    4. Test Adapter Bosch ebik connect / flow
      Thomas Braun Most Active @draexler last edited by
      @draexler sagte in Test Adapter Bosch ebik connect / flow:
      evtl. funktioniert es seit dem nicht mehr.
      Nee, das passt.
      Besser aber den stabilen Befehl
      iob nodejs-update
      verwenden.
      • bahnuhr
        Ich habe auch seit Heute im log:
        host.iobroker
        2023-12-02 10:38:18.898	error	instance system.adapter.bosch-ebike.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        host.iobroker
        2023-12-02 10:38:18.898	error	Caught by controller[1]: at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
        host.iobroker
        2023-12-02 10:38:18.898	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
        host.iobroker
        2023-12-02 10:38:18.898	error	Caught by controller[1]: at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:41)
        host.iobroker
        2023-12-02 10:38:18.898	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'value')
        host.iobroker
        2023-12-02 10:38:18.898	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        bosch-ebike.0
        2023-12-02 10:38:18.322	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        bosch-ebike.0
        2023-12-02 10:38:18.321	info	terminating
        bosch-ebike.0
        2023-12-02 10:38:18.311	error	Cannot read properties of undefined (reading 'value')
        bosch-ebike.0
        2023-12-02 10:38:18.311	error	TypeError: Cannot read properties of undefined (reading 'value') at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:41) at processTicksAndRejections (node:internal/process/task_queues:95:5) at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
        bosch-ebike.0
        2023-12-02 10:38:18.307	error	unhandled promise rejection: Cannot read properties of undefined (reading 'value')
        bosch-ebike.0
        2023-12-02 10:38:18.307	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        javascript.0
        2023-12-02 10:38:17.427	info	script.js.Scripte.Licht.Flur2_EG: Licht Flur 2 EG ausgeschaltet.
        bosch-ebike.0
        2023-12-02 10:38:17.265	info	Login to eBike flow
        Keine Veränderung durchgeführt. Und ich bin aktuell.
        Habe auch gleich ein issue erstellt.
        https://github.com/TA2k/ioBroker.bosch-ebike/issues/12
        bahnuhr created this issue in TA2k/ioBroker.bosch-ebike
        closed iob Fehler im log; Adapter wird nicht grün #12
        • bahnuhr
          Habe 0.1.5 installiert.
          Dann war alles ok.
            Marcus007 last edited by
            der Adapter funktioniert gut (Flow-App).
            Toll ist, dass die letzte Fahrt immer 01 ist.
            Was mache ich falsch, dass der Batteriestatus nicht angezeigt wird?
            Ein entsprechender Datenpunkt ist ja vorhanden.
            Viele Grüße
            Marcus
            • bahnuhr
              bahnuhr Forum Testing Most Active @Marcus007 last edited by
              @marcus007 sagte in Test Adapter Bosch ebik connect / flow:
              zeig den mal.
              ich habe bei den Objekten kein DP.
                Marcus007 @bahnuhr last edited by
                @bahnuhr
                Marcus
                • bahnuhr
                  @marcus007
                  Ah, ja doch den hab ich auch.
                  Steht aber nix drin.
                    @bahnuhr
                    Gibts keine Aussicht auf Übernahme des Akkustands?
                    Marcus
                    • bahnuhr
                      @marcus007
                      Keine Ahnung,
                      Ich glaube auch nicht, dass dies der Akkustand ist.
                      Sieht für mich eher aus wie: Verbrauch des Akkus während des trips.
                      Denn dieser DP gibt es ja bei allen trips.
                      Aber mach doch mal ein issue auf git auf.
                        tombox @bahnuhr last edited by
                        @bahnuhr Ja das ist der Verbrauch pro trip. Wird denn sowas in der app angezeigt? im Debug log sieht man auch immer was direkt von der API kommt
                        bahnuhr 2 Replies Last reply Reply Quote 0
                        • bahnuhr
                          bahnuhr Forum Testing Most Active @tombox last edited by
                          @tombox
                          Habe gerade mal in die app auf dem Handy unter Statistiken geschaut.
                          Dort steht bei den trips nichts von Battery.
                          Aber den DP musst du doch irgendwo her haben. Vielleicht gibt es diesen ja bei dem connect System.
                          Nur halt nicht bei flow.
                          • bahnuhr
                            bahnuhr Forum Testing Most Active @tombox last edited by bahnuhr
                            @tombox
                            Aber mal eine andere Frage:
                            In der app sieht man bei den trips ein kleines Bild (google maps oder unten links steht mapbox).
                            Könnte man dieses Bild auch einlesen um es dann in vis darstellen zu können.
                            Unter Details sind jede Menge Infos bzgl. lat und lon. Nur wie macht man daraus ein Bild ?
                              @bahnuhr Er kommt via API als leerer Wert zurück. Er wird nur nicht in der App dargestellt
                              • I
                                IOMax last edited by
                                Ich hatte gestern auf redis umgestellt und dabei ist mir aufgefallen, dass die Instanz nicht grün wird. Das ging noch mit den selben Credentials vor ein paar Wochen.
                                Der Log sagt:
                                error Error: getaddrinfo ENOTFOUND singlekey-id.comundefined
                                info starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.bosch-ebike, node: v18.19.0, js-controller: 5.0.17
                                Ich habe den Adapter auch schon gelöscht und neu installiert. Ändert aber leider nichts.
                                Gruß, Max
                                  tombox @IOMax last edited by
                                  @iomax die npm version sollte das problem nicht haben nur die GitHub version. GitHub version ist jetzt gefixt
                                  bahnuhr 1 Reply Last reply Reply Quote 1
                                  • I
                                    @tombox klappt jetzt über die GItHub Version. Vorher hatte ich den über das iobroker repository (nutze iobroker im Synology Docker) geladen. Die hatte ich ja auch nicht verändert und plötzlich lief es nicht mehr.
                                    • bahnuhr
                                      @tombox
                                      habe von npm die 0.1.5 installiert.
                                      Seit heute im log:
                                      bosch-ebike.0
                                      2023-12-15 20:49:50.053	error	Error: getaddrinfo ENOTFOUND singlekey-id.comundefined
                                      bosch-ebike.0
                                      2023-12-15 20:49:48.968	info	Login to eBike flow
                                      bosch-ebike.0
                                      2023-12-15 20:49:48.948	info	starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.bosch-ebike, node: v18.18.2, js-controller: 5.0.17
                                      Adapter bleibt gelb.
                                      Ist aber erst seit heute !
                                      • bahnuhr
                                        Und eben die 0.1.5. von git installiert.
                                        Da wurde die Instanz grün.
                                        draexler 1 Reply Last reply Reply Quote 0
                                        • draexler
                                          draexler @bahnuhr last edited by
                                          Hi, adapter seit heute wieder gelb. Jemand auch mit dem Problem?
                                          • bahnuhr
                                            bahnuhr Forum Testing Most Active @draexler last edited by
                                            @draexler
                                            Bei mir noch grün.
                                            178
                                            32301
