    4. Vis 1 lädt nicht mehr, Loading Values
    • Pamf
      Pamf @Thomas Braun last edited by Pamf
      Leider keine Änderung, VIS ist weiterhin nicht aufrufbar.
      ioBroker nodejs fixer 2023-10-13
      Recommended nodejs-version is: 18.19.0
      Checking your installation now. Please be patient!
      Your current setup is:
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      We found these nodejs versions available for installation:
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
      Nothing to do - Your installation is using the correct paths.
      Nothing to do - Your version is the recommended one.
      You can now keep your whole system up-to-date using the usual 'sudo apt update &        & sudo apt full-upgrade' commands.
      Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel.        They will break your current installation!
      npm ist auch laut Konsole bei 10.2.5
        Thomas Braun Most Active @Pamf last edited by
        @pamf sagte in Vis 1 lädt nicht mehr, Loading Values:
        Nein, auf 10.2.3, wie es richtig ist.
        Pamf 1 Reply Last reply Reply Quote 0
        • Pamf
          Laut Konsole nicht:
          patrick@IoBroker-auf-AMD:~$ npm -v
          10.2.5
            Homoran Global Moderator Administrators @Pamf last edited by
            @pamf bitte iob diag in der Langfassung
            • Pamf
              Pamf @Homoran last edited by
              Skript v.2023-10-10
              *** BASE SYSTEM ***
               Static hostname: IoBroker-auf-AMD
                     Icon name: computer-vm
                       Chassis: vm 🖴
                Virtualization: kvm
                        Kernel: Linux 6.1.0-15-amd64
                  Architecture: x86-64
               Hardware Vendor: QEMU
                Hardware Model: Standard PC _i440FX + PIIX, 1996_
              Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
              model name      : QEMU Virtual CPU version 2.5+
              Docker          : false
              Virtualization  : kvm
              Kernel          : x86_64
              Userland        : amd64
              Systemuptime and Load:
               21:35:30 up 10 min,  2 users,  load average: 0.57, 0.30, 0.12
              CPU threads: 4
              *** Time and Time Zones ***
                             Local time: Fri 2023-12-15 21:35:31 CET
                         Universal time: Fri 2023-12-15 20:35:31 UTC
                               RTC time: Fri 2023-12-15 20:35:31
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              patrick
              /home/patrick
              patrick cdrom floppy sudo audio dip video plugdev users netdev iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:             10G        2.9G        7.0G        581K        745M        7.5G
              Swap:           1.0G          0B        1.0G
              Total:           11G        2.9G        8.1G
                       9944 M total memory
                       2764 M used memory
                        125 M active memory
                       2877 M inactive memory
                       6712 M free memory
                         36 M buffer memory
                        674 M swap cache
                        974 M total swap
                          0 M used swap
                        974 M free swap
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              udev           devtmpfs  4.9G     0  4.9G   0% /dev
              tmpfs          tmpfs     995M  576K  994M   1% /run
              /dev/sda1      ext4       31G  5.9G   23G  21% /
              tmpfs          tmpfs     4.9G     0  4.9G   0% /dev/shm
              tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
              tmpfs          tmpfs     995M     0  995M   0% /run/user/1000
              [Fri Dec 15 21:24:39 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
              [Fri Dec 15 21:24:39 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
              TARGET SOURCE    FSTYPE OPTIONS
              /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
              /var:
              519M    /var/
              297M    /var/cache
              290M    /var/cache/apt
              214M    /var/cache/apt/archives
              171M    /var/lib
              Archived and active journals take up 8.0M in the file system.
