    4. Vis 1 lädt nicht mehr, Loading Values
      Thomas Braun Most Active @Pamf last edited by
      @pamf sagte in Vis 1 lädt nicht mehr, Loading Values:
      npm ist auch laut Konsole bei 10.2.5
      Nein, auf 10.2.3, wie es richtig ist.
      Pamf 1 Reply Last reply Reply Quote 0
      • Pamf
        Pamf @Thomas Braun last edited by
        Laut Konsole nicht:
        patrick@IoBroker-auf-AMD:~$ npm -v
        10.2.5
          Homoran Global Moderator Administrators @Pamf last edited by
          @pamf bitte iob diag in der Langfassung
          • Pamf
            Pamf @Homoran last edited by
            Skript v.2023-10-10
            *** BASE SYSTEM ***
             Static hostname: IoBroker-auf-AMD
                   Icon name: computer-vm
                     Chassis: vm 🖴
              Virtualization: kvm
                      Kernel: Linux 6.1.0-15-amd64
                Architecture: x86-64
             Hardware Vendor: QEMU
              Hardware Model: Standard PC _i440FX + PIIX, 1996_
            Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
            model name      : QEMU Virtual CPU version 2.5+
            Docker          : false
            Virtualization  : kvm
            Kernel          : x86_64
            Userland        : amd64
            Systemuptime and Load:
             21:35:30 up 10 min,  2 users,  load average: 0.57, 0.30, 0.12
            CPU threads: 4
            *** Time and Time Zones ***
                           Local time: Fri 2023-12-15 21:35:31 CET
                       Universal time: Fri 2023-12-15 20:35:31 UTC
                             RTC time: Fri 2023-12-15 20:35:31
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            patrick
            /home/patrick
            patrick cdrom floppy sudo audio dip video plugdev users netdev iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:             10G        2.9G        7.0G        581K        745M        7.5G
            Swap:           1.0G          0B        1.0G
            Total:           11G        2.9G        8.1G
                     9944 M total memory
                     2764 M used memory
                      125 M active memory
                     2877 M inactive memory
                     6712 M free memory
                       36 M buffer memory
                      674 M swap cache
                      974 M total swap
                        0 M used swap
                      974 M free swap
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            udev           devtmpfs  4.9G     0  4.9G   0% /dev
            tmpfs          tmpfs     995M  576K  994M   1% /run
            /dev/sda1      ext4       31G  5.9G   23G  21% /
            tmpfs          tmpfs     4.9G     0  4.9G   0% /dev/shm
            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
            tmpfs          tmpfs     995M     0  995M   0% /run/user/1000
            [Fri Dec 15 21:24:39 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
            [Fri Dec 15 21:24:39 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
            TARGET SOURCE    FSTYPE OPTIONS
            /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
            /var:
            519M    /var/
            297M    /var/cache
            290M    /var/cache/apt
            214M    /var/cache/apt/archives
            171M    /var/lib
            Archived and active journals take up 8.0M in the file system.
            /opt/iobroker/backups:
            388M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.1G    /opt/iobroker/iobroker-data/
            503M    /opt/iobroker/iobroker-data/files
            95M     /opt/iobroker/iobroker-data/backup-objects
            90M     /opt/iobroker/iobroker-data/files/echarts.admin
            87M     /opt/iobroker/iobroker-data/files/vis.0
            354M    /opt/iobroker/iobroker-data/states.jsonl
            35M     /opt/iobroker/iobroker-data/objects.jsonl
            24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
            24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
            24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
            USB-Devices by-id:
            /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2190944-if00
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.19.0
            /usr/bin/node           v18.19.0
            /usr/bin/npm            10.2.5
            /usr/bin/npx            10.2.5
            /usr/bin/corepack       0.22.0
            nodejs:
              Installed: 18.19.0-1nodesource1
              Candidate: 18.19.0-1nodesource1
              Version table:
             *** 18.19.0-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 18.18.2-1nodesource1 500
                 18.18.1-1nodesource1 500
                 18.18.0-1nodesource1 500
                 18.17.1-1nodesource1 500
                 18.17.0-1nodesource1 500
                 18.16.1-1nodesource1 500
                 18.16.0-1nodesource1 500
                 18.15.0-1nodesource1 500
                 18.14.2-1nodesource1 500
                 18.14.1-1nodesource1 500
                 18.14.0-1nodesource1 500
                 18.13.0+dfsg1-1 500
                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
                 18.13.0-1nodesource1 500
                 18.12.0-1nodesource1 500
                 18.11.0-1nodesource1 500
                 18.10.0-1nodesource1 500
                 18.9.1-1nodesource1 500
                 18.9.0-1nodesource1 500
                 18.8.0-1nodesource1 500
                 18.7.0-1nodesource1 500
                 18.6.0-1nodesource1 500
                 18.5.0-1nodesource1 500
                 18.4.0-1nodesource1 500
                 18.3.0-1nodesource1 500
                 18.2.0-1nodesource1 500
                 18.1.0-1nodesource1 500
                 18.0.0-1nodesource1 500
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.17
            admin:          6.12.0
            javascript:     7.1.6
            Adapters from github:   1
            Adapter State
            + system.adapter.admin.0                  : admin                 : IoBroker-auf-AMD                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : IoBroker-auf-AMD                         -  enabled
              system.adapter.alias-manager.0          : alias-manager         : IoBroker-auf-AMD                         - disabled
            + system.adapter.backitup.0               : backitup              : IoBroker-auf-AMD                         -  enabled
