    4. Kfz Akku überwachen - wie?
    • MartinP
      MartinP @Ralla66 last edited by MartinP
      @ralla66 Leider scheint die Dokumentation, was das Skripting mit I2C angeht nicht besonders erhellend zu sein ...
      https://github.com/arendst/Tasmota/discussions/19289
      https://tasmota.github.io/docs/Commands/#sensor13
      Sensor13
      INA219 and ISL28022 low voltage current sensor configuration
      There are 3 ways of configuring the INA219s
      1. Standard 0.1 ohm resistor (same setting applies to all INA219s):
        0,1,2 = set INA219 calibration to max 32V and 2A
        In all cases, ISL28022 is set to 60V mode
      2. Custom shunt resistor (legacy, same setting applies to all INA219)
        10..255: Define custom shunt resistor encoded as a decimal number RRM such that Rshunt = RR * 10^M milliohm
        Do not forget to choose a resistor adapted for the correct power dissipation and apply a 50% security margin !
        Examples:
        11 = 1 * 10^1 = 10 milliohm (Imax=32A => Pres=15W)
        21 = 2 * 10^1 = 20 milliohm (Imax=16A => Pres=7W)
        12 = 1 * 10^2 = 100 milliohm (default, Imax=3.2A => Pres=2W)
        13 = 1 * 10^3 = 1000 milliohm = 1 ohm (Imax=0.320A => Pres=0,2W)
      3. Fully flexible custom shunt (any value, independant setting per INA219)
        0, rshunt1, rhunt2, rshunt3, rshunt4 = set each INA219 with it's own shunt resistor in Ohm (floating point). Exemple:
        Sensor13 0, 0.1, 0.0005, 1.0, 0.0001 configure 1st INA219 with 0.1 Ohm, 2nd with 0.5 mOhm, 3rd with 1 Ohm, 4th with 0.1 mOhm
        IMPORTANT: This configuration mode is NOT saved to flash and requires a boot-rule to initialize the driver at each boot:
        Rule1 on system#init do Sensor13 Sensor13 0, 0.1, 0.0005, 1.0, 0.0001 endon
      Note: The driver seamlessly detect INA219/ISL28022 and adapt configuration and readings accordingly. The component label in Web GUI and SENSOR message will automatically match the detected part.
      It is possible to mix INA219 and ISL28022 as far as addresses do not conflicts.
      Shunt resistor setting applies to all INA219/ISL28022.
      https://github.com/erocm123/Sonoff-Tasmota/blob/master/sonoff/xsns_13_ina219.ino#L100
      • Ralla66
        Ralla66 Most Active @wcag22 last edited by Ralla66
        @pi-ter
        sodele, erste Test mit dem Spannungssensor, dein Link von Amazon.
        der KYYKA läuft bei mir.
        Anschluß und Wertetabelle im Bild.
        Getestet mit einer 9 Volt Blockbatterie
        Größer 16 Volt am ESP ( 1024 ) geht mit der Beschaltung nicht
        Teste mal bitte.
        >D
        ;a valid script must start with >D in the first line
        Timer=0
        SPG=0
        ;Faktor
        FAK=66
        ;ADC
        ADC=0
        >S
        ;Executed every second
        Timer+=1
        if Timer>2
        then
        ADC=adc(2 32)
        print ADC %ADC%
        SPG=ADC/FAK
        print V0LT %SPG%
        Timer=0
        endif
        >W
        ;The lines in this section are displayed in the web UI main page
        KYYKA
        Volt{m} %2SPG% V
        ADC{m} %0ADC%
        wcag22 2 Replies Last reply Reply Quote 0
        • wcag22
          wcag22 @Ralla66 last edited by
          @ralla66
          Danke und ok, kann ich aber erst morgen machen....vlt. 😞
          Früh erstmal ZA-Termin...
          BTW:
          Bis zu 15V (definierter Höchstwert) gings dann auch mit diesem 25V-Spannungssensor am D1 mit ESP Easy.
          Der ist eigentlich für den Arduino gedacht, der 5V ab kann.
          Tasmota schau ich mir an; und dann kam heute auch der Shelly Uni, auf den ich gespannt bin. Mit dem solls ja nun nochmal einfacher werden. Die größte Herausforderung wird wohl, die beiden (eher stabilen) Kabel für den Anschluss an den Akku mechanisch sicher mit den dünnen Drähtchen am Shelly so zu verbinden, dass diese Drähtchen nicht abbrechen...
          Ich melde mich dann mit Ergebnissen... und danke wieder bis hier...
