    3. Einsteigerfragen
    4. Fehler beim Update des Telegram Adapters
    • Andreas Stürzer
      Andreas Stürzer @Thomas Braun last edited by
      @thomas-braun Wurde wahrscheinlich bei der Anlage nicht gesetzt
      • Andreas Stürzer
        Used repository: Stable (default)
        Adapter    "admin"        : 6.12.0   , installed 6.12.1
        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
        Adapter    "evcc"         : 0.0.10   , installed 0.0.10
        Adapter    "ham"          : 5.3.1    , installed 5.3.1
        Adapter    "hmip"         : 1.20.0   , installed 1.20.0
        Adapter    "hue"          : 3.10.1   , installed 3.10.1
        Adapter    "ico-cloud"    : 1.1.0    , installed 1.1.0
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "knx"          : 2.0.23   , installed 2.0.23
        Adapter    "modbus"       : 5.0.11   , installed 5.0.11
        Adapter    "moma"         : 1.2.9    , installed 1.2.9
        Adapter    "mqtt"         : 5.1.0    , installed 2.7.4  [Updatable]
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
        Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
        Adapter    "pushbullet"   : 2.0.1    , installed 2.0.1
        Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "sma-em"       : 1.0.0    , installed 1.0.0
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
        Adapter    "telegram"     : 3.0.0    , installed 1.16.0 [Updatable]
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "text2command" : 3.0.2    , installed 3.0.2
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
        This upgrade of "telegram" will introduce the following changes:
        -> 3.0.0:
        BREAKING CHANGE: Socks5 support has been removed.
        Extended and improved the returned list of processed messages.
        -> 2.0.2:
        Dependencies have been updated.
        -> 2.0.1:
        Incorrect trailing zero in callback of sendTo() has been fixed. [#680]
        -> 2.0.0:
        Packets were updated.
        BREAKING CHANGE: The minimal node.js version is 16
        BREAKING CHANGE: Return an object with chatId and messageId instead of the message count
        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
        Would you like to upgrade telegram from @1.16.0 to @3.0.0 now? [(y)es, (n)o]: y
        Update telegram from @1.16.0 to @3.0.0
        Cannot upgrade: Cannot read properties of undefined (reading 'enabled')
          Thomas Braun Most Active @Andreas Stürzer last edited by
          @andreas-stürzer
          Dann setz den in die Gruppen rein:
          sudo usermod -a -G adm,dialout,iobroker Andreas
          Andreas Stürzer 1 Reply Last reply Reply Quote 0
          • Andreas Stürzer
            @thomas-braun ist erledigt
              @andreas-stürzer
              Vermutlich ist der Sprung zu groß.
              Deinstallier den telegram-Adapter und dann installierst du den neu.
              • Andreas Stürzer
                @thomas-braun Leider nicht:
                iobroker install telegram
                adapter "telegram" cannot be installed: Cannot read properties of undefined (reading 'enabled')
                • mcm1957
                  mcm1957 @Andreas Stürzer last edited by
                  Kann nur beisteuern dass eine Installation bei mir problemlos durchlief.
                    Thomas Braun Most Active @mcm1957 last edited by
                    @mcm57
                    Bei mir auch. Keine Ahnung wo es da beim TE klemmt.
                      @thomas-braun sagte in Fehler beim Update des Telegram Adapters:
                      Vielleicht verrät es uns iob install telegram --debug
                      • mcm1957
                        mcm1957 @Homoran last edited by
                        Ansonsten versuch mal
                        iob i telegramm@3.0.1
                        Hat sich zwar nicht viel geändert aber die neue Version sollte npm zwingen die Daten neu runterzuladen. Nicht dass ganz einfach der download defekt ist und npm meint eh alles im cache zu haben...
                        • Glasfaser
                          Glasfaser @Andreas Stürzer last edited by
                          @andreas-stürzer sagte in Fehler beim Update des Telegram Adapters:
                          Wie kommst du an diese Version ... das ist eine alte latest !?
                          851
