    4. Twinkly Adapter bleibt gelb
    • wollerosekaufe
      wollerosekaufe last edited by
      hab mir den adapter spaßhalber einmal angesehen.
      wenn ich den starte, einfach mal mit 127.0.0.1 als MQTT, sieht der debug log bei mir völlig anders aus:
      twinkly.0
      	2023-12-08 17:57:48.747	error	[test.interview.fw] Error: connect ECONNREFUSED 127.0.0.1:80
      twinkly.0
      	2023-12-08 17:57:48.744	debug	[test.request.GET] Error: "connect ECONNREFUSED 127.0.0.1:80", code="ECONNREFUSED", status=null, config="{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Content-Type":"application/json","X-Auth-Token":"","User-Agent":"axios/1.6.2","Content-Length":"4","Accept-Encoding":"gzip, compress, deflate, br"},"baseURL":"http://127.0.0.1/xled/v1/","url":"fw/version","method":"get","data":"null"}", stack="Error: connect ECONNREFUSED 127.0.0.1:80 at Function.AxiosError.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:606:25) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24) at ClientRequest.emit (node:events:529:35) at ClientRequest.emit (node:domain:489:12) at Socket.socketErrorListener (node:_http_client:501:9) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12)"
      twinkly.0
      	2023-12-08 17:57:48.140	debug	[test.request.GET] path="fw/version", body="null", headers="{}"
      twinkly.0
      	2023-12-08 17:57:48.090	debug	[test.ping] Ping result for 127.0.0.1: true in 0.130ms
      twinkly.0
      	2023-12-08 17:57:48.033	debug	[ping.probe] System command: /bin/ping -n -w 2 -c 1 127.0.0.1
      twinkly.0
      	2023-12-08 17:57:48.028	debug	[poll] Start polling...
      twinkly.0
      	2023-12-08 17:57:48.024	debug	[processObjectChanges] No tasks to process!
      twinkly.0
      	2023-12-08 17:57:48.021	debug	[processObjectChanges] Prepare tasks of objects update
      twinkly.0
      	2023-12-08 17:57:48.018	debug	[processObjectChanges] Add instance objects
      twinkly.0
      	2023-12-08 17:57:48.016	debug	[processObjectChanges] Remove all connections listed in config ==> Deletes all old connections
      twinkly.0
      	2023-12-08 17:57:47.852	debug	[processObjectChanges] Get existing objects
      twinkly.0
      	2023-12-08 17:57:47.783	debug	[syncConfig] config network: false
      twinkly.0
      	2023-12-08 17:57:47.782	debug	[syncConfig] config mqtt: false
      twinkly.0
      	2023-12-08 17:57:47.781	debug	[syncConfig] config details: false
      twinkly.0
      	2023-12-08 17:57:47.780	debug	[syncConfig] config interval: 60
      twinkly.0
      	2023-12-08 17:57:47.777	debug	[syncConfig] config devices: [{"enabled":true,"name":"test","host":"127.0.0.1","stateOn":"color"}]
      twinkly.0
      	2023-12-08 17:57:47.728	info	starting. Version 1.0.14 in /opt/iobroker/node_modules/iobroker.twinkly, node: v18.19.0, js-controller: 5.0.17
      bei dir besteht der halbe log aus redis/objects, vom networking kommt wenig bis nix. wundert mich etwas...
      wie sieht das bei dir denn aus wenn du mal eine zweite instanz aufmachst und dasselbe probierst?
