 M active memory
                    559 M inactive memory
                    321 M free memory
                    219 M buffer memory
                   3535 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          Raspberry only:
          oom events: 0
            UNIT                LOAD   ACTIVE SUB    DESCRIPTION
          * nut-monitor.service loaded failed failed Network UPS Tools - power device monitor and shutdown controller
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          1 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4      110G   18G   90G  17% /
          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     1.6G   11M  1.6G   1% /run
          /dev/sdb1      ext4      4.6T  3.4T  939G  79% /media/HDD1
          /dev/sdc       ext4      5.5T  3.4T  1.8T  66% /media/HDD2
          /dev/sda1      vfat      253M   42M  211M  17% /boot/firmware
          tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
          [Fri Dec  8 21:28:50 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:E2:C4:A5 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=5bc7cbe7-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Fri Dec  8 21:28:53 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Fri Dec  8 21:28:53 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Fri Dec  8 21:29:08 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
          [Fri Dec  8 21:29:11 2023] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Quota mode: none.
          [Fri Dec  8 21:29:11 2023] EXT4-fs (sdc): mounted filesystem with ordered data mode. Quota mode: none.
          [Mon Dec 11 03:33:57 2023] EXT4-fs (loop0): 1 orphan inode deleted
          [Mon Dec 11 03:33:57 2023] EXT4-fs (loop0): recovery complete
          [Mon Dec 11 03:33:57 2023] EXT4-fs (loop0): mounted filesystem with ordered data mode. Quota mode: none.
          [Mon Dec 11 03:33:58 2023] EXT4-fs (loop0): unmounting filesystem.
          /                /dev/sda2 ext4   rw,noatime
          |-/media/HDD1    /dev/sdb1 ext4   rw,nosuid,nodev,noexec,relatime
          |-/media/HDD2    /dev/sdc  ext4   rw,nosuid,nodev,noexec,relatime
          `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
          /var:
          7.6G    /var/
          2.9G    /var/log
          2.3G    /var/log/journal/3dd7c02f298247188f8650087c821e8c
          2.1G    /var/lib
          Archived and active journals take up 2.2G in the file system.
          2.3G    /opt/iobroker/backups/
          du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor-f9a64f/.piolibdeps/athom-presence-sensor-f9a64f/ESPAsyncTCP-esphome': Permission denied
          du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor-f9a64f/.piolibdeps/athom-presence-sensor-f9a64f/noise-c': Permission denied
          du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor-f9a64f/.piolibdeps/athom-presence-sensor-f9a64f/libsodium': Permission denied
          du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor-f9a64f/.piolibdeps/athom-presence-sensor-f9a64f/ESPAsyncWebServer-esphome': Permission denied
          du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor-f9a64f/.piolibdeps/athom-presence-sensor-f9a64f/ArduinoJson': Permission denied
          du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor-f9a64f/.piolibdeps/athom-presence-sensor-f9a64f/ESPAsyncTCP-esphome@1.2.3': Permission denied
          du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor/.piolibdeps/athom-presence-sensor/ESPAsyncTCP-esphome': Permission denied
          du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor/.piolibdeps/athom-presence-sensor/ESPAsyncWebServer-esphome': Permission denied
          du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor/.piolibdeps/athom-presence-sensor/ArduinoJson': Permission denied
          du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor/.piolibdeps/athom-presence-sensor/ESPAsyncTCP-esphome@1.2.3': Permission denied
          535M    /opt/iobroker/iobroker-data/
          221M    /opt/iobroker/iobroker-data/files
          151M    /opt/iobroker/iobroker-data/backup-objects
          99M     /opt/iobroker/iobroker-data/esphome.0/.esphome
          find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor-f9a64f/.piolibdeps/athom-presence-sensor-f9a64f/ESPAsyncTCP-esphome': Permission denied
          find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor-f9a64f/.piolibdeps/athom-presence-sensor-f9a64f/noise-c': Permission denied
          find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor-f9a64f/.piolibdeps/athom-presence-sensor-f9a64f/libsodium': Permission denied
          find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor-f9a64f/.piolibdeps/athom-presence-sensor-f9a64f/ESPAsyncWebServer-esphome': Permission denied
          find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor-f9a64f/.piolibdeps/athom-presence-sensor-f9a64f/ArduinoJson': Permission denied
          find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor-f9a64f/.piolibdeps/athom-presence-sensor-f9a64f/ESPAsyncTCP-esphome@1.2.3': Permission denied
          find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor/.piolibdeps/athom-presence-sensor/ESPAsyncTCP-esphome': Permission denied
          find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor/.piolibdeps/athom-presence-sensor/ESPAsyncWebServer-esphome': Permission denied
          find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor/.piolibdeps/athom-presence-sensor/ArduinoJson': Permission denied
          find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/athom-presence-sensor/.piolibdeps/athom-presence-sensor/ESPAsyncTCP-esphome@1.2.3': Permission denied
          37M     /opt/iobroker/iobroker-data/objects.jsonl
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          27M     /opt/iobroker/iobroker-data/states.jsonl