              /opt/iobroker/backups:
              388M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              1.1G    /opt/iobroker/iobroker-data/
              503M    /opt/iobroker/iobroker-data/files
              95M     /opt/iobroker/iobroker-data/backup-objects
              90M     /opt/iobroker/iobroker-data/files/echarts.admin
              87M     /opt/iobroker/iobroker-data/files/vis.0
              354M    /opt/iobroker/iobroker-data/states.jsonl
              35M     /opt/iobroker/iobroker-data/objects.jsonl
              24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
              24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
              24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
              USB-Devices by-id:
              /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2190944-if00
              *** NodeJS-Installation ***
              /usr/bin/npm            10.2.5
              /usr/bin/npx            10.2.5
              nodejs:
                Version table:
                   18.13.0+dfsg1-1 500
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.17
              admin:          6.12.0
              javascript:     7.1.6
              Adapters from github:   1
              Adapter State
              + system.adapter.admin.0                  : admin                 : IoBroker-auf-AMD                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.alexa2.0                 : alexa2                : IoBroker-auf-AMD                         -  enabled
                system.adapter.alias-manager.0          : alias-manager         : IoBroker-auf-AMD                         - disabled
              + system.adapter.backitup.0               : backitup              : IoBroker-auf-AMD                         -  enabled
              + system.adapter.backitup.1               : backitup              : Raspberry-Keller                         -  enabled
              + system.adapter.countdown.0              : countdown             : IoBroker-auf-AMD                         -  enabled
              + system.adapter.drops-weather.0          : drops-weather         : IoBroker-auf-AMD                         -  enabled
              + system.adapter.eventlist.0              : eventlist             : IoBroker-auf-AMD                         -  enabled
                system.adapter.feiertage.0              : feiertage             : IoBroker-auf-AMD                         -  enabled
                system.adapter.flot.0                   : flot                  : IoBroker-auf-AMD                         -  enabled
              + system.adapter.fullybrowser.0           : fullybrowser          : IoBroker-auf-AMD                         -  enabled
              + system.adapter.hue.0                    : hue                   : IoBroker-auf-AMD                         -  enabled, port: 443
              + system.adapter.influxdb.0               : influxdb              : IoBroker-auf-AMD                         -  enabled, port: 8086
              + system.adapter.jarvis.0                 : jarvis                : IoBroker-auf-AMD                         -  enabled
              + system.adapter.javascript.1             : javascript            : Raspberry-Keller                         -  enabled
              + system.adapter.javascript.2             : javascript            : IoBroker-auf-AMD                         -  enabled
              + system.adapter.logparser.0              : logparser             : IoBroker-auf-AMD                         -  enabled
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker-auf-AMD                         -  enabled, port: 54321
                system.adapter.proxmox.0                : proxmox               : IoBroker-auf-AMD                         - disabled, port: 8006
              + system.adapter.simple-api.0             : simple-api            : IoBroker-auf-AMD                         -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              + system.adapter.telegram.0               : telegram              : IoBroker-auf-AMD                         -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.telegram.2               : telegram              : IoBroker-auf-AMD                         -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.telegram.3               : telegram              : Raspberry-Keller                         -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.telegram.4               : telegram              : IoBroker-auf-AMD                         -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.telegram.5               : telegram              : IoBroker-auf-AMD                         -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.telegram.6               : telegram              : IoBroker-auf-AMD                         -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.tr-064.0                 : tr-064                : IoBroker-auf-AMD                         -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IoBroker-auf-AMD                         - disabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : IoBroker-auf-AMD                         - disabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : IoBroker-auf-AMD                         -  enabled
                system.adapter.vis-material-webfont.0   : vis-material-webfont  : IoBroker-auf-AMD                         -  enabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : IoBroker-auf-AMD                         -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : IoBroker-auf-AMD                         - disabled
                system.adapter.vis.0                    : vis                   : IoBroker-auf-AMD                         -  enabled
              + system.adapter.web.0                    : web                   : IoBroker-auf-AMD                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                system.adapter.yr.0                     : yr                    : IoBroker-auf-AMD                         -  enabled
              + system.adapter.zigbee.0                 : zigbee                : IoBroker-auf-AMD                         -  enabled, port: /dev/ttyACM0
              + system.adapter.zigbee.1                 : zigbee                : Raspberry-Keller                         -  enabled, port: /dev/ttyACM0
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
              Adapter    "backitup"     : 2.8.7    , installed 2.8.7
              Adapter    "countdown"    : 2.2.0    , installed 2.2.0
              Adapter    "echarts"      : 1.5.4    , installed 1.5.4
              Adapter    "eventlist"    : 2.0.0    , installed 2.0.0
              Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
              Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
              Adapter    "hue"          : 3.10.1   , installed 3.10.1
              Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
              Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
              Adapter    "javascript"   : 7.1.6    , installed 7.1.6
              Controller "js-controller": 5.0.17   , installed 5.0.17
              Adapter    "linux-control": 1.1.5    , installed 1.1.5
              Adapter    "logparser"    : 2.2.0    , installed 2.2.0
              Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
              Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
              Adapter    "telegram"     : 3.0.0    , installed 3.0.0
              Adapter    "vis"          : 1.4.16   , installed 1.4.16
              Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Adapter    "yr"           : 5.3.0    , installed 5.3.0
              Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
              Objects and States
              Objects:        8559
              States:         6966
              Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
              Hit:2 http://deb.debian.org/debian bookworm InRelease
              Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
              Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
              Reading package lists...
