    4. Node-Red
    5. Node Red DP erstellen
    • mickym
      mickym Most Active @dos1973 last edited by mickym
      @dos1973
      @dos1973 sagte in Node Red DP erstellen:
      @mickym
      {"scriptVersion":"0.1","src":"shellies/Pro3_EM","srcBle":{"mac":"b4:35:22:fe:56:ad"},"payload":{"encryption":false,"BTHome_version":2,"pid":253,"battery":100,"button":2,"rssi":-79,"address":"b4:35:22:fe:56:ad"}}
      Sehr gut. Ist nur eine Kleinigkeit - ich sag Dir gleich was. Das liegt einfach daran - dass ich bei den Screenshots nicht immer so genau schaue. 😉
      • mickym
        mickym Most Active last edited by mickym
        Du musst in der 1. Change Node (Ändere srcBle) nur auf die Objekteigenschaft verweisen:
        Das rot unterstrichene bitte dort anfügen.
        Und hinten NICHTS ändern - das topic in der Change Node bleibt so wie ich es erstellt habe.
        Nichts mit payload etc.
        Hier nochmal ein frischer Import:
               "id": "97b845b5a6599224",
               "type": "split",
               "z": "517cd16e4d7e6ae4",
               "name": "teile Objekt in Einzelnachrichten",
               "splt": "\\n",
               "spltType": "str",
               "arraySplt": 1,
               "arraySpltType": "len",
               "stream": false,
               "addname": "topic",
               "x": 830,
               "y": 660,
               "wires": [
                       "4ec1e6e4e84579e7"
               "id": "042bf417501565f3",
               "type": "change",
               "name": "Ändere srcBle",
               "rules": [
                       "t": "change",
                       "p": "srcBle.mac",
                       "pt": "msg",
                       "from": ":",
                       "fromt": "str",
                       "to": "-",
                       "tot": "str"
                       "t": "set",
                       "p": "srcBle",
                       "pt": "msg",
                       "to": "\"0_userdata.0.Wohnung.Status.Shelly.Shelly-BLE-Geraete.\" & srcBle.mac",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 280,
               "y": 660,
               "wires": [
                       "adb8c34172c9605f"
               "id": "adb8c34172c9605f",
               "type": "change",
               "name": "Entferne payload-Eigenschaften",
               "rules": [
                       "t": "delete",
                       "p": "payload.address",
                       "pt": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 530,
               "y": 660,
               "wires": [
                       "97b845b5a6599224"
               "id": "4ec1e6e4e84579e7",
               "type": "change",
               "name": "erstelle topic",
               "rules": [
                       "t": "set",
                       "p": "topic",
                       "pt": "msg",
                       "to": "srcBle & \".\" & topic",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1070,
               "y": 660,
               "wires": [
                       "bd42f02cc76dacad"
               "id": "bd42f02cc76dacad",
               "type": "ioBroker out",
               "name": "schreibe Werte",
               "topic": "",
               "ack": "true",
               "autoCreate": "true",
               "stateName": "",
               "role": "",
               "payloadType": "",
               "readonly": "false",
               "stateUnit": "",
               "stateMin": "",
               "stateMax": "",
               "x": 1260,
               "y": 660,
               "wires": []
          dos1973 @mickym last edited by
          @mickym
          nee klappt nicht.
          habe es ergänzt
          sieht alles genauso aus
          • mickym
            @dos1973 Entweder nochmal frischer Import - oder Du hast hinten an der topic Node was geändert. Ansonsten klemm die iobroker-out Node ab, mach einen debug dahinter und poste das. Aber erst neu importieren.
            Die Nachrichten, die in die iobroker-Out NOde gehen müssen so aussehen:
              @mickym
              ich habe es komplett neu importiert
              • mickym
                @mickym
                Und Debug Node hinten dran gemacht und bitte Screenshot der einzelnen Nachrichten bevor diese in die iobroker-Out Node gehen. - Ich hab dir gerade geschickt wie das aussehen muss.
                  @mickym
                  ich hoffe ich habs verstanden
                  • mickym
                    @dos1973 OK ich weiß nicht wo die 2 Punkte her kommen.
                    Ich werde nochmal mit diesem Objekt Deinen Input nachbauen und Du sagst, ob der mit Deinem identisch ist.
                      @mickym
                      ist irgendwie eine schwere geburt...
                      • mickym
                        Ich denke ich habe den Fehler gefunden:
                        da muss der Punkt raus - sorry war schlampig meinerseits
                        FALLS NICHT DANN
                        ... bitte diesen ganzen Flow importieren und bestätigen erstmal, dass nun das konstruierte Eingangsobjekt genauso wie Deine Nachrichten aussehen:
                        Also mit der Inject Node testen.