          VG
          Ralla66 1 Reply Last reply Reply Quote 0
          • Ralla66
            @pi-ter
            dann mach bitte mal ein Bild von den dünnen Drähtchen 🙂
            Andere Projekte lese ich gerne mit.
            Ina teste ich am Wochende wenn dieser geliefert wurde.
            Für ESP kann ja der Spannungteiler für > 16 Volt angepasst werden.
            Online Rechner ist dieser gut geeignet.
            Im script ist dann nur der Faktor FAK=66 anzupassen.
            Bis die Tage , bin Weg 🙂 ----------------------------------------->
            Nachtrag, ESP, 25 V, 100k / 15k, 3,26V , FAK=41 ----------------------->
            wcag22 1 Reply Last reply Reply Quote 0
            • wcag22
              wcag22 @Ralla66 last edited by wcag22
              @ralla66 sagte in Kfz Akku überwachen - wie?:
              @pi-ter
              Teste mal bitte.
              Passt!
              Sehr schön 🙂
              • wcag22
                @pi-ter
                Aber gern doch:
                Im Moment werde ich erst mal die beiden 25V-Sensoren verarbeiten, ist ja alles derzeit nur eher experimentel.
                Aber danke für die Werte...
                • Ralla66
                  @pi-ter
                  Test INA219
                  Kurz zur Info, läuft
                  muß aber noch die 12 Volt testen,
                  geflasht auf dem Wemos ist die Tasmota Sensor.bin
                  kein scripting
                  Messung angeschlossen über Klemmleiste
                  • an der Klemmleiste Vin- ist der Verbraucher ( Meßobjekt ) angeschlossen
                  • an der Klemmleiste Vin+ ist die Spannungsversorgung angeschlossen
                  Hatte zum test eine NodeMcu angeschlossen mit 80 ma Verbrauch.
                  Deswegen scheint Watt noch 0 zu sein, da < 1 Watt 🙂
                  Rest wie gewohnt im Bild :
                  wcag22 1 Reply Last reply Reply Quote 1
                  • wcag22
                    @ralla66
                    Super, danke für die Info.
                    Ich muss auf den 219er noch ein paar Tage warten.
                    Quäle mich gerade mit dem Shelly UNI herum. Eingebunden ins WLAN scheint er zu sein, da er in der Fritte als verbunden angezeigt wird. Statische IP...
                    Komme jedoch nicht auf die WebUI. Keine Ahnung, was das sein kann, bisher haben alle Shellys problemlos geklappt.
                    Für heute ist aber zunächst Schluss mit basteln 🙂 - morgen gehts weiter.
                    • Ralla66
                      @pi-ter
                      zumindest mögen meine Tasmota keine https was die mordenen Browser
                      ja gerne automatisch erzeugen.
                      Ina an Kfz Birne 5 Watt, 12 Volt nur schwankende Volt und Watt Werte.
                      Ampere passte soweit mit 0,4 A, da wird die Berechnung zu langsam sein.
                      Pause ------------------------------------->
                      • wcag22
                        @ralla66
                        Moin 😉
                        Die 3 INA219 kamen heute an. Werde mich dann auch damit beschäftigen.
                        Der Shelly UNI läuft nun. Wer weiß, was gestern Abend war. Allerdings tut er sich etwas schwer ins WLAN zu kommen. Entweder er braucht wirklich lange um zu booten oder die Feldstärke WLAN reicht nicht aus.
                        Obwohl: Fritte steht 5m in Sichtweite ... egal.
                        Speisen tue ich das Ganze zur Zeit aus einem Netzteil einer entsorgten NDAS-HD, 12,09V stabil.
                        Offset 0,1V. Ausgabe bewegt sich zwischen 11,98V und 12,15V. MAl sehen, wie es sich auf längere Zeit gestaltet.
                        Gerundet wird auf 1 Dezimalstelle.
                        Ralla66 2 Replies Last reply Reply Quote 0
                        • Ralla66
                          @pi-ter sagte in Kfz Akku überwachen - wie?:
                          hatte ich bei meinen ESP meist wenn,
                          • unsaubere Spannung, Wühltischnetzteile
                          • der Strom < 1A am Eingang war, beim connecten ins Wlan wird viel Strom benotigt
                          • das ESP Programm sofort ausgeführt wird
                          • Mqtt Verbindungsanfragen zu früh beginnen und keine Verbindung zu stande kommt
                            Homoran Global Moderator Administrators @Ralla66 last edited by
                            @ralla66 und was ist bei zu starkem 5GHz WLAN?
                            • Ralla66
                              Ralla66 Most Active @Homoran last edited by Ralla66
                              habe ich nicht, meine Nachbarn auch nicht.
