    4. Node-Red
    5. Node Red DP erstellen
    • mickym
      mickym Most Active last edited by mickym
      Du musst in der 1. Change Node (Ändere srcBle) nur auf die Objekteigenschaft verweisen:
      Das rot unterstrichene bitte dort anfügen.
      Und hinten NICHTS ändern - das topic in der Change Node bleibt so wie ich es erstellt habe.
      Nichts mit payload etc.
      Hier nochmal ein frischer Import:
             "id": "97b845b5a6599224",
             "type": "split",
             "z": "517cd16e4d7e6ae4",
             "name": "teile Objekt in Einzelnachrichten",
             "splt": "\\n",
             "spltType": "str",
             "arraySplt": 1,
             "arraySpltType": "len",
             "stream": false,
             "addname": "topic",
             "x": 830,
             "y": 660,
             "wires": [
                     "4ec1e6e4e84579e7"
             "id": "042bf417501565f3",
             "type": "change",
             "name": "Ändere srcBle",
             "rules": [
                     "t": "change",
                     "p": "srcBle.mac",
                     "pt": "msg",
                     "from": ":",
                     "fromt": "str",
                     "to": "-",
                     "tot": "str"
                     "t": "set",
                     "p": "srcBle",
                     "pt": "msg",
                     "to": "\"0_userdata.0.Wohnung.Status.Shelly.Shelly-BLE-Geraete.\" & srcBle.mac",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 280,
             "y": 660,
             "wires": [
                     "adb8c34172c9605f"
             "id": "adb8c34172c9605f",
             "type": "change",
             "name": "Entferne payload-Eigenschaften",
             "rules": [
                     "t": "delete",
                     "p": "payload.address",
                     "pt": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 530,
             "y": 660,
             "wires": [
                     "97b845b5a6599224"
             "id": "4ec1e6e4e84579e7",
             "type": "change",
             "name": "erstelle topic",
             "rules": [
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "to": "srcBle & \".\" & topic",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1070,
             "y": 660,
             "wires": [
                     "bd42f02cc76dacad"
             "id": "bd42f02cc76dacad",
             "type": "ioBroker out",
             "name": "schreibe Werte",
             "topic": "",
             "ack": "true",
             "autoCreate": "true",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "false",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 1260,
             "y": 660,
             "wires": []
        dos1973 @mickym last edited by
        @mickym
        nee klappt nicht.
        habe es ergänzt
        sieht alles genauso aus
        • mickym
          mickym Most Active @dos1973 last edited by mickym
          @dos1973 Entweder nochmal frischer Import - oder Du hast hinten an der topic Node was geändert. Ansonsten klemm die iobroker-out Node ab, mach einen debug dahinter und poste das. Aber erst neu importieren.
          Die Nachrichten, die in die iobroker-Out NOde gehen müssen so aussehen:
            @mickym
            ich habe es komplett neu importiert
            • mickym
              @dos1973 sagte in Node Red DP erstellen:
              @mickym
              Und Debug Node hinten dran gemacht und bitte Screenshot der einzelnen Nachrichten bevor diese in die iobroker-Out Node gehen. - Ich hab dir gerade geschickt wie das aussehen muss.
                @mickym
                ich hoffe ich habs verstanden
                • mickym
                  @dos1973 OK ich weiß nicht wo die 2 Punkte her kommen.
                  Ich werde nochmal mit diesem Objekt Deinen Input nachbauen und Du sagst, ob der mit Deinem identisch ist.
                  {"scriptVersion":"0.1","src":"shellies/Pro3_EM","srcBle":{"mac":"b4:35:22:fe:56:ad"},"payload":{"encryption":false,"BTHome_version":2,"pid":253,"battery":100,"button":2,"rssi":-79,"address":"b4:35:22:fe:56:ad"}}
                    @mickym
                    ist irgendwie eine schwere geburt...
                    • mickym
                      Ich denke ich habe den Fehler gefunden:
                      da muss der Punkt raus - sorry war schlampig meinerseits
                      FALLS NICHT DANN
                      ... bitte diesen ganzen Flow importieren und bestätigen erstmal, dass nun das konstruierte Eingangsobjekt genauso wie Deine Nachrichten aussehen:
                      Also mit der Inject Node testen.
