    3. Einsteigerfragen
    4. Fehler beim Update des Telegram Adapters
    • Andreas Stürzer
      Andreas Stürzer @Thomas Braun last edited by
      *** BASE SYSTEM ***
         Static hostname: iobroker-prod
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Ubuntu 20.04.6 LTS
                  Kernel: Linux 6.2.16-3-pve
            Architecture: x86-64
      model name      : AMD Ryzen 5 5600U with Radeon Graphics
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       23:22:16 up  3:25,  1 user,  load average: 1.99, 2.13, 2.02
      CPU threads: 6
      *** Time and Time Zones ***
                     Local time: Wed 2023-12-13 23:22:16 CET
                 Universal time: Wed 2023-12-13 22:22:16 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** User and Groups ***
      Andreas
      Andreas sudo
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             9G        2.3G        7.0G        0.0K        690M        7.6G
      Swap:          1.0G          0B        1.0G
      Total:          11G        2.3G        8.0G
               9980 M total memory
               2337 M used memory
                437 M active memory
               2360 M inactive memory
               6951 M free memory
                  0 M buffer memory
                690 M swap cache
               1024 M total swap
                  0 M used swap
               1024 M free swap
      *** FAILED SERVICES ***
        UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--102--disk--0 ext4       18G  4.8G   12G  29% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  7.5G     0  7.5G   0% /dev/tty
      tmpfs                            tmpfs     7.6G     0  7.6G   0% /dev/shm
      tmpfs                            tmpfs     1.6G  116K  1.6G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      dmesg: read kernel buffer failed: Operation not permitted
      TARGET                    SOURCE                           FSTYPE     OPTIONS
      /                         /dev/mapper/pve-vm--102--disk--0 ext4       rw,relatime,stripe=16
      |-/proc/cpuinfo           lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/diskstats         lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/loadavg           lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/meminfo           lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/slabinfo          lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/stat              lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/swaps             lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/uptime            lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      `-/sys/devices/system/cpu lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      1.5G    /var/
      810M    /var/log
      809M    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
      351M    /var/cache
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      33M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      385M    /opt/iobroker/iobroker-data/
      203M    /opt/iobroker/iobroker-data/files
      126M    /opt/iobroker/iobroker-data/backup-objects
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
      16M     /opt/iobroker/iobroker-data/objects.jsonl
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
      8.0M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           10.19.0~dfsg-3ubuntu1.3 500
              500 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
              500 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
           10.19.0~dfsg-3ubuntu1 500
              500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.1
      javascript:     7.1.6
      Adapters from github:   1
      Adapter State
      + system.adapter.admin.1                  : admin                 : iobroker-prod                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : iobroker-prod                            -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker-prod                            -  enabled
      + system.adapter.evcc.0                   : evcc                  : iobroker-prod                            -  enabled, port: 7070
        system.adapter.ham.0                    : ham                   : iobroker-prod                            - disabled
      + system.adapter.hmip.0                   : hmip                  : iobroker-prod                            -  enabled
      + system.adapter.hue.0                    : hue                   : iobroker-prod                            -  enabled, port: 80
      + system.adapter.ico-cloud.0              : ico-cloud             : iobroker-prod                            -  enabled
      + system.adapter.influxdb.1               : influxdb              : iobroker-prod                            -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker-prod                            -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker-prod                            -  enabled
      + system.adapter.knx.0                    : knx                   : iobroker-prod                            -  enabled, bind: 192.168.188.76
      + system.adapter.modbus.0                 : modbus                : iobroker-prod                            -  enabled
      + system.adapter.modbus.1                 : modbus                : iobroker-prod                            -  enabled
      + system.adapter.modbus.2                 : modbus                : iobroker-prod                            -  enabled
      + system.adapter.moma.0                   : moma                  : iobroker-prod                            -  enabled
      + system.adapter.mqtt.1                   : mqtt                  : iobroker-prod                            -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.mqtt.2                   : mqtt                  : iobroker-prod                            -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mywallbox.0              : mywallbox             : iobroker-prod                            -  enabled
      + system.adapter.netatmo.0                : netatmo               : iobroker-prod                            -  enabled
      + system.adapter.node-red.0               : node-red              : iobroker-prod                            -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.philips-tv.0             : philips-tv            : iobroker-prod                            -  enabled
      + system.adapter.pushbullet.0             : pushbullet            : iobroker-prod                            -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : iobroker-prod                            -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker-prod                            -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.shelly.1                 : shelly                : iobroker-prod                            - disabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : iobroker-prod                            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sma-em.0                 : sma-em                : iobroker-prod                            -  enabled