          16M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/ibeacon-mondeo/.pioenvs/ibeacon-mondeo/firmware.elf
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
          /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0052-if00-port0
          /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0063-if00-port0
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.6
          Adapters from github:   1
          Adapter State
          + system.adapter.admin.0                  : admin                 : Smartazamba                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : Smartazamba                              -  enabled
          + system.adapter.awtrix-light.0           : awtrix-light          : Smartazamba                              -  enabled
            system.adapter.awtrix-light.1           : awtrix-light          : Smartazamba                              - disabled
          + system.adapter.backitup.0               : backitup              : Smartazamba                              -  enabled
          + system.adapter.denon.0                  : denon                 : Smartazamba                              -  enabled
          + system.adapter.device-watcher.0         : device-watcher        : Smartazamba                              -  enabled
          + system.adapter.deyeidc.0                : deyeidc               : Smartazamba                              -  enabled, port: 8899
          + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : Smartazamba                              -  enabled
          + system.adapter.esphome.0                : esphome               : Smartazamba                              -  enabled
            system.adapter.feiertage.0              : feiertage             : Smartazamba                              -  enabled
            system.adapter.habpanel.0               : habpanel              : Smartazamba                              - disabled
          + system.adapter.hue.0                    : hue                   : Smartazamba                              -  enabled, port: 443
          + system.adapter.ical.0                   : ical                  : Smartazamba                              -  enabled
          + system.adapter.influxdb.0               : influxdb              : Smartazamba                              -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : Smartazamba                              -  enabled
          + system.adapter.iot.0                    : iot                   : Smartazamba                              -  enabled
          + system.adapter.iqontrol.0               : iqontrol              : Smartazamba                              -  enabled
          + system.adapter.javascript.0             : javascript            : Smartazamba                              -  enabled
          + system.adapter.kodi.0                   : kodi                  : Smartazamba                              -  enabled, port: 9090
          + system.adapter.life360.0                : life360               : Smartazamba                              -  enabled
          + system.adapter.linux-control.0          : linux-control         : Smartazamba                              -  enabled
          + system.adapter.logparser.0              : logparser             : Smartazamba                              -  enabled
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : Smartazamba                              -  enabled, port: 54321
          + system.adapter.mqtt.0                   : mqtt                  : Smartazamba                              -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.philips-tv.0             : philips-tv            : Smartazamba                              -  enabled
          + system.adapter.ping.0                   : ping                  : Smartazamba                              -  enabled
          + system.adapter.pixelit.0                : pixelit               : Smartazamba                              -  enabled
          + system.adapter.pixelit.1                : pixelit               : Smartazamba                              -  enabled
            system.adapter.pixelit.2                : pixelit               : Smartazamba                              - disabled
          + system.adapter.shelly.0                 : shelly                : Smartazamba                              -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shuttercontrol.0         : shuttercontrol        : Smartazamba                              -  enabled
          + system.adapter.simple-api.0             : simple-api            : Smartazamba                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.smartmeter.0             : smartmeter            : Smartazamba                              -  enabled
          + system.adapter.smartmeter.1             : smartmeter            : Smartazamba                              -  enabled
          + system.adapter.sonoff.0                 : sonoff                : Smartazamba                              -  enabled, port: 1884, bind: 0.0.0.0
          + system.adapter.sourceanalytix.0         : sourceanalytix        : Smartazamba                              -  enabled
          + system.adapter.telegram.0               : telegram              : Smartazamba                              -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.1               : telegram              : Smartazamba                              -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.unifi.0                  : unifi                 : Smartazamba                              -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : Smartazamba                              -  enabled
