    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. OpenDTU-onBattery
    OpenDTU-onBattery
    • Ralla66
      Ralla66 Most Active @Schmakus last edited by
      @schmakus
      eher nein, das Risiko das falsche Daten im Speicher verbleiben ist zu groß.
      Da durch hast du eventuell ein nicht sauber ausgeführtes Programm.
        PV Bastler @Ralla66 last edited by
        @ralla66
        Screenshots von Tasmota
        Danke für die Unterstützung!
        Ralla66 1 Reply Last reply Reply Quote 0
        • Ralla66
          Ralla66 Most Active @PV Bastler last edited by
          @pv-bastler
          bitte von der Konsole, du hast das script hochgeladen 🙂
            @ralla66
            Sory!
            15:13:24.556 RSL: STATE = {"Time":"2023-12-13T15:13:24","Uptime":"0T22:20:09","UptimeSec":80409,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzVM","BSSId":"98:9B:CB:A1:8A:DD","Channel":1,"Mode":"11n","RSSI":100,"Signal":-35,"LinkCount":2,"Downtime":"0T00:00:05"}}
            15:13:24.562 RSL: SENSOR = {"Time":"2023-12-13T15:13:24","":{"power":294,"counter_pos":800.90,"counter_neg":94.14}}
            15:18:24.560 RSL: STATE = {"Time":"2023-12-13T15:18:24","Uptime":"0T22:25:09","UptimeSec":80709,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzVM","BSSId":"98:9B:CB:A1:8A:DD","Channel":1,"Mode":"11n","RSSI":100,"Signal":-35,"LinkCount":2,"Downtime":"0T00:00:05"}}
            15:18:24.565 RSL: SENSOR = {"Time":"2023-12-13T15:18:24","":{"power":2325,"counter_pos":801.02,"counter_neg":94.14}}
            15:23:24.582 RSL: STATE = {"Time":"2023-12-13T15:23:24","Uptime":"0T22:30:09","UptimeSec":81009,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzVM","BSSId":"98:9B:CB:A1:8A:DD","Channel":1,"Mode":"11n","RSSI":100,"Signal":-34,"LinkCount":2,"Downtime":"0T00:00:05"}}
            15:23:24.588 RSL: SENSOR = {"Time":"2023-12-13T15:23:24","":{"power":2268,"counter_pos":801.21,"counter_neg":94.14}}
            15:28:24.591 RSL: STATE = {"Time":"2023-12-13T15:28:24","Uptime":"0T22:35:09","UptimeSec":81309,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzVM","BSSId":"98:9B:CB:A1:8A:DD","Channel":1,"Mode":"11n","RSSI":100,"Signal":-35,"LinkCount":2,"Downtime":"0T00:00:05"}}
            15:28:24.597 RSL: SENSOR = {"Time":"2023-12-13T15:28:24","":{"power":2056,"counter_pos":801.39,"counter_neg":94.14}}
            15:33:24.580 RSL: STATE = {"Time":"2023-12-13T15:33:24","Uptime":"0T22:40:09","UptimeSec":81609,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzVM","BSSId":"98:9B:CB:A1:8A:DD","Channel":1,"Mode":"11n","RSSI":100,"Signal":-36,"LinkCount":2,"Downtime":"0T00:00:05"}}
            15:33:24.585 RSL: SENSOR = {"Time":"2023-12-13T15:33:24","":{"power":2049,"counter_pos":801.57,"counter_neg":94.14}}
            15:38:24.581 RSL: STATE = {"Time":"2023-12-13T15:38:24","Uptime":"0T22:45:09","UptimeSec":81909,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzVM","BSSId":"98:9B:CB:A1:8A:DD","Channel":1,"Mode":"11n","RSSI":100,"Signal":-36,"LinkCount":2,"Downtime":"0T00:00:05"}}
            15:38:24.586 RSL: SENSOR = {"Time":"2023-12-13T15:38:24","":{"power":2076,"counter_pos":801.75,"counter_neg":94.14}}
            15:43:24.961 RSL: STATE = {"Time":"2023-12-13T15:43:24","Uptime":"0T22:50:09","UptimeSec":82209,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzVM","BSSId":"98:9B:CB:A1:8A:DD","Channel":1,"Mode":"11n","RSSI":100,"Signal":-36,"LinkCount":2,"Downtime":"0T00:00:05"}}
            15:43:24.967 RSL: SENSOR = {"Time":"2023-12-13T15:43:24","":{"power":2303,"counter_pos":801.93,"counter_neg":94.14}}
            15:48:24.583 RSL: STATE = {"Time":"2023-12-13T15:48:24","Uptime":"0T22:55:09","UptimeSec":82509,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzVM","BSSId":"98:9B:CB:A1:8A:DD","Channel":1,"Mode":"11n","RSSI":100,"Signal":-34,"LinkCount":2,"Downtime":"0T00:00:05"}}
            15:48:24.588 RSL: SENSOR = {"Time":"2023-12-13T15:48:24","":{"power":339,"counter_pos":801.98,"counter_neg":94.14}}
            15:53:24.577 RSL: STATE = {"Time":"2023-12-13T15:53:24","Uptime":"0T23:00:09","UptimeSec":82809,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FritzVM","BSSId":"98:9B:CB:A1:8A:DD","Channel":1,"Mode":"11n","RSSI":100,"Signal":-36,"LinkCount":2,"Downtime":"0T00:00:05"}}
            15:53:24.583 RSL: SENSOR = {"Time":"2023-12-13T15:53:24","":{"power":243,"counter_pos":802.01,"counter_neg":94.14}}
            • Ralla66
              @pv-bastler
              Telemetrieperiode in Tasmota steht auf 10 ?