      + system.adapter.sonoff.0                 : sonoff                : iobroker-prod                            -  enabled, port: 1889, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : iobroker-prod                            -  enabled
      + system.adapter.tahoma.0                 : tahoma                : iobroker-prod                            -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker-prod                            -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0               : terminal              : iobroker-prod                            -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      + system.adapter.text2command.0           : text2command          : iobroker-prod                            -  enabled
      + system.adapter.web.0                    : web                   : iobroker-prod                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : iobroker-prod                            -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): Stable (default)
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "admin"        : 6.12.0   , installed 6.12.1
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "evcc"         : 0.0.10   , installed 0.0.10
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "hmip"         : 1.20.0   , installed 1.20.0
      Adapter    "hue"          : 3.10.1   , installed 3.10.1
      Adapter    "ico-cloud"    : 1.1.0    , installed 1.1.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "knx"          : 2.0.23   , installed 2.0.23
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "moma"         : 1.2.9    , installed 1.2.9
      Adapter    "mqtt"         : 5.1.0    , installed 2.7.4  [Updatable]
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
      Adapter    "pushbullet"   : 2.0.1    , installed 2.0.1
      Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "sma-em"       : 1.0.0    , installed 1.0.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
      Adapter    "telegram"     : 3.0.0    , installed 1.16.0 [Updatable]
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
      Objects and States
      Objects:        4839
      States:         4028
      Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease
      Hit:3 http://archive.ubuntu.com/ubuntu focal-security InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          256387468  135/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          256385754  1/init
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          256386963  285/master
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       256389980  1483/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       256389973  1483/iobroker.js-co
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       256401570  1629/io.mqtt.1
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       256390126  1558/node-red
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       256400023  1674/io.shelly.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       256401641  1644/io.mqtt.2
      tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1000       256402667  1787/io.sonoff.0
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        256388408  96/systemd-resolved
      tcp6       0      0 :::8088                 :::*                    LISTEN      1000       256411530  3304/io.terminal.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       256405617  2236/io.simple-api.
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       256400456  1501/io.admin.1
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       256405810  2489/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          256387470  135/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          256385756  1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          256386964  285/master
      tcp6       0      0 :::3500                 :::*                    LISTEN      1000       256402598  1696/io.sonos.0
      udp        0      0 192.168.188.76:40004    0.0.0.0:*                           1000       256399260  2188/io.knx.0
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        256388407  96/systemd-resolved
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          256385755  1/init
      udp6       0      0 :::111                  :::*                                0          256385757  1/init
      2023-12-13 22:22:40.253  - info: knx.0 (2188) ( 3.6a ) Received L_DATA.con  06 10 04 20 00 15 04 01 bc 00 2e 00 bc e0 11 fa 72 00 01 00 00  was successfully processed by receiver.
      2023-12-13 22:22:40.253  - info: knx.0 (2188) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
      2023-12-13 22:22:40.253  - info: knx.0 (2188) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
      2023-12-13 22:22:40.253  - info: knx.0 (2188) =====> STATE_TUNNELING_ACK
      2023-12-13 22:22:40.253  - info: knx.0 (2188) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 01 bc 00   ChID : 1 SeqCntIN : 188 SeqCntOUT : 197 queue length : 1
      2023-12-13 22:22:40.253  - info: knx.0 (2188) ( 4.b ) return to STATE_READY, processing : false
      2023-12-13 22:22:40.253  - info: knx.0 (2188) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
      2023-12-13 22:22:40.253  - info: knx.0 (2188)  Has todo still 1 tasks, just processing : false
      2023-12-13 22:22:40.453  - info: knx.0 (2188) Change state from STATE_READY(7) to STATE_TUNNELLING_SENDING_DATA(8)
      2023-12-13 22:22:40.454  - info: knx.0 (2188) ( 1 ) Sending : GroupValueWrite :   06 10 04 20 00 19 04 01 c5 00 11 00 bc e0 11 fa 72 01 05 00 80 46 c6 16 20    sent to 192.168.188.26:3671  ChID: 1 SeqCntIN : 188 SeqCntOUT : 197 GA : 14/2/1 conCheck.conected : true
      2023-12-13 22:22:40.454  - info: knx.0 (2188) easy-knx: task.data : 06 10 04 20 00 19 04 01 c5 00 11 00 bc e0 11 fa 72 01 05 00 80 46 c6 16 20  byteLen : 25
      2023-12-13 22:22:40.454  - info: knx.0 (2188) Change state from STATE_TUNNELLING_SENDING_DATA(8) to STATE_TUNNELLING_WAIT_SENT_ACK(9)
      2023-12-13 22:22:40.455  - info: knx.0 (2188) ( 2 ) Received TUNNEL_ACK      :             06 10 04 21 00 0a 04 01 c5 00    from 192.168.188.26:3671 SeqCntIN : 188 SeqCntOUT : 198 GA : 0/0/0
      2023-12-13 22:22:40.455  - info: knx.0 (2188) Change state from STATE_TUNNELLING_WAIT_SENT_ACK(9) to STATE_TUNNELLING_SENT_DATA_ACK_RECV(11)
      2023-12-13 22:22:40.455  - info: knx.0 (2188) STATE_TUNNELLING_WAIT_SENT_ACK: received ACK for previous self sent package
      2023-12-13 22:22:40.455  - info: knx.0 (2188)  ==>  successful acknowledged previous package... processing next of 0
      2023-12-13 22:22:40.455  - info: knx.0 (2188) Change state from STATE_TUNNELLING_SENT_DATA_ACK_RECV(11) to STATE_READY(7)
      2023-12-13 22:22:40.455  - info: knx.0 (2188)  ==> easy-knx.js: signal runtime : 0s  1.33787ms
      2023-12-13 22:22:40.483  - info: knx.0 (2188) ( 3.6a ) Received L_DATA.con  06 10 04 20 00 19 04 01 bd 00 2e 00 bc e0 11 fa 72 01 05 00 80 46 c6 16 20  was successfully processed by receiver.