                        Wenn das so ist dann kannst Du vor die 2. Reihe Deine mqtt-In klemmen
                               "id": "85395d3e7d299c24",
                               "type": "inject",
                               "name": "Eingangswerte",
                               "props": [
                                       "p": "input",
                                       "v": "{\"scriptVersion\":\"0.1\",\"src\":\"shellies/Pro3_EM\",\"srcBle\":{\"mac\":\"b4:35:22:fe:56:ad\"},\"payload\":{\"encryption\":false,\"BTHome_version\":2,\"pid\":253,\"battery\":100,\"button\":2,\"rssi\":-79,\"address\":\"b4:35:22:fe:56:ad\"}}",
                                       "vt": "json"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "x": 180,
                               "y": 780,
                               "wires": [
                                       "9ac0c724ea2285d2",
                                       "71622aabe05c1ac5"
                               "id": "9ac0c724ea2285d2",
                               "type": "change",
                               "name": "konstruiere OriginalObjekt",
                               "rules": [
                                       "t": "move",
                                       "p": "input.scriptVersion",
                                       "pt": "msg",
                                       "to": "scriptVersion",
                                       "tot": "msg"
                                       "t": "move",
                                       "p": "input.src",
                                       "pt": "msg",
                                       "to": "src",
                                       "tot": "msg"
                                       "t": "set",
                                       "p": "input.srcBle",
                                       "pt": "msg",
                                       "to": "srcBle",
                                       "tot": "msg"
                                       "t": "move",
                                       "p": "input.payload",
                                       "pt": "msg",
                                       "to": "payload",
                                       "tot": "msg"
                                       "t": "delete",
                                       "p": "input",
                                       "pt": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 410,
                               "y": 780,
                               "wires": [
                                       "dbf5c78009b4f581",
                                       "f19cc6f7778c2633"
                               "id": "71622aabe05c1ac5",
                               "type": "debug",
                               "name": "Eingabewert",
                               "active": false,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "complete": "true",
                               "targetType": "full",
                               "statusVal": "",
                               "statusType": "auto",
                               "x": 370,
                               "y": 740,
                               "wires": []
                               "id": "dbf5c78009b4f581",
                               "type": "debug",
                               "name": "Originalobjekt",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "complete": "true",
                               "statusVal": "",
                               "x": 620,
                               "y": 740,
                               "wires": []
                               "id": "831875c3be845a77",
                               "type": "split",
                               "splt": "\\n",
                               "spltType": "str",
                               "arraySplt": 1,
                               "stream": false,
                               "addname": "topic",
                               "x": 790,
                               "y": 840,
                               "wires": [
                                       "4e6bbe32dfcc7c5d"
                               "id": "f19cc6f7778c2633",
                               "type": "change",
                               "rules": [
                                       "t": "change",
                                       "p": "srcBle.mac",
                                       "pt": "msg",
                                       "from": ":",
                                       "fromt": "str",
                                       "to": "-",
                                       "tot": "str"
                                       "t": "set",
                                       "p": "srcBle",
                                       "pt": "msg",
                                       "to": "\"0_userdata.0.Wohnung.Status.Shelly.Shelly-BLE-Geraete\" & srcBle.mac",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 240,
                               "y": 840,
                               "wires": [
                                       "c1cac0b6dc174190"
                               "id": "c1cac0b6dc174190",
                               "type": "change",
                               "rules": [
                                       "t": "delete",
                                       "pt": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 490,
                               "y": 840,
                               "wires": [
                                       "831875c3be845a77"
                               "id": "4e6bbe32dfcc7c5d",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1030,
                               "y": 840,
                               "wires": [
                                       "15bab36dddd209ed",
                                       "474c1b7582b85047"
                               "id": "474c1b7582b85047",
                               "type": "debug",
                               "name": "Einzelnachrichten",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "complete": "payload",
                               "targetType": "msg",
                               "statusVal": "",
                               "x": 1230,
                               "y": 800,
                               "wires": []
                               "id": "15bab36dddd209ed",
                               "d": true,
                               "topic": "",
                               "ack": "true",
                               "stateName": "",
                               "role": "",
                               "payloadType": "",
                               "stateUnit": "",
                               "stateMin": "",
                               "stateMax": "",
                               "x": 1220,
                               "y": 840,
                               "wires": []
                          @mickym
                          wenn ich den "Eingangswert Triggere" passiert nichts in der DP struktur
                          • mickym
                            @dos1973 Das ist klar - ist doch hinten deaktiviert. Wie gesagt mach einfach den Punkt raus an dem Originalflow den Du schon hast.
                              @mickym
                              ja, habs zu spät gesehen 🙂
                              • mickym
                                @dos1973
                                Das sollte aber hinhauen. Wie gesagt vorher war nur der Punkt zuviel
                                  @mickym
                                  das ist jetzt der neue flow.
