    4. Node-Red
    5. Node Red DP erstellen
    • mickym
      Ich denke ich habe den Fehler gefunden:
      da muss der Punkt raus - sorry war schlampig meinerseits
      FALLS NICHT DANN
      ... bitte diesen ganzen Flow importieren und bestätigen erstmal, dass nun das konstruierte Eingangsobjekt genauso wie Deine Nachrichten aussehen:
      Also mit der Inject Node testen.
      Wenn das so ist dann kannst Du vor die 2. Reihe Deine mqtt-In klemmen
             "id": "85395d3e7d299c24",
             "type": "inject",
             "z": "517cd16e4d7e6ae4",
             "name": "Eingangswerte",
             "props": [
                     "p": "input",
                     "v": "{\"scriptVersion\":\"0.1\",\"src\":\"shellies/Pro3_EM\",\"srcBle\":{\"mac\":\"b4:35:22:fe:56:ad\"},\"payload\":{\"encryption\":false,\"BTHome_version\":2,\"pid\":253,\"battery\":100,\"button\":2,\"rssi\":-79,\"address\":\"b4:35:22:fe:56:ad\"}}",
                     "vt": "json"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "x": 180,
             "y": 780,
             "wires": [
                     "9ac0c724ea2285d2",
                     "71622aabe05c1ac5"
             "id": "9ac0c724ea2285d2",
             "type": "change",
             "name": "konstruiere OriginalObjekt",
             "rules": [
                     "t": "move",
                     "p": "input.scriptVersion",
                     "pt": "msg",
                     "to": "scriptVersion",
                     "tot": "msg"
                     "t": "move",
                     "p": "input.src",
                     "pt": "msg",
                     "to": "src",
                     "tot": "msg"
                     "t": "set",
                     "p": "input.srcBle",
                     "pt": "msg",
                     "to": "srcBle",
                     "tot": "msg"
                     "t": "move",
                     "p": "input.payload",
                     "pt": "msg",
                     "to": "payload",
                     "tot": "msg"
                     "t": "delete",
                     "p": "input",
                     "pt": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 410,
             "y": 780,
             "wires": [
                     "dbf5c78009b4f581",
                     "f19cc6f7778c2633"
             "id": "71622aabe05c1ac5",
             "type": "debug",
             "name": "Eingabewert",
             "active": false,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "true",
             "targetType": "full",
             "statusVal": "",
             "statusType": "auto",
             "x": 370,
             "y": 740,
             "wires": []
             "id": "dbf5c78009b4f581",
             "type": "debug",
             "name": "Originalobjekt",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "true",
             "statusVal": "",
             "x": 620,
             "y": 740,
             "wires": []
             "id": "831875c3be845a77",
             "type": "split",
             "name": "teile Objekt in Einzelnachrichten",
             "splt": "\\n",
             "spltType": "str",
             "arraySplt": 1,
             "arraySpltType": "len",
             "stream": false,
             "addname": "topic",
             "x": 790,
             "y": 840,
             "wires": [
                     "4e6bbe32dfcc7c5d"
             "id": "f19cc6f7778c2633",
             "type": "change",
             "name": "Ändere srcBle",
             "rules": [
                     "t": "change",
                     "p": "srcBle.mac",
                     "pt": "msg",
                     "from": ":",
                     "fromt": "str",
                     "to": "-",
                     "tot": "str"
                     "t": "set",
                     "p": "srcBle",
                     "pt": "msg",
                     "to": "\"0_userdata.0.Wohnung.Status.Shelly.Shelly-BLE-Geraete\" & srcBle.mac",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 240,
             "y": 840,
             "wires": [
                     "c1cac0b6dc174190"
             "id": "c1cac0b6dc174190",
             "type": "change",
             "name": "Entferne payload-Eigenschaften",
             "rules": [
                     "t": "delete",
                     "p": "payload.address",
                     "pt": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 490,
             "y": 840,
             "wires": [
                     "831875c3be845a77"
             "id": "4e6bbe32dfcc7c5d",
             "type": "change",
             "name": "erstelle topic",
             "rules": [
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "to": "srcBle & \".\" & topic",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1030,
             "y": 840,
             "wires": [
                     "15bab36dddd209ed",
                     "474c1b7582b85047"
             "id": "474c1b7582b85047",
             "type": "debug",
             "name": "Einzelnachrichten",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "payload",
             "targetType": "msg",
             "statusVal": "",
             "x": 1230,
             "y": 800,
             "wires": []
             "id": "15bab36dddd209ed",
             "type": "ioBroker out",
             "d": true,
             "name": "schreibe Werte",
             "topic": "",
             "ack": "true",
             "autoCreate": "true",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "false",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 1220,
             "y": 840,
             "wires": []
        dos1973 @mickym last edited by
        @mickym
        wenn ich den "Eingangswert Triggere" passiert nichts in der DP struktur
        • mickym
          mickym Most Active @dos1973 last edited by
          @dos1973 Das ist klar - ist doch hinten deaktiviert. Wie gesagt mach einfach den Punkt raus an dem Originalflow den Du schon hast.
