    4. Node-Red
    5. Node Red DP erstellen
      dos1973 @mickym last edited by
      @mickym
      mach icg gleich.
      aber schau mal hier.
      ich triggere das manuell und das kommt an. hier fehlt do schon die mac als übergeordneter folder
      • mickym
        mickym Most Active @dos1973 last edited by
        @dos1973 Oh ich sehe - mein Fehler - ich bin heute anscheinend nicht fit.
          @mickym
          • mickym
            So nun kommen bei mir aber die topics mit der mac Adresse raus:
            Also das Ganze nochmal zum Import - erst mit der Inject Node testen:
                   "id": "85395d3e7d299c24",
                   "type": "inject",
                   "z": "517cd16e4d7e6ae4",
                   "name": "Eingangswerte",
                   "props": [
                           "p": "input",
                           "v": "{\"scriptVersion\":\"0.1\",\"src\":\"shellies/Pro3_EM\",\"srcBle\":{\"mac\":\"b4:35:22:fe:56:ad\"},\"payload\":{\"encryption\":false,\"BTHome_version\":2,\"pid\":253,\"battery\":100,\"button\":2,\"rssi\":-79,\"address\":\"b4:35:22:fe:56:ad\"}}",
                           "vt": "json"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "x": 180,
                   "y": 780,
                   "wires": [
                           "9ac0c724ea2285d2",
                           "71622aabe05c1ac5"
                   "id": "9ac0c724ea2285d2",
                   "type": "change",
                   "name": "konstruiere OriginalObjekt",
                   "rules": [
                           "t": "move",
                           "p": "input.scriptVersion",
                           "pt": "msg",
                           "to": "scriptVersion",
                           "tot": "msg"
                           "t": "move",
                           "p": "input.src",
                           "pt": "msg",
                           "to": "src",
                           "tot": "msg"
                           "t": "move",
                           "p": "input.srcBle",
                           "pt": "msg",
                           "to": "srcBle",
                           "tot": "msg"
                           "t": "move",
                           "p": "input.payload",
                           "pt": "msg",
                           "to": "payload",
                           "tot": "msg"
                           "t": "delete",
                           "p": "input",
                           "pt": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 410,
                   "y": 780,
                   "wires": [
                           "dbf5c78009b4f581",
                           "f19cc6f7778c2633"
                   "id": "71622aabe05c1ac5",
                   "type": "debug",
                   "name": "Eingabewert",
                   "active": false,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "complete": "true",
                   "targetType": "full",
                   "statusVal": "",
                   "statusType": "auto",
                   "x": 370,
                   "y": 740,
                   "wires": []
                   "id": "dbf5c78009b4f581",
                   "type": "debug",
                   "name": "Originalobjekt",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "complete": "true",
                   "statusVal": "",
                   "x": 620,
                   "y": 740,
                   "wires": []
                   "id": "831875c3be845a77",
                   "type": "split",
                   "name": "teile Objekt in Einzelnachrichten",
                   "splt": "\\n",
                   "spltType": "str",
                   "arraySplt": 1,
                   "arraySpltType": "len",
                   "stream": false,
                   "addname": "topic",
                   "x": 790,
                   "y": 840,
                   "wires": [
                           "4e6bbe32dfcc7c5d"
                   "id": "f19cc6f7778c2633",
                   "type": "change",
                   "name": "Ändere srcBle",
                   "rules": [
                           "t": "change",
                           "p": "srcBle.mac",
                           "pt": "msg",
                           "from": ":",
                           "fromt": "str",
                           "to": "-",
                           "tot": "str"
                           "t": "set",
                           "p": "srcBle",
                           "pt": "msg",
                           "to": "\"0_userdata.0.Wohnung.Status.Shelly.Shelly-BLE-Geraete.\" & srcBle.mac",
                           "tot": "jsonata"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 240,
                   "y": 840,
                   "wires": [
                           "c1cac0b6dc174190"
                   "id": "c1cac0b6dc174190",
                   "type": "change",
                   "name": "Entferne payload-Eigenschaften",
                   "rules": [
                           "t": "delete",
                           "p": "payload.address",
                           "pt": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 490,
                   "y": 840,
                   "wires": [
                           "831875c3be845a77"
                   "id": "4e6bbe32dfcc7c5d",
                   "type": "change",
                   "name": "erstelle topic",
                   "rules": [
                           "t": "set",
                           "p": "topic",
                           "pt": "msg",
                           "to": "srcBle & \".\" & topic",
                           "tot": "jsonata"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1030,
                   "y": 840,
                   "wires": [
                           "15bab36dddd209ed",
                           "474c1b7582b85047"
                   "id": "474c1b7582b85047",
                   "type": "debug",
                   "name": "Einzelnachrichten",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "complete": "payload",
                   "targetType": "msg",
                   "statusVal": "",
                   "x": 1230,
                   "y": 800,
                   "wires": []
                   "id": "15bab36dddd209ed",
                   "type": "ioBroker out",
                   "name": "schreibe Werte",
                   "topic": "",
                   "ack": "true",
                   "autoCreate": "true",
                   "stateName": "",
                   "role": "",
                   "payloadType": "",
                   "readonly": "false",
                   "stateUnit": "",
                   "stateMin": "",
                   "stateMax": "",
                   "x": 1220,
                   "y": 840,
                   "wires": []
            • mickym
              Und wenn es mit der Inject Node geht und mit den Nachrichten aus dem mqtt-In Node nicht - dann bitte mal genau schauen ,ob Du noch Unterschiede im konstruierten Nachrichtenobjekt mit der Inject Node und der aus der mqtt-In Node feststellen kannst.