      "das mit docker" mag zwar vlt. nicht SO kompliziert sein, aber wie @homoran schon andeutet 😄 ohne exakte infos (networking) geht da nichts voran.
      würde ins blaue hineinraten dass du in docker kein (host-)network definiert hast - oder der port f. twinkly fehlt (scheint über 80 zu gehen?! O_o)
        base last edited by
        @wollerosekaufe
        vielen Dank, ich habe keine Ahnung was da im Docker definiert ist. Hab mich bei der Insatallation an die Anleitung von smarthome.buanet.de gehalten. Sonst funktioniert ja alles und der Adapter hat ja auch mal funktioniert. Hab jetzt das Script von @patrickbs96 https://github.com/patrickbs96/script.twinkly ausprobiert, damit kann ich die Lichterkette erstmal steuern.
        patrickbs96 1 Reply Last reply Reply Quote 0
        • patrickbs96
          patrickbs96 Developer @base last edited by
          @base komisch das der Adapter bei dir nicht mehr funktioniert aber stattdessen das Skript. Ich hatte damals den Adapter anhand des Skripts erstellt.
          Die Datenpunkte für eine Lichterkette werden erst erstellt, wenn eine Verbindung zu der Kette aufgebaut werden konnte. Entferne sonst mal den Haken bei "Ping für Erreichbarkeit verwenden", vielleicht klappt das ja
            base @patrickbs96 last edited by
            @patrickbs96 geht leider auch nicht. Hab den Adapter nochmal deinstalliert und den Ping rausgenommen - ohne Erfolg. Es werden keine Datenpunkte angelegt.
            Bei den Datenpunkten vom Script funktionieren alle ausser der "connected" State.
              der-eine last edited by
              Hallo zusammen, Hallo @patrickbs96,
              wollte jetzt auch den Twinkly-Adapter installieren leider bleibt er bei mir auch gelb.
              Meine Fehlermeldung ist aber eine andere und komme hier leider auch nicht weiter.
              Hab auch ein Github Issue eröffnet.
              Wäre super, wenn mir jemand dabei helfen könnte.
              Danke.
              Versions:
              iobroker-Admin: 6.12.0
              Adapter version: 1.0.14
              JS-Controller version: 5.0.16
              Node version: 16.17.0
              Operating system: Debian 11 bullseye
              Twinkly Version: 2.8.18
              2023-12-14 12:11:51.101 - info: host.ioBroker "system.adapter.twinkly.0" enabled
              2023-12-14 12:11:51.400 - info: host.ioBroker instance system.adapter.twinkly.0 started with pid 1474
              2023-12-14 12:11:52.152 - debug: twinkly.0 (1474) Redis Objects: Use Redis connection: 127.0.0.1:9001
              2023-12-14 12:11:52.212 - debug: twinkly.0 (1474) Objects client ready ... initialize now
              2023-12-14 12:11:52.213 - debug: twinkly.0 (1474) Objects create System PubSub Client
              2023-12-14 12:11:52.214 - debug: twinkly.0 (1474) Objects create User PubSub Client
              2023-12-14 12:11:52.366 - debug: twinkly.0 (1474) Objects client initialize lua scripts
              2023-12-14 12:11:52.370 - debug: twinkly.0 (1474) Objects connected to redis: 127.0.0.1:9001
              2023-12-14 12:11:52.450 - debug: twinkly.0 (1474) Redis States: Use Redis connection: 127.0.0.1:9000
              2023-12-14 12:11:52.483 - debug: twinkly.0 (1474) States create System PubSub Client
              2023-12-14 12:11:52.484 - debug: twinkly.0 (1474) States create User PubSub Client
              2023-12-14 12:11:52.546 - debug: twinkly.0 (1474) States connected to redis: 127.0.0.1:9000
              2023-12-14 12:11:52.600 - debug: twinkly.0 (1474) Plugin sentry Initialize Plugin (enabled=true)
              2023-12-14 12:11:52.831 - info: twinkly.0 (1474) starting. Version 1.0.14 in /opt/iobroker/node_modules/iobroker.twinkly, node: v16.17.0, js-controller: 5.0.16
              2023-12-14 12:11:52.860 - debug: twinkly.0 (1474) [syncConfig] config devices: [{"enabled":true,"name":"Girlande","host":"192.168.20.100","stateOn":"color"}]
              2023-12-14 12:11:52.861 - debug: twinkly.0 (1474) [syncConfig] config interval: 60
              2023-12-14 12:11:52.861 - debug: twinkly.0 (1474) [syncConfig] config details: true
              2023-12-14 12:11:52.861 - debug: twinkly.0 (1474) [syncConfig] config mqtt: false
              2023-12-14 12:11:52.861 - debug: twinkly.0 (1474) [syncConfig] config network: true
              2023-12-14 12:11:52.890 - debug: twinkly.0 (1474) [processObjectChanges] Get existing objects
              2023-12-14 12:11:53.167 - debug: twinkly.0 (1474) [processObjectChanges] Remove all connections listed in config ==> Deletes all old connections
              2023-12-14 12:11:53.167 - debug: twinkly.0 (1474) [processObjectChanges] Add instance objects
              2023-12-14 12:11:53.168 - debug: twinkly.0 (1474) [processObjectChanges] Prepare tasks of objects update
              2023-12-14 12:11:53.169 - debug: twinkly.0 (1474) [processObjectChanges] No tasks to process!