            @mickym
            ja, habs zu spät gesehen 🙂
            • mickym
              mickym Most Active @dos1973 last edited by mickym
              @dos1973
              Das sollte aber hinhauen. Wie gesagt vorher war nur der Punkt zuviel
                @mickym
                das ist jetzt der neue flow.
                es passt aber nicht??
                • mickym
                  @dos1973 Klemm bitte nochmal die iobroker out Node ab. Lösche bitte in den Objekten nochmal den Baum Shelly-BLE-Geräte und poste nun die Einzelnachrichten im Debugfenster. Vielleicht auch den Browser refreshen -
                    @mickym
                    mach icg gleich.
                    aber schau mal hier.
                    ich triggere das manuell und das kommt an. hier fehlt do schon die mac als übergeordneter folder
                    • mickym
                      @dos1973 Oh ich sehe - mein Fehler - ich bin heute anscheinend nicht fit.
                        @mickym
                        • mickym
                          So nun kommen bei mir aber die topics mit der mac Adresse raus:
                          Also das Ganze nochmal zum Import - erst mit der Inject Node testen:
                                 "type": "inject",
                                 "props": [
                                         "p": "input",
                                         "vt": "json"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "x": 180,
                                 "y": 780,
                                 "wires": [
                                         "9ac0c724ea2285d2",
                                         "71622aabe05c1ac5"
                                 "type": "change",
                                 "rules": [
                                         "t": "move",
                                         "pt": "msg",
                                         "tot": "msg"
                                         "t": "move",
                                         "p": "input.src",
                                         "pt": "msg",
                                         "to": "src",
                                         "tot": "msg"
                                         "t": "move",
                                         "pt": "msg",
                                         "to": "srcBle",
                                         "tot": "msg"
                                         "t": "move",
                                         "pt": "msg",
                                         "to": "payload",
                                         "tot": "msg"
                                         "t": "delete",
                                         "p": "input",
                                         "pt": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 410,
                                 "y": 780,
                                 "wires": [
                                         "dbf5c78009b4f581",
                                         "f19cc6f7778c2633"
                                 "type": "debug",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "complete": "true",
                                 "statusVal": "",
                                 "x": 370,
                                 "y": 740,
                                 "wires": []
                                 "type": "debug",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "complete": "true",
                                 "statusVal": "",
                                 "x": 620,
                                 "y": 740,
                                 "wires": []
                                 "type": "split",
                                 "splt": "\\n",
                                 "spltType": "str",
                                 "arraySplt": 1,
                                 "stream": false,
                                 "addname": "topic",
                                 "x": 790,
                                 "y": 840,
                                 "wires": [
                                         "4e6bbe32dfcc7c5d"
                                 "type": "change",
                                 "rules": [
                                         "t": "change",
                                         "p": "srcBle.mac",
                                         "pt": "msg",
                                         "from": ":",
                                         "fromt": "str",
                                         "to": "-",
                                         "tot": "str"
                                         "t": "set",
                                         "p": "srcBle",
                                         "pt": "msg",
                                         "to": "\"0_userdata.0.Wohnung.Status.Shelly.Shelly-BLE-Geraete.\" & srcBle.mac",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 240,
                                 "y": 840,
                                 "wires": [
                                         "c1cac0b6dc174190"
                                 "type": "change",
                                 "rules": [
                                         "t": "delete",
                                         "pt": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 490,
                                 "y": 840,
                                 "wires": [
                                         "831875c3be845a77"
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1030,
                                 "y": 840,
                                 "wires": [
                                         "15bab36dddd209ed",
                                         "474c1b7582b85047"
                                 "type": "debug",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1230,
                                 "y": 800,
                                 "wires": []
                                 "topic": "",
                                 "ack": "true",
                                 "stateName": "",
                                 "role": "",
                                 "payloadType": "",
                                 "stateUnit": "",
                                 "stateMin": "",
                                 "stateMax": "",
                                 "x": 1220,
                                 "y": 840,
                                 "wires": []
                          • mickym
                            Und wenn es mit der Inject Node geht und mit den Nachrichten aus dem mqtt-In Node nicht - dann bitte mal genau schauen ,ob Du noch Unterschiede im konstruierten Nachrichtenobjekt mit der Inject Node und der aus der mqtt-In Node feststellen kannst.
                              @mickym
                              ja mit inject gehts, mit der nachrichten nicht
                              der untere ist mit inject, der obere mit der nachricht
                              • mickym
                                @dos1973 Ah ich sehe schon das ganze ist ein payload Objekt - OK ich ändere es wird einfacher.
