    4. Node-Red
    5. Node Red DP erstellen
      dos1973 @mickym last edited by
      @mickym
      • mickym
        So nun kommen bei mir aber die topics mit der mac Adresse raus:
        Also das Ganze nochmal zum Import - erst mit der Inject Node testen:
               "id": "85395d3e7d299c24",
               "type": "inject",
               "z": "517cd16e4d7e6ae4",
               "name": "Eingangswerte",
               "props": [
                       "p": "input",
                       "v": "{\"scriptVersion\":\"0.1\",\"src\":\"shellies/Pro3_EM\",\"srcBle\":{\"mac\":\"b4:35:22:fe:56:ad\"},\"payload\":{\"encryption\":false,\"BTHome_version\":2,\"pid\":253,\"battery\":100,\"button\":2,\"rssi\":-79,\"address\":\"b4:35:22:fe:56:ad\"}}",
                       "vt": "json"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "x": 180,
               "y": 780,
               "wires": [
                       "9ac0c724ea2285d2",
                       "71622aabe05c1ac5"
               "id": "9ac0c724ea2285d2",
               "type": "change",
               "name": "konstruiere OriginalObjekt",
               "rules": [
                       "t": "move",
                       "p": "input.scriptVersion",
                       "pt": "msg",
                       "to": "scriptVersion",
                       "tot": "msg"
                       "t": "move",
                       "p": "input.src",
                       "pt": "msg",
                       "to": "src",
                       "tot": "msg"
                       "t": "move",
                       "p": "input.srcBle",
                       "pt": "msg",
                       "to": "srcBle",
                       "tot": "msg"
                       "t": "move",
                       "p": "input.payload",
                       "pt": "msg",
                       "to": "payload",
                       "tot": "msg"
                       "t": "delete",
                       "p": "input",
                       "pt": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 410,
               "y": 780,
               "wires": [
                       "dbf5c78009b4f581",
                       "f19cc6f7778c2633"
               "id": "71622aabe05c1ac5",
               "type": "debug",
               "name": "Eingabewert",
               "active": false,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "complete": "true",
               "targetType": "full",
               "statusVal": "",
               "statusType": "auto",
               "x": 370,
               "y": 740,
               "wires": []
               "id": "dbf5c78009b4f581",
               "type": "debug",
               "name": "Originalobjekt",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "complete": "true",
               "statusVal": "",
               "x": 620,
               "y": 740,
               "wires": []
               "id": "831875c3be845a77",
               "type": "split",
               "name": "teile Objekt in Einzelnachrichten",
               "splt": "\\n",
               "spltType": "str",
               "arraySplt": 1,
               "arraySpltType": "len",
               "stream": false,
               "addname": "topic",
               "x": 790,
               "y": 840,
               "wires": [
                       "4e6bbe32dfcc7c5d"
               "id": "f19cc6f7778c2633",
               "type": "change",
               "name": "Ändere srcBle",
               "rules": [
                       "t": "change",
                       "p": "srcBle.mac",
                       "pt": "msg",
                       "from": ":",
                       "fromt": "str",
                       "to": "-",
                       "tot": "str"
                       "t": "set",
                       "p": "srcBle",
                       "pt": "msg",
                       "to": "\"0_userdata.0.Wohnung.Status.Shelly.Shelly-BLE-Geraete.\" & srcBle.mac",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 240,
               "y": 840,
               "wires": [
                       "c1cac0b6dc174190"
               "id": "c1cac0b6dc174190",
               "type": "change",
               "name": "Entferne payload-Eigenschaften",
               "rules": [
                       "t": "delete",
                       "p": "payload.address",
                       "pt": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 490,
               "y": 840,
               "wires": [
                       "831875c3be845a77"
               "id": "4e6bbe32dfcc7c5d",
               "type": "change",
               "name": "erstelle topic",
               "rules": [
                       "t": "set",
                       "p": "topic",
                       "pt": "msg",
                       "to": "srcBle & \".\" & topic",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1030,
               "y": 840,
               "wires": [
                       "15bab36dddd209ed",
                       "474c1b7582b85047"
               "id": "474c1b7582b85047",
               "type": "debug",
               "name": "Einzelnachrichten",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "complete": "payload",
               "targetType": "msg",
               "statusVal": "",
               "x": 1230,
               "y": 800,
               "wires": []
               "id": "15bab36dddd209ed",
               "type": "ioBroker out",
               "name": "schreibe Werte",
               "topic": "",
               "ack": "true",
               "autoCreate": "true",
               "stateName": "",
               "role": "",
               "payloadType": "",
               "readonly": "false",
               "stateUnit": "",
               "stateMin": "",
               "stateMax": "",
               "x": 1220,
               "y": 840,
               "wires": []
        • mickym
          Und wenn es mit der Inject Node geht und mit den Nachrichten aus dem mqtt-In Node nicht - dann bitte mal genau schauen ,ob Du noch Unterschiede im konstruierten Nachrichtenobjekt mit der Inject Node und der aus der mqtt-In Node feststellen kannst.