          + system.adapter.web.0                    : web                   : Smartazamba                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.windows-control.0        : windows-control       : Smartazamba                              -  enabled
            system.adapter.wiobrowser.0             : wiobrowser            : Smartazamba                              - disabled, port: 5000
          + system.adapter.wled.0                   : wled                  : Smartazamba                              -  enabled
          + system.adapter.ws.0                     : ws                    : Smartazamba                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.yeelight-2.0             : yeelight-2            : Smartazamba                              -  enabled
          + system.adapter.zigbee.0                 : zigbee                : Smartazamba                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
          + system.adapter.zigbee.1                 : zigbee                : Smartazamba                              -  enabled, port: tcp://192.168.178.4:6638
          + instance is alive
          Stable (default): http://download.iobroker.net/sources-dist.json
          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
          latest live   : http://iobroker.live/repo/sources-dist-latest.json
          Adapter    "awtrix-light" : 0.10.0   , installed 0.10.1
          Adapter    "denon"        : 1.15.4   , installed 1.15.4
          Adapter    "device-watcher": 2.9.6   , installed 2.9.9
          Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
          Adapter    "hue"          : 3.10.1   , installed 3.10.1
          Adapter    "kodi"         : 3.0.0    , installed 3.0.0
          Adapter    "linux-control": 1.1.5    , installed 1.1.5
          Adapter    "logparser"    : 2.2.0    , installed 2.2.0
          Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
          Adapter    "pixelit"      : 1.1.3    , installed 1.1.3
          Adapter    "windows-control": 0.1.5  , installed 0.1.5
          Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
          Adapter    "wled"         : 0.7.1    , installed 0.7.1
          Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
          Objects and States
          Objects:        14593
          States:         13373
          Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
          Hit:4 https://apt.grafana.com stable InRelease
          Hit:5 https://repos.influxdata.com/debian stable InRelease
          Hit:6 http://archive.raspberrypi.org/debian bookworm InRelease
          Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
          Pending Updates: 21
          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          844        812/smbd
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3986       652/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          845        812/smbd
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       11232449   2890204/iobroker.js
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       11231912   2890204/iobroker.js
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1002       11236409   2890951/io.shelly.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       11235712   2890921/io.mqtt.0
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1002       11235953   2891003/io.sonoff.0
          tcp        0      0 0.0.0.0:9999            0.0.0.0:*               LISTEN      1000       14687182   3794093/nc
          tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1002       11239324   2893036/python3
          tcp6       0      0 :::445                  :::*                    LISTEN      0          842        812/smbd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          3988       652/sshd: /usr/sbin
          tcp6       0      0 :::139                  :::*                    LISTEN      0          843        812/smbd
          tcp6       0      0 :::3000                 :::*                    LISTEN      109        13712      833/grafana
          tcp6       0      0 :::8081                 :::*                    LISTEN      1002       11233538   2890513/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1002       11238061   2892129/io.web.0
          tcp6       0      0 :::8084                 :::*                    LISTEN      1002       11239261   2892644/io.ws.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        11233293   2890156/influxd
          tcp6       0      0 :::8087                 :::*                    LISTEN      1002       11236903   2892073/io.simple-a
          udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          14810      794/nmbd
          udp        0      0 192.168.178.20:137      0.0.0.0:*                           0          14809      794/nmbd
          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          14797      794/nmbd
          udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          14812      794/nmbd
          udp        0      0 192.168.178.20:138      0.0.0.0:*                           0          14811      794/nmbd
          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          14798      794/nmbd
          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1002       11234006   2890906/io.mihome-v
          udp        0      0 0.0.0.0:49504           0.0.0.0:*                           108        13456      447/avahi-daemon: r
          udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1002       11239332   2893036/python3
          udp        0      0 192.168.178.20:5353     0.0.0.0:*                           1002       11239331   2893036/python3
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       11239327   2893036/python3
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       11240458   2892508/io.esphome.