              2023-12-14 12:11:53.170 - debug: twinkly.0 (1474) [poll] Start polling...
              2023-12-14 12:11:53.171 - debug: twinkly.0 (1474) [ping.probe] System command: /bin/ping -n -w 2 -c 1 192.168.20.100
              2023-12-14 12:11:53.183 - error: twinkly.0 (1474) [Girlande.ping]: [ping.probe] there was an error while executing the ping program. check the path or permissions...: /bin/ping: socket: Operation not permitted
              2023-12-14 12:11:53.228 - debug: twinkly.0 (1474) [checkConnection] Girlande is not available!
              2023-12-14 12:11:53.228 - debug: twinkly.0 (1474) [poll] Girlande not connected!
              2023-12-14 12:11:53.228 - debug: twinkly.0 (1474) [poll] Finished polling...
              2023-12-14 12:11:53.229 - info: twinkly.0 (1474) Startup complete
                Thomas Braun Most Active @der-eine last edited by
                @der-eine
                node: v16.17.0
                Veraltet, abgekündigt.
                Bring das auf nodejs@18.
                Per
                iob nodejs-update
                  @der-eine
                  type -p ping
                  sudo -u iobroker ping iobroker.net
                  sagt?
                    der-eine @Thomas Braun last edited by
                    @thomas-braun sagte in Twinkly Adapter bleibt gelb:
                    Update mach ich dann. Danke.
                    Hier die Ausgabe
                    daniel@ioBroker:~$ type -p ping
                    /usr/bin/ping
                    daniel@ioBroker:~$ sudo -u iobroker ping iobroker.net
                    [sudo] password for daniel:
                    daniel@ioBroker:~$
                      @der-eine sagte in Twinkly Adapter bleibt gelb:
                      Mach es jetzt. Ist überfällig.
                        @der-eine
                        ping iobroker.net
                          ping iobroker.net
                            der-eine @Thomas Braun last edited by der-eine
                            Last login: Thu Dec 14 19:03:34 CET 2023 on tty1
                            daniel@ioBroker:~$ node -v
                            v18.19.0
                            daniel@ioBroker:~$
                              @der-eine
                              Also dürfen user nicht pingen.
                              Was ist das da genau für eine Umgebung?
                              iob diag
                              in der Langfassung.
                                iob diag
                                was brauchst Du davon alles?
                                  @der-eine
                                  Die Langfassung ist: Alles.
                                    Hier die Langfassung:
                                      @der-eine
                                      Bei Containern weiß ich nicht wo das einzustellen ist.
                                        @thomas-braun was willst Du denn einstellen?
                                          @der-eine
                                          Die Rechte an ping natürlich.
                                            sudo apt-get install iputils-ping --reinstall
                                            behebt das Problem. Danke Dir für die Hilfe.
                                            2597
