    4. Adapter: ioBroker.unifi
      Pino72 @Meister Mopper last edited by Pino72
      @meister-mopper
      Leider immer noch selbes Problem mit 8.0.7.
      Bin auf neuestem ioBroker auf Windows, alles aktuell und Adapter 0.6.6.
      Und Pro wie gesagt auf 8.0.7
        warp735 last edited by
        Hab heute die UDM Pro auf die 3.2.7 gezogen und bekomm den Adapter nicht mehr auf grün. Ist da was bekannt?
        unifi.0
        	2023-12-13 09:32:29.199	info	terminating
        unifi.0
        	2023-12-13 09:32:28.698	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        unifi.0
        	2023-12-13 09:32:28.698	info	terminating
        unifi.0
        	2023-12-13 09:32:28.698	info	cleaned everything up...
        unifi.0
        	2023-12-13 09:32:28.696	error	Cannot read properties of undefined (reading 'captureException')
        unifi.0
        	2023-12-13 09:32:28.696	error	TypeError: Cannot read properties of undefined (reading 'captureException') at Unifi.handleError (/opt/iobroker/node_modules/iobroker.unifi/main.js:243:53) at Unifi.updateUnifiData (/opt/iobroker/node_modules/iobroker.unifi/main.js:268:22) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
        unifi.0
        	2023-12-13 09:32:28.696	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
        unifi.0
        	2023-12-13 09:32:28.696	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        unifi.0
        	2023-12-13 09:32:28.695	error	[updateUnifiData-login site undefined] error: Request failed with status code 401, stack: AxiosError: Request failed with status code 401 at settle (/opt/iobroker/node_modules/node-unifi/node_modules/axios/dist/node/axios.cjs:1909:12) at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/node-unifi/node_modules/axios/dist/node/axios.cjs:2989:11) at IncomingMessage.emit (node:events:529:35) at endReadableNT (node:internal/streams/readable:1400:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
        unifi.0
        	2023-12-13 09:32:28.695	error	Error site undefined (data): {"error":{"code":401,"message":"Unauthorized"}}
        unifi.0
        	2023-12-13 09:32:28.595	info	UniFi adapter is ready
          A Former User @warp735 last edited by
          @warp735 noe, Adapter laeuft einwandfrei auf 3.2.7 und Netzwerk 8.0.x
          Welche Version vom Adapter benutzt du denn?
          draexler W 2 Replies Last reply Reply Quote 0
          • draexler
            draexler @Guest last edited by
            @ilovegym Funktioniert bei dir noch die Vouchererstellung?
              A Former User @draexler last edited by
              @draexler
              Ich nutze das leider nicht, kann ich nicht sagen..
              draexler 1 Reply Last reply Reply Quote 0
                warp735 @Guest last edited by
                @ilovegym
                @ilovegym sagte in Adapter: ioBroker.unifi:
                stable 0.6.6
                bin jetzt auf die 0.6.7 und damit läufts wieder. Vielen Dank für den Schubs 👍
                  fliegema @warp735 last edited by
                  @warp735 Gude, muss mal blöd fragen, wie hast du die Version bekommen? Das ist ja noch nicht stable, aber selbst wenn ich
                  sudo npm i iobroker.unifi@0.6.7
                  eingebe, installiert er die Version zwar aber, im iobroker kommt die nicht an.
                  Sonst warte ich einfach, bis die Version stable wird.
                  Meister Mopper W Thomas Braun 3 Replies Last reply Reply Quote 0
                  • Meister Mopper
                    Meister Mopper @fliegema last edited by
                    @fliegema sagte in Adapter: ioBroker.unifi:
                    Das funktioniert im Expertenmodus über die Github-Katze. Bei 4. die Github-url reinkopieren.
                      warp735 @fliegema last edited by
                      @fliegema
                      Hab kurzzeitig auf latest gestellt, dann hats die angezeigt.
                        Thomas Braun Most Active @fliegema last edited by
                        Bitte NIE, NIE, NIE Befehle wie npm, iobroker usw. mit root-Rechten/sudo anpacken. NIE!
                        Hant0r 1 Reply Last reply Reply Quote 0
                        • Hant0r
                          Hant0r @Thomas Braun last edited by
                          @thomas-braun kannst du kurz erklären warum? - würde mich interessieren 🙂
                            Thomas Braun Most Active @Hant0r last edited by Thomas Braun
                            @hant0r
                            Weil sudo (ohne weitere Optionen) immer die root-Rechte heranzieht. Und Dateien, die mit diesen angepackt wurden dann dem root gehören und von anderen Usern nicht verwendet werden können (wenn die Rechte nicht im Nachgang angepasst wurden).