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       11238802   2892166/io.wled.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13454      447/avahi-daemon: r
          udp6       0      0 :::33004                :::*                                108        13457      447/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        13455      447/avahi-daemon: r
          2023-12-11 19:55:06.593  - info: weatherunderground.0 (3786469) starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v18.19.0, js-controller: 5.0.16
          2023-12-11 19:55:13.631  - info: weatherunderground.0 (3786469) Terminated (NO_ERROR): Without reason
          2023-12-11 19:55:14.299  - info: host.Smartazamba instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
          2023-12-11 19:55:46.394  - info: javascript.0 (2890554) script.js.Lampen._Switch_Status_Synch_: alias.0.Lampe_Ankleide_switch_State = wahr
          2023-12-11 19:56:53.489  - info: linux-control.0 (2891770) getting data from UDM_Pro (192.168.178.1:22)
          2023-12-11 19:56:53.655  - info: linux-control.0 (2891770) successful received data from UDM_Pro (192.168.178.1:22)
          2023-12-11 19:59:15.376  - info: sonoff.0 (2891003) Client [WiFi-Plug8] connection closed: timeout
          2023-12-11 19:59:30.626  - info: sonoff.0 (2891003) Client [Zisterne_ESP] connection closed: timeout
          2023-12-11 19:59:34.641  - info: sonoff.0 (2891003) Client [Zisterne_ESP] connected with secret 1702321174640_2847
          2023-12-11 20:00:00.049  - info: host.Smartazamba instance system.adapter.weatherunderground.0 started with pid 3790661
          2023-12-11 20:00:04.891  - info: weatherunderground.0 (3790661) starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v18.19.0, js-controller: 5.0.16
          2023-12-11 20:00:15.540  - info: weatherunderground.0 (3790661) Terminated (NO_ERROR): Without reason
          2023-12-11 20:00:16.060  - warn: weatherunderground.0 (3790661) get state error: Connection is closed.
          2023-12-11 20:00:16.318  - info: host.Smartazamba instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
          2023-12-11 20:01:00.048  - info: host.Smartazamba instance system.adapter.ical.0 started with pid 3792249
          2023-12-11 20:01:03.319  - info: ical.0 (3792249) Plugin sentry Sentry Plugin disabled for this process because data reporting is disabled on instance
          2023-12-11 20:01:05.681  - info: ical.0 (3792249) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.16
          2023-12-11 20:01:06.956  - info: ical.0 (3792249) processing URL: Urlaub Achmed https://calendar.google.com/calendar/ical/721d7n9uc93fj922qvcnbdmee0%40group.calendar.google.com/private-dd25a2cd91e0eea78d819e34fe353287/basic.ics
          2023-12-11 20:01:07.218  - info: ical.0 (3792249) processing URL: Feiertage https://calendar.google.com/calendar/ical/l3laeal84343un7jfnk086jd60%40group.calendar.google.com/private-01550163684717e766e329dea9b918ed/basic.ics
          2023-12-11 20:01:07.421  - info: ical.0 (3792249) processing URL: Müll MRS-Dorf https://calendar.google.com/calendar/ical/7a23l64891ng2gl3tepk30oogk%40group.calendar.google.com/private-1e69185ba61e0b490f41b74fa49d70b0/basic.ics
          2023-12-11 20:01:08.045  - info: ical.0 (3792249) processing URL: Gemeinsamer Kalender https://calendar.google.com/calendar/ical/7dv9sbegrrlhr2r14s4n0ecc0c%40group.calendar.google.com/private-17d9d3bf2114e6129dba509fd13d00d9/basic.ics
          2023-12-11 20:01:09.275  - info: ical.0 (3792249) processing URL: Achmed's Termine https://calendar.google.com/calendar/ical/acboua%40gmail.com/private-caed1e53a21b74d139fce60f6c675e76/basic.ics
          2023-12-11 20:01:13.188  - info: ical.0 (3792249) processing URL: Jenoptik https://calendar.google.com/calendar/ical/u1n33vfg1dv30uivkev82ukfo8%40group.calendar.google.com/private-bf26811c53d517b6ebe6d136462009ac/basic.ics
          2023-12-11 20:01:20.157  - info: ical.0 (3792249) Terminated (NO_ERROR): Without reason
          2023-12-11 20:01:20.749  - info: host.Smartazamba instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
            apollon77 @kiste01 last edited by
            @kiste01 ehrlich dann alles ok.