            @mickym
            ja mit inject gehts, mit der nachrichten nicht
            der untere ist mit inject, der obere mit der nachricht
            • mickym
              mickym Most Active @dos1973 last edited by mickym
              @dos1973 Ah ich sehe schon das ganze ist ein payload Objekt - OK ich ändere es wird einfacher.
              Ich dachte Du hättest mir das komplette Nachrichtenobjekt kopiert. Na dann wird es einfacher - warte ich stelle um .....
              Ich weiß ich müsste genauer hinschauen - aber ist einfach schwierig. 😉 Sorry, sorry.
              • mickym
                mickym Most Active @mickym last edited by mickym
                So nun sollte es aber:
                Hier ein neuer Import. Ich hoffe nun habe ich alles gesehen. Es war wohl eine payload in der payload.
                       "type": "inject",
                       "props": [
                               "p": "payload"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "{\"scriptVersion\":\"0.1\",\"src\":\"shellies/Pro3_EM\",\"srcBle\":{\"mac\":\"b4:35:22:fe:56:ad\"},\"payload\":{\"encryption\":false,\"BTHome_version\":2,\"pid\":253,\"battery\":100,\"button\":2,\"rssi\":-79,\"address\":\"b4:35:22:fe:56:ad\"}}",
                       "payloadType": "json",
                       "x": 140,
                       "y": 740,
                       "wires": [
                               "c7792c25c96d976f",
                               "f19cc6f7778c2633"
                       "type": "split",
                       "splt": "\\n",
                       "spltType": "str",
                       "arraySplt": 1,
                       "stream": false,
                       "addname": "topic",
                       "x": 970,
                       "y": 800,
                       "wires": [
                               "4e6bbe32dfcc7c5d"
                       "type": "change",
                       "name": "Ändere srcBle und payload",
                       "rules": [
                               "t": "move",
                               "p": "payload.srcBle.mac",
                               "pt": "msg",
                               "to": "srcBle",
                               "tot": "msg"
                               "t": "change",
                               "p": "srcBle",
                               "pt": "msg",
                               "from": ":",
                               "fromt": "str",
                               "to": "-",
                               "tot": "str"
                               "t": "set",
                               "p": "srcBle",
                               "pt": "msg",
                               "to": "\"0_userdata.0.Wohnung.Status.Shelly.Shelly-BLE-Geraete.\" & srcBle",
                               "tot": "jsonata"
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "payload.payload",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 380,
                       "y": 800,
                       "wires": [
                               "c1cac0b6dc174190"
                       "type": "change",
                       "rules": [
                               "t": "delete",
                               "pt": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 670,
                       "y": 800,
                       "wires": [
                               "831875c3be845a77"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "topic",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1210,
                       "y": 800,
                       "wires": [
                               "15bab36dddd209ed",
                               "474c1b7582b85047"
                       "type": "debug",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1430,
                       "y": 740,
                       "wires": []
                       "topic": "",
                       "ack": "true",
                       "stateName": "",
                       "role": "",
                       "payloadType": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 1420,
                       "y": 800,
                       "wires": []
                       "id": "c7792c25c96d976f",
                       "type": "debug",
                       "name": "Eingangs-payload",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 370,
                       "y": 740,
                       "wires": []
                  dos1973 @mickym last edited by dos1973
                  @mickym
                  yes! schaut gut aus.
                  das sind bereits 2 verschiedene Geräte
                  • mickym
                    @dos1973 Ok - ja sorry, sorry. - Aber Du siehst der Flow ist oft weniger entscheidend - man muss die richtigen Daten mit einer Inject-Node nachbilden können, um den Flow richtig zu machen. Kannst Du Dir ja wieder im Detail anschauen und wenn Du Fragen hast, warum was und wie - dann sprechen wir jede einzelne Node durch.
                      @mickym
                      ich beobacte das ganze mal. wie immer eine riese Danke für deine Hilfe und Geduld.
                      • mickym
                        @dos1973 Ja und entschuldige meine Schlampigkeit. Und wie gesagt, wenn Du so was selbst machen willst, dann frag einfach, warum was und wie.
                        2827