                              soll auch sowas wie, EMV-Störungen,Temperaturdrift, Nichtlinearitäten usw geben 🙂
                              • Ralla66
                                @pi-ter
                                war nicht in der neuen Shelly Software eine Konole mit dabei wo man die Log
                                Ausgabe sieht, so vom Timing her ?
                                • wcag22
                                  @ralla66
                                  Konsole nicht, aber ich könnte das Debug Log aktivieren. Aber wozu 🙂
                                  Das Teil funktioniert und tut seinen Pflicht.
                                  Man könnte nun den Signaleingang noch mit einem Entstörglied versehen, versuchen Einstrahlung zu eliminieren, das Teil bis auf die Antenne abschirmen... Aufwand nach oben offen 🙂
                                  Mir reicht es zunächst , wenn ich die Spannung auf eine Dezimalstelle "genau" verfolgen und plotten kann.
                                  Getreu dem Spruch:
                                  Nicht so genau messen, wie möglich, sondern so genau messen wie nötig.
                                  Und irgendwie ist mir die Neugier auf das, was man verschlimmbessern könnte, mit der Zeit abhanden gekommen 🙂
                                  Wenn die Ergebnisse mit dem ESP (Tasmota, EasyESP), dem 25V-"Sensor" oder INA219 besser sind, nehm ich diese Variante dann eben. Wir haben doch die Auswahl...
                                  Softwareseitig könnte man sicher die Ausgabe noch "glätten", aber lohnt der Aufwand für einen temporären Einsatz?
                                  • Ralla66
                                    @pi-ter
                                    Die 3 Wege wie es möglich ist haben wir aufgezeigt.
                                    Damit ist der Fall gelöst 🙂
                                    Meinerseits bleibe ich bei Tasmota da ich mit dem Scripting mehr spielen kann.
                                    Werde den Kyyka nehmen da mir die Genauigkeit von 99 % gefiel.
                                    Spiele halt gerne --------------------------------->
                                    wcag22 2 Replies Last reply Reply Quote 1
                                    • wcag22
                                      @ralla66
                                      Wenn der Shelly UNI "alltagstauglich" - sprich: Gehäuse, Anschlusskabel - gemacht, ist, setze ich ihn erst einmal ein.
                                      Dann beschäftige ich mich mit INA219.
                                      Halte mich bitte dazu auf dem Laufen, insbesondere was Deine Script-Kenntnisse angeht. Ich würde da gern noch an dem Thema/Projekt dran bleiben. Und wenn es nur zur Wissenserweiterung dienen sollte.
                                      Aber noch ein wenig genauer hätte ich das nämlich auch ganz gern. Derzeit bekomme ich gerundete Werte zwischen 12,0 und 12,2V bei konstatnt 12,09V Eingangsspannung.
                                      Der Vorteil beim Uni ist halt, dass ich nur zwei Kabel - Plus/Minus- benötige; sich der Shelly aus der Messspannung selbst versorgt. Zumindest in dem Fall, dass die Versorgungs-/Messspannung nicht deutlich unter 12 V liegt.
                                      Du kannst mich auch per Chat erreichen und ggfls. tauschen wir die Mailaddis aus, wenn Du magst.
                                      Na dann, schönes WE erst einmal...
                                      • Ralla66
                                        @pi-ter
                                        Ist der Verbrauch der Schaltung wichtig ?
                                        Sonst könnte man mit einem 7805 / TSR und 2 Widerständen am ESP8266 was schnitzen.
                                        • wcag22
                                          @pi-ter
                                          Yepp, könnte man bei Bedarf drüber nachdenken. Für die ESP bietet sich eine 5V-USB Versorgung aber geradezu an, da ist man eigentlich flexibler. Netzteile und Steckdosen mit USB-Anschluss hat man ja in der Regel reichlich.
                                          Und nach Umstellung auf USB-C sind auch genug Anschlusskabel übrig 🙂
                                          Da die ESPs fast perfekt in eine kleine Tic-Tac-Schachtel passen, möchte man sich ja vlt. zusätzliche Peripherie ersparen.
                                          Hier mal die einsatzbereite Einsatzvariante für den Shelly UNI:
                                          • wcag22
                                            @pi-ter
                                            Was ist das für eine Marke/Hersteller? Wo kaufst Du die?
                                            Bis jetzt habe ich immer versucht, die Sachen von AZDelivery zu nehmen, weil ich da ganz zufrieden mit war.
                                            Gibt es bessere Marken/Anbieter, was nehmt ihr so?
                                            4245