              Pending Updates: 1
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1370       1/init
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15921      548/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       18894      944/io.jarvis.0
              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       676        514/iobroker.js-con
              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       17409      514/iobroker.js-con
              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       17926      959/io.simple-api.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15948      566/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20908      1004/io.web.0
              tcp6       0      0 :::111                  :::*                    LISTEN      0          1371       1/init
              tcp6       0      0 :::22                   :::*                    LISTEN      0          15923      548/sshd: /usr/sbin
              tcp6       0      0 :::3000                 :::*                    LISTEN      1001       20825      929/io.fullybrowser
              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       15257      738/io.mihome-vacuu
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16426      402/dhclient
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15620      1/init
              udp6       0      0 :::111                  :::*                                0          14552      1/init
              2023-12-15 21:26:16.936  - debug: vis.0 (989) States create User PubSub Client
              2023-12-15 21:26:16.987  - debug: vis.0 (989) States connected to redis: 0.0.0.0:9000
              2023-12-15 21:26:16.987  - silly: vis.0 (989) statesDB connected
              2023-12-15 21:26:17.013  - info: vis.0 (989) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
              2023-12-15 21:26:17.047  - silly: vis.0 (989) States system redis pmessage system.adapter.vis.0.logLevel/system.adapter.vis.0.logLevel:{"val":"silly","ack":true,"ts":1702671977019,"q":0,"from":"system.adapter.vis.0","lc":1702593049548}
              2023-12-15 21:26:17.147  - info: vis.0 (989) vis license is OK.
              2023-12-15 21:26:17.908  - info: vis.0 (989) Terminated (NO_ERROR): Without reason
              2023-12-15 21:26:18.437  - info: host.IoBroker-auf-AMD instance system.adapter.vis.0 terminated while should be started once
              2023-12-15 21:26:20.568  - info: host.IoBroker-auf-AMD instance system.adapter.web.0 started with pid 1004
              2023-12-15 21:26:21.095  - info: web.0 (1004) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
              2023-12-15 21:26:21.152  - info: web.0 (1004) socket.io server listening on port 8082
              2023-12-15 21:26:21.154  - info: web.0 (1004) http server listening on port 8082
              2023-12-15 21:26:24.512  - info: web.0 (1004) ==> Connected system.user.admin from ::ffff:192.168.178.22
              2023-12-15 21:26:24.568  - info: host.IoBroker-auf-AMD instance system.adapter.logparser.0 started with pid 1019
              2023-12-15 21:26:24.661  - info: web.0 (1004) <== Disconnect system.user.admin from ::ffff:192.168.178.22
              2023-12-15 21:26:25.073  - info: logparser.0 (1019) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.logparser, node: v18.19.0, js-controller: 5.0.17
              2023-12-15 21:26:29.979  - info: web.0 (1004) ==> Connected system.user.admin from ::ffff:192.168.178.22
              2023-12-15 21:30:00.005  - info: javascript.2 (633) script.js.common.VIS_2024.Scripte_andere_Seiten.Speedtest: Speedtest gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
              2023-12-15 21:30:15.990  - info: javascript.2 (633) script.js.common.VIS_2024.Scripte_andere_Seiten.Speedtest: Speedtest durchgeführt. Ergebnisse: Download: 253.03 MBits/s | Upload: 36.18 MBits/s | Ping: 0.657ms
              2023-12-15 21:33:24.443  - info: web.0 (1004) ==> Connected system.user.admin from ::ffff:192.168.178.206
              2023-12-15 21:33:35.912  - info: web.0 (1004) <== Disconnect system.user.admin from ::ffff:192.168.178.206 vis.0
              2023-12-15 21:33:36.230  - info: web.0 (1004) ==> Connected system.user.admin from ::ffff:192.168.178.206
              2023-12-15 21:34:29.848  - info: web.0 (1004) <== Disconnect system.user.admin from ::ffff:192.168.178.22 vis.0
              2023-12-15 21:34:35.696  - info: web.0 (1004) ==> Connected system.user.admin from ::ffff:192.168.178.22
              2023-12-15 21:34:49.356  - info: influxdb.0 (618) Store 61 buffered influxDB history points
              iob diag has finished.