      2023-12-13 22:22:40.484  - info: knx.0 (2188) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
      2023-12-13 22:22:40.484  - info: knx.0 (2188) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
      2023-12-13 22:22:40.484  - info: knx.0 (2188) =====> STATE_TUNNELING_ACK
      2023-12-13 22:22:40.484  - info: knx.0 (2188) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 01 bd 00   ChID : 1 SeqCntIN : 189 SeqCntOUT : 198 queue length : 0
      2023-12-13 22:22:40.484  - info: knx.0 (2188) ( 4.b ) return to STATE_READY, processing : false
      2023-12-13 22:22:40.484  - info: knx.0 (2188) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
        Thomas Braun Most Active @Andreas Stürzer last edited by
        @andreas-stürzer
        Warum hat der User Andreas kein home?
        Andreas Stürzer 1 Reply Last reply Reply Quote 0
          @andreas-stürzer
          iob update
          iob upgrade telegram --debug
          sagt?
          • Andreas Stürzer
            @thomas-braun Wurde wahrscheinlich bei der Anlage nicht gesetzt
            • Andreas Stürzer
              This upgrade of "telegram" will introduce the following changes:
              -> 3.0.0:
              BREAKING CHANGE: Socks5 support has been removed.
              Extended and improved the returned list of processed messages.
              -> 2.0.2:
              Dependencies have been updated.
              -> 2.0.1:
              Incorrect trailing zero in callback of sendTo() has been fixed. [#680]
              -> 2.0.0:
              Packets were updated.
              BREAKING CHANGE: The minimal node.js version is 16
              BREAKING CHANGE: Return an object with chatId and messageId instead of the message count
              BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
              Would you like to upgrade telegram from @1.16.0 to @3.0.0 now? [(y)es, (n)o]: y
              Update telegram from @1.16.0 to @3.0.0
              Cannot upgrade: Cannot read properties of undefined (reading 'enabled')
                @andreas-stürzer
                Dann setz den in die Gruppen rein:
                sudo usermod -a -G adm,dialout,iobroker Andreas
                • Andreas Stürzer
                  @thomas-braun ist erledigt
                    @andreas-stürzer
                    Vermutlich ist der Sprung zu groß.
                    Deinstallier den telegram-Adapter und dann installierst du den neu.
                    • Andreas Stürzer
                      @thomas-braun Leider nicht:
                      iobroker install telegram
                      adapter "telegram" cannot be installed: Cannot read properties of undefined (reading 'enabled')
                      • mcm1957
                        mcm1957 @Andreas Stürzer last edited by
                        Kann nur beisteuern dass eine Installation bei mir problemlos durchlief.
                          Thomas Braun Most Active @mcm1957 last edited by
                          @mcm57
                          Bei mir auch. Keine Ahnung wo es da beim TE klemmt.
                            @thomas-braun sagte in Fehler beim Update des Telegram Adapters:
                            Vielleicht verrät es uns iob install telegram --debug
                            • mcm1957
                              mcm1957 @Homoran last edited by
                              Ansonsten versuch mal
                              iob i telegramm@3.0.1
                              Hat sich zwar nicht viel geändert aber die neue Version sollte npm zwingen die Daten neu runterzuladen. Nicht dass ganz einfach der download defekt ist und npm meint eh alles im cache zu haben...
                              • Glasfaser
                                Glasfaser @Andreas Stürzer last edited by
                                @andreas-stürzer sagte in Fehler beim Update des Telegram Adapters:
                                Wie kommst du an diese Version ... das ist eine alte latest !?
                                851