              apollon77 @Rushmed last edited by
              @rushmed gleiche Frage wie vor deinen Post. Und ja. Man sollte wissen was man tut. Aber Backup Konzept brauchst du auch so schon 😉
              • UweRLP
                UweRLP last edited by
                Nur mal so.
                Mein iobroker läuft unter Windows.
                Der Info Adapter hat mich heute verwirrt mit der Meldung.
                Vermutlich ist es für mich das Beste die Meldung zu ignorieren?
                Oder gibt es auf Windows in Bezug Redis was neues?
                Das System läuft gut und zügig auf einem
                ? apollon77 2 Replies Last reply Reply Quote 0
                  A Former User @UweRLP last edited by
                  @uwerlp
                  noe, kannst auch Redis auf dem Windows-Server installieren:
                  https://redis.io/docs/install/install-redis/install-redis-on-windows/
                  UweRLP 1 Reply Last reply Reply Quote 0
                  • UweRLP
                    UweRLP @Guest last edited by
                    @ilovegym Macht es auch Sinn?
                    Der Aufwand solch einer Installation zu betreiben und zu pflegen auch wenn das System schnell genug ist?
                    Es gibt Nachteile wenn ich es so belasse wie es ist?
                    Wenn ich es richtig verstanden habe muß ich dann in Zukunft die Redis DB extra sichern. Aktuell langt mir der BackupIt Adapter und regelmässiges kopieren des iobroker Verzeichnisses für ein Komplettbackup vom iobroker.
                    Mich stört es schon, dass ich die MariaDB extra sicher muß, aber wenn diese Daten verloren gehen ist es kein Drama bei der Redis DB denke ich schon.
                      @uwerlp
                      Naja, ich sag mal so:
                      wenn du mit dem System und allem zufrieden bist, du weiterhin iobroker unter Windows betreiben willst, dann lass es, wie es ist.
                      Es sei denn, du weisst, es kommen noch ein paar tausend Objects und States bald hinzu, wegen neuer Devices, die eingebunden werden sollen..
                      Redis ist schneller, und klar, auch die Redis.db muss gesichert werden, das kann auch der Backitup-Adapter (hab jetzt aber keine Erfahrung damit ob er das auch aus dem WSL rausholt.., mit Redis im Docker funktionierts, sollte da auch gehen).
                      Backuppen musste bei Redis nur die /var/lib/redis/redis.db und die /etc/redis/redis.conf, ist einfach umzuziehen.
                      Meine persoenliche Meinung ist, ein Linux System ist einfacher zu pflegen als Windows mit Linux-Implantationen.. 🙂
                      (das ist so, wenn man ein Sportwagen auf der Ladeflaeche eines LKW parkt und dann immer nur mit dem LKW rumfaehrt.., muss trotzdem beides regelmaessig in die Werkstatt und zum TUEV.. )
                      Und die Windows-Version, die du hier nutzt, ist eine Desktop-Version, und kein Server Betriebssystem...
                      Ich finde, das beste, was man mit Windows als Server machen kann, ist loeschen.. 🙂 und dann n Vernuenftiges Linux installieren, also Debian, RedHat, Suse..
                      • UweRLP
                        @ilovegym Erstmal danke für deine Meinung/Ausführung.
                        Ich habe auch schon mehmals mit dem Gedanken gespielt das alles unter Proxmox zum laufen zu bringen. Hatte auch schon mal in der Vergangeheit eine Teilinstallation. Allerding wird man da von neuen Informationen erschlagen. Es gilt bei meiner Installation nicht nur iobroker umzuziehen sonder auch noch CCU-Historian, Conbee II dann noch die MariaDB... alle lösbar ich weis 😊
                        Läuft aktuell alles unter dem Windows Desktop System
                        Dann später alles aktuell zu halten, geht ja unter Linux deutlich anderst als unter Windows.