              Mqtt hast du eingerichtet in Tasmota ?
                @ralla66
                Nein, habe sonst nichts eingerichtet.
                Außer Script.
                • Ralla66
                  @pv-bastler
                  teste mal im Browser :
                  http:// deine Tasmota IP /cm?cmnd=Status%2010
                  dann sollte sowas erscheinen ->
                    @ralla66
                    Muss warscheinlich mttq einrichten. Bei der Eingabe http://192.168.178.62 /cm?cmnd=Status%2010 kommt nichts raus.
                    Telemetrieperiode hab ich geändert von 300 auf 10
                    • Ralla66
                      Ralla66 Most Active @PV Bastler last edited by Ralla66
                      @pv-bastler
                      ok richte mal Mqtt und Sonoff Adapter ein.
                      Bei -> http:// deine Tasmota IP /cm?cmnd=Status%2010 achte auf http://
                      moderne Browser machen da gerne automatisch https raus
                      • Ralla66
                        Ralla66 Most Active @Ralla66 last edited by Ralla66
                        @ralla66
                        so als Tipp, Port 1886 oder 1887 nehmen da der Mqtt Adapter default 1883 hat
                        3 Haken setzen
                        zum testen nimm einfache Paßworte, 1234 oder so, keine Sonderzeichen.
                        rebooten Adapter und Esp nach den Eingaben
                          @ralla66
                          Das mit https hattest du recht.
                          Jetzt kommt sowas: {"StatusSNS":{"Time":"2023-12-13T17:33:53","":{"power":1127,"counter_pos":804.78,"counter_neg":94.14}}}
                          Leider kann ich mit sonoff überhaupt nichts anfangen. Ich dachte es wird außer Tasmota Ir und OpenDTU on Battery keine weitere Hardware benötigt. Ist sonoff Software? Werde mich später noch "schlau" googeln.
                          • Ralla66
                            @pv-bastler sagte in OpenDTU-onBattery:
                            schwierig da bei dir nur "," steht ,sonst wäre das etwa so
                            JSON bei dir:
                            StatusSNS/ ??? /power
                            bild war falsch
                            • Ralla66
                              @ralla66
                              mein script
                              >D
                              >B
                              =>sensor53 r
                              >M 1
                              +1,3,s,0,9600,MT175
                              1,77070100000000ff@#
                              schreibe mal in deinem script hinter 9600, Test hin. ( ist bei mir MT175 )
                              Also +1,3,s,0,9600,Test
                              dann teste noch einmal im Browser, dann sollte statt "," dort Test stehen
                              Dann wäre dein JSON
                              StatusSNS/Test/power
                              Dann sollte das kommen:
                              {"StatusSNS":{"Time":"2023-12-13T17:33:53"Test"":{"power":1127,"counter_pos":804.78,"counter_neg":94.14}}}
                                @ralla66
                                Du bist der Beste. Genau so gemacht und jetzt funktioniert es!
                                • Ralla66
                                  @pv-bastler
                                  für die Nachwelt noch ein Bild des Json in OpenDtu on Battery damit es andere leichter haben.
                                    @ralla66
                                    Bei mir bleibt die Http Anfrage wird gesendet unverändert.
                                    Leistung/Netz ändert sich nur bei Aktualisierung der Seite, ist das so normal?
                                    Ralla66 P 2 Replies Last reply Reply Quote 0
                                    • Ralla66
                                      @pv-bastler
                                      schau mal oben im Beitrag am 4 Nov 12:47
                                      hatte http und JSON unter Phase 1 eingetragen
                                        PV Bastler @PV Bastler last edited by
                                        @pv-bastler said in OpenDTU-onBattery:
                                        @ralla66
                                        Alles läuft wie geschmiert. War mein Fehler.
                                        Danke nochmal!
                                        • Ralla66
                                          @pv-bastler
                                          Prima, Top
                                          Webranger 1 Reply Last reply Reply Quote 0
                                          • Webranger
                                            Webranger @Ralla66 last edited by
                                            Kann ich irgendwie den Wert von meinem Discovergy Zähler in die openDTU onbattery schicken?
                                            Sollte doch auch gehen oder? Habe den wert ja in den Objekten stehen.
                                            opendtu pylontech shellys victron ve direkt
                                            23
                                            94
                                            36865