            + system.adapter.backitup.1               : backitup              : Raspberry-Keller                         -  enabled
            + system.adapter.countdown.0              : countdown             : IoBroker-auf-AMD                         -  enabled
            + system.adapter.drops-weather.0          : drops-weather         : IoBroker-auf-AMD                         -  enabled
            + system.adapter.eventlist.0              : eventlist             : IoBroker-auf-AMD                         -  enabled
              system.adapter.feiertage.0              : feiertage             : IoBroker-auf-AMD                         -  enabled
              system.adapter.flot.0                   : flot                  : IoBroker-auf-AMD                         -  enabled
            + system.adapter.fullybrowser.0           : fullybrowser          : IoBroker-auf-AMD                         -  enabled
            + system.adapter.hue.0                    : hue                   : IoBroker-auf-AMD                         -  enabled, port: 443
            + system.adapter.influxdb.0               : influxdb              : IoBroker-auf-AMD                         -  enabled, port: 8086
            + system.adapter.jarvis.0                 : jarvis                : IoBroker-auf-AMD                         -  enabled
            + system.adapter.javascript.1             : javascript            : Raspberry-Keller                         -  enabled
            + system.adapter.javascript.2             : javascript            : IoBroker-auf-AMD                         -  enabled
            + system.adapter.logparser.0              : logparser             : IoBroker-auf-AMD                         -  enabled
            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker-auf-AMD                         -  enabled, port: 54321
              system.adapter.proxmox.0                : proxmox               : IoBroker-auf-AMD                         - disabled, port: 8006
            + system.adapter.simple-api.0             : simple-api            : IoBroker-auf-AMD                         -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.telegram.0               : telegram              : IoBroker-auf-AMD                         -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.2               : telegram              : IoBroker-auf-AMD                         -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.3               : telegram              : Raspberry-Keller                         -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.4               : telegram              : IoBroker-auf-AMD                         -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.5               : telegram              : IoBroker-auf-AMD                         -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.6               : telegram              : IoBroker-auf-AMD                         -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.tr-064.0                 : tr-064                : IoBroker-auf-AMD                         -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IoBroker-auf-AMD                         - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : IoBroker-auf-AMD                         - disabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : IoBroker-auf-AMD                         -  enabled
              system.adapter.vis-material-webfont.0   : vis-material-webfont  : IoBroker-auf-AMD                         -  enabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : IoBroker-auf-AMD                         -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : IoBroker-auf-AMD                         - disabled
              system.adapter.vis.0                    : vis                   : IoBroker-auf-AMD                         -  enabled
            + system.adapter.web.0                    : web                   : IoBroker-auf-AMD                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.yr.0                     : yr                    : IoBroker-auf-AMD                         -  enabled
            + system.adapter.zigbee.0                 : zigbee                : IoBroker-auf-AMD                         -  enabled, port: /dev/ttyACM0
            + system.adapter.zigbee.1                 : zigbee                : Raspberry-Keller                         -  enabled, port: /dev/ttyACM0
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.12.0   , installed 6.12.0
            Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
            Adapter    "backitup"     : 2.8.7    , installed 2.8.7
            Adapter    "countdown"    : 2.2.0    , installed 2.2.0
            Adapter    "echarts"      : 1.5.4    , installed 1.5.4
            Adapter    "eventlist"    : 2.0.0    , installed 2.0.0
            Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
            Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
            Adapter    "hue"          : 3.10.1   , installed 3.10.1
            Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
            Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
            Adapter    "javascript"   : 7.1.6    , installed 7.1.6
            Controller "js-controller": 5.0.17   , installed 5.0.17
            Adapter    "linux-control": 1.1.5    , installed 1.1.5
            Adapter    "logparser"    : 2.2.0    , installed 2.2.0
            Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
            Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
            Adapter    "telegram"     : 3.0.0    , installed 3.0.0
            Adapter    "vis"          : 1.4.16   , installed 1.4.16
            Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
            Adapter    "web"          : 6.1.10   , installed 6.1.10
            Adapter    "ws"           : 2.5.8    , installed 2.5.8
            Adapter    "yr"           : 5.3.0    , installed 5.3.0
            Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
            Objects and States
            Objects:        8559
            States:         6966
            Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
            Hit:2 http://deb.debian.org/debian bookworm InRelease
            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
            Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
            Reading package lists...