                      Wenn das so ist dann kannst Du vor die 2. Reihe Deine mqtt-In klemmen
                             "id": "85395d3e7d299c24",
                             "type": "inject",
                             "name": "Eingangswerte",
                             "props": [
                                     "p": "input",
                                     "v": "{\"scriptVersion\":\"0.1\",\"src\":\"shellies/Pro3_EM\",\"srcBle\":{\"mac\":\"b4:35:22:fe:56:ad\"},\"payload\":{\"encryption\":false,\"BTHome_version\":2,\"pid\":253,\"battery\":100,\"button\":2,\"rssi\":-79,\"address\":\"b4:35:22:fe:56:ad\"}}",
                                     "vt": "json"
                             "repeat": "",
                             "crontab": "",
                             "once": false,
                             "onceDelay": 0.1,
                             "topic": "",
                             "x": 180,
                             "y": 780,
                             "wires": [
                                     "9ac0c724ea2285d2",
                                     "71622aabe05c1ac5"
                             "id": "9ac0c724ea2285d2",
                             "type": "change",
                             "name": "konstruiere OriginalObjekt",
                             "rules": [
                                     "t": "move",
                                     "p": "input.scriptVersion",
                                     "pt": "msg",
                                     "to": "scriptVersion",
                                     "tot": "msg"
                                     "t": "move",
                                     "p": "input.src",
                                     "pt": "msg",
                                     "to": "src",
                                     "tot": "msg"
                                     "t": "set",
                                     "p": "input.srcBle",
                                     "pt": "msg",
                                     "to": "srcBle",
                                     "tot": "msg"
                                     "t": "move",
                                     "p": "input.payload",
                                     "pt": "msg",
                                     "to": "payload",
                                     "tot": "msg"
                                     "t": "delete",
                                     "p": "input",
                                     "pt": "msg"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 410,
                             "y": 780,
                             "wires": [
                                     "dbf5c78009b4f581",
                                     "f19cc6f7778c2633"
                             "id": "71622aabe05c1ac5",
                             "type": "debug",
                             "name": "Eingabewert",
                             "active": false,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "complete": "true",
                             "targetType": "full",
                             "statusVal": "",
                             "statusType": "auto",
                             "x": 370,
                             "y": 740,
                             "wires": []
                             "id": "dbf5c78009b4f581",
                             "type": "debug",
                             "name": "Originalobjekt",
                             "active": true,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "complete": "true",
                             "statusVal": "",
                             "x": 620,
                             "y": 740,
                             "wires": []
                             "id": "831875c3be845a77",
                             "type": "split",
                             "splt": "\\n",
                             "spltType": "str",
                             "arraySplt": 1,
                             "stream": false,
                             "addname": "topic",
                             "x": 790,
                             "y": 840,
                             "wires": [
                                     "4e6bbe32dfcc7c5d"
                             "id": "f19cc6f7778c2633",
                             "type": "change",
                             "rules": [
                                     "t": "change",
                                     "p": "srcBle.mac",
                                     "pt": "msg",
                                     "from": ":",
                                     "fromt": "str",
                                     "to": "-",
                                     "tot": "str"
                                     "t": "set",
                                     "p": "srcBle",
                                     "pt": "msg",
                                     "to": "\"0_userdata.0.Wohnung.Status.Shelly.Shelly-BLE-Geraete\" & srcBle.mac",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 240,
                             "y": 840,
                             "wires": [
                                     "c1cac0b6dc174190"
                             "id": "c1cac0b6dc174190",
                             "type": "change",
                             "rules": [
                                     "t": "delete",
                                     "pt": "msg"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 490,
                             "y": 840,
                             "wires": [
                                     "831875c3be845a77"
                             "id": "4e6bbe32dfcc7c5d",
                             "type": "change",
                             "rules": [
                                     "t": "set",
                                     "p": "topic",
                                     "pt": "msg",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1030,
                             "y": 840,
                             "wires": [
                                     "15bab36dddd209ed",
                                     "474c1b7582b85047"
                             "id": "474c1b7582b85047",
                             "type": "debug",
                             "name": "Einzelnachrichten",
                             "active": true,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "complete": "payload",
                             "targetType": "msg",
                             "statusVal": "",
                             "x": 1230,
                             "y": 800,
                             "wires": []
                             "id": "15bab36dddd209ed",
                             "d": true,
                             "topic": "",
                             "ack": "true",
                             "stateName": "",
                             "role": "",
                             "payloadType": "",
                             "stateUnit": "",
                             "stateMin": "",
                             "stateMax": "",
                             "x": 1220,
                             "y": 840,
                             "wires": []
                        @mickym
                        wenn ich den "Eingangswert Triggere" passiert nichts in der DP struktur
                        • mickym
                          @dos1973 Das ist klar - ist doch hinten deaktiviert. Wie gesagt mach einfach den Punkt raus an dem Originalflow den Du schon hast.