                            Und man verwendet den root bzw. dessen Rechte nur dort, wo es unbedingt erforderlich ist, wenn es also in Bereiche im System geht, die für 'normale' user tabu sind. Den ioBroker kann aber jeder user anpacken, der auch in der Gruppe 'iobroker' enthalten ist. Sollte dein Standarduser aber sein.
                            Bei 'npm' kommt noch dazu, dass dieses Kommando im richtigen Verzeichnis ausgeführt werden muss. Da man das aber bei dir auch nicht sieht, wo du da standst gehe ich davon aus, dass du nun mit root-Rechten in ein home-Verzeichnis gedonnert hast. Also alles krumm.
                            Edit: User verwechselt. Der root-Missbraucher war ja @fliegema
                            Hant0r 1 Reply Last reply Reply Quote 1
                            • Hant0r
                              Hehe, dachte gerade schon, wieso ich?! 😄
                              Mich hat es nur interessiert, da ich im Linux-Umfeld nicht so bewandt bin - daher vielen Dank für die schlüssige Erklärung.
                              Bei NPM etc. verlasse ich mich immer voll auf die Anleitungen, die es hier im Forum gibt.
                              Bisher hat das auch (toi toi toi) meist gut geklappt 🙂
                              • Negalein
                                seit 0.6.7 startet der Adapter immer neu und die CPU schießt in die Höhe.
                                unifi.0 2023-12-14 16:51:11.294	error	[updateUnifiData-fetchSites site undefined] error: Cannot find view "system", stack: Error: Cannot find view "system" at ObjectsInRedisClient._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4317:19) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4392:37)
                                unifi.0 2023-12-14 16:51:11.246	error	Cannot find view "system" for search "state" : Connection is closed.
                                unifi.0 2023-12-14 16:51:11.245	error	[updateUnifiData site default] error: DB closed, stack: Error: DB closed at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24) at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25) at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40) at Unifi._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7710:33)
                                unifi.0 2023-12-14 16:51:11.127	warn	get state error: Connection is closed.
                                unifi.0 2023-12-14 16:51:00.720	error	[updateUnifiData-fetchSites site undefined] error: DB closed, stack: Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
                                unifi.0 2023-12-14 16:50:00.727	warn	get state error: Connection is closed.
                                unifi.0 2023-12-14 16:49:00.540	warn	get state error: Connection is closed.
                                • Meister Mopper
                                  Meister Mopper @Negalein last edited by
                                  @negalein sagte in Adapter: ioBroker.unifi:
                                  Das kann ich bei mir nicht beobachten. Ich sehe aber gerade, dass dein node.js etwas hinterher hinkt, vielleicht ist es das 🤷‍♂️ .
                                  • Negalein
                                    Negalein Global Moderator @Meister Mopper last edited by
                                    @meister-mopper sagte in Adapter: ioBroker.unifi:
                                    Ich sehe aber gerade, dass dein node.js etwas hinterher hinkt, vielleicht ist es das .
                                    vergess ich immer in der Signatur auszubessern.
                                    • Meister Mopper
                                      @negalein
                                      thomas@iobroker:~$ nodejs -v
                                      v18.19.0
                                      thomas@iobroker:~$ npm -v
                                      10.2.3
                                      thomas@iobroker:~$
                                      Dann stimmts trotzdem nicht 😁
                                      • draexler
                                        @ilovegym ok, trotzdem danke
                                        Gehts bei jemand anders noch? Will nur ausschließen das es an mir liegt.
                                          Pino72 @draexler last edited by
                                          Hi, hab denb Adapter auf 0.6.7 geupdated...ledier bekomme ich immer noch folgenden Fehler wie schon davor:
                                          [updateUnifiData-login site undefined] error: timeout of 10000ms exceeded, stack: AxiosError: timeout of 10000ms exceeded at RedirectableRequest.handleRequestTimeout (C:\Program Files\ioBroker\node_modules\axios\lib\adapters\http.js:643:16) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at Timeout.<anonymous> (C:\Program Files\ioBroker\node_modules\follow-redirects\index.js:179:12) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7)
                                          Habt ihr das auch oder nur bei mir so? Wie kann man das beheben? Leider wir der is_online Wert dann nicht mehr aktualisiert....
                                            A Former User @Pino72 last edited by
                                            @pino72
                                            Update mal deine Konfig, der Fehler sagt, dass du da nichts eingetragen hast..
                                            ( updateUnifiData-login site undefined )
                                            1.2k
                                            unifi
                                            171
                                            1010
                                            385450