            Pending Updates: 1
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1370       1/init
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15921      548/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       18894      944/io.jarvis.0
            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       676        514/iobroker.js-con
            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       17409      514/iobroker.js-con
            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       17926      959/io.simple-api.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15948      566/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20908      1004/io.web.0
            tcp6       0      0 :::111                  :::*                    LISTEN      0          1371       1/init
            tcp6       0      0 :::22                   :::*                    LISTEN      0          15923      548/sshd: /usr/sbin
            tcp6       0      0 :::3000                 :::*                    LISTEN      1001       20825      929/io.fullybrowser
            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       15257      738/io.mihome-vacuu
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16426      402/dhclient
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15620      1/init
            udp6       0      0 :::111                  :::*                                0          14552      1/init
            2023-12-15 21:26:16.936  - debug: vis.0 (989) States create User PubSub Client
            2023-12-15 21:26:16.987  - debug: vis.0 (989) States connected to redis: 0.0.0.0:9000
            2023-12-15 21:26:16.987  - silly: vis.0 (989) statesDB connected
            2023-12-15 21:26:17.013  - info: vis.0 (989) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
            2023-12-15 21:26:17.047  - silly: vis.0 (989) States system redis pmessage system.adapter.vis.0.logLevel/system.adapter.vis.0.logLevel:{"val":"silly","ack":true,"ts":1702671977019,"q":0,"from":"system.adapter.vis.0","lc":1702593049548}
            2023-12-15 21:26:17.147  - info: vis.0 (989) vis license is OK.
            2023-12-15 21:26:17.908  - info: vis.0 (989) Terminated (NO_ERROR): Without reason
            2023-12-15 21:26:18.437  - info: host.IoBroker-auf-AMD instance system.adapter.vis.0 terminated while should be started once
            2023-12-15 21:26:20.568  - info: host.IoBroker-auf-AMD instance system.adapter.web.0 started with pid 1004
            2023-12-15 21:26:21.095  - info: web.0 (1004) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
            2023-12-15 21:26:21.152  - info: web.0 (1004) socket.io server listening on port 8082
            2023-12-15 21:26:21.154  - info: web.0 (1004) http server listening on port 8082
            2023-12-15 21:26:24.512  - info: web.0 (1004) ==> Connected system.user.admin from ::ffff:192.168.178.22
            2023-12-15 21:26:24.568  - info: host.IoBroker-auf-AMD instance system.adapter.logparser.0 started with pid 1019
            2023-12-15 21:26:24.661  - info: web.0 (1004) <== Disconnect system.user.admin from ::ffff:192.168.178.22
            2023-12-15 21:26:25.073  - info: logparser.0 (1019) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.logparser, node: v18.19.0, js-controller: 5.0.17
            2023-12-15 21:26:29.979  - info: web.0 (1004) ==> Connected system.user.admin from ::ffff:192.168.178.22
            2023-12-15 21:30:00.005  - info: javascript.2 (633) script.js.common.VIS_2024.Scripte_andere_Seiten.Speedtest: Speedtest gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
            2023-12-15 21:30:15.990  - info: javascript.2 (633) script.js.common.VIS_2024.Scripte_andere_Seiten.Speedtest: Speedtest durchgeführt. Ergebnisse: Download: 253.03 MBits/s | Upload: 36.18 MBits/s | Ping: 0.657ms
            2023-12-15 21:33:24.443  - info: web.0 (1004) ==> Connected system.user.admin from ::ffff:192.168.178.206
            2023-12-15 21:33:35.912  - info: web.0 (1004) <== Disconnect system.user.admin from ::ffff:192.168.178.206 vis.0
            2023-12-15 21:33:36.230  - info: web.0 (1004) ==> Connected system.user.admin from ::ffff:192.168.178.206
            2023-12-15 21:34:29.848  - info: web.0 (1004) <== Disconnect system.user.admin from ::ffff:192.168.178.22 vis.0
            2023-12-15 21:34:35.696  - info: web.0 (1004) ==> Connected system.user.admin from ::ffff:192.168.178.22
            2023-12-15 21:34:49.356  - info: influxdb.0 (618) Store 61 buffered influxDB history points
            iob diag has finished.