                            @mickym
                            ja, habs zu spät gesehen 🙂
                            • mickym
                              @dos1973
                              Das sollte aber hinhauen. Wie gesagt vorher war nur der Punkt zuviel
                                @mickym
                                das ist jetzt der neue flow.
                                es passt aber nicht??
                                • mickym
                                  @dos1973 Klemm bitte nochmal die iobroker out Node ab. Lösche bitte in den Objekten nochmal den Baum Shelly-BLE-Geräte und poste nun die Einzelnachrichten im Debugfenster. Vielleicht auch den Browser refreshen -
                                    @mickym
                                    mach icg gleich.
                                    aber schau mal hier.
                                    ich triggere das manuell und das kommt an. hier fehlt do schon die mac als übergeordneter folder
                                    • mickym
                                      @dos1973 Oh ich sehe - mein Fehler - ich bin heute anscheinend nicht fit.
                                        @mickym
                                        • mickym
                                          So nun kommen bei mir aber die topics mit der mac Adresse raus:
                                          Also das Ganze nochmal zum Import - erst mit der Inject Node testen:
                                                 "type": "inject",
                                                 "props": [
                                                         "p": "input",
                                                         "vt": "json"
                                                 "repeat": "",
                                                 "crontab": "",
                                                 "once": false,
                                                 "onceDelay": 0.1,
                                                 "topic": "",
                                                 "x": 180,
                                                 "y": 780,
                                                 "wires": [
                                                         "9ac0c724ea2285d2",
                                                         "71622aabe05c1ac5"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "move",
                                                         "pt": "msg",
                                                         "tot": "msg"
                                                         "t": "move",
                                                         "p": "input.src",
                                                         "pt": "msg",
                                                         "to": "src",
                                                         "tot": "msg"
                                                         "t": "move",
                                                         "pt": "msg",
                                                         "to": "srcBle",
                                                         "tot": "msg"
                                                         "t": "move",
                                                         "pt": "msg",
                                                         "to": "payload",
                                                         "tot": "msg"
                                                         "t": "delete",
                                                         "p": "input",
                                                         "pt": "msg"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 410,
                                                 "y": 780,
                                                 "wires": [
                                                         "dbf5c78009b4f581",
                                                         "f19cc6f7778c2633"
                                                 "type": "debug",
                                                 "active": false,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "complete": "true",
                                                 "statusVal": "",
                                                 "x": 370,
                                                 "y": 740,
                                                 "wires": []
                                                 "type": "debug",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "complete": "true",
                                                 "statusVal": "",
                                                 "x": 620,
                                                 "y": 740,
                                                 "wires": []
                                                 "type": "split",
                                                 "splt": "\\n",
                                                 "spltType": "str",
                                                 "arraySplt": 1,
                                                 "stream": false,
                                                 "addname": "topic",
                                                 "x": 790,
                                                 "y": 840,
                                                 "wires": [
                                                         "4e6bbe32dfcc7c5d"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "change",
                                                         "p": "srcBle.mac",
                                                         "pt": "msg",
                                                         "from": ":",
                                                         "fromt": "str",
                                                         "to": "-",
                                                         "tot": "str"
                                                         "t": "set",
                                                         "p": "srcBle",
                                                         "pt": "msg",
                                                         "tot": "jsonata"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 240,
                                                 "y": 840,
                                                 "wires": [
                                                         "c1cac0b6dc174190"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "delete",
                                                         "pt": "msg"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 490,
                                                 "y": 840,
                                                 "wires": [
                                                         "831875c3be845a77"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "topic",
                                                         "pt": "msg",
                                                         "tot": "jsonata"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1030,
                                                 "y": 840,
                                                 "wires": [
                                                         "15bab36dddd209ed",
                                                         "474c1b7582b85047"
                                                 "type": "debug",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 1230,
                                                 "y": 800,
                                                 "wires": []
                                                 "topic": "",
                                                 "ack": "true",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1220,
                                                 "y": 840,
                                                 "wires": []
                                          • mickym
                                            Und wenn es mit der Inject Node geht und mit den Nachrichten aus dem mqtt-In Node nicht - dann bitte mal genau schauen ,ob Du noch Unterschiede im konstruierten Nachrichtenobjekt mit der Inject Node und der aus der mqtt-In Node feststellen kannst.
                                            2829