                                Ich dachte Du hättest mir das komplette Nachrichtenobjekt kopiert. Na dann wird es einfacher - warte ich stelle um .....
                                Ich weiß ich müsste genauer hinschauen - aber ist einfach schwierig. 😉 Sorry, sorry.
                                • mickym
                                  mickym Most Active @mickym last edited by mickym
                                  So nun sollte es aber:
                                  Hier ein neuer Import. Ich hoffe nun habe ich alles gesehen. Es war wohl eine payload in der payload.
                                         "type": "inject",
                                         "props": [
                                                 "p": "payload"
                                         "repeat": "",
                                         "crontab": "",
                                         "once": false,
                                         "onceDelay": 0.1,
                                         "topic": "",
                                         "payload": "{\"scriptVersion\":\"0.1\",\"src\":\"shellies/Pro3_EM\",\"srcBle\":{\"mac\":\"b4:35:22:fe:56:ad\"},\"payload\":{\"encryption\":false,\"BTHome_version\":2,\"pid\":253,\"battery\":100,\"button\":2,\"rssi\":-79,\"address\":\"b4:35:22:fe:56:ad\"}}",
                                         "payloadType": "json",
                                         "x": 140,
                                         "y": 740,
                                         "wires": [
                                                 "c7792c25c96d976f",
                                                 "f19cc6f7778c2633"
                                         "type": "split",
                                         "splt": "\\n",
                                         "spltType": "str",
                                         "arraySplt": 1,
                                         "stream": false,
                                         "addname": "topic",
                                         "x": 970,
                                         "y": 800,
                                         "wires": [
                                                 "4e6bbe32dfcc7c5d"
                                         "type": "change",
                                         "name": "Ändere srcBle und payload",
                                         "rules": [
                                                 "t": "move",
                                                 "p": "payload.srcBle.mac",
                                                 "pt": "msg",
                                                 "to": "srcBle",
                                                 "tot": "msg"
                                                 "t": "change",
                                                 "p": "srcBle",
                                                 "pt": "msg",
                                                 "from": ":",
                                                 "fromt": "str",
                                                 "to": "-",
                                                 "tot": "str"
                                                 "t": "set",
                                                 "p": "srcBle",
                                                 "pt": "msg",
                                                 "to": "\"0_userdata.0.Wohnung.Status.Shelly.Shelly-BLE-Geraete.\" & srcBle",
                                                 "tot": "jsonata"
                                                 "t": "set",
                                                 "p": "payload",
                                                 "pt": "msg",
                                                 "to": "payload.payload",
                                                 "tot": "msg"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 380,
                                         "y": 800,
                                         "wires": [
                                                 "c1cac0b6dc174190"
                                         "type": "change",
                                         "rules": [
                                                 "t": "delete",
                                                 "pt": "msg"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 670,
                                         "y": 800,
                                         "wires": [
                                                 "831875c3be845a77"
                                         "type": "change",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "topic",
                                                 "pt": "msg",
                                                 "tot": "jsonata"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 1210,
                                         "y": 800,
                                         "wires": [
                                                 "15bab36dddd209ed",
                                                 "474c1b7582b85047"
                                         "type": "debug",
                                         "active": true,
                                         "tosidebar": true,
                                         "console": false,
                                         "tostatus": false,
                                         "statusVal": "",
                                         "x": 1430,
                                         "y": 740,
                                         "wires": []
                                         "topic": "",
                                         "ack": "true",
                                         "stateName": "",
                                         "role": "",
                                         "payloadType": "",
                                         "stateUnit": "",
                                         "stateMin": "",
                                         "stateMax": "",
                                         "x": 1420,
                                         "y": 800,
                                         "wires": []
                                         "id": "c7792c25c96d976f",
                                         "type": "debug",
                                         "name": "Eingangs-payload",
                                         "active": true,
                                         "tosidebar": true,
                                         "console": false,
                                         "tostatus": false,
                                         "statusVal": "",
                                         "x": 370,
                                         "y": 740,
                                         "wires": []
                                    dos1973 @mickym last edited by dos1973
                                    @mickym
                                    yes! schaut gut aus.
                                    das sind bereits 2 verschiedene Geräte
                                    • mickym
                                      @dos1973 Ok - ja sorry, sorry. - Aber Du siehst der Flow ist oft weniger entscheidend - man muss die richtigen Daten mit einer Inject-Node nachbilden können, um den Flow richtig zu machen. Kannst Du Dir ja wieder im Detail anschauen und wenn Du Fragen hast, warum was und wie - dann sprechen wir jede einzelne Node durch.
                                        @mickym
                                        ich beobacte das ganze mal. wie immer eine riese Danke für deine Hilfe und Geduld.
                                        • mickym
                                          @dos1973 Ja und entschuldige meine Schlampigkeit. Und wie gesagt, wenn Du so was selbst machen willst, dann frag einfach, warum was und wie.
                                          2827