                        Dann die Backups, ist ja doch schon eine Umfangreiche Installation.
                        Unter Windows beende ich die Software und mach mit TotalCommander eine Kopie des Installationsverzeichnisses. Das Blicke ich, unter Linux verlasse ich mich auf Backupsoftware wo ich nicht sicher weis was die treibt und ob das Backup später nutzbar ist.
                        Proxmaox wäre dann so ein Kompromiss weil die VM's recht einfach zu sichern sind.
                        Ich glaub ich schweife ab... sorry
                          @uwerlp
                          Hi, ja, wenn du zufrieden bist mit deinem System, dann lass es so, mach da schoen die Updates mit, und alles ist gut.
                          Redis kann man, muss man aber nicht. Mit JsonL ist ja schon eine bessere und schnellere Verwaltung vorhanden, als mit files/files, wie es frueher war.
                            apollon77 @vepman last edited by
                            @vepman Mit den CPU Werten. Lass es was Umstellung angeht. Wir passen die Meldung an
                              apollon77 @UweRLP last edited by
                              @uwerlp Siehe ooben. Wenn die klast des js.controller ok ist dann nichts tun. Alles gut
                                Rushmed Most Active @apollon77 last edited by
                                @apollon77 Im Htop sehe ich für iobroker.js-controller ständig wechselnde Werte von 8...80 CPU% im Mittel aber etwa 35. Für das Gesamtsystem wird Load average: 1,12 1,21 1,28 angezeigt. Habe vier Kerne.
                                Ist da jetzt der Wechsel empfohlen?
                                  @rushmed Ich würde sagen das ist ok - es sei denn Du siehst Performanceissues bei der Nutzung
                                    @apollon77 Klar könnte alles schneller sein aber ich bin sehr zufrieden, vor allem wegen der Satbilität.
                                    Danke für den Rat.
                                      Bert 0 last edited by
                                      ich bin gerade dabei, mit meinem Qnap alles in Container zu verschieben. Dazu eine Frage.
                                      Ich habe Iobroker + Iobroker Slave auf einem Raspberry und möchte zukünftig mit redis auch Nextcloud im Container betreiben.
                                      Kann ich das alles mit einem installierten Rediscontainer machen?
                                      Danke Bert
                                      apollon77 JLeg Marc Berg 3 Replies Last reply Reply Quote 0
                                        apollon77 @Bert 0 last edited by
                                        @bert-0 sagte in Redis in ioBroker - Überblick:
                                        Klar ... Am Ende ist dieser Redis dann der neue "Master" im ioBroker System ...
                                        • JLeg
                                          JLeg @Bert 0 last edited by
                                          du möchtest eine Redis-Instanz für iobroker und Nextcloud nutzen? Dann achte einfach darauf, dass du bei Nextcloud in der Redis-Config einen "dbindex" > "0" einträgst - dann kommen sich die beiden nicht in die Quere (afair hat Redis im Default 16 "Datenbanken" konfiguriert, ohne weitere Angaben landet man üblicherweise in DB "0". Da dürfte dann der iobroker drin sein...)
                                            Bert 0 @JLeg last edited by Bert 0
                                            @jleg @apollon77
                                            Danke euch beiden. Ich werde nach Weihnachten mich mal ans Werk machen.
                                            Falls das mit der Redisdatenbank schief läuft, ist das ja über
                                            iobroker setup custom
                                            wieder rückgängig zu machen?
                                            Hoffe das es klappt, da das Antwortverhalten beim Iobroker schon grenzwertig ist ( Der Info TAB weist mich darauf hin, dass ich mehr als 30000 Objekte habe) und bei Nextcloud ausserhalb des Containers der Aufwand immer größer und dort die Anhebung der PHP Version mit QNAP immer schwieriger wird.
                                            Bert
                                            81.1k
                                            js-controller redis
                                            35
                                            136
                                            57682