            Ich habe soeben auch entdeckt, dass ich VIS öffnen kann, aber nicht mein eigentliches Projekt. Da fängt es an zu laden und friert ein.
              Thomas Braun Most Active @Pamf last edited by Thomas Braun
              @pamf
              sudo systemctl set-default multi-user.target
              sudo usermod -a -G adm patrick
              sudo apt update
              sudo apt full-upgrade
              sudo apt install --reinstall nodejs
              sudo reboot
              Und lass die Finger von npm-Updates. Das Ding wird nicht separat angepackt.
              • Pamf
                @thomas-braun Danke, zumindest die Versionen sind nun passend. Auf meine View hab ich aber leider weiterhin keinen Zugriff.
                Jemand noch eine Idee? Ich habe hier gestern nur Widgets erstellt (kopiert aus einem schon vorher bestehendem und inhaltlich angepasst) und seitdem hab ich keinen Zugriff mehr
                  Im Log steht dazu?
                    @thomas-braun sagte in Vis 1 lädt nicht mehr, Loading Values:
                    Im Log steht dazu?
                    @Pamf
                    oder in der Browserkonsole (f12)
                    • Pamf
                      im Log steht gar nichts, in der Browserkonsole u.a. (sorry, ich konnte es nicht als Text herauskopieren):
                        Glaube ich nicht.
                          das ist nicht die Konsole.
                          Das wäre der nächste Reiter
                          • Ro75
                            Ro75 @Pamf last edited by Ro75
                            @pamf Hast du auf dieser View Objekte/Widgets gruppiert, kopiert? Wenn ja ist das der Auslöser. Wenn dem so ist, Backup der VIS einspielem.
                            Ro75.
                            Pamf mcm1957 2 Replies Last reply Reply Quote 1
                            • Pamf
                              @thomas-braun Du hast recht, im Log steht etwas, aber nicht dazu. VIS, Web etc. haben nichts im Log eingetragen.
                              @Ro75 genau das habe ich gemacht, nach langer Zeit ohne Nutzung der Möglichkeit des Kopierens dieses mal wieder gemacht. Danke! Bin gerade beim Einspielen der Sicherung.
                              • Pamf
                                Pamf @Ro75 last edited by
                                @ro75 Geht wieder, vielen Dank!!
                                • mcm1957
                                  mcm1957 @Ro75 last edited by
                                  @ro75 said in Vis 1 lädt nicht mehr, Loading Values:
                                  Ro75.
                                  Ist dir dazu ein Issue im Adapter Repo bekannt?
                                  Offenbar gibt es hier ein bekanntes Problem. Ich konnte mal auf die Schnelle kein passendes Issue entdecken.
                                  Wenn dir auch keines bekannt ist, erstell dich du (oder sonst wer hier) ein passended Issue im Repo (https://github.com/ioBroker/ioBroker.vis/issues).
                                  Da ich vis nicht gut kenne, kann ich nicht sinnvoll beschreiben welche Aktion wie das Problem auslöst und welche Symptome da genau ausgelöst werden.
                                  DANKE
                                  81.1k
                                  1013