                                  es passt aber nicht??
                                  • mickym
                                    @dos1973 Klemm bitte nochmal die iobroker out Node ab. Lösche bitte in den Objekten nochmal den Baum Shelly-BLE-Geräte und poste nun die Einzelnachrichten im Debugfenster. Vielleicht auch den Browser refreshen -
                                      @mickym
                                      mach icg gleich.
                                      aber schau mal hier.
                                      ich triggere das manuell und das kommt an. hier fehlt do schon die mac als übergeordneter folder
                                      • mickym
                                        @dos1973 Oh ich sehe - mein Fehler - ich bin heute anscheinend nicht fit.
                                          @mickym
                                          • mickym
                                            So nun kommen bei mir aber die topics mit der mac Adresse raus:
                                            Also das Ganze nochmal zum Import - erst mit der Inject Node testen:
                                                   "type": "inject",
                                                   "props": [
                                                           "p": "input",
                                                           "vt": "json"
                                                   "repeat": "",
                                                   "crontab": "",
                                                   "once": false,
                                                   "onceDelay": 0.1,
                                                   "topic": "",
                                                   "x": 180,
                                                   "y": 780,
                                                   "wires": [
                                                           "9ac0c724ea2285d2",
                                                           "71622aabe05c1ac5"
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "move",
                                                           "pt": "msg",
                                                           "tot": "msg"
                                                           "t": "move",
                                                           "p": "input.src",
                                                           "pt": "msg",
                                                           "to": "src",
                                                           "tot": "msg"
                                                           "t": "move",
                                                           "pt": "msg",
                                                           "to": "srcBle",
                                                           "tot": "msg"
                                                           "t": "move",
                                                           "pt": "msg",
                                                           "to": "payload",
                                                           "tot": "msg"
                                                           "t": "delete",
                                                           "p": "input",
                                                           "pt": "msg"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 410,
                                                   "y": 780,
                                                   "wires": [
                                                           "dbf5c78009b4f581",
                                                           "f19cc6f7778c2633"
                                                   "type": "debug",
                                                   "active": false,
                                                   "tosidebar": true,
                                                   "console": false,
                                                   "tostatus": false,
                                                   "complete": "true",
                                                   "statusVal": "",
                                                   "x": 370,
                                                   "y": 740,
                                                   "wires": []
                                                   "type": "debug",
                                                   "active": true,
                                                   "tosidebar": true,
                                                   "console": false,
                                                   "tostatus": false,
                                                   "complete": "true",
                                                   "statusVal": "",
                                                   "x": 620,
                                                   "y": 740,
                                                   "wires": []
                                                   "type": "split",
                                                   "splt": "\\n",
                                                   "spltType": "str",
                                                   "arraySplt": 1,
                                                   "stream": false,
                                                   "addname": "topic",
                                                   "x": 790,
                                                   "y": 840,
                                                   "wires": [
                                                           "4e6bbe32dfcc7c5d"
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "change",
                                                           "p": "srcBle.mac",
                                                           "pt": "msg",
                                                           "from": ":",
                                                           "fromt": "str",
                                                           "to": "-",
                                                           "tot": "str"
                                                           "t": "set",
                                                           "p": "srcBle",
                                                           "pt": "msg",
                                                           "tot": "jsonata"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 240,
                                                   "y": 840,
                                                   "wires": [
                                                           "c1cac0b6dc174190"
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "delete",
                                                           "pt": "msg"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 490,
                                                   "y": 840,
                                                   "wires": [
                                                           "831875c3be845a77"
                                                   "type": "change",
                                                   "rules": [
                                                           "t": "set",
                                                           "p": "topic",
                                                           "pt": "msg",
                                                           "tot": "jsonata"
                                                   "action": "",
                                                   "property": "",
                                                   "from": "",
                                                   "to": "",
                                                   "reg": false,
                                                   "x": 1030,
                                                   "y": 840,
                                                   "wires": [
                                                           "15bab36dddd209ed",
                                                           "474c1b7582b85047"
                                                   "type": "debug",
                                                   "active": true,
                                                   "tosidebar": true,
                                                   "console": false,
                                                   "tostatus": false,
                                                   "statusVal": "",
                                                   "x": 1230,
                                                   "y": 800,
                                                   "wires": []
                                                   "topic": "",
                                                   "ack": "true",
                                                   "stateName": "",
                                                   "role": "",
                                                   "payloadType": "",
                                                   "stateUnit": "",
                                                   "stateMin": "",
                                                   "stateMax": "",
                                                   "x": 1220,
                                                   "y": 840,
                                                   "wires": []
                                            2829