              Ich habe soeben auch entdeckt, dass ich VIS öffnen kann, aber nicht mein eigentliches Projekt. Da fängt es an zu laden und friert ein.
                Thomas Braun Most Active @Pamf last edited by Thomas Braun
                @pamf
                sudo systemctl set-default multi-user.target
                sudo usermod -a -G adm patrick
                sudo apt update
                sudo apt install --reinstall nodejs
                sudo reboot
                Und lass die Finger von npm-Updates. Das Ding wird nicht separat angepackt.
                • Pamf
                  @thomas-braun Danke, zumindest die Versionen sind nun passend. Auf meine View hab ich aber leider weiterhin keinen Zugriff.
                  Jemand noch eine Idee? Ich habe hier gestern nur Widgets erstellt (kopiert aus einem schon vorher bestehendem und inhaltlich angepasst) und seitdem hab ich keinen Zugriff mehr
                    Im Log steht dazu?
                      @thomas-braun sagte in Vis 1 lädt nicht mehr, Loading Values:
                      Im Log steht dazu?
                      @Pamf
                      oder in der Browserkonsole (f12)
                      • Pamf
                        im Log steht gar nichts, in der Browserkonsole u.a. (sorry, ich konnte es nicht als Text herauskopieren):
                          Glaube ich nicht.
                            das ist nicht die Konsole.
                            Das wäre der nächste Reiter
                            • Ro75
                              Ro75 @Pamf last edited by Ro75
                              @pamf Hast du auf dieser View Objekte/Widgets gruppiert, kopiert? Wenn ja ist das der Auslöser. Wenn dem so ist, Backup der VIS einspielem.
                              Ro75.
                              Pamf mcm1957 2 Replies Last reply Reply Quote 1
                              • Pamf
                                @thomas-braun Du hast recht, im Log steht etwas, aber nicht dazu. VIS, Web etc. haben nichts im Log eingetragen.
                                @Ro75 genau das habe ich gemacht, nach langer Zeit ohne Nutzung der Möglichkeit des Kopierens dieses mal wieder gemacht. Danke! Bin gerade beim Einspielen der Sicherung.
                                • Pamf
                                  Pamf @Ro75 last edited by
                                  @ro75 Geht wieder, vielen Dank!!
                                  • mcm1957
                                    mcm1957 @Ro75 last edited by
                                    @ro75 said in Vis 1 lädt nicht mehr, Loading Values:
                                    Ro75.
                                    Ist dir dazu ein Issue im Adapter Repo bekannt?
                                    Offenbar gibt es hier ein bekanntes Problem. Ich konnte mal auf die Schnelle kein passendes Issue entdecken.
                                    Wenn dir auch keines bekannt ist, erstell dich du (oder sonst wer hier) ein passended Issue im Repo (https://github.com/ioBroker/ioBroker.vis/issues).
                                    Da ich vis nicht gut kenne, kann ich nicht sinnvoll beschreiben welche Aktion wie das Problem auslöst und welche Symptome da genau ausgelöst werden.
                                    DANKE
                                    596