                @mickym
                ja mit inject gehts, mit der nachrichten nicht
                der untere ist mit inject, der obere mit der nachricht
                • mickym
                  mickym Most Active @dos1973 last edited by mickym
                  @dos1973 Ah ich sehe schon das ganze ist ein payload Objekt - OK ich ändere es wird einfacher.
                  Ich dachte Du hättest mir das komplette Nachrichtenobjekt kopiert. Na dann wird es einfacher - warte ich stelle um .....
                  Ich weiß ich müsste genauer hinschauen - aber ist einfach schwierig. 😉 Sorry, sorry.
                  • mickym
                    mickym Most Active @mickym last edited by mickym
                    So nun sollte es aber:
                    Hier ein neuer Import. Ich hoffe nun habe ich alles gesehen. Es war wohl eine payload in der payload.
                           "type": "inject",
                           "props": [
                                   "p": "payload"
                           "repeat": "",
                           "crontab": "",
                           "once": false,
                           "onceDelay": 0.1,
                           "topic": "",
                           "payload": "{\"scriptVersion\":\"0.1\",\"src\":\"shellies/Pro3_EM\",\"srcBle\":{\"mac\":\"b4:35:22:fe:56:ad\"},\"payload\":{\"encryption\":false,\"BTHome_version\":2,\"pid\":253,\"battery\":100,\"button\":2,\"rssi\":-79,\"address\":\"b4:35:22:fe:56:ad\"}}",
                           "payloadType": "json",
                           "x": 140,
                           "y": 740,
                           "wires": [
                                   "c7792c25c96d976f",
                                   "f19cc6f7778c2633"
                           "type": "split",
                           "splt": "\\n",
                           "spltType": "str",
                           "arraySplt": 1,
                           "stream": false,
                           "addname": "topic",
                           "x": 970,
                           "y": 800,
                           "wires": [
                                   "4e6bbe32dfcc7c5d"
                           "type": "change",
                           "name": "Ändere srcBle und payload",
                           "rules": [
                                   "t": "move",
                                   "p": "payload.srcBle.mac",
                                   "pt": "msg",
                                   "to": "srcBle",
                                   "tot": "msg"
                                   "t": "change",
                                   "p": "srcBle",
                                   "pt": "msg",
                                   "from": ":",
                                   "fromt": "str",
                                   "to": "-",
                                   "tot": "str"
                                   "t": "set",
                                   "p": "srcBle",
                                   "pt": "msg",
                                   "to": "\"0_userdata.0.Wohnung.Status.Shelly.Shelly-BLE-Geraete.\" & srcBle",
                                   "tot": "jsonata"
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "to": "payload.payload",
                                   "tot": "msg"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 380,
                           "y": 800,
                           "wires": [
                                   "c1cac0b6dc174190"
                           "type": "change",
                           "rules": [
                                   "t": "delete",
                                   "pt": "msg"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 670,
                           "y": 800,
                           "wires": [
                                   "831875c3be845a77"
                           "type": "change",
                           "rules": [
                                   "t": "set",
                                   "p": "topic",
                                   "pt": "msg",
                                   "tot": "jsonata"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 1210,
                           "y": 800,
                           "wires": [
                                   "15bab36dddd209ed",
                                   "474c1b7582b85047"
                           "type": "debug",
                           "active": true,
                           "tosidebar": true,
                           "console": false,
                           "tostatus": false,
                           "statusVal": "",
                           "x": 1430,
                           "y": 740,
                           "wires": []
                           "topic": "",
                           "ack": "true",
                           "stateName": "",
                           "role": "",
                           "payloadType": "",
                           "stateUnit": "",
                           "stateMin": "",
                           "stateMax": "",
                           "x": 1420,
                           "y": 800,
                           "wires": []
                           "id": "c7792c25c96d976f",
                           "type": "debug",
                           "name": "Eingangs-payload",
                           "active": true,
                           "tosidebar": true,
                           "console": false,
                           "tostatus": false,
                           "statusVal": "",
                           "x": 370,
                           "y": 740,
                           "wires": []
                      dos1973 @mickym last edited by dos1973
                      @mickym
                      yes! schaut gut aus.
                      das sind bereits 2 verschiedene Geräte
                      • mickym
                        @dos1973 Ok - ja sorry, sorry. - Aber Du siehst der Flow ist oft weniger entscheidend - man muss die richtigen Daten mit einer Inject-Node nachbilden können, um den Flow richtig zu machen. Kannst Du Dir ja wieder im Detail anschauen und wenn Du Fragen hast, warum was und wie - dann sprechen wir jede einzelne Node durch.
                          @mickym
                          ich beobacte das ganze mal. wie immer eine riese Danke für deine Hilfe und Geduld.
                          • mickym
                            @dos1973 Ja und entschuldige meine Schlampigkeit. Und wie gesagt, wenn Du so was selbst machen willst, dann frag einfach, warum was und wie.
                            2827
